[GRASS-SVN] r32985 - grass-addons/gipe/i.biomass
Thu Aug 21 19:06:30 EDT 2008
Author: ychemin
Date: 2008-08-21 19:06:30 -0400 (Thu, 21 Aug 2008)
New Revision: 32985
   grass-addons/gipe/i.biomass/biomass.c
   grass-addons/gipe/i.biomass/main.c
   grass-addons/gipe/i.biomass/solar_day.c
GRASS GIS standard indentation parsing
Modified: grass-addons/gipe/i.biomass/biomass.c
--- grass-addons/gipe/i.biomass/biomass.c	2008-08-21 22:54:40 UTC (rev 32984)
+++ grass-addons/gipe/i.biomass/biomass.c	2008-08-21 23:06:30 UTC (rev 32985)
@@ -1,20 +1,21 @@
-#include<stdio.h>
-#include<math.h>
-#include<stdlib.h>
-double biomass( double fpar, double solar_day, double evap_fr, double light_use_ef )
-	double result, apar, conversion_coefs;
-	/*fPAR in Bastiaassen and Ali = a (= 1.257) * NDVI + b (= -0.161);*/
-	/*light use efficiency is variable for each crop!*/
-	/* Cotton light_use_ef in Uzbekistan is 1.9 */
-/*	apar 			= (b+a*ndvi);*/
-	conversion_coefs	= 0.0864*10;
-	apar			= fpar*(0.48*solar_day);
-	result 			= apar*light_use_ef*evap_fr*conversion_coefs;
-	return result;
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+ double biomass(double fpar, double solar_day, double evap_fr,
+		 double light_use_ef)
+    double result, apar, conversion_coefs;
+	/*fPAR in Bastiaassen and Ali = a (= 1.257) * NDVI + b (= -0.161); */
+	/*light use efficiency is variable for each crop! */
+	/* Cotton light_use_ef in Uzbekistan is 1.9 */
+	/*      apar                    = (b+a*ndvi); */
+	conversion_coefs = 0.0864 * 10;
+    apar = fpar * (0.48 * solar_day);
+    result = apar * light_use_ef * evap_fr * conversion_coefs;
+    return result;
Modified: grass-addons/gipe/i.biomass/main.c
--- grass-addons/gipe/i.biomass/main.c	2008-08-21 22:54:40 UTC (rev 32984)
+++ grass-addons/gipe/i.biomass/main.c	2008-08-21 23:06:30 UTC (rev 32985)
@@ -1,326 +1,361 @@
- * MODULE:       i.biomass
- * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
- * PURPOSE:      Creates a map of biomass growth
- * COPYRIGHT:    (C) 2002-2008 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 for details.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-double solar_day(double lat, double doy, double tsw );
-double biomass( double apar, double solar_day, double evap_fr, double light_use_ef );
-int main(int argc, char *argv[])
-	struct Cell_head cellhd; /*region+header info*/
-	char *mapset; /*mapset name*/
-	int nrows, ncols;
-	int row,col;
-	struct GModule *module;
-	struct Option *input1, *input2, *input3, *input4, *input5, *input6;
-	struct Option *output1;
-	struct Flag *flag1;
-	struct History history; /*metadata*/
-	struct Colors colors;
-	/* FMEO Declarations*****************/
-	char *name;   /* input raster name*/
-	char *result1,*result2; /*output raster name*/
-	/*File Descriptors*/
-	int infd_fpar, infd_lightuseff, infd_lat, infd_doy, infd_tsw, infd_wat_avail;
-	int outfd1;
-	char *fpar,*lightuseff,*lat,*doy,*tsw, *wat_avail;
-	int i=0,j=0;
-	void *inrast_fpar, *inrast_lightuseff, *inrast_lat, *inrast_doy, *inrast_tsw, *inrast_wat_avail;
-	DCELL *outrast1;
-	RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
-	RASTER_MAP_TYPE data_type_fpar;
-	RASTER_MAP_TYPE data_type_lightuseff;
-	RASTER_MAP_TYPE data_type_lat;
-	RASTER_MAP_TYPE data_type_doy;
-	RASTER_MAP_TYPE data_type_tsw;
-	RASTER_MAP_TYPE data_type_wat_avail;
-	G_gisinit(argv[0]);
-	module = G_define_module();
