[GRASS-SVN] r33075 - grass/trunk/lib/init
Mon Aug 25 20:54:44 EDT 2008
Author: glynn
Date: 2008-08-25 20:54:44 -0400 (Mon, 25 Aug 2008)
New Revision: 33075
Added:
   grass/trunk/lib/init/functions.sh
   grass/trunk/lib/init/Makefile
   grass/trunk/lib/init/grass-xterm-mac
   grass/trunk/lib/init/init.sh
Restructure Init.sh, remove references to dead code (d.m, set_data, d.mon)
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile	2008-08-25 23:40:20 UTC (rev 33074)
+++ grass/trunk/lib/init/Makefile	2008-08-26 00:54:44 UTC (rev 33075)
@@ -32,6 +32,7 @@
 FILES = \
 	$(ARCH_BINDIR)/$(START_UP) \
 	$(ETC)/Init.sh \
+	$(ETC)/functions.sh \
 	$(ETC)/prompt.sh \
 	$(ETC)/clean_temp$(EXE) \
 	$(ETC)/lock$(EXE) \
@@ -84,13 +85,10 @@
 $(ETC)/Init.sh: init.sh
 	rm -f $@
 	$(SHELL) -c "sed \
-	-e \"s#GRASS_VERSION_NUMBER#$(GRASS_VERSION_NUMBER)#\" \
-	-e \"s#GRASS_VERSION_DATE#$(GRASS_VERSION_DATE)#\" \
-	-e \"s#GRASS_VERSION_UPDATE_PKG#$(GRASS_VERSION_UPDATE)#\" \
-	-e \"s#LD_LIBRARY_PATH_VAR#$(LD_LIBRARY_PATH_VAR)#g\" \
-	-e \"s#PERL_COMMAND#$(PERL)#\" \
-	-e \"s#START_UP#$(START_UP)#\" \
-	-e \"s#CONFIG_PROJSHARE#$(PROJSHARE)#\" \
+	-e \"s#@GRASS_VERSION_NUMBER@#$(GRASS_VERSION_NUMBER)#\" \
+	-e \"s#@LD_LIBRARY_PATH_VAR@#$(LD_LIBRARY_PATH_VAR)#g\" \
+	-e \"s#@START_UP@#$(START_UP)#\" \
+	-e \"s#@CONFIG_PROJSHARE@#$(PROJSHARE)#\" \
 	init.sh > $@"
 	chmod +x $@
@@ -102,6 +100,9 @@
 	chmod +x $@
+$(ETC)/functions.sh: functions.sh
+	$(INSTALL_DATA) $< $@
 $(ETC)/echo$(EXE) $(ETC)/run$(EXE): $(ETC)/%$(EXE): $(OBJDIR)/%.o
 	$(CC) $(LDFLAGS) $< -o $@
Added: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh	                        (rev 0)
+++ grass/trunk/lib/init/functions.sh	2008-08-26 00:54:44 UTC (rev 33075)
@@ -0,0 +1,798 @@
+# all exits after setting up $tmp should also tidy it up
+cleanup_tmpdir()
+    # remove session files from tmpdir
+    rm -rf "$tmp"
+help_message()
+    cat <<-EOF
+	Usage:
+	  $CMD_NAME [-h | -help | --help] [-v | --version] [-c]
+		  [-text | -gui | -tcltk | -wxpython]
+		  [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
+	Flags:
+	  -h or -help or --help          print this help message
+	  -v or --version                show version information and exit
+	  -c                             create given mapset if it doesn\'t exist
+	  -text                          use text based interface
+	                                   and set as default
+	  -gui                           use graphical user interface ($DEFAULT_GUI by default)
+	  -tcltk                         use Tcl/Tk based graphical user interface
+	  -wxpython                      use wxPython based graphical user interface
+	Parameters:
+	  GISDBASE                       initial database (path to GIS data)
+	  LOCATION_NAME                  initial location
+	  MAPSET                         initial mapset
+	  GISDBASE/LOCATION_NAME/MAPSET  fully qualified initial mapset directory
+	Environment variables relevant for startup:
+	  GRASS_GUI                      select GUI (text, gui, tcltk, wxpython)
+	  GRASS_WISH                     set wish shell name to override 'wish'
+	  GRASS_HTML_BROWSER             set html web browser for help pages
+	  GRASS_ADDON_PATH               set additional path(s) to local GRASS modules
+	  GRASS_BATCH_JOB                shell script to be processed as batch job
+	  GRASS_PYTHON                   set python shell name to override 'python'
+	EOF
+create_tmp()
+## use TMPDIR if it exists, otherwise /tmp
+    tmp="${TMPDIR-/tmp}/grass7-$USER-$GIS_LOCK"
+    (umask 077 && mkdir "$tmp") || (
+	echo "Cannot create temporary directory! Exiting." 1>&2
+	exit 1
+create_gisrc()
+    # Set the session grassrc file
+    GISRC="$tmp/gisrc"
+    export GISRC
+    # remove invalid GISRC file to avoid disturbing error messages:
+    cat "$GISRCRC" 2>/dev/null| grep UNKNOWN >/dev/null
+    if [ $? -eq 0 ] ; then
+       rm -f "$GISRCRC"
+    fi
+    # Copy the global grassrc file to the session grassrc file
+    if [ -f "$GISRCRC" ] ; then
+	cp "$GISRCRC" "$GISRC"
+	if [ $? -eq 1 ] ; then
+	    echo "Cannot copy '$GISRCRC' to '$GISRC'"
+	    cleanup_tmpdir
+	    exit 1
+	fi
+    fi
+read_gui()
+    # At this point the GRASS user interface variable has been set from the
+    # command line, been set from an external environment variable, or is
+    # not set. So we check if it is not set
+    if [ ! "$GRASS_GUI" ] ; then
+	# Check for a reference to the GRASS user interface in the grassrc file
+	if [ -f "$GISRC" ] ; then
+	    GRASS_GUI=`awk '/GRASS_GUI/ {print $2}' "$GISRC"`
+	fi
+	# Set the GRASS user interface to the default if needed
+	    GRASS_GUI="$DEFAULT_GUI"
+	fi
+    fi
+    if [ "$GRASS_GUI" = "gui" ] ; then
+    fi
+    # d.m no longer exists
+    case "$GRASS_GUI" in
+    d.m | oldtcltk)
+	GRASS_GUI=gis.m
+    esac
+get_locale()
+    if [ "$LC_ALL" ] ; then
+	LCL=`echo "$LC_ALL" | sed 's/\(..\)\(.*\)/\1/'`
+    elif [ "$LC_MESSAGES" ] ; then
+	LCL=`echo "$LC_MESSAGES" | sed 's/\(..\)\(.*\)/\1/'`
+    else
+	LCL=`echo "$LANG" | sed 's/\(..\)\(.*\)/\1/'`
+    fi
+set_paths()
+    if [ -n "$GRASS_ADDON_PATH" ] ; then
+	PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:$PATH"
+    else
+	PATH="$GISBASE/bin:$GISBASE/scripts:$PATH"
+    fi
+    export PATH
+    # Set LD_LIBRARY_PATH to find GRASS shared libraries
+    if [ ! "GRASS_LD_LIBRARY_PATH" ] ; then
+	GRASS_LD_LIBRARY_PATH="$GISBASE/lib"
+    else
+	GRASS_LD_LIBRARY_PATH="$GISBASE/lib:$GRASS_LD_LIBRARY_PATH"
+    fi
+# Set PYTHONPATH to find GRASS Python modules
+if [ ! "PYTHONPATH" ] ; then
+  PYTHONPATH="$GISBASE/etc/python"
+else
+  PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
+fi
+export PYTHONPATH
+set_defaults()
+    # GRASS_PAGER
+    if [ ! "$GRASS_PAGER" ] ; then
+	if [ -x /bin/more ] || [ -x /usr/bin/more ] ; then
+	    GRASS_PAGER=more
+	elif [ -x /bin/less ] || [ -x /usr/bin/less ] ; then
+	    GRASS_PAGER=less
+	elif [ "$MINGW" ] ; then
+	    GRASS_PAGER=more
+	else
+	    GRASS_PAGER=cat
+	fi
+	export GRASS_PAGER
