[GRASS-SVN] r33133 - in grass/trunk/raster: r.average r.basins.fill r.bitpattern r.clump r.composite r.contour r.covar r.describe r.drain r.grow r.grow.distance r.info r.lake r.median r.mode r.neighbors r.out.arc r.out.ascii r.out.bin r.out.mat r.out.png r.out.pov r.out.ppm r.out.ppm3 r.out.tiff r.out.vrml r.out.vtk
Wed Aug 27 18:02:44 EDT 2008
Author: glynn
Date: 2008-08-27 18:02:44 -0400 (Wed, 27 Aug 2008)
New Revision: 33133
   grass/trunk/raster/r.average/main.c
   grass/trunk/raster/r.basins.fill/local_proto.h
   grass/trunk/raster/r.basins.fill/main.c
   grass/trunk/raster/r.basins.fill/read_map.c
   grass/trunk/raster/r.bitpattern/main.c
   grass/trunk/raster/r.clump/main.c
   grass/trunk/raster/r.composite/main.c
   grass/trunk/raster/r.contour/main.c
   grass/trunk/raster/r.covar/main.c
   grass/trunk/raster/r.describe/describe.c
   grass/trunk/raster/r.describe/local_proto.h
   grass/trunk/raster/r.describe/main.c
   grass/trunk/raster/r.drain/main.c
   grass/trunk/raster/r.grow.distance/main.c
   grass/trunk/raster/r.grow/main.c
   grass/trunk/raster/r.info/main.c
   grass/trunk/raster/r.lake/main.c
   grass/trunk/raster/r.median/main.c
   grass/trunk/raster/r.mode/main.c
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.neighbors/ncb.h
   grass/trunk/raster/r.neighbors/null_cats.c
   grass/trunk/raster/r.out.arc/main.c
   grass/trunk/raster/r.out.ascii/formspecific.c
   grass/trunk/raster/r.out.ascii/localproto.h
   grass/trunk/raster/r.out.ascii/main.c
   grass/trunk/raster/r.out.bin/main.c
   grass/trunk/raster/r.out.mat/main.c
   grass/trunk/raster/r.out.png/main.c
   grass/trunk/raster/r.out.pov/main.c
   grass/trunk/raster/r.out.ppm/main.c
   grass/trunk/raster/r.out.ppm3/main.c
   grass/trunk/raster/r.out.tiff/main.c
   grass/trunk/raster/r.out.vrml/main.c
   grass/trunk/raster/r.out.vtk/main.c
Remove explicit mapset references and G_find_* calls
Modified: grass/trunk/raster/r.average/main.c
--- grass/trunk/raster/r.average/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.average/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -34,7 +34,6 @@
 int main(int argc, char *argv[])
     char command[1024];
-    char *mapset;
     struct GModule *module;
     struct Option *basemap, *covermap, *outputmap;
     struct Flag *flag_c;
@@ -68,14 +67,8 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    if (!G_find_cell(basemap->answer, ""))
-	G_fatal_error(_("Raster map <%s> not found"), basemap->answer);
-    if (!(mapset = G_find_cell(covermap->answer, "")))
-	G_fatal_error(_("Raster map <%s> not found"), covermap->answer);
     if ((usecats = flag_c->answer)) {
-	if (G_read_cats(covermap->answer, mapset, &cats) < 0)
+	if (G_read_cats(covermap->answer, "", &cats) < 0)
 	    G_fatal_error(_("Error reading category file for <%s>"),
 			  covermap->answer);
Modified: grass/trunk/raster/r.basins.fill/local_proto.h
--- grass/trunk/raster/r.basins.fill/local_proto.h	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.basins.fill/local_proto.h	2008-08-27 22:02:44 UTC (rev 33133)
@@ -20,7 +20,7 @@
 #define __LOCAL_PROTO_H__
 /* read_map.c */
-CELL *read_map(char *, char *, int, int, int);
+CELL *read_map(const char *, int, int, int);
 #endif /* __LOCAL_PROTO_H__ */
Modified: grass/trunk/raster/r.basins.fill/main.c
--- grass/trunk/raster/r.basins.fill/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.basins.fill/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -38,14 +38,14 @@
     int partfd;
     int nrows, ncols;
-    char drain_name[GNAME_MAX], *drain_mapset;
-    char ridge_name[GNAME_MAX], *ridge_mapset;
-    char part_name[GNAME_MAX], *part_mapset;
+    const char *drain_name;
+    const char *ridge_name;
+    const char *part_name;
     CELL *drain, *ridge;
     struct Cell_head window;
     int row, col, npass, tpass;
-    struct Option *opt1, *opt2, *opt3, *opt4;
+    struct Option *num_opt, *drain_opt, *ridge_opt, *part_opt;
     G_gisinit(argv[0]);
@@ -54,63 +54,54 @@
     module->description =
 	_("Generates a raster map layer showing " "watershed subbasins.");
-    opt1 = G_define_option();
-    opt1->key = "number";
-    opt1->type = TYPE_INTEGER;
-    opt1->required = YES;
-    opt1->description = _("Number of passes through the dataset");
-    opt1->gisprompt = "old,cell,raster";
+    num_opt = G_define_option();
+    num_opt->key = "number";
+    num_opt->type = TYPE_INTEGER;
+    num_opt->required = YES;
+    num_opt->description = _("Number of passes through the dataset");
+    num_opt->gisprompt = "old,cell,raster";
-    opt2 = G_define_option();
-    opt2->key = "c_map";
-    opt2->type = TYPE_STRING;
-    opt2->required = YES;
-    opt2->description = _("Coded stream network file name");
-    opt2->gisprompt = "old,cell,raster";
+    drain_opt = G_define_option();
+    drain_opt->key = "c_map";
+    drain_opt->type = TYPE_STRING;
+    drain_opt->required = YES;
+    drain_opt->description = _("Coded stream network file name");
+    drain_opt->gisprompt = "old,cell,raster";
-    opt3 = G_define_option();
-    opt3->key = "t_map";
-    opt3->type = TYPE_STRING;
-    opt3->required = YES;
-    opt3->description = _("Thinned ridge network file name");
-    opt3->gisprompt = "old,cell,raster";
+    ridge_opt = G_define_option();
+    ridge_opt->key = "t_map";
+    ridge_opt->type = TYPE_STRING;
+    ridge_opt->required = YES;
+    ridge_opt->description = _("Thinned ridge network file name");
+    ridge_opt->gisprompt = "old,cell,raster";
-    opt4 = G_define_option();
-    opt4->key = "result";
-    opt4->type = TYPE_STRING;
-    opt4->required = YES;
-    opt4->description = _("Name for the resultant watershed partition file");
-    opt4->gisprompt = "new,cell,raster";
+    part_opt = G_define_option();
+    part_opt->key = "result";
+    part_opt->type = TYPE_STRING;
+    part_opt->required = YES;
+    part_opt->description = _("Name for the resultant watershed partition file");
