[GRASS-SVN] r33128 - in grass/trunk: include lib/driver lib/gis swig/perl
Wed Aug 27 16:10:03 EDT 2008
Author: glynn
Date: 2008-08-27 16:10:02 -0400 (Wed, 27 Aug 2008)
New Revision: 33128
Removed:
   grass/trunk/lib/gis/dig_title.c
   grass/trunk/lib/gis/fork.c
   grass/trunk/lib/gis/gishelp.c
   grass/trunk/lib/gis/unctrl.c
   grass/trunk/swig/perl/gis.h
   grass/trunk/swig/perl/gisdefs.h
   grass/trunk/include/gisdefs.h
   grass/trunk/lib/driver/Color.c
   grass/trunk/lib/driver/driver.h
   grass/trunk/lib/gis/cats.c
   grass/trunk/lib/gis/closecell.c
   grass/trunk/lib/gis/env.c
   grass/trunk/lib/gis/list.c
Remove unused functions
Declare functions "static" where appropriate
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/include/gisdefs.h	2008-08-27 20:10:02 UTC (rev 33128)
@@ -111,8 +111,6 @@
 int G_read_raster_cats(const char *, const char *, struct Categories *);
 int G_read_vector_cats(const char *, const char *, struct Categories *);
 CELL G_number_of_cats(const char *, const char *);
-CELL G__read_cats(const char *, const char *, const char *,
-		  struct Categories *, int);
 char *G_get_cats_title(const struct Categories *);
 char *G_get_raster_cats_title(const struct Categories *);
 char *G_get_cat(CELL, struct Categories *);
@@ -143,7 +141,6 @@
 int G_write_cats(const char *, struct Categories *);
 int G_write_raster_cats(const char *, struct Categories *);
 int G_write_vector_cats(const char *, struct Categories *);
-int G__write_cats(const char *, const char *, struct Categories *);
 char *G_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
 			     DCELL *);
 char *G_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
@@ -192,7 +189,6 @@
 /* closecell.c */
 int G_close_cell(int);
 int G_unopen_cell(int);
-int G__write_fp_format(int);
 /* color_compat.c */
 int G_make_ryg_colors(struct Colors *, CELL, CELL);
@@ -425,8 +421,6 @@
 int G__read_env(void);
 void G_set_gisrc_mode(int);
 int G_get_gisrc_mode(void);
-int G__set_gisrc_file(const char *);
-char *G__get_gisrc_file(void);
 int G__create_alt_env(void);
 int G__switch_env(void);
@@ -475,9 +469,6 @@
 int G_zlib_read(int, int, unsigned char *, int);
 int G_zlib_write_noCompress(int, const unsigned char *, int);
-/* fork.c */
-int G_fork(void);
 /* format.c */
 int G__check_format(int);
 int G__read_row_ptrs(int);
@@ -586,9 +577,6 @@
 /* gisdbase.c */
 char *G_gisdbase(void);
-/* gishelp.c */
-int G_gishelp(const char *, const char *);
 /* gisinit.c */
 int G__gisinit(const char *, const char *);
 int G__no_gisinit(const char *);
@@ -690,7 +678,6 @@
 				 double);
 /* list.c */
-int G_set_list_hit_return(int);
 int G_list_element(const char *, const char *, const char *,
 		   int (*)(const char *, const char *, const char *));
 char **G_list(int, const char *, const char *, const char *);
@@ -1150,9 +1137,6 @@
 /* trim_dec.c */
 int G_trim_decimal(char *);
-/* unctrl.c */
-char *G_unctrl(int);
 /* verbose.c */
 int G_verbose(void);
 int G_verbose_min(void);
Modified: grass/trunk/lib/driver/Color.c
--- grass/trunk/lib/driver/Color.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/driver/Color.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -2,14 +2,14 @@
 #include "driver.h"
 #include "driverlib.h"
-int DRV_lookup_color(int r, int g, int b)
+static int lookup_color(int r, int g, int b)
     if (driver->lookup_color)
 	return (*driver->lookup_color) (r, g, b);
     return 0;
-void DRV_color(int number)
+static void color(int number)
     if (driver->color)
 	(*driver->color) (number);
@@ -18,7 +18,7 @@
 void COM_Color_RGB(unsigned char r, unsigned char g, unsigned char b)
-    DRV_color(DRV_lookup_color(r, g, b));
+    color(lookup_color(r, g, b));
 void COM_Standard_color(int number)
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/driver/driver.h	2008-08-27 20:10:02 UTC (rev 33128)
@@ -134,10 +134,6 @@
 /* Driver Operations */
-/* Color.c */
-extern int DRV_lookup_color(int, int, int);
-extern void DRV_color(int);
 /* Draw.c */
 extern void DRV_draw_bitmap(int, int, int, const unsigned char *);
 extern void DRV_draw_line(double, double, double, double);
Modified: grass/trunk/lib/gis/cats.c
--- grass/trunk/lib/gis/cats.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/cats.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -329,6 +329,10 @@
 static int get_fmt(char **, char *, int *);
 static int cmp(const void *, const void *);
+static int write_cats(const char *element, const char *name, struct Categories *cats);
+static CELL read_cats(const char *element,
+		      const char *name,
+		      const char *mapset, struct Categories * pcats, int full);
  * \brief read raster category file
@@ -367,7 +371,7 @@
     char *type;
-    switch (G__read_cats("cats", name, mapset, pcats, 1)) {
+    switch (read_cats("cats", name, mapset, pcats, 1)) {
     case -2:
 	type = "missing";
 	break;
@@ -403,7 +407,7 @@
     char *type;
-    switch (G__read_cats("dig_cats", name, mapset, pcats, 1)) {
+    switch (read_cats("dig_cats", name, mapset, pcats, 1)) {
     case -2:
 	type = "missing";
 	break;
@@ -433,9 +437,9 @@
     return max;
-CELL G__read_cats(const char *element,
-		  const char *name,
-		  const char *mapset, struct Categories * pcats, int full)
+		      const char *name,
     FILE *fd;
     char buff[1024];
@@ -1180,7 +1184,7 @@
 int G_write_cats(const char *name, struct Categories *cats)
-    return G__write_cats("cats", name, cats);
+    return write_cats("cats", name, cats);
@@ -1196,7 +1200,7 @@
 int G_write_raster_cats(const char *name, struct Categories *cats)
@@ -1216,10 +1220,10 @@
 int G_write_vector_cats(const char *name, struct Categories *cats)
-    return G__write_cats("dig_cats", name, cats);
+    return write_cats("dig_cats", name, cats);
-int G__write_cats(const char *element, const char *name, struct Categories *cats)
     FILE *fd;
     int i, fp_map;
@@ -1227,7 +1231,6 @@
     DCELL val1, val2;
     char str1[100], str2[100];
-    /* DEBUG fprintf(stderr,"G__write_cats(*element = '%s', name = '%s', cats = %p\n",element,name,cats); */
     if (!(fd = G_fopen_new(element, name)))
 	return -1;
@@ -1247,7 +1250,6 @@
 	fp_map = 0;
     else
 	fp_map = G_raster_map_is_fp(name, G_mapset());
-    /* DEBUG fprintf(stderr,"G__write_cats(): fp_map = %d\n",fp_map); */
     if (!fp_map)
 	G_sort_cats(cats);
@@ -1272,7 +1274,6 @@
     fclose(fd);
-    /* DEBUG fprintf(stderr,"G__write_cats(): done\n"); */
     return (1);
Modified: grass/trunk/lib/gis/closecell.c
--- grass/trunk/lib/gis/closecell.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/closecell.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -43,6 +43,7 @@
 static int close_new(int, int);
 static char CELL_DIR[100];
+static int write_fp_format(int fd);
  * \brief close a raster map
@@ -248,7 +249,7 @@
 	if (fcb->map_type != CELL_TYPE) {	/* floating point map */
 	    int cell_fd;
-	    if (G__write_fp_format(fd) != 0) {
+	    if (write_fp_format(fd) != 0) {
 		G_warning(_("Error writing floating point format file for map %s"),
 			  fcb->name);
 		stat = -1;
@@ -397,7 +398,7 @@
 /* returns 0 on success, 1 on failure */
-int G__write_fp_format(int fd)
     struct fileinfo *fcb = &G__.fileinfo[fd];
     struct Key_Value *format_kv;
Deleted: grass/trunk/lib/gis/dig_title.c
--- grass/trunk/lib/gis/dig_title.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/dig_title.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -1,36 +0,0 @@
- * char *G_get_cell_title (name, mapset)
- *   char *name        name of map file
- *   char *mapset      mapset containing name
- *   returns pointer to string containing cell title. (from cats file)
-#include <stdio.h>
-#include <grass/gis.h>
-char *G_get_dig_title(const char *name, const char *mapset)
-    FILE *fd;
-    int stat = -1;
-    char title[100];
-    fd = G_fopen_old("dig_cats", name, mapset);
-    if (fd) {
-	stat = 1;
-	if (!fgets(title, sizeof title, fd))	/* skip number of cats */
-	    stat = -1;
-	else if (!G_getl(title, sizeof title, fd))	/* read title */
-	    stat = -1;
-	fclose(fd);
-    if (stat < 0)
-	*title = 0;
-    else
-	G_strip(title);
-    return G_store(title);
Modified: grass/trunk/lib/gis/env.c
--- grass/trunk/lib/gis/env.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/env.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -500,34 +500,6 @@
-   \brief Sets filename for gisrc
-   \param name filename
-   \return 0
-int G__set_gisrc_file(const char *name)
-    gisrc = NULL;
-    if (name && *name)
-	gisrc = G_store(name);
-    return 0;
-   \brief Get gisrc filename
-   \param
-   \return char pointer to filename
-    return gisrc;
    \brief Set up alternative environment variables
    \param
Deleted: grass/trunk/lib/gis/fork.c
--- grass/trunk/lib/gis/fork.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/fork.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -1,43 +0,0 @@
-#include <grass/config.h>
-#include <unistd.h>
- * G_fork()
- * Issue a system fork() call and protect the child from all
- * signals (which it does by changing the process group for the child)
- * returns:
- *     -1 fork failed.
