[GRASS-SVN] r29946 - grass/trunk/gui/wxpython/vdigit
Mon Feb 4 16:00:49 EST 2008
Author: martinl
Date: 2008-02-04 16:00:48 -0500 (Mon, 04 Feb 2008)
New Revision: 29946
Added:
   grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
   grass/trunk/gui/wxpython/vdigit/select.cpp
wxGUI/vdigit: New methods for selecting features added. Also cpp file generated by SWIG added (to simplify compilation process).
Added: grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
--- grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp	                        (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp	2008-02-04 21:00:48 UTC (rev 29946)
@@ -0,0 +1,12638 @@
+ * This file was automatically generated by SWIG (http://www.swig.org).
+ * Version 1.3.33
+ * This file is not intended to be easily readable and contains a number of
+ * coding conventions designed to improve portability and efficiency. Do not make
+ * changes to this file unless you know what you are doing--modify the SWIG
+ * interface file instead.
+#define SWIGPYTHON
+#define SWIG_PYTHON_DIRECTOR_NO_VTABLE
+#ifdef __cplusplus
+template<typename T> class SwigValueWrapper {
+    T *tt;
+public:
+    SwigValueWrapper() : tt(0) { }
+    SwigValueWrapper(const SwigValueWrapper<T>& rhs) : tt(new T(*rhs.tt)) { }
+    SwigValueWrapper(const T& t) : tt(new T(t)) { }
+    ~SwigValueWrapper() { delete tt; }
+    SwigValueWrapper& operator=(const T& t) { delete tt; tt = new T(t); return *this; }
+    operator T&() const { return *tt; }
+    T *operator&() { return tt; }
+private:
+    SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
+template <typename T> T SwigValueInit() {
+  return T();
+#endif
+ *  This section contains generic SWIG labels for method/variable
+ *  declarations/attributes, and other compiler dependent labels.
+/* template workaround for compilers that cannot correctly implement the C++ standard */
+#ifndef SWIGTEMPLATEDISAMBIGUATOR
+# if defined(__SUNPRO_CC) && (__SUNPRO_CC <= 0x560)
+#  define SWIGTEMPLATEDISAMBIGUATOR template
+# elif defined(__HP_aCC)
+/* Needed even with `aCC -AA' when `aCC -V' reports HP ANSI C++ B3910B A.03.55 */
+/* If we find a maximum version that requires this, the test would be __HP_aCC <= 35500 for A.03.55 */
+# else
+# endif
+#endif
+/* inline attribute */
+#ifndef SWIGINLINE
+# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
+#   define SWIGINLINE inline
+# else
+# endif
+#endif
+/* attribute recognised by some compilers to avoid 'unused' warnings */
+#ifndef SWIGUNUSED
+# if defined(__GNUC__)
+#   if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
+#     define SWIGUNUSED __attribute__ ((__unused__))
+#   else
+#   endif
+# elif defined(__ICC)
+# else
+# endif
+#endif
+#ifndef SWIGUNUSEDPARM
+# ifdef __cplusplus
+#   define SWIGUNUSEDPARM(p)
+# else
+#   define SWIGUNUSEDPARM(p) p SWIGUNUSED
+# endif
+#endif
+/* internal SWIG method */
+#ifndef SWIGINTERN
+# define SWIGINTERN static SWIGUNUSED
+#endif
+/* internal inline SWIG method */
+#ifndef SWIGINTERNINLINE
+# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
+#endif
+/* exporting methods */
+#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
+#  ifndef GCC_HASCLASSVISIBILITY
+#    define GCC_HASCLASSVISIBILITY
+#  endif
+#endif
+#ifndef SWIGEXPORT
+# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
+#   if defined(STATIC_LINKED)
+#     define SWIGEXPORT
+#   else
+#     define SWIGEXPORT __declspec(dllexport)
+#   endif
+# else
+#   if defined(__GNUC__) && defined(GCC_HASCLASSVISIBILITY)
+#     define SWIGEXPORT __attribute__ ((visibility("default")))
+#   else
+#   endif
+# endif
+#endif
+/* calling conventions for Windows */
+#ifndef SWIGSTDCALL
+#   define SWIGSTDCALL __stdcall
+# else
+# endif
+#endif
+/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
+#if !defined(SWIG_NO_CRT_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
+# define _CRT_SECURE_NO_DEPRECATE
+#endif
+/* Deal with Microsoft's attempt at deprecating methods in the standard C++ library */
+#if !defined(SWIG_NO_SCL_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_SCL_SECURE_NO_DEPRECATE)
+# define _SCL_SECURE_NO_DEPRECATE
+#endif
+/* Python.h has to appear first */
+#include <Python.h>
+ * swigrun.swg
+ * This file contains generic CAPI SWIG runtime support for pointer
+ * type checking.
+/* This should only be incremented when either the layout of swig_type_info changes,
+   or for whatever reason, the runtime changes incompatibly */
+#define SWIG_RUNTIME_VERSION "3"
+/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
+#ifdef SWIG_TYPE_TABLE
+# define SWIG_QUOTE_STRING(x) #x
+# define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
+# define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
+#else
+#endif
+  You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
+  creating a static or dynamic library from the swig runtime code.
+  In 99.9% of the cases, swig just needs to declare them as 'static'.
+  But only do this if is strictly necessary, ie, if you have problems
+  with your compiler or so.
+#ifndef SWIGRUNTIME
+# define SWIGRUNTIME SWIGINTERN
+#endif
+#ifndef SWIGRUNTIMEINLINE
+# define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
+#endif
+/*  Generic buffer size */
+#ifndef SWIG_BUFFER_SIZE
+# define SWIG_BUFFER_SIZE 1024
+#endif
+/* Flags for pointer conversions */
+#define SWIG_POINTER_DISOWN        0x1
+/* Flags for new pointer objects */
+#define SWIG_POINTER_OWN           0x1
+   Flags/methods for returning states.
+   The swig conversion methods, as ConvertPtr, return and integer
+   that tells if the conversion was successful or not. And if not,
+   an error code can be returned (see swigerrors.swg for the codes).
+   Use the following macros/flags to set or process the returning
+   states.
+   In old swig versions, you usually write code as:
+     if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
+       // success code
+     } else {
+       //fail code
+   Now you can be more explicit as:
+    int res = SWIG_ConvertPtr(obj,vptr,ty.flags);
+    if (SWIG_IsOK(res)) {
+      // success code
+    } else {
+      // fail code
+   that seems to be the same, but now you can also do
+    Type *ptr;
+    int res = SWIG_ConvertPtr(obj,(void **)(&ptr),ty.flags);
+      // success code
+      if (SWIG_IsNewObj(res) {
+	delete *ptr;
+      } else {
+    } else {
+      // fail code
+   I.e., now SWIG_ConvertPtr can return new objects and you can
+   identify the case and take care of the deallocation. Of course that
+   requires also to SWIG_ConvertPtr to return new result values, as
+      int SWIG_ConvertPtr(obj, ptr,...) {
+        if (<obj is ok>) {
+          if (<need new object>) {
+            *ptr = <ptr to new allocated object>;
+            return SWIG_NEWOBJ;
+          } else {
+            *ptr = <ptr to old object>;
+            return SWIG_OLDOBJ;
+        } else {
+          return SWIG_BADOBJ;
+   Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
+   more explicit by returning SWIG_BADOBJ, SWIG_ERROR or any of the
+   swig errors code.
+   Finally, if the SWIG_CASTRANK_MODE is enabled, the result code
+   allows to return the 'cast rank', for example, if you have this
+       int food(double)
+       int fooi(int);
+   and you call
+      food(1)   // cast rank '1'  (1 -> 1.0)
+      fooi(1)   // cast rank '0'
+   just use the SWIG_AddCast()/SWIG_CheckState()
+#define SWIG_OK                    (0)
+#define SWIG_ERROR                 (-1)
+#define SWIG_IsOK(r)               (r >= 0)
+#define SWIG_ArgError(r)           ((r != SWIG_ERROR) ? r : SWIG_TypeError)
+/* The CastRankLimit says how many bits are used for the cast rank */
+#define SWIG_CASTRANKLIMIT         (1 << 8)
+/* The NewMask denotes the object was created (using new/malloc) */
+#define SWIG_NEWOBJMASK            (SWIG_CASTRANKLIMIT  << 1)
+/* The TmpMask is for in/out typemaps that use temporal objects */
+#define SWIG_TMPOBJMASK            (SWIG_NEWOBJMASK << 1)
+/* Simple returning values */
+#define SWIG_BADOBJ                (SWIG_ERROR)
+#define SWIG_OLDOBJ                (SWIG_OK)
+#define SWIG_NEWOBJ                (SWIG_OK | SWIG_NEWOBJMASK)
+#define SWIG_TMPOBJ                (SWIG_OK | SWIG_TMPOBJMASK)
+/* Check, add and del mask methods */
+#define SWIG_AddNewMask(r)         (SWIG_IsOK(r) ? (r | SWIG_NEWOBJMASK) : r)
+#define SWIG_DelNewMask(r)         (SWIG_IsOK(r) ? (r & ~SWIG_NEWOBJMASK) : r)
+#define SWIG_IsNewObj(r)           (SWIG_IsOK(r) && (r & SWIG_NEWOBJMASK))
+#define SWIG_AddTmpMask(r)         (SWIG_IsOK(r) ? (r | SWIG_TMPOBJMASK) : r)
+#define SWIG_DelTmpMask(r)         (SWIG_IsOK(r) ? (r & ~SWIG_TMPOBJMASK) : r)
+#define SWIG_IsTmpObj(r)           (SWIG_IsOK(r) && (r & SWIG_TMPOBJMASK))
+/* Cast-Rank Mode */
+#if defined(SWIG_CASTRANK_MODE)
+#  ifndef SWIG_TypeRank
+#    define SWIG_TypeRank             unsigned long
+#  endif
+#  ifndef SWIG_MAXCASTRANK            /* Default cast allowed */
+#    define SWIG_MAXCASTRANK          (2)
+#  endif
+#  define SWIG_CASTRANKMASK          ((SWIG_CASTRANKLIMIT) -1)
+#  define SWIG_CastRank(r)           (r & SWIG_CASTRANKMASK)
+SWIGINTERNINLINE int SWIG_AddCast(int r) {
+  return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
+SWIGINTERNINLINE int SWIG_CheckState(int r) {
+  return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
+#else /* no cast-rank mode */
+#  define SWIG_AddCast
+#  define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
+#endif
+#include <string.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+typedef void *(*swig_converter_func)(void *);
+typedef struct swig_type_info *(*swig_dycast_func)(void **);
+/* Structure to store inforomation on one type */
+typedef struct swig_type_info {
+  const char             *name;			/* mangled name of this type */
+  const char             *str;			/* human readable name of this type */
+  swig_dycast_func        dcast;		/* dynamic cast function down a hierarchy */
+  struct swig_cast_info  *cast;			/* linked list of types that can cast into this type */
+  void                   *clientdata;		/* language specific type data */
+  int                    owndata;		/* flag if the structure owns the clientdata */
+} swig_type_info;
+/* Structure to store a type and conversion function used for casting */
+typedef struct swig_cast_info {
+  swig_type_info         *type;			/* pointer to type that is equivalent to this type */
+  swig_converter_func     converter;		/* function to cast the void pointers */
+  struct swig_cast_info  *next;			/* pointer to next cast in linked list */
+  struct swig_cast_info  *prev;			/* pointer to the previous cast */
+} swig_cast_info;
+/* Structure used to store module information
+ * Each module generates one structure like this, and the runtime collects
+ * all of these structures and stores them in a circularly linked list.*/
+typedef struct swig_module_info {
+  swig_type_info         **types;		/* Array of pointers to swig_type_info structures that are in this module */
+  size_t                 size;		        /* Number of types in this module */
+  struct swig_module_info *next;		/* Pointer to next element in circularly linked list */
+  swig_type_info         **type_initial;	/* Array of initially generated type structures */
+  swig_cast_info         **cast_initial;	/* Array of initially generated casting structures */
+  void                    *clientdata;		/* Language specific module data */
+} swig_module_info;
+  Compare two type names skipping the space characters, therefore
+  "char*" == "char *" and "Class<int>" == "Class<int >", etc.
+  Return 0 when the two name types are equivalent, as in
+  strncmp, but skipping ' '.
+SWIGRUNTIME int
+SWIG_TypeNameComp(const char *f1, const char *l1,
+		  const char *f2, const char *l2) {
+  for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
+    while ((*f1 == ' ') && (f1 != l1)) ++f1;
+    while ((*f2 == ' ') && (f2 != l2)) ++f2;
+    if (*f1 != *f2) return (*f1 > *f2) ? 1 : -1;
+  return (int)((l1 - f1) - (l2 - f2));
+  Check type equivalence in a name list like <name1>|<name2>|...
+  Return 0 if not equal, 1 if equal
+SWIGRUNTIME int
+SWIG_TypeEquiv(const char *nb, const char *tb) {
+  int equiv = 0;
+  const char* te = tb + strlen(tb);
+  const char* ne = nb;
+  while (!equiv && *ne) {
+    for (nb = ne; *ne; ++ne) {
+      if (*ne == '|') break;
+    equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
+    if (*ne) ++ne;
+  return equiv;
+  Return 0 if equal, -1 if nb < tb, 1 if nb > tb
+SWIGRUNTIME int
+SWIG_TypeCompare(const char *nb, const char *tb) {
+  int equiv = 0;
+    if (*ne) ++ne;
+  return equiv;
+/* think of this as a c++ template<> or a scheme macro */
+#define SWIG_TypeCheck_Template(comparison, ty)         \
+  if (ty) {                                             \
+    swig_cast_info *iter = ty->cast;                    \
+    while (iter) {                                      \
+      if (comparison) {                                 \
+        if (iter == ty->cast) return iter;              \
+        /* Move iter to the top of the linked list */   \
+        iter->prev->next = iter->next;                  \
+        if (iter->next)                                 \
+          iter->next->prev = iter->prev;                \
+        iter->next = ty->cast;                          \
+        iter->prev = 0;                                 \
+        if (ty->cast) ty->cast->prev = iter;            \
+        ty->cast = iter;                                \
+        return iter;                                    \
+      iter = iter->next;                                \
+  return 0
+  Check the typename
+SWIGRUNTIME swig_cast_info *
+SWIG_TypeCheck(const char *c, swig_type_info *ty) {
+  SWIG_TypeCheck_Template(strcmp(iter->type->name, c) == 0, ty);
+/* Same as previous function, except strcmp is replaced with a pointer comparison */
+SWIG_TypeCheckStruct(swig_type_info *from, swig_type_info *into) {
+  SWIG_TypeCheck_Template(iter->type == from, into);
+  Cast a pointer up an inheritance hierarchy
+SWIGRUNTIMEINLINE void *
+SWIG_TypeCast(swig_cast_info *ty, void *ptr) {
+  return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr);
+   Dynamic pointer casting. Down an inheritance hierarchy
+SWIGRUNTIME swig_type_info *
+SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
+  swig_type_info *lastty = ty;
+  if (!ty || !ty->dcast) return ty;
+  while (ty && (ty->dcast)) {
+    ty = (*ty->dcast)(ptr);
+    if (ty) lastty = ty;
+  return lastty;
+  Return the name associated with this type
+SWIGRUNTIMEINLINE const char *
+SWIG_TypeName(const swig_type_info *ty) {
+  return ty->name;
+  Return the pretty name associated with this type,
+  that is an unmangled type name in a form presentable to the user.
+SWIGRUNTIME const char *
+SWIG_TypePrettyName(const swig_type_info *type) {
+  /* The "str" field contains the equivalent pretty names of the
+     type, separated by vertical-bar characters.  We choose
+     to print the last name, as it is often (?) the most
+     specific. */
+  if (!type) return NULL;
+  if (type->str != NULL) {
+    const char *last_name = type->str;
+    const char *s;
+    for (s = type->str; *s; s++)
+      if (*s == '|') last_name = s+1;
+    return last_name;
+  else
+    return type->name;
+   Set the clientdata field for a type
+SWIGRUNTIME void
+SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
+  swig_cast_info *cast = ti->cast;
+  /* if (ti->clientdata == clientdata) return; */
+  ti->clientdata = clientdata;
+  while (cast) {
+    if (!cast->converter) {
+      swig_type_info *tc = cast->type;
+      if (!tc->clientdata) {
+	SWIG_TypeClientData(tc, clientdata);
+    cast = cast->next;
+SWIGRUNTIME void
+SWIG_TypeNewClientData(swig_type_info *ti, void *clientdata) {
+  SWIG_TypeClientData(ti, clientdata);
+  ti->owndata = 1;
+  Search for a swig_type_info structure only by mangled name
+  Search is a O(log #types)
+  We start searching at module start, and finish searching when start == end.
+  Note: if start == end at the beginning of the function, we go all the way around
+  the circular list.
+SWIG_MangledTypeQueryModule(swig_module_info *start,
+                            swig_module_info *end,
+		            const char *name) {
+  swig_module_info *iter = start;
+  do {
+    if (iter->size) {
+      register size_t l = 0;
+      register size_t r = iter->size - 1;
+      do {
+	/* since l+r >= 0, we can (>> 1) instead (/ 2) */
+	register size_t i = (l + r) >> 1;
+	const char *iname = iter->types[i]->name;
+	if (iname) {
+	  register int compare = strcmp(name, iname);
+	  if (compare == 0) {
+	    return iter->types[i];
+	  } else if (compare < 0) {
+	    if (i) {
+	      r = i - 1;
+	    } else {
+	      break;
+	  } else if (compare > 0) {
+	    l = i + 1;
+	} else {
+	  break; /* should never happen */
+      } while (l <= r);
+  } while (iter != end);
+  return 0;
+  Search for a swig_type_info structure for either a mangled name or a human readable name.
+  It first searches the mangled names of the types, which is a O(log #types)
+  If a type is not found it then searches the human readable names, which is O(#types).
+SWIG_TypeQueryModule(swig_module_info *start,
+  /* STEP 1: Search the name field using binary search */
+  swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
+  if (ret) {
+    return ret;
+  } else {
+    /* STEP 2: If the type hasn't been found, do a complete search
+       of the str field (the human readable name) */
+    do {
+      register size_t i = 0;
+      for (; i < iter->size; ++i) {
+	if (iter->types[i]->str && (SWIG_TypeEquiv(iter->types[i]->str, name)))
+  /* neither found a match */
+  return 0;
+   Pack binary data into a string
+SWIGRUNTIME char *
+SWIG_PackData(char *c, void *ptr, size_t sz) {
+  static const char hex[17] = "0123456789abcdef";
+  register const unsigned char *u = (unsigned char *) ptr;
+  register const unsigned char *eu =  u + sz;
+  for (; u != eu; ++u) {
+    register unsigned char uu = *u;
+    *(c++) = hex[(uu & 0xf0) >> 4];
+    *(c++) = hex[uu & 0xf];
+  return c;
+   Unpack binary data from a string
+SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
+  register unsigned char *u = (unsigned char *) ptr;
+    register char d = *(c++);
+    register unsigned char uu;
+    if ((d >= '0') && (d <= '9'))
+      uu = ((d - '0') << 4);
+    else if ((d >= 'a') && (d <= 'f'))
+      uu = ((d - ('a'-10)) << 4);
+    else
+      return (char *) 0;
+    d = *(c++);
+      uu |= (d - '0');
+      uu |= (d - ('a'-10));
+    else
+    *u = uu;
+  return c;
+   Pack 'void *' into a string buffer.