+    part_opt->gisprompt = "new,cell,raster";
 	exit(EXIT_FAILURE);
-    sscanf(opt1->answer, "%d", &tpass);
+    sscanf(num_opt->answer, "%d", &tpass);
-    strcpy(drain_name, opt2->answer);
-    drain_mapset = G_find_cell2(drain_name, "");
-    if (drain_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), opt2->answer);
+    drain_name = drain_opt->answer;
     /* this isn't a nice thing to do. G_align_window() should be used first */
-    G_get_cellhd(drain_name, drain_mapset, &window);
+    G_get_cellhd(drain_name, "", &window);
     G_set_window(&window);
     nrows = G_window_rows();
     ncols = G_window_cols();
-    strcpy(ridge_name, opt3->answer);
-    ridge_mapset = G_find_cell2(ridge_name, "");
-    if (ridge_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), opt3->answer);
+    ridge_name = ridge_opt->answer;
-    strcpy(part_name, opt4->answer);
-    part_mapset = G_find_cell2(part_name, "");
-    if (part_mapset != NULL)
-	G_fatal_error(_("Raster map <%s> already exists"), opt4->answer);
+    part_name = part_opt->answer;
-    drain = read_map(drain_name, drain_mapset, NOMASK, nrows, ncols);
-    ridge = read_map(ridge_name, ridge_mapset, NOMASK, nrows, ncols);
+    drain = read_map(drain_name, NOMASK, nrows, ncols);
+    ridge = read_map(ridge_name, NOMASK, nrows, ncols);
     partfd = G_open_cell_new(part_name);
     if (partfd < 0)
Modified: grass/trunk/raster/r.basins.fill/read_map.c
--- grass/trunk/raster/r.basins.fill/read_map.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.basins.fill/read_map.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -17,25 +17,26 @@
 #include <grass/gis.h>
+#include <grass/glocale.h>
 #include "local_proto.h"
-CELL *read_map(char *name, char *mapset, int nomask, int nrows, int ncols)
+CELL *read_map(const char *name, int nomask, int nrows, int ncols)
     int fd;
     CELL *map;
     int row;
-    int (*get_row) ();
+    int (*get_row)(int, CELL *, int);
     /* allocate entire map */
     map = (CELL *) G_malloc(nrows * ncols * sizeof(CELL));
     /* open the map */
-    if ((fd = G_open_cell_old(name, mapset)) < 0)
-	G_fatal_error("unable to open [%s] in [%s]", name, mapset);
+    if ((fd = G_open_cell_old(name, "")) < 0)
+	G_fatal_error(_("Unable to open <%s>"), name);
     /* read the map */
-    G_message("READING [%s] in [%s] ... ", name, mapset);
+    G_message(_("Reading <%s> ... "), name);
     if (nomask)
 	get_row = G_get_map_row_nomask;
@@ -45,7 +46,7 @@
     for (row = 0; row < nrows; row++) {
 	G_percent(row, nrows, 10);
 	if ((*get_row) (fd, map + row * ncols, row) < 0)
-	    G_fatal_error("error reading [%s] in [%s]", name, mapset);
+	    G_fatal_error(_("Error reading <%s>"), name);
     G_percent(nrows, nrows, 10);
Modified: grass/trunk/raster/r.bitpattern/main.c
--- grass/trunk/raster/r.bitpattern/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.bitpattern/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -43,7 +43,7 @@
     struct Cell_head cellhd;
-    char *name, *result, *mapset;
+    char *name, *result;
     void *inrast;
     unsigned char *outrast;
     int nrows, ncols;
@@ -95,19 +95,14 @@
     pat = atoi(pattern->answer);
     patv = atoi(patval->answer);
-    /* find map in mapset */
-    mapset = G_find_cell2(name, "");
-    if (mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), name);
     /*if Gispf() error */
-    if ((infd = G_open_cell_old(name, mapset)) < 0)
+    if ((infd = G_open_cell_old(name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), name);
     /* determine the inputmap type (CELL/FCELL/DCELL) */
     data_type = G_get_raster_map_type(infd);
-    if (G_get_cellhd(name, mapset, &cellhd) < 0)
+    if (G_get_cellhd(name, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"), name);
     /* Allocate input buffer */
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.clump/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -28,16 +28,15 @@
     struct Colors colr;
     struct Range range;
     CELL min, max;
-    char *mapset;
     int in_fd, out_fd;
     char title[512];
     char name[GNAME_MAX];
     char *OUTPUT;
     char *INPUT;
-    struct Option *opt1;
-    struct Option *opt2;
-    struct Option *opt3;
+    struct Option *opt_in;
+    struct Option *opt_out;
+    struct Option *opt_title;
     G_gisinit(argv[0]);
@@ -49,30 +48,26 @@
 	_("Recategorizes data in a raster map layer by grouping cells "
 	  "that form physically discrete areas into unique categories.");
-    opt1 = G_define_standard_option(G_OPT_R_INPUT);
+    opt_in = G_define_standard_option(G_OPT_R_INPUT);
-    opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt_out = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt3->key = "title";
-    opt3->key_desc = "\"string\"";
-    opt3->required = NO;
-    opt3->description = _("Title, in quotes");
+    opt_title = G_define_option();
+    opt_title->key = "title";
+    opt_title->type = TYPE_STRING;
+    opt_title->required = NO;
+    opt_title->description = _("Title");
     /* parse options */
 	exit(EXIT_FAILURE);
-    INPUT = opt1->answer;
-    OUTPUT = opt2->answer;
+    INPUT = opt_in->answer;
+    OUTPUT = opt_out->answer;
     strcpy(name, INPUT);
-    if (!mapset)
-	G_fatal_error(_("Raster map <%s> not found"), INPUT);
-    in_fd = G_open_cell_old(name, mapset);
+    in_fd = G_open_cell_old(name, "");
     if (in_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), INPUT);
@@ -89,10 +84,10 @@
     /* build title */
-    if (opt3->answer != NULL)
-	strcpy(title, opt3->answer);
+    if (opt_title->answer != NULL)
+	strcpy(title, opt_title->answer);
     else
-	sprintf(title, "clump of %s in %s", name, mapset);
+	sprintf(title, "clump of %s", name);
     G_put_cell_title(OUTPUT, title);
     G_read_range(OUTPUT, G_mapset(), &range);
Modified: grass/trunk/raster/r.composite/main.c
