[GRASS-SVN] r33006 - in grass/trunk: db/base db/db.login display/d.thematic.area display/d.vect include lib/gis swig/perl swig/python/interfaces vector/v.class vector/v.db.connect vector/v.db.select vector/v.distance vector/v.edit vector/v.extract vector/v.extrude vector/v.generalize vector/v.in.db vector/v.in.ogr vector/v.label vector/v.random vector/v.reclass vector/v.surf.rst vector/v.to.db vector/v.to.rast vector/v.transform vector/v.univar vector/v.vol.rst vector/v.what.rast
Fri Aug 22 11:58:29 EDT 2008
Author: martinl
Date: 2008-08-22 11:58:28 -0400 (Fri, 22 Aug 2008)
New Revision: 33006
   grass/trunk/db/base/columns.c
   grass/trunk/db/base/connect.c
   grass/trunk/db/base/copy.c
   grass/trunk/db/base/createdb.c
   grass/trunk/db/base/databases.c
   grass/trunk/db/base/describe.c
   grass/trunk/db/base/dropdb.c
   grass/trunk/db/base/droptable.c
   grass/trunk/db/base/execute.c
   grass/trunk/db/base/select.c
   grass/trunk/db/base/tables.c
   grass/trunk/db/db.login/main.c
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/include/gis.h
   grass/trunk/lib/gis/parser.c
   grass/trunk/swig/perl/gis.h
   grass/trunk/swig/python/interfaces/gis.i
   grass/trunk/vector/v.class/main.c
   grass/trunk/vector/v.db.connect/main.c
   grass/trunk/vector/v.db.select/main.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.edit/args.c
   grass/trunk/vector/v.extract/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.in.db/main.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.label/main.c
   grass/trunk/vector/v.random/main.c
   grass/trunk/vector/v.reclass/main.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.to.db/parse.c
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.univar/main.c
   grass/trunk/vector/v.vol.rst/main.c
   grass/trunk/vector/v.what.rast/main.c
Change db-related standard options to G_OPT_DB_*
Modified: grass/trunk/db/base/columns.c
--- grass/trunk/db/base/columns.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/columns.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -75,15 +75,15 @@
     /* Initialize the GIS calls */
     G_gisinit(argv[0]);
-    table = G_define_standard_option(G_OPT_TABLE);
+    table = G_define_standard_option(G_OPT_DB_TABLE);
     table->required = YES;
-    driver = G_define_standard_option(G_OPT_DRIVER);
+    driver = G_define_standard_option(G_OPT_DB_DRIVER);
     driver->options = db_list_drivers();
     if ((drv = db_get_default_driver_name()))
 	driver->answer = (char *) drv;
-    database = G_define_standard_option(G_OPT_DATABASE);
+    database = G_define_standard_option(G_OPT_DB_DATABASE);
     if ((db = db_get_default_database_name()))
 	database->answer = (char *) db;
Modified: grass/trunk/db/base/connect.c
--- grass/trunk/db/base/connect.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/connect.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -56,11 +56,11 @@
     check_set_default->description =
 	_("Check connection parameters, set if uninitialized, and exit");
     driver->answer = (char *) db_get_default_driver_name();
     database->answer = (char *) db_get_default_database_name();
     schema = G_define_option();
Modified: grass/trunk/db/base/copy.c
--- grass/trunk/db/base/copy.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/copy.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -37,25 +37,25 @@
 	_("Either 'from_table' (optionaly with 'where') can be used "
 	  "or 'select' option, but not 'from_table' and 'select' at the same time.");
-    from_driver = G_define_standard_option(G_OPT_DRIVER);
+    from_driver = G_define_standard_option(G_OPT_DB_DRIVER);
     from_driver->key = "from_driver";
     from_driver->options = db_list_drivers();
     from_driver->description = _("Input driver name");
       from_driver->answer = (char *) drv;
-    from_database = G_define_standard_option(G_OPT_DATABASE);
+    from_database = G_define_standard_option(G_OPT_DB_DATABASE);
     from_database->key = "from_database";
     from_database->description = _("Input database name");
       from_database->answer = (char *) db;
-    from_table = G_define_standard_option(G_OPT_TABLE);
+    from_table = G_define_standard_option(G_OPT_DB_TABLE);
     from_table->key = "from_table";