+    fi
+    # GRASS_WISH
+    if [ ! "$GRASS_WISH" ] ; then
+	GRASS_WISH=wish
+	export GRASS_WISH
+    fi
+    # GRASS_PYTHON
+    if [ ! "$GRASS_PYTHON" ] ; then
+	GRASS_PYTHON=python
+	export GRASS_PYTHON
+    fi
+    # GRASS_GNUPLOT
+    if [ ! "$GRASS_GNUPLOT" ] ; then
+	GRASS_GNUPLOT="gnuplot -persist"
+	export GRASS_GNUPLOT
+    fi
+set_browser()
+    # GRASS_HTML_BROWSER
+    if [ ! "$GRASS_HTML_BROWSER" ] ; then
+	if [ "$MACOSX" ] ; then
+	    # OSX doesn't execute browsers from the shell PATH - route thru a script
+	    GRASS_HTML_BROWSER="$ETC/html_browser_mac.sh"
+	    GRASS_HTML_BROWSER_MACOSX="-b com.apple.helpviewer"
+	    export GRASS_HTML_BROWSER_MACOSX
+	elif [ "$MINGW" -o "$CYGWIN" ] ; then
+	    # MinGW startup moved to into init.bat
+	    iexplore="$SYSTEMDRIVE/Program Files/Internet Explorer/iexplore.exe"
+	    if [ -f "$iexplore" ] ; then
+		GRASS_HTML_BROWSER=$iexplore
+	    else
+		GRASS_HTML_BROWSER="iexplore"
+	    fi
+	else
+	    # the usual suspects
+	    BROWSERS="htmlview konqueror mozilla mozilla-firefox firefox opera netscape dillo"
+	    for BROWSER in $BROWSERS ; do
+		for i in `echo "$PATH" | sed 's/^:/.:/ ; s/::/:.:/g ; s/:$/:./ ; s/:/ /g'` ; do
+		    if [ -f "$i/$BROWSER" ] ; then
+			GRASS_HTML_BROWSER="$BROWSER"
+			break
+		    fi
+		done
+		if [ -n "$GRASS_HTML_BROWSER" ] ; then
+		    break
+		fi
+	    done
+	fi
+    fi
+    if [ "$MACOSX" -a "$GRASS_HTML_BROWSER" != "" ] ; then
+	GRASS_HTML_BROWSER_MACOSX="-b $GRASS_HTML_BROWSER"
+    fi
+	echo "WARNING: Searched for a web browser, but none found." 1>&2
+	# even so we set konqueror to make lib/gis/parser.c happy:
+	GRASS_HTML_BROWSER=konqueror
+    fi
+grass_intro()
+    if [ ! -f "$GISBASE/locale/$LCL/etc/grass_intro" ] ; then
+	cat "$ETC/grass_intro"
+    else
+	cat "$GISBASE/locale/$LCL/etc/grass_intro"
+    fi
+    echo
+    echo "Hit RETURN to continue"
+    read ans
+    #for convenience, define pwd as GISDBASE:
+    cat > "$GISRC" <<-EOF
+	GISDBASE: $PWD
+	LOCATION_NAME: <UNKNOWN>
+	MAPSET: <UNKNOWN>
+	EOF
+check_gui()
+    # Check if we are running X windows by checking the DISPLAY variable
+    if [ "$DISPLAY" -o "$MINGW" ] ; then
+	# Check if python is working properly
+	if [ "$GRASS_GUI" = "wxpython" ]; then
+	    echo 'variable=True' | "$GRASS_PYTHON" >/dev/null 2>&1
+	fi
+	# Check if we need to find wish
+	if [ "$GRASS_GUI" = "tcltk" ] || \
+	    [ "$GRASS_GUI" = "gis.m" ] ; then
+	    # Check if wish is working properly
+	    echo 'exit 0' | "$GRASS_WISH" >/dev/null 2>&1
+	fi
+	# ok
+	if [ "$?" = 0 ] ; then
+	    # Set the tcltkgrass base directory
+	    TCLTKGRASSBASE="$ETC"
+	    # Set the wxpython base directory
+	    WXPYTHONGRASSBASE="$ETC/wxpython"
+	else
+	    # Wish was not found - switch to text interface mode
+	    cat <<-EOF
+		WARNING: The wish command does not work as expected!
+		Please check your GRASS_WISH environment variable.
+		Use the -help option for details.
+		Switching to text based interface mode.
+		Hit RETURN to continue.
+		EOF
+	    read ans
+	    GRASS_GUI="text"
+	fi
+    else
+	# Display a message if a graphical interface was expected
+	if [ "$GRASS_GUI" != "text" ] ; then
+	    # Set the interface mode to text
+	    cat <<-EOF
+		WARNING: It appears that the X Windows system is not active.
+		A graphical based user interface is not supported.
+		EOF
+	    read ans
+	    GRASS_GUI="text"
+	fi
+    fi
+    # Save the user interface variable in the grassrc file - choose a temporary
+    # file name that should not match another file
+	awk '$1 !~ /GRASS_GUI/ {print}' "$GISRC" > "$GISRC.$$"
+	echo "GRASS_GUI: $GRASS_GUI" >> "$GISRC.$$"
+	mv -f "$GISRC.$$" "$GISRC"
+    fi
+non_interactive()
+    # Try non-interactive startup
+    L=
+    if [ "$1" = "-" ] ; then
+	if [ "$LOCATION" ] ; then
+	    L="$LOCATION"
+	fi
+    else
+	L="$1"
+    fi
+    if [ "$L" ] ; then
+	if [ "$L" = "." ] ; then
+	    L=$PWD
+	elif [ `echo "$L" | cut -c 1` != "/" ] ; then
+	    L="$PWD/$L"
+	fi
+	MAPSET=`basename "$L"`
+	L=`dirname "$L"`
+	if [ "$L" != "." ] ; then
+	    LOCATION_NAME=`basename "$L"`
+	    L=`dirname "$L"`
+		GISDBASE="$L"
+	    fi
+	fi
+    fi
+    #strip off white space from LOCATION_NAME and MAPSET: only supported for $GISDBASE
+    MAPSET=`echo $MAPSET | sed 's+ ++g'`
+    LOCATION_NAME=`echo $LOCATION_NAME | sed 's+ ++g'`
+    if [ "$GISDBASE" -a "$LOCATION_NAME" -a "$MAPSET" ] ; then
+	LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
+	if [ ! -r "$LOCATION/WIND" ] ; then
+	    if [ "$LOCATION_NAME" = "PERMANENT" ] ; then
+		echo "$LOCATION: Not a valid GRASS location"
+		cleanup_tmpdir
+		exit 1
+	    else
+		   # the user wants to create mapset on the fly
+		if [ -n "$CREATE_NEW" ] && [ "$CREATE_NEW" -eq 1 ] ; then
+		    if [ ! -f "$GISDBASE/$LOCATION_NAME/PERMANENT/DEFAULT_WIND" ] ; then
+			echo "The LOCATION \"$LOCATION_NAME\" does not exist. Please create it first"
+			cleanup_tmpdir
+			exit 1
+		    else
+			mkdir -p "$LOCATION"
+			cp "$GISDBASE/$LOCATION_NAME/PERMANENT/DEFAULT_WIND" "$LOCATION/WIND"
+			echo "Missing WIND file fixed"
+		    fi
+		else
+		    cleanup_tmpdir
+		    exit 1
+		fi
+	    fi
+	fi
+	if [ -s "$GISRC" ] ; then
+	    sed -e "s|^GISDBASE:.*$|GISDBASE: $GISDBASE|; \
+		s|^LOCATION_NAME:.*$|LOCATION_NAME: $LOCATION_NAME|; \
+		s|^MAPSET:.*$|MAPSET: $MAPSET|" "$GISRC" > "$GISRC.$$"
+	    else
+		rm -f "$GISRC.$$"
+		echo "Failed to create new $GISRC"
+		LOCATION=
+	    fi
+	else
+		GISDBASE: $GISDBASE
+		LOCATION_NAME: $LOCATION_NAME
+		MAPSET: $MAPSET
+		EOF
+	fi
+    else
+	echo "GISDBASE, LOCATION_NAME and MAPSET variables not set properly."
+	echo "Interactive startup needed."
+	cleanup_tmpdir
+	exit 1
+    fi
+set_data()
+    # User selects LOCATION and MAPSET if not set
+    if [ ! "$LOCATION" ] ; then
+	    # Check for text interface
+	    text)
+	    # Check for GUI
+	    tcltk | gis.m | wxpython)
+		gui_startup
+		# Shouldn't need this but you never know
+		echo "ERROR: Invalid user interface specified - <$GRASS_GUI>."