--- grass/trunk/raster/r.composite/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.composite/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -59,7 +59,6 @@
     CELL *out_array;
     struct Colors out_colors;
     int levels;
-    char *mapset;
     int atrow, atcol;
     unsigned char *dummy, *nulls;
@@ -152,12 +151,8 @@
 	/* Get name of layer to be used */
 	b->name = b->opt_name->answer;
-	mapset = G_find_cell2(b->name, "");
-	    G_fatal_error(_("Raster map <%s> not found"), b->name);
 	/* Make sure map is available */
-	if ((b->file = G_open_cell_old(b->name, mapset)) == -1)
+	if ((b->file = G_open_cell_old(b->name, "")) == -1)
 	    G_fatal_error(_("Unable to open raster map <%s>"), b->name);
 	b->type = G_get_raster_map_type(b->file);
@@ -165,7 +160,7 @@
 	b->size = G_raster_size(b->type);
 	/* Reading color lookup table */
-	if (G_read_colors(b->name, mapset, &b->colors) == -1)
+	if (G_read_colors(b->name, "", &b->colors) == -1)
 	    G_fatal_error(_("Color file for <%s> not available"), b->name);
 	for (j = 0; j < 3; j++)
@@ -186,10 +181,6 @@
     /* open output files */
     out_name = opt_out->answer;
-    mapset = G_find_cell2(out_name, "");
-    if (mapset != NULL)
-	G_remove("cell", out_name);
     if ((out_file = G_open_cell_new(out_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), out_name);
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.contour/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -65,7 +65,6 @@
     struct Cell_head Wind;
     char *name;
-    char *mapset;
     struct Map_info Map;
     DCELL **z_array;
     struct FPRange range;
@@ -131,15 +130,12 @@
     name = map->answer;
-    fd = G_open_cell_old(name, mapset);
+    fd = G_open_cell_old(name, "");
     if (fd < 0)
-    if (G_read_fp_range(name, mapset, &range) < 0)
+    if (G_read_fp_range(name, "", &range) < 0)
 	G_fatal_error(_("Could not read range file"));
     /* get window info */
Modified: grass/trunk/raster/r.covar/main.c
--- grass/trunk/raster/r.covar/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.covar/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -28,7 +28,7 @@
     int nrows, ncols;
     DCELL **dcell;
-    char *name, *mapset;
+    char *name;
     double *sum, **sum2;
     double count;
     double ii, jj;
@@ -75,10 +75,7 @@
 	sum2[i] = (double *)G_calloc(nfiles, sizeof(double));
 	dcell[i] = G_allocate_d_raster_buf();
 	name = maps->answers[i];
-	mapset = G_find_cell(name, "");
-	if (!mapset)
-	fd[i] = G_open_cell_old(name, mapset);
+	fd[i] = G_open_cell_old(name, "");
 	if (fd[i] < 0)
Modified: grass/trunk/raster/r.describe/describe.c
--- grass/trunk/raster/r.describe/describe.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.describe/describe.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -17,10 +17,11 @@
-int describe(char *name, char *mapset, int compact, char *no_data_str,
+int describe(const char *name, int compact, char *no_data_str,
 	     int range, int windowed, int nsteps, int as_int, int skip_nulls)
     int fd;
@@ -35,23 +36,19 @@
     struct Quant q;
     struct FPRange r;
     DCELL dmin, dmax;
     if (windowed) {
 	get_row = G_get_c_raster_row;
     else {
-	char msg[100];
+	if (G_get_cellhd(name, "", &window) < 0)
+	    G_fatal_error(_("Unable to get cell header for <%s>"), name);
-	if (G_get_cellhd(name, mapset, &window) < 0) {
-	    sprintf(msg, "can't get cell header for [%s] in [%s]", name,
-		    mapset);
-	    G_fatal_error(msg);
 	get_row = G_get_c_raster_row_nomask;
     if (fd < 0)
 	return 0;
@@ -87,7 +84,7 @@
     /* set up quantization rules */
     if (map_type != CELL_TYPE) {
 	G_quant_init(&q);
-	G_read_fp_range(name, mapset, &r);
+	G_read_fp_range(name, "", &r);
 	G_get_fp_range_min_max(&r, &dmin, &dmax);
 	G_quant_add_rule(&q, dmin, dmax, 1, nsteps);
 	G_set_quant_rules(fd, &q);
@@ -96,7 +93,7 @@
-    G_verbose_message("Reading [%s in %s] ...", name, mapset);
+    G_verbose_message(_("Reading <%s> ..."), name);
 	G_percent(row, nrows, 2);
 	if ((*get_row) (fd, b = buf, row) < 0)
Modified: grass/trunk/raster/r.describe/local_proto.h
--- grass/trunk/raster/r.describe/local_proto.h	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.describe/local_proto.h	2008-08-27 22:02:44 UTC (rev 33133)
@@ -20,7 +20,7 @@
 #define __R_DESC_LOCAL_PROTO_H__
 /* describe.c */
-int describe(char *, char *, int, char *, int, int, int, int, int);
+int describe(const char *, int, char *, int, int, int, int, int);
 /* dumplist.c */
 int long_list(struct Cell_stats *, DCELL, DCELL, char *, int, RASTER_MAP_TYPE,
Modified: grass/trunk/raster/r.describe/main.c
--- grass/trunk/raster/r.describe/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.describe/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -31,8 +31,6 @@
     int range;
     int windowed;
     int nsteps;
-    char name[GNAME_MAX];
-    char *mapset;
     char *no_data_str;
     struct
@@ -111,15 +109,8 @@
 	G_fatal_error(_("%s = %s -- must be greater than zero"),
 		      option.nsteps->key, option.nsteps->answer);
-    strcpy(name, option.map->answer);
+    describe(option.map->answer, compact, no_data_str,
+	     range, windowed, nsteps, as_int, flag.n->answer);
-    if ((mapset = G_find_cell2(name, ""))) {
-	describe(name, mapset, compact, no_data_str,
-		 range, windowed, nsteps, as_int, flag.n->answer);
-	exit(EXIT_SUCCESS);
-    G_fatal_error(_("%s: [%s] not found"), G_program_name(), name);
     return EXIT_SUCCESS;
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.drain/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -74,9 +74,8 @@
     int nrows, ncols, points_row[MAX_POINTS], points_col[MAX_POINTS], npoints;
     int cell_open(), cell_open_new();
     int map_id;
-    char map_name[GNAME_MAX], *map_mapset, new_map_name[GNAME_MAX];
+    char map_name[GNAME_MAX], new_map_name[GNAME_MAX];
     char *tempfile1, *tempfile2;
-    char *search_mapset;