-	module->keywords = _("biomass, fpar, yield");
-	module->description = _("biomass growth calculation, precursor of yield calculation when processing crop ");
-	/* Define the different options */
-	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input1->key	   = _("fpar");
-	input1->description=_("Name of the fPAR map");
-	input1->answer     =_("fpar");
-	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input2->key        =_("lightuseff");
-	input2->description=_("Name of the light use efficiency map (UZB:cotton=1.9)");
-	input2->answer     =_("lightuseff");
-	input3 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input3->key        =_("lat");
-	input3->description=_("Name of the degree latitude map [dd.ddd]");
-	input3->answer     =_("lat");
-	input4 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input4->key        =_("doy");
-	input4->description=_("Name of the Day of Year map [0.0-366.0]");
-	input4->answer     =_("doy");
-	input5 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input5->key        =_("tsw");
-	input5->description=_("Name of the single-way transmissivity map [0.0-1.0]");
-	input5->answer     =_("tsw");
-	input6 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input6->key        =_("wat_avail");
-	input6->description=_("Value of the water availability map (1-water stress, can use evaporative fraction directly) [0.0;1.0]");
-	input6->answer     =_("wat_avail");
-	output1 = G_define_standard_option(G_OPT_R_INPUT) ;
-	output1->key        =_("output");
-	output1->description=_("Name of the output daily biomass growth layer");
-	output1->answer     =_("biomass");
-	if (G_parser(argc, argv))
-		exit (EXIT_FAILURE);
-	fpar	 	= input1->answer;
-	lightuseff 	= input2->answer;
-	lat		= input3->answer;
-	doy	 	= input4->answer;
-	tsw	 	= input5->answer;
-	wat_avail 	= input6->answer;
-	result1  = output1->answer;
-	mapset = G_find_cell2(fpar, "");
-	if (mapset == NULL) {
-		G_fatal_error(_("cell file [%s] not found"), fpar);
-	data_type_fpar = G_raster_map_type(fpar,mapset);
-	if ( (infd_fpar = G_open_cell_old (fpar,mapset)) < 0)
-		G_fatal_error (_("Cannot open cell file [%s]"), fpar);
-	if (G_get_cellhd (fpar, mapset, &cellhd) < 0)
-		G_fatal_error (_("Cannot read file header of [%s])"), fpar);
-	inrast_fpar = G_allocate_raster_buf(data_type_fpar);
-	mapset = G_find_cell2 (lightuseff, "");
-		G_fatal_error(_("cell file [%s] not found"), lightuseff);
-	data_type_lightuseff = G_raster_map_type(lightuseff,mapset);
-	if ( (infd_lightuseff = G_open_cell_old (lightuseff,mapset)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), lightuseff);
-	if (G_get_cellhd (lightuseff, mapset, &cellhd) < 0)
-		G_fatal_error(_("Cannot read file header of [%s]"), lightuseff);
-	inrast_lightuseff = G_allocate_raster_buf(data_type_lightuseff);
-	mapset = G_find_cell2 (lat, "");
-		G_fatal_error(_("Cell file [%s] not found"), lat);
-	data_type_lat = G_raster_map_type(lat,mapset);
-	if ( (infd_lat = G_open_cell_old (lat,mapset)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), lat);
-	if (G_get_cellhd (lat, mapset, &cellhd) < 0)
-		G_fatal_error(_("Cannot read file header of [%s]"), lat);
-	inrast_lat = G_allocate_raster_buf(data_type_lat);
-	mapset = G_find_cell2 (doy, "");
-		G_fatal_error(_("Cell file [%s] not found"), doy);
-	data_type_doy = G_raster_map_type(doy,mapset);