+SWIGRUNTIME char *
+SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
+  char *r = buff;
+  if ((2*sizeof(void *) + 2) > bsz) return 0;
+  *(r++) = '_';
+  r = SWIG_PackData(r,&ptr,sizeof(void *));
+  if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
+  strcpy(r,name);
+  return buff;
+SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
+  if (*c != '_') {
+    if (strcmp(c,"NULL") == 0) {
+      *ptr = (void *) 0;
+      return name;
+    } else {
+      return 0;
+  return SWIG_UnpackData(++c,ptr,sizeof(void *));
+SWIGRUNTIME char *
+SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
+  char *r = buff;
+  size_t lname = (name ? strlen(name) : 0);
+  if ((2*sz + 2 + lname) > bsz) return 0;
+  *(r++) = '_';
+  r = SWIG_PackData(r,ptr,sz);
+  if (lname) {
+    strncpy(r,name,lname+1);
+  } else {
+    *r = 0;
+  return buff;
+SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
+  if (*c != '_') {
+      memset(ptr,0,sz);
+      return name;
+    } else {
+      return 0;
+  return SWIG_UnpackData(++c,ptr,sz);
+#ifdef __cplusplus
+#endif
+/*  Errors in SWIG */
+#define  SWIG_UnknownError    	   -1
+#define  SWIG_IOError        	   -2
+#define  SWIG_RuntimeError   	   -3
+#define  SWIG_IndexError     	   -4
+#define  SWIG_TypeError      	   -5
+#define  SWIG_DivisionByZero 	   -6
+#define  SWIG_OverflowError  	   -7
+#define  SWIG_SyntaxError    	   -8
+#define  SWIG_ValueError     	   -9
+#define  SWIG_SystemError    	   -10
+#define  SWIG_AttributeError 	   -11
+#define  SWIG_MemoryError    	   -12
+#define  SWIG_NullReferenceError   -13
+/* Add PyOS_snprintf for old Pythons */
+#if PY_VERSION_HEX < 0x02020000
+# if defined(_MSC_VER) || defined(__BORLANDC__) || defined(_WATCOM)
+#  define PyOS_snprintf _snprintf
+# else
+#  define PyOS_snprintf snprintf
+# endif
+#endif
+/* A crude PyString_FromFormat implementation for old Pythons */
+#ifndef SWIG_PYBUFFER_SIZE
+# define SWIG_PYBUFFER_SIZE 1024
+#endif
+static PyObject *
+PyString_FromFormat(const char *fmt, ...) {
+  va_list ap;
+  char buf[SWIG_PYBUFFER_SIZE * 2];
+  int res;
+  va_start(ap, fmt);
+  res = vsnprintf(buf, sizeof(buf), fmt, ap);
+  va_end(ap);
+  return (res < 0 || res >= (int)sizeof(buf)) ? 0 : PyString_FromString(buf);
+#endif
+/* Add PyObject_Del for old Pythons */
+#if PY_VERSION_HEX < 0x01060000
+# define PyObject_Del(op) PyMem_DEL((op))
+#endif
+#ifndef PyObject_DEL
+# define PyObject_DEL PyObject_Del
+#endif
+/* A crude PyExc_StopIteration exception for old Pythons */
+# ifndef PyExc_StopIteration
+#  define PyExc_StopIteration PyExc_RuntimeError
+# endif
+# ifndef PyObject_GenericGetAttr
+#  define PyObject_GenericGetAttr 0
+# endif
+#endif
+/* Py_NotImplemented is defined in 2.1 and up. */
+#if PY_VERSION_HEX < 0x02010000
+# ifndef Py_NotImplemented
+#  define Py_NotImplemented PyExc_RuntimeError
+# endif
+#endif
+/* A crude PyString_AsStringAndSize implementation for old Pythons */
+# ifndef PyString_AsStringAndSize
+#  define PyString_AsStringAndSize(obj, s, len) {*s = PyString_AsString(obj); *len = *s ? strlen(*s) : 0;}
+# endif
+#endif
+/* PySequence_Size for old Pythons */
+#if PY_VERSION_HEX < 0x02000000
+# ifndef PySequence_Size
+#  define PySequence_Size PySequence_Length
+# endif
+#endif
+/* PyBool_FromLong for old Pythons */
+#if PY_VERSION_HEX < 0x02030000
+static
+PyObject *PyBool_FromLong(long ok)
+  PyObject *result = ok ? Py_True : Py_False;
+  Py_INCREF(result);
+  return result;
+#endif
+/* Py_ssize_t for old Pythons */
+/* This code is as recommended by: */
+/* http://www.python.org/dev/peps/pep-0353/#conversion-guidelines */
+#if PY_VERSION_HEX < 0x02050000 && !defined(PY_SSIZE_T_MIN)
+typedef int Py_ssize_t;
+# define PY_SSIZE_T_MAX INT_MAX
+# define PY_SSIZE_T_MIN INT_MIN
+#endif
+ * error manipulation
+SWIGRUNTIME PyObject*
+SWIG_Python_ErrorType(int code) {
+  PyObject* type = 0;
+  switch(code) {
+  case SWIG_MemoryError:
+    type = PyExc_MemoryError;
+    break;
+  case SWIG_IOError:
+    type = PyExc_IOError;
+    break;
+  case SWIG_RuntimeError:
+    type = PyExc_RuntimeError;
+    break;
+  case SWIG_IndexError:
+    type = PyExc_IndexError;
+    break;
+  case SWIG_TypeError:
+    type = PyExc_TypeError;
+    break;
+  case SWIG_DivisionByZero:
+    type = PyExc_ZeroDivisionError;
+    break;
+  case SWIG_OverflowError:
+    type = PyExc_OverflowError;
+    break;
+  case SWIG_SyntaxError:
+    type = PyExc_SyntaxError;
+    break;
+  case SWIG_ValueError:
+    type = PyExc_ValueError;
+    break;
+  case SWIG_SystemError:
+    type = PyExc_SystemError;
+    break;
+  case SWIG_AttributeError:
+    type = PyExc_AttributeError;
+    break;
+  default:
+  return type;
+SWIGRUNTIME void
+SWIG_Python_AddErrorMsg(const char* mesg)
+  PyObject *type = 0;
+  PyObject *value = 0;
+  PyObject *traceback = 0;
+  if (PyErr_Occurred()) PyErr_Fetch(&type, &value, &traceback);
+  if (value) {
+    PyObject *old_str = PyObject_Str(value);
+    PyErr_Clear();
+    Py_XINCREF(type);
+    PyErr_Format(type, "%s %s", PyString_AsString(old_str), mesg);
+    Py_DECREF(old_str);
+    Py_DECREF(value);
+  } else {
+    PyErr_Format(PyExc_RuntimeError, mesg);
+#if defined(SWIG_PYTHON_NO_THREADS)
+#  if defined(SWIG_PYTHON_THREADS)
+#    undef SWIG_PYTHON_THREADS
+#  endif
+#endif
+#if defined(SWIG_PYTHON_THREADS) /* Threading support is enabled */
+#  if !defined(SWIG_PYTHON_USE_GIL) && !defined(SWIG_PYTHON_NO_USE_GIL)
+#    if (PY_VERSION_HEX >= 0x02030000) /* For 2.3 or later, use the PyGILState calls */
+#      define SWIG_PYTHON_USE_GIL
+#    endif
+#  endif
+#  if defined(SWIG_PYTHON_USE_GIL) /* Use PyGILState threads calls */
+#    ifndef SWIG_PYTHON_INITIALIZE_THREADS
+#     define SWIG_PYTHON_INITIALIZE_THREADS  PyEval_InitThreads()
+#    endif
+#    ifdef __cplusplus /* C++ code */
+       class SWIG_Python_Thread_Block {
+         bool status;
+         PyGILState_STATE state;
+       public:
+         void end() { if (status) { PyGILState_Release(state); status = false;} }
+         SWIG_Python_Thread_Block() : status(true), state(PyGILState_Ensure()) {}
+         ~SWIG_Python_Thread_Block() { end(); }
+       class SWIG_Python_Thread_Allow {
+         bool status;
+         PyThreadState *save;
+       public:
+         void end() { if (status) { PyEval_RestoreThread(save); status = false; }}
+         SWIG_Python_Thread_Allow() : status(true), save(PyEval_SaveThread()) {}
+         ~SWIG_Python_Thread_Allow() { end(); }
+#      define SWIG_PYTHON_THREAD_BEGIN_BLOCK   SWIG_Python_Thread_Block _swig_thread_block
+#      define SWIG_PYTHON_THREAD_END_BLOCK     _swig_thread_block.end()
+#      define SWIG_PYTHON_THREAD_BEGIN_ALLOW   SWIG_Python_Thread_Allow _swig_thread_allow
+#      define SWIG_PYTHON_THREAD_END_ALLOW     _swig_thread_allow.end()
+#    else /* C code */
+#      define SWIG_PYTHON_THREAD_BEGIN_BLOCK   PyGILState_STATE _swig_thread_block = PyGILState_Ensure()
+#      define SWIG_PYTHON_THREAD_END_BLOCK     PyGILState_Release(_swig_thread_block)
+#      define SWIG_PYTHON_THREAD_BEGIN_ALLOW   PyThreadState *_swig_thread_allow = PyEval_SaveThread()
+#      define SWIG_PYTHON_THREAD_END_ALLOW     PyEval_RestoreThread(_swig_thread_allow)
+#    endif
+#  else /* Old thread way, not implemented, user must provide it */
+#    if !defined(SWIG_PYTHON_INITIALIZE_THREADS)
+#    endif
+#    if !defined(SWIG_PYTHON_THREAD_BEGIN_BLOCK)
+#    endif
+#    if !defined(SWIG_PYTHON_THREAD_END_BLOCK)
+#    endif
+#    if !defined(SWIG_PYTHON_THREAD_BEGIN_ALLOW)
+#    endif
+#    if !defined(SWIG_PYTHON_THREAD_END_ALLOW)
+#    endif
+#  endif
+#else /* No thread support */
+#endif
+ * Python API portion that goes into the runtime
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* cc-mode */
+#endif
+#endif
+ * Constant declarations
+/* Constant Types */
+#define SWIG_PY_POINTER 4
+#define SWIG_PY_BINARY  5
+/* Constant information structure */
+typedef struct swig_const_info {
+  int type;
+  char *name;
+  long lvalue;
+  double dvalue;
+  void   *pvalue;
+  swig_type_info **ptype;
+} swig_const_info;
+#ifdef __cplusplus
+#if 0
+{ /* cc-mode */
+#endif
+#endif
+ * See the LICENSE file for information on copyright, usage and redistribution
+ * of SWIG, and the README file for authors - http://www.swig.org/release.html.
+ * pyrun.swg
+ * This file contains the runtime support for Python modules
+ * and includes code for managing global variables and pointer
+ * type checking.
+/* Common SWIG API */
+/* for raw pointers */
+#define SWIG_Python_ConvertPtr(obj, pptr, type, flags)  SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
+#define SWIG_ConvertPtr(obj, pptr, type, flags)         SWIG_Python_ConvertPtr(obj, pptr, type, flags)
+#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own)  SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, own)
+#define SWIG_NewPointerObj(ptr, type, flags)            SWIG_Python_NewPointerObj(ptr, type, flags)
+#define SWIG_CheckImplicit(ty)                          SWIG_Python_CheckImplicit(ty)
+#define SWIG_AcquirePtr(ptr, src)                       SWIG_Python_AcquirePtr(ptr, src)
+#define swig_owntype                                    int
+/* for raw packed data */
+#define SWIG_ConvertPacked(obj, ptr, sz, ty)            SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
+#define SWIG_NewPackedObj(ptr, sz, type)                SWIG_Python_NewPackedObj(ptr, sz, type)
+/* for class or struct pointers */
+#define SWIG_ConvertInstance(obj, pptr, type, flags)    SWIG_ConvertPtr(obj, pptr, type, flags)
+#define SWIG_NewInstanceObj(ptr, type, flags)           SWIG_NewPointerObj(ptr, type, flags)
+/* for C or C++ function pointers */
+#define SWIG_ConvertFunctionPtr(obj, pptr, type)        SWIG_Python_ConvertFunctionPtr(obj, pptr, type)
+#define SWIG_NewFunctionPtrObj(ptr, type)               SWIG_Python_NewPointerObj(ptr, type, 0)
+/* for C++ member pointers, ie, member methods */
+#define SWIG_ConvertMember(obj, ptr, sz, ty)            SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
+#define SWIG_NewMemberObj(ptr, sz, type)                SWIG_Python_NewPackedObj(ptr, sz, type)
+/* Runtime API */
+#define SWIG_GetModule(clientdata)                      SWIG_Python_GetModule()
+#define SWIG_SetModule(clientdata, pointer)             SWIG_Python_SetModule(pointer)
+#define SWIG_NewClientData(obj)                         PySwigClientData_New(obj)
+#define SWIG_SetErrorObj                                SWIG_Python_SetErrorObj
+#define SWIG_SetErrorMsg                        	SWIG_Python_SetErrorMsg
+#define SWIG_ErrorType(code)                    	SWIG_Python_ErrorType(code)
+#define SWIG_Error(code, msg)            		SWIG_Python_SetErrorMsg(SWIG_ErrorType(code), msg)
+#define SWIG_fail                        		goto fail
+/* Runtime API implementation */
+/* Error manipulation */
+SWIGINTERN void
+SWIG_Python_SetErrorObj(PyObject *errtype, PyObject *obj) {
+  SWIG_PYTHON_THREAD_BEGIN_BLOCK;
+  PyErr_SetObject(errtype, obj);
+  Py_DECREF(obj);
+  SWIG_PYTHON_THREAD_END_BLOCK;
+SWIGINTERN void
+SWIG_Python_SetErrorMsg(PyObject *errtype, const char *msg) {
+  PyErr_SetString(errtype, (char *) msg);
+#define SWIG_Python_Raise(obj, type, desc)  SWIG_Python_SetErrorObj(SWIG_Python_ExceptionType(desc), obj)
+/* Set a constant value */
+SWIGINTERN void
+SWIG_Python_SetConstant(PyObject *d, const char *name, PyObject *obj) {
+  PyDict_SetItemString(d, (char*) name, obj);
+  Py_DECREF(obj);
+/* Append a value to the result obj */
+SWIGINTERN PyObject*
+SWIG_Python_AppendOutput(PyObject* result, PyObject* obj) {
+#if !defined(SWIG_PYTHON_OUTPUT_TUPLE)
+  if (!result) {
+    result = obj;
+  } else if (result == Py_None) {
+    Py_DECREF(result);
+    result = obj;
+  } else {
+    if (!PyList_Check(result)) {
+      PyObject *o2 = result;
+      result = PyList_New(1);
+      PyList_SetItem(result, 0, o2);
+    PyList_Append(result,obj);
+    Py_DECREF(obj);
+  return result;
+#else
+  PyObject*   o2;
+  PyObject*   o3;
+  if (!result) {
+    result = obj;
+    result = obj;
+  } else {
+    if (!PyTuple_Check(result)) {
+      o2 = result;
+      result = PyTuple_New(1);
+      PyTuple_SET_ITEM(result, 0, o2);
+    o3 = PyTuple_New(1);
+    PyTuple_SET_ITEM(o3, 0, obj);
+    o2 = result;
+    result = PySequence_Concat(o2, o3);
+    Py_DECREF(o2);
+    Py_DECREF(o3);
+  return result;
+#endif
+/* Unpack the argument tuple */
+SWIGINTERN int
+SWIG_Python_UnpackTuple(PyObject *args, const char *name, Py_ssize_t min, Py_ssize_t max, PyObject **objs)
+  if (!args) {
+    if (!min && !max) {
+      return 1;
+    } else {
+      PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got none",
+		   name, (min == max ? "" : "at least "), (int)min);
+      return 0;
+  if (!PyTuple_Check(args)) {
+    PyErr_SetString(PyExc_SystemError, "UnpackTuple() argument list is not a tuple");
+    return 0;
+  } else {
+    register Py_ssize_t l = PyTuple_GET_SIZE(args);
+    if (l < min) {
+      PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got %d",
+		   name, (min == max ? "" : "at least "), (int)min, (int)l);
+      return 0;
+    } else if (l > max) {
+		   name, (min == max ? "" : "at most "), (int)max, (int)l);
+      return 0;
+    } else {
+      register int i;
+      for (i = 0; i < l; ++i) {
+	objs[i] = PyTuple_GET_ITEM(args, i);
+      for (; l < max; ++l) {
+	objs[l] = 0;
+      return i + 1;
+/* A functor is a function object with one single object argument */
+#if PY_VERSION_HEX >= 0x02020000
+#define SWIG_Python_CallFunctor(functor, obj)	        PyObject_CallFunctionObjArgs(functor, obj, NULL);
+#else
+#define SWIG_Python_CallFunctor(functor, obj)	        PyObject_CallFunction(functor, "O", obj);
+#endif
+  Helper for static pointer initialization for both C and C++ code, for example
+  static PyObject *SWIG_STATIC_POINTER(MyVar) = NewSomething(...);
+#ifdef __cplusplus
+#define SWIG_STATIC_POINTER(var)  var
+#else
+#define SWIG_STATIC_POINTER(var)  var = 0; if (!var) var
+#endif
+ * Pointer declarations
+#define SWIG_POINTER_NOSHADOW       (SWIG_POINTER_OWN      << 1)
+#define SWIG_POINTER_NEW            (SWIG_POINTER_NOSHADOW | SWIG_POINTER_OWN)
+#define SWIG_POINTER_IMPLICIT_CONV  (SWIG_POINTER_DISOWN   << 1)
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* cc-mode */
+#endif
+#endif
+/*  How to access Py_None */
+#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
+#  ifndef SWIG_PYTHON_NO_BUILD_NONE
+#    ifndef SWIG_PYTHON_BUILD_NONE
+#      define SWIG_PYTHON_BUILD_NONE
+#    endif
+#  endif
+#endif
+#ifdef SWIG_PYTHON_BUILD_NONE
+#  ifdef Py_None
+#   undef Py_None
+#   define Py_None SWIG_Py_None()
+#  endif
+SWIGRUNTIMEINLINE PyObject *
+_SWIG_Py_None(void)
+  PyObject *none = Py_BuildValue((char*)"");
+  Py_DECREF(none);
+  return none;
+SWIGRUNTIME PyObject *
+SWIG_Py_None(void)
+  static PyObject *SWIG_STATIC_POINTER(none) = _SWIG_Py_None();
+  return none;
+#endif
+/* The python void return value */
+SWIG_Py_Void(void)
+  PyObject *none = Py_None;
+  Py_INCREF(none);
+  return none;
+/* PySwigClientData */
+typedef struct {
+  PyObject *klass;
+  PyObject *newraw;
+  PyObject *newargs;
+  PyObject *destroy;
+  int delargs;
+  int implicitconv;
+} PySwigClientData;
+SWIGRUNTIMEINLINE int
+SWIG_Python_CheckImplicit(swig_type_info *ty)
+  PySwigClientData *data = (PySwigClientData *)ty->clientdata;
+  return data ? data->implicitconv : 0;
+SWIG_Python_ExceptionType(swig_type_info *desc) {
+  PySwigClientData *data = desc ? (PySwigClientData *) desc->clientdata : 0;
+  PyObject *klass = data ? data->klass : 0;
+  return (klass ? klass : PyExc_RuntimeError);
+SWIGRUNTIME PySwigClientData *
+PySwigClientData_New(PyObject* obj)
+  if (!obj) {
+    return 0;
+  } else {
+    PySwigClientData *data = (PySwigClientData *)malloc(sizeof(PySwigClientData));
+    /* the klass element */
+    data->klass = obj;
+    Py_INCREF(data->klass);
+    /* the newraw method and newargs arguments used to create a new raw instance */
+    if (PyClass_Check(obj)) {
+      data->newraw = 0;
+      data->newargs = obj;
+      Py_INCREF(obj);
+    } else {
+#if (PY_VERSION_HEX < 0x02020000)
+      data->newraw = 0;
+#else
+      data->newraw = PyObject_GetAttrString(data->klass, (char *)"__new__");
+#endif
+      if (data->newraw) {
+	Py_INCREF(data->newraw);
+	data->newargs = PyTuple_New(1);
+	PyTuple_SetItem(data->newargs, 0, obj);
+      } else {
+      Py_INCREF(data->newargs);
+    /* the destroy method, aka as the C++ delete method */
+    data->destroy = PyObject_GetAttrString(data->klass, (char *)"__swig_destroy__");
+    if (PyErr_Occurred()) {
+      PyErr_Clear();
+      data->destroy = 0;
+    if (data->destroy) {
+      int flags;
+      Py_INCREF(data->destroy);
+      flags = PyCFunction_GET_FLAGS(data->destroy);
+#ifdef METH_O
+      data->delargs = !(flags & (METH_O));
+#else
+      data->delargs = 0;
+#endif
+    } else {
+    data->implicitconv = 0;
+    return data;
+SWIGRUNTIME void
+PySwigClientData_Del(PySwigClientData* data)
+  Py_XDECREF(data->newraw);
+  Py_XDECREF(data->newargs);
+  Py_XDECREF(data->destroy);
+/* =============== PySwigObject =====================*/
+typedef struct {
+  PyObject_HEAD
+  void *ptr;
+  swig_type_info *ty;
+  int own;
+  PyObject *next;
+} PySwigObject;
+PySwigObject_long(PySwigObject *v)
+  return PyLong_FromVoidPtr(v->ptr);
+PySwigObject_format(const char* fmt, PySwigObject *v)
+  PyObject *res = NULL;
+  PyObject *args = PyTuple_New(1);
+  if (args) {
+    if (PyTuple_SetItem(args, 0, PySwigObject_long(v)) == 0) {
+      PyObject *ofmt = PyString_FromString(fmt);
+      if (ofmt) {
+	res = PyString_Format(ofmt,args);
+	Py_DECREF(ofmt);
+      Py_DECREF(args);
+  return res;
+PySwigObject_oct(PySwigObject *v)
+  return PySwigObject_format("%o",v);
+PySwigObject_hex(PySwigObject *v)
+  return PySwigObject_format("%x",v);
+#ifdef METH_NOARGS
+PySwigObject_repr(PySwigObject *v)
+#else
+PySwigObject_repr(PySwigObject *v, PyObject *args)
+#endif
+  const char *name = SWIG_TypePrettyName(v->ty);
+  PyObject *hex = PySwigObject_hex(v);
+  PyObject *repr = PyString_FromFormat("<Swig Object of type '%s' at 0x%s>", name, PyString_AsString(hex));
+  Py_DECREF(hex);
+  if (v->next) {
+#ifdef METH_NOARGS
+    PyObject *nrep = PySwigObject_repr((PySwigObject *)v->next);
+#else
+    PyObject *nrep = PySwigObject_repr((PySwigObject *)v->next, args);
+#endif
+    PyString_ConcatAndDel(&repr,nrep);
+  return repr;
+SWIGRUNTIME int
+PySwigObject_print(PySwigObject *v, FILE *fp, int SWIGUNUSEDPARM(flags))
+#ifdef METH_NOARGS
+  PyObject *repr = PySwigObject_repr(v);
+#else
+  PyObject *repr = PySwigObject_repr(v, NULL);
+#endif
+  if (repr) {
+    fputs(PyString_AsString(repr), fp);
+    Py_DECREF(repr);
+    return 0;
+  } else {
+    return 1;
+PySwigObject_str(PySwigObject *v)
+  char result[SWIG_BUFFER_SIZE];
+  return SWIG_PackVoidPtr(result, v->ptr, v->ty->name, sizeof(result)) ?
