[GRASS-SVN] r33131 - in grass/trunk/raster: r.mfilter r.mfilter.fp
Wed Aug 27 17:56:35 EDT 2008
Author: glynn
Date: 2008-08-27 17:56:35 -0400 (Wed, 27 Aug 2008)
New Revision: 33131
Added:
   grass/trunk/raster/r.mfilter/Makefile
   grass/trunk/raster/r.mfilter/apply.c
   grass/trunk/raster/r.mfilter/execute.c
   grass/trunk/raster/r.mfilter/filter
   grass/trunk/raster/r.mfilter/filter.ave
   grass/trunk/raster/r.mfilter/filter.h
   grass/trunk/raster/r.mfilter/getfilt.c
   grass/trunk/raster/r.mfilter/getrow.c
   grass/trunk/raster/r.mfilter/glob.h
   grass/trunk/raster/r.mfilter/local_proto.h
   grass/trunk/raster/r.mfilter/main.c
   grass/trunk/raster/r.mfilter/perform.c
   grass/trunk/raster/r.mfilter/r.mfilter.html
   grass/trunk/raster/r.mfilter/uppercase.c
Removed:
   grass/trunk/raster/r.mfilter.fp/Makefile
   grass/trunk/raster/r.mfilter.fp/apply.c
   grass/trunk/raster/r.mfilter.fp/execute.c
   grass/trunk/raster/r.mfilter.fp/filter
   grass/trunk/raster/r.mfilter.fp/filter.ave
   grass/trunk/raster/r.mfilter.fp/filter.h
   grass/trunk/raster/r.mfilter.fp/getfilt.c
   grass/trunk/raster/r.mfilter.fp/getrow.c
   grass/trunk/raster/r.mfilter.fp/glob.h
   grass/trunk/raster/r.mfilter.fp/local_proto.h
   grass/trunk/raster/r.mfilter.fp/main.c
   grass/trunk/raster/r.mfilter.fp/perform.c
   grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html
   grass/trunk/raster/r.mfilter.fp/uppercase.c
   grass/trunk/raster/r.mfilter/TODO
Replace r.mfilter with r.mfilter.fp
Deleted: grass/trunk/raster/r.mfilter/Makefile
--- grass/trunk/raster/r.mfilter/Makefile	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/Makefile	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,10 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = r.mfilter
-LIBES = $(ROWIOLIB) $(GISLIB)
-DEPENDENCIES = $(ROWIODEP) $(GISDEP)
-include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
Copied: grass/trunk/raster/r.mfilter/Makefile (from rev 33119, grass/trunk/raster/r.mfilter.fp/Makefile)
--- grass/trunk/raster/r.mfilter/Makefile	                        (rev 0)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.mfilter
+LIBES = $(ROWIOLIB) $(GISLIB)
+DEPENDENCIES = $(ROWIODEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Deleted: grass/trunk/raster/r.mfilter/TODO
--- grass/trunk/raster/r.mfilter/TODO	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/TODO	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,5 +0,0 @@
-TODO:
-should accept FP filter rules
-6/2001
Deleted: grass/trunk/raster/r.mfilter/apply.c
--- grass/trunk/raster/r.mfilter/apply.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/apply.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,54 +0,0 @@
-#include "filter.h"
- * apply_filter: apply the filter to a single neighborhood
- *  filter:    filter to be applied
- *  input:     input buffers
-CELL apply_filter(FILTER * filter, CELL ** input)
-    int **matrix;
-    int size;
-    int divisor;
-    int round;
-    register int r, c;
-    register CELL v;
-    size = filter->size;
-    divisor = filter->divisor;
-    matrix = filter->matrix;
-    v = 0;
-    for (r = 0; r < size; r++)
-	for (c = 0; c < size; c++)
-	    v += input[r][c] * matrix[r][c];
-    /* zero divisor means compute a divisor. this is done by adding the
-       numbers is the divisor matrix where the corresponding cell value
-       is not zero.
-    if (divisor == 0) {
-	matrix = filter->dmatrix;
-		if (input[r][c])
-		    divisor += matrix[r][c];
-    /* now round the result to nearest integer. negative numbers are rounded
-       a little differently than non-negative numbers
-    if (divisor) {
-	if (round = divisor / 2) {
-	    if ((round > 0 && v > 0) || (round < 0 && v < 0))
-		v += round;
-	    else
-		v -= round;
-	v /= divisor;
-    else
-	v = 0;
-    return v;
Copied: grass/trunk/raster/r.mfilter/apply.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/apply.c)
--- grass/trunk/raster/r.mfilter/apply.c	                        (rev 0)
@@ -0,0 +1,50 @@
+#include "filter.h"
+ * apply_filter: apply the filter to a single neighborhood
+ *  filter:    filter to be applied
+ *  input:     input buffers
+DCELL apply_filter(FILTER * filter, DCELL ** input)
+    int size = filter->size;
+    double **matrix = filter->matrix;
+    double divisor = filter->divisor;
+    int r, c;
+    DCELL v;
+    v = 0;
+    if (divisor == 0) {
+	int have_result = 0;
+	for (r = 0; r < size; r++)
+	    for (c = 0; c < size; c++) {
+		if (G_is_d_null_value(&input[r][c]))
+		    continue;
+		v += input[r][c] * matrix[r][c];
+		divisor += filter->dmatrix[r][c];
+		have_result = 1;
+	if (have_result)
+	    v /= divisor;
+	else
+	    G_set_d_null_value(&v, 1);
+    else {
+		if (G_is_d_null_value(&input[r][c])) {
+		    return v;
+	v /= divisor;
+    return v;
Deleted: grass/trunk/raster/r.mfilter/execute.c
--- grass/trunk/raster/r.mfilter/execute.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/execute.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,121 +0,0 @@
-#include <unistd.h>
-#include <grass/rowio.h>
-#include "glob.h"
-int execute_filter(ROWIO * r, int out, FILTER * filter, CELL * cell)
-    int i;
-    int count;
-    int size;
-    int row, rcount;
-    int col, ccount;
-    int startx, starty;
-    int dx, dy;
-    int mid;
-    CELL **bufs, **box, *cp;
-    CELL apply_filter();
-    mid = size / 2;
-    bufs = (CELL **) G_malloc(size * sizeof(CELL *));
-    box = (CELL **) G_malloc(size * sizeof(CELL *));
-    switch (filter->start) {
-    case UR:
-	startx = ncols - size;
-	starty = 0;
-	dx = -1;
-	dy = 1;
-	break;
-    case LL:
-	startx = 0;
-	starty = nrows - size;
-	dx = 1;
-	dy = -1;
-	break;
-    case LR:
-	dx = -1;
-	dy = -1;
-	break;
-    case UL:
-    default:
-	startx = 0;
-	starty = 0;
-	dx = 1;
-	dy = 1;
-	break;
-    direction = dy;
-    G_debug(3, "direction %d, dx=%d, dy=%d", direction, dx, dy);
-    rcount = nrows - (size - 1);
-    ccount = ncols - (size - 1);
-    /* rewind output */
-    lseek(out, 0L, 0);
-    /* copy border rows to output */
-    row = starty;
-    for (i = 0; i < mid; i++) {
-	cp = (CELL *) rowio_get(r, row);
-	write(out, cp, buflen);
-	row += dy;
-    /* for each row */
-    for (count = 0; count < rcount; count++) {
-	G_percent(count, rcount, 2);
-	row = starty;
-	starty += dy;
-	/* get "size" rows */
-	for (i = 0; i < size; i++) {
-	    bufs[i] = (CELL *) rowio_get(r, row);
-	    box[i] = bufs[i] + startx;
-	    row += dy;
-	if (filter->type == SEQUENTIAL)
-	    cell = bufs[mid];
-	/* copy border */
-	cp = cell;
-	    *cp++ = bufs[mid][i];
-	/* filter row */
-	col = ccount;
-	while (col--) {
-	    if (zero_only) {
-		if (!box[mid][mid])
-		    *cp++ = apply_filter(filter, box);
-		else
-		    *cp++ = box[mid][mid];
-	    else {
-		box[i] += dx;