     struct History history;
@@ -147,13 +146,8 @@
     strcpy(map_name, opt1->answer);
     strcpy(new_map_name, opt2->answer);
-    /* get the name of the elevation map layer for filling */
-    map_mapset = G_find_cell(map_name, "");
-    if (!map_mapset)
-	G_fatal_error(_("Raster map <%s> not found"), map_name);
     /*      allocate cell buf for the map layer */
-    in_type = G_raster_map_type(map_name, map_mapset);
+    in_type = G_raster_map_type(map_name, "");
     /* set the pointers for multi-typed functions */
     set_func_pointers(in_type);
@@ -210,13 +204,8 @@
 	    int dims, strs, dbls;
 	    RASTER_MAP_TYPE cat;
-	    search_mapset = G_find_sites(vpointopt->answers[i], "");
-	    if (search_mapset == NULL)
-		G_fatal_error(_("Vector map <%s> not found"),
-			      vpointopt->answers[i]);
+	    fp = G_fopen_sites_old(vpointopt->answers[i], "");
-	    fp = G_fopen_sites_old(vpointopt->answers[i], search_mapset);
 	    if (0 != G_site_describe(fp, &dims, &cat, &strs, &dbls))
 		G_fatal_error(_("Failed to guess site file format"));
@@ -294,7 +283,7 @@
     in_buf = get_buf();
     /* open the original map and get its file id  */
-    map_id = G_open_cell_old(map_name, map_mapset);
+    map_id = G_open_cell_old(map_name, "");
     /* get some temp files */
     tempfile1 = G_tempfile();
Modified: grass/trunk/raster/r.grow/main.c
--- grass/trunk/raster/r.grow/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.grow/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -112,7 +112,6 @@
     double radius;
     int oldval = 0;
     int newval = 0;
-    char *mapset;
     RASTER_MAP_TYPE type;
     int in_fd;
     int out_fd;
@@ -181,10 +180,6 @@
     verbose = !flag.q->answer;
-    mapset = G_find_cell(in_name, "");
-    if (!mapset)
-	G_fatal_error(_("Raster map <%s> not found"), in_name);
@@ -197,7 +192,7 @@
     else
 	G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
-    in_fd = G_open_cell_old(in_name, mapset);
+    in_fd = G_open_cell_old(in_name, "");
     if (in_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), in_name);
@@ -207,12 +202,12 @@
     if (out_fd < 0)
-    if (G_read_cats(in_name, mapset, &cats) == -1) {
+    if (G_read_cats(in_name, "", &cats) == -1) {
 	G_warning(_("Error reading category file for <%s>"), in_name);
 	G_init_cats(0, "", &cats);
-    if (G_read_colors(in_name, mapset, &colr) == -1) {
+    if (G_read_colors(in_name, "", &colr) == -1) {
 	G_warning(_("Error in reading color file for <%s>"), in_name);
 	colrfile = 0;
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.grow.distance/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -102,7 +102,6 @@
     } opt;
     char *in_name;
     char *out_name;
-    char *mapset;
     int in_fd;
     int out_fd;
     char *temp_name;
@@ -139,10 +138,6 @@
     in_name = opt.in->answer;
     out_name = opt.out->answer;
-    if (!mapset)
     if (strcmp(opt.met->answer, "euclidian") == 0)
 	distance = &distance_euclidian_squared;
     else if (strcmp(opt.met->answer, "squared") == 0)
@@ -154,7 +149,7 @@
     else
     if (in_fd < 0)
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.info/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -117,19 +117,19 @@
     if ((mapset = G_find_cell2(name, "")) == NULL)
-    head_ok = G_get_cellhd(name, mapset, &cellhd) >= 0;
-    cats_ok = G_read_cats(name, mapset, &cats) >= 0;
-    hist_ok = G_read_history(name, mapset, &hist) >= 0;
-    is_reclass = G_get_reclass(name, mapset, &reclass);
-    data_type = G_raster_map_type(name, mapset);
+    head_ok = G_get_cellhd(name, "", &cellhd) >= 0;
+    cats_ok = G_read_cats(name, "", &cats) >= 0;
+    hist_ok = G_read_history(name, "", &hist) >= 0;
+    is_reclass = G_get_reclass(name, "", &reclass);
+    data_type = G_raster_map_type(name, "");
-    if (G_read_raster_units(name, mapset, units) != 0)
+    if (G_read_raster_units(name, "", units) != 0)
 	units[0] = '\0';
-    if (G_read_raster_vdatum(name, mapset, vdatum) != 0)
+    if (G_read_raster_vdatum(name, "", vdatum) != 0)
 	vdatum[0] = '\0';
     /*Check the Timestamp */
-    time_ok = G_read_raster_timestamp(name, mapset, &ts) > 0;
+    time_ok = G_read_raster_timestamp(name, "", &ts) > 0;
     /*Check for valid entries, show none if no timestamp available */
     if (time_ok) {
 	if (ts.count > 0)
@@ -138,7 +138,7 @@
 	    second_time_ok = 1;
 	G_fatal_error(_("Unable to read range file"));
     G_get_fp_range_min_max(&range, &zmin, &zmax);
@@ -228,7 +228,7 @@
 			 tmp1, tmp2, tmp3);
 	    if (data_type == CELL_TYPE) {
-		if (2 == G_read_range(name, mapset, &crange))
+		if (2 == G_read_range(name, "", &crange))
 		    compose_line(out,
 				 "  Range of data:    min = NULL  max = NULL");
 		else
@@ -320,7 +320,7 @@
 	if (rflag->answer) {
-		if (2 == G_read_range(name, mapset, &crange)) {
+		if (2 == G_read_range(name, "", &crange)) {
 		    fprintf(out, "min=NULL\n");
 		    fprintf(out, "max=NULL\n");
Modified: grass/trunk/raster/r.lake/main.c
--- grass/trunk/raster/r.lake/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.lake/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -131,7 +131,7 @@
-    char *terrainmap, *seedmap, *lakemap, *mapset;
+    char *terrainmap, *seedmap, *lakemap;
     int rows, cols, in_terran_fd, out_fd, lake_fd, row, col, pases, pass;
     int lastcount, curcount, start_col, start_row;
     double east, north, area = 0, volume = 0;
@@ -237,25 +237,15 @@
     /* Open terran map */
-    mapset = G_find_cell2(terrainmap, "");
-	G_fatal_error(_("Raster map <%s> not found"), terrainmap);
-    in_terran_fd = G_open_cell_old(terrainmap, mapset);
+    in_terran_fd = G_open_cell_old(terrainmap, "");
     if (in_terran_fd < 0)
-	G_fatal_error(_("Unable to open raster map <%s>"),
-		      G_fully_qualified_name(terrainmap, mapset));
+	G_fatal_error(_("Unable to open raster map <%s>"), terrainmap);
     /* Open seed map */
     if (smap_opt->answer) {