+		echo "Use the --help option to see valid interface names."
+		cleanup_tmpdir
+		exit 1
+	esac
+    fi
+gui_startup()
+    if [ "$GRASS_GUI" = "tcltk" ] || [ "$GRASS_GUI" = "gis.m" ] ; then
+		# eval `foo` will return subshell return code and not app foo return code!!!
+	eval '"$GRASS_WISH" -file "$TCLTKGRASSBASE/gis_set.tcl"'
+	thetest=$?
+    else
+	eval '"$GRASS_PYTHON" "$WXPYTHONGRASSBASE/gis_set.py"'
+	thetest=$?
+    fi
+    case $thetest in
+	1)
+	    # The gis_set.tcl script printed an error message so wait
+	    # for user to read it
+	    cat <<-EOF
+		Error in GUI startup. If necessary, please
+		report this error to the GRASS developers.
+		Switching to text mode now.
+		Hit RETURN to continue...
+		EOF
+	    read ans
+	    exec "$CMD_NAME" -text
+	    cleanup_tmpdir
+	    exit 1
+	0)
+	    # These checks should not be necessary with real init stuff
+	    if [ "$LOCATION_NAME" = "##NONE##" ] || [ "$LOCATION_NAME" = "##ERROR##" ] ; then
+		echo "The selected location is not a valid GRASS location"
+		cleanup_tmpdir
+		exit 1
+	    fi
+	2)
+	    # User wants to exit from GRASS
+	    echo "Received EXIT message from GUI."
+	    echo "GRASS is not started. Bye."
+	    cleanup_tmpdir
+	    exit 0
+	    echo "ERROR: Invalid return code from gis_set.tcl."
+	    echo "Please advise GRASS developers of this error."
+	    cleanup_tmpdir
+	    exit 1
+    esac
+read_gisrc()
+    GISDBASE=`g.gisenv GISDBASE`
+    LOCATION_NAME=`g.gisenv LOCATION_NAME`
+    MAPSET=`g.gisenv MAPSET`
+    if [ -z "$GISDBASE" ] || [ -z "$LOCATION_NAME" ] || [ -z "$MAPSET" ] ; then
+	cat <<-EOF
+	ERROR: Reading data path information from g.gisenv.
+	GISDBASE=[$GISDBASE]
+	LOCATION_NAME=[$LOCATION_NAME]
+	MAPSET=[$MAPSET]
+	Check the <$GISRCRC> file.
+	EOF
+	cleanup_tmpdir
+	exit 1
+    fi
+    LOCATION="${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}"
+check_lock()
+    # Check for concurrent use
+    lockfile="$LOCATION/.gislock"
+    "$ETC/lock" "$lockfile" $$
+    case $? in
+	0) ;;
+	1)
+	    echo "$USER is currently running GRASS in selected mapset (file $lockfile found). Concurrent use not allowed."
+	    cleanup_tmpdir
+	    exit 1 ;;
+	    echo Unable to properly access "$lockfile"
+	    echo Please notify system personel.
+	    cleanup_tmpdir
+	    exit 1 ;;
+    esac
+make_fontcap()
+if [ "$GRASS_FONT_CAP" ] && [ ! -f "$GRASS_FONT_CAP" ] ; then
+	echo "Building user fontcap ..."
+	g.mkfontcap
+fi
+check_shell()
+    # cygwin has many problems with the shell setup
+    # below, so i hardcoded everything here.
+    if [ "$CYGWIN" ] ; then
+        sh="cygwin"
+        shellname="GNU Bash (Cygwin)"
+        export SHELL=/usr/bin/bash.exe
+        export OSTYPE=cygwin
+    else
+        sh=`basename "$SHELL"`
+        case "$sh" in
+            ksh)  shellname="Korn Shell";;
+            csh)  shellname="C Shell" ;;
+            tcsh) shellname="TC Shell" ;;
+            bash) shellname="Bash Shell" ;;
+            sh)   shellname="Bourne Shell";;
+            *)    shellname=shell;;
+        esac
+    fi
+    # check for SHELL
+    if [ ! -x "$SHELL" ] ; then
+        echo "ERROR: The SHELL variable is not set" 1>&2
+        rm -f "$lockfile"
+        cleanup_tmpdir
+        exit 1
+    fi
+check_batch_job()
+    # hack to process batch jobs:
+    if [ -n "$GRASS_BATCH_JOB" ] ; then
+       # defined, but ...
+       if [ ! -f "$GRASS_BATCH_JOB" ] ; then
+          # wrong file
+          echo "Job file '$GRASS_BATCH_JOB' has been defined in"
+          echo "the 'GRASS_BATCH_JOB' variable but not found. Exiting."
+          echo
+          echo "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
+          cleanup_tmpdir
+          exit 1
+       else
+          # right file, but ...
+          if [ ! -x "$GRASS_BATCH_JOB" ] ; then
+             echo "Please change file permission to 'executable' for '$GRASS_BATCH_JOB'"
+             cleanup_tmpdir
+             exit 1
+          else
+             echo "Executing '$GRASS_BATCH_JOB' ..."
+             GRASS_GUI="text"
+             SHELL="$GRASS_BATCH_JOB"
+          fi
+       fi
+    fi
+start_gui()
+    # Start the chosen GUI but ignore text
+    if [ "$GRASS_DEBUG" -ne 0 ] ; then
+       echo "GRASS GUI should be $GRASS_GUI"
+    fi
+        # Check for tcltk interface
+        tcltk | gis.m)
+            "$GISBASE/scripts/gis.m"
+        wxpython)
+            "$GISBASE/etc/wxpython/scripts/wxgui"
+        # Ignore others
+    esac
+clear_screen()
+if [ "$MINGW" ] ; then
+# TODO: uncomment when PDCurses works.
+#	cls
+else
+	if [ -z "$GRASS_BATCH_JOB" ] && [ "$GRASS_DEBUG" -eq 0 ] ; then
+	   tput clear
+	fi
+fi
+show_banner()
+    cat <<EOF
+          __________  ___   __________    _______________
+         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
+        / / __/ /_/ / /| | \__ \\\\_  \\   / / __ / / \\__ \\
+       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
+       \____/_/ |_/_/  |_/____/____/   \____/___//____/
+EOF
+say_hello()
+    if [ -f "$GISBASE/locale/$LCL/etc/welcome" ] ; then
+	cat "$GISBASE/locale/$LCL/etc/welcome"
+    else
+	cat "$ETC/welcome"
+    fi
+show_info()
+    cat <<-EOF
+	GRASS homepage:                          http://grass.osgeo.org/
+	This version running through:            $shellname ($SHELL)
+	Help is available with the command:      g.manual -i
+	See the licence terms with:              g.version -c
+	EOF
+    tcltk | gis.m)
+        echo "If required, restart the GUI with:       g.gui tcltk"
+    wxpython)
+        echo "If required, restart the GUI with:       g.gui wxpython"
+        echo "Start the GUI with:                      g.gui $DEFAULT_GUI"
+    esac
+    echo "When ready to quit enter:                exit"
+    echo
+csh_startup()
+    USERHOME="$HOME"      # save original home
+    HOME="$LOCATION"
+    export HOME
+    cshrc="$HOME/.cshrc"
+    tcshrc="$HOME/.tcshrc"
+    rm -f "$cshrc" "$tcshrc"
+    echo "set home = $USERHOME" > "$cshrc"
+    echo "set history = 3000 savehist = 3000  noclobber ignoreeof" >> "$cshrc"
+    echo "set histfile = $HOME/.history" >> "$cshrc"
+    echo "set prompt = '\\" >> "$cshrc"
+    echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >> "$cshrc"
+    echo "GRASS $GRASS_VERSION > '" >> "$cshrc"
+    echo 'set BOGUS=``;unset BOGUS' >> "$cshrc"
+    if [ -r "$USERHOME/.grass.cshrc" ]
+    then
+	cat "$USERHOME/.grass.cshrc" >> "$cshrc"
+    fi
+    if [ -r "$USERHOME/.cshrc" ]
+    then
+	grep '^ *set  *mail *= *' "$USERHOME/.cshrc" >> "$cshrc"
+    fi
+    if [ -r "$USERHOME/.tcshrc" ]
+    then
+	grep '^ *set  *mail *= *' "$USERHOME/.tcshrc" >> "$cshrc"
+    fi
+    if [ -r "$USERHOME/.login" ]
+    then
+	grep '^ *set  *mail *= *' "$USERHOME/.login" >> "$cshrc"
+    fi
+    echo "set path = ( $PATH ) " | sed 's/:/ /g' >> "$cshrc"
+    cp "$cshrc" "$tcshrc"
+    "$ETC/run" "$SHELL"
+    EXIT_VAL=$?