+    PyString_FromString(result) : 0;
+SWIGRUNTIME int
+PySwigObject_compare(PySwigObject *v, PySwigObject *w)
+  void *i = v->ptr;
+  void *j = w->ptr;
+  return (i < j) ? -1 : ((i > j) ? 1 : 0);
+SWIGRUNTIME PyTypeObject* _PySwigObject_type(void);
+PySwigObject_type(void) {
+  static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigObject_type();
+  return type;
+PySwigObject_Check(PyObject *op) {
+  return ((op)->ob_type == PySwigObject_type())
+    || (strcmp((op)->ob_type->tp_name,"PySwigObject") == 0);
+PySwigObject_New(void *ptr, swig_type_info *ty, int own);
+SWIGRUNTIME void
+PySwigObject_dealloc(PyObject *v)
+  PySwigObject *sobj = (PySwigObject *) v;
+  PyObject *next = sobj->next;
+  if (sobj->own) {
+    swig_type_info *ty = sobj->ty;
+    PySwigClientData *data = ty ? (PySwigClientData *) ty->clientdata : 0;
+    PyObject *destroy = data ? data->destroy : 0;
+    if (destroy) {
+      /* destroy is always a VARARGS method */
+      PyObject *res;
+      if (data->delargs) {
+	/* we need to create a temporal object to carry the destroy operation */
+	PyObject *tmp = PySwigObject_New(sobj->ptr, ty, 0);
+	res = SWIG_Python_CallFunctor(destroy, tmp);
+	Py_DECREF(tmp);
+      } else {
+	PyCFunction meth = PyCFunction_GET_FUNCTION(destroy);
+	PyObject *mself = PyCFunction_GET_SELF(destroy);
+	res = ((*meth)(mself, v));
+      Py_XDECREF(res);
+    } else {
+      const char *name = SWIG_TypePrettyName(ty);
+#if !defined(SWIG_PYTHON_SILENT_MEMLEAK)
+      printf("swig/python detected a memory leak of type '%s', no destructor found.\n", name);
+#endif
+  Py_XDECREF(next);
+  PyObject_DEL(v);
+PySwigObject_append(PyObject* v, PyObject* next)
+#ifndef METH_O
+  PyObject *tmp = 0;
+  if (!PyArg_ParseTuple(next,(char *)"O:append", &tmp)) return NULL;
+  next = tmp;
+#endif
+  if (!PySwigObject_Check(next)) {
+    return NULL;
+  sobj->next = next;
+  Py_INCREF(next);
+  return SWIG_Py_Void();
+#ifdef METH_NOARGS
+PySwigObject_next(PyObject* v)
+#else
+PySwigObject_next(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
+#endif
+  if (sobj->next) {
+    Py_INCREF(sobj->next);
+    return sobj->next;
+  } else {
+#ifdef METH_NOARGS
+PySwigObject_disown(PyObject *v)
+#else
+PySwigObject_disown(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
+#endif
+  PySwigObject *sobj = (PySwigObject *)v;
+  sobj->own = 0;
+#ifdef METH_NOARGS
+PySwigObject_acquire(PyObject *v)
+#else
+PySwigObject_acquire(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
+#endif
+  sobj->own = SWIG_POINTER_OWN;
+PySwigObject_own(PyObject *v, PyObject *args)
+  PyObject *val = 0;
+  if (!PyArg_ParseTuple(args,(char *)"|O:own",&val))
+#else
+  if (!PyArg_UnpackTuple(args, (char *)"own", 0, 1, &val))
+#endif
+      return NULL;
+  else
+      PyObject *obj = PyBool_FromLong(sobj->own);
+      if (val) {
+#ifdef METH_NOARGS
+	if (PyObject_IsTrue(val)) {
+	  PySwigObject_acquire(v);
+	} else {
+	  PySwigObject_disown(v);
+#else
+	  PySwigObject_acquire(v,args);
+	} else {
+	  PySwigObject_disown(v,args);
+#endif
+      return obj;
+#ifdef METH_O
+static PyMethodDef
+swigobject_methods[] = {
+  {(char *)"disown",  (PyCFunction)PySwigObject_disown,  METH_NOARGS,  (char *)"releases ownership of the pointer"},
+  {(char *)"acquire", (PyCFunction)PySwigObject_acquire, METH_NOARGS,  (char *)"aquires ownership of the pointer"},
+  {(char *)"own",     (PyCFunction)PySwigObject_own,     METH_VARARGS, (char *)"returns/sets ownership of the pointer"},
+  {(char *)"append",  (PyCFunction)PySwigObject_append,  METH_O,       (char *)"appends another 'this' object"},
+  {(char *)"next",    (PyCFunction)PySwigObject_next,    METH_NOARGS,  (char *)"returns the next 'this' object"},
+  {(char *)"__repr__",(PyCFunction)PySwigObject_repr,    METH_NOARGS,  (char *)"returns object representation"},
+  {0, 0, 0, 0}
+#else
+static PyMethodDef
+  {(char *)"disown",  (PyCFunction)PySwigObject_disown,  METH_VARARGS,  (char *)"releases ownership of the pointer"},
+  {(char *)"acquire", (PyCFunction)PySwigObject_acquire, METH_VARARGS,  (char *)"aquires ownership of the pointer"},
+  {(char *)"append",  (PyCFunction)PySwigObject_append,  METH_VARARGS,  (char *)"appends another 'this' object"},
+  {(char *)"next",    (PyCFunction)PySwigObject_next,    METH_VARARGS,  (char *)"returns the next 'this' object"},
+  {(char *)"__repr__",(PyCFunction)PySwigObject_repr,   METH_VARARGS,  (char *)"returns object representation"},
+  {0, 0, 0, 0}
+#endif
+SWIGINTERN PyObject *
+PySwigObject_getattr(PySwigObject *sobj,char *name)
+  return Py_FindMethod(swigobject_methods, (PyObject *)sobj, name);
+#endif
+_PySwigObject_type(void) {
+  static char swigobject_doc[] = "Swig object carries a C/C++ instance pointer";
+  static PyNumberMethods PySwigObject_as_number = {
+    (binaryfunc)0, /*nb_add*/
+    (binaryfunc)0, /*nb_subtract*/
+    (binaryfunc)0, /*nb_multiply*/
+    (binaryfunc)0, /*nb_divide*/
+    (binaryfunc)0, /*nb_remainder*/
+    (binaryfunc)0, /*nb_divmod*/
+    (ternaryfunc)0,/*nb_power*/
+    (unaryfunc)0,  /*nb_negative*/
+    (unaryfunc)0,  /*nb_positive*/
+    (unaryfunc)0,  /*nb_absolute*/
+    (inquiry)0,    /*nb_nonzero*/
+    0,		   /*nb_invert*/
+    0,		   /*nb_lshift*/
+    0,		   /*nb_rshift*/
+    0,		   /*nb_and*/
+    0,		   /*nb_xor*/
+    0,		   /*nb_or*/
+    (coercion)0,   /*nb_coerce*/
+    (unaryfunc)PySwigObject_long, /*nb_int*/
+    (unaryfunc)PySwigObject_long, /*nb_long*/
+    (unaryfunc)0,                 /*nb_float*/
+    (unaryfunc)PySwigObject_oct,  /*nb_oct*/
+    (unaryfunc)PySwigObject_hex,  /*nb_hex*/
+#if PY_VERSION_HEX >= 0x02050000 /* 2.5.0 */
+    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_index */
+#elif PY_VERSION_HEX >= 0x02020000 /* 2.2.0 */
+    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_true_divide */
+#elif PY_VERSION_HEX >= 0x02000000 /* 2.0.0 */
+    0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_or */
+#endif
+  static PyTypeObject pyswigobject_type;
+  static int type_init = 0;
+  if (!type_init) {
+    const PyTypeObject tmp
+	PyObject_HEAD_INIT(NULL)
+	0,				    /* ob_size */
+	(char *)"PySwigObject",		    /* tp_name */
+	sizeof(PySwigObject),		    /* tp_basicsize */
+	0,			            /* tp_itemsize */
+	(destructor)PySwigObject_dealloc,   /* tp_dealloc */
+	(printfunc)PySwigObject_print,	    /* tp_print */
+	(getattrfunc)PySwigObject_getattr,  /* tp_getattr */
+#else
+	(getattrfunc)0,			    /* tp_getattr */
+#endif
+	(setattrfunc)0,			    /* tp_setattr */
+	(cmpfunc)PySwigObject_compare,	    /* tp_compare */
+	(reprfunc)PySwigObject_repr,	    /* tp_repr */
+	&PySwigObject_as_number,	    /* tp_as_number */
+	0,				    /* tp_as_sequence */
+	0,				    /* tp_as_mapping */
+	(hashfunc)0,			    /* tp_hash */
+	(ternaryfunc)0,			    /* tp_call */
+	(reprfunc)PySwigObject_str,	    /* tp_str */
+	PyObject_GenericGetAttr,            /* tp_getattro */
+	0,				    /* tp_setattro */
+	0,		                    /* tp_as_buffer */
+	Py_TPFLAGS_DEFAULT,	            /* tp_flags */
+	swigobject_doc, 	            /* tp_doc */
+	0,                                  /* tp_traverse */
+	0,                                  /* tp_clear */
+	0,                                  /* tp_richcompare */
+	0,                                  /* tp_weaklistoffset */
+	0,                                  /* tp_iter */
+	0,                                  /* tp_iternext */
+	swigobject_methods,		    /* tp_methods */
+	0,			            /* tp_members */
+	0,				    /* tp_getset */
+	0,			            /* tp_base */
+	0,				    /* tp_dict */
+	0,				    /* tp_descr_get */
+	0,				    /* tp_descr_set */
+	0,				    /* tp_dictoffset */
+	0,				    /* tp_init */
+	0,				    /* tp_alloc */
+	0,			            /* tp_new */
+	0,	                            /* tp_free */
+        0,                                  /* tp_is_gc */
+	0,				    /* tp_bases */
+	0,				    /* tp_mro */
+	0,				    /* tp_cache */
+ 	0,				    /* tp_subclasses */
+	0,				    /* tp_weaklist */
+#endif
+#if PY_VERSION_HEX >= 0x02030000
+	0,                                  /* tp_del */
+#endif
+#ifdef COUNT_ALLOCS
+	0,0,0,0                             /* tp_alloc -> tp_next */
+#endif
+    pyswigobject_type = tmp;
+    pyswigobject_type.ob_type = &PyType_Type;
+    type_init = 1;
+  return &pyswigobject_type;
+  PySwigObject *sobj = PyObject_NEW(PySwigObject, PySwigObject_type());
+  if (sobj) {
+    sobj->ptr  = ptr;
+    sobj->ty   = ty;
+    sobj->own  = own;
+    sobj->next = 0;
+  return (PyObject *)sobj;
+ * Implements a simple Swig Packed type, and use it instead of string
+typedef struct {
+  PyObject_HEAD
+  void *pack;
+  size_t size;
+} PySwigPacked;
+SWIGRUNTIME int
+PySwigPacked_print(PySwigPacked *v, FILE *fp, int SWIGUNUSEDPARM(flags))
+  fputs("<Swig Packed ", fp);
+  if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))) {
+    fputs("at ", fp);
+    fputs(result, fp);
+  fputs(v->ty->name,fp);
+  fputs(">", fp);
+  return 0;
+PySwigPacked_repr(PySwigPacked *v)
+    return PyString_FromFormat("<Swig Packed at %s%s>", result, v->ty->name);
+  } else {
+    return PyString_FromFormat("<Swig Packed %s>", v->ty->name);
+PySwigPacked_str(PySwigPacked *v)
+  if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))){
+    return PyString_FromFormat("%s%s", result, v->ty->name);
+  } else {
+    return PyString_FromString(v->ty->name);
+SWIGRUNTIME int
+PySwigPacked_compare(PySwigPacked *v, PySwigPacked *w)
+  size_t i = v->size;
+  size_t j = w->size;
+  int s = (i < j) ? -1 : ((i > j) ? 1 : 0);
+  return s ? s : strncmp((char *)v->pack, (char *)w->pack, 2*v->size);
+SWIGRUNTIME PyTypeObject* _PySwigPacked_type(void);
+PySwigPacked_type(void) {
+  static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigPacked_type();
+  return type;
+PySwigPacked_Check(PyObject *op) {
+  return ((op)->ob_type == _PySwigPacked_type())
+    || (strcmp((op)->ob_type->tp_name,"PySwigPacked") == 0);
+SWIGRUNTIME void
+PySwigPacked_dealloc(PyObject *v)
+  if (PySwigPacked_Check(v)) {
+    PySwigPacked *sobj = (PySwigPacked *) v;
+    free(sobj->pack);
+  PyObject_DEL(v);
+_PySwigPacked_type(void) {
+  static char swigpacked_doc[] = "Swig object carries a C/C++ instance pointer";
+  static PyTypeObject pyswigpacked_type;
+  if (!type_init) {
+	0,				    /* ob_size */
+	(char *)"PySwigPacked",		    /* tp_name */
+	sizeof(PySwigPacked),		    /* tp_basicsize */
+	(destructor)PySwigPacked_dealloc,   /* tp_dealloc */
+	(printfunc)PySwigPacked_print,	    /* tp_print */
+	(cmpfunc)PySwigPacked_compare,	    /* tp_compare */
+	(reprfunc)PySwigPacked_repr,	    /* tp_repr */
+	0,	                            /* tp_as_number */
+	(reprfunc)PySwigPacked_str,	    /* tp_str */
+	swigpacked_doc, 	            /* tp_doc */
+	0,                                  /* tp_clear */
+	0,                                  /* tp_iter */
+	0,		                    /* tp_methods */
+	0,			            /* tp_base */
+	0,				    /* tp_dict */
+	0,				    /* tp_init */
+	0,				    /* tp_alloc */
+	0,			            /* tp_new */
+	0, 	                            /* tp_free */
+        0,                                  /* tp_is_gc */
+	0,				    /* tp_bases */
+	0,				    /* tp_mro */
+	0,				    /* tp_cache */
+#endif
+	0,                                  /* tp_del */
+#endif
+#endif
+    pyswigpacked_type = tmp;
+    pyswigpacked_type.ob_type = &PyType_Type;
+    type_init = 1;
+  return &pyswigpacked_type;
+PySwigPacked_New(void *ptr, size_t size, swig_type_info *ty)
+  PySwigPacked *sobj = PyObject_NEW(PySwigPacked, PySwigPacked_type());
+  if (sobj) {
+    void *pack = malloc(size);
+    if (pack) {
+      memcpy(pack, ptr, size);
+      sobj->pack = pack;
+      sobj->ty   = ty;
+      sobj->size = size;
+    } else {
+      PyObject_DEL((PyObject *) sobj);
+      sobj = 0;
+  return (PyObject *) sobj;
+PySwigPacked_UnpackData(PyObject *obj, void *ptr, size_t size)
+  if (PySwigPacked_Check(obj)) {
+    PySwigPacked *sobj = (PySwigPacked *)obj;
+    if (sobj->size != size) return 0;
+    memcpy(ptr, sobj->pack, size);
+    return sobj->ty;
+  } else {
+    return 0;
+ * pointers/data manipulation
+_SWIG_This(void)
+  return PyString_FromString("this");
+SWIG_This(void)
+  static PyObject *SWIG_STATIC_POINTER(swig_this) = _SWIG_This();
+  return swig_this;
+/* #define SWIG_PYTHON_SLOW_GETSET_THIS */
+SWIGRUNTIME PySwigObject *
+SWIG_Python_GetSwigThis(PyObject *pyobj)
+  if (PySwigObject_Check(pyobj)) {
+    return (PySwigObject *) pyobj;
+  } else {
+    PyObject *obj = 0;
+#if (!defined(SWIG_PYTHON_SLOW_GETSET_THIS) && (PY_VERSION_HEX >= 0x02030000))
+    if (PyInstance_Check(pyobj)) {
+      obj = _PyInstance_Lookup(pyobj, SWIG_This());
+    } else {
+      PyObject **dictptr = _PyObject_GetDictPtr(pyobj);
+      if (dictptr != NULL) {
+	PyObject *dict = *dictptr;
+	obj = dict ? PyDict_GetItem(dict, SWIG_This()) : 0;
+      } else {
+#ifdef PyWeakref_CheckProxy
+	if (PyWeakref_CheckProxy(pyobj)) {
+	  PyObject *wobj = PyWeakref_GET_OBJECT(pyobj);
+	  return wobj ? SWIG_Python_GetSwigThis(wobj) : 0;
+#endif
+	obj = PyObject_GetAttr(pyobj,SWIG_This());
+	if (obj) {
+	  Py_DECREF(obj);
+	} else {
+	  if (PyErr_Occurred()) PyErr_Clear();
+	  return 0;
+#else
+    if (obj) {
+      Py_DECREF(obj);
+    } else {
+      return 0;
+#endif
+    if (obj && !PySwigObject_Check(obj)) {
+      /* a PyObject is called 'this', try to get the 'real this'
+	 PySwigObject from it */
+      return SWIG_Python_GetSwigThis(obj);
+    return (PySwigObject *)obj;
+/* Acquire a pointer value */
+SWIGRUNTIME int
+SWIG_Python_AcquirePtr(PyObject *obj, int own) {
+  if (own) {
+    PySwigObject *sobj = SWIG_Python_GetSwigThis(obj);
+    if (sobj) {
+      int oldown = sobj->own;
+      sobj->own = own;
+      return oldown;
+  return 0;
+/* Convert a pointer value */
+SWIGRUNTIME int
+SWIG_Python_ConvertPtrAndOwn(PyObject *obj, void **ptr, swig_type_info *ty, int flags, int *own) {
+  if (!obj) return SWIG_ERROR;
+  if (obj == Py_None) {
+    if (ptr) *ptr = 0;
+    return SWIG_OK;
+  } else {
+    while (sobj) {
+      void *vptr = sobj->ptr;
+      if (ty) {
+	swig_type_info *to = sobj->ty;
+	if (to == ty) {
+	  /* no type cast needed */
+	  if (ptr) *ptr = vptr;
+	  break;
+	} else {
+	  swig_cast_info *tc = SWIG_TypeCheck(to->name,ty);
+	  if (!tc) {
+	    sobj = (PySwigObject *)sobj->next;
+	  } else {
+	    if (ptr) *ptr = SWIG_TypeCast(tc,vptr);
+	    break;
+      } else {
+	break;
+    if (sobj) {
+      if (own) *own = sobj->own;
+      if (flags & SWIG_POINTER_DISOWN) {
+	sobj->own = 0;
+      return SWIG_OK;
+    } else {
+      int res = SWIG_ERROR;
+      if (flags & SWIG_POINTER_IMPLICIT_CONV) {
+	if (data && !data->implicitconv) {
+	  PyObject *klass = data->klass;
+	  if (klass) {
+	    PyObject *impconv;
+	    data->implicitconv = 1; /* avoid recursion and call 'explicit' constructors*/
+	    impconv = SWIG_Python_CallFunctor(klass, obj);
+	      PyErr_Clear();
+	      impconv = 0;
+	    if (impconv) {
+	      PySwigObject *iobj = SWIG_Python_GetSwigThis(impconv);
+	      if (iobj) {
+		void *vptr;
+		res = SWIG_Python_ConvertPtrAndOwn((PyObject*)iobj, &vptr, ty, 0, 0);
+		  if (ptr) {
+		    *ptr = vptr;
+		    /* transfer the ownership to 'ptr' */
+		    iobj->own = 0;
+		    res = SWIG_AddCast(res);
+		    res = SWIG_AddNewMask(res);
+		  } else {
+	      Py_DECREF(impconv);
+      return res;
+/* Convert a function ptr value */
+SWIGRUNTIME int
+SWIG_Python_ConvertFunctionPtr(PyObject *obj, void **ptr, swig_type_info *ty) {
+  if (!PyCFunction_Check(obj)) {
+    return SWIG_ConvertPtr(obj, ptr, ty, 0);
+  } else {
+    void *vptr = 0;
+    /* here we get the method pointer for callbacks */
+    const char *doc = (((PyCFunctionObject *)obj) -> m_ml -> ml_doc);
+    const char *desc = doc ? strstr(doc, "swig_ptr: ") : 0;
+    if (desc) {
+      desc = ty ? SWIG_UnpackVoidPtr(desc + 10, &vptr, ty->name) : 0;
+      if (!desc) return SWIG_ERROR;
+    if (ty) {
+      swig_cast_info *tc = SWIG_TypeCheck(desc,ty);
+      if (!tc) return SWIG_ERROR;
+      *ptr = SWIG_TypeCast(tc,vptr);
+    } else {
+      *ptr = vptr;
+    return SWIG_OK;
+/* Convert a packed value value */
+SWIGRUNTIME int
+SWIG_Python_ConvertPacked(PyObject *obj, void *ptr, size_t sz, swig_type_info *ty) {
+  swig_type_info *to = PySwigPacked_UnpackData(obj, ptr, sz);
+  if (!to) return SWIG_ERROR;
+  if (ty) {
+    if (to != ty) {
+      /* check type cast? */
+  return SWIG_OK;
+ * Create a new pointer object
+  Create a new instance object, whitout calling __init__, and set the
+  'this' attribute.
