[GRASS-SVN] r33032 - grass/branches/develbranch_6/vector/v.db.select
Sat Aug 23 16:37:32 EDT 2008
Author: martinl
Date: 2008-08-23 16:37:32 -0400 (Sat, 23 Aug 2008)
New Revision: 33032
   grass/branches/develbranch_6/vector/v.db.select/description.html
   grass/branches/develbranch_6/vector/v.db.select/main.c
v.db.select: flag to print minimal region extent instead of attribures added (used in wxGUI for "Highlight and zoom")
Modified: grass/branches/develbranch_6/vector/v.db.select/description.html
--- grass/branches/develbranch_6/vector/v.db.select/description.html	2008-08-23 14:29:20 UTC (rev 33031)
+++ grass/branches/develbranch_6/vector/v.db.select/description.html	2008-08-23 20:37:32 UTC (rev 33032)
@@ -3,11 +3,11 @@
 <em>v.db.select</em> prints attributes of a vector map from one or several
 user selected attribute table columns.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
 Select and show entire table:
 <div class="code"><pre>
-v.db.select roads
+v.db.select map=roads
 cat|label
 0|no data
 1|interstate
@@ -17,10 +17,10 @@
 5|unimproved road
 </pre></div>
-<p>
-Select and show single column from table (multiple columns can be specified as comma separated list):
+Select and show single column from table (multiple columns can be
+specified as comma separated list):
-v.db.select roads col=label
+v.db.select map=roads column=label
 label
 no data
 interstate
@@ -30,13 +30,25 @@
 unimproved road
 </pre></div>
+Print region extent of selected vector features:
+<div class="code"><pre>
+v.db.select -r map=roads where="label ~ 'highway'"
+n=4928063.398015
+s=4914089.153930
+w=589532.054964
+e=609527.210215
+</pre></div>
 <h2>SEE ALSO</h2>
 <em><a HREF="db.select.html">db.select</a></em>
 <h2>AUTHOR</h2>
-Radim Blazek, ITC-Irst, Trento, Italy
+Radim Blazek, ITC-Irst, Trento, Italy<br>
+Minimal region extent added by Martin Landa,
+FBK-irst (formerly ITC-irst), Trento, Italy (2008/08)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/vector/v.db.select/main.c
--- grass/branches/develbranch_6/vector/v.db.select/main.c	2008-08-23 14:29:20 UTC (rev 33031)
+++ grass/branches/develbranch_6/vector/v.db.select/main.c	2008-08-23 20:37:32 UTC (rev 33032)
@@ -31,7 +31,7 @@
     struct GModule *module;
     struct Option *map_opt, *field_opt, *fs_opt, *vs_opt, *nv_opt, *col_opt,
 	*where_opt;
-    struct Flag *c_flag, *v_flag;
+    struct Flag *c_flag, *v_flag, *r_flag;
     dbDriver *driver;
     dbString sql, value_string;
     dbCursor cursor;
@@ -43,7 +43,11 @@
     struct Map_info Map;
     char *mapset;
     char query[1024];
+    struct ilist *list_lines;
+    BOUND_BOX *min_box, *line_box;
+    int i, line, area, init_box, cat;
     module = G_define_module();
     module->keywords = _("vector, database, attribute table");
     module->description = _("Prints vector map attributes.");
@@ -57,25 +61,35 @@
     fs_opt = G_define_standard_option(G_OPT_F_SEP);
     fs_opt->description = _("Output field separator");
+    fs_opt->guisection = _("Format");
     vs_opt = G_define_standard_option(G_OPT_F_SEP);
     vs_opt->key = "vs";
     vs_opt->description = _("Output vertical record separator");
     vs_opt->answer = NULL;
+    vs_opt->guisection = _("Format");
     nv_opt = G_define_option();
     nv_opt->key = "nv";
     nv_opt->type = TYPE_STRING;
     nv_opt->required = NO;
     nv_opt->description = _("Null value indicator");
+    nv_opt->guisection = _("Format");
+    r_flag = G_define_flag();
+    r_flag->key = 'r';
+    r_flag->description =
+	_("Print minimal region extent of selected vector features instead");
     c_flag = G_define_flag();
     c_flag->key = 'c';
     c_flag->description = _("Do not include column names in output");