+    HOME="$USERHOME"
+    export HOME
+bash_startup()
+    # save command history in mapset dir and remember more
+    export HISTFILE="$LOCATION/.bash_history"
+    if [ -z "$HISTSIZE" ] && [ -z "$HISTFILESIZE" ] ; then
+	export HISTSIZE=3000
+    fi
+    # instead of changing $HOME, start bash with: --rcfile "$LOCATION/.bashrc" ?
+    #   if so, must care be taken to explicity call .grass.bashrc et al for
+    #   non-interactive bash batch jobs?
+    HOME="$LOCATION"      # save .bashrc in $LOCATION
+    export HOME
+    bashrc="$HOME/.bashrc"
+    rm -f "$bashrc"
+    echo "test -r ~/.alias && . ~/.alias" >> "$bashrc"
+    echo "PS1='$GRASS GRASS_VERSION ($LOCATION_NAME):\w > '" >> "$bashrc"
+    echo "PROMPT_COMMAND=$GISBASE/etc/prompt.sh" >> "$bashrc"
+    if [ -r "$USERHOME/.grass.bashrc" ]
+    then
+        cat "$USERHOME/.grass.bashrc" >> "$bashrc"
+    fi
+    echo "export PATH=\"$PATH\"" >> "$bashrc"
+    echo "export HOME=\"$USERHOME\"" >> "$bashrc" # restore user home path
+    EXIT_VAL=$?
+    HOME="$USERHOME"
+    export HOME
+default_startup()
+    PS1="GRASS $GRASS_VERSION ($LOCATION_NAME):\w > "
+    export PS1
+    if [ "$MINGW" ] ; then
+	# "$ETC/run" doesn't work at all???
+        "$SHELL"
+	rm -rf "$LOCATION/.tmp"/*  # remove gis.m session files from .tmp
+    else
+	EXIT_VAL=$?
+    fi
+done_message()
+    if [ -x "$GRASS_BATCH_JOB" ] ; then
+        echo "Batch job '$GRASS_BATCH_JOB' (defined in GRASS_BATCH_JOB variable) was executed."
+        echo "Goodbye from GRASS GIS"
+	exit $EXIT_VAL
+    else
+        echo "Done."
+        echo
+        echo
+    fi
+clean_temp()
+    echo "Cleaning up temporary files ..."
+    "$ETC/clean_temp" > /dev/null
Modified: grass/trunk/lib/init/grass-xterm-mac
--- grass/trunk/lib/init/grass-xterm-mac	2008-08-25 23:40:20 UTC (rev 33074)
+++ grass/trunk/lib/init/grass-xterm-mac	2008-08-26 00:54:44 UTC (rev 33075)
@@ -9,46 +9,48 @@
 if [ "$SYSTEMOSX" ] ; then
     # manually transfer the necessary env vars
     TMPSCRIPT="/tmp/grassxterm_$$"
-    touch "$TMPSCRIPT.sh"
+	cat <<-EOF
+	#!/bin/sh
+	DISPLAY="$DISPLAY"
+	PATH="$PATH"
+	GIS_LOCK="$GIS_LOCK"
+	GISRC="$GISRC"
+	GISBASE="$GISBASE"
+	GRASS_VERSION="$GRASS_VERSION"
+	GRASS_PAGER="$GRASS_PAGER"
+	DYLD_LIBRARY_PATH="$DYLD_LIBRARY_PATH"
+	GRASS_WISH="$GRASS_WISH"
+	GRASS_TCLSH="$GRASS_TCLSH"
+	GRASS_HTML_BROWSER="$GRASS_HTML_BROWSER"
+	GRASS_HTML_BROWSER_MACOSX="$GRASS_HTML_BROWSER_MACOSX"
+	export DISPLAY PATH GIS_LOCK GISRC GISBASE GRASS_VERSION GRASS_PAGER DYLD_LIBRARY_PATH GRASS_LD_LIBRARY_PATH GRASS_WISH GRASS_TCLSH GRASS_HTML_BROWSER GRASS_HTML_BROWSER_MACOSX
+	EOF
+	if [ "$GRASS_ADDON_PATH" ] ; then
+	    echo "GRASS_ADDON_PATH=\"$GRASS_ADDON_PATH\""
+	    echo "export GRASS_ADDON_PATH"
+	fi
+	if [ "$TCL_LIBRARY" ] ; then
+	    echo "TCL_LIBRARY=\"$TCL_LIBRARY\""
+	    echo "export TCL_LIBRARY"
+	fi
+	if [ "$TK_LIBRARY" ] ; then
+	    echo "TK_LIBRARY=\"$TK_LIBRARY\""
+	    echo "export TK_LIBRARY"
+	fi
+	# get command, ignore all other xterm flags
+	while true ; do
+	    if [ "$1" = "-e" ] ; then break ; fi
+	    shift
+	done
+	shift
+	# and add it to end of script
+	echo "$@"
+    ) > "$TMPSCRIPT.sh"
     chmod +x "$TMPSCRIPT.sh"
-    echo "#!/bin/sh" > "$TMPSCRIPT.sh"
-    echo "DISPLAY=$DISPLAY" >> "$TMPSCRIPT.sh"
-    echo "PATH=\"$PATH\"" >> "$TMPSCRIPT.sh"
-    echo "GIS_LOCK=\"$GIS_LOCK\"" >> "$TMPSCRIPT.sh"
-    echo "GISRC=\"$GISRC\"" >> "$TMPSCRIPT.sh"
-    echo "GISBASE=\"$GISBASE\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_VERSION=\"$GRASS_VERSION\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_PAGER=$GRASS_PAGER" >> "$TMPSCRIPT.sh"
-    echo "DYLD_LIBRARY_PATH=\"$DYLD_LIBRARY_PATH\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_LD_LIBRARY_PATH=\"$GRASS_LD_LIBRARY_PATH\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_WISH=\"$GRASS_WISH\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_TCLSH=\"$GRASS_TCLSH\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_HTML_BROWSER=\"$GRASS_HTML_BROWSER\"" >> "$TMPSCRIPT.sh"
-    echo "GRASS_HTML_BROWSER_MACOSX=\"$GRASS_HTML_BROWSER_MACOSX\"" >> "$TMPSCRIPT.sh"
-    echo "export DISPLAY PATH GIS_LOCK GISRC GISBASE GRASS_VERSION GRASS_PAGER DYLD_LIBRARY_PATH GRASS_LD_LIBRARY_PATH GRASS_WISH GRASS_TCLSH GRASS_HTML_BROWSER GRASS_HTML_BROWSER_MACOSX" >> "$TMPSCRIPT.sh"
-    if [ "$GRASS_ADDON_PATH" ] ; then
-        echo "GRASS_ADDON_PATH=\"$GRASS_ADDON_PATH\"" >> "$TMPSCRIPT.sh"
-        echo "export GRASS_ADDON_PATH" >> "$TMPSCRIPT.sh"
-    fi
-    if [ "$TCL_LIBRARY" ] ; then
-        echo "TCL_LIBRARY=\"$TCL_LIBRARY\"" >> "$TMPSCRIPT.sh"
-        echo "export TCL_LIBRARY" >> "$TMPSCRIPT.sh"
-    fi
-    if [ "$TK_LIBRARY" ] ; then
-        echo "TK_LIBRARY=\"$TK_LIBRARY\"" >> "$TMPSCRIPT.sh"
-        echo "export TK_LIBRARY" >> "$TMPSCRIPT.sh"
-    fi
-    # get command, ignore all other xterm flags
-    while true ; do
-        if [ "$1" = "-e" ] ; then break ; fi
-        shift
-    done
-    shift
-    # and add it to end of script
-    echo "$@" >> "$TMPSCRIPT.sh"
     # execute
     # save current active app/window, return to it when script finishes.
     osascript - <<EOF
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh	2008-08-25 23:40:20 UTC (rev 33074)
+++ grass/trunk/lib/init/init.sh	2008-08-26 00:54:44 UTC (rev 33075)
@@ -24,6 +24,8 @@
 trap "echo 'User break!' ; exit" 2 3 15
+source "$GISBASE/etc/functions.sh"
 # Set default GUI
 DEFAULT_GUI="wxpython"