-	mapset = G_find_cell2(seedmap, "");
-	    G_fatal_error(_("Raster map <%s> not found"), seedmap);
-	out_fd = G_open_cell_old(seedmap, mapset);
+	out_fd = G_open_cell_old(seedmap, "");
 	if (out_fd < 0)
-			  G_fully_qualified_name(seedmap, mapset));
+	    G_fatal_error(_("Unable to open raster map <%s>"), seedmap);
     /* Pointers to rows. Row = ptr to 'col' size array. */
Modified: grass/trunk/raster/r.median/main.c
--- grass/trunk/raster/r.median/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.median/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -29,8 +29,8 @@
 	struct Option *base, *cover, *output;
     } parm;
-    char *basemap, *base_mapset;
-    char *covermap, *cover_mapset;
+    char *basemap;
+    char *covermap;
     char *outmap;
     char command[1024];
     struct Categories cover_cats;
@@ -66,36 +66,20 @@
     covermap = parm.cover->answer;
     outmap = parm.output->answer;
-    base_mapset = G_find_cell2(basemap, "");
-    if (base_mapset == NULL)
-	G_fatal_error(_("Base raster map <%s> not found"), basemap);
-    cover_mapset = G_find_cell2(covermap, "");
-    if (cover_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), covermap);
-    if (strcmp(G_mapset(), base_mapset) == 0 && strcmp(basemap, outmap) == 0)
-	G_fatal_error(_("Base map and output map <%s> must be different"),
-		      outmap);
-    if (G_read_cats(covermap, cover_mapset, &cover_cats) < 0)
+    if (G_read_cats(covermap, "", &cover_cats) < 0)
 	G_fatal_error(_("Unable to read category labels of raster map <%s>"),
 		      covermap);
-    strcpy(command, "r.stats -an \"");
-    strcat(command, G_fully_qualified_name(basemap, base_mapset));
-    strcat(command, ",");
-    strcat(command, G_fully_qualified_name(covermap, cover_mapset));
-    strcat(command, "\"");
+    sprintf(command, "r.stats -an \"%s,%s\"", basemap, covermap);
     /* strcpy (command,"cat /tmp/t"); */
     G_debug(3, "command: %s", command);
     stats_fd = popen(command, "r");
-    G_debug(3, "r.reclass i=\"%s\" o=\"%s\"",
-	    G_fully_qualified_name(basemap, base_mapset), outmap);
-    sprintf(command, "r.reclass i=\"%s\" o=\"%s\"",
+    G_debug(3, "r.reclass i=\"%s\" o=\"%s\"", basemap, outmap);
+    sprintf(command, "r.reclass i=\"%s\" o=\"%s\"", basemap, outmap);
     reclass_fd = popen(command, "w");
     first = 1;
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.mode/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -34,8 +34,8 @@
     } parm;
+    char *basemap;
+    char *covermap;
     char *outmap;
     char command[1024];
@@ -81,35 +81,16 @@
-    if (base_mapset == NULL) {
-	G_fatal_error(_("%s: base raster map not found"), basemap);
-    if (cover_mapset == NULL) {
-	G_fatal_error(_("%s: cover raster map not found"), covermap);
-    if (strcmp(G_mapset(), base_mapset) == 0 && strcmp(basemap, outmap) == 0) {
-	G_fatal_error(_("%s: base map and output map must be different"),
-		      outmap);
-    if (G_read_cats(covermap, cover_mapset, &cover_cats) < 0) {
+    if (G_read_cats(covermap, "", &cover_cats) < 0) {
 	G_fatal_error(_("%s: Unable to read category labels"), covermap);
     /* printf(command); */
     stats = popen(command, "r");
     reclass = popen(command, "w");
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.neighbors/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -171,15 +171,11 @@
     if (parm.weight->answer && flag.circle->answer)
 	G_fatal_error(_("weight= and -c are mutually exclusive"));
-    p = ncb.oldcell.name = parm.input->answer;
-    if (NULL == (ncb.oldcell.mapset = G_find_cell2(p, ""))) {
-	G_fatal_error(_("Raster map <%s> not found"), p);
-    p = ncb.newcell.name = parm.output->answer;
-    ncb.newcell.mapset = G_mapset();
+    ncb.oldcell = parm.input->answer;
+    ncb.newcell = parm.output->answer;
     if (!flag.align->answer) {
-	if (G_get_cellhd(ncb.oldcell.name, ncb.oldcell.mapset, &cellhd) < 0)
+	if (G_get_cellhd(ncb.oldcell, "", &cellhd) < 0)
 	    exit(EXIT_FAILURE);
 	G_get_window(&window);
 	G_align_window(&window, &cellhd);
@@ -190,9 +186,9 @@
     /* open raster maps */
-    if ((in_fd = G_open_cell_old(ncb.oldcell.name, ncb.oldcell.mapset)) < 0)
-	G_fatal_error(_("Unable to open raster map <%s> in mapset <%s>"),
-		      ncb.oldcell.name, ncb.oldcell.mapset);
+    if ((in_fd = G_open_cell_old(ncb.oldcell, "")) < 0)
+		      ncb.oldcell);
     map_type = G_get_raster_map_type(in_fd);
@@ -218,7 +214,7 @@
     if (copycolr) {
 	G_suppress_warnings(1);
 	copycolr =
-	    (G_read_colors(ncb.oldcell.name, ncb.oldcell.mapset, &colr) > 0);
+	    (G_read_colors(ncb.oldcell, "", &colr) > 0);
 	G_suppress_warnings(0);
@@ -240,7 +236,7 @@
 	strcpy(ncb.title, parm.title->answer);
     else
 	sprintf(ncb.title, "%dx%d neighborhood: %s of %s",
-		ncb.nsize, ncb.nsize, menu[method].name, ncb.oldcell.name);
+		ncb.nsize, ncb.nsize, menu[method].name, ncb.oldcell);
     /* initialize the cell bufs with 'dist' rows of the old cellfile */
@@ -250,12 +246,12 @@
 	readcell(in_fd, readrow++, nrows, ncols);
     /* open raster map */
-    in_fd = G_open_cell_old(ncb.oldcell.name, ncb.oldcell.mapset);
+    in_fd = G_open_cell_old(ncb.oldcell, "");
     if (in_fd < 0)
 	exit(EXIT_FAILURE);
     /*open the new raster map */
-    out_fd = G_open_raster_new(ncb.newcell.name, map_type);
+    out_fd = G_open_raster_new(ncb.newcell, map_type);
     if (out_fd < 0)
 	exit(EXIT_FAILURE);
@@ -303,14 +299,14 @@
     if ((cat_names = menu[method].cat_names))
 	cat_names();
-    G_write_cats(ncb.newcell.name, &ncb.cats);
+    G_write_cats(ncb.newcell, &ncb.cats);
     if (copycolr)
-	G_write_colors(ncb.newcell.name, ncb.newcell.mapset, &colr);
+	G_write_colors(ncb.newcell, G_mapset(), &colr);
-    G_short_history(ncb.newcell.name, "raster", &history);
+    G_short_history(ncb.newcell, "raster", &history);
     G_command_history(&history);
-    G_write_history(ncb.newcell.name, &history);