     from_table->description =
 	_("Input table name (only, if 'select' is not used)");
-    to_driver = G_define_standard_option(G_OPT_DRIVER);
+    to_driver = G_define_standard_option(G_OPT_DB_DRIVER);
     to_driver->key = "to_driver";
     to_driver->options = db_list_drivers();
     to_driver->required = NO;
@@ -63,19 +63,19 @@
       to_driver->answer = (char *) drv;
-    to_database = G_define_standard_option(G_OPT_DATABASE);
+    to_database = G_define_standard_option(G_OPT_DB_DATABASE);
     to_database->key = "to_database";
     to_database->description = _("Output database name");
       to_database->answer = (char *) db;
-    to_table = G_define_standard_option(G_OPT_TABLE);
+    to_table = G_define_standard_option(G_OPT_DB_TABLE);
     to_table->key = "to_table";
     to_table->required = YES;
     to_table->description = _("Output table name");
     to_table->gisprompt = "new,dbtable,dbtable";
-    where = G_define_standard_option(G_OPT_WHERE);
+    where = G_define_standard_option(G_OPT_DB_WHERE);
     select = G_define_option();
     select->key = "select";
Modified: grass/trunk/db/base/createdb.c
--- grass/trunk/db/base/createdb.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/createdb.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -59,11 +59,11 @@
     G_gisinit(argv[0]);
     driver->required = YES;
     database->required = YES;
     /* Set description */
Modified: grass/trunk/db/base/databases.c
--- grass/trunk/db/base/databases.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/databases.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -74,7 +74,7 @@
     G_gisinit(argv[0]);
     location = G_define_option();
Modified: grass/trunk/db/base/describe.c
--- grass/trunk/db/base/describe.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/describe.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -108,15 +108,15 @@
     tdesc->key = 't';
     tdesc->description = _("Print table structure");
Modified: grass/trunk/db/base/dropdb.c
--- grass/trunk/db/base/dropdb.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/dropdb.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -59,11 +59,11 @@
     G_gisinit(argv[0]);
Modified: grass/trunk/db/base/droptable.c
--- grass/trunk/db/base/droptable.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/droptable.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -65,13 +65,13 @@
     G_gisinit(argv[0]);
-    table = G_define_standard_option(G_OPT_DRIVER);
+    table = G_define_standard_option(G_OPT_DB_DRIVER);
     module = G_define_module();
Modified: grass/trunk/db/base/execute.c
--- grass/trunk/db/base/execute.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/execute.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -110,12 +110,12 @@
     input->required = NO;
     input->description = _("Name of file containing SQL statements");
Modified: grass/trunk/db/base/select.c
--- grass/trunk/db/base/select.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/select.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -172,13 +172,13 @@
     G_gisinit(argv[0]);
Modified: grass/trunk/db/base/tables.c
--- grass/trunk/db/base/tables.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/base/tables.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -73,12 +73,12 @@
     G_gisinit(argv[0]);
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/db/db.login/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -43,12 +43,12 @@
     module->keywords = _("database, SQL");
     module->description = _("Sets user/password for driver/database.");
     driver->answer = db_get_default_driver_name();
     database->answer = db_get_default_database_name();
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/display/d.thematic.area/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -130,7 +130,7 @@
     field_opt->description =
 	_("Layer number. If -1, all layers are displayed.");
-    where_opt = G_define_standard_option(G_OPT_WHERE);
+    where_opt = G_define_standard_option(G_OPT_DB_WHERE);
     where_opt->guisection = _("Query");
     bwidth_opt = G_define_option();
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/display/d.vect/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -151,7 +151,7 @@