+SWIG_Python_NewShadowInstance(PySwigClientData *data, PyObject *swig_this)
+#if (PY_VERSION_HEX >= 0x02020000)
+  PyObject *inst = 0;
+  PyObject *newraw = data->newraw;
+  if (newraw) {
+    inst = PyObject_Call(newraw, data->newargs, NULL);
+    if (inst) {
+#if !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
+      PyObject **dictptr = _PyObject_GetDictPtr(inst);
+	if (dict == NULL) {
+	  dict = PyDict_New();
+	  *dictptr = dict;
+	  PyDict_SetItem(dict, SWIG_This(), swig_this);
+#else
+      PyObject *key = SWIG_This();
+      PyObject_SetAttr(inst, key, swig_this);
+#endif
+  } else {
+    PyObject *dict = PyDict_New();
+    inst = PyInstance_NewRaw(data->newargs, dict);
+    Py_DECREF(dict);
+  return inst;
+#else
+#if (PY_VERSION_HEX >= 0x02010000)
+  PyObject *inst;
+  Py_DECREF(dict);
+  return (PyObject *) inst;
+#else
+  PyInstanceObject *inst = PyObject_NEW(PyInstanceObject, &PyInstance_Type);
+  if (inst == NULL) {
+    return NULL;
+  inst->in_class = (PyClassObject *)data->newargs;
+  Py_INCREF(inst->in_class);
+  inst->in_dict = PyDict_New();
+  if (inst->in_dict == NULL) {
+    Py_DECREF(inst);
+    return NULL;
+#ifdef Py_TPFLAGS_HAVE_WEAKREFS
+  inst->in_weakreflist = NULL;
+#endif
+#ifdef Py_TPFLAGS_GC
+  PyObject_GC_Init(inst);
+#endif
+  PyDict_SetItem(inst->in_dict, SWIG_This(), swig_this);
+#endif
+#endif
+SWIGRUNTIME void
+SWIG_Python_SetSwigThis(PyObject *inst, PyObject *swig_this)
+ PyObject *dict;
+#if (PY_VERSION_HEX >= 0x02020000) && !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
+   dict = *dictptr;
+     *dictptr = dict;
+   return;
+#endif
+ dict = PyObject_GetAttrString(inst, (char*)"__dict__");
+ Py_DECREF(dict);
+SWIG_Python_InitShadowInstance(PyObject *args) {
+  PyObject *obj[2];
+  if (!SWIG_Python_UnpackTuple(args,(char*)"swiginit", 2, 2, obj)) {
+    return NULL;
+  } else {
+    PySwigObject *sthis = SWIG_Python_GetSwigThis(obj[0]);
+    if (sthis) {
+      PySwigObject_append((PyObject*) sthis, obj[1]);
+    } else {
+      SWIG_Python_SetSwigThis(obj[0], obj[1]);
+/* Create a new pointer object */
+SWIG_Python_NewPointerObj(void *ptr, swig_type_info *type, int flags) {
+  if (!ptr) {
+  } else {
+    int own = (flags & SWIG_POINTER_OWN) ? SWIG_POINTER_OWN : 0;
+    PyObject *robj = PySwigObject_New(ptr, type, own);
+    PySwigClientData *clientdata = type ? (PySwigClientData *)(type->clientdata) : 0;
+    if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
+      PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
+      if (inst) {
+	Py_DECREF(robj);
+	robj = inst;
+    return robj;
+/* Create a new packed object */
+SWIG_Python_NewPackedObj(void *ptr, size_t sz, swig_type_info *type) {
+  return ptr ? PySwigPacked_New((void *) ptr, sz, type) : SWIG_Py_Void();
+ *  Get type list
+#ifdef SWIG_LINK_RUNTIME
+void *SWIG_ReturnGlobalTypeList(void *);
+#endif
+SWIGRUNTIME swig_module_info *
+SWIG_Python_GetModule(void) {
+  static void *type_pointer = (void *)0;
+  /* first check if module already created */
+  if (!type_pointer) {
+    type_pointer = SWIG_ReturnGlobalTypeList((void *)0);
+#else
+    type_pointer = PyCObject_Import((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
+				    (char*)"type_pointer" SWIG_TYPE_TABLE_NAME);
+      PyErr_Clear();
+      type_pointer = (void *)0;
+#endif
+  return (swig_module_info *) type_pointer;
+#if PY_MAJOR_VERSION < 2
+/* PyModule_AddObject function was introduced in Python 2.0.  The following function
+   is copied out of Python/modsupport.c in python version 2.3.4 */
+SWIGINTERN int
+PyModule_AddObject(PyObject *m, char *name, PyObject *o)
+  PyObject *dict;
+  if (!PyModule_Check(m)) {
+    PyErr_SetString(PyExc_TypeError,
+		    "PyModule_AddObject() needs module as first arg");
+    return SWIG_ERROR;
+  if (!o) {
+		    "PyModule_AddObject() needs non-NULL value");
+  dict = PyModule_GetDict(m);
+    /* Internal error -- modules must have a dict! */
+    PyErr_Format(PyExc_SystemError, "module '%s' has no __dict__",
+		 PyModule_GetName(m));
+  if (PyDict_SetItemString(dict, name, o))
+  Py_DECREF(o);
+  return SWIG_OK;
+#endif
+SWIGRUNTIME void
+SWIG_Python_DestroyModule(void *vptr)
+  swig_module_info *swig_module = (swig_module_info *) vptr;
+  swig_type_info **types = swig_module->types;
+  size_t i;
+  for (i =0; i < swig_module->size; ++i) {
+    swig_type_info *ty = types[i];
+    if (ty->owndata) {
+      PySwigClientData *data = (PySwigClientData *) ty->clientdata;
+      if (data) PySwigClientData_Del(data);
+  Py_DECREF(SWIG_This());
+SWIGRUNTIME void
+SWIG_Python_SetModule(swig_module_info *swig_module) {
+  static PyMethodDef swig_empty_runtime_method_table[] = { {NULL, NULL, 0, NULL} };/* Sentinel */
+  PyObject *module = Py_InitModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
+				   swig_empty_runtime_method_table);
+  PyObject *pointer = PyCObject_FromVoidPtr((void *) swig_module, SWIG_Python_DestroyModule);
+  if (pointer && module) {
+    PyModule_AddObject(module, (char*)"type_pointer" SWIG_TYPE_TABLE_NAME, pointer);
+  } else {
+    Py_XDECREF(pointer);
+/* The python cached type query */
+SWIG_Python_TypeCache(void) {
+  static PyObject *SWIG_STATIC_POINTER(cache) = PyDict_New();
+  return cache;
+SWIG_Python_TypeQuery(const char *type)
+  PyObject *cache = SWIG_Python_TypeCache();
+  PyObject *key = PyString_FromString(type);
+  PyObject *obj = PyDict_GetItem(cache, key);
+  swig_type_info *descriptor;
+  if (obj) {
+    descriptor = (swig_type_info *) PyCObject_AsVoidPtr(obj);
+  } else {
+    swig_module_info *swig_module = SWIG_Python_GetModule();
+    descriptor = SWIG_TypeQueryModule(swig_module, swig_module, type);
+    if (descriptor) {
+      obj = PyCObject_FromVoidPtr(descriptor, NULL);
+      PyDict_SetItem(cache, key, obj);
+      Py_DECREF(obj);
+  Py_DECREF(key);
+  return descriptor;
+   For backward compatibility only
+#define SWIG_POINTER_EXCEPTION  0
+#define SWIG_arg_fail(arg)      SWIG_Python_ArgFail(arg)
+#define SWIG_MustGetPtr(p, type, argnum, flags)  SWIG_Python_MustGetPtr(p, type, argnum, flags)
+SWIGRUNTIME int
+SWIG_Python_AddErrMesg(const char* mesg, int infront)
+    PyErr_Fetch(&type, &value, &traceback);
+    if (value) {
+      Py_XINCREF(type);
+      PyErr_Clear();
+      if (infront) {
+	PyErr_Format(type, "%s %s", mesg, PyString_AsString(old_str));
+      } else {
+    return 1;
+  } else {
+    return 0;
+SWIGRUNTIME int
+SWIG_Python_ArgFail(int argnum)
+    /* add information about failing argument */
+    char mesg[256];
+    PyOS_snprintf(mesg, sizeof(mesg), "argument number %d:", argnum);
+    return SWIG_Python_AddErrMesg(mesg, 1);
+  } else {
+    return 0;
+PySwigObject_GetDesc(PyObject *self)
+  PySwigObject *v = (PySwigObject *)self;
+  swig_type_info *ty = v ? v->ty : 0;
+  return ty ? ty->str : (char*)"";
+SWIGRUNTIME void
+SWIG_Python_TypeError(const char *type, PyObject *obj)
+  if (type) {
+#if defined(SWIG_COBJECT_TYPES)
+    if (obj && PySwigObject_Check(obj)) {
+      const char *otype = (const char *) PySwigObject_GetDesc(obj);
+      if (otype) {
+	PyErr_Format(PyExc_TypeError, "a '%s' is expected, 'PySwigObject(%s)' is received",
+		     type, otype);
+	return;
+    } else
+#endif
+      const char *otype = (obj ? obj->ob_type->tp_name : 0);
+      if (otype) {
+	PyObject *str = PyObject_Str(obj);
+	const char *cstr = str ? PyString_AsString(str) : 0;
+	if (cstr) {
+	  PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s(%s)' is received",
+		       type, otype, cstr);
+	} else {
+	  PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s' is received",
+		       type, otype);
+	Py_XDECREF(str);
+	return;
+    PyErr_Format(PyExc_TypeError, "a '%s' is expected", type);
+  } else {
+    PyErr_Format(PyExc_TypeError, "unexpected type is received");
+/* Convert a pointer value, signal an exception on a type mismatch */
+SWIGRUNTIME void *
+SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int argnum, int flags) {
+  void *result;
+  if (SWIG_Python_ConvertPtr(obj, &result, ty, flags) == -1) {
+    PyErr_Clear();
+    if (flags & SWIG_POINTER_EXCEPTION) {
+      SWIG_Python_TypeError(SWIG_TypePrettyName(ty), obj);
+      SWIG_Python_ArgFail(argnum);
+  return result;
+#ifdef __cplusplus
+#if 0
+{ /* cc-mode */
+#endif
+#endif
+#define SWIG_exception_fail(code, msg) do { SWIG_Error(code, msg); SWIG_fail; } while(0)
+#define SWIG_contract_assert(expr, msg) if (!(expr)) { SWIG_Error(SWIG_RuntimeError, msg); SWIG_fail; } else
+  #define SWIG_exception(code, msg) do { SWIG_Error(code, msg); SWIG_fail;; } while(0)
+/* -------- TYPES TABLE (BEGIN) -------- */
+#define SWIGTYPE_p_Digit swig_types[0]
+#define SWIGTYPE_p_DisplayDriver swig_types[1]
+#define SWIGTYPE_p_allocator_type swig_types[2]
+#define SWIGTYPE_p_char swig_types[3]
+#define SWIGTYPE_p_difference_type swig_types[4]
+#define SWIGTYPE_p_key_type swig_types[5]
+#define SWIGTYPE_p_mapped_type swig_types[6]
+#define SWIGTYPE_p_p_PyObject swig_types[7]
+#define SWIGTYPE_p_size_type swig_types[8]
+#define SWIGTYPE_p_std__invalid_argument swig_types[9]
+#define SWIGTYPE_p_std__lessTint_t swig_types[10]
+#define SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t swig_types[11]
+#define SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type swig_types[12]
+#define SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t swig_types[13]
+#define SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type swig_types[14]
+#define SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t swig_types[15]
+#define SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t__allocator_type swig_types[16]
+#define SWIGTYPE_p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t swig_types[17]
+#define SWIGTYPE_p_swig__PySwigIterator swig_types[18]
+#define SWIGTYPE_p_value_type swig_types[19]
+static swig_type_info *swig_types[21];
+static swig_module_info swig_module = {swig_types, 20, 0, 0, 0, 0};
+#define SWIG_TypeQuery(name) SWIG_TypeQueryModule(&swig_module, &swig_module, name)
+#define SWIG_MangledTypeQuery(name) SWIG_MangledTypeQueryModule(&swig_module, &swig_module, name)
+/* -------- TYPES TABLE (END) -------- */
+#if (PY_VERSION_HEX <= 0x02000000)
+# if !defined(SWIG_PYTHON_CLASSIC)
+#  error "This python version requires swig to be run with the '-classic' option"
+# endif
+#endif
+              @(target):= _grass6_wxvdigit.so
+#define SWIG_init    init_grass6_wxvdigit
+#define SWIG_name    "_grass6_wxvdigit"
+#define SWIGVERSION 0x010333
+#define SWIG_VERSION SWIGVERSION
+#define SWIG_as_voidptr(a) const_cast< void * >(static_cast< const void * >(a))
+#define SWIG_as_voidptrptr(a) ((void)SWIG_as_voidptr(*a),reinterpret_cast< void** >(a))
+#include <stdexcept>
+namespace swig {
+  class PyObject_ptr {
+  protected:
+    PyObject *_obj;
+  public:
+    PyObject_ptr() :_obj(0)
+    PyObject_ptr(const PyObject_ptr& item) : _obj(item._obj)
+      Py_XINCREF(_obj);
+    PyObject_ptr(PyObject *obj, bool initial_ref = true) :_obj(obj)
+      if (initial_ref) Py_XINCREF(_obj);
+    PyObject_ptr & operator=(const PyObject_ptr& item)
+      Py_XINCREF(item._obj);
+      Py_XDECREF(_obj);
+      _obj = item._obj;
+      return *this;
+    ~PyObject_ptr()
+      Py_XDECREF(_obj);
+    operator PyObject *() const
+      return _obj;
+    PyObject *operator->() const
+      return _obj;
+namespace swig {
+  struct PyObject_var : PyObject_ptr {
+    PyObject_var(PyObject* obj = 0) : PyObject_ptr(obj, false) { }
+    PyObject_var & operator = (PyObject* obj)
+      Py_XDECREF(_obj);
+      _obj = obj;
+      return *this;
+#include <grass/gis.h>
+#include <grass/gisdefs.h>
+#include <grass/Vect.h>
+#include <grass/vect/dig_structs.h>
+#include "driver.h"
+#include "digit.h"
+#include <iostream>
+#if defined(__SUNPRO_CC) && defined(_RWSTD_VER)
+#  define SWIG_STD_NOASSIGN_STL
+#  define SWIG_STD_NOINSERT_TEMPLATE_STL
+#  define SWIG_STD_NOITERATOR_TRAITS_STL
+#endif
+#if defined(__GNUC__)
+#  if __GNUC__ == 2 && __GNUC_MINOR <= 96
+#     define SWIG_STD_NOMODERN_STL
+#  endif
+#endif
+#include <string>
+namespace swig {
+  struct stop_iteration {
+  struct PySwigIterator {
+  private:
+    PyObject_ptr _seq;
+  protected:
+    PySwigIterator(PyObject *seq) : _seq(seq)
+  public:
+    virtual ~PySwigIterator() {}
+    // Access iterator method, required by Python
+    virtual PyObject *value() const = 0;
+    // Forward iterator method, required by Python
+    virtual PySwigIterator *incr(size_t n = 1) = 0;
+    // Backward iterator method, very common in C++, but not required in Python
+    virtual PySwigIterator *decr(size_t n = 1)
+      throw stop_iteration();
+    // Random access iterator methods, but not required in Python
+    virtual ptrdiff_t distance(const PySwigIterator &x) const
+      throw std::invalid_argument("operation not supported");
+    virtual bool equal (const PySwigIterator &x) const
+    // C++ common/needed methods
+    virtual PySwigIterator *copy() const = 0;
+    PyObject *next()
+      PyObject *obj = value();
+      incr();
+      return obj;
+    PyObject *previous()
+      decr();
+      return value();
+    PySwigIterator *advance(ptrdiff_t n)
+      return  (n > 0) ?  incr(n) : decr(-n);
+    bool operator == (const PySwigIterator& x)  const
+      return equal(x);
+    bool operator != (const PySwigIterator& x) const
+      return ! operator==(x);
+    PySwigIterator& operator += (ptrdiff_t n)
+      return *advance(n);
+    PySwigIterator& operator -= (ptrdiff_t n)
+      return *advance(-n);
+    PySwigIterator* operator + (ptrdiff_t n) const
+      return copy()->advance(n);
+    PySwigIterator* operator - (ptrdiff_t n) const
+      return copy()->advance(-n);
+    ptrdiff_t operator - (const PySwigIterator& x) const
+      return x.distance(*this);
+    static swig_type_info* descriptor() {
+      static int init = 0;
+      static swig_type_info* desc = 0;
+      if (!init) {
+	desc = SWIG_TypeQuery("swig::PySwigIterator *");
+	init = 1;
+      return desc;
+SWIGINTERN int
+SWIG_AsVal_double (PyObject *obj, double *val)
+  int res = SWIG_TypeError;
+  if (PyFloat_Check(obj)) {
+    if (val) *val = PyFloat_AsDouble(obj);
+    return SWIG_OK;
+  } else if (PyInt_Check(obj)) {
+    if (val) *val = PyInt_AsLong(obj);
+    return SWIG_OK;
+  } else if (PyLong_Check(obj)) {
+    double v = PyLong_AsDouble(obj);
+    if (!PyErr_Occurred()) {
+      if (val) *val = v;
+      return SWIG_OK;
+    } else {
+      PyErr_Clear();
+#ifdef SWIG_PYTHON_CAST_MODE
+    int dispatch = 0;
+    double d = PyFloat_AsDouble(obj);
+      if (val) *val = d;
+      return SWIG_AddCast(SWIG_OK);
+    } else {
+      PyErr_Clear();
+    if (!dispatch) {
+      long v = PyLong_AsLong(obj);
+	return SWIG_AddCast(SWIG_AddCast(SWIG_OK));
+      } else {
+	PyErr_Clear();
+#endif
+  return res;
+#include <float.h>
+#include <math.h>
+SWIG_CanCastAsInteger(double *d, double min, double max) {
+  double x = *d;
+  if ((min <= x && x <= max)) {
+   double fx = floor(x);
+   double cx = ceil(x);
+   double rd =  ((x - fx) < 0.5) ? fx : cx; /* simple rint */
+   if ((errno == EDOM) || (errno == ERANGE)) {
+     errno = 0;
+   } else {
+     double summ, reps, diff;
+     if (rd < x) {
+       diff = x - rd;
+     } else if (rd > x) {
+       diff = rd - x;
+     } else {
+       return 1;
+     summ = rd + x;
+     reps = diff/summ;
+     if (reps < 8*DBL_EPSILON) {
+       *d = rd;
+       return 1;
+  return 0;
+SWIGINTERN int
+SWIG_AsVal_unsigned_SS_long (PyObject *obj, unsigned long *val)
+  if (PyInt_Check(obj)) {
+    long v = PyInt_AsLong(obj);
+    if (v >= 0) {
+      return SWIG_OK;
+    } else {
+      return SWIG_OverflowError;
+    unsigned long v = PyLong_AsUnsignedLong(obj);
+      return SWIG_OK;
+    } else {
+      PyErr_Clear();
+    int dispatch = 0;
+    } else {
+      PyErr_Clear();
+    if (!dispatch) {
+      double d;
+      int res = SWIG_AddCast(SWIG_AsVal_double (obj,&d));
+      if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, 0, ULONG_MAX)) {
+	if (val) *val = (unsigned long)(d);
+	return res;
+#endif
+  return SWIG_TypeError;
+SWIG_AsVal_size_t (PyObject * obj, size_t *val)
+  unsigned long v;
+  int res = SWIG_AsVal_unsigned_SS_long (obj, val ? &v : 0);
+  if (SWIG_IsOK(res) && val) *val = static_cast< size_t >(v);
+  return res;
+  #define SWIG_From_long   PyInt_FromLong
+SWIGINTERNINLINE PyObject *
+SWIG_From_ptrdiff_t  (ptrdiff_t value)
+  return SWIG_From_long  (static_cast< long >(value));
+SWIGINTERNINLINE PyObject*
+  SWIG_From_bool  (bool value)
+  return PyBool_FromLong(value ? 1 : 0);
+SWIGINTERN int
+SWIG_AsVal_long (PyObject *obj, long* val)
+    return SWIG_OK;
+      return SWIG_OK;
+    } else {
+      PyErr_Clear();
+    int dispatch = 0;
+    } else {
+      PyErr_Clear();
+    if (!dispatch) {
+      double d;
+      if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, LONG_MIN, LONG_MAX)) {
+	if (val) *val = (long)(d);
+	return res;
+#endif
+SWIG_AsVal_ptrdiff_t (PyObject * obj, ptrdiff_t *val)
+  long v;
+  int res = SWIG_AsVal_long (obj, val ? &v : 0);
+  if (SWIG_IsOK(res) && val) *val = static_cast< ptrdiff_t >(v);
+  return res;
+#include <algorithm>
+#include <vector>
+namespace swig {
+  template <class Type>
+  struct noconst_traits {
+    typedef Type noconst_type;
+  struct noconst_traits<const Type> {
+    type categories
+  struct pointer_category { };
+  struct value_category { };
+    General traits that provides type_name and type_info
+  template <class Type> struct traits { };
+  inline const char* type_name() {
+    return traits<typename noconst_traits<Type >::noconst_type >::type_name();
+  struct traits_info {
+    static swig_type_info *type_query(std::string name) {
+      name += " *";
+      return SWIG_TypeQuery(name.c_str());
+    static swig_type_info *type_info() {
+      static swig_type_info *info = type_query(type_name<Type>());
+      return info;
+  inline swig_type_info *type_info() {
+    return traits_info<Type>::type_info();
+    Partial specialization for pointers
+  template <class Type> struct traits <Type *> {
+    typedef pointer_category category;
+    static std::string make_ptr_name(const char* name) {
+      std::string ptrname = name;
+      ptrname += " *";
+      return ptrname;
+    static const char* type_name() {
+      static std::string name = make_ptr_name(swig::type_name<Type>());
+      return name.c_str();
+  template <class Type, class Category>
+  struct traits_as { };
+  struct traits_check { };
+namespace swig {
+    Traits that provides the from method
+  template <class Type> struct traits_from_ptr {
+    static PyObject *from(Type *val, int owner = 0) {