-	/* copy border */
-	for (i = ncols - mid; i < ncols; i++)
-	/* write row */
-	write(out, cell, buflen);
-    row = starty + mid * dy;
-	row += dy;
-    return 0;
Copied: grass/trunk/raster/r.mfilter/execute.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/execute.c)
--- grass/trunk/raster/r.mfilter/execute.c	                        (rev 0)
@@ -0,0 +1,120 @@
+#include <unistd.h>
+#include <grass/rowio.h>
+#include "glob.h"
+int execute_filter(ROWIO * r, int out, FILTER * filter, DCELL * cell)
+    int i;
+    int count;
+    int size;
+    int row, rcount;
+    int col, ccount;
+    int startx, starty;
+    int dx, dy;
+    int mid;
+    DCELL **bufs, **box, *cp;
+    size = filter->size;
+    mid = size / 2;
+    bufs = (DCELL **) G_malloc(size * sizeof(DCELL *));
+    box = (DCELL **) G_malloc(size * sizeof(DCELL *));
+    switch (filter->start) {
+    case UR:
+	startx = ncols - size;
+	starty = 0;
+	dx = -1;
+	dy = 1;
+	break;
+    case LL:
+	startx = 0;
+	starty = nrows - size;
+	dx = 1;
+	dy = -1;
+	break;
+    case LR:
+	dx = -1;
+	dy = -1;
+	break;
+    case UL:
+    default:
+	startx = 0;
+	starty = 0;
+	dx = 1;
+	dy = 1;
+	break;
+    direction = dy;
+    G_debug(3, "direction %d, dx=%d, dy=%d", direction, dx, dy);
+    rcount = nrows - (size - 1);
+    ccount = ncols - (size - 1);
+    /* rewind output */
+    lseek(out, 0L, 0);
+    /* copy border rows to output */
+    row = starty;
+    for (i = 0; i < mid; i++) {
+	cp = (DCELL *) rowio_get(r, row);
+	write(out, cp, buflen);
+	row += dy;
+    /* for each row */
+    for (count = 0; count < rcount; count++) {
+	G_percent(count, rcount, 2);
+	row = starty;
+	starty += dy;
+	/* get "size" rows */
+	for (i = 0; i < size; i++) {
+	    bufs[i] = (DCELL *) rowio_get(r, row);
+	    box[i] = bufs[i] + startx;
+	    row += dy;
+	if (filter->type == SEQUENTIAL)
+	    cell = bufs[mid];
+	/* copy border */
+	cp = cell;
+	    *cp++ = bufs[mid][i];
+	/* filter row */
+	col = ccount;
+	while (col--) {
+	    if (null_only) {
+		if (G_is_d_null_value(&box[mid][mid]))
+		    *cp++ = apply_filter(filter, box);
+		else
+		    *cp++ = box[mid][mid];
+	    else {
+		box[i] += dx;
+	/* copy border */
+	for (i = ncols - mid; i < ncols; i++)
+	/* write row */
+	write(out, cell, buflen);
+    row = starty + mid * dy;
+	row += dy;
+    return 0;
Deleted: grass/trunk/raster/r.mfilter/filter
--- grass/trunk/raster/r.mfilter/filter	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/filter	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,9 +0,0 @@
-MATRIX 5
-1 1 1 1 1
-1 1 1 1 1
-1 1 1 1 1
-1 1 1 1 1
-1 1 1 1 1
-DIVISOR  0
-TYPE     P
Copied: grass/trunk/raster/r.mfilter/filter (from rev 33119, grass/trunk/raster/r.mfilter.fp/filter)
--- grass/trunk/raster/r.mfilter/filter	                        (rev 0)
@@ -0,0 +1,9 @@
+MATRIX 5
+1 1 1 1 1
+1 1 1 1 1
+1 1 1 1 1
+1 1 1 1 1
+1 1 1 1 1
+DIVISOR  0
+TYPE     P
Deleted: grass/trunk/raster/r.mfilter/filter.ave
--- grass/trunk/raster/r.mfilter/filter.ave	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/filter.ave	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,6 +0,0 @@
-MATRIX 3
-1 1 1
-1 1 1
-1 1 1
-DIVISOR 9
-START LR
Copied: grass/trunk/raster/r.mfilter/filter.ave (from rev 33119, grass/trunk/raster/r.mfilter.fp/filter.ave)
--- grass/trunk/raster/r.mfilter/filter.ave	                        (rev 0)
@@ -0,0 +1,6 @@
+MATRIX 3
+1 1 1
+1 1 1
+1 1 1
+DIVISOR 9
+START LR
Deleted: grass/trunk/raster/r.mfilter/filter.h
--- grass/trunk/raster/r.mfilter/filter.h	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/filter.h	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,31 +0,0 @@
-#include <grass/gis.h>
-typedef struct
-    int size;			/* size of filter matrix */
-    int **matrix;		/* filter coefficient matrix */
-    int **dmatrix;		/* divisor coefficient matrix */
-    int divisor;		/* filter scale factor */
-    int type;			/* sequential or parallel */
-    int start;			/* starting corner */
-} FILTER;
-#define PARALLEL 1
-#define SEQUENTIAL 2
-#define UL 1
-#define UR 2
-#define LL 3
-#define LR 4
-/* apply.c */
-CELL apply_filter(FILTER *, CELL **);
-/* getfilt.c */
-FILTER *get_filter(char *, int *, char *);
-/* perform.c */
-int perform_filter(char *, char *, char *, FILTER *, int, int);
-#ifdef GRASS_ROWIO_H
-/* execute.c */
-int execute_filter(ROWIO *, int, FILTER *, CELL *);
-#endif
Copied: grass/trunk/raster/r.mfilter/filter.h (from rev 33119, grass/trunk/raster/r.mfilter.fp/filter.h)
--- grass/trunk/raster/r.mfilter/filter.h	                        (rev 0)
@@ -0,0 +1,30 @@
+#include <grass/gis.h>
+typedef struct
+    int size;			/* size of filter matrix */
+    double **matrix;		/* filter coefficient matrix */
+    double **dmatrix;		/* divisor coefficient matrix */
+    double divisor;		/* filter scale factor */
+    int type;			/* sequential or parallel */
+    int start;			/* starting corner */
+} FILTER;
+#define PARALLEL 1
+#define SEQUENTIAL 2
+#define UL 1
+#define UR 2
+#define LL 3
+#define LR 4
+/* apply.c */
+DCELL apply_filter(FILTER *, DCELL **);
+/* getfilt.c */
+FILTER *get_filter(char *, int *, char *);
+/* perform.c */
+int perform_filter(const char *, const char *, FILTER *, int, int);
+/* execute.c */
+int execute_filter(ROWIO *, int, FILTER *, DCELL *);
Deleted: grass/trunk/raster/r.mfilter/getfilt.c
--- grass/trunk/raster/r.mfilter/getfilt.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/getfilt.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,160 +0,0 @@
-#include <string.h>
-#include <grass/glocale.h>
-#include "local_proto.h"
-FILTER *get_filter(char *name, int *nfilters, char *title)
-    FILE *fd;
-    FILTER *filter, *f;
-    char buf[300];
-    char temp[100];
-    char label[50];
-    int row, col;
-    int n;
-    int have_divisor;
-    int have_type;
-    int have_start;
-    int count;
-    f = filter = 0;
-    count = *nfilters = 0;
-    *title = 0;
-    fd = fopen(name, "r");
-    if (!fd) {
-	G_fatal_error(_("Cannot open filter file '%s'"), name);
-    while (fgets(buf, sizeof buf, fd)) {
-	G_strip(buf);
-	if (*buf == '#' || *buf == 0)
-	    continue;
-	if (sscanf(buf, "%s %[^\n]", label, temp) == 2) {
-	    uppercase(label);
-	    if (strcmp(label, "TITLE") == 0) {
-		G_strip(temp);
-		strcpy(title, temp);
-		continue;
-	uppercase(buf);
-	if (sscanf(buf, "MATRIX %d", &n) == 1) {
-	    if (n < 3) {
-		G_fatal_error(_("Illegal filter matrix size specified"));
-	    if (n % 2 == 0) {
-		G_fatal_error(_("Even filter matrix size specified"));
-	    count++;
-	    filter = (FILTER *) G_realloc(filter, count * sizeof(FILTER));
-	    f = &filter[count - 1];
-	    f->size = n;
-	    f->divisor = 1;
-	    f->dmatrix = NULL;
-	    f->type = PARALLEL;
-	    f->start = UL;
-	    have_divisor = 0;
-	    have_type = 0;