+    c_flag->guisection = _("Format");
     v_flag = G_define_flag();
     v_flag->key = 'v';
     v_flag->description = _("Vertical output (instead of horizontal)");
+    v_flag->guisection = _("Format");
     G_gisinit(argv[0]);
@@ -85,6 +99,18 @@
     /* set input vector map name and mapset */
     field = atoi(field_opt->answer);
+    if (r_flag->answer) {
+	min_box = (BOUND_BOX *) G_malloc(sizeof(BOUND_BOX));
+	G_zero((void *)min_box, sizeof(BOUND_BOX));
+	line_box = (BOUND_BOX *) G_malloc(sizeof(BOUND_BOX));
+	list_lines = Vect_new_list();
+    else {
+      min_box = line_box = NULL;
+      list_lines = NULL;
     db_init_string(&sql);
     db_init_string(&value_string);
@@ -93,7 +119,18 @@
 	G_fatal_error(_("Vector map <%s> not found"), map_opt->answer);
-    Vect_open_old_head(&Map, map_opt->answer, mapset);
+    if (!r_flag) {
+	Vect_open_old_head(&Map, map_opt->answer, mapset);
+    else {
+	if (2 > Vect_open_old(&Map, map_opt->answer, mapset)) {
+	    Vect_close(&Map);
+	    G_fatal_error(_("Unable to open vector map <%s> at topology level. "
+			   "Flag '%c' requires topology level."),
+			  G_fully_qualified_name(map_opt->answer, mapset),
+			  r_flag->key);
     if ((Fi = Vect_get_field(&Map, field)) == NULL)
 	G_fatal_error(_("Database connection not defined for layer %d"),
@@ -128,8 +165,8 @@
     table = db_get_cursor_table(&cursor);
     ncols = db_get_table_number_of_columns(table);
-    /* column names if horizontal output */
-    if (!v_flag->answer && !c_flag->answer) {
+    /* column names if horizontal output (ignore for -r) */
+    if (!v_flag->answer && !c_flag->answer && !r_flag->answer) {
 	for (col = 0; col < ncols; col++) {
 	    column = db_get_table_column(table, col);
 	    if (col)
@@ -139,6 +176,8 @@
 	fprintf(stdout, "\n");
+    init_box = 1;
     /* fetch the data */
     while (1) {
 	if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
@@ -148,9 +187,20 @@
 	if (!more)
 	    break;
+	cat = -1;
 	    value = db_get_column_value(column);
+	    if (cat < 0 && strcmp(Fi->key, db_get_column_name(column)) == 0) {
+		cat = db_get_value_int(value);
+		    break;
+		continue;
 	    db_convert_column_value_to_string(column, &value_string);
 	    if (!c_flag->answer && v_flag->answer)
@@ -168,12 +218,57 @@
 	    if (v_flag->answer)
-	if (!v_flag->answer)
-	    fprintf(stdout, "\n");
-	else if (vs_opt->answer)
-	    fprintf(stdout, "%s\n", vs_opt->answer);
+	    /* get minimal region extent */
+	    Vect_cidx_find_all(&Map, field, -1, cat, list_lines);
+	    for (i = 0; i < list_lines->n_values; i++) {
+		line = list_lines->value[i];
+		area = Vect_get_centroid_area(&Map, line);
+		if (area > 0) {
+		    if (!Vect_get_area_box(&Map, area, line_box))
+			G_fatal_error(_("Unable to get bounding box of area %d"),
+				      area);
+		else {
+		    if (!Vect_get_line_box(&Map, line, line_box))
+			G_fatal_error(_("Unable to get bounding box of line %d"),
+				      line);
+		if (init_box) {
+		    Vect_box_copy(min_box, line_box);
+		    init_box = 0;
+		else {
+		    Vect_box_extend(min_box, line_box);
+	else {
+	    if (!v_flag->answer)
+		fprintf(stdout, "\n");
+	    else if (vs_opt->answer)
+		fprintf(stdout, "%s\n", vs_opt->answer);
+	fprintf(stdout, "n=%f\n", min_box->N);
+	fprintf(stdout, "s=%f\n", min_box->S);
+	fprintf(stdout, "w=%f\n", min_box->W);
+	fprintf(stdout, "e=%f\n", min_box->E);
+	if (Vect_is_3d(&Map)) {
+	    fprintf(stdout, "t=%f\n", min_box->T);
+	    fprintf(stdout, "b=%f\n", min_box->B);
+	fflush(stdout);
+	G_free((void *)min_box);
+	G_free((void *)line_box);
+	Vect_destroy_list(list_lines);
     if (!driver)
 	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 		      Fi->database, Fi->driver);