- *      0 child
- *     >0 parent
-int G_fork(void)
-#ifdef __MINGW32__
-    return -1;
-#else /* __MINGW32__ */
-    int pid;
-    pid = fork();
-     * change the process group for the child (pid == 0)
-     * note: we use the BSD calling sequence, since
-     * it will work ok for ATT call which has no arguments
-    if (pid == 0)
-#ifdef SETPGRP_VOID
-	setpgrp();
-#else
-	setpgrp(0, getpid());
-#endif
-    return pid;
-#endif /* __MINGW32__ */
Deleted: grass/trunk/lib/gis/gishelp.c
--- grass/trunk/lib/gis/gishelp.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/gishelp.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -1,53 +0,0 @@
- * MODULE:       GRASS 5 gis library, gishelp.c
- * AUTHOR(S):    unknown
- * PURPOSE:      Print help information
- * COPYRIGHT:    (C) 2000 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
- *  G_gishelp(helpfile, request)
- *      char *helpfile           help directory where "request" is found
- *      char *request            help file desired
- *   Prints a helpfile to the screen.  Helpfiles are stored in directories
- *   associated with different GRID programs.  A given file will be
- *   found in   $GISBASE/txt/"helpfile"/"request".
-#include <grass/glocale.h>
-#include <stdlib.h>
-#include <grass/spawn.h>
-#define GEN_HELP	"gen_help"
-int G_gishelp(const char *helpfile, const char *request)
-    char file[1024];
-    if (request == NULL)
-	request = GEN_HELP;
-    sprintf(file, "%s/txt/%s/%s", G_getenv("GISBASE"), helpfile, request);
-    if (!access(file, 04)) {
-	fprintf(stderr, _("one moment...\n"));
-	G_spawn(getenv("GRASS_PAGER"), getenv("GRASS_PAGER"), file, NULL);
-    else {
-	fprintf(stderr, _("No help available for command [%s]\n"), request);
-    return 0;
Modified: grass/trunk/lib/gis/list.c
--- grass/trunk/lib/gis/list.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/list.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -24,17 +24,10 @@
 static int broken_pipe;
-static int hit_return = 0;
 static int list_element(FILE *, const char *, const char *, const char *,
 static void sigpipe_catch(int);
-int G_set_list_hit_return(int flag)
-    hit_return = flag;
-    return 0;
    \brief General purpose list function.
@@ -130,10 +123,6 @@
 #ifdef SIGPIPE
     signal(SIGPIPE, sigpipe);
 #endif
-    if (hit_return && isatty(1)) {
-	fprintf(stderr, _("hit RETURN to continue -->"));
-	while (getchar() != '\n') ;
     return 0;
Deleted: grass/trunk/lib/gis/unctrl.c
--- grass/trunk/lib/gis/unctrl.c	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/lib/gis/unctrl.c	2008-08-27 20:10:02 UTC (rev 33128)
@@ -1,48 +0,0 @@
- * \file unctrl.c
- * \brief GIS Library - Handles control characters.
- * (C) 2001-2008 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author GRASS GIS Development Team
- * \date 1999-2006
-#include <stdio.h>
- * \brief Printable version of control character.
- * This routine returns a pointer to a string which contains an
- * English-like representation for the character <b>c</b>. This is useful for
- * nonprinting characters, such as control characters. Control characters are
- * represented by ctrl-C, e.g., control A is represented by ctrl-A. 0177 is
- * represented by DEL/RUB. Normal characters remain unchanged.
- * \param[in] int c
- * \return char * pointer to string containing English-like representation for character <b>c</b>
-char *G_unctrl(int c)
-    static char buf[20];
-    if (c < ' ')
-	sprintf(buf, "ctrl-%c", c | 0100);
-    else if (c < 0177)
-	sprintf(buf, "%c", c);
-    else if (c == 0177)
-	sprintf(buf, "DEL/RUB");
-    else
-	sprintf(buf, "Mctrl-%c", (c & 77) | 0100);
-    return buf;
Deleted: grass/trunk/swig/perl/gis.h
--- grass/trunk/swig/perl/gis.h	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/swig/perl/gis.h	2008-08-27 20:10:02 UTC (rev 33128)
@@ -1,610 +0,0 @@
- * MODULE:      Grass Include Files
- * AUTHOR(S):   Original author unknown - probably CERL
- *              Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th
- * PURPOSE:     This file contains definitions of variables and data types
- *              for use with most, if not all, Grass programs. This file is
- *              usually included in every Grass program.
- *              for details.
-#ifndef GRASS_GIS_H
-#define GRASS_GIS_H
-/*============================= Include Files ==============================*/
-/* System include files */
-#include <stdio.h>
-#include <stdarg.h>
-/* Grass and local include files */
-#include <grass/datetime.h>
-/*=========================== Constants/Defines ============================*/
-#if !defined __GNUC__ || __GNUC__ < 2
-#undef __attribute__
-#define __attribute__(x)
-#endif
-static const char *GRASS_copyright __attribute__ ((unused))
-    = "GRASS GNU GPL licensed Software";
-/* Define TRUE and FALSE for boolean comparisons */
-#ifndef TRUE
-#define TRUE 1
-#endif
-#ifndef FALSE
-#define FALSE 0
-#endif
-#define MAXEDLINES  50
-#define RECORD_LEN  80
-#define NEWLINE     '\n'
-#define RECLASS_TABLE 1
-#define RECLASS_RULES 2
-#define RECLASS_SCALE 3
-#define METERS    1
-#define FEET      2
-#define DEGREES   3
-#define CELL_TYPE 0
-#define FCELL_TYPE 1
-#define DCELL_TYPE 2
-#define PROJECTION_XY  0
-#define PROJECTION_UTM 1
-#define PROJECTION_SP  2
-#define PROJECTION_LL  3
-#define PROJECTION_OTHER  99
-#define PROJECTION_FILE "PROJ_INFO"
-#define UNIT_FILE "PROJ_UNITS"
-/* define PI and friends */
-#undef M_PI
-#define M_PI    3.14159265358979323846	/* pi */
-#undef M_PI_2
-#define M_PI_2  1.57079632679489661923	/* pi/2 */
-#undef M_PI_4
-#define M_PI_4  0.78539816339744830962	/* pi/4 */
-/* epsilon (IEEE: 2.220446e-16) */
-#define GRASS_EPSILON 1.0e-15
-/* Location of envariment variables */
-#define G_VAR_GISRC    0
-#define G_VAR_MAPSET   1
-/* Where to find/store variables */
-#define G_GISRC_MODE_FILE     0	/* files */
-#define G_GISRC_MODE_MEMORY   1	/* memory only */
-/* for G_parser() */
-#define TYPE_INTEGER  1
-#define TYPE_DOUBLE   2
-#define TYPE_STRING   3
-#define YES           1
-#define NO            0
-#define GISPROMPT_COLOR "color,grass,color"
-/* File/directory name lengths */
-#define GNAME_MAX 256
-#define GMAPSET_MAX 256
-#define GPATH_MAX 4096
-/* Macros for type size independent integers                    */
-/* Use these for portability to ensure integers are truly 32bit */
-/* and are handled in a uniform manner                          */
-/* Convert integer to 4 bytes - little endian */
-#define serialize_int32_le(buf, x) do { \
-    (buf)[0] = ((x) >>  0) & 0xFF; \
-    (buf)[1] = ((x) >>  8) & 0xFF; \
-    (buf)[2] = ((x) >> 16) & 0xFF; \
-    (buf)[3] = ((x) >> 24) & 0xFF; \
-} while(0)
-/* Convert 4 bytes to an integer - little endian */
-#define deserialize_int32_le(buf) (((buf)[0] <<  0) | \
-                                   ((buf)[1] <<  8) | \
-                                   ((buf)[2] << 16) | \
-                                   ((buf)[3] << 24))
-/* Convert integer to 4 bytes - big endian */
-#define serialize_int32_be(buf, x) do { \
-    (buf)[0] = ((x) >> 24) & 0xFF; \
-    (buf)[1] = ((x) >> 16) & 0xFF; \
-    (buf)[2] = ((x) >>  8) & 0xFF; \
-    (buf)[3] = ((x) >>  0) & 0xFF; \
-} while(0)
-/* Convert 4 bytes to an integer - big endian */
-#define deserialize_int32_be(buf) (((buf)[0] << 24) | \
-                                   ((buf)[1] << 16) | \
-                                   ((buf)[2] <<  8) | \
-                                   ((buf)[3] <<  0))
-/* Cross-platform Directory Separator Character and null device stuff */
-#define GRASS_DIRSEP '/'
-#ifdef __MINGW32__
-#  define HOST_DIRSEP '\\'
-#  define G_DEV_NULL 'NUL:'
-#else
-#  define HOST_DIRSEP '/'
-#  define G_DEV_NULL '/dev/null'
-#endif
- /**/ typedef enum
-    G_OPT_DB_WHERE,		/* SQL where conditions */
-    G_OPT_DB_COLUMN,		/* one attr column */
-    G_OPT_DB_COLUMNS,		/* one or more attr columns */
-    G_OPT_I_GROUP,		/* old input imagery group */
-    G_OPT_R_INPUT,		/* old input raster map */
-    G_OPT_R_INPUTS,		/* old input raster maps */
-    G_OPT_R_OUTPUT,		/* new output raster map */
-    G_OPT_R_MAP,		/* old input raster map */
-    G_OPT_R_MAPS,		/* old input rasters map */
-    G_OPT_R_BASE,		/* old input base raster map */
-    G_OPT_R_COVER,		/* old input cover raster map */
-    G_OPT_R_ELEV,		/* old input elevation raster map */
-    G_OPT_R_ELEVS,		/* old input elevation raster maps */
-    G_OPT_R3_INPUT,		/* old input raster3d map */
-    G_OPT_R3_INPUTS,		/* old input raster3d maps */
-    G_OPT_R3_OUTPUT,		/* new output raster3d map */
-    G_OPT_V_INPUT,		/* old input vector map */
-    G_OPT_V_INPUTS,		/* old input vector maps */
-    G_OPT_V_OUTPUT,		/* new output vector map */
-    G_OPT_V_MAP,		/* old input vector map */
-    G_OPT_V_TYPE,		/* primitive type */
-    G_OPT_V_FIELD,		/* field number */
-    G_OPT_V_CAT,		/* one category */
-    G_OPT_V_CATS,		/* more categories */
-    G_OPT_F_INPUT,		/* old input file */
-    G_OPT_F_OUTPUT,		/* new output file */
-    G_OPT_F_SEP,		/* data field separator */
-    G_OPT_C_FG,			/* foreground color */
-    G_OPT_C_BG			/* background color */
-} STD_OPT;
-/* Message format */
-#define G_INFO_FORMAT_STANDARD 0	/* GRASS_MESSAGE_FORMAT=standard or not defined */
-#define G_INFO_FORMAT_GUI      1	/* GRASS_MESSAGE_FORMAT=gui */
-#define G_INFO_FORMAT_SILENT   2	/* GRASS_MESSAGE_FORMAT=silent */
-/* Icon types */
-#define G_ICON_CROSS  0
-#define G_ICON_BOX    1
-#define G_ICON_ARROW  2
-/* default colors */
-#define DEFAULT_FG_COLOR "black"
-#define DEFAULT_BG_COLOR "white"
-/* for G_get_raster_sample(), INTERP_TYPE */
-#define UNKNOWN	  0
-#define NEAREST   1		/* nearest neighbor interpolation  */
-#define BILINEAR  2		/* bilinear interpolation          */
-#define CUBIC     3		/* cubic interpolation             */
-/* for raster maps */
-#define GR_FATAL_EXIT    0
-#define GR_FATAL_PRINT   1
-#define GR_FATAL_RETURN  2
-/* Element types */
-enum
-{				/* Dir */
-    G_ELEMENT_RASTER = 1,	/* cell */
-    G_ELEMENT_VECTOR = 2,	/* vector */
-    G_ELEMENT_GROUP = 3,	/* group */
-    G_ELEMENT_REGION = 4	/* window */
-/*=========================== Typedefs/Structures ==========================*/
-typedef int CELL;
-typedef double DCELL;
-typedef float FCELL;
-extern CELL CELL_NODATA;
-typedef int RASTER_MAP_TYPE;
-/* for G_get_raster_sample() */
-typedef int INTERP_TYPE;
-struct Cell_head
-    int format;			/* max numer of bytes per cell minus 1          */
-    int compressed;		/* 0 = uncompressed, 1 = compressed, -1 pre 3.0 */
-    int rows;			/* number of rows in the data 2D                */
-    int rows3;			/* number of rows in the data 3D                */
-    int cols;			/* number of columns in the data 2D             */
-    int cols3;			/* number of columns in the data 3D             */
-    int depths;			/* number of depths in data                     */