-	    have_start = 0;
-	    f->matrix = (int **)G_malloc(n * sizeof(int *));
-	    for (row = 0; row < n; row++)
-		f->matrix[row] = (int *)G_malloc(n * sizeof(int));
-		for (col = 0; col < n; col++)
-		    if (fscanf(fd, "%d", &f->matrix[row][col]) != 1) {
-			G_fatal_error(_("Illegal filter matrix"));
-	    continue;
-	if (sscanf(buf, "DIVISOR %d", &n) == 1)
-	    if (sscanf(buf, "%s", label) == 1 &&
-		strcmp(label, "DIVISOR") == 0) {
-		if (!filter) {
-		    G_fatal_error(_("Filter file format error"));
-		if (have_divisor) {
-		    G_fatal_error(_("Duplicate filter divisor specified"));
-		have_divisor = 1;
-		if (sscanf(buf, "DIVISOR %d", &n) == 1) {
-		    f->divisor = n;
-		    if (n == 0)
-			f->dmatrix = f->matrix;
-		    continue;
-		f->divisor = 0;
-		f->dmatrix = (int **)G_malloc(f->size * sizeof(int *));
-		for (row = 0; row < f->size; row++)
-		    f->dmatrix[row] = (int *)G_malloc(f->size * sizeof(int));
-		    for (col = 0; col < f->size; col++)
-			if (fscanf(fd, "%d", &f->dmatrix[row][col]) != 1) {
-			    G_fatal_error(_("Illegal divisor matrix"));
-		continue;
-	if (sscanf(buf, "TYPE %s", temp) == 1) {
-	    if (!filter) {
-	    if (have_type) {
-		G_fatal_error(_("Duplicate filter type specified"));
-	    if (strcmp(temp, "P") == 0)
-	    else if (strcmp(temp, "S") == 0)
-		f->type = SEQUENTIAL;
-	    else {
-		G_fatal_error(_("Illegal filter type specified"));
-	    have_type = 1;
-	    continue;
-	if (sscanf(buf, "START %s", temp) == 1) {
-	    if (!filter) {
-	    if (have_start) {
-		G_fatal_error(_("Duplicate filter start specified"));
-	    if (strcmp(temp, "UL") == 0)
-		f->start = UL;
-	    /* disable any other starting corner until the rest of
-	     * this program handles them properly
-	    else
-		G_warning(_("Filter start %s ignored, using UL"), temp);
-	    /* disable these others
-	       else if (strcmp (temp, "UR") == 0)
-	       f->start  = UR ;
-	       else if (strcmp (temp, "LL") == 0)
-	       f->start  = LL ;
-	       else if (strcmp (temp, "LR") == 0)
-	       f->start  = LR ;
-	       else
-	       ERROR ("illegal filter type specified");
-	    have_start = 1;
-	    continue;
-	/* other lines are ignored */
-    if (!filter) {
-	G_fatal_error(_("Illegal filter file format"));
-    *nfilters = count;
-    return filter;
Copied: grass/trunk/raster/r.mfilter/getfilt.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/getfilt.c)
--- grass/trunk/raster/r.mfilter/getfilt.c	                        (rev 0)
@@ -0,0 +1,162 @@
+#include <string.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+FILTER *get_filter(char *name, int *nfilters, char *title)
+    FILE *fd;
+    FILTER *filter, *f;
+    char buf[300];
+    char temp[100];
+    char label[50];
+    int row, col;
+    int n;
+    int have_divisor;
+    int have_type;
+    int have_start;
+    int count;
+    double div;
+    f = filter = 0;
+    count = *nfilters = 0;
+    *title = 0;
+    fd = fopen(name, "r");
+    if (!fd) {
+	G_fatal_error(_("Cannot open filter file '%s'"), name);
+    while (fgets(buf, sizeof buf, fd)) {
+	G_strip(buf);
+	if (*buf == '#' || *buf == 0)
+	    continue;
+	if (sscanf(buf, "%s %[^\n]", label, temp) == 2) {
+	    uppercase(label);
+	    if (strcmp(label, "TITLE") == 0) {
+		G_strip(temp);
+		strcpy(title, temp);
+		continue;
+	uppercase(buf);
+	if (sscanf(buf, "MATRIX %d", &n) == 1) {
+	    if (n < 3) {
+		G_fatal_error(_("Illegal filter matrix size specified"));
+	    if (n % 2 == 0) {
+		G_fatal_error(_("Even filter matrix size specified"));
+	    count++;
+	    filter = (FILTER *) G_realloc(filter, count * sizeof(FILTER));
+	    f = &filter[count - 1];
+	    f->size = n;
+	    f->divisor = 1;
+	    f->dmatrix = NULL;
+	    f->type = PARALLEL;
+	    f->start = UL;
+	    have_divisor = 0;
+	    have_type = 0;
+	    have_start = 0;
+	    f->matrix = (DCELL **) G_malloc(n * sizeof(DCELL *));
+	    for (row = 0; row < n; row++)
+		f->matrix[row] = (DCELL *) G_malloc(n * sizeof(DCELL));
+		for (col = 0; col < n; col++)
+		    if (fscanf(fd, "%lf", &f->matrix[row][col]) != 1) {
+			G_fatal_error(_("Illegal filter matrix"));
+	    continue;
+	if (sscanf(buf, "DIVISOR %lf", &div) == 1)
+	    if (sscanf(buf, "%s", label) == 1 &&
+		strcmp(label, "DIVISOR") == 0) {
+		if (!filter) {
+		    G_fatal_error(_("Filter file format error"));
+		if (have_divisor) {
+		    G_fatal_error(_("Duplicate filter divisor specified"));
+		have_divisor = 1;
+		if (sscanf(buf, "DIVISOR %lf", &div) == 1) {
+		    f->divisor = div;
+		    if (n == 0)
+			f->dmatrix = f->matrix;
+		    continue;
+		f->divisor = 0;
+		f->dmatrix = (DCELL **) G_malloc(f->size * sizeof(DCELL *));
+		for (row = 0; row < f->size; row++)
+		    f->dmatrix[row] =
+			(DCELL *) G_malloc(f->size * sizeof(DCELL));
+		    for (col = 0; col < f->size; col++)
+			if (fscanf(fd, "%lf", &f->dmatrix[row][col]) != 1) {
+			    G_fatal_error(_("Illegal divisor matrix"));
+		continue;
+	if (sscanf(buf, "TYPE %s", temp) == 1) {
+	    if (!filter) {
+	    if (have_type) {
+		G_fatal_error(_("Duplicate filter type specified"));
+	    if (strcmp(temp, "P") == 0)
+	    else if (strcmp(temp, "S") == 0)
+		f->type = SEQUENTIAL;
+	    else {
+		G_fatal_error(_("Illegal filter type specified"));
+	    have_type = 1;
+	    continue;
+	if (sscanf(buf, "START %s", temp) == 1) {
+	    if (!filter) {
+	    if (have_start) {
+		G_fatal_error(_("Duplicate filter start specified"));
+	    if (strcmp(temp, "UL") == 0)
+		f->start = UL;
+	    /* disable any other starting corner until the rest of
+	     * this program handles them properly
+	    else
+		G_warning(_("Filter start %s ignored, using UL"), temp);
+	    /* disable these others
+	       else if (strcmp (temp, "UR") == 0)
+	       f->start  = UR ;
+	       else if (strcmp (temp, "LL") == 0)
+	       f->start  = LL ;
+	       else if (strcmp (temp, "LR") == 0)
+	       f->start  = LR ;
+	       else
+	       ERROR ("illegal filter type specified");
+	    have_start = 1;
+	    continue;
+	/* other lines are ignored */
+    if (!filter) {
+	G_fatal_error(_("Illegal filter file format"));
+    *nfilters = count;
+    return filter;
Deleted: grass/trunk/raster/r.mfilter/getrow.c
--- grass/trunk/raster/r.mfilter/getrow.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/getrow.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,25 +0,0 @@
-#include <stdlib.h>
-#include <sys/types.h>
-#include "glob.h"
-int getmaprow(int fd, void *buf, int row, int len)
-    if (G_get_map_row(fd, (CELL *) buf, row) < 0)
-	G_fatal_error(_("Cannot read raster row %d"), row);
-    return 1;
-int getrow(int fd, void *buf, int row, int len)
-    if (direction > 0)
-	lseek(fd, (off_t) row * len, 0);
-    else
-	lseek(fd, (off_t) (nrows - row - 1) * len, 0);
-    if (read(fd, (CELL *) buf, len) != len)