+    G_write_history(ncb.newcell, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.neighbors/ncb.h
--- grass/trunk/raster/r.neighbors/ncb.h	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.neighbors/ncb.h	2008-08-27 22:02:44 UTC (rev 33133)
@@ -10,12 +10,8 @@
     FILE *out;
     char **mask;
     DCELL **weights;
-    struct
-	char *name;
-	char *mapset;
-    oldcell, newcell;
+    const char *oldcell;
+    const char *newcell;
 extern struct ncb ncb;
Modified: grass/trunk/raster/r.neighbors/null_cats.c
--- grass/trunk/raster/r.neighbors/null_cats.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.neighbors/null_cats.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -5,7 +5,7 @@
     int ncats;
-    ncats = G_number_of_cats(ncb.newcell.name, ncb.newcell.mapset);
+    ncats = G_number_of_cats(ncb.newcell, G_mapset());
     G_init_cats(ncats, ncb.title, &ncb.cats);
     return 0;
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.arc/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -30,7 +30,6 @@
     RASTER_MAP_TYPE out_type, map_type;
     char *outfile;
-    char *mapset;
     char null_str[80];
     char cell_buf[300];
     int fd;
@@ -109,11 +108,7 @@
     sprintf(null_str, "-9999");
-    mapset = G_find_cell(parm.map->answer, "");
-	G_fatal_error(_("Raster map <%s> not found"), parm.map->answer);
-    fd = G_open_cell_old(parm.map->answer, mapset);
+    fd = G_open_cell_old(parm.map->answer, "");
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), parm.map->answer);
Modified: grass/trunk/raster/r.out.ascii/formspecific.c
--- grass/trunk/raster/r.out.ascii/formspecific.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.ascii/formspecific.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -126,14 +126,14 @@
 /* write the Surfer grid heading */
-int writeGSheader(FILE * fp, char *name, char *mapset)
+int writeGSheader(FILE * fp, const char *name)
     struct Cell_head region;
     char fromc[128], toc[128];
     DCELL Z_MIN, Z_MAX;
 	return 1;
     fprintf(fp, "DSAA \n");
Modified: grass/trunk/raster/r.out.ascii/localproto.h
--- grass/trunk/raster/r.out.ascii/localproto.h	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.ascii/localproto.h	2008-08-27 22:02:44 UTC (rev 33133)
@@ -4,5 +4,5 @@
 int writeMFheader(FILE *, int, int, int);
 int write_MODFLOW(int, FILE *, int, int, int, int, int);
-int writeGSheader(FILE *, char *, char *);
+int writeGSheader(FILE *, const char *);
 int write_GSGRID(int, FILE *, int, int, int, int, char *, int);
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.ascii/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -29,7 +29,6 @@
     char *name;
-    char *mapset;
     char *null_str;
     char surfer_null_str[13] = { "1.70141e+038" };
     int fd;
@@ -140,13 +139,9 @@
 	G_fatal_error(_("Use -M or -s, not both"));
     name = parm.map->answer;
-    if (!mapset)
     if (fd < 0)
@@ -177,7 +172,7 @@
     /* process the requested output format */
     if (flag.surfer->answer) {
 	if (!flag.noheader->answer) {
-	    if (writeGSheader(fp, name, mapset))
+	    if (writeGSheader(fp, name))
 		G_fatal_error(_("Unable to read fp range for <%s>"), name);
 	rc = write_GSGRID(fd, fp, nrows, ncols, out_type, dp, surfer_null_str,
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.bin/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -24,7 +24,6 @@
     char *name;
     char outfile[GNAME_MAX];
-    char *mapset;
     int null_str = 0;
     char buf[128];
     int fd;
@@ -123,12 +122,7 @@
     G_get_window(&region);
     if (fd < 0)
@@ -159,7 +153,7 @@
     /* Set up Parameters for GMT header */
     if (flag.gmt_hd->answer) {
-	G_read_fp_range(name, mapset, &range);
+	G_read_fp_range(name, "", &range);
 	G_get_fp_range_min_max(&range, &Z_MIN, &Z_MAX);
 	header.nx = region.cols;
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.mat/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -43,7 +43,7 @@
     float val_f;		/* for misc use */
     double val_d;		/* for misc use */
-    char *infile, *outfile, *mapset, *maptitle, *basename;
+    char *infile, *outfile, *maptitle, *basename;
     void *raster, *ptr;
     RASTER_MAP_TYPE map_type;
@@ -81,12 +81,7 @@
     outfile = G_malloc(strlen(basename) + 5);
     sprintf(outfile, "%s.mat", basename);
-    mapset = G_find_cell(infile, "");
-    if (mapset == NULL) {
-	G_fatal_error(_("Raster map <%s> not found"), infile);
-    fd = G_open_cell_old(infile, mapset);
+    fd = G_open_cell_old(infile, "");
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), infile);
@@ -143,7 +138,7 @@
     /********** Write title (if there is one) **********/
-    maptitle = G_get_cell_title(infile, mapset);
+    maptitle = G_get_cell_title(infile, "");
     if (strlen(maptitle) >= 1) {
 	/** write text element (map title) **/
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.png/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -49,8 +49,8 @@
     struct Option *rast, *png_file;
-    char *cellmap, *map, *p, *basename = NULL, *ofile;
-    char rastermap[1024];
+    char *rastermap;
+    char *basename = NULL, *ofile;
     unsigned char *set, *ored, *ogrn, *oblu;
     CELL *cell_buf;
     FCELL *fcell_buf;
@@ -108,15 +108,14 @@
     rast->required = YES;
     rast->multiple = NO;
     rast->gisprompt = "old,cell,Raster";
-    rast->description = "Raster file to be converted.";
+    rast->description = _("Raster file to be converted.");
     png_file = G_define_option();
     png_file->key = "output";
     png_file->type = TYPE_STRING;
-    png_file->required = NO;
+    png_file->required = YES;
     png_file->multiple = NO;
-    png_file->answer = "<rasterfilename>.png";
-    png_file->description = "Name for new PNG file. (use out=- for stdout)";
+    png_file->description = _("Name for new PNG file. (use out=- for stdout)");
     /* see what can be done to convert'em -A.Sh.