-    int proj;			/* Projection (see #defines above)              */
-    int zone;			/* Projection zone                              */
-    double ew_res;		/* East to West cell size 2D                    */
-    double ew_res3;		/* East to West cell size 3D                    */
-    double ns_res;		/* North to South cell size 2D                  */
-    double ns_res3;		/* North to South cell size 3D                  */
-    double tb_res;		/* Top to Bottom cell size                      */
-    double north;		/* coordinates of layer                         */
-    double south;
-    double east;
-    double west;
-    double top;
-    double bottom;
-struct _Color_Rule_
-    struct
-	DCELL value;
-	unsigned char red;
-	unsigned char grn;
-	unsigned char blu;
-    } low, high;
-    struct _Color_Rule_ *next;
-    struct _Color_Rule_ *prev;
-struct _Color_Info_
-    struct _Color_Rule_ *rules;
-    int n_rules;
-    struct
-	unsigned char *red;
-	unsigned char *grn;
-	unsigned char *blu;
-	unsigned char *set;
-	int nalloc;
-	int active;
-    } lookup;
-    struct
-	DCELL *vals;
-	/* pointers to color rules corresponding to the intervals btwn vals */
-	struct _Color_Rule_ **rules;
-	int nalloc;
-	int active;
-    } fp_lookup;
-    DCELL min, max;
-struct Colors
-    int version;		/* set by read_colors: -1=old,1=new */
-    DCELL shift;
-    int invert;
-    int is_float;		/* defined on floating point raster data? */
-    int null_set;		/* the colors for null are set? */
-    unsigned char null_red;
-    unsigned char null_grn;
-    unsigned char null_blu;
-    int undef_set;		/* the colors for cells not in range are set? */
-    unsigned char undef_red;
-    unsigned char undef_grn;
-    unsigned char undef_blu;
-    struct _Color_Info_ fixed;
-    struct _Color_Info_ modular;
-    DCELL cmin;
-    DCELL cmax;
-typedef struct
-    unsigned char r, g, b, a;	/* red, green, blue, and alpha */
-} RGBA_Color;
-typedef RGBA_Color RGB_Color;
-/* RGBA_Color alpha presets */
-#define RGBA_COLOR_OPAQUE     255
-#define RGBA_COLOR_TRANSPARENT  0
-#define RGBA_COLOR_NONE         0
-struct Reclass
-    char *name;			/* name of raster map being reclassed    */
-    char *mapset;		/* mapset in which "name" is found      */
-    int type;			/* type of reclass                      */
-    int num;			/* size of reclass table                */
-    CELL min;			/* table min                            */
-    CELL max;			/* table max                            */
-    CELL *table;		/* reclass table                        */
-struct FPReclass_table
-    DCELL dLow;			/* domain low */
-    DCELL dHigh;		/* domain high */
-    DCELL rLow;			/* range low */
-    DCELL rHigh;		/* range high */
-/* reclass structure from double to double used by r.recode to reclass */
-/* between types: int to double, float to int,... */
-struct FPReclass
-    int defaultDRuleSet;	/* 1 if default domain rule set */
-    int defaultRRuleSet;	/* 1 if default range rule set */
-    int infiniteLeftSet;	/* 1 if negative infinite interval rule exists */
-    int infiniteRightSet;	/* 1 if positive infinite interval rule exists */
-    int rRangeSet;		/* 1 if range range (i.e. interval) is set */
-    int maxNofRules;
-    int nofRules;
-    DCELL defaultDMin;		/* default domain minimum value */
-    DCELL defaultDMax;		/* default domain maximum value */
-    DCELL defaultRMin;		/* default range minimum value */
-    DCELL defaultRMax;		/* default range maximum value */
-    DCELL infiniteDLeft;	/* neg infinite rule */
-    DCELL infiniteDRight;	/* neg infinite rule */
-    DCELL infiniteRLeft;	/* pos infinite rule */
-    DCELL infiniteRRight;	/* pos infinite rule */
-    DCELL dMin;			/* minimum domain values in rules */
-    DCELL dMax;			/* maximum domain values in rules */
-    DCELL rMin;			/* minimum range values in rules */
-    DCELL rMax;			/* maximum range values in rules */
-    struct FPReclass_table *table;
-struct Quant_table
-    DCELL dLow;
-    DCELL dHigh;
-    CELL cLow;
-    CELL cHigh;
-struct Quant
-    int truncate_only;
-    int round_only;
-    int defaultCRuleSet;
-    int cRangeSet;
-    int maxNofRules;
-    int nofRules;
-    CELL defaultCMin;
-    CELL defaultCMax;
-    CELL infiniteCLeft;
-    CELL infiniteCRight;
-    DCELL dMin;
-    DCELL dMax;
-    CELL cMin;
-    CELL cMax;
-    struct Quant_table *table;
-    struct
-	DCELL *vals;
-	/* pointers to quant rules corresponding to the intervals btwn vals */
-	struct Quant_table **rules;
-	int nalloc;
-	int active;
-	DCELL inf_dmin;
-	DCELL inf_dmax;
-	CELL inf_min;
-	CELL inf_max;
-	/* all values smaller than inf_dmin become inf_min */
-	/* all values larger than inf_dmax become inf_max */
-	/* inf_min and/or inf_max can be NULL if there are no inf rules */
-    } fp_lookup;
-struct Categories
-    CELL ncats;			/* total number of categories              */
-    CELL num;			/* the highest cell values. Only exists
-				   for backwards compatibility = (CELL)
-				   max_fp_values in quant rules          */
-    char *title;		/* name of data layer                      */
-    char *fmt;			/* printf-like format to generate labels   */
-    float m1;			/* Multiplication coefficient 1            */
-    float a1;			/* Addition coefficient 1                  */
-    float m2;			/* Multiplication coefficient 2            */
-    float a2;			/* Addition coefficient 2                  */
-    struct Quant q;		/* rules mapping cell values to index in
-				   list of labels                        */
-    char **labels;		/* array of labels of size num             */
-    int *marks;			/* was the value with this label was used? */
-    int nalloc;
-    int last_marked_rule;
-    /* NOTE: to get a rule corresponfing to cats.labels[i], use */
-    /* G_get_ith_c/f/d_raster_cat (pcats, i, val1, val2) */
-    /* it calls */
-    /* G_quant_get_ith_rule(&cats->q, i, val1, val2, &index, &index); */
-    /* and idex ==i, because rule is added at the same time as a */
-    /* label, and quant rules are never reordered. Olga apr,95 */
-struct History
-    char mapid[RECORD_LEN];
-    char title[RECORD_LEN];
-    char mapset[RECORD_LEN];
-    char creator[RECORD_LEN];
-    char maptype[RECORD_LEN];
-    char datsrc_1[RECORD_LEN];
-    char datsrc_2[RECORD_LEN];
-    char keywrd[RECORD_LEN];
-    int edlinecnt;
-    char edhist[MAXEDLINES][RECORD_LEN];
-struct Cell_stats
-    struct Cell_stats_node
-	int idx;
-	long *count;
-	int left;
-	int right;
-    } *node;			/* tree of values */
-    int tlen;			/* allocated tree size */
-    int N;			/* number of actual nodes in tree */
-    int curp;
-    long null_data_count;
-    int curoffset;
-struct Histogram
-    int num;
-    struct Histogram_list
-	CELL cat;
-	long count;
-    } *list;
-struct Range
-    CELL min;
-    CELL max;
-    int first_time;		/* whether or not range was updated */
-struct FPRange
-    DCELL min;
-    DCELL max;
- ** Structure for I/O of 3dview files  (view.c)
-struct G_3dview
-    char pgm_id[40];		/* user-provided identifier */
-    float from_to[2][3];	/* eye position & lookat position */
-    float fov;			/* field of view */
-    float twist;		/* right_hand rotation about from_to */
-    float exag;			/* terrain elevation exageration */
-    int mesh_freq;		/* cells per grid line */
-    int poly_freq;		/* cells per polygon */
-    int display_type;		/* 1 for mesh, 2 for poly, 3 for both */
-    int lightson;		/* boolean */
-    int dozero;			/* boolean */
-    int colorgrid;		/* boolean */
-    int shading;		/* boolean */
-    int fringe;			/* boolean */
-    int surfonly;		/* boolean */
-    int doavg;			/* boolean */
-    char grid_col[40];		/* colors */
-    char bg_col[40];		/* colors */
-    char other_col[40];		/* colors */
-    float lightpos[4];		/* east, north, height, 1.0 for local 0.0 infin */
-    float lightcol[3];		/* values between 0.0 to 1.0 for red, grn, blu */
-    float ambient;
-    float shine;
-    struct Cell_head vwin;
-struct Key_Value
-    int nitems;
-    int nalloc;
-    char **key;
-    char **value;
-struct Option			/* Structure that stores option info */
-    char *key;			/* Key word used on command line    */
-    int type;			/* Option type                      */
-    int required;		/* REQUIRED or OPTIONAL             */
-    int multiple;		/* Multiple entries OK              */
-    char *options;		/* Approved values or range or NULL */
-    char **opts;		/* NULL or NULL terminated array of parsed options */
-    char *key_desc;		/* one word describing the key      */
-    char *label;		/* Optional short label, used in GUI as item label */
-    char *description;		/* String describing option         */
-    char *descriptions;		/* ';' separated pairs of option and option descriptions */
-    /* For example: (with ->options = "break,rmdupl")
-     * "break;break lines on intersections;"
-     * "rmdupl;remove duplicates"
-    char **descs;		/* parsed descriptions, array of either NULL or string */
-    /* in the same order as options */
-    char *answer;		/* Option answer                    */
-    char *def;			/* Where original answer gets saved */
-    char **answers;		/* Option answers (for multiple=YES) */
-    struct Option *next_opt;	/* Pointer to next option struct    */
-    char *gisprompt;		/* Interactive prompt guidance      */
-    char *guisection;		/* GUI Layout guidance: ';' delimited heirarchical tree position */
-    int (*checker) ();		/* Routine to check answer or NULL  */
-    int count;
-struct Flag			/* Structure that stores flag info  */
-    char key;			/* Key char used on command line    */
-    char answer;		/* Stores flag state: 0/1           */
-    char *description;		/* String describing flag meaning   */
-    struct Flag *next_flag;	/* Pointer to next flag struct      */
-struct GModule			/* Structure that stores module info  */
-    char *label;		/* Optional short description for GUI */
-    char *description;		/* String describing module */
-    char *keywords;		/* Keywords describing module */
-    /* further items are possible: author(s), version */
-    int overwrite;		/* overwrite old files */
-    int verbose;		/* print all informations about progress and so on */
-struct TimeStamp
-    DateTime dt[2];		/* two datetimes */
-    int count;
-/*============================== Prototypes ================================*/
-/* Since there are so many prototypes for the gis library they are stored */
-/* in the file gisdefs.h */
-#include <grass/gisdefs.h>
-#endif /* GRASS_GIS_H */
Deleted: grass/trunk/swig/perl/gisdefs.h
--- grass/trunk/swig/perl/gisdefs.h	2008-08-27 20:08:49 UTC (rev 33127)
+++ grass/trunk/swig/perl/gisdefs.h	2008-08-27 20:10:02 UTC (rev 33128)
@@ -1,1276 +0,0 @@
- * PURPOSE:     This file contains the prototypes for all the functions in the
- *              gis library (src/libes/gis).