-	G_fatal_error(_("Error reading temporary file"));
-    return 1;
Copied: grass/trunk/raster/r.mfilter/getrow.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/getrow.c)
--- grass/trunk/raster/r.mfilter/getrow.c	                        (rev 0)
@@ -0,0 +1,25 @@
+#include <stdlib.h>
+#include <sys/types.h>
+#include "glob.h"
+int getmaprow(int fd, void *buf, int row, int len)
+    if (G_get_d_raster_row(fd, (DCELL *) buf, row) < 0)
+	G_fatal_error(_("Cannot read raster row %d"), row);
+    return 1;
+int getrow(int fd, void *buf, int row, int len)
+    if (direction > 0)
+	lseek(fd, (off_t) row * len, 0);
+    else
+	lseek(fd, (off_t) (nrows - row - 1) * len, 0);
+    if (read(fd, (DCELL *) buf, len) != len)
+	G_fatal_error(_("Error reading temporary file"));
+    return 1;
Deleted: grass/trunk/raster/r.mfilter/glob.h
--- grass/trunk/raster/r.mfilter/glob.h	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/glob.h	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,5 +0,0 @@
-extern int nrows, ncols;
-extern int buflen;
-extern int direction;
-extern int zero_only;
-extern int preserve_edges;
Copied: grass/trunk/raster/r.mfilter/glob.h (from rev 33119, grass/trunk/raster/r.mfilter.fp/glob.h)
--- grass/trunk/raster/r.mfilter/glob.h	                        (rev 0)
@@ -0,0 +1,6 @@
+extern int nrows, ncols;
+extern int buflen;
+extern int direction;
+extern int null_only;
+extern int preserve_edges;
Deleted: grass/trunk/raster/r.mfilter/local_proto.h
--- grass/trunk/raster/r.mfilter/local_proto.h	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/local_proto.h	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,6 +0,0 @@
-/* getrow.c */
-int getmaprow(int, void *, int, int);
-int getrow(int, void *, int, int);
-/* uppercase.c */
-int uppercase(char *);
Copied: grass/trunk/raster/r.mfilter/local_proto.h (from rev 33119, grass/trunk/raster/r.mfilter.fp/local_proto.h)
--- grass/trunk/raster/r.mfilter/local_proto.h	                        (rev 0)
@@ -0,0 +1,6 @@
+/* getrow.c */
+int getmaprow(int, void *, int, int);
+int getrow(int, void *, int, int);
+/* uppercase.c */
+int uppercase(char *);
Deleted: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/main.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,140 +0,0 @@
- * MODULE:       r.mfilter
- * AUTHOR(S):    Michael Shapiro, CERL (original contributor)
- *               Roberto Flor <flor itc.it>, Markus Neteler <neteler itc.it>
- *               Glynn Clements <glynn gclements.plus.com>, Jachym Cepicky <jachym les-ejk.cz>,
- *               Jan-Oliver Wagner <jan intevation.de>
- * PURPOSE:
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-#include <stdio.h>
-#include "glob.h"
-int nrows, ncols;
-int buflen;
-int direction;
-int zero_only;
-int preserve_edges;
-int main(int argc, char *argv[])
-    FILTER *filter;
-    int nfilters;
-    int repeat;
-    char *in_name, *in_mapset;
-    char *filt_name;
-    char *out_name;
-    char title[1024];
-    char temp[300];
-    int i;
-    struct GModule *module;
-    struct Flag *flag2;
-    struct Option *opt1;
-    struct Option *opt2;
-    struct Option *opt3;
-    struct Option *opt4;
-    struct Option *opt5;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    module->keywords = _("raster, map algebra");
-    module->description = _("Raster map matrix filter.");
-    /* Define the different options */
-    opt1 = G_define_standard_option(G_OPT_R_INPUT);
-    opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt3 = G_define_standard_option(G_OPT_F_INPUT);
-    opt3->key = "filter";
-    opt3->required = YES;
-    opt3->description = _("Name of filter file");
-    opt4 = G_define_option();
-    opt4->key = "repeat";
-    opt4->type = TYPE_INTEGER;
-    opt4->multiple = NO;
-    opt4->required = NO;
-    opt4->answer = "1";
-    opt4->description = _("Number of times to repeat the filter");
-    opt5 = G_define_option();
-    opt5->key = "title";
-    opt5->type = TYPE_STRING;
-    opt5->required = NO;
-    opt5->description = _("Output raster map title");
-    /* Define the different flags */
-    /* this isn't implemented at all
-       flag3 = G_define_flag() ;
-       flag3->key         = 'p' ;
-       flag3->description = _("Preserved edge") ;
-    flag2 = G_define_flag();
-    flag2->key = 'z';
-    flag2->description = _("Apply filter only to zero data values");
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-       preserve_edges = flag3->answer;
-    zero_only = flag2->answer;
-    sscanf(opt4->answer, "%d", &repeat);
-    out_name = opt2->answer;
-    filt_name = opt3->answer;
-    in_name = opt1->answer;
-    in_mapset = G_find_cell2(in_name, "");
-    if (in_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), in_name);
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    buflen = ncols * sizeof(CELL);
-    /* get the filter */
-    filter = get_filter(filt_name, &nfilters, temp);
-    /* make sure filter matrix won't extend outside the raster map */
-    for (i = 0; i < nfilters; i++) {
-	if (filter[i].size > ncols || filter[i].size > nrows)
-	    G_fatal_error(_("Raster map too small for the size of the filter"));
-    /* make a title for result */
-    if (opt5->answer)
-	strcpy(title, opt5->answer);
-    else {
-	if (*temp == 0)
-	    strcpy(temp, "unknown filter");
-	sprintf(title, "%s filtered using %s", in_name, temp);
-    perform_filter(in_name, in_mapset, out_name, filter, nfilters, repeat);
-    G_put_cell_title(out_name, title);
-    exit(EXIT_SUCCESS);
Copied: grass/trunk/raster/r.mfilter/main.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/main.c)
--- grass/trunk/raster/r.mfilter/main.c	                        (rev 0)
@@ -0,0 +1,137 @@
+ * MODULE:       r.mfilter
+ * AUTHOR(S):    Michael Shapiro, CERL (original contributor)
+ *               Roberto Flor <flor itc.it>, Markus Neteler <neteler itc.it>
+ *               Glynn Clements <glynn gclements.plus.com>, Jachym Cepicky <jachym les-ejk.cz>,
+ *               Jan-Oliver Wagner <jan intevation.de>
+ * PURPOSE:
+ * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include "glob.h"
+int nrows, ncols;
+int buflen;
+int direction;
+int null_only;
+int preserve_edges;
+int main(int argc, char **argv)
+    FILTER *filter;
+    int nfilters;
+    int repeat;
+    char *in_name;
+    char *filt_name;
+    char *out_name;
+    char title[1024];
+    char temp[300];
+    int i;
+    struct GModule *module;
+    struct Flag *flag2;
+    struct Option *opt1;
+    struct Option *opt2;
+    struct Option *opt3;
+    struct Option *opt4;
+    struct Option *opt5;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("raster, map algebra");
+    module->description = _("Raster map matrix filter.");
+    /* Define the different options */