     cat_opt = G_define_standard_option(G_OPT_V_CATS);
     cat_opt->guisection = _("Query");
     /* Colors */
@@ -175,7 +175,7 @@
     fcolor_opt->description =
 	_("Either a standard GRASS color, R:G:B triplet, or \"none\"");
-    rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
+    rgbcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     rgbcol_opt->key = "rgb_column";
     rgbcol_opt->guisection = _("Colors");
     rgbcol_opt->description = _("Name of color definition column (for use with -a flag)");
@@ -198,7 +198,7 @@
     width_opt->guisection = _("Lines");
     width_opt->description = _("Line width");
-    wcolumn_opt = G_define_standard_option(G_OPT_COLUMN);
+    wcolumn_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     wcolumn_opt->key = "wcolumn";
     wcolumn_opt->guisection = _("Lines");
     wcolumn_opt->description =
@@ -231,7 +231,7 @@
     size_opt->description = _("Symbol size");
     /* Labels */
-    attrcol_opt = G_define_standard_option(G_OPT_COLUMN);
+    attrcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     attrcol_opt->key = "attrcol";
     attrcol_opt->multiple = NO;	/* or fix attr.c, around line 102 */
     attrcol_opt->guisection = _("Labels");
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/include/gis.h	2008-08-22 15:58:28 UTC (rev 33006)
@@ -161,12 +161,12 @@
  /**/ typedef enum
-    G_OPT_WHERE,		/* SQL where conditions */
-    G_OPT_TABLE,		/* table name */
-    G_OPT_DRIVER,		/* driver name */
-    G_OPT_DATABASE,		/* database name */
-    G_OPT_COLUMN,		/* one attr column */
-    G_OPT_COLUMNS,		/* one or more attr columns */
+    G_OPT_DB_WHERE,		/* SQL where conditions */
+    G_OPT_DB_TABLE,		/* table name */
+    G_OPT_DB_DRIVER,		/* driver name */
+    G_OPT_DB_DATABASE,		/* database name */
+    G_OPT_DB_COLUMN,		/* one attr column */
+    G_OPT_DB_COLUMNS,		/* one or more attr columns */
     G_OPT_I_GROUP,		/* old input imagery group */
     G_OPT_I_SUBGROUP,		/* old input imagery subgroup */
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/lib/gis/parser.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -294,15 +294,46 @@
  * If an invalid parameter was specified a empty Option structure will
  * be returned (not NULL).
- *  - general: G_OPT_WHERE, G_OPT_COLUMN, G_OPT_COLUMNS, G_OPT_TABLE, G_OPT_DRIVER, G_OPT_DATABASE
+ *  - general:
+ *   - G_OPT_DB_WHERE
+ *   - G_OPT_DB_COLUMN
+ *   - G_OPT_DB_COLUMNS
+ *   - G_OPT_DB_TABLE
+ *   - G_OPT_DB_DRIVER
+ *   - G_OPT_DB_DATABASE
- *  - imagery: G_OPT_I_GROUP, G_OPT_I_SUBGROUP
+ *  - imagery:
+ *   - G_OPT_I_GROUP
+ *   - G_OPT_I_SUBGROUP
- *  - raster: G_OPT_R_INPUT, G_OPT_R_INPUTS, G_OPT_R_OUTPUT, G_OPT_R_MAP, G_OPT_R_MAPS, G_OPT_R_BASE, G_OPT_R_COVER, G_OPT_R_ELEV, G_OPT_R_ELEVS
+ *  - raster:
+ *   - G_OPT_R_INPUT
+ *   - G_OPT_R_INPUTS
+ *   - G_OPT_R_OUTPUT
+ *   - G_OPT_R_MAP
+ *   - G_OPT_R_MAPS
+ *   - G_OPT_R_BASE
+ *   - G_OPT_R_COVER
+ *   - G_OPT_R_ELEV
+ *   - G_OPT_R_ELEVS
- *  - raster3d: G_OPT_R3_INPUT, G_OPT_R3_INPUTS, G_OPT_R3_OUTPUT, G_OPT_R3_MAP, G_OPT_R3_MAPS
+ *  - raster3d:
+ *   - G_OPT_R3_INPUT
+ *   - G_OPT_R3_INPUTS
+ *   - G_OPT_R3_OUTPUT
+ *   - G_OPT_R3_MAP
+ *   - G_OPT_R3_MAPS
- *  - vector: G_OPT_V_INPUT, G_OPT_V_INPUTS, G_OPT_V_OUTPUT, G_OPT_V_MAP, G_OPT_V_MAPS, G_OPT_V_TYPE, G_OPT_V_FIELD, G_OPT_V_CAT, G_OPT_V_CATS
+ *  - vector:
+ *   - G_OPT_V_INPUT
+ *   - G_OPT_V_INPUTS
+ *   - G_OPT_V_OUTPUT
+ *   - G_OPT_V_MAP
+ *   - G_OPT_V_MAPS
+ *   - G_OPT_V_TYPE
+ *   - G_OPT_V_FIELD
+ *   - G_OPT_V_CAT
+ *   - G_OPT_V_CATS
  * \param[in] opt Type of Option struct to create
@@ -316,8 +347,7 @@
     Opt = G_define_option();
     switch (opt) {
-	/* Database options (change to G_OPT_DB_*?) */
-    case G_OPT_WHERE:
+    case G_OPT_DB_WHERE:
 	Opt->key = "where";
 	Opt->type = TYPE_STRING;
 	Opt->key_desc = "sql_query";
@@ -325,7 +355,7 @@
 	Opt->label = _("WHERE conditions of SQL statement without 'where' keyword");
 	Opt->description = _("Example: income < 1000 and inhab >= 10000");
 	break;
-    case G_OPT_TABLE:
+    case G_OPT_DB_TABLE:
 	Opt->key = "table";
 	Opt->key_desc = "name";
@@ -334,7 +364,7 @@
 	Opt->description = _("Table name");