- *              for details.
-#ifndef GRASS_GISDEFS_H
-#define GRASS_GISDEFS_H
-/* none */
-/* none (look in gis.h) */
-/* adj_cellhd.c */
-char *G_adjust_Cell_head(struct Cell_head *, int, int);
-char *G_adjust_Cell_head3(struct Cell_head *, int, int, int);
-/* align_window.c */
-char *G_align_window(struct Cell_head *, const struct Cell_head *);
-/* alloc.c */
-void *G_malloc(size_t);
-void *G_calloc(size_t, size_t);
-void *G_realloc(void *, size_t);
-void G_free(void *);
-/* alloc_cell.c */
-int G_raster_size(RASTER_MAP_TYPE);
-CELL *G_allocate_cell_buf(void);
-void *G_allocate_raster_buf(RASTER_MAP_TYPE);
-CELL *G_allocate_c_raster_buf(void);
-FCELL *G_allocate_f_raster_buf(void);
-DCELL *G_allocate_d_raster_buf(void);
-char *G_allocate_null_buf(void);
-unsigned char *G__allocate_null_bits(int);
-int G__null_bitstream_size(int);
-/* area.c */
-int G_begin_cell_area_calculations(void);
-double G_area_of_cell_at_row(int);
-int G_begin_polygon_area_calculations(void);
-double G_area_of_polygon(const double *, const double *, int);
-/* area_ellipse.c */
-int G_begin_zone_area_on_ellipsoid(double, double, double);
-double G_darea0_on_ellipsoid(double);
-double G_area_for_zone_on_ellipsoid(double, double);
-/* area_poly1.c */
-int G_begin_ellipsoid_polygon_area(double, double);
-double G_ellipsoid_polygon_area(const double *, const double *, int);
-/* area_poly2.c */
-double G_planimetric_polygon_area(const double *, const double *, int);
-/* area_sphere.c */
-int G_begin_zone_area_on_sphere(double, double);
-double G_darea0_on_sphere(double);
-double G_area_for_zone_on_sphere(double, double);
-/* ascii_chk.c */
-int G_ascii_check(char *);
-/* ask.c */
-char *G_ask_new(const char *, char *, char *, char *);
-char *G_ask_new_ext(const char *, char *, char *, char *, char *, int (*)());
-char *G_ask_old(const char *, char *, char *, char *);
-char *G_ask_old_ext(const char *, char *, char *, char *, char *, int (*)());
-char *G_ask_any(const char *, char *, char *, char *, int);
-char *G_ask_any_ext(const char *, char *, char *, char *, int, char *,
-		    int (*)());
-char *G_ask_in_mapset(const char *, char *, char *, char *);
-char *G_ask_in_mapset_ext(const char *, char *, char *, char *, char *,
-			  int (*)());
-char *G_ask_new_file(const char *, char *, char *, char *);
-char *G_ask_old_file(const char *, char *, char *, char *);
-int G_set_ask_return_msg(const char *);
-char *G_get_ask_return_msg(void);
-/* ask_cell.c */
-char *G_ask_cell_new(const char *, char *);
-char *G_ask_cell_old(const char *, char *);
-char *G_ask_cell_in_mapset(const char *, char *);
-char *G_ask_cell_any(const char *, char *);
-/* ask_vctrs.c */
-char *G_ask_vector_new(const char *, char *);
-char *G_ask_vector_old(const char *, char *);
-char *G_ask_vector_any(const char *, char *);
-char *G_ask_vector_in_mapset(const char *, char *);
-/* asprintf.c */
-/* Do it better if you know how */
-/* asprintf is not found on MINGW but exists */
- *  Because configure script in GDAL test is G_asprintf exists in gis lib
- *  the G_asprintf macro is disabled until a stable version of GDAL
- *  with a different function becomes widely used
-/* commented - need to better understand how to SWIG this: */
-/* int G_vasprintf(char **, const char *, va_list); */
-/* int G_asprintf(char **, const char *, ...); */
-/* auto_mask.c */
-int G__check_for_auto_masking(void);
-int G_suppress_masking(void);
-int G_unsuppress_masking(void);
-/* basename.c */
-char *G_basename(char *, const char *);
-/* bres_line.c */
-int G_bresenham_line(int, int, int, int, int (*)(int, int));
-/* cats.c */
-int G_read_cats(const char *, const char *, struct Categories *);
-int G_read_raster_cats(const char *, const char *, struct Categories *);
-int G_read_vector_cats(const char *, const char *, struct Categories *);
-CELL G_number_of_cats(const char *, const char *);
-char *G_get_cats_title(const struct Categories *);
-char *G_get_raster_cats_title(const struct Categories *);
-char *G_get_cat(CELL, struct Categories *);
-char *G_get_c_raster_cat(CELL *, struct Categories *);
-char *G_get_f_raster_cat(FCELL *, struct Categories *);
-char *G_get_d_raster_cat(DCELL *, struct Categories *);
-char *G_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
-int G_unmark_raster_cats(struct Categories *);
-int G_mark_c_raster_cats(CELL *, int, struct Categories *);
-int G_mark_f_raster_cats(FCELL *, int, struct Categories *);
-int G_mark_d_raster_cats(DCELL *, int, struct Categories *);
-int G_mark_raster_cats(void *, int, struct Categories *, RASTER_MAP_TYPE);
-int G_rewind_raster_cats(struct Categories *);
-char *G_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
-				     long *);
-char *G_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
-				     long *);
-char *G_get_next_marked_f_raster_cat(struct Categories *, FCELL *, FCELL *,
-				     long *);
-char *G_get_next_marked_raster_cat(struct Categories *, void *, void *,
-				   long *, RASTER_MAP_TYPE);
-int G_set_cat(CELL, char *, struct Categories *);
-int G_set_c_raster_cat(CELL *, CELL *, char *, struct Categories *);
-int G_set_f_raster_cat(FCELL *, FCELL *, char *, struct Categories *);
-int G_set_d_raster_cat(DCELL *, DCELL *, char *, struct Categories *);
-int G_set_raster_cat(void *, void *, char *, struct Categories *,
-		     RASTER_MAP_TYPE);
-int G_write_cats(char *, struct Categories *);
-int G_write_raster_cats(char *, struct Categories *);
-int G_write_vector_cats(char *, struct Categories *);
-int G__write_cats(char *, char *, struct Categories *);
-char *G_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
-			     DCELL *);
-char *G_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
-char *G_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
-char *G_get_ith_raster_cat(const struct Categories *, int, void *, void *,
-			   RASTER_MAP_TYPE);
-int G_init_cats(CELL, const char *, struct Categories *);
-int G_init_raster_cats(const char *, struct Categories *);
-int G_set_cats_title(const char *, struct Categories *);
-int G_set_raster_cats_title(const char *, struct Categories *);
-int G_set_cats_fmt(const char *, double, double, double, double,
-		   struct Categories *);
-int G_set_raster_cats_fmt(const char *, double, double, double, double,
-int G_free_cats(struct Categories *);
-int G_free_raster_cats(struct Categories *);
-int G_copy_raster_cats(struct Categories *, const struct Categories *);
-int G_number_of_raster_cats(struct Categories *);
-int G_sort_cats(struct Categories *);
-/* cell_stats.c */
-int G_init_cell_stats(struct Cell_stats *);
-int G_update_cell_stats(const CELL *, int, struct Cell_stats *);
-int G_find_cell_stat(CELL, long *, const struct Cell_stats *);
-int G_rewind_cell_stats(struct Cell_stats *);
-int G_next_cell_stat(CELL *, long *, struct Cell_stats *);
-int G_get_stats_for_null_value(long *, const struct Cell_stats *);
-int G_free_cell_stats(struct Cell_stats *);
-/* cell_title.c */
-char *G_get_cell_title(const char *, const char *);
-/* cellstats_eq.c */
-int G_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
-			  void (*)(CELL, CELL, CELL));
-/* chop.c */
-char *G_chop(char *);
-/* clear_scrn.c */
-int G_clear_screen(void);
-/* clicker.c */
-int G_clicker(void);
-/* closecell.c */
-int G_close_cell(int);
-int G_unopen_cell(int);
-/* color_compat.c */
-int G_make_ryg_colors(struct Colors *, CELL, CELL);
-int G_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_aspect_colors(struct Colors *, CELL, CELL);
-int G_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_byr_colors(struct Colors *, CELL, CELL);
-int G_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_byg_colors(struct Colors *, CELL, CELL);
-int G_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_grey_scale_colors(struct Colors *, CELL, CELL);
-int G_make_grey_scale_fp_colors(struct Colors *, double, double);
-int G_make_gyr_colors(struct Colors *, CELL, CELL);
-int G_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_rainbow_colors(struct Colors *, CELL, CELL);
-int G_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_ramp_colors(struct Colors *, CELL, CELL);
-int G_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_wave_colors(struct Colors *, CELL, CELL);
-int G_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
-/* color_free.c */
-int G_free_colors(struct Colors *);
-int G__color_free_rules(struct _Color_Info_ *);
-int G__color_free_lookup(struct _Color_Info_ *);
-int G__color_free_fp_lookup(struct _Color_Info_ *);
-int G__color_reset(struct Colors *);
-/* color_get.c */
-int G_get_color(CELL, int *, int *, int *, struct Colors *);
-int G_get_raster_color(const void *, int *, int *, int *, struct Colors *,
-		       RASTER_MAP_TYPE);
-int G_get_c_raster_color(const CELL *, int *, int *, int *, struct Colors *);