+    opt1 = G_define_standard_option(G_OPT_R_INPUT);
+    opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt3 = G_define_standard_option(G_OPT_F_INPUT);
+    opt3->key = "filter";
+    opt3->required = YES;
+    opt3->description = _("Name of filter file");
+    opt4 = G_define_option();
+    opt4->key = "repeat";
+    opt4->type = TYPE_INTEGER;
+    opt4->multiple = NO;
+    opt4->required = NO;
+    opt4->answer = "1";
+    opt4->description = _("Number of times to repeat the filter");
+    opt5 = G_define_option();
+    opt5->key = "title";
+    opt5->type = TYPE_STRING;
+    opt5->required = NO;
+    opt5->description = _("Output raster map title");
+    /* Define the different flags */
+    /* this isn't implemented at all
+       flag3 = G_define_flag() ;
+       flag3->key         = 'p' ;
+       flag3->description = _("Preserved edge") ;
+    flag2 = G_define_flag();
+    flag2->key = 'z';
+    flag2->description = _("Apply filter only to null data values");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+       preserve_edges = flag3->answer;
+    null_only = flag2->answer;
+    sscanf(opt4->answer, "%d", &repeat);
+    out_name = opt2->answer;
+    filt_name = opt3->answer;
+    in_name = opt1->answer;
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    buflen = ncols * sizeof(DCELL);
+    /* get the filter */
+    filter = get_filter(filt_name, &nfilters, temp);
+    /* make sure filter matrix won't extend outside the raster map */
+    for (i = 0; i < nfilters; i++) {
+	if (filter[i].size > ncols || filter[i].size > nrows)
+	    G_fatal_error(_("Raster map too small for the size of the filter"));
+    /* make a title for result */
+    if (opt5->answer)
+	strcpy(title, opt5->answer);
+    else {
+	if (*temp == 0)
+	    strcpy(temp, "unknown filter");
+	sprintf(title, "%s filtered using %s", in_name, temp);
+    perform_filter(in_name, out_name, filter, nfilters, repeat);
+    G_put_cell_title(out_name, title);
+    exit(EXIT_SUCCESS);
Deleted: grass/trunk/raster/r.mfilter/perform.c
--- grass/trunk/raster/r.mfilter/perform.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/perform.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,103 +0,0 @@
-#include <fcntl.h>
-#include "glob.h"
-int perform_filter(char *in_name, char *in_mapset, char *out_name,
-		   FILTER * filter, int nfilters, int repeat)
-    int in;
-    int out;
-    int n;
-    int pass;
-    ROWIO r;
-    char *tmp1, *tmp2;
-    int count;
-    int row;
-    CELL *cell;
-    cell = G_allocate_cell_buf();
-    count = 0;
-    for (pass = 0; pass < repeat; pass++) {
-	G_debug(1, "Pass %d", pass + 1);
-	for (n = 0; n < nfilters; n++, count++) {
-	    G_debug(1, "Filter %d", n + 1);
-	    if (count == 0) {
-		in = G_open_cell_old(in_name, in_mapset);
-		G_debug(1, "Open raster map %s in %s = %d", in_name,
-			in_mapset, in);
-		if (in < 0) {
-		    G_fatal_error(_("Cannot open raster map <%s>"), in_name);
-		close(creat(tmp1 = G_tempfile(), 0666));
-		out = open(tmp1, 2);
-		if (out < 0)
-		    G_fatal_error(_("Unable to create temporary file"));
-	    else if (count == 1) {
-		G_debug(1, "Closing raster map");
-		G_close_cell(in);
-		in = out;
-		close(creat(tmp2 = G_tempfile(), 0666));
-		out = open(tmp2, 2);
-		if (out < 0)
-	    else {
-		int fd;
-		G_debug(1, "Swap temp files");
-		fd = in;
-		in = out;
-		out = fd;
-	    rowio_setup(&r, in, filter[n].size, buflen,
-			count ? getrow : getmaprow, NULL);
-	    execute_filter(&r, out, &filter[n], cell);
-	    rowio_release(&r);
-    if (count == 1)
-	G_close_cell(in);
-    else if (count > 1)
-	close(in);
-    /* copy final result to output raster map */
-    in = out;
-    out = G_open_cell_new(out_name);
-    if (out < 0) {
-	G_fatal_error(_("Cannot create raster map <%s>"), out_name);
-    G_message(_("Writing raster map <%s>"), out_name);
-    for (row = 0; row < nrows; row++) {
-	getrow(in, cell, row, buflen);
-	G_put_raster_row(out, cell, CELL_TYPE);
-    /* remove the temporary files before closing so that the G_close_cell()
-       has more disk to work with
-    if (count > 0)
-	unlink(tmp1);
-    if (count > 1)
-	unlink(tmp2);
-    G_close_cell(out);
-    return 0;
Copied: grass/trunk/raster/r.mfilter/perform.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/perform.c)
--- grass/trunk/raster/r.mfilter/perform.c	                        (rev 0)
@@ -0,0 +1,102 @@
+#include <fcntl.h>
+#include "glob.h"
+int perform_filter(const char *in_name, const char *out_name,
+		   FILTER * filter, int nfilters, int repeat)
+    int in;
+    int out;
+    int n;
+    int pass;
+    ROWIO r;
+    char *tmp1, *tmp2;
+    int count;
+    int row;
+    DCELL *cell;
+    cell = G_allocate_d_raster_buf();
+    count = 0;
+    for (pass = 0; pass < repeat; pass++) {
+	G_debug(1, "Pass %d", pass + 1);
+	for (n = 0; n < nfilters; n++, count++) {
+	    G_debug(1, "Filter %d", n + 1);
+	    if (count == 0) {
+		in = G_open_cell_old(in_name, "");
+		G_debug(1, "Open raster map %s = %d", in_name, in);
+		if (in < 0) {
+		    G_fatal_error(_("Cannot open raster map <%s>"), in_name);
+		close(creat(tmp1 = G_tempfile(), 0666));
+		out = open(tmp1, 2);
+		if (out < 0)
+		    G_fatal_error(_("Unable to create temporary file"));
+	    else if (count == 1) {
+		G_debug(1, "Closing raster map");
+		G_close_cell(in);
+		in = out;
+		close(creat(tmp2 = G_tempfile(), 0666));
+		out = open(tmp2, 2);
+		if (out < 0)
+	    else {
+		int fd;
+		G_debug(1, "Swap temp files");
+		fd = in;
+		in = out;
+		out = fd;
+	    rowio_setup(&r, in, filter[n].size, buflen,
+			count ? getrow : getmaprow, NULL);
+	    execute_filter(&r, out, &filter[n], cell);
+	    rowio_release(&r);
+    if (count == 1)
+	G_close_cell(in);
+    else if (count > 1)
+	close(in);
+    /* copy final result to output raster map */
+    in = out;
+    out = G_open_fp_cell_new(out_name);
+    if (out < 0) {
+	G_fatal_error(_("Cannot create raster map <%s>"), out_name);
+    G_message(_("Writing raster map <%s>"), out_name);
+    for (row = 0; row < nrows; row++) {
+	getrow(in, cell, row, buflen);
+	G_put_d_raster_row(out, cell);
+    /* remove the temporary files before closing so that the G_close_cell()
+       has more disk to work with
+    if (count > 0)
+	unlink(tmp1);
+    if (count > 1)
+	unlink(tmp2);
+    G_close_cell(out);
+    return 0;
Deleted: grass/trunk/raster/r.mfilter/r.mfilter.html
--- grass/trunk/raster/r.mfilter/r.mfilter.html	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/r.mfilter.html	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,156 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.mfilter</em> filters the raster <em>input</em> to produce the
-raster <em>output</em> according to the matrix <em>filter</em> designed
-by the user (see <em>FILTERS</em> below).
