[GRASS-SVN] r33161 - in grass/trunk/vector: v.buffer v.build v.build.polylines v.category v.class v.clean v.db.connect v.db.select v.distance v.drape v.edit v.extract v.extrude v.generalize v.hull v.info
Fri Aug 29 18:27:02 EDT 2008
Author: glynn
Date: 2008-08-29 18:27:02 -0400 (Fri, 29 Aug 2008)
New Revision: 33161
   grass/trunk/vector/v.buffer/main.c
   grass/trunk/vector/v.build.polylines/main.c
   grass/trunk/vector/v.build/main.c
   grass/trunk/vector/v.category/main.c
   grass/trunk/vector/v.class/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.db.connect/main.c
   grass/trunk/vector/v.db.select/main.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.edit/main.c
   grass/trunk/vector/v.extract/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.info/main.c
Remove explicit mapset references and G_find_* calls
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.buffer/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -232,7 +232,6 @@
     struct Map_info In, Out;
     struct line_pnts *Points, *BPoints;
     struct line_cats *Cats, *BCats;
-    char *mapset;
     struct GModule *module;
     struct Option *in_opt, *out_opt, *type_opt, *buffer_opt, *tolerance_opt,
 	*bufcol_opt, *scale_opt, *debug_opt, *field_opt;
@@ -362,12 +361,8 @@
     BCats = Vect_new_cats_struct();
     /* open input vector */
-    if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
-	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
     Vect_set_open_level(2);
-    Vect_open_old(&In, in_opt->answer, mapset);
+    Vect_open_old(&In, in_opt->answer, "");
     Vect_set_fatal_error(GV_FATAL_PRINT);
     if (0 > Vect_open_new(&Out, out_opt->answer, 0)) {
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.build/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -79,11 +79,6 @@
     /* build topology */
     if (build) {
-	/* open input vector */
-	if (G_find_vector2(map_opt->answer, G_mapset()) == NULL)
-	    G_fatal_error(_("Vector map <%s> not found in the current mapset"),
-			  map_opt->answer);
 	Vect_set_open_level(1);
 	Vect_open_old(&Map, map_opt->answer, G_mapset());
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.build.polylines/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -101,7 +101,6 @@
     int nlines, type;
     int write_cats;
-    char *mapset;
     int start_type;
     /*  Initialize the GIS calls */
@@ -137,11 +136,8 @@
 				 GV_FATAL_EXIT);
     /* Open binary vector map at level 2 */
-    mapset = G_find_vector2(input->answer, "");
-    if (mapset == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), input->answer);
-    Vect_open_old(&map, input->answer, mapset);
+    Vect_open_old(&map, input->answer, "");
     /* Open new vector */
     G_find_vector2(output->answer, "");
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.category/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -180,16 +180,12 @@
 	G_fatal_error(_("2 layers must be specified"));
     if ((option != O_REP) && (option != O_PRN)) {
-	if (out_opt->answer == NULL) {
+	if (out_opt->answer == NULL)
 	    G_fatal_error(_("Output vector wasn't entered"));
 	Vect_check_input_output_name(in_opt->answer, out_opt->answer,
 				     GV_FATAL_EXIT);
-    else {
-	if (G_find_vector2(in_opt->answer, "") == NULL)
     Points = Vect_new_line_struct();
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.class/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -29,7 +29,6 @@
     struct Option *map_opt, *field_opt, *col_opt, *where_opt;
     struct Option *algo_opt, *nbclass_opt;
     struct Flag *shell_flag;
-    char *mapset;
     struct Map_info Map;
     struct field_info *Fi;
     dbDriver *Driver;
@@ -91,11 +90,8 @@
     ofield = atoi(field_opt->answer);
-    if ((mapset = G_find_vector2(map_opt->answer, "")) == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), map_opt->answer);
-    Vect_open_old(&Map, map_opt->answer, mapset);
+    Vect_open_old(&Map, map_opt->answer, "");
     /* Read attributes */
     db_CatValArray_init(&Cvarr);
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.clean/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -26,7 +26,6 @@
     struct Map_info In, Out, Err, *pErr;
     int i, otype, with_z;
-    char *mapset;
     struct Option *in_opt, *out_opt, *type_opt, *tool_opt, *thresh_opt,
 	*err_opt;
@@ -237,16 +236,11 @@