 	Opt->gisprompt = GISPROMPT_DBTABLE;
 	break;
-    case G_OPT_DRIVER:
+    case G_OPT_DB_DRIVER:
 	Opt->key = "driver";
@@ -342,7 +372,7 @@
 	Opt->multiple = NO;
 	Opt->description = _("Driver name");
 	break;
-    case G_OPT_DATABASE:
+    case G_OPT_DB_DATABASE:
 	Opt->key = "database";
@@ -350,7 +380,7 @@
 	Opt->multiple = NO;
 	Opt->description = _("Database name");
 	break;
-    case G_OPT_COLUMN:
+    case G_OPT_DB_COLUMN:
 	Opt->key = "column";
@@ -359,7 +389,7 @@
 	Opt->description = _("Name of attribute column");
 	Opt->gisprompt = GISPROMPT_DBCOLUMN;
 	break;
-    case G_OPT_COLUMNS:
+    case G_OPT_DB_COLUMNS:
 	Opt->key = "columns";
Modified: grass/trunk/swig/perl/gis.h
--- grass/trunk/swig/perl/gis.h	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/swig/perl/gis.h	2008-08-22 15:58:28 UTC (rev 33006)
@@ -150,9 +150,9 @@
  /**/ typedef enum
     G_OPT_R_INPUT,		/* old input raster map */
Modified: grass/trunk/swig/python/interfaces/gis.i
--- grass/trunk/swig/python/interfaces/gis.i	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/swig/python/interfaces/gis.i	2008-08-22 15:58:28 UTC (rev 33006)
@@ -38,7 +38,7 @@
 #define NO            0
 typedef enum {
-    G_OPT_WHERE,
+    G_OPT_DB_WHERE,
     G_OPT_R_INPUT,
     G_OPT_R_OUTPUT,
     G_OPT_R_MAP,
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.class/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -57,7 +57,7 @@
     col_opt->description = _("Column name or expression");
     algo_opt = G_define_option();
     algo_opt->key = "algorithm";
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.db.connect/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -53,18 +53,18 @@
     inopt = G_define_standard_option(G_OPT_V_MAP);
-    dbdriver = G_define_standard_option(G_OPT_DRIVER);
+    dbdriver = G_define_standard_option(G_OPT_DB_DRIVER);
     dbdriver->options = db_list_drivers();
     if ((drv = G__getenv2("DB_DRIVER", G_VAR_MAPSET)))
 	dbdriver->answer = G_store(drv);
-    dbdatabase = G_define_standard_option(G_OPT_DATABASE);
+    dbdatabase = G_define_standard_option(G_OPT_DB_DATABASE);
     if ((db = G__getenv2("DB_DATABASE", G_VAR_MAPSET)))
 	dbdatabase->answer = G_store(db);
-    dbtable = G_define_standard_option(G_OPT_TABLE);
+    dbtable = G_define_standard_option(G_OPT_DB_TABLE);
-    dbkey = G_define_standard_option(G_OPT_COLUMN);
+    dbkey = G_define_standard_option(G_OPT_DB_COLUMN);
     dbkey->key = "key";
     dbkey->answer = "cat";
     dbkey->label = _("Key column name");
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.db.select/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -51,9 +51,9 @@
     map_opt = G_define_standard_option(G_OPT_V_MAP);
     field_opt = G_define_standard_option(G_OPT_V_FIELD);
-    col_opt = G_define_standard_option(G_OPT_COLUMNS);
+    col_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
     fs_opt = G_define_standard_option(G_OPT_F_SEP);
     fs_opt->description = _("Output field separator");
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.distance/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -193,20 +193,20 @@
     /*  "from_y - y coordinate of the nearest point on 'from' feature;" */
     /* "from_along - distance to the nearest point on 'from' feature along linear feature;" */
-    column_opt = G_define_standard_option(G_OPT_COLUMN);
+    column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     column_opt->required = YES;
     column_opt->multiple = YES;
 	_("Column name(s) where values specified by 'upload' option will be uploaded");
     column_opt->guisection = _("From_map");
-    to_column_opt = G_define_standard_option(G_OPT_COLUMN);
+    to_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     to_column_opt->key = "to_column";
     to_column_opt->description =
 	_("Column name of nearest feature (used with upload=to_attr)");
     to_column_opt->guisection = _("To_map");
-    table_opt = G_define_standard_option(G_OPT_TABLE);
+    table_opt = G_define_standard_option(G_OPT_DB_TABLE);
     table_opt->description =
 	_("Name of table created for output when the distance to all flag is used");
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.edit/args.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -158,7 +158,7 @@