-The filter is applied <em>repeat</em> times (default <em>value</em> is 1).
-The <em>output</em> raster map layer can be given a <em>TITLE</em> if desired.
-(This TITLE should be put in quotes if it contains more than one word.)
-With <b>-z</b> flag the filter is applied only to zero category values in
-the input raster map layer.  The non-zero category values are not changed.
-Note that if there is more than one filter step, this rule is applied to the
-intermediate raster map layer -- only zero category values which result from
-the first filter will be changed.  In most cases this will NOT be the
-desired result. Hence -z should be used only with single step filters.
-<p>
-The <b>filter</b> parameter defines the name of an existing, user-created
-UNIX ASCII file whose contents is a matrix defining the way in which the
-<em>input</em> file will be filtered. The format of this file is described
-below, under FILTERS.
-<p>
-The <b>repeat</b> parameter defines the number of times the <em>filter</em>
-is to be applied to the <em>input</em> data.
-<h2>FILTERS</h2>
-The <em>filter</em> file is a normal UNIX ASCII file designed by the user.
-It has the following format:
-<pre>
-     TITLE      TITLE
-     MATRIX     n
-     n lines of n integers
-     DIVISOR    d
-     TYPE        S/P
-</pre>
-<dl>
-<dt>TITLE
-<dd>A one-line TITLE for the filter.
-If a TITLE was not specified on the command line, it can be specified here.
-This TITLE would be used to construct a TITLE for the resulting raster map
-layer.  It should be a one-line description of the filter.
-<dt>MATRIX
-<dd>The matrix (n x n) follows on the next n lines.  <em>n</em> must be
-an odd integer greater than or equal to 3.
-The matrix itself consists of n rows of n integers.
-The integers must be separated from each other by at least 1 blank.
-<dt>DIVISOR
-<dd>The filter divisor is <em>d</em>.  If not specified, the default is 1.
-If the divisor is zero (0), then the divisor is dependent on the
-category values in the neighborhood
-(see HOW THE FILTER WORKS below).
-<dt>TYPE
-<dd>The filter type.  <em>S</em> means sequential, while <em>P</em> mean parallel.
-If not specified, the default is S.
-<p>
-Sequential filtering happens in place.  As the filter is applied to the
-raster map layer, the category values that were changed in neighboring
-cells affect the resulting category value of the current
-cell being filtered.
-<p>
-Parallel filtering happens in such a way that the original raster
-map layer category values are used to produce the new category value.
-<p>
-More than one filter may be specified in the filter file.
-The additional filter(s) are described just like the first.
-For example, the following describes two filters:
-</p>
-</dl>
-<h2>EXAMPLE FILTER FILE</h2>
-<pre>
-      TITLE     3x3 average, non-zero data only, followed by 5x5 average
-     MATRIX    3
-     1 1 1
-     1 1 1
-     1 1 1
-     DIVISOR   0
-     TYPE      P
-     MATRIX    5
-     1 1 1 1 1
-     1 1 1 1 1
-     1 1 1 1 1
-     1 1 1 1 1
-     1 1 1 1 1
-     DIVISOR   25
-     TYPE      P
-</pre>
-<h2>HOW THE FILTER WORKS</h2>
-The filter process produces a new category value for each cell
-in the input raster map layer by multiplying the category values of the
-cells in the n x n neighborhood around the center cell
-by the corresponding matrix value and adding them together.
-If a divisor is specified, the sum is divided by this divisor,
-rounding to the nearest integer.
-(If a zero divisor was specified, then
-the divisor is computed for each cell as the sum of the MATRIX
-values where the corresponding input cell is non-zero.)
-<p>
-If more than one filter step is specified, either because the
-repeat value was greater than one or because the filter file
-contained more than one matrix, these steps are performed
-sequentially. This means that first one filter is applied to
-the entire input raster map layer to produce an intermediate result;
-then the next filter is applied to the intermediate result to
-produce another intermediate result;  and so on, until the
-final filter is applied.  Then the output cell is written.
-<h2>NOTES</h2>
-If the resolution of the geographic region does not agree with the
-resolution of the raster map layer, unintended resampling of the original
-data may occur.  The user should be sure that the geographic region
-is set properly.
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.clump.html">r.clump</a></em>,
-<em><a href="r.neighbors.html">r.neighbors</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.mfilter/r.mfilter.html (from rev 33119, grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html)
--- grass/trunk/raster/r.mfilter/r.mfilter.html	                        (rev 0)
@@ -0,0 +1,157 @@
+<h2>DESCRIPTION</h2>
+<em>r.mfilter.fp</em> filters the raster <em>input</em> to produce the
+raster <em>output</em> according to the matrix <em>filter</em> designed
+by the user (see <em>FILTERS</em> below).
+The filter is applied <em>repeat</em> times (default <em>value</em> is 1).
+The <em>output</em> raster map layer can be given a <em>TITLE</em> if desired.
+(This TITLE should be put in quotes if it contains more than one word.)
+With <b>-z</b> flag the filter is applied only to null values in
+the input raster map layer.  The non-null category values are not changed.
+Note that if there is more than one filter step, this rule is applied to the
+intermediate raster map layer -- only null category values which result from
+the first filter will be changed.  In most cases this will NOT be the
+desired result. Hence -z should be used only with single step filters.
+<p>
+The <b>filter</b> parameter defines the name of an existing, user-created
+UNIX ASCII file whose contents is a matrix defining the way in which the
+<em>input</em> file will be filtered. The format of this file is described
+below, under FILTERS.
+<p>
+The <b>repeat</b> parameter defines the number of times the <em>filter</em>
+is to be applied to the <em>input</em> data.
+<h2>FILTERS</h2>
+The <em>filter</em> file is a normal UNIX ASCII file designed by the user.