     G_message(SEP);
     /* Input vector may be both on level 1 and 2. Level 2 is necessary for
      * virtual centroids (shapefile/OGR) and level 1 is better if input is too big
      * and build in previous module (like v.in.ogr or other call to v.clean) would take
      * a long time */
-    level = Vect_open_old(&In, in_opt->answer, mapset);
+    level = Vect_open_old(&In, in_opt->answer, "");
     with_z = Vect_is_3d(&In);
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.db.connect/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -30,7 +30,7 @@
 int main(int argc, char **argv)
-    char *input, *mapset;
+    char *input;
     struct Option *inopt, *dbdriver, *dbdatabase, *dbtable, *field_opt,
 	*dbkey;
@@ -112,24 +112,19 @@
-    /* set input vector map name and mapset */
+    /* set input vector map name */
     input = inopt->answer;
-    mapset = G_find_vector2(input, "");
-    if (!mapset)
-	G_fatal_error(_("Vector map <%s> not found"), input);
     if (field_opt->answer)
     else
 	field = 1;
-    G_debug(3, "Mapset = %s", mapset);
     if (print->answer && shell_print->answer)
 	G_fatal_error(_("Please choose only one print style"));
     if (print->answer || shell_print->answer || columns->answer)
-	Vect_open_old(&Map, inopt->answer, mapset);
+	Vect_open_old(&Map, inopt->answer, "");
     else {
 	if (Vect_open_update_head(&Map, inopt->answer, G_mapset()) < 1)
 	    G_fatal_error(_("Unable to modify vector map stored in other mapset"));
@@ -140,13 +135,13 @@
 	num_dblinks = Vect_get_num_dblinks(&Map);
 	if (num_dblinks <= 0)
 	    G_fatal_error(_("Database connection for map <%s> is not defined in DB file"),
-			  G_fully_qualified_name(input, mapset));
+			  input);
 	else {			/* num_dblinks > 0 */
 	    if (print->answer || shell_print->answer) {
 		if (!(shell_print->answer)) {
 		    G_message(_("Vector map <%s> is connected by:"),
+			      input);
 		for (i = 0; i < num_dblinks; i++) {
 		    if ((fi = Vect_get_dblink(&Map, i)) == NULL)
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.db.select/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -41,7 +41,6 @@
     int field, ncols, col, more;
-    char *mapset;
     char query[1024];
     struct ilist *list_lines;
@@ -115,20 +114,14 @@
     db_init_string(&value_string);
-    if ((mapset = G_find_vector2(map_opt->answer, "")) == NULL) {
-    if (!r_flag->answer) {
-	Vect_open_old_head(&Map, map_opt->answer, mapset);
+    if (!r_flag->answer)
+	Vect_open_old_head(&Map, map_opt->answer, "");
     else {
-	if (2 > Vect_open_old(&Map, map_opt->answer, mapset)) {
+	if (2 > Vect_open_old(&Map, map_opt->answer, "")) {
 	    Vect_close(&Map);
 	    G_fatal_error(_("Unable to open vector map <%s> at topology level. "
 			   "Flag '%c' requires topology level."),
-			  G_fully_qualified_name(map_opt->answer, mapset),
-			  r_flag->key);
+			  map_opt->answer, r_flag->key);
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.distance/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -74,7 +74,6 @@
     int i, j, k;
     int print_as_matrix;	/* only for all */
     int all;			/* calculate from each to each within the threshold */
-    char *mapset;
     struct Option *from_opt, *to_opt, *from_type_opt, *to_type_opt,
 	*from_field_opt, *to_field_opt;
@@ -294,20 +293,12 @@
 	G_fatal_error(_("Not enough column names"));
     /* Open 'from' vector */
-    if ((mapset = G_find_vector2(from_opt->answer, "")) == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), from_opt->answer);
-    if (!print_flag->answer && strcmp(mapset, G_mapset()) != 0)
-	G_fatal_error(_("Vector map <%s> is not in user mapset and cannot be updated"),
-		      from_opt->answer);
-    Vect_open_old(&From, from_opt->answer, mapset);
+    Vect_open_old(&From, from_opt->answer, G_mapset());
     /* Open 'to' vector */
-    mapset = G_find_vector2(to_opt->answer, "");
-    Vect_open_old(&To, to_opt->answer, mapset);
+    Vect_open_old(&To, to_opt->answer, "");
     /* Open output vector */
     if (out_opt->answer) {
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.drape/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -136,13 +136,8 @@
 				 GV_FATAL_EXIT);
-    mapset = G_find_vector2(in_opt->answer, "");
-    if (!mapset) {
     /* checks
        does the elevation raster cover the entire are of the vector map?