     params->poly->description = _("Polygon for selecting features");
     params->poly->guisection = _("Query");
-    params->where = G_define_standard_option(G_OPT_WHERE);
+    params->where = G_define_standard_option(G_OPT_DB_WHERE);
     params->where->guisection = _("Query");
     params->query = G_define_option();
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.extract/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -121,7 +121,7 @@
 	_("Input text file with category numbers/number ranges to be extracted");
     fileopt->description = _("If '-' given reads from standard input");
-    whereopt = G_define_standard_option(G_OPT_WHERE);
+    whereopt = G_define_standard_option(G_OPT_DB_WHERE);
     /* heeeerrrrrre's the   PARSER */
     if (G_parser(argc, argv))
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.extrude/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -97,7 +97,7 @@
     height->multiple = NO;
     height->description = _("Fixed height for 3D vector objects");
-    hcolumn = G_define_standard_option(G_OPT_COLUMN);
+    hcolumn = G_define_standard_option(G_OPT_DB_COLUMN);
     hcolumn->key = "hcolumn";
     hcolumn->multiple = NO;
     hcolumn->description = _("Name of attribute column with object heights");
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.generalize/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -202,7 +202,7 @@
     ca_flag = G_define_flag();
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.in.db/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -53,38 +53,38 @@
 	_("Creates new vector (points) map from database table containing coordinates.");
     table_opt->required = YES;
     table_opt->description = _("Input table name");
-    driver_opt = G_define_standard_option(G_OPT_DRIVER);
+    driver_opt = G_define_standard_option(G_OPT_DB_DRIVER);
     driver_opt->options = db_list_drivers();
     driver_opt->answer = db_get_default_driver_name();
-    database_opt = G_define_standard_option(G_OPT_DATABASE);
+    database_opt = G_define_standard_option(G_OPT_DB_DATABASE);
     database_opt->answer = db_get_default_database_name();
-    xcol_opt = G_define_standard_option(G_OPT_COLUMN);
+    xcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     xcol_opt->key = "x";
     xcol_opt->required = YES;
     xcol_opt->description = _("Name of column containing x coordinate");
-    ycol_opt = G_define_standard_option(G_OPT_COLUMN);
+    ycol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     ycol_opt->key = "y";
     ycol_opt->required = YES;
     ycol_opt->description = _("Name of column containing y coordinate");
-    zcol_opt = G_define_standard_option(G_OPT_COLUMN);
+    zcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     zcol_opt->key = "z";
     zcol_opt->description = _("Name of column containing z coordinate");
-    keycol_opt = G_define_standard_option(G_OPT_COLUMN);
+    keycol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     keycol_opt->key = "key";
     keycol_opt->required = YES;
     keycol_opt->description = _("Name of column containing category number");
     keycol_opt->description = _("Must refer to an integer column");
     outvect = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.in.ogr/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -140,7 +140,7 @@
     spat_opt->description =
 	_("Format: xmin,ymin,xmax,ymax - usually W,S,E,N");
     min_area_opt = G_define_option();
Modified: grass/trunk/vector/v.label/main.c
--- grass/trunk/vector/v.label/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.label/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -74,7 +74,7 @@
     Vectfile = G_define_standard_option(G_OPT_V_MAP);
-    Colopt = G_define_standard_option(G_OPT_COLUMN);
+    Colopt = G_define_standard_option(G_OPT_DB_COLUMN);
     Colopt->required = YES;
     Colopt->description = _("Name of attribute column to be used for labels");
@@ -83,7 +83,7 @@
     Typopt->answer = "point,line,boundary,centroid";
     Fieldopt = G_define_standard_option(G_OPT_V_FIELD);
     Along_flag = G_define_flag();
     Along_flag->key = 'a';
