[GRASS-SVN] r34795 - in grass/trunk: imagery/i.cluster lib/imagery
Mon Dec 8 06:47:01 EST 2008
Author: martinl
Date: 2008-12-08 06:47:00 -0500 (Mon, 08 Dec 2008)
New Revision: 34795
   grass/trunk/imagery/i.cluster/checkpt.c
   grass/trunk/imagery/i.cluster/main.c
   grass/trunk/imagery/i.cluster/open_files.c
   grass/trunk/lib/imagery/sigfile.c
i.cluster: message standardization
       more guisections
imagerylib: allow fully qualified group name + doxygenization (sigfice.c)
	(merge from devbr6, r34794)
Modified: grass/trunk/imagery/i.cluster/checkpt.c
--- grass/trunk/imagery/i.cluster/checkpt.c	2008-12-08 11:44:30 UTC (rev 34794)
+++ grass/trunk/imagery/i.cluster/checkpt.c	2008-12-08 11:47:00 UTC (rev 34795)
@@ -37,7 +37,7 @@
 	if (verbose) {
 	    cur_time = time(NULL);
 	    elapsed_time = cur_time - start_time;
-	    G_message(_("Iteration %d: %% Convergence: %.2f (%s elapsed, %s left)"),
+	    G_message(_("Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"),
 		      X->iteration, (double)X->percent_stable,
 		      print_time(elapsed_time),
 		      print_time(iters * elapsed_time / (X->iteration + 1) -
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c	2008-12-08 11:44:30 UTC (rev 34794)
+++ grass/trunk/imagery/i.cluster/main.c	2008-12-08 11:47:00 UTC (rev 34795)
@@ -11,7 +11,7 @@
  *               Glynn Clements <glynn gclements.plus.com>,
  *               Jan-Oliver Wagner <jan intevation.de>
  * PURPOSE:      builds pixel clusters based on multi-image pixel values
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -77,7 +77,7 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("imagery");
+    module->keywords = _("imagery, classification, signatures");
     module->label =
 	_("Generates spectral signatures for land cover "
 	  "types in an image using a clustering algorithm.");
@@ -86,19 +86,17 @@
 	  "to generate an unsupervised image classification.");
     parm.group_name = G_define_standard_option(G_OPT_I_GROUP);
-    parm.group_name->description =
-	_("Group of imagery files to be clustered");
     parm.subgroup_name = G_define_option();
     parm.subgroup_name->key = "subgroup";
     parm.subgroup_name->type = TYPE_STRING;
     parm.subgroup_name->required = YES;
-    parm.subgroup_name->description = _("Subgroup name in the above group");
+    parm.subgroup_name->description = _("Name of subgroup in the above group");
     parm.out_sig = G_define_standard_option(G_OPT_F_OUTPUT);
     parm.out_sig->key = "sigfile";
     parm.out_sig->required = YES;
-    parm.out_sig->description = _("File to contain result signatures");
+    parm.out_sig->description = _("Name for output file containing result signatures");
     parm.class = G_define_option();
     parm.class->key = "classes";
@@ -106,11 +104,12 @@
     parm.class->options = "1-255";
     parm.class->required = YES;
     parm.class->description = _("Initial number of classes");
+    parm.class->guisection = _("Settings");
     parm.seed_sig = G_define_standard_option(G_OPT_F_INPUT);
     parm.seed_sig->key = "seed";
     parm.seed_sig->required = NO;
-    parm.seed_sig->description = _("File containing initial signatures");
+    parm.seed_sig->description = _("Name of file containing initial signatures");
     parm.sample_interval = G_define_option();
     parm.sample_interval->key = "sample";
@@ -119,6 +118,7 @@
     parm.sample_interval->required = NO;
     parm.sample_interval->description =
 	_("Sampling intervals (by row and col); default: ~10,000 pixels");
+    parm.sample_interval->guisection = _("Settings");
     parm.iterations = G_define_option();
     parm.iterations->key = "iterations";
@@ -126,6 +126,7 @@
     parm.iterations->required = NO;
     parm.iterations->description = _("Maximum number of iterations");
     parm.iterations->answer = "30";
+    parm.iterations->guisection = _("Settings");
     parm.convergence = G_define_option();
     parm.convergence->key = "convergence";
@@ -134,6 +135,7 @@
     parm.convergence->options = "0-100";
     parm.convergence->description = _("Percent convergence");
     parm.convergence->answer = "98.0";
+    parm.convergence->guisection = _("Settings");
     parm.separation = G_define_option();
     parm.separation->key = "separation";
@@ -141,6 +143,7 @@
     parm.separation->required = NO;
     parm.separation->description = _("Cluster separation");
     parm.separation->answer = "0.0";