        does the current region include the entire input vector map ?
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.edit/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -27,7 +27,6 @@
     struct Map_info **BgMap;	/* backgroud vector maps */
     int nbgmaps;		/* number of registrated background maps */
-    char *mapset;
     enum mode action_mode;
     FILE *ascii;
@@ -104,17 +103,10 @@
     else {			/* open selected vector file */
-	mapset = G_find_vector2(params.map->answer, G_mapset());
-	if (mapset == NULL) {
-			  params.map->answer);
-	else if (action_mode == MODE_ADD) {	/* write */
-	    ret = Vect_open_update(&Map, params.map->answer, mapset);
-	else {			/* read-only -- select features */
-	    ret = Vect_open_old(&Map, params.map->answer, mapset);
+	if (action_mode == MODE_ADD)	/* write */
+	    ret = Vect_open_update(&Map, params.map->answer, G_mapset());
+	else			/* read-only -- select features */
+	    ret = Vect_open_old(&Map, params.map->answer, G_mapset());
 	if (ret < 2)
 	    G_fatal_error(_("Unable to open vector map <%s> at topological level %d"),
@@ -126,37 +118,28 @@
     /* open backgroud maps */
     if (params.bmaps->answer) {
 	i = 0;
-	char *bmap;
 	while (params.bmaps->answers[i]) {
-	    bmap = params.bmaps->answers[i];
-	    mapset = G_find_vector2(bmap, "");
+	    const char *bmap = params.bmaps->answers[i];
+	    const char *mapset = G_find_vector2(bmap, "");
+	    if (!mapset)
 		G_fatal_error(_("Vector map <%s> not found"), bmap);
-	    if (strcmp
-		(G_fully_qualified_name
-		 ((const char *)params.map->answer, (const char *)G_mapset()),
-		 G_fully_qualified_name((const char *)bmap,
-					(const char *)mapset)) == 0) {
+	    if (strcmp(
+		    G_fully_qualified_name(params.map->answer, G_mapset()),
+		    G_fully_qualified_name(bmap, mapset)) == 0) {
 		G_fatal_error(_("Unable to open vector map <%s> as the backround map. "
 			       "It is given as vector map to be edited."),
 			      bmap);
 	    nbgmaps++;
-	    BgMap =
-		(struct Map_info **)G_realloc((void *)BgMap,
-					      nbgmaps *
-					      sizeof(struct Map_info *));
+	    BgMap = (struct Map_info **)G_realloc(
+		BgMap, nbgmaps * sizeof(struct Map_info *));
 	    BgMap[nbgmaps - 1] =
 		(struct Map_info *)G_malloc(sizeof(struct Map_info));
-	    if (Vect_open_old(BgMap[nbgmaps - 1], bmap, mapset) == -1) {
-		G_fatal_error(_("Unable to open vector map <%s>"),
-			      G_fully_qualified_name(bmap, mapset));
-	    G_verbose_message(_("Background vector map <%s> registered"),
+	    if (Vect_open_old(BgMap[nbgmaps - 1], bmap, "") == -1)
+		G_fatal_error(_("Unable to open vector map <%s>"), bmap);
+	    G_verbose_message(_("Background vector map <%s> registered"), bmap);
 	    i++;
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.extract/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -53,7 +53,7 @@
     int **ocats, *nocats, nfields, *fields;
     int dissolve = 0, x, y, type_only;
     char buffr[1024], text[80];
-    char *input, *output, *mapset;
+    char *input, *output;
     struct Option *inopt, *outopt, *fileopt, *newopt, *typopt, *listopt,
 	*fieldopt;
@@ -139,12 +139,7 @@
-    if (!mapset)
     /* set output vector map name */
     output = outopt->answer;
@@ -162,7 +157,7 @@
     /* Do initial read of input file */
-    Vect_open_old(&In, input, mapset);
+    Vect_open_old(&In, input, "");
     /* Open output file */
     Vect_open_new(&Out, output, Vect_is_3d(&In));