+      return SWIG_NewPointerObj(val, type_info<Type>(), owner);
+  template <class Type> struct traits_from {
+    static PyObject *from(const Type& val) {
+      return traits_from_ptr<Type>::from(new Type(val), 1);
+  template <class Type> struct traits_from<Type *> {
+    static PyObject *from(Type* val) {
+      return traits_from_ptr<Type>::from(val, 0);
+  template <class Type> struct traits_from<const Type *> {
+    static PyObject *from(const Type* val) {
+      return traits_from_ptr<Type>::from(const_cast<Type*>(val), 0);
+  inline PyObject *from(const Type& val) {
+    return traits_from<Type>::from(val);
+  inline PyObject *from_ptr(Type* val, int owner) {
+    return traits_from_ptr<Type>::from(val, owner);
+    Traits that provides the asval/as/check method
+  struct traits_asptr {
+    static int asptr(PyObject *obj, Type **val) {
+      Type *p;
+      int res = (SWIG_ConvertPtr(obj, (void**)&p, type_info<Type>(), 0) == SWIG_OK) ? SWIG_OLDOBJ : 0;
+      if (SWIG_IsOK(res)) {
+	if (val) *val = p;
+      return res;
+  inline int asptr(PyObject *obj, Type **vptr) {
+    return traits_asptr<Type>::asptr(obj, vptr);
+  struct traits_asval {
+    static int asval(PyObject *obj, Type *val) {
+      if (val) {
+	Type *p = 0;
+	int res = traits_asptr<Type>::asptr(obj, &p);
+	if (!SWIG_IsOK(res)) return res;
+	if (p) {
+	  typedef typename noconst_traits<Type>::noconst_type noconst_type;
+	  *(const_cast<noconst_type*>(val)) = *p;
+	  if (SWIG_IsNewObj(res)){
+	    delete p;
+	    res = SWIG_DelNewMask(res);
+	  return res;
+	} else {
+      } else {
+	return traits_asptr<Type>::asptr(obj, (Type **)(0));
+  template <class Type> struct traits_asval<Type*> {
+    static int asval(PyObject *obj, Type **val) {
+      if (val) {
+        noconst_type *p = 0;
+        int res = traits_asptr<noconst_type>::asptr(obj,  &p);
+          *(const_cast<noconst_type**>(val)) = p;
+	return res;
+      } else {
+  inline int asval(PyObject *obj, Type *val) {
+    return traits_asval<Type>::asval(obj, val);
+  struct traits_as<Type, value_category> {
+    static Type as(PyObject *obj, bool throw_error) {
+      Type v;
+      int res = asval(obj, &v);
+      if (!obj || !SWIG_IsOK(res)) {
+	  SWIG_Error(SWIG_TypeError,  swig::type_name<Type>());
+	if (throw_error) throw std::invalid_argument("bad type");
+      return v;
+  struct traits_as<Type, pointer_category> {
+      Type *v = 0;
+      int res = (obj ? traits_asptr<Type>::asptr(obj, &v) : SWIG_ERROR);
+      if (SWIG_IsOK(res) && v) {
+	if (SWIG_IsNewObj(res)) {
+	  Type r(*v);
+	  delete v;
+	  return r;
+	} else {
+	  return *v;
+      } else {
+	// Uninitialized return value, no Type() constructor required.
+	static Type *v_def = (Type*) malloc(sizeof(Type));
+	memset(v_def,0,sizeof(Type));
+	return *v_def;
+  struct traits_as<Type*, pointer_category> {
+    static Type* as(PyObject *obj, bool throw_error) {
+      Type *v = 0;
+	return v;
+      } else {
+	return 0;
+  inline Type as(PyObject *obj, bool te = false) {
+    return traits_as<Type, typename traits<Type>::category>::as(obj, te);
+  struct traits_check<Type, value_category> {
+    static bool check(PyObject *obj) {
+      int res = obj ? asval(obj, (Type *)(0)) : SWIG_ERROR;
+      return SWIG_IsOK(res) ? true : false;
+  struct traits_check<Type, pointer_category> {
+      int res = obj ? asptr(obj, (Type **)(0)) : SWIG_ERROR;
+  inline bool check(PyObject *obj) {
+    return traits_check<Type, typename traits<Type>::category>::check(obj);
+#include <functional>
+namespace std {
+  template <>
+  struct less <PyObject *>: public binary_function<PyObject *, PyObject *, bool>
+    bool
+    operator()(PyObject * v, PyObject *w) const
+      bool res;
+      res = PyObject_Compare(v, w) < 0;
+      return res;
+  template <>
+  struct less <swig::PyObject_ptr>: public binary_function<swig::PyObject_ptr, swig::PyObject_ptr, bool>
+    bool
+    operator()(const swig::PyObject_ptr& v, const swig::PyObject_ptr& w) const
+      return std::less<PyObject *>()(v, w);
+  template <>
+  struct less <swig::PyObject_var>: public binary_function<swig::PyObject_var, swig::PyObject_var, bool>
+    bool
+    operator()(const swig::PyObject_var& v, const swig::PyObject_var& w) const
+namespace swig {
+  template <> struct traits<PyObject *> {
+    typedef value_category category;
+    static const char* type_name() { return "PyObject *"; }
+  template <>  struct traits_asval<PyObject * > {
+    typedef PyObject * value_type;
+    static int asval(PyObject *obj, value_type *val) {
+      if (val) *val = obj;
+      return SWIG_OK;
+  template <>
+  struct traits_check<PyObject *, value_category> {
+    static bool check(PyObject *) {
+      return true;
+  template <>  struct traits_from<PyObject *> {
+    static PyObject *from(const value_type& val) {
+      Py_XINCREF(val);
+      return val;
+namespace swig {
+  inline size_t
+  check_index(ptrdiff_t i, size_t size, bool insert = false) {
+    if ( i < 0 ) {
+      if ((size_t) (-i) <= size)
+	return (size_t) (i + size);
+    } else if ( (size_t) i < size ) {
+      return (size_t) i;
+    } else if (insert && ((size_t) i == size)) {
+      return size;
+    throw std::out_of_range("index out of range");
+  inline size_t
+  slice_index(ptrdiff_t i, size_t size) {
+    if ( i < 0 ) {
+      if ((size_t) (-i) <= size) {
+      } else {
+    } else {
+      return ( (size_t) i < size ) ? ((size_t) i) : size;
+  template <class Sequence, class Difference>
+  inline typename Sequence::iterator
+  getpos(Sequence* self, Difference i)  {
+    typename Sequence::iterator pos = self->begin();
+    std::advance(pos, check_index(i,self->size()));
+    return pos;
+  inline typename Sequence::const_iterator
+  cgetpos(const Sequence* self, Difference i)  {
+    typename Sequence::const_iterator pos = self->begin();
+    return pos;
+  inline Sequence*
+  getslice(const Sequence* self, Difference i, Difference j) {
+    typename Sequence::size_type size = self->size();
+    typename Sequence::size_type ii = swig::check_index(i, size);
+    typename Sequence::size_type jj = swig::slice_index(j, size);
+    if (jj > ii) {
+      typename Sequence::const_iterator vb = self->begin();
+      typename Sequence::const_iterator ve = self->begin();
+      std::advance(vb,ii);
+      std::advance(ve,jj);
+      return new Sequence(vb, ve);
+    } else {
+      return new Sequence();
+  template <class Sequence, class Difference, class InputSeq>
+  inline void
+  setslice(Sequence* self, Difference i, Difference j, const InputSeq& v) {
+    typename Sequence::size_type ii = swig::check_index(i, size, true);
+    if (jj < ii) jj = ii;
+    size_t ssize = jj - ii;
+    if (ssize <= v.size()) {
+      typename Sequence::iterator sb = self->begin();
+      typename InputSeq::const_iterator vmid = v.begin();
+      std::advance(sb,ii);
+      std::advance(vmid, jj - ii);
+      self->insert(std::copy(v.begin(), vmid, sb), vmid, v.end());
+    } else {
+      typename Sequence::iterator se = self->begin();
+      std::advance(se,jj);
+      self->erase(sb,se);
+      self->insert(sb, v.begin(), v.end());
+  inline void
+  delslice(Sequence* self, Difference i, Difference j) {
+    if (jj > ii) {
+#if !defined(SWIG_STD_NOITERATOR_TRAITS_STL)
+#include <iterator>
+#else
+namespace std  {
+  template <class Iterator>
+  struct iterator_traits {
+    typedef ptrdiff_t difference_type;
+    typedef typename Iterator::value_type value_type;
+  template <class Iterator, class Category,class T, class Reference, class Pointer, class Distance>
+  struct iterator_traits<__reverse_bi_iterator<Iterator,Category,T,Reference,Pointer,Distance> > {
+    typedef Distance difference_type;
+    typedef T value_type;
+#endif
+  template <class T>
+  struct iterator_traits<T*> {
+  template<typename _InputIterator>
+  inline typename iterator_traits<_InputIterator>::difference_type
+  distance(_InputIterator __first, _InputIterator __last)
+    typename iterator_traits<_InputIterator>::difference_type __n = 0;
+    while (__first != __last) {
+      ++__first; ++__n;
+    return __n;
+#endif
+namespace swig {
+  template<typename OutIterator>
+  class PySwigIterator_T :  public PySwigIterator
+  public:
+    typedef OutIterator out_iterator;
+    typedef typename std::iterator_traits<out_iterator>::value_type value_type;
+    typedef PySwigIterator_T<out_iterator> self_type;
+    PySwigIterator_T(out_iterator curr, PyObject *seq)
+      : PySwigIterator(seq), current(curr)
+    const out_iterator& get_current() const
+      return current;
+    bool equal (const PySwigIterator &iter) const
+      const self_type *iters = dynamic_cast<const self_type *>(&iter);
+      if (iters) {
+	return (current == iters->get_current());
+      } else {
+	throw std::invalid_argument("bad iterator type");
+    ptrdiff_t distance(const PySwigIterator &iter) const
+      if (iters) {
+	return std::distance(current, iters->get_current());
+      } else {
+  protected:
+    out_iterator current;
+  template <class ValueType>
+  struct from_oper
+    typedef const ValueType& argument_type;
+    typedef PyObject *result_type;
+    result_type operator()(argument_type v) const
+      return swig::from(v);
+  template<typename OutIterator,
+	   typename ValueType = typename std::iterator_traits<OutIterator>::value_type,
+	   typename FromOper = from_oper<ValueType> >
+  class PySwigIteratorOpen_T :  public PySwigIterator_T<OutIterator>
+  public:
+    FromOper from;
+    typedef ValueType value_type;
+    typedef PySwigIterator_T<out_iterator>  base;
+    typedef PySwigIteratorOpen_T<OutIterator, ValueType, FromOper> self_type;
+    PySwigIteratorOpen_T(out_iterator curr, PyObject *seq)
+      : PySwigIterator_T<OutIterator>(curr, seq)
+    PyObject *value() const {
+      return from(static_cast<const value_type&>(*(base::current)));
+    PySwigIterator *copy() const
+      return new self_type(*this);
+    PySwigIterator *incr(size_t n = 1)
+      while (n--) {
+	++base::current;
+      return this;
+    PySwigIterator *decr(size_t n = 1)
+      while (n--) {
+	--base::current;
+      return this;
+  class PySwigIteratorClosed_T :  public PySwigIterator_T<OutIterator>
+  public:
+    FromOper from;
+    typedef PySwigIteratorClosed_T<OutIterator, ValueType, FromOper> self_type;
+    PySwigIteratorClosed_T(out_iterator curr, out_iterator first, out_iterator last, PyObject *seq)
+      : PySwigIterator_T<OutIterator>(curr, seq), begin(first), end(last)
+      if (base::current == end) {
+      } else {
+      while (n--) {
+	} else {
+	  ++base::current;
+      return this;
+      while (n--) {
+	if (base::current == begin) {
+	} else {
+	  --base::current;
+      return this;
+  private:
+    out_iterator begin;
+    out_iterator end;
+  template<typename OutIter>
+  inline PySwigIterator*
+  make_output_iterator(const OutIter& current, const OutIter& begin,const OutIter& end, PyObject *seq = 0)
+    return new PySwigIteratorClosed_T<OutIter>(current, begin, end, seq);
+  make_output_iterator(const OutIter& current, PyObject *seq = 0)
+    return new PySwigIteratorOpen_T<OutIter>(current, seq);
+namespace swig
+  struct PySequence_Ref
+    PySequence_Ref(PyObject* seq, int index)
+      : _seq(seq), _index(index)
+    operator T () const
+      swig::PyObject_var item = PySequence_GetItem(_seq, _index);
+      try {
+	return swig::as<T>(item, true);
+      } catch (std::exception& e) {
+	char msg[1024];
+	sprintf(msg, "in sequence element %d ", _index);
+	  SWIG_Error(SWIG_TypeError,  swig::type_name<T>());
+	SWIG_Python_AddErrorMsg(msg);
+	SWIG_Python_AddErrorMsg(e.what());
+	throw;
+    PySequence_Ref& operator=(const T& v)
+      PySequence_SetItem(_seq, _index, swig::from<T>(v));
+      return *this;
+  private:
+    PyObject* _seq;
+    int _index;
+  struct PySequence_ArrowProxy
+    PySequence_ArrowProxy(const T& x): m_value(x) {}
+    const T* operator->() const { return &m_value; }
+    operator const T*() const { return &m_value; }
+    T m_value;
+  template <class T, class Reference >
+  struct PySequence_InputIterator
+    typedef PySequence_InputIterator<T, Reference > self;
+    typedef std::random_access_iterator_tag iterator_category;
+    typedef Reference reference;
+    typedef T* pointer;
+    typedef int difference_type;
+    PySequence_InputIterator()
+    PySequence_InputIterator(PyObject* seq, int index)
+    reference operator*() const
+      return reference(_seq, _index);
+    PySequence_ArrowProxy<T>
+    operator->() const {
+      return PySequence_ArrowProxy<T>(operator*());
+    bool operator==(const self& ri) const
+      return (_index == ri._index) && (_seq == ri._seq);
+    bool operator!=(const self& ri) const
+      return !(operator==(ri));
+    self& operator ++ ()
+      ++_index;
+      return *this;
+    self& operator -- ()
+      --_index;
+      return *this;
+    self& operator += (difference_type n)
+      _index += n;
+      return *this;
+    self operator +(difference_type n) const
+      return self(_seq, _index + n);
+    self& operator -= (difference_type n)
+      _index -= n;
+      return *this;
+    self operator -(difference_type n) const
+      return self(_seq, _index - n);
+    difference_type operator - (const self& ri) const
+      return _index - ri._index;
+    bool operator < (const self& ri) const
+      return _index < ri._index;
+    reference
+    operator[](difference_type n) const
+      return reference(_seq, _index + n);
+  private:
+    PyObject* _seq;
+    difference_type _index;
+  struct PySequence_Cont
+    typedef PySequence_Ref<T> reference;
+    typedef const PySequence_Ref<T> const_reference;
+    typedef int size_type;
+    typedef const pointer const_pointer;
+    typedef PySequence_InputIterator<T, reference> iterator;
+    typedef PySequence_InputIterator<T, const_reference> const_iterator;
+    PySequence_Cont(PyObject* seq) : _seq(0)
+      if (!PySequence_Check(seq)) {
+	throw std::invalid_argument("a sequence is expected");
+      _seq = seq;
+      Py_INCREF(_seq);
+    ~PySequence_Cont()
+      if (_seq) Py_DECREF(_seq);
+    size_type size() const
+      return static_cast<size_type>(PySequence_Size(_seq));
+    bool empty() const
+      return size() == 0;
+    iterator begin()
+      return iterator(_seq, 0);
+    const_iterator begin() const
+      return const_iterator(_seq, 0);
+    iterator end()
+      return iterator(_seq, size());
+    const_iterator end() const
+      return const_iterator(_seq, size());
+    reference operator[](difference_type n)
+      return reference(_seq, n);
+    const_reference operator[](difference_type n)  const
+      return const_reference(_seq, n);
+    bool check(bool set_err = true) const
+      int s = size();
+      for (int i = 0; i < s; ++i) {
+	swig::PyObject_var item = PySequence_GetItem(_seq, i);
+	if (!swig::check<value_type>(item)) {
+	  if (set_err) {
+	    char msg[1024];
+	    sprintf(msg, "in sequence element %d", i);
+	    SWIG_Error(SWIG_RuntimeError, msg);
+	  return false;
+      return true;
+  private:
+    PyObject* _seq;
+#include <limits.h>
+#if !defined(SWIG_NO_LLONG_MAX)
+# if !defined(LLONG_MAX) && defined(__GNUC__) && defined (__LONG_LONG_MAX__)
+#   define LLONG_MAX __LONG_LONG_MAX__
+#   define LLONG_MIN (-LLONG_MAX - 1LL)
+#   define ULLONG_MAX (LLONG_MAX * 2ULL + 1ULL)
+# endif
+#endif
+SWIGINTERN int
+SWIG_AsVal_int (PyObject * obj, int *val)
+  long v;
+  int res = SWIG_AsVal_long (obj, &v);
+    if ((v < INT_MIN || v > INT_MAX)) {
+    } else {
+      if (val) *val = static_cast< int >(v);
+  return res;
+SWIG_From_int  (int value)
+  return SWIG_From_long  (value);
+namespace swig {
+  template <> struct traits<int > {
+    static const char* type_name() { return"int"; }
+  template <>  struct traits_asval<int > {
+    typedef int value_type;
+      return SWIG_AsVal_int (obj, val);
+  template <>  struct traits_from<int > {
+      return SWIG_From_int  (val);
+namespace swig {
+  template <class PySeq, class Seq>
+  inline void
+  assign(const PySeq& pyseq, Seq* seq) {
+#ifdef SWIG_STD_NOASSIGN_STL
+    typedef typename PySeq::value_type value_type;
+    typename PySeq::const_iterator it = pyseq.begin();
+    for (;it != pyseq.end(); ++it) {
+      seq->insert(seq->end(),(value_type)(*it));
+#else
+    seq->assign(pyseq.begin(), pyseq.end());
+#endif
+  template <class Seq, class T = typename Seq::value_type >
+  struct traits_asptr_stdseq {
+    typedef Seq sequence;
+    static int asptr(PyObject *obj, sequence **seq) {
+      if (PySequence_Check(obj)) {
+	try {
+	  PySequence_Cont<value_type> pyseq(obj);
+	  if (seq) {
+	    sequence *pseq = new sequence();
+	    assign(pyseq, pseq);
+	    *seq = pseq;
+	    return SWIG_NEWOBJ;
+	  } else {
+	    return pyseq.check() ? SWIG_OK : SWIG_ERROR;
+	  if (seq) {
+	      PyErr_SetString(PyExc_TypeError, e.what());
+      } else {
+	sequence *p;
+	if (SWIG_ConvertPtr(obj,(void**)&p,
+			    swig::type_info<sequence>(),0) == SWIG_OK) {
+	  if (seq) *seq = p;
+	  return SWIG_OLDOBJ;
+  struct traits_from_stdseq {
+    typedef typename Seq::size_type size_type;
+    typedef typename sequence::const_iterator const_iterator;
+    static PyObject *from(const sequence& seq) {
+      size_type size = seq.size();
+      if (size <= (size_type)INT_MAX) {
+	PyObject *obj = PyTuple_New((int)size);
+	int i = 0;
+	for (const_iterator it = seq.begin();
+	     it != seq.end(); ++it, ++i) {
+	  PyTuple_SetItem(obj,i,swig::from<value_type>(*it));
+	return obj;
+      } else {
+	PyErr_SetString(PyExc_OverflowError,"sequence size not valid in python");
+	return NULL;
+  namespace swig {
+    struct traits_asptr<std::vector<T> >  {
+      static int asptr(PyObject *obj, std::vector<T> **vec) {
+	return traits_asptr_stdseq<std::vector<T> >::asptr(obj, vec);
+    struct traits_from<std::vector<T> > {
+      static PyObject *from(const std::vector<T>& vec) {
+	return traits_from_stdseq<std::vector<T> >::from(vec);
+      namespace swig {
+	template <>  struct traits<std::vector<int, std::allocator<int > > > {
+	    return "std::vector<" "int" "," "std::allocator<int >" " >";
+SWIGINTERN swig::PySwigIterator *std_vector_Sl_int_Sg__iterator(std::vector<int > *self,PyObject **PYTHON_SELF){
+      return swig::make_output_iterator(self->begin(), self->begin(), self->end(), *PYTHON_SELF);
+SWIGINTERN bool std_vector_Sl_int_Sg____nonzero__(std::vector<int > const *self){
+      return !(self->empty());
+SWIGINTERN std::vector<int >::size_type std_vector_Sl_int_Sg____len__(std::vector<int > const *self){
+      return self->size();
+SWIG_From_unsigned_SS_long  (unsigned long value)
+  return (value > LONG_MAX) ?
