[GRASS-SVN] r35030 - grass/branches/releasebranch_6_4/lib/gtcltk
Fri Dec 26 02:14:13 EST 2008
Author: cmbarton
Date: 2008-12-26 02:14:12 -0500 (Fri, 26 Dec 2008)
New Revision: 35030
   grass/branches/releasebranch_6_4/lib/gtcltk/gronsole.tcl
   grass/branches/releasebranch_6_4/lib/gtcltk/select.tcl
select.tcl: fixed mouse wheel scrolling, dictionary sorting (PERMANENT at top)
gronsole.tcl: switched to cut icon for cutting text
Modified: grass/branches/releasebranch_6_4/lib/gtcltk/gronsole.tcl
--- grass/branches/releasebranch_6_4/lib/gtcltk/gronsole.tcl	2008-12-26 07:13:38 UTC (rev 35029)
+++ grass/branches/releasebranch_6_4/lib/gtcltk/gronsole.tcl	2008-12-26 07:14:12 UTC (rev 35030)
@@ -187,7 +187,9 @@
 proc Gronsole::create_command {path cmd} {
+	global iconpath
 	variable _data
 	set textarea $path.text
 	incr _data($path,count)
@@ -208,7 +210,7 @@
 	bind $cmdlabel <Button-1> "Gronsole::do_click $path $ci"
 	# set cmdlabel [text $frame.cmdline.cmd -height 1 -width 10]
 	# $cmdlabel insert end $cmd
-	set ex [button $frame.cmdline.eX -text "X" -command "Gronsole::destroy_command $path $ci"]
+	set ex [button $frame.cmdline.eX -image [image create photo -file "$iconpath/edit-cut.gif"] -command "Gronsole::destroy_command $path $ci"]
 	pack $ex -side right
 	pack $frame.cmdline.tags -side right
 	set iconwidth ""
Modified: grass/branches/releasebranch_6_4/lib/gtcltk/select.tcl
--- grass/branches/releasebranch_6_4/lib/gtcltk/select.tcl	2008-12-26 07:13:38 UTC (rev 35029)
+++ grass/branches/releasebranch_6_4/lib/gtcltk/select.tcl	2008-12-26 07:14:12 UTC (rev 35030)
@@ -26,7 +26,7 @@
 set bind_scroll_list {}
-proc handle_scroll {ammount} {
+proc handle_scroll {amount} {
     global bind_scroll_list
     foreach {x y} {-1 -1} {}
@@ -46,7 +46,7 @@
 		set l [string length $parent]
         if {[string equal -length $l $parent $keyboard_focus] || \
             [string equal -length $l $parent $mouse_focus]} {
-            $window yview scroll [expr {-$ammount/120}] units
+            $window yview scroll [expr -1 * $amount] units
@@ -176,7 +176,7 @@
                 -image [Bitmap::get folder] -drawcross auto
             set path "$location_path/$dir/$element/"
-            foreach fp [ lsort [glob -nocomplain $path/*] ]  {
+            foreach fp [ lsort -dictionary [glob -nocomplain $path/*] ]  {
             set file [file tail $fp]
             $tree insert end ms_$dir $file@$dir -text $file -data $file \
                 -image [Bitmap::get file] -drawcross never
@@ -189,12 +189,12 @@
         $tree insert end root ms_$sympath -text SYMBOLS -data $sympath -open 1 \
             -image [Bitmap::get openfold] -drawcross auto
-        foreach ic_dir [ lsort [glob -nocomplain $sympath/*] ]  {
+        foreach ic_dir [ lsort -dictionary [glob -nocomplain $sympath/*] ]  {
             set dir_tail [file tail $ic_dir]
             $tree insert end ms_$sympath ms_$dir_tail  -text $dir_tail -data $dir_tail \
-            foreach ic_file [ lsort [glob -nocomplain $sympath/$dir_tail/*] ]  {
+            foreach ic_file [ lsort -dictionary [glob -nocomplain $sympath/$dir_tail/*] ]  {
                 set file [file tail $ic_file]
                 $tree insert end ms_$dir_tail $dir_tail/$file -text $file -data $file \