+    parm.separation->guisection = _("Settings");
     parm.min_size = G_define_option();
     parm.min_size->key = "min_size";
@@ -148,11 +151,12 @@
     parm.min_size->required = NO;
     parm.min_size->description = _("Minimum number of pixels in a class");
     parm.min_size->answer = "17";
+    parm.min_size->guisection = _("Settings");
     parm.report_file = G_define_standard_option(G_OPT_F_OUTPUT);
     parm.report_file->key = "reportfile";
     parm.report_file->required = NO;
-    parm.report_file->description = _("Output file to contain final report");
+    parm.report_file->description = _("Name for output file containing final report");
     flag.q = G_define_flag();
     flag.q->key = 'q';
@@ -175,10 +179,8 @@
     if (sscanf(parm.class->answer, "%d", &maxclass) != 1 || maxclass < 1
 	|| maxclass > 255) {
-	G_warning(_("\n<%s> -- illegal number of initial classes"),
-		  parm.class->answer);
-	G_usage();
-	exit(EXIT_FAILURE);
+	G_fatal_error(_("Illegal number of initial classes (%s)"),
+		      parm.class->answer);
     insigfile = parm.seed_sig->answer;
@@ -188,10 +190,8 @@
 	    (parm.sample_interval->answer, "%d,%d", &sample_rows,
 	     &sample_cols) != 2 || sample_rows < 1 || sample_cols < 1 ||
 	    sample_rows > nrows || sample_cols > ncols) {
-	    G_warning(_("\n<%s> -- illegal value(s) of sample intervals"),
-		      parm.sample_interval->answer);
-	    G_usage();
+	    G_fatal_error(_("Illegal value(s) of sample intervals (%s)"),
+			  parm.sample_interval->answer);
     else {
@@ -204,32 +204,24 @@
     if (sscanf(parm.iterations->answer, "%d", &iters) != 1 || iters < 1) {
-	G_warning(_("\n<%s> -- illegal value of iterations"),
-		  parm.iterations->answer);
-	G_usage();
+	G_fatal_error(_("Illegal value of iterations (%s>)"),
+		      parm.iterations->answer);
     if (sscanf(parm.convergence->answer, "%lf", &conv) != 1 || conv < 0.0 ||
 	conv > 100.0) {
-	G_warning(_("\n<%s> -- illegal value of convergence"),
-		  parm.convergence->answer);
-	G_usage();
+	G_fatal_error(_("Illegal value of convergence (%s)"),
+		      parm.convergence->answer);
     if (sscanf(parm.separation->answer, "%lf", &sep) != 1 || sep < 0.0) {
-	G_warning(_("\n<%s> -- illegal value of separation"),
-		  parm.separation->answer);
-	G_usage();
+	G_fatal_error(_("Illegal value of separation (%s)"),
+		      parm.separation->answer);
     if (sscanf(parm.min_size->answer, "%d", &mcs) != 1 || mcs < 2) {
-	G_warning(_("\n<%s> -- illegal value of min_size"),
-		  parm.min_size->answer);
-	G_usage();
+	G_fatal_error(_("Illegal value of min_size (%s)"),
+		      parm.min_size->answer);
     verbose = !flag.q->answer;
@@ -239,9 +231,8 @@
     else
 	report = fopen(reportfile, "w");
     if (report == NULL) {
-	G_warning(_("Can't creat reportfile: "));
-	perror(reportfile);
+	G_fatal_error(_("Unable to create report file <%s>"),
+		      reportfile);
     open_files();
@@ -291,33 +282,33 @@
     I_cluster_begin(&C, ref.nfiles);
     count = 0;
-    if (verbose)
-	G_message(_("Reading image ... "));
+    G_message(_("Reading raster maps..."));
     for (row = sample_rows - 1; row < nrows; row += sample_rows) {
-	if (verbose)
-	    G_percent(row, nrows, 2);
+	G_percent(row, nrows, 2);
 	for (n = 0; n < ref.nfiles; n++)
 	    if (G_get_d_raster_row(cellfd[n], cell[n], row) < 0)
+		G_fatal_error(_("Unable to read raster map row %d"),
+			      row);
 	for (col = sample_cols - 1; col < ncols; col += sample_cols) {
 	    count++;
 		x[n] = cell[n][col];
 	    if (I_cluster_point(&C, x) < 0)
-		G_fatal_error(_("Out of Memory. Please run again and choose a smaller sample size"));
+		G_fatal_error(_("Out of Memory. Please run again and choose a "
+				"smaller sample size."));
-    if (verbose)
-	G_percent(nrows, nrows, 2);
+    G_percent(nrows, nrows, 2);
     fprintf(report, _("Sample size: %d points\n"), C.npoints);
     fprintf(report, "\n");
     if (count < 2)
 	G_fatal_error(_("Not enough sample points. Please run again and "
-			"choose a larger sample size"));
+			"choose a larger sample size."));
     if (C.npoints < 2)
 	G_fatal_error(_("Not enough non-zero sample data points. Check "
-			"your current region (and mask)"));
+			"your current region (and mask)."));
     for (n = 0; n < ref.nfiles; n++) {
 	G_free(cell[n]);
@@ -341,7 +332,7 @@
 	fclose(fd);
     else {
-	G_fatal_error(_("Could not write signature file <%s> for group "