-int G_get_f_raster_color(const FCELL *, int *, int *, int *, struct Colors *);
-int G_get_d_raster_color(const DCELL *, int *, int *, int *, struct Colors *);
-int G_get_null_value_color(int *, int *, int *, const struct Colors *);
-int G_get_default_color(int *, int *, int *, const struct Colors *);
-/* color_hist.c */
-int G_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
-int G_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int,
-				int);
-/* color_init.c */
-int G_init_colors(struct Colors *);
-/* color_insrt.c */
-int G__insert_color_into_lookup(CELL, int, int, int, struct _Color_Info_ *);
-/* color_invrt.c */
-int G_invert_colors(struct Colors *);
-/* color_look.c */
-int G_lookup_colors(const CELL *, unsigned char *, unsigned char *,
-		    unsigned char *, unsigned char *, int, struct Colors *);
-int G_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
-			     struct Colors *);
-int G_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
-			   struct Colors *, RASTER_MAP_TYPE);
-int G_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
-			     struct Colors *);
-int G_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
-			     struct Colors *);
-int G__lookup_colors(const void *, unsigned char *, unsigned char *,
-		     unsigned char *, unsigned char *, int, struct Colors *,
-		     int, int, RASTER_MAP_TYPE);
-int G__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
-			      unsigned char *, const struct _Color_Rule_ *);
-/* color_org.c */
-int G__organize_colors(struct Colors *);
-/* color_rand.c */
-int G_make_random_colors(struct Colors *, CELL, CELL);
-/* color_range.c */
-int G_set_color_range(CELL, CELL, struct Colors *);
-int G_set_d_color_range(DCELL, DCELL, struct Colors *);
-int G_get_color_range(CELL *, CELL *, const struct Colors *);
-int G_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
-/* color_read.c */
-int G_read_colors(const char *, const char *, struct Colors *);
-int G_mark_colors_as_fp(struct Colors *);
-/* color_remove.c */
-int G_remove_colors(const char *, const char *);
-/* color_rule.c */
-int G_add_d_raster_color_rule(const DCELL *, int, int, int, const DCELL *,
-			      int, int, int, struct Colors *);
-int G_add_f_raster_color_rule(const FCELL *, int, int, int, const FCELL *,
-int G_add_c_raster_color_rule(const CELL *, int, int, int, const CELL *, int,
-			      int, int, struct Colors *);
-int G_add_raster_color_rule(const void *, int, int, int, const void *, int,
-			    int, int, struct Colors *, RASTER_MAP_TYPE);
-int G_add_color_rule(const CELL, int, int, int, const CELL, int, int, int,
-		     struct Colors *);
-int G_add_modular_d_raster_color_rule(const DCELL *, int, int, int,
-				      const DCELL *, int, int, int,
-				      struct Colors *);
-int G_add_modular_f_raster_color_rule(const FCELL *, int, int, int,
-				      const FCELL *, int, int, int,
-				      struct Colors *);
-int G_add_modular_c_raster_color_rule(const CELL *, int, int, int,
-				      const CELL *, int, int, int,
-				      struct Colors *);
-int G_add_modular_raster_color_rule(const void *, int, int, int, const void *,
-				    int, int, int, struct Colors *,
-				    RASTER_MAP_TYPE);
-int G_add_modular_color_rule(CELL, int, int, int, CELL, int, int, int,
-			     struct Colors *);
-/* color_rule_get.c */
-int G_colors_count(const struct Colors *);
-int G_get_f_color_rule(DCELL *, unsigned char *, unsigned char *,
-		       unsigned char *, DCELL *, unsigned char *,
-		       const struct Colors *, int);
-/* color_rules.c */
-typedef int read_rule_fn(void *, DCELL, DCELL,
-			 DCELL *, int *, int *, int *, int *, int *, int *);
-int G_parse_color_rule(DCELL, DCELL, const char *, DCELL *, int *, int *,
-		       int *, int *, int *, int *);
-const char *G_parse_color_rule_error(int);
-int G_read_color_rule(void *, DCELL, DCELL, DCELL *, int *, int *, int *,
-		      int *, int *, int *);
-int G_read_color_rules(struct Colors *, DCELL, DCELL, read_rule_fn *, void *);
-int G_load_colors(struct Colors *, const char *, CELL, CELL);
-int G_load_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-int G_make_colors(struct Colors *, const char *, CELL, CELL);
-int G_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-/* color_set.c */
-int G_set_color(CELL, int, int, int, struct Colors *);
-int G_set_d_color(DCELL, int, int, int, struct Colors *);
-int G_set_null_value_color(int, int, int, struct Colors *);
-int G_set_default_color(int, int, int, struct Colors *);
-/* color_shift.c */
-int G_shift_colors(int, struct Colors *);
-int G_shift_d_colors(DCELL, struct Colors *);
-/* color_str.c */
-int G_str_to_color(const char *, int *, int *, int *);
-/* color_write.c */
-int G_write_colors(const char *, const char *, struct Colors *);
-int G__write_colors(FILE *, struct Colors *);
-/* color_xform.c */
-int G_histogram_eq_colors(struct Colors *, struct Colors *,
-			  struct Cell_stats *);
-int G_log_colors(struct Colors *, struct Colors *, int);
-/* commas.c */
-int G_insert_commas(char *);
-int G_remove_commas(char *);
-/* copy.c */
-int G_copy(void *, const void *, int);
-/* copy_file.c */
-int G_copy_file(const char *infile, const char *outfile);
-/* dalloc.c */
-double *G_alloc_vector(size_t);
-double **G_alloc_matrix(int, int);
-float *G_alloc_fvector(size_t);
-float **G_alloc_fmatrix(int, int);
-int G_free_vector(double *);
-int G_free_matrix(double **);
-int G_free_fmatrix(float **);
-/* date.c */
-char *G_date(void);
-/* datum.c */
-int G_get_datum_by_name(const char *);
-char *G_datum_name(int);
-char *G_datum_description(int);
-char *G_datum_ellipsoid(int);
-int G_get_datumparams_from_projinfo(const struct Key_Value *projinfo,
-				    char *datumname, char *params);
-/* debug.c */
-int G_debug(int, const char *, ...);
-/* distance.c */
-int G_begin_distance_calculations(void);
-double G_distance(double, double, double, double);
-double G_distance_between_line_segments(double, double, double, double,
-					double, double, double, double);
-double G_distance_point_to_line_segment(double, double, double, double,
-					double, double);
-/* done_msg.c */
-int G_done_msg(const char *, ...);
-/* eigen_tools.c */
-int G_tqli(double[], double[], int, double **);
-void G_tred2(double **, int, double[], double[]);
-/* endian.c */
-int G_is_little_endian(void);
-/* env.c */
-char *G_getenv(const char *);
-char *G_getenv2(const char *, int);
-char *G__getenv(const char *);
-char *G__getenv2(const char *, int);
-int G_setenv(const char *, const char *);
-int G_setenv2(const char *, const char *, int);
-int G__setenv(const char *, const char *);
-int G__setenv2(const char *, const char *, int);
-int G_unsetenv(const char *);
-int G_unsetenv2(const char *, int);
-int G__write_env(void);
-char *G__env_name(int);
-int G__read_env(void);
-void G_set_gisrc_mode(int);
-int G_get_gisrc_mode(void);
-int G__create_alt_env(void);
-int G__switch_env(void);
-/* error.c */
-int G_info_format(void);
-void G_message(const char *, ...);
-void G_verbose_message(const char *, ...);
-void G_important_message(const char *, ...);
-int G_fatal_error(const char *, ...);
-int G_warning(const char *, ...);
-int G_suppress_warnings(int);
-int G_sleep_on_error(int);
-int G_set_error_routine(int (*)(const char *, int));
-int G_unset_error_routine(void);
-/* file_name.c */
-char *G__file_name(char *, const char *, const char *, const char *);
-char *G__file_name_misc(char *, const char *, const char *, const char *,
-			const char *);
-/* find_cell.c */
-char *G_find_cell(char *, const char *);
-char *G_find_cell2(const char *, const char *);
-/* find_file.c */
-char *G_find_file(const char *, char *, const char *);
-char *G_find_file2(const char *, const char *, const char *);
-char *G_find_file_misc(const char *, const char *, char *, const char *);
-char *G_find_file2_misc(const char *, const char *, const char *,
-			const char *);
-/* find_etc.c */
-char *G_find_etc(const char *);
-/* find_vect.c */
-char *G_find_vector(char *, const char *);
-char *G_find_vector2(const char *, const char *);
-/* flate.c */
-int G_zlib_compress(const unsigned char *, int, unsigned char *, int);
-int G_zlib_expand(const unsigned char *, int, unsigned char *, int);
-int G_zlib_write(int, const unsigned char *, int);
-int G_zlib_read(int, int, unsigned char *, int);
-int G_zlib_write_noCompress(int, const unsigned char *, int);
-/* fork.c */
-int G_fork(void);
-/* format.c */
-int G__check_format(int);
-int G__read_row_ptrs(int);
-int G__write_row_ptrs(int);
-/* fpreclass.c */
-void G_fpreclass_clear(struct FPReclass *);
-void G_fpreclass_reset(struct FPReclass *);
-int G_fpreclass_init(struct FPReclass *);
-void G_fpreclass_set_domain(struct FPReclass *, DCELL, DCELL);
-void G_fpreclass_set_range(struct FPReclass *, DCELL, DCELL);
-int G_fpreclass_get_limits(const struct FPReclass *, DCELL *, DCELL *,