-	if ( (infd_doy = G_open_cell_old (doy,mapset)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), doy);
-	if (G_get_cellhd (doy, mapset, &cellhd) < 0)
-		G_fatal_error(_("Cannot read file header of [%s]"), doy);
-	inrast_doy = G_allocate_raster_buf(data_type_doy);
-	mapset = G_find_cell2 (tsw, "");
-		G_fatal_error(_("Cell file [%s] not found"), tsw);
-	data_type_tsw = G_raster_map_type(tsw,mapset);
-	if ( (infd_tsw = G_open_cell_old (tsw,mapset)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), tsw);
-	if (G_get_cellhd (tsw, mapset, &cellhd) < 0)
-		G_fatal_error(_("Cannot read file header of [%s]"), tsw);
-	inrast_tsw = G_allocate_raster_buf(data_type_tsw);
-	mapset = G_find_cell2 (wat_avail, "");
-		G_fatal_error(_("Cell file [%s] not found"), wat_avail);
-	data_type_wat_avail = G_raster_map_type(wat_avail,mapset);
-	if ( (infd_wat_avail = G_open_cell_old (wat_avail,mapset)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), wat_avail);
-	if (G_get_cellhd (wat_avail, mapset, &cellhd) < 0)
-		G_fatal_error(_("Cannot read file header of [%s]"), wat_avail);
-	inrast_wat_avail = G_allocate_raster_buf(data_type_wat_avail);
-	G_debug(3, "number of rows %d",cellhd.rows);
-	nrows = G_window_rows();
-	ncols = G_window_cols();
-	outrast1 = G_allocate_raster_buf(data_type_output);
-	/* Create New raster files */
-	if ( (outfd1 = G_open_raster_new (result1,data_type_output)) < 0)
-		G_fatal_error(_("Could not open <%s>"),result1);
-	/* Process pixels */
-	for (row = 0; row < nrows; row++)
-		DCELL d;
-		DCELL d_fpar;
-		DCELL d_lightuseff;
-		DCELL d_lat;
-		DCELL d_doy;
-		DCELL d_tsw;
-		DCELL d_solar;
-		DCELL d_wat_avail;
-		G_percent(row,nrows,2);
-		/* read input maps */
-		if(G_get_raster_row(infd_fpar,inrast_fpar,row,data_type_fpar)<0)
-			G_fatal_error(_("Could not read from <%s>"),fpar);
-		if(G_get_raster_row(infd_lightuseff,inrast_lightuseff,row,data_type_lightuseff)<0)
-			G_fatal_error(_("Could not read from <%s>"),lightuseff);
-		if(G_get_raster_row(infd_lat,inrast_lat,row,data_type_lat)<0)
-			G_fatal_error(_("Could not read from <%s>"),lat);
-		if(G_get_raster_row(infd_doy,inrast_doy,row,data_type_doy)<0)
-			G_fatal_error(_("Could not read from <%s>"),doy);
-		if(G_get_raster_row(infd_tsw,inrast_tsw,row,data_type_tsw)<0)
-			G_fatal_error(_("Could not read from <%s>"),tsw);
-		if(G_get_raster_row(infd_wat_avail,inrast_wat_avail,row,data_type_wat_avail)<0)
-			G_fatal_error(_("Could not read from <%s>"),wat_avail);
-		/*process the data */
-		for (col=0; col < ncols; col++)
-			switch(data_type_fpar){
-				case CELL_TYPE:
-					d_fpar = (double) ((CELL *) inrast_fpar)[col];
-					break;
-				case FCELL_TYPE:
-					d_fpar = (double) ((FCELL *) inrast_fpar)[col];
-					break;
-				case DCELL_TYPE:
-					d_fpar = ((DCELL *) inrast_fpar)[col];
-					break;
-			switch(data_type_lightuseff){
-				case CELL_TYPE:
-					d_lightuseff = (double) ((CELL *) inrast_lightuseff)[col];
-					break;
-				case FCELL_TYPE:
-					d_lightuseff= (double) ((FCELL *) inrast_lightuseff)[col];
-					break;
-				case DCELL_TYPE:
-					d_lightuseff = ((DCELL *) inrast_lightuseff)[col];
-					break;
-			switch(data_type_lat){
-				case CELL_TYPE:
-					d_lat = (double) ((CELL *) inrast_lat)[col];
-					break;
-				case FCELL_TYPE:
-					d_lat = (double) ((FCELL *) inrast_lat)[col];
-					break;
-				case DCELL_TYPE:
-					d_lat = ((DCELL *) inrast_lat)[col];
-					break;
