[GRASS-SVN] r34857 - grass-addons/raster/r.pack
Sat Dec 13 23:15:32 EST 2008
Author: hamish
Date: 2008-12-13 23:15:32 -0500 (Sat, 13 Dec 2008)
New Revision: 34857
Added:
   grass-addons/raster/r.pack/r.unpack2
new version of r.unpack copying elements instead of using r.in.mat
Copied: grass-addons/raster/r.pack/r.unpack2 (from rev 34846, grass-addons/raster/r.pack/r.unpack)
--- grass-addons/raster/r.pack/r.unpack2	                        (rev 0)
+++ grass-addons/raster/r.pack/r.unpack2	2008-12-14 04:15:32 UTC (rev 34857)
@@ -0,0 +1,162 @@
+#!/bin/sh
+#  r.unpack   --  unpack up a raster map packed with r.pack:
+#     tar+gzip'd map elements => GRASS 6 mapset structure
+#   (c) 2004-2008 GRASS Development Team
+#   AUTHOR: Hamish Bowman, Otago University, New Zealand
+#   This program is free software under the GNU General Public
+#   License (>=v2). Read the file COPYING that comes with GRASS
+#   for details.
+#%Module
+#%  description: UnPacks a raster map packed with r.pack
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old_file,file,input
+#% description: Name of an existing pack file
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Output raster map (default: taken from input file internals)
+#% required : no
+#%end
+#%flag
+#%  key: o
+#%  description: Override projection check (use current location's projection)
+#%end
+if [ -z "$GISBASE" ] ; then
+   echo "You must be in GRASS GIS to run this program." >&2
+   exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+   exec g.parser "$0" "$@"
+fi
+# check for tar,gzip
+for PRGM in tar gzip ; do
+   if [ -z "`which $PRGM`" ] ; then
+      g.message -e "$PRGM must be installed to use this program."
+      exit 1
+   fi
+done
+if [ -z "$GRASS_OVERWRITE" ] ; then
+   GRASS_OVERWRITE=0
+fi
+if [ ! -e "$GIS_OPT_INPUT" ] ; then
+   g.message -e "File not found <$GIS_OPT_INPUT>"
+   exit 1
+fi
+eval `g.gisenv`
+MSET_DIR="$GISDBASE/$LOCATION_NAME/$MAPSET"
+# create temporary directory to hold bits
+TMP_DIR="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP_DIR" ] ; then
+   g.message -e "Unable to create temporary files"
+   exit 1
+fi
+rm -f "$TMP_DIR"
+mkdir "$TMP_DIR"
+if [ ! -d "$TMP_DIR" ] ; then
+   g.message -e "Unable to create temporary directory"
+   exit 1
+fi
+cleanup()
+   g.message -v "Cleaning up ..."
+   cd "$MSET_DIR"
+   rm -rf "$TMP_DIR"
+#### trap ctrl-c so that we can clean up tmp
+trap 'cleanup' 2 3 15
+cp "$GIS_OPT_INPUT" "$TMP_DIR"/
+cd "$TMP_DIR"/
+# remove .pack and path from $GIS_OPT_INPUT
+#MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
+INPUT_BASE=`basename $GIS_OPT_INPUT`
+DATA_NAME=`tar tzf "$INPUT_BASE" | head -n 1 | cut -f1 -d'/'`
+if [ -z "$DATA_NAME" ] ; then
+   g.message -e "Pack file unreadable"
+   cleanup
+   exit 1
+fi
+if [ -z "$GIS_OPT_OUTPUT" ] ; then
+   MAP_NAME="$DATA_NAME"
+else
+   MAP_NAME="$GIS_OPT_OUTPUT"
+fi
+eval `g.findfile element=cell file="$MAP_NAME" mapset=.`
+if [ ! -z "$file" ] && [ "$GRASS_OVERWRITE" -ne 1 ] ; then
+   g.message -e "Raster map <$MAP_NAME> already exists"
+   cleanup
+   exit 1
+fi
+# extract data
+tar xzf "$INPUT_BASE"
+if [ $? -ne 0 ] ; then
+   cleanup
+   exit 1
+fi
+cd "$DATA_NAME"/
+# check projection compatibility in a rather crappy way
+if [ ! -z `diff PROJ_INFO "$MSET_DIR"/../PERMANENT/PROJ_INFO` ] ; then
+    if [ $GIS_FLAG_O -eq 1 ] ; then
+        g.message -w "Projection information does not match. Proceeding.."
+    else
+        g.message -e "Projection information does not match. Aborting."
+        cleanup
+        exit 1
+    fi
+fi
+# install in $MAPSET
+for ELEMENT in cats cell cellhd colr fcell grid3 hist ; do
+    if [ -e "$ELEMENT" ] ; then
+	if [ ! -d "$MSET_DIR/$ELEMENT/" ] ; then
+	   mkdir "$MSET_DIR/$ELEMENT/"
+	fi
+	cp "$ELEMENT" "$MSET_DIR/$ELEMENT/$MAP_NAME"
+    fi
+done
+if [ -d "cell_misc" ] ; then
+    if [ ! -d "$MSET_DIR/cell_misc" ] ; then
+	mkdir "$MSET_DIR/cell_misc"
+    fi
+    cp -r "cell_misc"/ "$MSET_DIR/cell_misc/$MAP_NAME"
+fi
+cleanup
+g.message -v "Done. Map saved to <$MAP_NAME>"
+exit 0