-			   DCELL *, DCELL *);
-int G_fpreclass_nof_rules(const struct FPReclass *);
-void G_fpreclass_get_ith_rule(const struct FPReclass *, int, DCELL *, DCELL *,
-void G_fpreclass_set_neg_infinite_rule(struct FPReclass *, DCELL, DCELL);
-int G_fpreclass_get_neg_infinite_rule(const struct FPReclass *, DCELL *,
-				      DCELL *);
-void G_fpreclass_set_pos_infinite_rule(struct FPReclass *, DCELL, DCELL);
-int G_fpreclass_get_pos_infinite_rule(const struct FPReclass *, DCELL *,
-				      DCELL *);
-void G_fpreclass_add_rule(struct FPReclass *, DCELL, DCELL, DCELL, DCELL);
-void G_fpreclass_reverse_rule_order(struct FPReclass *);
-DCELL G_fpreclass_get_cell_value(const struct FPReclass *, DCELL);
-void G_fpreclass_perform_di(const struct FPReclass *, const DCELL *, CELL *,
-			    int);
-void G_fpreclass_perform_df(const struct FPReclass *, const DCELL *, FCELL *,
-			    int);
-void G_fpreclass_perform_dd(const struct FPReclass *, const DCELL *, DCELL *,
-			    int);
-void G_fpreclass_perform_fi(const struct FPReclass *, const FCELL *, CELL *,
-			    int);
-void G_fpreclass_perform_ff(const struct FPReclass *, const FCELL *, FCELL *,
-			    int);
-void G_fpreclass_perform_fd(const struct FPReclass *, const FCELL *, DCELL *,
-			    int);
-void G_fpreclass_perform_ii(const struct FPReclass *, const CELL *, CELL *,
-			    int);
-void G_fpreclass_perform_if(const struct FPReclass *, const CELL *, FCELL *,
-			    int);
-void G_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
-			    int);
-/* geodesic.c */
-int G_begin_geodesic_equation(double, double, double, double);
-double G_geodesic_lat_from_lon(double);
-/* geodist.c */
-int G_begin_geodesic_distance(double, double);
-int G_set_geodesic_distance_lat1(double);
-int G_set_geodesic_distance_lat2(double);
-double G_geodesic_distance_lon_to_lon(double, double);
-double G_geodesic_distance(double, double, double, double);
-/* get_cellhd.c */
-int G_get_cellhd(const char *, const char *, struct Cell_head *);
-/* get_datum_name.c */
-int G_ask_datum_name(char *, char *);
-/* get_ell_name.c */
-int G_ask_ellipse_name(char *);
-/* get_ellipse.c */
-int G_get_ellipsoid_parameters(double *, double *);
-int G_get_spheroid_by_name(const char *, double *, double *, double *);
-int G_get_ellipsoid_by_name(const char *, double *, double *);
-char *G_ellipsoid_name(int);
-char *G_ellipsoid_description(int);
-/* get_projinfo.c */
-struct Key_Value *G_get_projunits(void);
-struct Key_Value *G_get_projinfo(void);
-/* get_projname.c */
-int G_ask_proj_name(char *, char *);
-/* get_row.c */
-int G_get_map_row_nomask(int, CELL *, int);
-int G_get_raster_row_nomask(int, void *, int, RASTER_MAP_TYPE);
-int G_get_c_raster_row_nomask(int, CELL *, int);
-int G_get_f_raster_row_nomask(int, FCELL *, int);
-int G_get_d_raster_row_nomask(int, DCELL *, int);
-int G_get_map_row(int, CELL *, int);
-int G_get_raster_row(int, void *, int, RASTER_MAP_TYPE);
-int G_get_c_raster_row(int, CELL *, int);
-int G_get_f_raster_row(int, FCELL *, int);
-int G_get_d_raster_row(int, DCELL *, int);
-int G_get_null_value_row(int, char *, int);
-/* get_row_colr.c */
-int G_get_raster_row_colors(int, int, struct Colors *,
-			    unsigned char *, unsigned char *, unsigned char *,
-			    unsigned char *);
-/* get_window.c */
-int G_get_window(struct Cell_head *);
-int G_get_default_window(struct Cell_head *);
-char *G__get_window(struct Cell_head *, const char *, const char *,
-		    const char *);
-/* getl.c */
-int G_getl(char *, int, FILE *);
-int G_getl2(char *, int, FILE *);
-/* gets.c */
-int G_gets(char *);
-/* gisbase.c */
-char *G_gisbase(void);
-/* gisdbase.c */
-char *G_gisdbase(void);
-/* gishelp.c */
-/* gisinit.c */
-int G_gisinit(const char *);
-int G_no_gisinit(void);
-int G__check_gisinit(void);
-/* histo_eq.c */
-int G_histogram_eq(const struct Histogram *, unsigned char **, CELL *,
-		   CELL *);
-/* histogram.c */
-int G_init_histogram(struct Histogram *);
-int G_read_histogram(const char *, const char *, struct Histogram *);
-int G_write_histogram(const char *, const struct Histogram *);
-int G_write_histogram_cs(const char *, struct Cell_stats *);
-int G_make_histogram_cs(struct Cell_stats *, struct Histogram *);
-int G_get_histogram_num(const struct Histogram *);
-CELL G_get_histogram_cat(int, const struct Histogram *);
-long G_get_histogram_count(int, const struct Histogram *);
-int G_free_histogram(struct Histogram *);
-int G_sort_histogram(struct Histogram *);
-int G_sort_histogram_by_count(struct Histogram *);
-int G_remove_histogram(const char *);
-int G_add_histogram(CELL, long, struct Histogram *);
-int G_set_histogram(CELL, long, struct Histogram *);
-int G_extend_histogram(CELL, long, struct Histogram *);
-int G_zero_histogram(struct Histogram *);
-/* history.c */
-int G_read_history(const char *, const char *, struct History *);
-int G_write_history(const char *, struct History *);
-int G_short_history(const char *, const char *, struct History *);
-int G_command_history(struct History *);
-/* home.c */
-char *G_home(void);
-char *G__home(void);
-/* ialloc.c */
-int *G_alloc_ivector(size_t);
-int **G_alloc_imatrix(int, int);
-int G_free_ivector(int *);
-int G_free_imatrix(int **);
-/* index.c */
-char *G_index(const char *, int);
-char *G_rindex(const char *, int);
-/* init_map.c */
-int G__random_d_initialize_0(int, int, int);
-int G__random_f_initialize_0(int, int, int);
-/* interp.c */
-DCELL G_interp_linear(double, DCELL, DCELL);
-DCELL G_interp_bilinear(double, double, DCELL, DCELL, DCELL, DCELL);
-DCELL G_interp_cubic(double, DCELL, DCELL, DCELL, DCELL);
-DCELL G_interp_bicubic(double, double,
-		       DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL,
-		       DCELL);
-/* intersect.c */
-int G_intersect_line_segments(double, double, double, double, double, double,
-			      double, double, double *, double *, double *,
-			      double *);
-/* intr_char.c */
-char G_intr_char(void);
-/* is.c */
-int G_is_gisbase(const char *);
-int G_is_location(const char *);
-int G_is_mapset(const char *);
-/* key_value1.c */
-struct Key_Value *G_create_key_value(void);
-int G_set_key_value(const char *, const char *, struct Key_Value *);
-char *G_find_key_value(const char *, const struct Key_Value *);
-int G_free_key_value(struct Key_Value *);
-/* key_value2.c */
-int G_fwrite_key_value(FILE *, const struct Key_Value *);
-struct Key_Value *G_fread_key_value(FILE *);
-/* key_value3.c */
-int G_write_key_value_file(const char *, const struct Key_Value *, int *);
-struct Key_Value *G_read_key_value_file(const char *, int *);
-/* key_value4.c */
-int G_update_key_value_file(const char *, const char *, const char *);
-int G_lookup_key_value_from_file(const char *, const char *, char[], int);
-/* legal_name.c */
-int G_legal_filename(const char *);
-int G_check_input_output_name(const char *, const char *, int);
-/* line_dist.c */
-int G_set_distance_to_line_tolerance(double);
-double G_distance2_point_to_line(double, double, double, double, double,
-				 double);
-/* list.c */
-int G_list_element(const char *, const char *, const char *,
-		   int (*)(const char *, const char *, const char *));
-char **G_list(int, const char *, const char *, const char *);
-void G_free_list(char **);
-/* ll_format.c */
-int G_lat_format(double, char *);
-char *G_lat_format_string(void);
-int G_lon_format(double, char *);
-char *G_lon_format_string(void);
-int G_llres_format(double, char *);
-char *G_llres_format_string(void);
-int G_lat_parts(double, int *, int *, double *, char *);
-int G_lon_parts(double, int *, int *, double *, char *);
-/* ll_scan.c */
-int G_lat_scan(const char *, double *);
-int G_lon_scan(const char *, double *);
-int G_llres_scan(const char *, double *);
-/* location.c */
-char *G_location_path(void);
-char *G_location(void);
-char *G__location_path(void);
-/* ls.c */
-char **G__ls(const char *, int *);
-void G_ls(const char *, FILE *);
-void G_ls_format(const char **, int, int, FILE *);
-/* lu.c */
-int G_ludcmp(double **, int, int *, double *);
-void G_lubksb(double **, int, int *, double[]);
-/* lzw.c */
-unsigned char *lzw_decode(unsigned char *, unsigned int);
-int lzw_expand(int (*)(), int (*)());
-int G_lzw_nof_read_bytes(void);
-int G_lzw_max_used_bits(void);
-void G_lzw_set_bits(int);
-int G_lzw_compress(unsigned char *, unsigned char *, int);
-int G_lzw_expand(unsigned char *, unsigned char *, int);
-int G_lzw_compress_count_only_array(unsigned char *, int);
-int G_lzw_compress_count_only_file(int);
-int G_lzw_write(int, unsigned char *, int);
-int G_lzw_write_noCompress(int, unsigned char *, int);
-int G_lzw_test_status(int);
-int G_lzw_read2(int, unsigned char *, int, int);
-int G_lzw_read(int, unsigned char *, int);
-int G_lzw_transfer_compress(int, int, int);
-int G_lzw_transfer_expand(int, int, int);
-/* mach_name.c */
