[GRASS-SVN] r33119 - grass/trunk/raster/r.external
Wed Aug 27 09:19:22 EDT 2008
Author: glynn
Date: 2008-08-27 09:19:22 -0400 (Wed, 27 Aug 2008)
New Revision: 33119
   grass/trunk/raster/r.external/main.c
Write f_format file for FP maps
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2008-08-27 12:42:42 UTC (rev 33118)
+++ grass/trunk/raster/r.external/main.c	2008-08-27 13:19:22 UTC (rev 33119)
@@ -399,6 +399,34 @@
     fclose(fp);
+void write_fp_format(const char *output, const struct band_info *info)
+    struct Key_Value *key_val;
+    const char *type;
+    FILE *fp;
+    if (info->data_type == CELL_TYPE)
+	return;
+    key_val = G_create_key_value();
+    type = (info->data_type == FCELL_TYPE)
+	? "float"
+	: "double";
+    G_set_key_value("type", type, key_val);
+    G_set_key_value("byte_order", "xdr", key_val);
+    fp = G_fopen_new_misc("cell_misc", "f_format", output);
+    if (!fp)
+	G_fatal_error(_("Unable to create cell_misc/%s/f_format file"), output);
+    if (G_fwrite_key_value(fp, key_val) < 0)
+	G_fatal_error(_("Error writing cell_misc/%s/f_format file"), output);
+    G_free_key_value(key_val);
 static void create_map(const char *input, int band, const char *output,
 		       struct Cell_head *cellhd, struct band_info *info,
 		       const char *title)
@@ -422,6 +450,7 @@
 	fprange.min = info->range[0];
 	fprange.max = info->range[1];
 	G_write_fp_range(output, &fprange);
+	write_fp_format(output, info);
     G_verbose_message(_("Creating support files for %s"), output);
