[GRASS-SVN] r33081 - grass/trunk/gui/wxpython/gui_modules
Tue Aug 26 04:15:43 EDT 2008
Author: martinl
Date: 2008-08-26 04:15:43 -0400 (Tue, 26 Aug 2008)
New Revision: 33081
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/gselect.py
wxGUI: update r33077, don't duplicate code, use inheritance instead
(merge from devbr6, r33080)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-08-26 08:11:18 UTC (rev 33080)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-08-26 08:15:43 UTC (rev 33081)
@@ -54,6 +54,7 @@
 import gcmd
 import utils
 import gdialogs
+import gselect
 from debug import Debug as Debug
 from preferences import globalSettings as UserSettings
@@ -3125,105 +3126,12 @@
         return True
-class VectorDBInfo:
+class VectorDBInfo(gselect.VectorDBInfo):
     """Class providing information about attribute tables
     linked to the vector map"""
     def __init__(self, map):
-        self.map = map
-        # {layer number : {table, database, driver})
-        self.layers = {}
-        # {table : {column name : type, length, values, ids}}
-        self.tables = {}
-        if not self.__CheckDBConnection(): # -> self.layers
-            return
-        self.__DescribeTables() # -> self.tables
-    def __CheckDBConnection(self):
-        """Check DB connection"""
-        layerCommand = gcmd.Command(cmd=["v.db.connect",
-                                         "-g", "--q",
-                                         "map=%s" % self.map],
-                                    rerr=None, stderr=None)
-        if layerCommand.returncode != 0:
-            return False
-        # list of available layers & (table, database, driver)
-        for line in layerCommand.ReadStdOutput():
-            lineList = line.split(' ')
-            layer = lineList[0]
-            if '/' in layer:
-                layer, layer_name = lineList[0].split('/')
-            else:
-                layer_name = None
-            # database can contain ' ' in it's path
-            if len(lineList) > 5:
-                database = ''.join(lineList[3:-1])
-            else:
-                database = lineList[3]
-            self.layers[int(layer)] = {
-                "name"     : layer_name,
-                "table"    : lineList[1],
-                "key"      : lineList[2],
-                "database" : database,
-                "driver"   : lineList[-1]
-        if (len(self.layers.keys()) == 0):
-            return False
-        return True
-    def __DescribeTables(self):
-        """Describe linked tables"""
-        for layer in self.layers.keys():
-            # determine column names and types
-            table = self.layers[layer]["table"]
-            columnsCommand = gcmd.Command (cmd=["db.describe",
-                                                "-c", "--q",
-                                                "table=%s" % self.layers[layer]["table"],
-                                                "driver=%s" % self.layers[layer]["driver"],
-                                                "database=%s" % self.layers[layer]["database"]])
-            columns = {} # {name: {type, length, [values], [ids]}}
-            if columnsCommand.returncode == 0:
-                # skip nrows and ncols
-                i = 0
-                for line in columnsCommand.ReadStdOutput()[2:]:
-                    num, name, type, length = line.strip().split(':')
-                    # FIXME: support more datatypes
-                    if type.lower() == "integer":
-                        ctype = int
-                    elif type.lower() == "double precision":
-                        ctype = float
-                    else:
-                        ctype = str
-                    columns[name.strip()] = { 'index'  : i,
-                                              'type'   : type.lower(),
-                                              'ctype'  : ctype,
-                                              'length' : int(length),
-                                              'values' : [],
-                                              'ids'    : []}
-                    i += 1
-            else:
-                return False
-            # check for key column
-            # v.db.connect -g/p returns always key column name lowercase
-            if self.layers[layer]["key"] not in columns.keys():
-                for col in columns.keys():
-                    if col.lower() == self.layers[layer]["key"]:
-                        self.layers[layer]["key"] = col.upper()
-                        break
-            self.tables[table] = columns
-        return True
+        gselect.VectorDBInfo.__init__(self, map)
     def GetColumns(self, table):
         """Return list of columns names (based on their index)"""
         names = [''] * len(self.tables[table].keys())
@@ -3308,15 +3216,6 @@
         return nselected
-    def Reset(self):
-        """Reset"""
-        for layer in self.layers:
-            table = self.layers[layer]["table"] # get table desc
-            columns = self.tables[table]
-            for name in self.tables[table].keys():
-                self.tables[table][name]['values'] = []
-                self.tables[table][name]['ids']    = []
 class ModifyTableRecord(wx.Dialog):
     """Dialog for inserting/updating table record"""
     def __init__(self, parent, id, title, data, keyEditable=(-1, True),
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-08-26 08:11:18 UTC (rev 33080)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-08-26 08:15:43 UTC (rev 33081)
@@ -1,18 +1,21 @@
-MODULE: gselect
+ at package gselect
+ at brief Custom control that selects GRASS GIS elements
 CLASSES:
- * Select
- * TreeCrtlComboPopup
+ - Select
+ - TreeCrtlComboPopup
+ - VectorDBInfo
+ - LayerSelect
+ - ColumnSelect
-PURPOSE: Custon control that selects GRASS GIS elements
+(C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
-AUTHORS: The GRASS Development Team. Michael Barton & Martin Landa
-COPYRIGHT: (C) 2007 by the GRASS Development Team
-           This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
+ at author Michael Barton, Martin Landa
 import os