-			switch(data_type_doy){
-				case CELL_TYPE:
-					d_doy = (double) ((CELL *) inrast_doy)[col];
-					break;
-				case FCELL_TYPE:
-					d_doy = (double) ((FCELL *) inrast_doy)[col];
-					break;
-				case DCELL_TYPE:
-					d_doy = ((DCELL *) inrast_doy)[col];
-					break;
-			switch(data_type_tsw){
-				case CELL_TYPE:
-					d_tsw = (double) ((CELL *) inrast_tsw)[col];
-					break;
-				case FCELL_TYPE:
-					d_tsw = (double) ((FCELL *) inrast_tsw)[col];
-					break;
-				case DCELL_TYPE:
-					d_tsw = ((DCELL *) inrast_tsw)[col];
-					break;
-			switch(data_type_wat_avail){
-				case CELL_TYPE:
-					d_wat_avail = (double) ((CELL *) inrast_wat_avail)[col];
-					break;
-				case FCELL_TYPE:
-					d_wat_avail = (double) ((FCELL *) inrast_wat_avail)[col];
-					break;
-				case DCELL_TYPE:
-					d_wat_avail = ((DCELL *) inrast_wat_avail)[col];
-					break;
-			if(G_is_d_null_value(&d_fpar)||
-			G_is_d_null_value(&d_lightuseff)||
-			G_is_d_null_value(&d_lat)||
-			G_is_d_null_value(&d_doy)||
-			G_is_d_null_value(&d_tsw)||
-			G_is_d_null_value(&d_wat_avail)){
-				G_set_d_null_value(&outrast1[col],1);
-			}else {
-				d_solar = solar_day(d_lat, d_doy, d_tsw );
-				d = biomass(d_fpar,d_solar,d_wat_avail,d_lightuseff);
-				outrast1[col] = d;
-		if (G_put_raster_row (outfd1, outrast1, data_type_output) < 0)
-			G_fatal_error(_("Cannot write to output raster file"));
-	/* Color table for biomass */
-	G_init_colors(&colors);
-	G_add_color_rule(0,0,0,0,1,255,255,255,&colors);
-	G_free (inrast_fpar);
-	G_free (inrast_lightuseff);
-	G_free (inrast_lat);
-	G_free (inrast_doy);
-	G_free (inrast_tsw);
-	G_free (inrast_wat_avail);
-	G_close_cell (infd_fpar);
-	G_close_cell (infd_lightuseff);
-	G_close_cell (infd_lat);
-	G_close_cell (infd_doy);
-	G_close_cell (infd_tsw);
-	G_close_cell (infd_wat_avail);
-	G_free (outrast1);
-	G_close_cell (outfd1);
-	G_short_history(result1, "raster", &history);
-	G_command_history(&history);
-	G_write_history(result1,&history);
-	exit(EXIT_SUCCESS);
+ * MODULE:       i.biomass
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Creates a map of biomass growth
+ * COPYRIGHT:    (C) 2002-2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+double solar_day(double lat, double doy, double tsw);
+double biomass(double apar, double solar_day, double evap_fr,
+		double light_use_ef);
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/*region+header info */
+    char *mapset;		/*mapset name */
+    int nrows, ncols;
+    int row, col;
+    struct GModule *module;
+    struct Option *input1, *input2, *input3, *input4, *input5, *input6;
+    struct Option *output1;
+    struct Flag *flag1;
+    struct History history;	/*metadata */
+    struct Colors colors;
+	/* FMEO Declarations**************** */
+    char *name;			/* input raster name */
+    char *result1, *result2;	/*output raster name */
+	/*File Descriptors */
+    int infd_fpar, infd_lightuseff, infd_lat, infd_doy, infd_tsw,
+	infd_wat_avail;
+    int outfd1;
+    char *fpar, *lightuseff, *lat, *doy, *tsw, *wat_avail;
+    int i = 0, j = 0;
+    void *inrast_fpar, *inrast_lightuseff, *inrast_lat, *inrast_doy,
+	*inrast_tsw, *inrast_wat_avail;
+    DCELL * outrast1;
+    RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
+    RASTER_MAP_TYPE data_type_fpar;
+    RASTER_MAP_TYPE data_type_lightuseff;
+    RASTER_MAP_TYPE data_type_lat;
+    RASTER_MAP_TYPE data_type_doy;