@@ -33,21 +35,17 @@
    GRASS_DEBUG=0
 fi
-# Set the GRASS_PERL variable
-GRASS_PERL=PERL_COMMAND
-export GRASS_PERL
 # GRASS_SH is normally just for Windows when not started from a bourne
 # shell. But when starting from Init.sh is still needed for Tcl/Tk.
 GRASS_SH=/bin/sh
 export GRASS_SH
 # Set GRASS version number for R interface etc (must be an env_var for MS-Windows)
-GRASS_VERSION="GRASS_VERSION_NUMBER"
+GRASS_VERSION="@GRASS_VERSION_NUMBER@"
 export GRASS_VERSION
 # Get the command name
-CMD_NAME=START_UP
+CMD_NAME=@START_UP@
 # Get the system name
 SYSTEM=`uname -s`
@@ -63,97 +61,6 @@
 esac
-# Go through the command line options
-for i in "$@" ; do
-    # Use a case to check the command line options
-    case "$i" in
-    	# Check if the user asked for the version
-	-v|--version)
-	    cat "$GISBASE/etc/license"
-	    exit
-    	# Check if the user asked for help
-	help|-h|-help|--help)
-	    echo "Usage:"
-	    echo "  $CMD_NAME [-h | -help | --help] [-v | --version] [-c]"
-	    echo "          [-text | -gui | -tcltk | -oldtcltk | -wxpython]"
-	    echo "          [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]"
-	    echo
-            echo "Flags:"
-            echo "  -h or -help or --help          print this help message"
-	    echo "  -v or --version                show version information and exit"
-	    echo "  -c                             create given mapset if it doesn't exist"
-            echo "  -text                          use text based interface"
-            echo "                                   and set as default"
-            echo "  -gui                           use graphical user interface ($DEFAULT_GUI by default)"
-            echo "  -tcltk                         use Tcl/Tk based graphical user interface"
-	    echo "  -oldtcltk                      use old Tcl/Tk based graphical user interface"
-            echo "  -wxpython                      use wxPython based graphical user interface"
-            echo
-            echo "Parameters:"
-            echo "  GISDBASE                       initial database (path to GIS data)"
-            echo "  LOCATION_NAME                  initial location"
-            echo "  MAPSET                         initial mapset"
-            echo
-            echo "  GISDBASE/LOCATION_NAME/MAPSET  fully qualified initial mapset directory"
-            echo
-            echo "Environment variables relevant for startup:"
-            echo "  GRASS_GUI                      select GUI (text, gui, tcltk, oldtcltk, wxpython)"
-            echo "  GRASS_TCLSH                    set tclsh shell name to override 'tclsh'"
-            echo "  GRASS_WISH                     set wish shell name to override 'wish'"
-            echo "  GRASS_HTML_BROWSER             set html web browser for help pages"
-            echo "  GRASS_ADDON_PATH               set additional path(s) to local GRASS modules"
-            echo "  GRASS_BATCH_JOB                shell script to be processed as batch job"
-            echo "  GRASS_PYTHON                   set python shell name to override 'python'"
-	    exit
-	# Check if the -text flag was given
-	-text)
-	    GRASS_GUI="text"
-	    shift
-	# Check if the -gui flag was given
-	-gui)
-	    GRASS_GUI="$DEFAULT_GUI"
-	    shift
-	# Check if the -tcltk flag was given
-	-tcltk)
-	    GRASS_GUI="tcltk"
-	    shift
-	# Check if the -oldtcltk flag was given
-	-oldtcltk)
-	    GRASS_GUI="oldtcltk"
-	    shift
-	# Check if the -wxpython flag was given
-	-wxpython)
-	    GRASS_GUI="wxpython"
-	    shift
-    	# Check if the user wants to create a new mapset
-	-c)
-	    CREATE_NEW=1
-	    shift
-    esac
-done
 # Set the GIS_LOCK variable to current process id
 GIS_LOCK=$$
 export GIS_LOCK
@@ -161,202 +68,93 @@
 # Set the global grassrc file
 GISRCRC="$HOME/.grassrc7"
-# Set the session grassrc file
+# Set PATH to GRASS bin, ETC to GRASS etc
+ETC="$GISBASE/etc"
+# Set the username and working directory
 	PWD=`pwd -W`
 	USER="$USERNAME"
 	if [ ! "$USER" ] ; then
 		USER="user_name"
 	fi
-	if [ ! -f "$GISBASE/etc/monitorcap" ] ; then
-		# create an empty monitorcap
-		touch "$GISBASE/etc/monitorcap"
-	fi
 else
 	PWD=`pwd`
 	USER="`whoami`"
 fi
+# Parse the command-line options
+# This can't be put into a function as it modifies argv
+for i in "$@" ; do
+    case "$i" in
+    # Check if the user asked for the version
+    -v|--version)
+        cat "$GISBASE/etc/license"
+        exit
-# all exits after setting up $tmp should also tidy it up
-cleanup_tmp()
-  # remove session files from tmpdir
-  rm -rf "$tmp"
+    # Check if the user asked for help
+    help|-h|-help|--help)
+        help_message
+        exit
-## use TMPDIR if it exists, otherwise /tmp
-#tmp=${TMPDIR-/tmp}
-#tmp="$tmp/grass7-$USER-$GIS_LOCK"
-tmp=/tmp/grass7-$USER-$GIS_LOCK
-(umask 077 && mkdir "$tmp") || {
-    echo "Cannot create temporary directory! Exiting." 1>&2
-    exit 1
-GISRC="$tmp/gisrc"
-export GISRC
+    # Check if the -text flag was given
+    -text)
+        GRASS_GUI="text"
+        shift
-# remove invalid GISRC file to avoid disturbing error messages:
-cat "$GISRCRC" 2>/dev/null| grep UNKNOWN >/dev/null
-if [ $? -eq 0 ] ; then
-   rm -f "$GISRCRC"
-fi
+    # Check if the -gui flag was given
+    -gui)
+        shift
-# Copy the global grassrc file to the session grassrc file
-if [ -f "$GISRCRC" ] ; then
-    cp "$GISRCRC" "$GISRC"
-    if [ $? -eq 1 ] ; then
-    	echo "Cannot copy '$GISRCRC' to '$GISRC'"
-	cleanup_tmp
-    	exit 1
-    fi
-fi
+    # Check if the -tcltk flag was given
+    -tcltk)
+        GRASS_GUI="tcltk"
+        shift
-# Copy global grassrc file to session grassrc
+    # Check if the -wxpython flag was given
+    -wxpython)
+        GRASS_GUI="wxpython"
+        shift
-# At this point the GRASS user interface variable has been set from the
-# command line, been set from an external environment variable, or is
-# not set. So we check if it is not set
-if [ ! "$GRASS_GUI" ] ; then
+    # Check if the user wants to create a new mapset
+    -c)
+        CREATE_NEW=1
+        shift
+    esac
+done
-    # Check for a reference to the GRASS user interface in the grassrc file
-    if [ -f "$GISRC" ] ; then
-    	GRASS_GUI=`awk '/GRASS_GUI/ {print $2}' "$GISRC"`
-    fi
-    # Set the GRASS user interface to the default if needed
-    if [ ! "$GRASS_GUI" ] ; then
-    fi
-else
-    if [ "$GRASS_GUI" = "gui" ] ; then
-    fi