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.extrude/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -34,7 +34,6 @@
 int main(int argc, char *argv[])
-    char *mapset;
     struct Option *old, *new, *zshift, *height, *elevation, *hcolumn,
 	*type_opt, *field_opt;
     struct Flag *t_flag;
@@ -138,8 +137,6 @@
     Vect_check_input_output_name(old->answer, new->answer, GV_FATAL_EXIT);
-    if ((mapset = G_find_vector2(old->answer, "")) == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), old->answer);
     /* vector setup */
@@ -149,7 +146,7 @@
     Vect_open_new(&Out, new->answer, WITH_Z);
     /* opening old vector */
-    Vect_open_old(&In, old->answer, mapset);
+    Vect_open_old(&In, old->answer, "");
     Vect_hist_copy(&In, &Out);
     Vect_hist_command(&Out);
@@ -173,12 +170,8 @@
 	/* raster setup */
 	G_get_window(&window);
-	/* check for the elev raster, and check for error condition */
-	if ((mapset = G_find_cell2(elevation->answer, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"), elevation->answer);
 	/* open the elev raster, and check for error condition */
-	if ((fdrast = G_open_cell_old(elevation->answer, mapset)) < 0)
+	if ((fdrast = G_open_cell_old(elevation->answer, "")) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"),
 			  elevation->answer);
@@ -340,7 +333,7 @@
     char *comment;
     G_asprintf(&comment, "Generated by %s from vector map <%s>",
-	       G_program_name(), G_fully_qualified_name(old->answer, mapset));
+	       G_program_name(), old->answer);
     Vect_set_comment(&Out, comment);
     G_free(comment);
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.generalize/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -46,7 +46,6 @@
     static struct line_pnts *Points;
     struct line_cats *Cats;
     int i, type, iter;
-    char *mapset;
     struct GModule *module;	/* GRASS module for parsing arguments */
     struct Option *map_in, *map_out, *thresh_opt, *method_opt,
 	*look_ahead_opt;
@@ -297,14 +296,10 @@
     Vect_check_input_output_name(map_in->answer, map_out->answer,
 				 GV_FATAL_EXIT);
-    if ((mapset = G_find_vector2(map_in->answer, "")) == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), map_in->answer);
-    if (1 > Vect_open_old(&In, map_in->answer, mapset))
-		      G_fully_qualified_name(map_in->answer, mapset));
+    if (Vect_open_old(&In, map_in->answer, "") < 1)
+	G_fatal_error(_("Unable to open vector map <%s>"), map_in->answer);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.hull/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -271,7 +271,6 @@
     struct Flag *all, *flat;
     struct Cell_head window;
-    char *mapset;
     char *sitefile;
@@ -310,15 +309,11 @@
     sitefile = input->answer;
-    mapset = G_find_vector2(sitefile, "");
-	G_fatal_error(_("Vector map <%s> not found"), sitefile);
     Vect_check_input_output_name(input->answer, output->answer,
 				 GV_FATAL_EXIT);
     /* open site file */
-    if (Vect_open_old(&Map, sitefile, mapset) < 0)
+    if (Vect_open_old(&Map, sitefile, "") < 0)
 	G_fatal_error(_("Cannot open vector map <%s>"), sitefile);
     /* load site coordinates */
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2008-08-29 20:57:26 UTC (rev 33160)
+++ grass/trunk/vector/v.info/main.c	2008-08-29 22:27:02 UTC (rev 33161)
@@ -100,7 +100,7 @@
-    Vect_open_old_head(&Map, in_opt->answer, mapset);
+    Vect_open_old_head(&Map, in_opt->answer, "");
     with_z = Vect_is_3d(&Map);
     v_head = Map.head;