+    RASTER_MAP_TYPE data_type_tsw;
+    RASTER_MAP_TYPE data_type_wat_avail;
+	G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("biomass, fpar, yield");
+    module->description =
+	_("biomass growth calculation, precursor of yield calculation when processing crop ");
+	/* Define the different options */
+	input1 = G_define_standard_option(G_OPT_R_INPUT);
+    input1->key = _("fpar");
+    input1->description = _("Name of the fPAR map");
+    input1->answer = _("fpar");
+    input2 = G_define_standard_option(G_OPT_R_INPUT);
+    input2->key = _("lightuseff");
+    input2->description =
+	_("Name of the light use efficiency map (UZB:cotton=1.9)");
+    input2->answer = _("lightuseff");
+    input3 = G_define_standard_option(G_OPT_R_INPUT);
+    input3->key = _("lat");
+    input3->description = _("Name of the degree latitude map [dd.ddd]");
+    input3->answer = _("lat");
+    input4 = G_define_standard_option(G_OPT_R_INPUT);
+    input4->key = _("doy");
+    input4->description = _("Name of the Day of Year map [0.0-366.0]");
+    input4->answer = _("doy");
+    input5 = G_define_standard_option(G_OPT_R_INPUT);
+    input5->key = _("tsw");
+    input5->description =
+	_("Name of the single-way transmissivity map [0.0-1.0]");
+    input5->answer = _("tsw");
+    input6 = G_define_standard_option(G_OPT_R_INPUT);
+    input6->key = _("wat_avail");
+    input6->description =
+	_("Value of the water availability map (1-water stress, can use evaporative fraction directly) [0.0;1.0]");
+    input6->answer = _("wat_avail");
+    output1 = G_define_standard_option(G_OPT_R_INPUT);
+    output1->key = _("output");
+    output1->description =
+	_("Name of the output daily biomass growth layer");
+    output1->answer = _("biomass");
+	if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    fpar = input1->answer;
+    lightuseff = input2->answer;
+    lat = input3->answer;
+    doy = input4->answer;
+    tsw = input5->answer;
+    wat_avail = input6->answer;
+    result1 = output1->answer;
+	mapset = G_find_cell2(fpar, "");
+    if (mapset == NULL) {
+	G_fatal_error(_("cell file [%s] not found"), fpar);
+    data_type_fpar = G_raster_map_type(fpar, mapset);
+    if ((infd_fpar = G_open_cell_old(fpar, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), fpar);
+    if (G_get_cellhd(fpar, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s])"), fpar);
+    inrast_fpar = G_allocate_raster_buf(data_type_fpar);
+	mapset = G_find_cell2(lightuseff, "");
+	G_fatal_error(_("cell file [%s] not found"), lightuseff);
+    data_type_lightuseff = G_raster_map_type(lightuseff, mapset);
+    if ((infd_lightuseff = G_open_cell_old(lightuseff, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), lightuseff);
+    if (G_get_cellhd(lightuseff, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s]"), lightuseff);
+    inrast_lightuseff = G_allocate_raster_buf(data_type_lightuseff);
+	mapset = G_find_cell2(lat, "");
+	G_fatal_error(_("Cell file [%s] not found"), lat);
+    data_type_lat = G_raster_map_type(lat, mapset);
+    if ((infd_lat = G_open_cell_old(lat, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), lat);
+    if (G_get_cellhd(lat, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s]"), lat);
+    inrast_lat = G_allocate_raster_buf(data_type_lat);
+	mapset = G_find_cell2(doy, "");
+	G_fatal_error(_("Cell file [%s] not found"), doy);