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.random/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -108,7 +108,7 @@
 	_("Maximum z height (needs -z flag or column name)");
     parm.zmax->answer = "0.0";
-    parm.zcol = G_define_standard_option(G_OPT_COLUMN);
+    parm.zcol = G_define_standard_option(G_OPT_DB_COLUMN);
     parm.zcol->key = "column";
     parm.zcol->required = NO;
     parm.zcol->multiple = NO;
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.reclass/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -74,7 +74,7 @@
     rules_opt->required = NO;
     rules_opt->description = _("Full path to the reclass rule file");
-    col_opt = G_define_standard_option(G_OPT_COLUMN);
+    col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     col_opt->label =
 	_("The name of the column whose values are to be used as new categories");
     col_opt->description = _("The column must be type integer or string");
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.surf.rst/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -193,7 +193,7 @@
     parm.zcol->description =
 	_("Name of the attribute column with values to be used for approximation (if layer>0)");
-    parm.wheresql = G_define_standard_option(G_OPT_WHERE);
+    parm.wheresql = G_define_standard_option(G_OPT_DB_WHERE);
     parm.elev = G_define_standard_option(G_OPT_R_OUTPUT);
     parm.elev->key = "elev";
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.to.db/parse.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -83,9 +83,9 @@
     parms.units->description =
 	_("mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)");
-    parms.col = G_define_standard_option(G_OPT_COLUMNS);
+    parms.col = G_define_standard_option(G_OPT_DB_COLUMNS);
-    parms.qcol = G_define_standard_option(G_OPT_COLUMN);
+    parms.qcol = G_define_standard_option(G_OPT_DB_COLUMN);
     parms.qcol->key = "qcolumn";
     parms.qcol->label = _("Name of attribute column used for 'query' option");
     parms.qcol->description = _("E.g. 'cat', 'count(*)', 'sum(val)'");
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.to.rast/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -63,7 +63,7 @@
     /* for GRASS 7, IMHO this should be changed to "attrcolumn" */
-    col = G_define_standard_option(G_OPT_COLUMN);
+    col = G_define_standard_option(G_OPT_DB_COLUMN);
     col->description =
 	_("Name of column for attr parameter (data type must be numeric)");
     col->guisection = _("Attributes");
@@ -84,13 +84,13 @@
     rows->answer = "4096";
     rows->description = _("Number of rows to hold in memory");
     rgbcol_opt->key = "rgbcolumn";
 	_("Name of color definition column (with RRR:GGG:BBB entries)");
     rgbcol_opt->guisection = _("Attributes");
-    label_opt = G_define_standard_option(G_OPT_COLUMN);
+    label_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     label_opt->key = "labelcolumn";
     label_opt->description =
 	_("Name of column used as raster category labels");
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.transform/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -184,12 +184,12 @@
     zrot->answer = "0.0";
     zrot->guisection = _("Custom");
 	_("Name of table containing transformation parameters");
     table->guisection = _("Custom");
-    columns = G_define_standard_option(G_OPT_COLUMNS);
+    columns = G_define_standard_option(G_OPT_DB_COLUMNS);
     columns->label =
 	_("Name of attribute column(s) used as transformation parameters");
     columns->description =
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.univar/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -78,7 +78,7 @@
     col_opt->description = _("Column name");
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.vol.rst/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -288,7 +288,7 @@
 	_("Name of the column with smoothing parameters");
     parm.scol->guisection = _("Settings");
     parm.devi = G_define_option();
     parm.devi->key = "devi";
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c	2008-08-22 15:54:05 UTC (rev 33005)
+++ grass/trunk/vector/v.what.rast/main.c	2008-08-22 15:58:28 UTC (rev 33006)
@@ -99,7 +99,7 @@
 	_("Column name (will be updated by raster values)");
 	exit(EXIT_FAILURE);
