[GRASS-SVN] r33065 - grass/trunk/gui/wxpython/gui_modules
Mon Aug 25 11:17:19 EDT 2008
Author: martinl
Date: 2008-08-25 11:17:19 -0400 (Mon, 25 Aug 2008)
New Revision: 33065
   grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: snapping value -1 -> calculate from computational resolution
(merge from devbr6, r33064)
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py	2008-08-25 15:02:05 UTC (rev 33064)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py	2008-08-25 15:17:19 UTC (rev 33065)
@@ -2080,18 +2080,27 @@
         value = self.snappingValue.GetValue()
         if value < 0:
-            self.snappingInfo.SetLabel(_("No limit for snapping"))
-            return
+            region = self.parent.MapWindow.Map.GetRegion()
+            res = (region['nsres'] + region['ewres']) / 2.
+            threshold = self.parent.digit.driver.GetThreshold(value=res)
+        else:
+            if self.snappingUnit.GetStringSelection() == "map units":
+                threshold = value
+            else:
+                threshold = self.parent.digit.driver.GetThreshold(value=value)
+        if value == 0:
+            self.snappingInfo.SetLabel(_("Snapping disabled"))
+        elif value < 0:
+            self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s "
+                                         "(based on computation resolution)") %
+                                       {'value' : threshold,
+                                        'units' : self.mapUnits.lower()})
+        else:
+            self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
-        if self.snappingUnit.GetStringSelection() == "map units":
-            threshold = value
-        else:
-            threshold = self.parent.digit.driver.GetThreshold(value=value)
-        self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
-                                   {'value' : threshold,
-                                    'units' : self.mapUnits})
         event.Skip()
     def OnChangeSnappingUnits(self, event):