+    data_type_doy = G_raster_map_type(doy, mapset);
+    if ((infd_doy = G_open_cell_old(doy, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), doy);
+    if (G_get_cellhd(doy, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s]"), doy);
+    inrast_doy = G_allocate_raster_buf(data_type_doy);
+	mapset = G_find_cell2(tsw, "");
+	G_fatal_error(_("Cell file [%s] not found"), tsw);
+    data_type_tsw = G_raster_map_type(tsw, mapset);
+    if ((infd_tsw = G_open_cell_old(tsw, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), tsw);
+    if (G_get_cellhd(tsw, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s]"), tsw);
+    inrast_tsw = G_allocate_raster_buf(data_type_tsw);
+	mapset = G_find_cell2(wat_avail, "");
+	G_fatal_error(_("Cell file [%s] not found"), wat_avail);
+    data_type_wat_avail = G_raster_map_type(wat_avail, mapset);
+    if ((infd_wat_avail = G_open_cell_old(wat_avail, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), wat_avail);
+    if (G_get_cellhd(wat_avail, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s]"), wat_avail);
+    inrast_wat_avail = G_allocate_raster_buf(data_type_wat_avail);
+	G_debug(3, "number of rows %d", cellhd.rows);
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    outrast1 = G_allocate_raster_buf(data_type_output);
+	/* Create New raster files */
+	if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
+	G_fatal_error(_("Could not open <%s>"), result1);
+	/* Process pixels */
+	for (row = 0; row < nrows; row++)
+	DCELL d;
+	DCELL d_fpar;
+	DCELL d_lightuseff;
+	DCELL d_lat;
+	DCELL d_doy;
+	DCELL d_tsw;
+	DCELL d_solar;
+	DCELL d_wat_avail;
+	G_percent(row, nrows, 2);
+	    /* read input maps */
+	    if (G_get_raster_row(infd_fpar, inrast_fpar, row, data_type_fpar)
+		< 0)
+	    G_fatal_error(_("Could not read from <%s>"), fpar);
+	     (infd_lightuseff, inrast_lightuseff, row,
+	      data_type_lightuseff) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), lightuseff);
+	if (G_get_raster_row(infd_lat, inrast_lat, row, data_type_lat) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), lat);
+	if (G_get_raster_row(infd_doy, inrast_doy, row, data_type_doy) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), doy);
+	if (G_get_raster_row(infd_tsw, inrast_tsw, row, data_type_tsw) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), tsw);
+	     (infd_wat_avail, inrast_wat_avail, row, data_type_wat_avail) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), wat_avail);
+	    /*process the data */
+	    for (col = 0; col < ncols; col++)
+	    switch (data_type_fpar) {
+	    case CELL_TYPE:
+		d_fpar = (double)((CELL *) inrast_fpar)[col];
+		break;
+	    case FCELL_TYPE:
+		d_fpar = (double)((FCELL *) inrast_fpar)[col];
+		break;
+	    case DCELL_TYPE:
+		d_fpar = ((DCELL *) inrast_fpar)[col];
+		break;
+	    switch (data_type_lightuseff) {
+	    case CELL_TYPE:
+		d_lightuseff = (double)((CELL *) inrast_lightuseff)[col];
+		break;
+	    case FCELL_TYPE:
+		d_lightuseff = (double)((FCELL *) inrast_lightuseff)[col];
+		break;
+	    case DCELL_TYPE:
+		d_lightuseff = ((DCELL *) inrast_lightuseff)[col];
+		break;
+	    switch (data_type_lat) {
+	    case CELL_TYPE:
+		d_lat = (double)((CELL *) inrast_lat)[col];
+		break;
+	    case FCELL_TYPE:
+		d_lat = (double)((FCELL *) inrast_lat)[col];
+		break;
+	    case DCELL_TYPE:
+		d_lat = ((DCELL *) inrast_lat)[col];