+It has the following format:
+<pre>
+     TITLE      TITLE
+     MATRIX     n
+     n lines of n values
+     DIVISOR    d
+     TYPE        S/P
+</pre>
+<dl>
+<dt>TITLE
+<dd>A one-line TITLE for the filter.
+If a TITLE was not specified on the command line, it can be specified here.
+This TITLE would be used to construct a TITLE for the resulting raster map
+layer.  It should be a one-line description of the filter.
+<dt>MATRIX
+<dd>The matrix (n x n) follows on the next n lines.  <em>n</em> must be
+an odd integer greater than or equal to 3.
+The matrix itself consists of n rows of n values.
+The values must be separated from each other by at least 1 blank.
+<dt>DIVISOR
+<dd>The filter divisor is <em>d</em>.  If not specified, the default is 1.
+If the divisor is zero (0), then the divisor is dependent on the
+category values in the neighborhood
+(see HOW THE FILTER WORKS below).
+<dt>TYPE
+<dd>The filter type.  <em>S</em> means sequential, while <em>P</em> mean parallel.
+If not specified, the default is S.
+<p>
+Sequential filtering happens in place.  As the filter is applied to the
+raster map layer, the category values that were changed in neighboring
+cells affect the resulting category value of the current
+cell being filtered.
+<p>
+Parallel filtering happens in such a way that the original raster
+map layer category values are used to produce the new category value.
+<p>
+More than one filter may be specified in the filter file.
+The additional filter(s) are described just like the first.
+For example, the following describes two filters:
+</p>
+</dl>
+<h2>EXAMPLE FILTER FILE</h2>
+<pre>
+      TITLE     3x3 average, non-null data only, followed by 5x5 average
+     MATRIX    3
+     1 1 1
+     1 1 1
+     1 1 1
+     DIVISOR   0
+     TYPE      P
+     MATRIX    5
+     1 1 1 1 1
+     1 1 1 1 1
+     1 1 1 1 1
+     1 1 1 1 1
+     1 1 1 1 1
+     DIVISOR   25
+     TYPE      P
+</pre>
+<h2>HOW THE FILTER WORKS</h2>
+The filter process produces a new category value for each cell
+in the input raster map layer by multiplying the category values of the
+cells in the n x n neighborhood around the center cell
+by the corresponding matrix value and adding them together.
+If a divisor is specified, the sum is divided by this divisor.
+(If a zero divisor was specified, then
+the divisor is computed for each cell as the sum of the MATRIX
+values where the corresponding input cell is non-null.)
+<p>
+If more than one filter step is specified, either because the
+repeat value was greater than one or because the filter file
+contained more than one matrix, these steps are performed
+sequentially. This means that first one filter is applied to
+the entire input raster map layer to produce an intermediate result;
+then the next filter is applied to the intermediate result to
+produce another intermediate result;  and so on, until the
+final filter is applied.  Then the output cell is written.
+<h2>NOTES</h2>
+If the resolution of the geographic region does not agree with the
+resolution of the raster map layer, unintended resampling of the original
+data may occur.  The user should be sure that the geographic region
+is set properly.
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.clump.html">r.clump</a></em>,
+<em><a href="r.neighbors.html">r.neighbors</a></em>
+<em><a href="r.mfilter.html">r.mfilter</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements.
+Based upon r.mfilter, by Michael Shapiro,
+U.S.Army Construction Engineering Research Laboratory
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.mfilter/uppercase.c
--- grass/trunk/raster/r.mfilter/uppercase.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter/uppercase.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,8 +0,0 @@
-int uppercase(char *s)
-    for (; *s; s++)
-	if (*s >= 'a' && *s <= 'z')
-	    *s += 'A' - 'a';
-    return 0;
Copied: grass/trunk/raster/r.mfilter/uppercase.c (from rev 33119, grass/trunk/raster/r.mfilter.fp/uppercase.c)
--- grass/trunk/raster/r.mfilter/uppercase.c	                        (rev 0)
@@ -0,0 +1,8 @@
+int uppercase(char *s)
+    for (; *s; s++)
+	if (*s >= 'a' && *s <= 'z')
+	    *s += 'A' - 'a';
+    return 0;
Deleted: grass/trunk/raster/r.mfilter.fp/Makefile
--- grass/trunk/raster/r.mfilter.fp/Makefile	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/Makefile	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,10 +0,0 @@
-PGM = r.mfilter.fp
-default: cmd
Deleted: grass/trunk/raster/r.mfilter.fp/apply.c
--- grass/trunk/raster/r.mfilter.fp/apply.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/apply.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,50 +0,0 @@
-DCELL apply_filter(FILTER * filter, DCELL ** input)
-    int size = filter->size;
-    double **matrix = filter->matrix;
-    double divisor = filter->divisor;
-    int r, c;
-    DCELL v;
-    v = 0;
-	int have_result = 0;
-	    for (c = 0; c < size; c++) {
-		if (G_is_d_null_value(&input[r][c]))
-		    continue;
-		divisor += filter->dmatrix[r][c];
-		have_result = 1;
-	if (have_result)
-	    v /= divisor;
-	else
-	    G_set_d_null_value(&v, 1);
-    else {
-		if (G_is_d_null_value(&input[r][c])) {
-		    return v;
-	v /= divisor;
-    return v;
Deleted: grass/trunk/raster/r.mfilter.fp/execute.c
--- grass/trunk/raster/r.mfilter.fp/execute.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/execute.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,120 +0,0 @@
-#include "glob.h"
-int execute_filter(ROWIO * r, int out, FILTER * filter, DCELL * cell)
-    int i;
-    int count;
-    int size;
-    int row, rcount;
-    int col, ccount;
-    int dx, dy;
-    int mid;
-    DCELL **bufs, **box, *cp;
-    mid = size / 2;
-    bufs = (DCELL **) G_malloc(size * sizeof(DCELL *));
-    box = (DCELL **) G_malloc(size * sizeof(DCELL *));
-    case UR:
-	starty = 0;
-	dx = -1;
-	dy = 1;
-	break;
-    case LL:
-	startx = 0;
-	dx = 1;
-	dy = -1;
-	break;
-    case LR:
-	dx = -1;
-	dy = -1;
-	break;
-    case UL:
-    default:
-	startx = 0;
-	starty = 0;
-	dx = 1;
-	dy = 1;
-	break;
-    direction = dy;
-    row = starty;
-	cp = (DCELL *) rowio_get(r, row);
-	row += dy;
-	row = starty;
-	starty += dy;
-	    bufs[i] = (DCELL *) rowio_get(r, row);
-	    row += dy;
-	    cell = bufs[mid];
-	/* copy border */
-	cp = cell;
-	/* filter row */
-	col = ccount;
-	while (col--) {
-	    if (null_only) {
-		if (G_is_d_null_value(&box[mid][mid]))
-		else
-	    else {
-		box[i] += dx;
-	/* copy border */
-	/* write row */
-	row += dy;
-    return 0;
Deleted: grass/trunk/raster/r.mfilter.fp/filter
--- grass/trunk/raster/r.mfilter.fp/filter	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/filter	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,9 +0,0 @@
-MATRIX 5
-1 1 1 1 1
-1 1 1 1 1
-1 1 1 1 1
-1 1 1 1 1
-1 1 1 1 1
-DIVISOR  0
-TYPE     P
Deleted: grass/trunk/raster/r.mfilter.fp/filter.ave
