[GRASS-SVN] r32893 - grass/trunk/lib/vector/Vlib
Tue Aug 19 10:15:12 EDT 2008
Author: martinl
Date: 2008-08-19 10:15:12 -0400 (Tue, 19 Aug 2008)
New Revision: 32893
   grass/trunk/lib/vector/Vlib/find.c
Vlib: bugfix in Vect_find_line_list() -- don't check cur_dist
(merge from devbr6, r32892)
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c	2008-08-19 14:12:53 UTC (rev 32892)
+++ grass/trunk/lib/vector/Vlib/find.c	2008-08-19 14:15:12 UTC (rev 32893)
@@ -209,11 +209,12 @@
 	Vect_line_distance(Points, ux, uy, uz, with_z, NULL, NULL, NULL,
 			   &new_dist, NULL, NULL);
 	G_debug(3, " line = %d distance = %f", line, new_dist);
+	if (found && new_dist <= maxdist) {
+	    Vect_list_append(found, line);
 	if ((++gotone == 1) || (new_dist <= cur_dist)) {
-	    if (found) {
-		Vect_list_append(found, line);
 	    if (new_dist == cur_dist) {
 		/* TODO */
 		/* choice = dig_center_check (map->Line, choice, a, ux, uy); */
