[GRASS-SVN] r35107 - grass/trunk/raster/r.mapcalc
Mon Dec 29 15:40:05 EST 2008
Author: neteler
Date: 2008-12-29 15:40:01 -0500 (Mon, 29 Dec 2008)
New Revision: 35107
   grass/trunk/raster/r.mapcalc/r.mapcalc.html
   grass/trunk/raster/r.mapcalc/r3.mapcalc.html
changed for new parser support; some outdated stuff removed
Modified: grass/trunk/raster/r.mapcalc/r.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r.mapcalc.html	2008-12-29 19:15:51 UTC (rev 35106)
+++ grass/trunk/raster/r.mapcalc/r.mapcalc.html	2008-12-29 20:40:01 UTC (rev 35107)
@@ -3,14 +3,12 @@
 New raster map layers can be created which are arithmetic expressions
 involving existing raster map layers, integer or floating point constants,
 and functions.
 <h2>PROGRAM USE</h2>
-If used without command line arguments, <em>r.mapcalc</em> will read its
-input, one line at a time, from standard input
-(which is the keyboard, unless redirected from a file or across a pipe).
-Otherwise, the expression on the command line is evaluated.
 <em>r.mapcalc</em> expects its input to have the form:
 <p>
-<b>result=</b><em>expression</em>
+<b>result =</b><em> expression</em>
 <p>
 where <em>result</em> is the name of a raster map layer
 to contain the result of the calculation and
@@ -20,6 +18,55 @@
 Parentheses are allowed in the expression and may be nested to any depth.
 <em>result</em> will be created in the user's current mapset.
 <p>
+As <em>expression=</em> is the first option, it is the default. This
+means that passing an expression on the command line is possible
+as long as the expression is quoted and a space is included before the
+first <em>=</em> sign.
+Example ('foo' is the resulting map):
+<div class="code"><pre>
+r.mapcalc "foo = 1"
+</pre></div>
+or:
+r.mapcalc 'foo = 1'
+</pre></div>
+An unquoted expression (i.e. split over multiple arguments) won't
+work, nor will omitting the space before the = sign:
+r.mapcalc 'foo=1'
+Sorry, &lt;foo&gt; is not a valid parameter
+</pre></div>
+If no options are given, it manufactures "input=-" (which reads from
+stdin), so you can continue to use e.g.:
+r.mapcalc &lt; file
+</pre></div>
+or:
+r.mapcalc &lt;&lt;EOF
+foo = 1
+EOF
+</pre></div>
+But unless you need compatibility with previous versions, use input=
+explicitly, e.g.:
+r.mapcalc input=file
+</pre></div>
+or:
+r.mapcalc input=- &lt;&lt;EOF
+foo = 1
+EOF
+</pre></div>
+<p>
 The formula entered to <em>r.mapcalc</em> by the user is recorded both in the
 <em>result</em> map title (which appears in the category file for <em>result</em>)
 and in the history file for <em>result</em>.
@@ -350,7 +397,7 @@
 to be a floating point value. Multiplying one of them by 1.0 will
 produce a floating-point result, as will using float():
-      r.mapcalc "ndvi=float(lsat.4 - lsat.3) / (lsat.4 + lsat.3)"
+      r.mapcalc "ndvi = float(lsat.4 - lsat.3) / (lsat.4 + lsat.3)"
 </pre></div>
 <h2>NULL support</h2>
 <ul>
@@ -523,20 +570,11 @@
 <p>
 It is advisable to put single quotes around the expression; e.g.:
-result = 'elevation * 2'
+'result = elevation * 2'
 </pre></div>
 Without the quotes, the *, which has special meaning to the UNIX shell,
 would be altered and <em>r.mapcalc</em> would see something other than the *.
 <p>
-If the input comes directly from the keyboard and the <em>result</em> raster
-map layer exists, the user will be asked if it can be overwritten.
-Otherwise, the <em>result</em> raster map layer will automatically be
-overwritten if it exists.
-<p>
-Quoting <em>result</em> is not allowed.
-However, it is never necessary to quote <em>result</em> since
-it is always taken to be a raster map layer name.
-<p>
 For formulas that the user enters from standard input
 (rather than from the command line), a line continuation feature now exists.
 If the user adds \e to the end of an input line, <em>r.mapcalc</em> assumes that
@@ -562,14 +600,7 @@
 be meaningless and the equation will not work as the user intended.
 This is important for the eval() function.
 <p>
-Error messages produced by <em>r.mapcalc</em> are almost useless.
-In future, <em>r.mapcalc</em> should make some attempt
-to point the user to the offending section of the equation, e.g.:
-<div class="code"><pre>
-x = a * b ++ c
-ERROR: somewhere in line 1: ...  b ++ c ...
-</pre></div>
-<p>
+<!-- STILL TRUE ??-->
 Currently, there is no comment mechanism in <em>r.mapcalc</em>.
 Perhaps adding a capability that would cause the entire line to be
 ignored when the user inserted a # at the start of a line
@@ -582,11 +613,11 @@
 r.mapcalc does not print a warning in case of operations on NULL cells.
 It is left to the user to utilize the isnull() function.
 <h2>SEE ALSO</h2>
-<b><a href="http://grass.itc.it/gdp/raster/mapcalc-algebra.pdf">r.mapcalc: An Algebra for GIS and Image
+<b><a href="http://grass.osgeo.org/gdp/raster/mapcalc-algebra.pdf">r.mapcalc: An Algebra for GIS and Image
 Processing</a></b>, by Michael Shapiro and Jim Westervelt, U.S. Army
 Construction Engineering Research Laboratory (March/1991).