--- grass/trunk/raster/r.mfilter.fp/filter.ave	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/filter.ave	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,6 +0,0 @@
-MATRIX 3
-1 1 1
-1 1 1
-1 1 1
-DIVISOR 9
-START LR
Deleted: grass/trunk/raster/r.mfilter.fp/filter.h
--- grass/trunk/raster/r.mfilter.fp/filter.h	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/filter.h	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,30 +0,0 @@
-typedef struct
-    double **matrix;		/* filter coefficient matrix */
-    double **dmatrix;		/* divisor coefficient matrix */
-    double divisor;		/* filter scale factor */
-} FILTER;
-#define PARALLEL 1
-#define UL 1
-#define UR 2
-#define LL 3
-#define LR 4
-/* apply.c */
-DCELL apply_filter(FILTER *, DCELL **);
-/* getfilt.c */
-/* perform.c */
-/* execute.c */
-int execute_filter(ROWIO *, int, FILTER *, DCELL *);
Deleted: grass/trunk/raster/r.mfilter.fp/getfilt.c
--- grass/trunk/raster/r.mfilter.fp/getfilt.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/getfilt.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,162 +0,0 @@
-    FILE *fd;
-    char buf[300];
-    char temp[100];
-    char label[50];
-    int row, col;
-    int n;
-    int have_divisor;
-    int have_type;
-    int have_start;
-    int count;
-    double div;
-    f = filter = 0;
-    *title = 0;
-    if (!fd) {
-	G_strip(buf);
-	    continue;
-	    uppercase(label);
-		G_strip(temp);
-		continue;
-	uppercase(buf);
-	    if (n < 3) {
-	    if (n % 2 == 0) {
-	    count++;
-	    f->size = n;
-	    f->divisor = 1;
-	    f->start = UL;
-	    have_divisor = 0;
-	    have_type = 0;
-	    have_start = 0;
-	    f->matrix = (DCELL **) G_malloc(n * sizeof(DCELL *));
-		f->matrix[row] = (DCELL *) G_malloc(n * sizeof(DCELL));
-		    if (fscanf(fd, "%lf", &f->matrix[row][col]) != 1) {
-	    continue;
-	if (sscanf(buf, "DIVISOR %lf", &div) == 1)
-		if (!filter) {
-		have_divisor = 1;
-		if (sscanf(buf, "DIVISOR %lf", &div) == 1) {
-		    f->divisor = div;
-		    if (n == 0)
-		    continue;
-		f->divisor = 0;
-		f->dmatrix = (DCELL **) G_malloc(f->size * sizeof(DCELL *));
-		    f->dmatrix[row] =
-			(DCELL *) G_malloc(f->size * sizeof(DCELL));
-			if (fscanf(fd, "%lf", &f->dmatrix[row][col]) != 1) {
-		continue;
-	    if (!filter) {
-	    if (have_type) {
-	    else {
-	    have_type = 1;
-	    continue;
-	    if (!filter) {
-	    if (have_start) {
-		f->start = UL;
-	    else
-	       f->start  = UR ;
-	       f->start  = LL ;
-	       f->start  = LR ;
-	       else
-	    have_start = 1;
-	    continue;
-    if (!filter) {
-    return filter;
Deleted: grass/trunk/raster/r.mfilter.fp/getrow.c
--- grass/trunk/raster/r.mfilter.fp/getrow.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/getrow.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,25 +0,0 @@
-#include "glob.h"
-    if (G_get_d_raster_row(fd, (DCELL *) buf, row) < 0)
-    return 1;
-    else
-    if (read(fd, (DCELL *) buf, len) != len)
-    return 1;
Deleted: grass/trunk/raster/r.mfilter.fp/glob.h
--- grass/trunk/raster/r.mfilter.fp/glob.h	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/glob.h	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,6 +0,0 @@
-extern int buflen;
-extern int null_only;
Deleted: grass/trunk/raster/r.mfilter.fp/local_proto.h
--- grass/trunk/raster/r.mfilter.fp/local_proto.h	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/local_proto.h	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,6 +0,0 @@
-/* getrow.c */
-/* uppercase.c */
Deleted: grass/trunk/raster/r.mfilter.fp/main.c
--- grass/trunk/raster/r.mfilter.fp/main.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/main.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,141 +0,0 @@
- * PURPOSE:
- *               for details.
-#include <stdio.h>
-#include "glob.h"
-int nrows, ncols;
-int buflen;
-int direction;
-int null_only;
-int main(int argc, char **argv)
-    FILTER *filter;
-    int nfilters;
-    int repeat;
-    char *filt_name;
-    char *out_name;
-    char title[1024];
-    char temp[300];
-    int i;
-    flag2->key = 'z';
-    flag2->description = _("Apply filter only to null data values");
-    null_only = flag2->answer;
-    buflen = ncols * sizeof(DCELL);
-    if (opt5->answer)
-    else {
-	if (*temp == 0)
Deleted: grass/trunk/raster/r.mfilter.fp/perform.c
--- grass/trunk/raster/r.mfilter.fp/perform.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/perform.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,103 +0,0 @@
-#include <fcntl.h>
-#include "glob.h"
-    int in;
-    int out;
-    int n;
-    int pass;
-    ROWIO r;
-    int count;
-    int row;
-    DCELL *cell;
-    cell = G_allocate_d_raster_buf();
-    count = 0;
-	    if (count == 0) {
-			in_mapset, in);
-		if (in < 0) {
-		if (out < 0)
-		G_close_cell(in);
-		in = out;
-		if (out < 0)
-	    else {
-		int fd;
-		fd = in;
-		in = out;
-		out = fd;
-    if (count == 1)
-	G_close_cell(in);
-	close(in);
-    in = out;
-    out = G_open_fp_cell_new(out_name);
-    if (out < 0) {
-	G_put_d_raster_row(out, cell);
-    if (count > 0)
-	unlink(tmp1);
-    if (count > 1)
-	unlink(tmp2);
-    return 0;
Deleted: grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html
--- grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,157 +0,0 @@
-<em>r.mfilter.fp</em> filters the raster <em>input</em> to produce the
-With <b>-z</b> flag the filter is applied only to null values in
-the input raster map layer.  The non-null category values are not changed.
-intermediate raster map layer -- only null category values which result from
-<p>
-<p>
-<h2>FILTERS</h2>
-<pre>
-     TITLE      TITLE
-     MATRIX     n
-     n lines of n values
-     DIVISOR    d
-     TYPE        S/P
-</pre>
-<dl>
-<dt>TITLE
-<dt>MATRIX
-The matrix itself consists of n rows of n values.
-The values must be separated from each other by at least 1 blank.
-<dt>DIVISOR
-<dt>TYPE
-<p>
-<p>
-<p>
-</p>
-</dl>
-<pre>
-      TITLE     3x3 average, non-null data only, followed by 5x5 average
-     MATRIX    3
-     1 1 1
-     1 1 1
-     1 1 1
-     DIVISOR   0
-     TYPE      P
-     MATRIX    5
-     1 1 1 1 1
-     1 1 1 1 1
-     1 1 1 1 1
-     1 1 1 1 1
-     1 1 1 1 1
-     DIVISOR   25
-     TYPE      P
-</pre>
-If a divisor is specified, the sum is divided by this divisor.
-values where the corresponding input cell is non-null.)
-<p>
-<h2>NOTES</h2>
-is set properly.
-<h2>SEE ALSO</h2>
-<em><a href="r.mfilter.html">r.mfilter</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements.
-Based upon r.mfilter, by Michael Shapiro,
-<p>
Deleted: grass/trunk/raster/r.mfilter.fp/uppercase.c
--- grass/trunk/raster/r.mfilter.fp/uppercase.c	2008-08-27 20:48:08 UTC (rev 33130)
+++ grass/trunk/raster/r.mfilter.fp/uppercase.c	2008-08-27 21:56:35 UTC (rev 33131)
@@ -1,8 +0,0 @@
-    for (; *s; s++)
-	    *s += 'A' - 'a';
-    return 0;