+		break;
+	    switch (data_type_doy) {
+	    case CELL_TYPE:
+		d_doy = (double)((CELL *) inrast_doy)[col];
+		break;
+	    case FCELL_TYPE:
+		d_doy = (double)((FCELL *) inrast_doy)[col];
+		break;
+	    case DCELL_TYPE:
+		d_doy = ((DCELL *) inrast_doy)[col];
+		break;
+	    switch (data_type_tsw) {
+	    case CELL_TYPE:
+		d_tsw = (double)((CELL *) inrast_tsw)[col];
+		break;
+	    case FCELL_TYPE:
+		d_tsw = (double)((FCELL *) inrast_tsw)[col];
+		break;
+	    case DCELL_TYPE:
+		d_tsw = ((DCELL *) inrast_tsw)[col];
+		break;
+	    switch (data_type_wat_avail) {
+	    case CELL_TYPE:
+		d_wat_avail = (double)((CELL *) inrast_wat_avail)[col];
+		break;
+	    case FCELL_TYPE:
+		d_wat_avail = (double)((FCELL *) inrast_wat_avail)[col];
+		break;
+	    case DCELL_TYPE:
+		d_wat_avail = ((DCELL *) inrast_wat_avail)[col];
+		break;
+	    if (G_is_d_null_value(&d_fpar) ||
+		 G_is_d_null_value(&d_lightuseff) ||
+		 G_is_d_null_value(&d_lat) || G_is_d_null_value(&d_doy) ||
+		 G_is_d_null_value(&d_tsw) ||
+		 G_is_d_null_value(&d_wat_avail)) {
+		G_set_d_null_value(&outrast1[col], 1);
+	    else {
+		d_solar = solar_day(d_lat, d_doy, d_tsw);
+		d = biomass(d_fpar, d_solar, d_wat_avail, d_lightuseff);
+		outrast1[col] = d;
+	if (G_put_raster_row(outfd1, outrast1, data_type_output) < 0)
+	    G_fatal_error(_("Cannot write to output raster file"));
+	/* Color table for biomass */
+	G_init_colors(&colors);
+    G_add_color_rule(0, 0, 0, 0, 1, 255, 255, 255, &colors);
+    G_free(inrast_fpar);
+    G_free(inrast_lightuseff);
+    G_free(inrast_lat);
+    G_free(inrast_doy);
+    G_free(inrast_tsw);
+    G_free(inrast_wat_avail);
+    G_close_cell(infd_fpar);
+    G_close_cell(infd_lightuseff);
+    G_close_cell(infd_lat);
+    G_close_cell(infd_doy);
+    G_close_cell(infd_tsw);
+    G_close_cell(infd_wat_avail);
+    G_free(outrast1);
+    G_close_cell(outfd1);
+    G_short_history(result1, "raster", &history);
+    G_command_history(&history);
+    G_write_history(result1, &history);
+    exit(EXIT_SUCCESS);
Modified: grass-addons/gipe/i.biomass/solar_day.c
--- grass-addons/gipe/i.biomass/solar_day.c	2008-08-21 22:54:40 UTC (rev 32984)
+++ grass-addons/gipe/i.biomass/solar_day.c	2008-08-21 23:06:30 UTC (rev 32985)
@@ -1,28 +1,25 @@
-#include<stdio.h>
-#include<math.h>
-#include<stdlib.h>
- * Average Solar Diurnal Radiation after Bastiaanssen (1995)
-#define PI 3.1415927
-	double ws, cosun, n10_temp, delta, ds, result;
-	ds = 1.0 + 0.01672 * sin(2*PI*(doy-93.5)/365.0);
-	delta = 0.4093*sin((2*PI*doy/365)-1.39);
-	 n10_temp =  lat * PI / 180.0;
-	 ws = acos(-tan(n10_temp)*tan(delta*PI/180.0));
-	 cosun = ws*sin(delta*PI/180.0)*sin(n10_temp)+cos(delta*PI/180.0)*cos(n10_temp)*sin(ws);
-	 result = ( cosun * 1367 * tsw ) / ( PI * ds * ds );
-	return result;
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+     * Average Solar Diurnal Radiation after Bastiaanssen (1995)
+#define PI 3.1415927
+    double ws, cosun, n10_temp, delta, ds, result;
+    ds = 1.0 + 0.01672 * sin(2 * PI * (doy - 93.5) / 365.0);
+    delta = 0.4093 * sin((2 * PI * doy / 365) - 1.39);
+    n10_temp = lat * PI / 180.0;
+    ws = acos(-tan(n10_temp) * tan(delta * PI / 180.0));
+    cosun =
+	ws * sin(delta * PI / 180.0) * sin(n10_temp) +
+	cos(delta * PI / 180.0) * cos(n10_temp) * sin(ws);
+    result = (cosun * 1367 * tsw) / (PI * ds * ds);
+    return result;