-fi
+# Create the temporary directory and session grassrc file
+create_tmp
-# Set PATH to GRASS bin, ETC to GRASS etc
-ETC="$GISBASE/etc"
+# Create the session grassrc file
+create_gisrc
-if [ "$LC_ALL" ] ; then
-	LCL=`echo "$LC_ALL" | sed 's/\(..\)\(.*\)/\1/'`
-elif [ "$LC_MESSAGES" ] ; then
-	LCL=`echo "$LC_MESSAGES" | sed 's/\(..\)\(.*\)/\1/'`
-else
-	LCL=`echo "$LANG" | sed 's/\(..\)\(.*\)/\1/'`
-fi
+# Ensure GRASS_GUI is set
+read_gui
-if [ -n "$GRASS_ADDON_PATH" ] ; then
-   PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:$PATH"
-else
-   PATH="$GISBASE/bin:$GISBASE/scripts:$PATH"
-fi
-export PATH
+# Get Locale name
+get_locale
-# Set LD_LIBRARY_PATH to find GRASS shared libraries
-if [ ! "$LD_LIBRARY_PATH_VAR" ] ; then
-  LD_LIBRARY_PATH_VAR="$GISBASE/lib"
-else
-  LD_LIBRARY_PATH_VAR="$GISBASE/lib:$LD_LIBRARY_PATH_VAR"
-fi
-export LD_LIBRARY_PATH_VAR
-# Additional copy of variable to use with grass-run.sh
-GRASS_LD_LIBRARY_PATH="$LD_LIBRARY_PATH_VAR"
-export GRASS_LD_LIBRARY_PATH
+# Set PATH, @LD_LIBRARY_PATH_VAR@, PYTHONPATH
+GRASS_LD_LIBRARY_PATH="$@LD_LIBRARY_PATH_VAR@"
+set_paths
+ at LD_LIBRARY_PATH_VAR@="$GRASS_LD_LIBRARY_PATH"
+export @LD_LIBRARY_PATH_VAR@
-# Set some environment variables if they are not set
-if [ ! "$GRASS_PAGER" ] ; then
-    if [ -x /bin/more ] || [ -x /usr/bin/more ] ; then
-        GRASS_PAGER=more
-    elif [ -x /bin/less ] || [ -x /usr/bin/less ] ; then
-        GRASS_PAGER=less
-    elif [ "$MINGW" ] ; then
-        GRASS_PAGER=more
-    else
-        GRASS_PAGER=cat
-    fi
-    export GRASS_PAGER
-fi
+# Set GRASS_PAGER, GRASS_WISH, GRASS_PYTHON, GRASS_GNUPLOT
+set_defaults
-# Set up tcltk and wish environment
+# Set GRASS_HTML_BROWSER
+set_browser
-if [ ! "$GRASS_TCLSH" ] ; then
-   GRASS_TCLSH=tclsh
-   export GRASS_TCLSH
-fi
-#WISH_OS=`echo 'puts $tcl_platform(platform) ; exit 0' | wish`
-if [ ! "$GRASS_WISH" ] ; then
-   GRASS_WISH=wish
-   export GRASS_WISH
-fi
-if [ ! "$GRASS_PYTHON" ] ; then
-      GRASS_PYTHON=python
-fi
-export GRASS_PYTHON
-# Set PYTHONPATH to find GRASS Python modules
-if [ ! "PYTHONPATH" ] ; then
-  PYTHONPATH="$GISBASE/etc/python"
-else
-  PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
-fi
-export PYTHONPATH
-# try and find a web browser if one isn't already specified
-if [ ! "$GRASS_HTML_BROWSER" ] ; then
-    if [ "$MACOSX" ] ; then
-        # OSX doesn't execute browsers from the shell PATH - route thru a script
-        GRASS_HTML_BROWSER="$ETC/html_browser_mac.sh"
-        GRASS_HTML_BROWSER_MACOSX="-b com.apple.helpviewer"
-        export GRASS_HTML_BROWSER_MACOSX
-    elif [ "$MINGW" -o "$CYGWIN" ] ; then
-	# MinGW startup moved to into init.bat
-	iexplore="$SYSTEMDRIVE/Program Files/Internet Explorer/iexplore.exe"
-	if [ -f "$iexplore" ] ; then
-	    GRASS_HTML_BROWSER=$iexplore
-	else
-	    GRASS_HTML_BROWSER="iexplore"
-	fi
-    else
-      # the usual suspects
-      BROWSERS="htmlview konqueror mozilla mozilla-firefox firefox opera netscape dillo"
-      for BROWSER in $BROWSERS ; do
-	for i in `echo "$PATH" | sed 's/^:/.:/
-                                s/::/:.:/g
-                                s/:$/:./
-                                s/:/ /g'`
-	do
-	  if [ -f "$i/$BROWSER" ] ; then
-            GRASS_HTML_BROWSER="$BROWSER"
-            break
-	  fi
-	done
-	if [ -n "$GRASS_HTML_BROWSER" ] ; then
-	   break
-	fi
-      done
-    fi
-elif [ "$MACOSX" ] ; then
-    GRASS_HTML_BROWSER_MACOSX="-b $GRASS_HTML_BROWSER"
-fi
-    echo "WARNING: Searched for a web browser, but none found." 1>&2
-    # even so we set konqueror to make lib/gis/parser.c happy:
-    GRASS_HTML_BROWSER=konqueror
-fi
-export GRASS_HTML_BROWSER
 #predefine monitor size for certain architectures
 if [ "$HOSTTYPE" = "arm" ] ; then
    #small monitor on ARM (iPAQ, zaurus... etc)
@@ -365,371 +163,42 @@
    export GRASS_HEIGHT GRASS_WIDTH
 fi
-if [ ! "$GRASS_GNUPLOT" ] ; then
-    GRASS_GNUPLOT="gnuplot -persist"
-    export GRASS_GNUPLOT
-fi
 if [ ! "$GRASS_PROJSHARE" ] ; then
-    GRASS_PROJSHARE=CONFIG_PROJSHARE
+    GRASS_PROJSHARE=@CONFIG_PROJSHARE@
     export GRASS_PROJSHARE
 fi
 # First time user - GISRC is defined in the GRASS script
 if [ ! -f "$GISRC" ] ; then
-    if [ ! -f "$GISBASE/locale/$LCL/etc/grass_intro" ] ; then
-	cat "$ETC/grass_intro"
-    else
-	cat "$GISBASE/locale/$LCL/etc/grass_intro"
-    fi
-    echo
-    echo "Hit RETURN to continue"
-    read ans
-    #for convenience, define pwd as GISDBASE:
-    echo "GISDBASE: $PWD" > "$GISRC"
-    echo 'LOCATION_NAME: <UNKNOWN>' >> "$GISRC"
-    echo 'MAPSET: <UNKNOWN>' >> "$GISRC"
-    # This is a hack for not having a good initial gui - should be removed
-    # with next version of initialization gui
-    #GRASS_GUI="text"
+    grass_intro
 else
-    echo "Cleaning up temporary files ..."
-    ("$ETC/clean_temp" > /dev/null &)
+    clean_temp
 fi
 echo "Starting GRASS ..."
-# Check if we are running X windows by checking the DISPLAY variable
-if [ "$DISPLAY" -o "$MINGW" ] ; then
+# Check that the GUI works
+check_gui "$@"
-    # Check if python is working properly
-    if [ "$GRASS_GUI" = "wxpython" ]; then
-        echo 'variable=True' | "$GRASS_PYTHON" >/dev/null 2>&1
-    fi
-    # Check if we need to find wish
-    if [ "$GRASS_GUI" = "tcltk" ] || \
-        [ "$GRASS_GUI" = "gis.m" ] || \
-	[ "$GRASS_GUI" = "oldtcltk" ] || \
-        [ "$GRASS_GUI" = "d.m" ] ; then
-	# Check if wish is working properly
-	echo 'exit 0' | "$GRASS_WISH" >/dev/null 2>&1
-    fi
-    # ok
-    if [ "$?" = 0 ] ; then
-        # Set the tcltkgrass base directory
-        TCLTKGRASSBASE="$ETC"
-        # Set the wxpython base directory
-        WXPYTHONGRASSBASE="$ETC/wxpython"
-    else
-        # Wish was not found - switch to text interface mode
-        echo
-        echo "WARNING: The wish command does not work as expected!"
-        echo "Please check your GRASS_WISH environment variable."
-        echo "Use the -help option for details."
-        echo "Switching to text based interface mode."
-        echo
-        echo "Hit RETURN to continue."
-        read ans
-        GRASS_GUI="text"
-    fi
-else
-    # Display a message if a graphical interface was expected
-    if [ "$GRASS_GUI" != "text" ] ; then
-        # Set the interface mode to text
-    	echo
-	echo "WARNING: It appears that the X Windows system is not active."
-	echo "A graphical based user interface is not supported."