+    PyLong_FromUnsignedLong(value) : PyInt_FromLong(static_cast< long >(value));
+SWIG_From_size_t  (size_t value)
+  return SWIG_From_unsigned_SS_long  (static_cast< unsigned long >(value));
+SWIGINTERN std::vector<int >::value_type std_vector_Sl_int_Sg__pop(std::vector<int > *self){
+      if (self->size() == 0)
+	throw std::out_of_range("pop from empty container");
+      std::vector<int,std::allocator<int > >::value_type x = self->back();
+      self->pop_back();
+      return x;
+SWIGINTERN std::vector<int,std::allocator<int > > *std_vector_Sl_int_Sg____getslice__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::difference_type j){
+      return swig::getslice(self, i, j);
+SWIGINTERN void std_vector_Sl_int_Sg____setslice__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::difference_type j,std::vector<int,std::allocator<int > > const &v){
+      swig::setslice(self, i, j, v);
+SWIGINTERN void std_vector_Sl_int_Sg____delslice__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::difference_type j){
+      swig::delslice(self, i, j);
+SWIGINTERN void std_vector_Sl_int_Sg____delitem__(std::vector<int > *self,std::vector<int >::difference_type i){
+      self->erase(swig::getpos(self,i));
+SWIGINTERN std::vector<int >::value_type const &std_vector_Sl_int_Sg____getitem__(std::vector<int > const *self,std::vector<int >::difference_type i){
+      return *(swig::cgetpos(self, i));
+SWIGINTERN void std_vector_Sl_int_Sg____setitem__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::value_type const &x){
+      *(swig::getpos(self,i)) = x;
+SWIGINTERN void std_vector_Sl_int_Sg__append(std::vector<int > *self,std::vector<int >::value_type const &x){
+      self->push_back(x);
+  #define SWIG_From_double   PyFloat_FromDouble
+namespace swig {
+  template <> struct traits<double > {
+    static const char* type_name() { return"double"; }
+  template <>  struct traits_asval<double > {
+    typedef double value_type;
+      return SWIG_AsVal_double (obj, val);
+  template <>  struct traits_from<double > {
+      return SWIG_From_double  (val);
+      namespace swig {
+	template <>  struct traits<std::vector<double, std::allocator<double > > > {
+	    return "std::vector<" "double" "," "std::allocator<double >" " >";
+SWIGINTERN swig::PySwigIterator *std_vector_Sl_double_Sg__iterator(std::vector<double > *self,PyObject **PYTHON_SELF){
+SWIGINTERN bool std_vector_Sl_double_Sg____nonzero__(std::vector<double > const *self){
+SWIGINTERN std::vector<double >::size_type std_vector_Sl_double_Sg____len__(std::vector<double > const *self){
+SWIGINTERN std::vector<double >::value_type std_vector_Sl_double_Sg__pop(std::vector<double > *self){
+      std::vector<double,std::allocator<double > >::value_type x = self->back();
+      self->pop_back();
+      return x;
+SWIGINTERN std::vector<double,std::allocator<double > > *std_vector_Sl_double_Sg____getslice__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::difference_type j){
+SWIGINTERN void std_vector_Sl_double_Sg____setslice__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::difference_type j,std::vector<double,std::allocator<double > > const &v){
+SWIGINTERN void std_vector_Sl_double_Sg____delslice__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::difference_type j){
+SWIGINTERN void std_vector_Sl_double_Sg____delitem__(std::vector<double > *self,std::vector<double >::difference_type i){
+SWIGINTERN std::vector<double >::value_type const &std_vector_Sl_double_Sg____getitem__(std::vector<double > const *self,std::vector<double >::difference_type i){
+SWIGINTERN void std_vector_Sl_double_Sg____setitem__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::value_type const &x){
+SWIGINTERN void std_vector_Sl_double_Sg__append(std::vector<double > *self,std::vector<double >::value_type const &x){
+#include <utility>
+#include <map>
+  namespace swig {
+    template <class T, class U >
+    struct traits_asptr<std::pair<T,U> >  {
+      typedef std::pair<T,U> value_type;
+      static int get_pair(PyObject* first, PyObject* second,
+			  std::pair<T,U> **val)
+	if (val) {
+	  value_type *vp = (new std::pair<T,U>);
+	  T *pfirst = &(vp->first);
+	  int res1 = swig::asval((PyObject*)first, pfirst);
+	  if (!SWIG_IsOK(res1)) return res1;
+	  U *psecond = &(vp->second);
+	  int res2 = swig::asval((PyObject*)second, psecond);
+	  if (!SWIG_IsOK(res2)) return res2;
+	  *val = vp;
+	  return SWIG_AddNewMask(res1 > res2 ? res1 : res2);
+	} else {
+	  T *pfirst = 0;
+	  U *psecond = 0;
+	  return res1 > res2 ? res1 : res2;
+      static int asptr(PyObject *obj, std::pair<T,U> **val) {
+	if (PyTuple_Check(obj)) {
+	  if (PyTuple_GET_SIZE(obj) == 2) {
+	    res = get_pair(PyTuple_GET_ITEM(obj,0),PyTuple_GET_ITEM(obj,1), val);
+	} else if (PySequence_Check(obj)) {
+	  if (PySequence_Size(obj) == 2) {
+	    swig::PyObject_var first = PySequence_GetItem(obj,0);
+	    swig::PyObject_var second = PySequence_GetItem(obj,1);
+	    res = get_pair(first, second, val);
+	} else {
+	  value_type *p;
+	  res = SWIG_ConvertPtr(obj,(void**)&p,swig::type_info<value_type>(),0);
+	  if (SWIG_IsOK(res) && val)  *val = p;
+	return res;
+    struct traits_from<std::pair<T,U> >   {
+      static PyObject *from(const std::pair<T,U>& val) {
+	PyObject* obj = PyTuple_New(2);
+	PyTuple_SetItem(obj,0,swig::from(val.first));
+	PyTuple_SetItem(obj,1,swig::from(val.second));
+	return obj;
+      namespace swig {
+	template <>  struct traits<std::pair< int, std::vector<int,std::allocator<int > > > > {
+	    return "std::pair<" "int" "," "std::vector<int,std::allocator<int > >" " >";
+  namespace swig {
+    template <class PySeq, class K, class T >
+    inline void
+    assign(const PySeq& pyseq, std::map<K,T > *map) {
+      typedef typename std::map<K,T>::value_type value_type;
+	map->insert(value_type(it->first, it->second));
+    template <class K, class T>
+    struct traits_asptr<std::map<K,T> >  {
+      typedef std::map<K,T> map_type;
+      static int asptr(PyObject *obj, map_type **val) {
+	if (PyDict_Check(obj)) {
+	  PyObject_var items = PyObject_CallMethod(obj,"items",NULL);
+	  res = traits_asptr_stdseq<std::map<K,T>, std::pair<K, T> >::asptr(items, val);
+	} else {
+	  map_type *p;
+	  res = SWIG_ConvertPtr(obj,(void**)&p,swig::type_info<map_type>(),0);
+	return res;
+    template <class K, class T >
+    struct traits_from<std::map<K,T> >  {
+      typedef typename map_type::const_iterator const_iterator;
+      typedef typename map_type::size_type size_type;
+      static PyObject *from(const map_type& map) {
+	swig_type_info *desc = swig::type_info<map_type>();
+	if (desc && desc->clientdata) {
+	  return SWIG_NewPointerObj(new map_type(map), desc, SWIG_POINTER_OWN);
+	} else {
+	  size_type size = map.size();
+	  int pysize = (size <= (size_type) INT_MAX) ? (int) size : -1;
+	  if (pysize < 0) {
+	    SWIG_PYTHON_THREAD_BEGIN_BLOCK;
+			    "map size not valid in python");
+	    SWIG_PYTHON_THREAD_END_BLOCK;
+	    return NULL;
+	  PyObject *obj = PyDict_New();
+	  for (const_iterator i= map.begin(); i!= map.end(); ++i) {
+	    swig::PyObject_var key = swig::from(i->first);
+	    swig::PyObject_var val = swig::from(i->second);
+	    PyDict_SetItem(obj, key, val);
+	  return obj;
+    struct from_key_oper
+	return swig::from(v.first);
+    struct from_value_oper
+	return swig::from(v.second);
+    template<class OutIterator, class FromOper, class ValueType = typename OutIterator::value_type>
+    struct PyMapIterator_T : PySwigIteratorClosed_T<OutIterator, ValueType, FromOper>
+      PyMapIterator_T(OutIterator curr, OutIterator first, OutIterator last, PyObject *seq)
+	: PySwigIteratorClosed_T<OutIterator,ValueType,FromOper>(curr, first, last, seq)
+	     class FromOper = from_key_oper<typename OutIterator::value_type> >
+    struct PyMapKeyIterator_T : PyMapIterator_T<OutIterator, FromOper>
+      PyMapKeyIterator_T(OutIterator curr, OutIterator first, OutIterator last, PyObject *seq)
+	: PyMapIterator_T<OutIterator, FromOper>(curr, first, last, seq)
+    make_output_key_iterator(const OutIter& current, const OutIter& begin, const OutIter& end, PyObject *seq = 0)
+      return new PyMapKeyIterator_T<OutIter>(current, begin, end, seq);
+	     class FromOper = from_value_oper<typename OutIterator::value_type> >
+    struct PyMapValueIterator_T : PyMapIterator_T<OutIterator, FromOper>
+      PyMapValueIterator_T(OutIterator curr, OutIterator first, OutIterator last, PyObject *seq)
+    make_output_value_iterator(const OutIter& current, const OutIter& begin, const OutIter& end, PyObject *seq = 0)
+      return new PyMapValueIterator_T<OutIter>(current, begin, end, seq);
+      namespace swig {
+	template <>  struct traits<std::map<int, std::vector<int,std::allocator<int > >, std::less<int >, std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > > {
+	    return "std::map<" "int" "," "std::vector<int,std::allocator<int > >" "," "std::less<int >" "," "std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > >" " >";
+SWIGINTERN swig::PySwigIterator *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__iterator(std::map<int,std::vector<int > > *self,PyObject **PYTHON_SELF){
+SWIGINTERN bool std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____nonzero__(std::map<int,std::vector<int > > const *self){
+SWIGINTERN std::map<int,std::vector<int > >::size_type std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____len__(std::map<int,std::vector<int > > const *self){
+SWIGINTERN std::map<int,std::vector<int > >::mapped_type std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____getitem__(std::map<int,std::vector<int > > const *self,std::map<int,std::vector<int > >::key_type const &key){
+      std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::const_iterator i = self->find(key);
+      if (i != self->end())
+	return i->second;
+      else
+	throw std::out_of_range("key not found");
+SWIGINTERN void std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____delitem__(std::map<int,std::vector<int > > *self,std::map<int,std::vector<int > >::key_type const &key){
+      std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::iterator i = self->find(key);
+	self->erase(i);
+      else
+SWIGINTERN bool std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__has_key(std::map<int,std::vector<int > > const *self,std::map<int,std::vector<int > >::key_type const &key){
+      return i != self->end();
+SWIGINTERN PyObject *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__keys(std::map<int,std::vector<int > > *self){
+      std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::size_type size = self->size();
+      int pysize = (size <= (std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::size_type) INT_MAX) ? (int) size : -1;
+      if (pysize < 0) {
+	return NULL;
+      PyObject* keyList = PyList_New(pysize);
+      std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::const_iterator i = self->begin();
+      for (int j = 0; j < pysize; ++i, ++j) {
+	PyList_SET_ITEM(keyList, j, swig::from(i->first));
+      return keyList;
+SWIGINTERN PyObject *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__values(std::map<int,std::vector<int > > *self){
+      if (pysize < 0) {
+	return NULL;
+      PyObject* valList = PyList_New(pysize);
+	PyList_SET_ITEM(valList, j, swig::from(i->second));
+      return valList;
+SWIGINTERN PyObject *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__items(std::map<int,std::vector<int > > *self){
+      if (pysize < 0) {
+	return NULL;
+      PyObject* itemList = PyList_New(pysize);
+	PyList_SET_ITEM(itemList, j, swig::from(*i));
+      return itemList;
+SWIGINTERN bool std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____contains__(std::map<int,std::vector<int > > *self,std::map<int,std::vector<int > >::key_type const &key){
+      return self->find(key) != self->end();
+SWIGINTERN swig::PySwigIterator *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__key_iterator(std::map<int,std::vector<int > > *self,PyObject **PYTHON_SELF){
+      return swig::make_output_key_iterator(self->begin(), self->begin(), self->end(), *PYTHON_SELF);
+SWIGINTERN swig::PySwigIterator *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__value_iterator(std::map<int,std::vector<int > > *self,PyObject **PYTHON_SELF){
+      return swig::make_output_value_iterator(self->begin(), self->begin(), self->end(), *PYTHON_SELF);
+SWIGINTERN void std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____setitem__(std::map<int,std::vector<int > > *self,std::map<int,std::vector<int > >::key_type const &key,std::map<int,std::vector<int > >::mapped_type const &x){
+      (*self)[key] = x;
+SWIGINTERN int
+SWIG_AsVal_bool (PyObject *obj, bool *val)
+  int r = PyObject_IsTrue(obj);
+  if (r == -1)
+  if (val) *val = r ? true : false;
+  return SWIG_OK;
+SWIGINTERN swig_type_info*
+SWIG_pchar_descriptor(void)
+  static swig_type_info* info = 0;
+  if (!init) {
+    info = SWIG_TypeQuery("_p_char");
+    init = 1;
+  return info;
+SWIGINTERN int
+SWIG_AsCharPtrAndSize(PyObject *obj, char** cptr, size_t* psize, int *alloc)
+  if (PyString_Check(obj)) {
+    char *cstr; Py_ssize_t len;
+    PyString_AsStringAndSize(obj, &cstr, &len);
+    if (cptr)  {
+      if (alloc) {
+	   In python the user should not be able to modify the inner
+	   string representation. To warranty that, if you define
+	   SWIG_PYTHON_SAFE_CSTRINGS, a new/copy of the python string
+	   buffer is always returned.
+	   The default behavior is just to return the pointer value,
+	   so, be careful.