 <p>
-<b><a href="http://grass.itc.it/gdp/raster/mapcalc.pdf">Performing Map Calculations on GRASS Data:
+<b><a href="http://grass.osgeo.org/gdp/raster/mapcalc.pdf">Performing Map Calculations on GRASS Data:
 r.mapcalc Program Tutorial</a></b>, by Marji Larson, Michael Shapiro and Scott
 Tweddale, U.S. Army Construction Engineering Research Laboratory (December
 1991)
Modified: grass/trunk/raster/r.mapcalc/r3.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r3.mapcalc.html	2008-12-29 19:15:51 UTC (rev 35106)
+++ grass/trunk/raster/r.mapcalc/r3.mapcalc.html	2008-12-29 20:40:01 UTC (rev 35107)
@@ -1,30 +1,78 @@
 <h2>DESCRIPTION</h2>
-<em>r3.mapcalc</em> performs arithmetic on 3D grid volume data. New 3D grids
-can be created which are arithmetic expressions involving existing 3D grids,
-integer or floating point constants, and functions.
+<em>r3.mapcalc</em> performs arithmetic on raster map layers.
+New raster map layers can be created which are arithmetic expressions
+involving existing raster map layers, integer or floating point constants,
+and functions.
-If used without command line arguments, <em>r3.mapcalc</em> will read its
-input, one line at a time, from standard input (which is the keyboard,
-unless redirected from a file or across a pipe).
-Otherwise, the expression on the command line is evaluated. <em>r3.mapcalc</em>
-expects its input to have the form:
+<em>r3.mapcalc</em> expects its input to have the form:
 <p>
 <p>
-where <em>result</em> is the name of a 3D grid to contain the result of
-the calculation and <em>expression</em> is any legal arithmetic expression
-involving existing 3D grid, floating point constants, and functions known
-to the calculator. Parentheses are allowed in the expression and may be
-nested to any depth. <em>result</em> will be created in the user's current
-mapset.
+where <em>result</em> is the name of a raster map layer
+to contain the result of the calculation and
+<em>expression</em> is any legal arithmetic expression involving existing
+raster map layers, integer or floating point constants,
+and functions known to the calculator.
+Parentheses are allowed in the expression and may be nested to any depth.
+<em>result</em> will be created in the user's current mapset.
 <p>
-The formula entered to <em>r3.mapcalc</em> by the user is recorded both
-in the <em>result</em> grid title (which appears in the category file for
-<em>result</em>)
+r3.mapcalc "foo = 1"
+</pre></div>
+or:
+r3.mapcalc 'foo = 1'
+</pre></div>
+r3.mapcalc 'foo=1'
+</pre></div>
+r3.mapcalc &lt; file
+</pre></div>
+or:
+r3.mapcalc &lt;&lt;EOF
+foo = 1
+EOF
+</pre></div>
+explicitly, e.g.:
+r3.mapcalc input=file
+</pre></div>
+or:
+r3.mapcalc input=- &lt;&lt;EOF
+foo = 1
+EOF
+</pre></div>
+<p>
+The formula entered to <em>r3.mapcalc</em> by the user is recorded both in the
+<em>result</em> map title (which appears in the category file for <em>result</em>)
 <p>
 Some characters have special meaning to the command shell. If the user
-is entering input to <em>r.mapcalc</em> on the command line, expressions
+is entering input to <em>r3.mapcalc</em> on the command line, expressions
 should be enclosed within single quotes.  See NOTES, below.
 <p>
 <h2>OPERATORS AND ORDER OF PRECEDENCE</h2>
@@ -234,7 +282,7 @@
+      r3.mapcalc "ratio = float(soil.4 - soil.3) / soil.3)"
 </pre></div>
 <ul>
@@ -406,18 +454,11 @@
 <p>
 </pre></div>
 would be altered and <em>r3.mapcalc</em> would see something other than the *.
 <p>
-3D grid exists, the user will be asked if it can be overwritten. Otherwise,
-the <em>result</em> 3D grid will automatically be overwritten if it exists.
-<p>
-Quoting <em>result</em> is not allowed. However, it is never necessary
-to quote <em>result</em> since it is always taken to be a 3D grid name.
-<p>
 For formulas that the user enters from standard input (rather than from
 the command line), a line continuation feature now exists. If the user
 adds \e to the end of an input line, <em>r3.mapcalc</em> assumes that the
@@ -429,28 +470,16 @@
 map title will contain only some of it, but most (if not all) of the formula
 will be placed into the history file for the <em>result</em> map.
 <p>
-When the user enters input to <em>r3.mapcalc</em> non-interactively on
-the command line, the program will not warn the user not to overwrite existing
-3D grids. Users should therefore take care to assign program outputs 3D
-grid file names that do not yet exist in their current mapsets.
-<p>
 The environment variable GRASS_RND_SEED is read to initialise the
 random number generator.
 <h2>BUGS</h2>
 Continuation lines must end with a \ and have NO trailing white space
 (blanks or tabs).  If the user does leave white space at the end of
-continuation lines, the error messages produced by <em>r.mapcalc</em> will
+continuation lines, the error messages produced by <em>r3.mapcalc</em> will
 <p>
-x = a * b ++ c
-</pre></div>
-<p>
 Currently, there is no comment mechanism in <em>r3.mapcalc</em>. Perhaps
 adding a capability that would cause the entire line to be ignored when
 the user inserted a # at the start of a line as if it were not present,
@@ -460,15 +489,15 @@
 of simply a blank line. This would make separation of multiple scripts
 separable by white space.
 <p>
-r.mapcalc does not print a warning in case of operations on NULL cells.
+r3.mapcalc does not print a warning in case of operations on NULL cells.
 <h2>SEE ALSO</h2>
+<b><a href="http://grass.osgeo.org/gdp/raster/mapcalc-algebra.pdf">r3.mapcalc: An Algebra for GIS and Image
 <p>
 1991)