+	G_fatal_error(_("Unable to create signature file <%s> for group "
 			"<%s>, subsgroup <%s>"), outsigfile, group, subgroup);
@@ -352,6 +343,9 @@
     fprintf(report, _("\n######## CLUSTER END (%s) ########\n"), G_date());
     fclose(report);
+    G_done_msg(_("File <%s> created."),
+	       outsigfile);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.cluster/open_files.c
--- grass/trunk/imagery/i.cluster/open_files.c	2008-12-08 11:44:30 UTC (rev 34794)
+++ grass/trunk/imagery/i.cluster/open_files.c	2008-12-08 11:47:00 UTC (rev 34795)
@@ -14,11 +14,12 @@
     G_strip(group);
     if (!I_find_group(group))
-	G_fatal_error(_("\n group <%s> not found"), group);
+	G_fatal_error(_("Group <%s> not found"), group);
     G_strip(subgroup);
     if (!I_find_subgroup(group, subgroup))
-	G_fatal_error(_("subgroup <%s> not found"), subgroup);
+	G_fatal_error(_("Subgroup <%s> in group <%s> not found"),
+		      subgroup, group);
     I_free_group_ref(&ref);
     I_get_subgroup_ref(group, subgroup, &ref);
@@ -34,14 +35,15 @@
     if (missing)
-	exit(1);
+	G_fatal_error(_("No raster maps found"));
     if (ref.nfiles <= 1) {
 	if (ref.nfiles <= 0)
-	    G_warning(_("Subgroup [%s] doesn't have any files"), subgroup);
+	    G_warning(_("Subgroup <%s> doesn't have any raster maps"),
+		      subgroup);
 	else
-	    G_warning(_("Subgroup [%s] only has 1 file"), subgroup);
-	G_fatal_error(_("The subgroup must have at least 2 files to run %s"),
-		      G_program_name());
+	    G_warning(_("Subgroup <%s> only has 1 raster map"), subgroup);
+	G_fatal_error(_("Subgroup must have at least 2 raster maps"));
     cell = (DCELL **) G_malloc(ref.nfiles * sizeof(DCELL *));
@@ -51,20 +53,21 @@
 	name = ref.file[n].name;
 	mapset = ref.file[n].mapset;
 	if ((cellfd[n] = G_open_cell_old(name, mapset)) < 0)
-	    G_fatal_error(_("Unable to proceed"));
+	    G_fatal_error(_("Unable to open raster map <%s>"),
+			  G_fully_qualified_name(name, mapset));
     I_init_signatures(&in_sig, ref.nfiles);
     if (insigfile) {
 	fd = I_fopen_signature_file_old(group, subgroup, insigfile);
 	if (fd == NULL)
-	    G_fatal_error(_("Can't open seed signature file <%s>"),
+	    G_fatal_error(_("Unable to open seed signature file <%s>"),
 			  insigfile);
 	n = I_read_signatures(fd, &in_sig);
 	fclose(fd);
 	if (n < 0)
-	    G_fatal_error(_("Can't read signature file <%s>"),
+	    G_fatal_error(_("Unable to read signature file <%s>"),
 			  insigfile);
 	if (in_sig.nsigs > 255)
Modified: grass/trunk/lib/imagery/sigfile.c
--- grass/trunk/lib/imagery/sigfile.c	2008-12-08 11:44:30 UTC (rev 34794)
+++ grass/trunk/lib/imagery/sigfile.c	2008-12-08 11:47:00 UTC (rev 34795)
@@ -1,38 +1,75 @@
+   \file sigfile.c
+   \brief Imagery Library - Signature file functions.
+   (C) 2001-2008 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2). Read the file COPYING that comes with GRASS for details.
+   \author USA CERL
 #include <string.h>
 #include <grass/imagery.h>
+   \brief Create signature file
+   \param group group name
+   \param subgroup subgroup name in given group
+   \param name signature filename
+   \return pointer to FILE*
+   \return NULL on error
 FILE *I_fopen_signature_file_new(const char *group,
 				 const char *subgroup, const char *name)
-    char element[GNAME_MAX * 2];
+    char element[GPATH_MAX];
+    char group_name[GNAME_MAX], group_mapset[GMAPSET_MAX];
     FILE *fd;
+    if (!G__name_is_fully_qualified(group, group_name, group_mapset)) {
+	strcpy(group_name, group);
     /* create sigset directory */
-    sprintf(element, "%s/subgroup/%s/sig", group, subgroup);
+    sprintf(element, "%s/subgroup/%s/sig", group_name, subgroup);
     G__make_mapset_element_misc("group", element);
     sprintf(element, "subgroup/%s/sig/%s", subgroup, name);
-    fd = G_fopen_new_misc("group", element, group);
-    if (fd == NULL)
-	G_warning
-	    ("unable to create signature file %s for subgroup %s of group %s",
-	     name, subgroup, group);
+    fd = G_fopen_new_misc("group", element, group_name);
     return fd;
+   \brief Open signature file
 FILE *I_fopen_signature_file_old(const char *group,
     FILE *fd;
-    fd = G_fopen_old_misc("group", element, group, G_mapset());
-    if (fd == NULL)
-	G_warning
-	    ("unable to open signature file %s for subgroup %s of group [%s in %s]",
-	     name, subgroup, group, G_mapset());
+    fd = G_fopen_old_misc("group", element, group_name, G_mapset());
     return fd;