+#if defined(SWIG_PYTHON_SAFE_CSTRINGS)
+	if (*alloc != SWIG_OLDOBJ)
+#else
+	if (*alloc == SWIG_NEWOBJ)
+#endif
+	    *cptr = reinterpret_cast< char* >(memcpy((new char[len + 1]), cstr, sizeof(char)*(len + 1)));
+	    *alloc = SWIG_NEWOBJ;
+	else {
+	  *cptr = cstr;
+	  *alloc = SWIG_OLDOBJ;
+      } else {
+	*cptr = PyString_AsString(obj);
+    if (psize) *psize = len + 1;
+    return SWIG_OK;
+  } else {
+    swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
+    if (pchar_descriptor) {
+      void* vptr = 0;
+      if (SWIG_ConvertPtr(obj, &vptr, pchar_descriptor, 0) == SWIG_OK) {
+	if (cptr) *cptr = (char *) vptr;
+	if (psize) *psize = vptr ? (strlen((char *)vptr) + 1) : 0;
+	if (alloc) *alloc = SWIG_OLDOBJ;
+	return SWIG_OK;
+#ifdef __cplusplus
+extern "C" {
+#endif
+SWIGINTERN PyObject *_wrap_delete_PySwigIterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *resultobj = 0;
+  swig::PySwigIterator *arg1 = (swig::PySwigIterator *) 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  PyObject * obj0 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:delete_PySwigIterator",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_DISOWN |  0 );
+  if (!SWIG_IsOK(res1)) {
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_PySwigIterator" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+  arg1 = reinterpret_cast< swig::PySwigIterator * >(argp1);
+  delete arg1;
+  resultobj = SWIG_Py_Void();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_value(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_value",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__PySwigIterator, 0 |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_value" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+  try {
+    result = (PyObject *)((swig::PySwigIterator const *)arg1)->value();
+  catch(swig::stop_iteration &_e) {
+      (void)_e;
+      SWIG_SetErrorObj(PyExc_StopIteration, SWIG_Py_Void());
+      SWIG_fail;
+  resultobj = result;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_incr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  size_t arg2 ;
+  swig::PySwigIterator *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  PyObject * obj1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_incr",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_incr" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+  ecode2 = SWIG_AsVal_size_t(obj1, &val2);
+  if (!SWIG_IsOK(ecode2)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_incr" "', argument " "2"" of type '" "size_t""'");
+  arg2 = static_cast< size_t >(val2);
+  try {
+    result = (swig::PySwigIterator *)(arg1)->incr(arg2);
+      (void)_e;
+      SWIG_fail;
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, 0 |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_incr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_incr",&obj0)) SWIG_fail;
+  try {
+    result = (swig::PySwigIterator *)(arg1)->incr();
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_incr(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[3];
+  int ii;
+  if (!PyTuple_Check(args)) SWIG_fail;
+  argc = (int)PyObject_Length(args);
+  for (ii = 0; (ii < argc) && (ii < 2); ii++) {
+    argv[ii] = PyTuple_GET_ITEM(args,ii);
+  if (argc == 1) {
+    int _v;
+    void *vptr = 0;
+    int res = SWIG_ConvertPtr(argv[0], &vptr, SWIGTYPE_p_swig__PySwigIterator, 0);
+    _v = SWIG_CheckState(res);
+    if (_v) {
+      return _wrap_PySwigIterator_incr__SWIG_1(self, args);
+  if (argc == 2) {
+    int _v;
+    void *vptr = 0;
+    if (_v) {
+        int res = SWIG_AsVal_size_t(argv[1], NULL);
+      if (_v) {
+        return _wrap_PySwigIterator_incr__SWIG_0(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'PySwigIterator_incr'.\n  Possible C/C++ prototypes are:\n""    incr(swig::PySwigIterator *,size_t)\n""    incr(swig::PySwigIterator *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_decr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  size_t arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_decr",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_decr" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_decr" "', argument " "2"" of type '" "size_t""'");
+  try {
+    result = (swig::PySwigIterator *)(arg1)->decr(arg2);
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_decr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_decr",&obj0)) SWIG_fail;
+  try {
+    result = (swig::PySwigIterator *)(arg1)->decr();
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_decr(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    void *vptr = 0;
+    if (_v) {
+      return _wrap_PySwigIterator_decr__SWIG_1(self, args);
+  if (argc == 2) {
+    int _v;
+    void *vptr = 0;
+    if (_v) {
+      if (_v) {
+        return _wrap_PySwigIterator_decr__SWIG_0(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'PySwigIterator_decr'.\n  Possible C/C++ prototypes are:\n""    decr(swig::PySwigIterator *,size_t)\n""    decr(swig::PySwigIterator *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_distance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  swig::PySwigIterator *arg2 = 0 ;
+  ptrdiff_t result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_distance",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_distance" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+  res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_swig__PySwigIterator,  0  | 0);
+  if (!SWIG_IsOK(res2)) {
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator_distance" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator_distance" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  arg2 = reinterpret_cast< swig::PySwigIterator * >(argp2);
+  try {
+    result = ((swig::PySwigIterator const *)arg1)->distance((swig::PySwigIterator const &)*arg2);
+  catch(std::invalid_argument &_e) {
+    SWIG_Python_Raise(SWIG_NewPointerObj((new std::invalid_argument(static_cast< const std::invalid_argument& >(_e))),SWIGTYPE_p_std__invalid_argument,SWIG_POINTER_OWN), "std::invalid_argument", SWIGTYPE_p_std__invalid_argument); SWIG_fail;
+  resultobj = SWIG_From_ptrdiff_t(static_cast< ptrdiff_t >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_equal(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_equal",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_equal" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator_equal" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator_equal" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  try {
+    result = (bool)((swig::PySwigIterator const *)arg1)->equal((swig::PySwigIterator const &)*arg2);
+  resultobj = SWIG_From_bool(static_cast< bool >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_copy(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_copy",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_copy" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+  result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->copy();
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_next(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_next",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_next" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+  try {
+    result = (PyObject *)(arg1)->next();
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_previous(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_previous",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_previous" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+  try {
+    result = (PyObject *)(arg1)->previous();
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator_advance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  ptrdiff_t arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_advance",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_advance" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+  ecode2 = SWIG_AsVal_ptrdiff_t(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_advance" "', argument " "2"" of type '" "ptrdiff_t""'");
+  arg2 = static_cast< ptrdiff_t >(val2);
+  try {
+    result = (swig::PySwigIterator *)(arg1)->advance(arg2);
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___eq__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___eq__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___eq__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___eq__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___eq__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  result = (bool)((swig::PySwigIterator const *)arg1)->operator ==((swig::PySwigIterator const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___ne__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___ne__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___ne__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___ne__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___ne__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  result = (bool)((swig::PySwigIterator const *)arg1)->operator !=((swig::PySwigIterator const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___iadd__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  ptrdiff_t arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___iadd__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___iadd__" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___iadd__" "', argument " "2"" of type '" "ptrdiff_t""'");
+  try {
+      swig::PySwigIterator &_result_ref = (arg1)->operator +=(arg2);
+      result = (swig::PySwigIterator *) &_result_ref;
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___isub__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  ptrdiff_t arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___isub__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___isub__" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___isub__" "', argument " "2"" of type '" "ptrdiff_t""'");
+  try {
+      swig::PySwigIterator &_result_ref = (arg1)->operator -=(arg2);
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___add__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  ptrdiff_t arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___add__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___add__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___add__" "', argument " "2"" of type '" "ptrdiff_t""'");
+  try {
+    result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->operator +(arg2);
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___sub____SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  ptrdiff_t arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___sub__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___sub__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "ptrdiff_t""'");
+  try {
+    result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->operator -(arg2);
+      (void)_e;
+      SWIG_fail;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___sub____SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  ptrdiff_t result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
+  result = ((swig::PySwigIterator const *)arg1)->operator -((swig::PySwigIterator const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_PySwigIterator___sub__(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 2) {
+    int _v;
+    void *vptr = 0;
+    if (_v) {
+      int res = SWIG_ConvertPtr(argv[1], 0, SWIGTYPE_p_swig__PySwigIterator, 0);
+      if (_v) {
+        return _wrap_PySwigIterator___sub____SWIG_1(self, args);
+  if (argc == 2) {
+    int _v;
+    void *vptr = 0;
+    if (_v) {
+        int res = SWIG_AsVal_ptrdiff_t(argv[1], NULL);
+      if (_v) {
+        return _wrap_PySwigIterator___sub____SWIG_0(self, args);
+fail:
+  Py_INCREF(Py_NotImplemented);
+  return Py_NotImplemented;
+SWIGINTERN PyObject *PySwigIterator_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *obj;
+  if (!PyArg_ParseTuple(args,(char*)"O|swigregister", &obj)) return NULL;
+  SWIG_TypeNewClientData(SWIGTYPE_p_swig__PySwigIterator, SWIG_NewClientData(obj));
+  return SWIG_Py_Void();
+SWIGINTERN PyObject *_wrap_IntVector_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int > *arg1 = (std::vector<int > *) 0 ;
+  PyObject **arg2 = (PyObject **) 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  arg2 = &obj0;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_iterator",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, 0 |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_iterator" "', argument " "1"" of type '" "std::vector<int > *""'");
+  arg1 = reinterpret_cast< std::vector<int > * >(argp1);
+  result = (swig::PySwigIterator *)std_vector_Sl_int_Sg__iterator(arg1,arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___nonzero__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector___nonzero__",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___nonzero__" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = (bool)std_vector_Sl_int_Sg____nonzero__((std::vector<int > const *)arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___len__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::size_type result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector___len__",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___len__" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = std_vector_Sl_int_Sg____len__((std::vector<int > const *)arg1);
+  resultobj = SWIG_From_size_t(static_cast< size_t >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_pop(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::value_type result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_pop",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_pop" "', argument " "1"" of type '" "std::vector<int > *""'");
+  try {
+    result = (std::vector<int >::value_type)std_vector_Sl_int_Sg__pop(arg1);
+  catch(std::out_of_range &_e) {
+    SWIG_exception_fail(SWIG_IndexError, (&_e)->what());
+  resultobj = SWIG_From_int(static_cast< int >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___getslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::difference_type arg2 ;
+  std::vector<int >::difference_type arg3 ;
+  std::vector<int,std::allocator<int > > *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  ptrdiff_t val3 ;
+  int ecode3 = 0 ;
+  PyObject * obj2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector___getslice__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___getslice__" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___getslice__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
+  arg2 = static_cast< std::vector<int >::difference_type >(val2);
+  ecode3 = SWIG_AsVal_ptrdiff_t(obj2, &val3);
+  if (!SWIG_IsOK(ecode3)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___getslice__" "', argument " "3"" of type '" "std::vector<int >::difference_type""'");
+  arg3 = static_cast< std::vector<int >::difference_type >(val3);
+  try {
+    result = (std::vector<int,std::allocator<int > > *)std_vector_Sl_int_Sg____getslice__(arg1,arg2,arg3);
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___setslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int,std::allocator<int > > *arg4 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  ptrdiff_t val3 ;
+  int ecode3 = 0 ;
+  int res4 = SWIG_OLDOBJ ;
+  PyObject * obj3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOO:IntVector___setslice__",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___setslice__" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___setslice__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___setslice__" "', argument " "3"" of type '" "std::vector<int >::difference_type""'");
+    std::vector<int,std::allocator<int > > *ptr = (std::vector<int,std::allocator<int > > *)0;
+    res4 = swig::asptr(obj3, &ptr);
+    if (!SWIG_IsOK(res4)) {
+      SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "IntVector___setslice__" "', argument " "4"" of type '" "std::vector<int,std::allocator<int > > const &""'");
+    if (!ptr) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVector___setslice__" "', argument " "4"" of type '" "std::vector<int,std::allocator<int > > const &""'");
+    arg4 = ptr;
+  try {
+    std_vector_Sl_int_Sg____setslice__(arg1,arg2,arg3,(std::vector<int,std::allocator<int > > const &)*arg4);
+    SWIG_exception_fail(SWIG_ValueError, (&_e)->what());
+  if (SWIG_IsNewObj(res4)) delete arg4;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___delslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  ptrdiff_t val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector___delslice__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___delslice__" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___delslice__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___delslice__" "', argument " "3"" of type '" "std::vector<int >::difference_type""'");
+  try {
+    std_vector_Sl_int_Sg____delslice__(arg1,arg2,arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___delitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector___delitem__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___delitem__" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___delitem__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
+  try {
+    std_vector_Sl_int_Sg____delitem__(arg1,arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___getitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::value_type *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector___getitem__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___getitem__" "', argument " "1"" of type '" "std::vector<int > const *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___getitem__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
+  try {
+      std::vector<int >::value_type const &_result_ref = std_vector_Sl_int_Sg____getitem__((std::vector<int > const *)arg1,arg2);
+      result = (std::vector<int >::value_type *) &_result_ref;
+  resultobj = SWIG_From_int(static_cast< int >(*result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector___setitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::value_type *arg3 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  std::vector<int >::value_type temp3 ;
+  int val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector___setitem__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___setitem__" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___setitem__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
+  ecode3 = SWIG_AsVal_int(obj2, &val3);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___setitem__" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
+  temp3 = static_cast< std::vector<int >::value_type >(val3);
+  arg3 = &temp3;
+  try {
+    std_vector_Sl_int_Sg____setitem__(arg1,arg2,(int const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_append(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::value_type *arg2 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  std::vector<int >::value_type temp2 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_append",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_append" "', argument " "1"" of type '" "std::vector<int > *""'");
+  ecode2 = SWIG_AsVal_int(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_append" "', argument " "2"" of type '" "std::vector<int >::value_type""'");
+  temp2 = static_cast< std::vector<int >::value_type >(val2);
+  arg2 = &temp2;
+  std_vector_Sl_int_Sg__append(arg1,(int const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int > *result = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)":new_IntVector")) SWIG_fail;
+  result = (std::vector<int > *)new std::vector<int >();
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_POINTER_NEW |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int > *arg1 = 0 ;
+  int res1 = SWIG_OLDOBJ ;
+  if (!PyArg_ParseTuple(args,(char *)"O:new_IntVector",&obj0)) SWIG_fail;
+    res1 = swig::asptr(obj0, &ptr);
+      SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_IntVector" "', argument " "1"" of type '" "std::vector<int > const &""'");
+    if (!ptr) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_IntVector" "', argument " "1"" of type '" "std::vector<int > const &""'");
+    arg1 = ptr;
+  result = (std::vector<int > *)new std::vector<int >((std::vector<int > const &)*arg1);
+  if (SWIG_IsNewObj(res1)) delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_empty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_empty",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_empty" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = (bool)((std::vector<int > const *)arg1)->empty();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_size(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_size",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_size" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->size();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_clear(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_clear",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_clear" "', argument " "1"" of type '" "std::vector<int > *""'");
+  (arg1)->clear();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_swap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int > *arg2 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_swap",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_swap" "', argument " "1"" of type '" "std::vector<int > *""'");
+  res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t,  0 );
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "IntVector_swap" "', argument " "2"" of type '" "std::vector<int > &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVector_swap" "', argument " "2"" of type '" "std::vector<int > &""'");
+  arg2 = reinterpret_cast< std::vector<int > * >(argp2);
+  (arg1)->swap(*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_get_allocator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  SwigValueWrapper< std::allocator<int > > result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_get_allocator",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_get_allocator" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->get_allocator();
+  resultobj = SWIG_NewPointerObj((new std::vector<int >::allocator_type(static_cast< const std::vector<int >::allocator_type& >(result))), SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t__allocator_type, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_begin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_begin",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_begin" "', argument " "1"" of type '" "std::vector<int > *""'");
+  result = (arg1)->begin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::iterator & >(result)),
+    swig::PySwigIterator::descriptor(),SWIG_POINTER_OWN);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_begin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::const_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_begin" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->begin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::const_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_begin(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[2];
+  int ii;
+  for (ii = 0; (ii < argc) && (ii < 1); ii++) {
+  if (argc == 1) {
+    int _v;
+    int res = swig::asptr(argv[0], (std::vector<int,std::allocator<int > >**)(0));
+    if (_v) {
+      return _wrap_IntVector_begin__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_begin__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_begin'.\n  Possible C/C++ prototypes are:\n""    begin(std::vector<int > *)\n""    begin(std::vector<int > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_end__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_end",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_end" "', argument " "1"" of type '" "std::vector<int > *""'");
+  result = (arg1)->end();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_end__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_end" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->end();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_end(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_end__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_end__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_end'.\n  Possible C/C++ prototypes are:\n""    end(std::vector<int > *)\n""    end(std::vector<int > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_rbegin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::reverse_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_rbegin",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rbegin" "', argument " "1"" of type '" "std::vector<int > *""'");
+  result = (arg1)->rbegin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::reverse_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_rbegin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::const_reverse_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rbegin" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->rbegin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::const_reverse_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_rbegin(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_rbegin__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_rbegin__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_rbegin'.\n  Possible C/C++ prototypes are:\n""    rbegin(std::vector<int > *)\n""    rbegin(std::vector<int > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_rend__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_rend",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rend" "', argument " "1"" of type '" "std::vector<int > *""'");
+  result = (arg1)->rend();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_rend__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rend" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->rend();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_rend(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_rend__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVector_rend__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_rend'.\n  Possible C/C++ prototypes are:\n""    rend(std::vector<int > *)\n""    rend(std::vector<int > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::size_type arg1 ;
+  size_t val1 ;
+  int ecode1 = 0 ;
+  ecode1 = SWIG_AsVal_size_t(obj0, &val1);
+  if (!SWIG_IsOK(ecode1)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_IntVector" "', argument " "1"" of type '" "std::vector<int >::size_type""'");
+  arg1 = static_cast< std::vector<int >::size_type >(val1);
+  result = (std::vector<int > *)new std::vector<int >(arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_pop_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_pop_back",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_pop_back" "', argument " "1"" of type '" "std::vector<int > *""'");
+  (arg1)->pop_back();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_resize__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::size_type arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_resize",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_resize" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_resize" "', argument " "2"" of type '" "std::vector<int >::size_type""'");
+  arg2 = static_cast< std::vector<int >::size_type >(val2);
+  (arg1)->resize(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_erase__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::iterator arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  swig::PySwigIterator *iter2 = 0 ;
+  int res2 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_erase",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_erase" "', argument " "1"" of type '" "std::vector<int > *""'");
+  res2 = SWIG_ConvertPtr(obj1, SWIG_as_voidptrptr(&iter2), swig::PySwigIterator::descriptor(), 0);
+  if (!SWIG_IsOK(res2) || !iter2) {
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVector_erase" "', argument " "2"" of type '" "std::vector<int >::iterator""'");
+  } else {
+    swig::PySwigIterator_T<std::vector<int >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<int >::iterator > *>(iter2);
+    if (iter_t) {
+      arg2 = iter_t->get_current();
+    } else {
+  result = (arg1)->erase(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_erase__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::iterator arg3 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  swig::PySwigIterator *iter3 = 0 ;
+  int res3 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_erase",&obj0,&obj1,&obj2)) SWIG_fail;
+  } else {
+    if (iter_t) {
+    } else {
+  res3 = SWIG_ConvertPtr(obj2, SWIG_as_voidptrptr(&iter3), swig::PySwigIterator::descriptor(), 0);
+  if (!SWIG_IsOK(res3) || !iter3) {
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVector_erase" "', argument " "3"" of type '" "std::vector<int >::iterator""'");
+  } else {
+    swig::PySwigIterator_T<std::vector<int >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<int >::iterator > *>(iter3);
+    if (iter_t) {
+      arg3 = iter_t->get_current();
+    } else {
+  result = (arg1)->erase(arg2,arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_erase(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[4];
+  int ii;
+  for (ii = 0; (ii < argc) && (ii < 3); ii++) {
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+      swig::PySwigIterator *iter = 0;
+      int res = SWIG_ConvertPtr(argv[1], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
+      _v = (SWIG_IsOK(res) && iter && (dynamic_cast<swig::PySwigIterator_T<std::vector<int >::iterator > *>(iter) != 0));
+      if (_v) {
+        return _wrap_IntVector_erase__SWIG_0(self, args);
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        int res = SWIG_ConvertPtr(argv[2], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
+        if (_v) {
+          return _wrap_IntVector_erase__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_erase'.\n  Possible C/C++ prototypes are:\n""    erase(std::vector<int > *,std::vector<int >::iterator)\n""    erase(std::vector<int > *,std::vector<int >::iterator,std::vector<int >::iterator)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_3(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  size_t val1 ;
+  int ecode1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:new_IntVector",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "new_IntVector" "', argument " "2"" of type '" "std::vector<int >::value_type""'");
+  arg2 = &temp2;
+  result = (std::vector<int > *)new std::vector<int >(arg1,(std::vector<int >::value_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVector(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 0) {
+    return _wrap_new_IntVector__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+      int res = SWIG_AsVal_size_t(argv[0], NULL);
+    if (_v) {
+      return _wrap_new_IntVector__SWIG_2(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_new_IntVector__SWIG_1(self, args);
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+        int res = SWIG_AsVal_int(argv[1], NULL);
+      if (_v) {
+        return _wrap_new_IntVector__SWIG_3(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'new_IntVector'.\n  Possible C/C++ prototypes are:\n""    std::vector<(int)>()\n""    std::vector<(int)>(std::vector<int > const &)\n""    std::vector<(int)>(std::vector<int >::size_type)\n""    std::vector<(int)>(std::vector<int >::size_type,std::vector<int >::value_type const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_push_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_push_back",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_push_back" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_push_back" "', argument " "2"" of type '" "std::vector<int >::value_type""'");