-char *G__machine_name(void);
-/* make_colr.c */
-int G_ask_colors(const char *, const char *, struct Colors *);
-/* make_loc.c */
-int G__make_location(const char *, struct Cell_head *, struct Key_Value *,
-		     struct Key_Value *, FILE *);
-int G_make_location(const char *, struct Cell_head *, struct Key_Value *,
-int G_compare_projections(const struct Key_Value *, const struct Key_Value *,
-			  const struct Key_Value *, const struct Key_Value *);
-/* make_mapset.c */
-int G__make_mapset(const char *gisdbase_name, const char *location_name,
-		   const char *mapset_name);
-int G_make_mapset(const char *gisdbase_name, const char *location_name,
-/* mapcase.c */
-char *G_tolcase(char *);
-char *G_toucase(char *);
-/* mapset.c */
-char *G_mapset(void);
-char *G__mapset(void);
-/* mapset_msc.c */
-int G__make_mapset_element(const char *);
-int G__make_mapset_element_misc(const char *, const char *);
-int G__mapset_permissions(const char *);
-int G__mapset_permissions2(const char *, const char *, const char *);
-/* mapset_nme.c */
-char *G__mapset_name(int);
-int G__create_alt_search_path(void);
-int G__switch_search_path(void);
-int G_reset_mapsets(void);
-char **G_available_mapsets(void);
-void G_add_mapset_to_search_path(const char *mapset);
-/* mask_info.c */
-char *G_mask_info(void);
-int G__mask_info(char *, char *);
-/* maskfd.c */
-int G_maskfd(void);
-/* myname.c */
-char *G_myname(void);
-/* named_colr.c */
-int G_color_values(const char *, float *, float *, float *);
-const char *G_color_name(int);
-/* nl_to_spaces.c */
-void G_newlines_to_spaces(char *);
-/* nme_in_mps.c */
-int G__name_in_mapset(const char *, char *, char *);
-int G__name_is_fully_qualified(const char *, char *, char *);
-char *G_fully_qualified_name(const char *, const char *);
-/* null_val.c */
-void G__init_null_patterns(void);
-void G__set_null_value(void *, int, int, RASTER_MAP_TYPE);
-void G_set_null_value(void *, int, RASTER_MAP_TYPE);
-void G_set_c_null_value(CELL *, int);
-void G_set_f_null_value(FCELL *, int);
-void G_set_d_null_value(DCELL *, int);
-int G_is_null_value(const void *, RASTER_MAP_TYPE);
-int G_is_c_null_value(const CELL *);
-int G_is_f_null_value(const FCELL *);
-int G_is_d_null_value(const DCELL *);
-int G_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
-int G_insert_c_null_values(CELL *, char *, int);
-int G_insert_f_null_values(FCELL *, char *, int);
-int G_insert_d_null_values(DCELL *, char *, int);
-int G__check_null_bit(const unsigned char *, int, int);
-int G__set_flags_from_01_random(const char *, unsigned char *, int, int, int);
-int G__convert_01_flags(const char *, unsigned char *, int);
-int G__convert_flags_01(char *, const unsigned char *, int);
-int G__init_null_bits(unsigned char *, int);
-/* open.c */
-int G_open_new(const char *, const char *);
-int G_open_old(const char *, const char *, const char *);
-int G_open_update(const char *, const char *);
-FILE *G_fopen_new(const char *, const char *);
-FILE *G_fopen_old(const char *, const char *, const char *);
-FILE *G_fopen_append(const char *, const char *);
-FILE *G_fopen_modify(const char *, const char *);
-/* open_misc.c */
-int G_open_new_misc(const char *, const char *, const char *);
-int G_open_old_misc(const char *, const char *, const char *, const char *);
-int G_open_update_misc(const char *, const char *, const char *);
-FILE *G_fopen_new_misc(const char *, const char *, const char *);
-FILE *G_fopen_old_misc(const char *, const char *, const char *,
-		       const char *);
-FILE *G_fopen_append_misc(const char *, const char *, const char *);
-FILE *G_fopen_modify_misc(const char *, const char *, const char *);
-/* opencell.c */
-int G_open_cell_old(const char *, const char *);
-int G__open_cell_old(const char *, const char *);
-int G_open_cell_new(const char *);
-int G_open_cell_new_random(const char *);
-int G_open_cell_new_uncompressed(const char *);
-int G_want_histogram(int);
-int G_set_cell_format(int);
-int G_cellvalue_format(CELL);
-int G_open_fp_cell_new(const char *);
-int G_open_fp_cell_new_uncompressed(const char *);
-int G__reallocate_work_buf(int);
-int G__reallocate_null_buf(void);
-int G__reallocate_mask_buf(void);
-int G__reallocate_temp_buf(void);
-int G_set_fp_type(RASTER_MAP_TYPE);
-int G_raster_map_is_fp(const char *, const char *);
-RASTER_MAP_TYPE G_raster_map_type(const char *, const char *);
-RASTER_MAP_TYPE G_raster_map_type2(const char *, const char *);
-RASTER_MAP_TYPE G__check_fp_type(const char *, const char *);
-RASTER_MAP_TYPE G_get_raster_map_type(int);
-int G_open_raster_new(const char *, RASTER_MAP_TYPE);
-int G_open_raster_new_uncompressed(const char *, RASTER_MAP_TYPE);
-int G_set_quant_rules(int, struct Quant *);
-/* parser.c */
-int G_disable_interactive(void);
-struct GModule *G_define_module(void);
-struct Flag *G_define_flag(void);
-struct Option *G_define_option(void);
-struct Option *G_define_standard_option(int);
-int G_parser(int, char **);
-int G_usage(void);
-char *G_recreate_command(void);
-/* paths.c */
-int G_mkdir(const char *);
-int G_is_dirsep(char);
-int G_is_absolute_path(const char *);
-char *G_convert_dirseps_to_host(char *);
-char *G_convert_dirseps_from_host(char *);
-struct stat;
-int G_lstat(const char *, struct stat *);
-int G_stat(const char *, struct stat *);
-/* percent.c */
-int G_percent(long, long, int);
-int G_percent2(long, long, int, FILE *);
-int G_percent_reset(void);
-/* plot.c */
-int G_setup_plot(double, double, double, double, int (*)(int, int),
-		 int (*)(int, int));
-int G_setup_fill(int);
-int G_plot_where_xy(double, double, int *, int *);
-int G_plot_where_en(int, int, double *, double *);
-int G_plot_point(double, double);
-int G_plot_line(double, double, double, double);
-int G_plot_line2(double, double, double, double);
-int G_plot_polygon(const double *, const double *, int);
-int G_plot_area(double *const *, double *const *, int *, int);
-int G_plot_fx(double (*)(double), double, double);
-int G_plot_icon(double, double, int, double, double);
-/* pole_in_poly.c */
-int G_pole_in_polygon(const double *, const double *, int);
-/* popen.c */
-FILE *G_popen(const char *, const char *);
-int G_pclose(FILE *);
-/* progrm_nme.c */
-const char *G_program_name(void);
-int G_set_program_name(const char *);
-/* proj1.c */
-int G_projection(void);
-/* proj2.c */
-int G__projection_units(int);
-char *G__unit_name(int, int);
-char *G__projection_name(int);
-/* proj3.c */
-char *G_database_unit_name(int);
-char *G_database_projection_name(void);
-double G_database_units_to_meters_factor(void);
-char *G_database_datum_name(void);
-char *G_database_ellipse_name(void);
-/* put_cellhd.c */
-int G_put_cellhd(const char *, struct Cell_head *);
-/* put_row.c */
-int G_zeros_r_nulls(int);
-int G_put_map_row(int, const CELL *);
-int G_put_map_row_random(int, const CELL *, int, int, int);
-int G__put_null_value_row(int, const char *);
-int G_put_raster_row(int, const void *, RASTER_MAP_TYPE);
-int G_put_c_raster_row(int, const CELL *);
-int G_put_f_raster_row(int, const FCELL *);
-int G_put_d_raster_row(int, const DCELL *);
-int G__write_data(int, int, int);
-int G__write_data_compressed(int, int, int);
-int G__open_null_write(int);
-int G__write_null_bits(int, const unsigned char *, int, int, int);
-/* put_title.c */
-int G_put_cell_title(const char *, const char *);
-/* put_window.c */
-int G_put_window(const struct Cell_head *);
-int G__put_window(const struct Cell_head *, char *, char *);
-/* putenv.c */
-void G_putenv(const char *, const char *);
-/* quant.c */
-void G_quant_clear(struct Quant *);
-void G_quant_free(struct Quant *);
-int G__quant_organize_fp_lookup(struct Quant *);
-int G_quant_init(struct Quant *);
-int G_quant_is_truncate(const struct Quant *);
-int G_quant_is_round(const struct Quant *);
-int G_quant_truncate(struct Quant *);
-int G_quant_round(struct Quant *);
-int G_quant_get_limits(const struct Quant *, DCELL *, DCELL *, CELL *,
-		       CELL *);
-int G_quant_nof_rules(const struct Quant *);
-void G_quant_get_ith_rule(const struct Quant *, int, DCELL *, DCELL *, CELL *,
-			  CELL *);
-void G_quant_set_neg_infinite_rule(struct Quant *, DCELL, CELL);
-int G_quant_get_neg_infinite_rule(const struct Quant *, DCELL *, CELL *);
-void G_quant_set_pos_infinite_rule(struct Quant *, DCELL, CELL);
-int G_quant_get_pos_infinite_rule(const struct Quant *, DCELL *, CELL *);
-void G_quant_add_rule(struct Quant *, DCELL, DCELL, CELL, CELL);
-void G_quant_reverse_rule_order(struct Quant *);
-CELL G_quant_get_cell_value(struct Quant *, DCELL);
-void G_quant_perform_d(struct Quant *, const DCELL *, CELL *, int);
-void G_quant_perform_f(struct Quant *, const FCELL *, CELL *, int);
-struct Quant_table *G__quant_get_rule_for_d_raster_val(const struct Quant *,
-						       DCELL);
-/* quant_io.c */