-	echo
-	read ans
-        GRASS_GUI="text"
-    fi
-fi
-# Save the user interface variable in the grassrc file - choose a temporary
-# file name that should not match another file
-if [ -f "$GISRC" ] ; then
-    awk '$1 !~ /GRASS_GUI/ {print}' "$GISRC" > "$GISRC.$$"
-    echo "GRASS_GUI: $GRASS_GUI" >> "$GISRC.$$"
-    mv -f "$GISRC.$$" "$GISRC"
-fi
 # Parsing argument to get LOCATION
 if [ ! "$1" ] ; then
     # Try interactive startup
     LOCATION=
 else
-    # Try non-interactive startup
-    L=
-    if [ "$1" = "-" ] ; then
-    	if [ "$LOCATION" ] ; then
-    	    L="$LOCATION"
-    	fi
-    else
-    	L="$1"
-    fi
-    if [ "$L" ] ; then
-	if [ "$L" = "." ] ; then
-	    L=$PWD
-	elif [ `echo "$L" | cut -c 1` != "/" ] ; then
-    	    L="$PWD/$L"
-    	fi
-    	MAPSET=`basename "$L"`
-    	L=`dirname "$L"`
-    	if [ "$L" != "." ] ; then
-    	    LOCATION_NAME=`basename "$L"`
-    	    L=`dirname "$L"`
-    	    	GISDBASE="$L"
-    	    fi
-    	fi
-    fi
-    #strip off white space from LOCATION_NAME and MAPSET: only supported for $GISDBASE
-    MAPSET=`echo $MAPSET | sed 's+ ++g'`
-    LOCATION_NAME=`echo $LOCATION_NAME | sed 's+ ++g'`
-    if [ "$GISDBASE" -a "$LOCATION_NAME" -a "$MAPSET" ] ; then
-    	LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
-    	if [ ! -r "$LOCATION/WIND" ] ; then
-		if [ "$LOCATION_NAME" = "PERMANENT" ] ; then
-		   echo "$LOCATION: Not a valid GRASS location"
-		   cleanup_tmp
-		   exit 1
-		else
-		   # the user wants to create mapset on the fly
-		   if [ -n "$CREATE_NEW" ] && [ "$CREATE_NEW" -eq 1 ] ; then
-		     if [ ! -f "$GISDBASE/$LOCATION_NAME/PERMANENT/DEFAULT_WIND" ] ; then
-			echo "The LOCATION \"$LOCATION_NAME\" does not exist. Please create it first"
-			cleanup_tmp
-			exit 1
-		     else
-			mkdir -p "$LOCATION"
-			cp "$GISDBASE/$LOCATION_NAME/PERMANENT/DEFAULT_WIND" "$LOCATION/WIND"
-			echo "Missing WIND file fixed"
-		     fi
-		   else
-			cleanup_tmp
-			exit 1
-		   fi
-		fi
-    	fi
-    	if [ -s "$GISRC" ] ; then
-    	    sed -e "s|^GISDBASE:.*$|GISDBASE: $GISDBASE|; \
-    	    	s|^LOCATION_NAME:.*$|LOCATION_NAME: $LOCATION_NAME|; \
-    	    	s|^MAPSET:.*$|MAPSET: $MAPSET|" "$GISRC" > "$GISRC.$$"
-    	    if [ $? -eq 0 ] ; then
-    	    else
-    	    	rm -f "$GISRC.$$"
-    	    	echo "Failed to create new $GISRC"
-    	    	LOCATION=
-    	    fi
-    	else
-    	    echo "GISDBASE: $GISDBASE" > "$GISRC"
-    	    echo "LOCATION_NAME: $LOCATION_NAME" >> "$GISRC"
-    	    echo "MAPSET: $MAPSET" >> "$GISRC"
-    	fi
-    else
-    	echo "GISDBASE, LOCATION_NAME and MAPSET variables not set properly."
-    	echo "Interactive startup needed."
-	cleanup_tmp
-    	exit 1
-    fi
+    non_interactive "$@"
 fi
-if [ ! "$LOCATION" ] ; then
+set_data
-    case "$GRASS_GUI" in
+# Set GISDBASE, LOCATION_NAME, MAPSET, LOCATION from $GISRC
+read_gisrc
-	# Check for text interface
-	text)
-	    "$ETC/set_data"
+# Check .gislock file
+check_lock
-	    case $? in
-     	    	0) ;;
-		    # Check for an invalid GISRC file
-			VALUE=`grep "GISDBASE" "$GISRC"`
-			if [ "$VALUE" = "" ] ; then
-    			    echo "Invalid resource file, removing $GISRC"
-			    rm -f "$GISRC"
-			fi
-		    fi
-		    cleanup_tmp
-		    exit
-    	    esac
-	# Check for tcltk interface
-	tcltk | gis.m | oldtcltk | d.m | wxpython)
-			# eval `foo` will return subshell return code and not app foo return code!!!
-			eval '"$GRASS_WISH" -file "$TCLTKGRASSBASE/gis_set.tcl"'
-			thetest=$?
-		else
-			eval '"$GRASS_PYTHON" "$WXPYTHONGRASSBASE/gis_set.py"'
-			thetest=$?
-		fi
-	    case $thetest in
-     	    	1)
-         	    # The gis_set.tcl script printed an error message so wait
-		    # for user to read it
-		    echo "Error in GUI startup. If necessary, please"
-		    echo "report this error to the GRASS developers."
-		    echo "Switching to text mode now."
-		    echo "Hit RETURN to continue..."
-		    read ans
-		    GRASS_GUI="text"
-                    fi
-		    "$ETC/set_data"
-		    case $? in
-     	    		0) ;;
-				    rm -f "$GISRC"
-				fi
-			    fi
-			    cleanup_tmp
-			    exit
-    		    esac
-     	    	0)
-		    # These checks should not be necessary with real init stuff
-		    if [ "$LOCATION_NAME" = "##NONE##" ] ; then
-    	    		"$ETC/set_data"
-    	    		if [ $? != 0 ]; then
-    	    		    echo "GISDBASE: $OLD_DB" > "$GISRC"
-    	    		    echo "LOCATION_NAME: $OLD_LOC" >> "$GISRC"
-    	    		    echo "MAPSET: $OLD_MAP" >> "$GISRC"
-    	    		    cleanup_tmp
-			    exit
-    	    		fi
-    		    fi
-		    if [ "$LOCATION_NAME" = "##ERROR##" ] ; then
-    	    		echo "The selected location is not a valid GRASS location"
-    	    		cleanup_tmp
-			exit 1
-		    fi
-		2)
-			# User wants to exit from GRASS
-			echo "Received EXIT message from GUI."
-			echo "GRASS is not started. Bye."
-			cleanup_tmp
-			exit 0
-		    echo "ERROR: Invalid return code from gis_set.tcl."
-		    echo "Please advise GRASS developers of this error."
-    	    esac
-	    # Shouldn't need this but you never know
-	    echo "ERROR: Invalid user interface specified - <$GRASS_GUI>."
-	    echo "Use the --help option to see valid interface names."
-	    cleanup_tmp
-	    exit 1
-    esac
-fi
-GISDBASE=`g.gisenv GISDBASE`
-LOCATION_NAME=`g.gisenv LOCATION_NAME`
-MAPSET=`g.gisenv MAPSET`
-if [ -z "$GISDBASE" ] || [ -z "$LOCATION_NAME" ] || [ -z "$MAPSET" ] ; then
-    echo "ERROR: Reading data path information from g.gisenv."
-    echo "GISDBASE=[$GISDBASE]"
-    echo "LOCATION_NAME=[$LOCATION_NAME]"
-    echo "MAPSET=[$MAPSET]"
-    echo
-    echo "Check the <$GISRCRC> file."
-    cleanup_tmp
-    exit 1
-fi
-LOCATION="${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}"
-# Check for concurrent use
-lockfile="$LOCATION/.gislock"
-"$ETC/lock" "$lockfile" $$
-case $? in
-    0) ;;
-    1)
-    	echo "$USER is currently running GRASS in selected mapset (file $lockfile found). Concurrent use not allowed."
-    	cleanup_tmp
-    	exit 1 ;;
-    	echo Unable to properly access "$lockfile"
-    	echo Please notify system personel.
-	cleanup_tmp
-    	exit 1 ;;
-esac
 # build user fontcap if specified but not present
-if [ "$GRASS_FONT_CAP" ] && [ ! -f "$GRASS_FONT_CAP" ] ; then
-	echo "Building user fontcap ..."
-	g.mkfontcap
-fi
+make_fontcap
 # predefine default driver if DB connection not defined
 #  is this really needed?? Modules should call this when/if required.
@@ -739,283 +208,50 @@
 trap "" 2 3 15
-# cygwin has many problems with the shell setup
-# below, so i hardcoded everything here.
