[GRASS-SVN] r29924 - grass/trunk/display/drivers/cairo
Fri Feb 1 06:18:32 EST 2008
Author: glynn
Date: 2008-02-01 06:18:32 -0500 (Fri, 01 Feb 2008)
New Revision: 29924
   grass/trunk/display/drivers/cairo/description.html
Update cairo driver documentation to reflect recent configure changes
Modified: grass/trunk/display/drivers/cairo/description.html
--- grass/trunk/display/drivers/cairo/description.html	2008-02-01 07:17:38 UTC (rev 29923)
+++ grass/trunk/display/drivers/cairo/description.html	2008-02-01 11:18:32 UTC (rev 29924)
@@ -126,15 +126,11 @@
 <H2>NOTES</H2>
-<P>
-The driver is still in development. Currently the way to enable Cairo driver
-support is to build grass with
-<div class="code"><PRE>
-make USE_CAIRO=1
-</PRE></div>
+<P>The driver is still in development. Enable it by specifying
+<CODE>--with-cairo</CODE> when configuring GRASS. This
+requires a reasonably recent version of the Cairo libraries
+and a working pkg-config.</P>
-This requires a reasonably recent version of the cairo libraries (cairo.h).
 <P>Antialiasing is enabled by default for bitmap formats. There is
 currently no way of disabling this.</P>