-int G__quant_import(const char *, const char *, struct Quant *);
-int G__quant_export(const char *, const char *, const struct Quant *);
-/* quant_rw.c */
-int G_truncate_fp_map(const char *, const char *);
-int G_round_fp_map(const char *, const char *);
-int G_quantize_fp_map(const char *, const char *, CELL, CELL);
-int G_quantize_fp_map_range(const char *, const char *, DCELL, DCELL, CELL,
-			    CELL);
-int G_write_quant(const char *, const char *, const struct Quant *);
-int G_read_quant(const char *, const char *, struct Quant *);
-/* radii.c */
-double G_meridional_radius_of_curvature(double, double, double);
-double G_transverse_radius_of_curvature(double, double, double);
-double G_radius_of_conformal_tangent_sphere(double, double, double);
-/* range.c */
-int G__remove_fp_range(const char *);
-int G_construct_default_range(struct Range *);
-int G_read_fp_range(const char *, const char *, struct FPRange *);
-int G_read_range(const char *, const char *, struct Range *);
-int G_write_range(const char *, const struct Range *);
-int G_write_fp_range(const char *, const struct FPRange *);
-int G_update_range(CELL, struct Range *);
-int G_update_fp_range(DCELL, struct FPRange *);
-int G_row_update_range(const CELL *, int, struct Range *);
-int G__row_update_range(const CELL *, int, struct Range *, int);
-int G_row_update_fp_range(const void *, int, struct FPRange *,
-			  RASTER_MAP_TYPE);
-int G_init_range(struct Range *);
-int G_get_range_min_max(const struct Range *, CELL *, CELL *);
-int G_init_fp_range(struct FPRange *);
-int G_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
-/* raster.c */
-void *G_incr_void_ptr(const void *, int);
-int G_raster_cmp(const void *, const void *, RASTER_MAP_TYPE);
-int G_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
-int G_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
-int G_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
-int G_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
-CELL G_get_raster_value_c(const void *, RASTER_MAP_TYPE);
-FCELL G_get_raster_value_f(const void *, RASTER_MAP_TYPE);
-DCELL G_get_raster_value_d(const void *, RASTER_MAP_TYPE);
-/* raster_metadata.c */
-int G_read_raster_units(const char *, const char *, char *);
-int G_read_raster_vdatum(const char *, const char *, char *);
-int G_write_raster_units(const char *, const char *);
-int G_write_raster_vdatum(const char *, const char *);
-int G__raster_misc_read_line(const char *, const char *, const char *,
-			     char *);
-int G__raster_misc_write_line(const char *, const char *, const char *);
-/* rd_cellhd.c */
-char *G__read_Cell_head(FILE *, struct Cell_head *, int);
-char *G__read_Cell_head_array(char **, struct Cell_head *, int);
-/* reclass.c */
-int G_is_reclass(const char *, const char *, char *, char *);
-int G_is_reclassed_to(const char *, const char *, int *, char ***);
-int G_get_reclass(const char *, const char *, struct Reclass *);
-int G_free_reclass(struct Reclass *);
-int G_put_reclass(const char *, const struct Reclass *);
-/* remove.c */
-int G_remove(const char *, const char *);
-int G_remove_misc(const char *, const char *, const char *);
-/* rename.c */
-int G_rename(const char *, const char *, const char *);
-/* rhumbline.c */
-int G_begin_rhumbline_equation(double, double, double, double);
-double G_rhumbline_lat_from_lon(double);
-/* rotate.c */
-void G_rotate_around_point(double, double, double *, double *, double);
-void G_rotate_around_point_int(int, int, int *, int *, double);
-/* sample.c */
-double G_get_raster_sample(int, const struct Cell_head *, struct Categories *,
-			   double, double, int, INTERP_TYPE);
-/* set_window.c */
-int G_get_set_window(struct Cell_head *);
-int G_set_window(struct Cell_head *);
-/* short_way.c */
-int G_shortest_way(double *, double *);
-/* sleep.c */
-void G_sleep(unsigned int);
-/* snprintf.c */
-int G_snprintf(char *, size_t, const char *, ...);
-/* squeeze.c */
-char *G_squeeze(char *);
-/* store.c */
-char *G_store(const char *);
-/* strings.c */
-char *G_strcpy(char *, const char *);
-char *G_chrcpy(char *, const char *, int);
-char *G_strncpy(char *, const char *, int);
-char *G_strcat(char *, const char *);
-char *G_chrcat(char *, const char *, int);
-char *G_strmov(char *, const char *);
-char *G_chrmov(char *, const char *, int);
-int G_strcasecmp(const char *, const char *);
-char *G_strstr(const char *, const char *);
-char *G_strdup(const char *);
-char *G_strchg(char *, char, char);
-char *G_str_replace(char *, const char *, const char *);
-void G_str_to_upper(char *);
-void G_str_to_lower(char *);
-int G_str_to_sql(char *);
-int G_strip(char *);
-/* svd.c */
-int G_svdcmp(double **, int, int, double *, double **);
-int G_svbksb(double **, double[], double **, int, int, double[], double[]);
-int G_svelim(double *, int);
-/* system.c */
-int G_system(const char *);
-/* tempfile.c */
-char *G_tempfile(void);
-char *G__tempfile(int);
-int G__temp_element(char *);
-/* timestamp.c */
-void G_init_timestamp(struct TimeStamp *);
-void G_set_timestamp(struct TimeStamp *, const DateTime *);
-void G_set_timestamp_range(struct TimeStamp *, const DateTime *,
-			   const DateTime *);
-int G__read_timestamp(FILE *, struct TimeStamp *);
-int G__write_timestamp(FILE *, const struct TimeStamp *);
-int G_get_timestamps(const struct TimeStamp *, DateTime *, DateTime *, int *);
-int G_read_raster_timestamp(const char *, const char *, struct TimeStamp *);
-int G_read_vector_timestamp(const char *, const char *, struct TimeStamp *);
-int G_write_raster_timestamp(const char *, const struct TimeStamp *);
-int G_write_vector_timestamp(const char *, const struct TimeStamp *);
-int G_format_timestamp(const struct TimeStamp *, char *);
-int G_scan_timestamp(struct TimeStamp *, char *);
-int G_remove_raster_timestamp(const char *);
-int G_remove_vector_timestamp(const char *);
-int G_read_grid3_timestamp(const char *, const char *, struct TimeStamp *);
-int G_remove_grid3_timestamp(const char *);
-int G_write_grid3_timestamp(const char *, const struct TimeStamp *);
-/* token.c */
-char **G_tokenize(const char *, const char *);
-int G_number_of_tokens(char **);
-int G_free_tokens(char **);
-/* trim_dec.c */
-int G_trim_decimal(char *);
-/* unctrl.c */
-char *G_unctrl(int);
-/* unix_socks.c */
-char *G_sock_get_fname(const char *);
-int G_sock_exists(const char *);
-int G_sock_bind(const char *);
-int G_sock_listen(int, unsigned int);
-int G_sock_accept(int);
-int G_sock_connect(const char *);
-/* verbose.c */
-int G_verbose(void);
-int G_verbose_min(void);
-int G_verbose_std(void);
-int G_verbose_max(void);
-int G_set_verbose(int);
-/* view.c */
-int G_3dview_warning(int);
-int G_get_3dview_defaults(struct G_3dview *, struct Cell_head *);
-int G_put_3dview(const char *, const char *, const struct G_3dview *,
-		 const struct Cell_head *);
-int G_get_3dview(const char *, const char *, struct G_3dview *);
-/* whoami.c */
-char *G_whoami(void);
-/* wind_2_box.c */
-int G_adjust_window_to_box(const struct Cell_head *, struct Cell_head *, int,
-			   int);
-/* wind_format.c */
-int G_format_northing(double, char *, int);
-int G_format_easting(double, char *, int);
-int G_format_resolution(double, char *, int);
-/* wind_in.c */
-int G_point_in_region(double, double);
-int G_point_in_window(double, double, const struct Cell_head *);
-/* wind_limits.c */
-int G_limit_east(double *, int);
-int G_limit_west(double *, int);
-int G_limit_north(double *, int);
-int G_limit_south(double *, int);
-/* wind_overlap.c */
-int G_window_overlap(const struct Cell_head *, double, double, double,
-		     double);
-double G_window_percentage_overlap(const struct Cell_head *, double, double,
-				   double, double);
-/* wind_scan.c */
-int G_scan_northing(const char *, double *, int);
-int G_scan_easting(const char *, double *, int);
-int G_scan_resolution(const char *, double *, int);
-/* window_map.c */
-int G__create_window_mapping(int);
-double G_northing_to_row(double, const struct Cell_head *);
-double G_adjust_east_longitude(double, double);
-double G_adjust_easting(double, const struct Cell_head *);
-double G_easting_to_col(double, const struct Cell_head *);
-double G_row_to_northing(double, const struct Cell_head *);
-double G_col_to_easting(double, const struct Cell_head *);
-int G_window_rows(void);
-int G_window_cols(void);
-int G__init_window(void);
-int G_row_repeat_nomask(int, int);
-/* wr_cellhd.c */
-int G__write_Cell_head(FILE *, const struct Cell_head *, int);
-int G__write_Cell_head3(FILE *, const struct Cell_head *, int);
-/* writ_zeros.c */
-int G_write_zeros(int, size_t);
-/* yes.c */
-int G_yes(const char *, int);
-/* zero.c */
-int G_zero(void *, int);
-/* zero_cell.c */
-int G_zero_cell_buf(CELL *);
-int G_zero_raster_buf(void *, RASTER_MAP_TYPE);
-/* zone.c */
-int G_zone(void);
-#endif /* GRASS_GISDEFS_H */