-if [ "$CYGWIN" ] ; then
-    sh="cygwin"
-    shellname="GNU Bash (Cygwin)"
-    export SHELL=/usr/bin/bash.exe
-    export OSTYPE=cygwin
-else
-    sh=`basename "$SHELL"`
-    case "$sh" in
-        ksh)  shellname="Korn Shell";;
-        csh)  shellname="C Shell" ;;
-        tcsh) shellname="TC Shell" ;;
-        bash) shellname="Bash Shell" ;;
-        sh)   shellname="Bourne Shell";;
-        *)    shellname=shell;;
-    esac
-fi
+check_shell
-# check for SHELL
-if [ ! -x "$SHELL" ] ; then
-    echo "ERROR: The SHELL variable is not set" 1>&2
-    rm -f "$lockfile"
-    cleanup_tmp
-    exit 1
-fi
+check_batch_job
-# hack to process batch jobs:
-if [ -n "$GRASS_BATCH_JOB" ] ; then
-   # defined, but ...
-   if [ ! -f "$GRASS_BATCH_JOB" ] ; then
-      # wrong file
-      echo "Job file '$GRASS_BATCH_JOB' has been defined in"
-      echo "the 'GRASS_BATCH_JOB' variable but not found. Exiting."
-      echo
-      echo "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
-      cleanup_tmp
-      exit 1
-   else
-      # right file, but ...
-      if [ ! -x "$GRASS_BATCH_JOB" ] ; then
-	 echo "Please change file permission to 'executable' for '$GRASS_BATCH_JOB'"
-	 cleanup_tmp
-	 exit 1
-      else
-         echo "Executing '$GRASS_BATCH_JOB' ..."
-         GRASS_GUI="text"
-         SHELL="$GRASS_BATCH_JOB"
-      fi
-   fi
-fi
+start_gui
-# Start the chosen GUI but ignore text
-if [ "$GRASS_DEBUG" -ne 0 ] ; then
-   echo "GRASS GUI should be $GRASS_GUI"
-fi
-case "$GRASS_GUI" in
-    tcltk | gis.m)
-	"$GISBASE/scripts/gis.m"
-    oldtcltk | d.m)
-	"$GISBASE/scripts/d.m"
-    wxpython)
-        "$GISBASE/etc/wxpython/scripts/wxgui"
-    # Ignore others
-esac
+clear_screen
 # Display the version and license info
-if [ "$MINGW" ] ; then
-# TODO: uncomment when PDCurses works.
-#	cls
-else
-	if [ -z "$GRASS_BATCH_JOB" ] && [ "$GRASS_DEBUG" -eq 0 ] ; then
-	   tput clear
-	fi
-fi
-say_hello()
-    if [ -f "$GISBASE/locale/$LCL/etc/welcome" ] ; then
-	cat "$GISBASE/locale/$LCL/etc/welcome"
-    else
-	cat "$ETC/welcome"
-    fi
   say_hello
 else
-  cat <<EOF
-          __________  ___   __________    _______________
-         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
-        / / __/ /_/ / /| | \__ \\\\_  \\   / / __ / / \\__ \\
-       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
-       \____/_/ |_/_/  |_/____/____/   \____/___//____/
-EOF
+  show_banner
   say_hello
-  echo "GRASS homepage:                          http://grass.osgeo.org/"
-  echo "This version running thru:               $shellname ($SHELL)"
-  echo "Help is available with the command:      g.manual -i"
-  echo "See the licence terms with:              g.version -c"
-     tcltk | gis.m)
-        echo "If required, restart the GUI with:       g.gui tcltk"
-     oldtcltk | d.m)
-        echo "If required, restart the GUI with:       g.gui oldtcltk"
-     wxpython)
-        echo "If required, restart the GUI with:       g.gui wxpython"
-        echo "Start the GUI with:                      g.gui $DEFAULT_GUI"
-  esac
-  echo "When ready to quit enter:                exit"
-  echo
+  show_info
 fi
 case "$sh" in
 csh|tcsh)
-    USERHOME="$HOME"      # save original home
-    HOME="$LOCATION"
-    export HOME
-    cshrc="$HOME/.cshrc"
-    tcshrc="$HOME/.tcshrc"
-    rm -f "$cshrc" "$tcshrc"
-    echo "set home = $USERHOME" > "$cshrc"
-    echo "set history = 3000 savehist = 3000  noclobber ignoreeof" >> "$cshrc"
-    echo "set histfile = $HOME/.history" >> "$cshrc"
-    echo "set prompt = '\\" >> "$cshrc"
-    echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >> "$cshrc"
-    echo "GRASS GRASS_VERSION_NUMBER > '" >> "$cshrc"
-    echo 'set BOGUS=``;unset BOGUS' >> "$cshrc"
-    if [ -r "$USERHOME/.grass.cshrc" ]
-    then
-	cat "$USERHOME/.grass.cshrc" >> "$cshrc"
-    fi
-    if [ -r "$USERHOME/.cshrc" ]
-    then
-	grep '^ *set  *mail *= *' "$USERHOME/.cshrc" >> "$cshrc"
-    fi
-    if [ -r "$USERHOME/.tcshrc" ]
-    then
-	grep '^ *set  *mail *= *' "$USERHOME/.tcshrc" >> "$cshrc"
-    fi
-    if [ -r "$USERHOME/.login" ]
-    then
-	grep '^ *set  *mail *= *' "$USERHOME/.login" >> "$cshrc"
-    fi
-    echo "set path = ( $PATH ) " | sed 's/:/ /g' >> "$cshrc"
-    cp "$cshrc" "$tcshrc"
-    "$ETC/run" "$SHELL"
-    EXIT_VAL=$?
-    HOME="$USERHOME"
-    export HOME
+    csh_startup
 bash|msh|cygwin)
-    # save command history in mapset dir and remember more
-    export HISTFILE="$LOCATION/.bash_history"
-    if [ -z "$HISTSIZE" ] && [ -z "$HISTFILESIZE" ] ; then
-	export HISTSIZE=3000
-    fi
-    # instead of changing $HOME, start bash with: --rcfile "$LOCATION/.bashrc" ?
-    #   if so, must care be taken to explicity call .grass.bashrc et al for
-    #   non-interactive bash batch jobs?
-    HOME="$LOCATION"      # save .bashrc in $LOCATION
-    export HOME
-    bashrc="$HOME/.bashrc"
-    rm -f "$bashrc"
-    echo "test -r ~/.alias && . ~/.alias" >> "$bashrc"
-    echo "PS1='GRASS GRASS_VERSION_NUMBER ($LOCATION_NAME):\w > '" >> "$bashrc"
-    echo "PROMPT_COMMAND=$GISBASE/etc/prompt.sh" >> "$bashrc"
-    if [ -r "$USERHOME/.grass.bashrc" ]
-    then
-        cat "$USERHOME/.grass.bashrc" >> "$bashrc"
-    fi
-    echo "export PATH=\"$PATH\"" >> "$bashrc"
-    echo "export HOME=\"$USERHOME\"" >> "$bashrc" # restore user home path
-    EXIT_VAL=$?
-    HOME="$USERHOME"
-    export HOME
+    bash_startup
-    PS1="GRASS $GRASS_VERSION ($LOCATION_NAME):\w > "
-    export PS1
-    if [ "$MINGW" ] ; then
-	# "$ETC/run" doesn't work at all???
-        "$SHELL"
-	rm -rf "$LOCATION/.tmp"/*  # remove gis.m session files from .tmp
-    else
-	EXIT_VAL=$?
-    fi
+    default_startup
 esac
 trap 2 3 15
-# GRASS session finished
-#	cls
-else
-	   tput clear
-	fi
-fi
+clear_screen
-echo "Closing monitors ..."
-for MON  in `d.mon -L | grep running | grep -v "not running" | sed 's/ .*//'`
-do
-    if [ "$GRASS_DEBUG" -ne 0 ] ; then
-       echo "d.mon stop=$MON"
-    fi
-    d.mon stop="$MON"
-done
+clean_temp
-echo "Cleaning up temporary files ..."
-"$ETC/clean_temp" > /dev/null
 rm -f "$lockfile"
 # Save GISRC
 cp "$GISRC" "$GISRCRC"
+cleanup_tmpdir
-cleanup_tmp
 #### after this point no more grass modules may be called ####
-if [ -x "$GRASS_BATCH_JOB" ] ; then
-   echo "Batch job '$GRASS_BATCH_JOB' (defined in GRASS_BATCH_JOB variable) was executed."
-   echo "Goodbye from GRASS GIS"
-   exit $EXIT_VAL
-else
-   echo "Done."
-   echo
-   echo
-   echo
-   echo
-fi
+done_message