      * gscale = G_define_flag ();
@@ -132,23 +131,12 @@
 	exit(EXIT_FAILURE);
-    strncpy(rastermap, rast->answer, 1024 * sizeof(char));
+    rastermap = rast->answer;
-    if (strcmp(png_file->answer, "<rasterfilename>.png")) {
-	if (strcmp(png_file->answer, "-"))
-	    basename = G_store(png_file->answer);
-	else
-	    do_stdout = 1;
-    else {
-	map = p = rast->answer;
-	/* knock off any GRASS location suffix */
-	if ((char *)NULL != (p = strrchr(map, '@'))) {
-	    if (p != map)
-		*p = '\0';
-	basename = G_store(map);
+    if (strcmp(png_file->answer, "-") != 0)
+	basename = G_store(png_file->answer);
+    else
+	do_stdout = 1;
     if (basename) {
 	G_basename(basename, "png");
@@ -163,23 +151,17 @@
     G_message(_("rows = %d, cols = %d"), w.rows, w.cols);
     /* open raster map for reading */
-	cellmap = G_find_file2("cell", rastermap, "");
-	if (!cellmap)
-	    G_fatal_error("Couldn't find raster map %s", rastermap);
+    if ((cellfile = G_open_cell_old(rast->answer, "")) == -1)
+	G_fatal_error(_("Unable to open cellfile for <%s>"), rastermap);
-	if ((cellfile = G_open_cell_old(rast->answer, cellmap)) == -1)
-	    G_fatal_error("Not able to open cellfile for [%s]", rastermap);
     cell_buf = G_allocate_c_raster_buf();
     fcell_buf = G_allocate_f_raster_buf();
     dcell_buf = G_allocate_d_raster_buf();
-    ored = (unsigned char *)G_malloc(w.cols * sizeof(unsigned char));
-    ogrn = (unsigned char *)G_malloc(w.cols * sizeof(unsigned char));
-    oblu = (unsigned char *)G_malloc(w.cols * sizeof(unsigned char));
-    set = (unsigned char *)G_malloc(w.cols * sizeof(unsigned char));
+    ored = G_malloc(w.cols);
+    ogrn = G_malloc(w.cols);
+    oblu = G_malloc(w.cols);
+    set  = G_malloc(w.cols);
     /* open png file for writing */
@@ -239,7 +221,7 @@
 	struct Colors colors;
-	G_read_colors(rast->answer, cellmap, &colors);
+	G_read_colors(rast->answer, "", &colors);
 	rtype = G_get_raster_map_type(cellfile);
 	if (rtype == CELL_TYPE)
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.pov/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -101,7 +101,6 @@
     CELL *cell;
     char *name;
-    char *mapset;
     int fd;
     int nrows, ncols;
     double bias;
@@ -169,11 +168,8 @@
 	sscanf(parm.scaleFactor->answer, "%lf", &verticalScale);
     if (fd < 0)
@@ -208,7 +204,7 @@
     southMost = region.south;
     G_init_range(&range);
-    G_read_range(name, mapset, &range);
+    G_read_range(name, "", &range);
     G_get_range_min_max(&range, &range_min, &range_max);
     if (range.min < 0 || range.max < 0)
 	G_warning(_("Negative elevation values in input"));
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.ppm/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -34,7 +34,7 @@
     struct Option *rast, *ppm_file;
     struct Flag *gscale;
-    char *cellmap, *map, *p, ofile[1000];
+    char *map, *p, ofile[1000];
     CELL *cell_buf;
     FCELL *fcell_buf;
@@ -95,25 +95,17 @@
-	cellmap = G_find_file2("cell", rast->answer, "");
-	if (!cellmap) {
-	    G_fatal_error(_("Raster map <%s> not found"), rast->answer);
+	G_fatal_error(_("Unable to open raster map <%s>"), rast->answer);
-	if ((cellfile = G_open_cell_old(rast->answer, cellmap)) == -1) {
-	    G_fatal_error(_("Unable to open raster map <%s>"), rast->answer);
     /* open ppm file for writing */
@@ -154,7 +146,7 @@
Modified: grass/trunk/raster/r.out.ppm3/main.c
--- grass/trunk/raster/r.out.ppm3/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.ppm3/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -97,22 +97,16 @@
     for (i = 0; i < 3; i++) {
 	/* Get name of layer */
 	char *name = B[i].opt->answer;
-	char *mapset;
-	/* Get mapset of layer */
-	if (!mapset)
 	/* Open raster map */
-	if ((B[i].file = G_open_cell_old(name, mapset)) == -1)
+	if ((B[i].file = G_open_cell_old(name, "")) == -1)
 	/* Get map type (CELL/FCELL/DCELL) */
 	B[i].type = G_get_raster_map_type(B[i].file);
 	/* Get color table */
-	if (G_read_colors(name, mapset, &B[i].colors) == -1)
+	if (G_read_colors(name, "", &B[i].colors) == -1)
 	    G_fatal_error(_("Color file for <%s> not available"), name);
Modified: grass/trunk/raster/r.out.tiff/main.c
--- grass/trunk/raster/r.out.tiff/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.tiff/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -86,7 +86,7 @@
     int col, tfw, palette, tiled;
-    char *mapset, *basename, *filename;
+    char *basename, *filename;
     int red, grn, blu, mapsize, isfp;
@@ -144,22 +144,18 @@
     palette = pflag->answer;
     tfw = tflag->answer;
-    mapset = G_find_cell(inopt->answer, "");
-    if (!mapset)
-	G_fatal_error(_("Raster map <%s> not found"), inopt->answer);
-    if ((G_get_cellhd(inopt->answer, mapset, &cellhd) < 0))
+    if ((G_get_cellhd(inopt->answer, "", &cellhd) < 0))
 		      inopt->answer);
     if ((G_get_window(&cellhd) < 0))
 	G_fatal_error(_("Can't set window"));
-    G_read_colors(inopt->answer, mapset, &colors);
-    if ((isfp = G_raster_map_is_fp(inopt->answer, mapset)))
-	G_warning(_("Raster map <%s> in mapset <%s> is a floating point "
-		    "map. Decimal values will be rounded to integer!"),
-		  inopt->answer, mapset);
+    G_read_colors(inopt->answer, "", &colors);
+    if ((isfp = G_raster_map_is_fp(inopt->answer, "")))
+	G_warning(_("Raster map <%s>> is a floating point "
+		    "map. Fractional values will be rounded to integer"),
+		  inopt->answer);
     G_set_null_value_color(255, 255, 255, &colors);
     if (palette && (colors.cmax - colors.cmin > 255))
@@ -167,7 +163,7 @@
 			"than 256 colors for the available range of data"));
     cell = G_allocate_cell_buf();
-    if ((in = G_open_cell_old(inopt->answer, mapset)) < 0)
+    if ((in = G_open_cell_old(inopt->answer, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), inopt->answer);
     basename = G_store(outopt->answer);
Modified: grass/trunk/raster/r.out.vrml/main.c
--- grass/trunk/raster/r.out.vrml/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.vrml/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -30,11 +30,10 @@
     struct Option *rast_el, *rast_co, *out;
     struct Option *exag_opt;
-    char *t_mapset;
