[GRASS-SVN] r33018 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sat Aug 23 08:46:47 EDT 2008
Author: martinl
Date: 2008-08-23 08:46:47 -0400 (Sat, 23 Aug 2008)
New Revision: 33018
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI: fix map toolbar radio items, trac #208
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-23 11:55:39 UTC (rev 33017)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-23 12:46:47 UTC (rev 33018)
@@ -2835,10 +2835,12 @@
     def OnPointer(self, event):
         """Pointer button clicked"""
+        self.toolbars['map'].OnTool(event)
+        self.toolbars['map'].action['desc'] = ''
         self.MapWindow.mouse['use'] = "pointer"
         self.MapWindow.mouse['box'] = "point"
         # change the cursor
         if self.toolbars['vdigit']:
             # digitization tool activated
@@ -2866,11 +2868,14 @@
         Zoom in the map.
         Set mouse cursor, zoombox attributes, and zoom direction
         self.MapWindow.mouse['use'] = "zoom"
         self.MapWindow.mouse['box'] = "box"
         self.MapWindow.zoomtype = 1
         self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
         # change the cursor
         self.MapWindow.SetCursor(self.cursors["cross"])
@@ -2879,11 +2884,14 @@
         Zoom out the map.
         self.MapWindow.zoomtype = -1
         # change the cursor
@@ -2897,11 +2905,13 @@
         Panning, set mouse to drag
         self.MapWindow.mouse['use'] = "pan"
         self.MapWindow.mouse['box'] = "pan"
         self.MapWindow.zoomtype = 0
-#        event.Skip()
         # change the cursor
         self.MapWindow.SetCursor(self.cursors["hand"])
@@ -3211,6 +3221,12 @@
         Query currrent raster/vector map layers (display mode)
+        if self.toolbars['map'].GetAction() == 'displayAttrb': # select previous action
+            self.toolbars['map'].SelectDefault(event)
+            return
+        self.toolbars['map'].action['desc'] = 'displayAttrb'
         # switch GIS Manager to output console to show query results
         self.gismanager.notebook.SetSelection(1)
@@ -3225,6 +3241,12 @@
         Query vector map layer (edit mode)
+        if self.toolbars['map'].GetAction() == 'modifyAttrb': # select previous action
+            return
+        self.toolbars['map'].action['desc'] = 'modifyAttrb'
         self.MapWindow.mouse['use'] = "queryVector"
@@ -3355,16 +3377,27 @@
     def OnQuery(self, event):
         """Query tools menu"""
+        action = self.toolbars['map'].GetAction()
         point = wx.GetMousePosition()
         toolsmenu = wx.Menu()
         # Add items to the menu
-        display = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["queryDisplay"].GetLabel())
+        display = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
+                              text=Icons["queryDisplay"].GetLabel(),
+                              kind=wx.ITEM_CHECK)
         toolsmenu.AppendItem(display)
         self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
-        modify = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["queryModify"].GetLabel())
+        if action == "displayAttrb":
+            display.Check(True)
+        modify = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
+                             text=Icons["queryModify"].GetLabel(),
         toolsmenu.AppendItem(modify)
         self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
+        if action == "modifyAttrb":
+            modify.Check(True)
         self.PopupMenu(toolsmenu)
         toolsmenu.Destroy()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-08-23 11:55:39 UTC (rev 33017)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-08-23 12:46:47 UTC (rev 33018)
@@ -39,9 +39,9 @@
 class AbstractToolbar(object):
     """Abstract toolbar class"""
-    def __init__():
+    def __init__(self):
         pass
     def InitToolbar(self, parent, toolbar, toolData):
         """Initialize toolbar, i.e. add tools to the toolbar
@@ -56,7 +56,6 @@
     def ToolbarData(self):
         """Toolbar data"""
         return None
     def CreateTool(self, parent, toolbar, tool, label, bitmap, kind,
@@ -95,13 +94,43 @@
                 self._toolbar.SetToolLongHelp(tool[0], tool[5])
             else:
                 self._toolbar.SetToolLongHelp(tool[0], "")
+    def OnTool(self, event):
+        """Tool selected"""
+        if event:
+            # deselect previously selected tool
+            id = self.action.get('id', -1)
+            if id != event.GetId():
+                self._toolbar.ToggleTool(self.action['id'], False)
+            else:
+                self._toolbar.ToggleTool(self.action['id'], True)
+            self.action['id'] = event.GetId()
+            event.Skip()
+        else:
+            # initialize toolbar
+    def GetAction(self, type='desc'):
+        """Get current action info"""
+        return self.action.get(type, '')
+    def SelectDefault(self, event):
+        """Select default tool"""
+        self._toolbar.ToggleTool(self.defaultAction['id'], True)
+        self.defaultAction['bind'](event)
+        self.action = { 'id' : self.defaultAction['id'],
+                        'desc' : self.defaultAction.get('desc', '') }
 class MapToolbar(AbstractToolbar):
     Main Map Display toolbar
     def __init__(self, mapdisplay, map):
+        AbstractToolbar.__init__(self)
         self.mapcontent = map
         self.mapdisplay = mapdisplay
@@ -120,10 +149,16 @@
         # realize the toolbar
         self.toolbar.Realize()
-        #workaround for Mac bug. May be fixed by 2.8.8, but not before then.
+        # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
         self.combo.Hide()
         self.combo.Show()
+        # default action
+        self.action = { 'id' : self.pointer }
+        self.defaultAction = { 'id' : self.pointer,
+                               'bind' : self.mapdisplay.OnPointer }
+        self.OnTool(None)
         """Toolbar data"""
@@ -155,19 +190,19 @@
              self.mapdisplay.OnErase),
             (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
+             wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
              self.mapdisplay.OnPointer),
             (self.query, "queryDisplay", Icons["queryDisplay"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["queryDisplay"].GetLabel(), Icons["queryDisplay"].GetDesc(),
+             wx.ITEM_CHECK, Icons["queryDisplay"].GetLabel(), Icons["queryDisplay"].GetDesc(),
              self.mapdisplay.OnQuery),
             (self.pan, "pan", Icons["pan"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+             wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
              self.mapdisplay.OnPan),
             (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+             wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
              self.mapdisplay.OnZoomIn),
             (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+             wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
              self.mapdisplay.OnZoomOut),
             (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
              wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
@@ -502,12 +537,16 @@
         id = self.parent.toolbars['map'].pointer
         self.parent.toolbars['map'].toolbar.ToggleTool(id, True)
         self.parent.toolbars['map'].mapdisplay.OnPointer(event)
         if event:
-            if self.action.has_key('id'):
                 self.toolbar[0].ToggleTool(self.action['id'], False)
+            else:
+                self.toolbar[0].ToggleTool(self.action['id'], True)
             event.Skip()
         else:
@@ -683,7 +722,7 @@
                            kind=wx.ITEM_CHECK)
         toolMenu.AppendItem(copy)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
-        if self.action['desc'] == "copyLine":
+        if self.toolbars['map'].GetAction() == "copyLine":
             copy.Check(True)
         flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
@@ -691,7 +730,7 @@
                            kind=wx.ITEM_CHECK)
         toolMenu.AppendItem(flip)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
-        if self.action['desc'] == "flipLine":
+        if self.toolbars['map'].GetAction() == "flipLine":
             flip.Check(True)
         merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
@@ -1058,10 +1097,6 @@
         """Get selected layer for editing -- MapLayer instance"""
         return self.mapLayer
-    def GetAction(self, type='desc'):
-        """Get current action info"""
-        return self.action[type]
 class ProfileToolbar(AbstractToolbar):
     Toolbar for profiling raster map
