[GRASS-SVN] r32934 - grass/branches/develbranch_6/vector/v.in.ascii
Wed Aug 20 15:36:08 EDT 2008
Author: martinl
Date: 2008-08-20 15:36:08 -0400 (Wed, 20 Aug 2008)
New Revision: 32934
   grass/branches/develbranch_6/vector/v.in.ascii/in.c
v.in.ascii: don't use G_OPT_COLUMNS for columns option
Modified: grass/branches/develbranch_6/vector/v.in.ascii/in.c
--- grass/branches/develbranch_6/vector/v.in.ascii/in.c	2008-08-20 19:30:57 UTC (rev 32933)
+++ grass/branches/develbranch_6/vector/v.in.ascii/in.c	2008-08-20 19:36:08 UTC (rev 32934)
@@ -80,7 +80,10 @@
     skip_opt->description =
 	_("Number of header lines to skip at top of input file (points mode)");
-    columns_opt = G_define_standard_option(G_OPT_COLUMNS);
+    columns_opt = G_define_option();
+    columns_opt->key = "columns";
+    columns_opt->type = TYPE_STRING;
+    columns_opt->required = NO;
     columns_opt->multiple = NO;
     columns_opt->guisection = _("Columns");
     columns_opt->label = _("Column definition in SQL style (points mode)");