     FILEDESC elevfd = 0, colorfd = 0;
     FILE *vout = NULL;
     struct Colors colr;
-    char errbuf[100], outfile[256];
+    char outfile[GPATH_MAX];
     int shh, color_ok;
     double exag, min, max;
@@ -81,17 +80,8 @@
     G_get_set_window(&W);
-    t_mapset = NULL;
-    t_mapset = G_find_file2("cell", rast_el->answer, "");
-    if (!t_mapset) {
-	sprintf(errbuf, "Couldn't find raster map %s", rast_el->answer);
-	G_fatal_error(errbuf);
-    if ((elevfd = G_open_cell_old(rast_el->answer, t_mapset)) == -1) {
-	sprintf(errbuf, "Not able to open cellfile for [%s]",
-		rast_el->answer);
+    if ((elevfd = G_open_cell_old(rast_el->answer, "")) == -1)
+	G_fatal_error("Unable to open cellfile for <%s>", rast_el->answer);
 	CELL cmin, cmax;
@@ -100,24 +90,20 @@
 	DCELL dmin, dmax;
 	struct FPRange fp_range;
-	is_fp = G_raster_map_is_fp(rast_el->answer, t_mapset);
+	is_fp = G_raster_map_is_fp(rast_el->answer, "");
 	if (is_fp) {
-	    if (G_read_fp_range(rast_el->answer, t_mapset, &fp_range) != 1) {
-		sprintf(errbuf,
-			"Range info for [%s] not available (run r.support)\n",
-			rast_el->answer);
+	    if (G_read_fp_range(rast_el->answer, "", &fp_range) != 1) {
+		G_fatal_error(_("Range info for [%s] not available (run r.support)"),
+			      rast_el->answer);
 	    G_get_fp_range_min_max(&fp_range, &dmin, &dmax);
 	    min = dmin;
 	    max = dmax;
 	else {
-	    if (G_read_range(rast_el->answer, t_mapset, &range) == -1) {
-		sprintf(errbuf,
-			rast_el->answer);
+	    if (G_read_range(rast_el->answer, "", &range) == -1) {
+		G_fatal_error(_("Range info for <%s> not available (run r.support)"),
+			      rast_el->answer);
 	    G_get_range_min_max(&range, &cmin, &cmax);
 	    min = cmin;
@@ -126,19 +112,10 @@
     if (rast_co->answer) {
-	t_mapset = NULL;
-	t_mapset = G_find_file2("cell", rast_co->answer, "");
-	if (!t_mapset) {
-	    sprintf(errbuf, "Couldn't find raster map %s", rast_co->answer);
-	    G_warning(errbuf);
-	else if ((colorfd = G_open_cell_old(rast_co->answer, t_mapset)) == -1) {
-		    rast_co->answer);
+	if ((colorfd = G_open_cell_old(rast_co->answer, "")) == -1)
+	    G_warning(_("Unable to open cellfile for <%s>"), rast_co->answer);
 	else {
-	    G_read_colors(rast_co->answer, t_mapset, &colr);
+	    G_read_colors(rast_co->answer, "", &colr);
 	    color_ok = 1;
@@ -162,8 +139,7 @@
 	/* open file for writing VRML */
 	G_message(_("Opening %s for writing... "), outfile);
 	if (NULL == (vout = fopen(outfile, "w"))) {
-	    sprintf(errbuf, "Couldn't open output file %s", outfile);
+	    G_fatal_error(_("Unable to open output file <%s>"), outfile);
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c	2008-08-27 21:59:09 UTC (rev 33132)
+++ grass/trunk/raster/r.out.vtk/main.c	2008-08-27 22:02:44 UTC (rev 33133)
@@ -31,101 +31,7 @@
 double x_extent;
 double y_extent;
-/*local protos */
-static void check_input_maps(void);
-/* Check the input maps **************************************************** */
-void check_input_maps(void)
-    char *mapset = NULL;
-    int i;
-    /*Check for elevation map */
-    if (param.elevationmap->answer) {
-	mapset = G_find_cell2(param.elevationmap->answer, "");
-			  param.elevationmap->answer);
-	    exit(EXIT_FAILURE);
-    /*Check for normal input map */
-    if (param.input->answers != NULL) {
-	for (i = 0; param.input->answers[i] != NULL; i++) {
-	    mapset = NULL;
-	    mapset = G_find_cell2(param.input->answers[i], "");
-			      param.input->answers[i]);
-    /*RGB raster maps */
-    if (param.rgbmaps->answers != NULL) {
-	if (param.rgbmaps->answers[0] != NULL &&
-	    param.rgbmaps->answers[1] != NULL &&
-	    param.rgbmaps->answers[2] != NULL) {
-	    /*Loop over all input maps! */
-	    for (i = 0; i < 3; i++) {
-		mapset = NULL;
-		mapset = G_find_cell2(param.rgbmaps->answers[i], "");
-		    G_fatal_error(_("RGB raster map <%s> not found"),
-				  param.rgbmaps->answers[i]);
-	else {
-	    G_fatal_error(_("Cannot create RGB data, please provide three maps [r,g,b]"));
-    /*Vector raster maps */
-    if (param.vectmaps->answers != NULL) {
-	if (param.vectmaps->answers[0] != NULL &&
-	    param.vectmaps->answers[1] != NULL &&
-	    param.vectmaps->answers[2] != NULL) {
-		mapset = NULL;
-		mapset = G_find_cell2(param.vectmaps->answers[i], "");
-		    G_fatal_error(_("Vector cell map <%s> not found"),
-				  param.vectmaps->answers[i]);
-	else {
-	    G_fatal_error(_("Cannot create vector data, please provide three maps [x,y,z]"));
-    /*Give a warning if no output cell/point or rgb data was specified */
-    if (param.input->answers == NULL && param.rgbmaps->answers == NULL &&
-	param.vectmaps->answers == NULL) {
-	G_warning
-	    ("No g3d data, RGB or vector maps are provided! Will only write the geometry.");
-    return;
 /* MAIN ******************************************************************** */
@@ -135,7 +41,7 @@
     FILE *fp = NULL;
     int i = 0, polytype = 0;
-    char *null_value, *mapset;
+    char *null_value;
     int out_type;
     int fd;			/*Normale maps ;) */
     int rgbfd[3];
@@ -171,9 +77,6 @@
     else
 	fp = stdout;
-    /*Check the input maps */
-    check_input_maps();
     /*Correct the coordinates, so the precision of VTK is not hurt :( */
     if (param.coorcorr->answer) {
 	/*Get the default region for coordiante correction */
@@ -218,10 +121,8 @@
 	G_debug(3, _("Open Raster file %s"), param.elevationmap->answer);
-	fd = G_open_cell_old(param.elevationmap->answer, mapset);
+	fd = G_open_cell_old(param.elevationmap->answer, "");
 	if (fd < 0)
@@ -283,11 +184,8 @@
 	    G_debug(3, _("Open Raster file %s"), param.input->answers[i]);
-	    mapset = NULL;
-	    fd = G_open_cell_old(param.input->answers[i], mapset);
+	    fd = G_open_cell_old(param.input->answers[i], "");
 	    if (fd < 0)
@@ -311,12 +209,8 @@
-		mapset = NULL;
-		rgbfd[i] = G_open_cell_old(param.rgbmaps->answers[i], mapset);
+		rgbfd[i] = G_open_cell_old(param.rgbmaps->answers[i], "");
 		if (rgbfd[i] < 0)
@@ -357,13 +251,9 @@
-		mapset = NULL;
 		vectfd[i] =
-		    G_open_cell_old(param.vectmaps->answers[i], mapset);
+		    G_open_cell_old(param.vectmaps->answers[i], "");
 		if (vectfd[i] < 0)