+  arg2 = &temp2;
+  (arg1)->push_back((std::vector<int >::value_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_front(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_front",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_front" "', argument " "1"" of type '" "std::vector<int > const *""'");
+    std::vector<int >::value_type const &_result_ref = ((std::vector<int > const *)arg1)->front();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_back",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_back" "', argument " "1"" of type '" "std::vector<int > const *""'");
+    std::vector<int >::value_type const &_result_ref = ((std::vector<int > const *)arg1)->back();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_assign(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  int val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_assign",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_assign" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_assign" "', argument " "2"" of type '" "std::vector<int >::size_type""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_assign" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
+  arg3 = &temp3;
+  (arg1)->assign(arg2,(std::vector<int >::value_type const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_resize__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  int val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_resize",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_resize" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
+  arg3 = &temp3;
+  (arg1)->resize(arg2,(std::vector<int >::value_type const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_resize(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        return _wrap_IntVector_resize__SWIG_0(self, args);
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+          int res = SWIG_AsVal_int(argv[2], NULL);
+        if (_v) {
+          return _wrap_IntVector_resize__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_resize'.\n  Possible C/C++ prototypes are:\n""    resize(std::vector<int > *,std::vector<int >::size_type)\n""    resize(std::vector<int > *,std::vector<int >::size_type,std::vector<int >::value_type const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_insert__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  int val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_insert",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_insert" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVector_insert" "', argument " "2"" of type '" "std::vector<int >::iterator""'");
+  } else {
+    if (iter_t) {
+    } else {
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_insert" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
+  arg3 = &temp3;
+  result = (arg1)->insert(arg2,(std::vector<int >::value_type const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_insert__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int >::size_type arg3 ;
+  std::vector<int >::value_type *arg4 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  size_t val3 ;
+  int ecode3 = 0 ;
+  std::vector<int >::value_type temp4 ;
+  int val4 ;
+  int ecode4 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOO:IntVector_insert",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+  } else {
+    if (iter_t) {
+    } else {
+  ecode3 = SWIG_AsVal_size_t(obj2, &val3);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_insert" "', argument " "3"" of type '" "std::vector<int >::size_type""'");
+  arg3 = static_cast< std::vector<int >::size_type >(val3);
+  ecode4 = SWIG_AsVal_int(obj3, &val4);
+  if (!SWIG_IsOK(ecode4)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "IntVector_insert" "', argument " "4"" of type '" "std::vector<int >::value_type""'");
+  temp4 = static_cast< std::vector<int >::value_type >(val4);
+  arg4 = &temp4;
+  (arg1)->insert(arg2,arg3,(std::vector<int >::value_type const &)*arg4);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_insert(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[5];
+  int ii;
+  for (ii = 0; (ii < argc) && (ii < 4); ii++) {
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        if (_v) {
+          return _wrap_IntVector_insert__SWIG_0(self, args);
+  if (argc == 4) {
+    int _v;
+    if (_v) {
+      if (_v) {
+          int res = SWIG_AsVal_size_t(argv[2], NULL);
+        if (_v) {
+            int res = SWIG_AsVal_int(argv[3], NULL);
+          if (_v) {
+            return _wrap_IntVector_insert__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_insert'.\n  Possible C/C++ prototypes are:\n""    insert(std::vector<int > *,std::vector<int >::iterator,std::vector<int >::value_type const &)\n""    insert(std::vector<int > *,std::vector<int >::iterator,std::vector<int >::size_type,std::vector<int >::value_type const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_reserve(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_reserve",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_reserve" "', argument " "1"" of type '" "std::vector<int > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_reserve" "', argument " "2"" of type '" "std::vector<int >::size_type""'");
+  (arg1)->reserve(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVector_capacity(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVector_capacity",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_capacity" "', argument " "1"" of type '" "std::vector<int > const *""'");
+  result = ((std::vector<int > const *)arg1)->capacity();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_delete_IntVector(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:delete_IntVector",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_POINTER_DISOWN |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_IntVector" "', argument " "1"" of type '" "std::vector<int > *""'");
+  delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *IntVector_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *obj;
+  SWIG_TypeNewClientData(SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_DoubleVector_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double > *arg1 = (std::vector<double > *) 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  arg2 = &obj0;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_iterator",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, 0 |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_iterator" "', argument " "1"" of type '" "std::vector<double > *""'");
+  arg1 = reinterpret_cast< std::vector<double > * >(argp1);
+  result = (swig::PySwigIterator *)std_vector_Sl_double_Sg__iterator(arg1,arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___nonzero__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector___nonzero__",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___nonzero__" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = (bool)std_vector_Sl_double_Sg____nonzero__((std::vector<double > const *)arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___len__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::size_type result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector___len__",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___len__" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = std_vector_Sl_double_Sg____len__((std::vector<double > const *)arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_pop(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::value_type result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_pop",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_pop" "', argument " "1"" of type '" "std::vector<double > *""'");
+  try {
+    result = (std::vector<double >::value_type)std_vector_Sl_double_Sg__pop(arg1);
+  resultobj = SWIG_From_double(static_cast< double >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___getslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::difference_type arg2 ;
+  std::vector<double >::difference_type arg3 ;
+  std::vector<double,std::allocator<double > > *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  ptrdiff_t val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector___getslice__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___getslice__" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___getslice__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
+  arg2 = static_cast< std::vector<double >::difference_type >(val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___getslice__" "', argument " "3"" of type '" "std::vector<double >::difference_type""'");
+  arg3 = static_cast< std::vector<double >::difference_type >(val3);
+  try {
+    result = (std::vector<double,std::allocator<double > > *)std_vector_Sl_double_Sg____getslice__(arg1,arg2,arg3);
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___setslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double,std::allocator<double > > *arg4 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  ptrdiff_t val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOO:DoubleVector___setslice__",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___setslice__" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___setslice__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___setslice__" "', argument " "3"" of type '" "std::vector<double >::difference_type""'");
+    std::vector<double,std::allocator<double > > *ptr = (std::vector<double,std::allocator<double > > *)0;
+      SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "DoubleVector___setslice__" "', argument " "4"" of type '" "std::vector<double,std::allocator<double > > const &""'");
+    if (!ptr) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "DoubleVector___setslice__" "', argument " "4"" of type '" "std::vector<double,std::allocator<double > > const &""'");
+    arg4 = ptr;
+  try {
+    std_vector_Sl_double_Sg____setslice__(arg1,arg2,arg3,(std::vector<double,std::allocator<double > > const &)*arg4);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___delslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  ptrdiff_t val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector___delslice__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___delslice__" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___delslice__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___delslice__" "', argument " "3"" of type '" "std::vector<double >::difference_type""'");
+  try {
+    std_vector_Sl_double_Sg____delslice__(arg1,arg2,arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___delitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector___delitem__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___delitem__" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___delitem__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
+  try {
+    std_vector_Sl_double_Sg____delitem__(arg1,arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___getitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::value_type *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector___getitem__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___getitem__" "', argument " "1"" of type '" "std::vector<double > const *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___getitem__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
+  try {
+      std::vector<double >::value_type const &_result_ref = std_vector_Sl_double_Sg____getitem__((std::vector<double > const *)arg1,arg2);
+      result = (std::vector<double >::value_type *) &_result_ref;
+  resultobj = SWIG_From_double(static_cast< double >(*result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector___setitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::value_type *arg3 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  ptrdiff_t val2 ;
+  int ecode2 = 0 ;
+  std::vector<double >::value_type temp3 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector___setitem__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___setitem__" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___setitem__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
+  ecode3 = SWIG_AsVal_double(obj2, &val3);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___setitem__" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
+  temp3 = static_cast< std::vector<double >::value_type >(val3);
+  arg3 = &temp3;
+  try {
+    std_vector_Sl_double_Sg____setitem__(arg1,arg2,(double const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_append(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *resultobj = 0;
+  std::vector<double >::value_type *arg2 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  std::vector<double >::value_type temp2 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  PyObject * obj0 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_append",&obj0,&obj1)) SWIG_fail;
+  if (!SWIG_IsOK(res1)) {
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_append" "', argument " "1"" of type '" "std::vector<double > *""'");
+  ecode2 = SWIG_AsVal_double(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_append" "', argument " "2"" of type '" "std::vector<double >::value_type""'");
+  temp2 = static_cast< std::vector<double >::value_type >(val2);
+  arg2 = &temp2;
+  std_vector_Sl_double_Sg__append(arg1,(double const &)*arg2);
+  resultobj = SWIG_Py_Void();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double > *result = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)":new_DoubleVector")) SWIG_fail;
+  result = (std::vector<double > *)new std::vector<double >();
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_POINTER_NEW |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double > *arg1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:new_DoubleVector",&obj0)) SWIG_fail;
+      SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_DoubleVector" "', argument " "1"" of type '" "std::vector<double > const &""'");
+    if (!ptr) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_DoubleVector" "', argument " "1"" of type '" "std::vector<double > const &""'");
+    arg1 = ptr;
+  result = (std::vector<double > *)new std::vector<double >((std::vector<double > const &)*arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_empty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_empty",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_empty" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = (bool)((std::vector<double > const *)arg1)->empty();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_size(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_size",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_size" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->size();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_clear(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_clear",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_clear" "', argument " "1"" of type '" "std::vector<double > *""'");
+  (arg1)->clear();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_swap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double > *arg2 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  PyObject * obj1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_swap",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_swap" "', argument " "1"" of type '" "std::vector<double > *""'");
+  res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t,  0 );
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "DoubleVector_swap" "', argument " "2"" of type '" "std::vector<double > &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "DoubleVector_swap" "', argument " "2"" of type '" "std::vector<double > &""'");
+  arg2 = reinterpret_cast< std::vector<double > * >(argp2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_get_allocator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  SwigValueWrapper< std::allocator<double > > result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_get_allocator",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_get_allocator" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->get_allocator();
+  resultobj = SWIG_NewPointerObj((new std::vector<double >::allocator_type(static_cast< const std::vector<double >::allocator_type& >(result))), SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_begin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_begin",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_begin" "', argument " "1"" of type '" "std::vector<double > *""'");
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_begin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::const_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_begin" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->begin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::const_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_begin(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (!PyTuple_Check(args)) SWIG_fail;
+  argc = (int)PyObject_Length(args);
+    argv[ii] = PyTuple_GET_ITEM(args,ii);
+  if (argc == 1) {
+    int _v;
+    int res = swig::asptr(argv[0], (std::vector<double,std::allocator<double > >**)(0));
+    _v = SWIG_CheckState(res);
+    if (_v) {
+      return _wrap_DoubleVector_begin__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_begin__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_begin'.\n  Possible C/C++ prototypes are:\n""    begin(std::vector<double > *)\n""    begin(std::vector<double > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_end__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_end",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_end" "', argument " "1"" of type '" "std::vector<double > *""'");
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_end__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_end" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->end();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_end(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_end__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_end__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_end'.\n  Possible C/C++ prototypes are:\n""    end(std::vector<double > *)\n""    end(std::vector<double > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_rbegin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::reverse_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_rbegin",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rbegin" "', argument " "1"" of type '" "std::vector<double > *""'");
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::reverse_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_rbegin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::const_reverse_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rbegin" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->rbegin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::const_reverse_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_rbegin(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_rbegin__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_rbegin__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_rbegin'.\n  Possible C/C++ prototypes are:\n""    rbegin(std::vector<double > *)\n""    rbegin(std::vector<double > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_rend__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_rend",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rend" "', argument " "1"" of type '" "std::vector<double > *""'");
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_rend__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rend" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->rend();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_rend(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_rend__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_DoubleVector_rend__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_rend'.\n  Possible C/C++ prototypes are:\n""    rend(std::vector<double > *)\n""    rend(std::vector<double > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::size_type arg1 ;
+  size_t val1 ;
+  int ecode1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_DoubleVector" "', argument " "1"" of type '" "std::vector<double >::size_type""'");
+  arg1 = static_cast< std::vector<double >::size_type >(val1);
+  result = (std::vector<double > *)new std::vector<double >(arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_pop_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_pop_back",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_pop_back" "', argument " "1"" of type '" "std::vector<double > *""'");
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_resize__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::size_type arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_resize",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_resize" "', argument " "1"" of type '" "std::vector<double > *""'");
+  ecode2 = SWIG_AsVal_size_t(obj1, &val2);
+  if (!SWIG_IsOK(ecode2)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_resize" "', argument " "2"" of type '" "std::vector<double >::size_type""'");
+  arg2 = static_cast< std::vector<double >::size_type >(val2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_erase__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::iterator arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_erase",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_erase" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "DoubleVector_erase" "', argument " "2"" of type '" "std::vector<double >::iterator""'");
+  } else {
+    swig::PySwigIterator_T<std::vector<double >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<double >::iterator > *>(iter2);
+    if (iter_t) {
+    } else {
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_erase__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::iterator arg3 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  int res3 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_erase",&obj0,&obj1,&obj2)) SWIG_fail;
+  } else {
+    if (iter_t) {
+    } else {
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "DoubleVector_erase" "', argument " "3"" of type '" "std::vector<double >::iterator""'");
+  } else {
+    swig::PySwigIterator_T<std::vector<double >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<double >::iterator > *>(iter3);
+    if (iter_t) {
+    } else {
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_erase(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+      _v = (SWIG_IsOK(res) && iter && (dynamic_cast<swig::PySwigIterator_T<std::vector<double >::iterator > *>(iter) != 0));
+      if (_v) {
+        return _wrap_DoubleVector_erase__SWIG_0(self, args);
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        if (_v) {
+          return _wrap_DoubleVector_erase__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_erase'.\n  Possible C/C++ prototypes are:\n""    erase(std::vector<double > *,std::vector<double >::iterator)\n""    erase(std::vector<double > *,std::vector<double >::iterator,std::vector<double >::iterator)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_3(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  size_t val1 ;
+  int ecode1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:new_DoubleVector",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "new_DoubleVector" "', argument " "2"" of type '" "std::vector<double >::value_type""'");
+  arg2 = &temp2;
+  result = (std::vector<double > *)new std::vector<double >(arg1,(std::vector<double >::value_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_DoubleVector(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[3];
+  int ii;
+  for (ii = 0; (ii < argc) && (ii < 2); ii++) {
+  if (argc == 0) {
+    return _wrap_new_DoubleVector__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_new_DoubleVector__SWIG_2(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_new_DoubleVector__SWIG_1(self, args);
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+        int res = SWIG_AsVal_double(argv[1], NULL);
+      if (_v) {
+        return _wrap_new_DoubleVector__SWIG_3(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'new_DoubleVector'.\n  Possible C/C++ prototypes are:\n""    std::vector<(double)>()\n""    std::vector<(double)>(std::vector<double > const &)\n""    std::vector<(double)>(std::vector<double >::size_type)\n""    std::vector<(double)>(std::vector<double >::size_type,std::vector<double >::value_type const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_push_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_push_back",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_push_back" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_push_back" "', argument " "2"" of type '" "std::vector<double >::value_type""'");
+  arg2 = &temp2;
+  (arg1)->push_back((std::vector<double >::value_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_front(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_front",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_front" "', argument " "1"" of type '" "std::vector<double > const *""'");
+    std::vector<double >::value_type const &_result_ref = ((std::vector<double > const *)arg1)->front();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_back",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_back" "', argument " "1"" of type '" "std::vector<double > const *""'");
+    std::vector<double >::value_type const &_result_ref = ((std::vector<double > const *)arg1)->back();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_assign(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_assign",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_assign" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_assign" "', argument " "2"" of type '" "std::vector<double >::size_type""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_assign" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
+  arg3 = &temp3;
+  (arg1)->assign(arg2,(std::vector<double >::value_type const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_resize__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  PyObject * obj2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_resize",&obj0,&obj1,&obj2)) SWIG_fail;
+  if (!SWIG_IsOK(ecode3)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_resize" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
+  arg3 = &temp3;
+  (arg1)->resize(arg2,(std::vector<double >::value_type const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_resize(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+        int res = SWIG_AsVal_size_t(argv[1], NULL);
+      if (_v) {
+        return _wrap_DoubleVector_resize__SWIG_0(self, args);
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+          int res = SWIG_AsVal_double(argv[2], NULL);
+        if (_v) {
+          return _wrap_DoubleVector_resize__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_resize'.\n  Possible C/C++ prototypes are:\n""    resize(std::vector<double > *,std::vector<double >::size_type)\n""    resize(std::vector<double > *,std::vector<double >::size_type,std::vector<double >::value_type const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_insert__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_insert",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_insert" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "DoubleVector_insert" "', argument " "2"" of type '" "std::vector<double >::iterator""'");
+  } else {
+    if (iter_t) {
+    } else {
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_insert" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
+  arg3 = &temp3;
+  result = (arg1)->insert(arg2,(std::vector<double >::value_type const &)*arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_insert__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<double >::size_type arg3 ;
+  std::vector<double >::value_type *arg4 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  size_t val3 ;
+  int ecode3 = 0 ;
+  std::vector<double >::value_type temp4 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  PyObject * obj3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOO:DoubleVector_insert",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+  } else {
+    if (iter_t) {
+    } else {
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_insert" "', argument " "3"" of type '" "std::vector<double >::size_type""'");
+  arg3 = static_cast< std::vector<double >::size_type >(val3);
+  ecode4 = SWIG_AsVal_double(obj3, &val4);
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DoubleVector_insert" "', argument " "4"" of type '" "std::vector<double >::value_type""'");
+  temp4 = static_cast< std::vector<double >::value_type >(val4);
+  arg4 = &temp4;
+  (arg1)->insert(arg2,arg3,(std::vector<double >::value_type const &)*arg4);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_insert(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        if (_v) {
+          return _wrap_DoubleVector_insert__SWIG_0(self, args);
+  if (argc == 4) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        if (_v) {
+            int res = SWIG_AsVal_double(argv[3], NULL);
+          if (_v) {
+            return _wrap_DoubleVector_insert__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_insert'.\n  Possible C/C++ prototypes are:\n""    insert(std::vector<double > *,std::vector<double >::iterator,std::vector<double >::value_type const &)\n""    insert(std::vector<double > *,std::vector<double >::iterator,std::vector<double >::size_type,std::vector<double >::value_type const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_reserve(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  size_t val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_reserve",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_reserve" "', argument " "1"" of type '" "std::vector<double > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_reserve" "', argument " "2"" of type '" "std::vector<double >::size_type""'");
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DoubleVector_capacity(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_capacity",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_capacity" "', argument " "1"" of type '" "std::vector<double > const *""'");
+  result = ((std::vector<double > const *)arg1)->capacity();
+  resultobj = SWIG_From_size_t(static_cast< size_t >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_delete_DoubleVector(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:delete_DoubleVector",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_POINTER_DISOWN |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_DoubleVector" "', argument " "1"" of type '" "std::vector<double > *""'");
+  delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *DoubleVector_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *obj;
+  if (!PyArg_ParseTuple(args,(char*)"O|swigregister", &obj)) return NULL;
+  SWIG_TypeNewClientData(SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_NewClientData(obj));
+  return SWIG_Py_Void();
+SWIGINTERN PyObject *_wrap_new_IntVecIntMap__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::less<int > *arg1 = 0 ;
+  std::map<int,std::vector<int > > *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:new_IntVecIntMap",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1, SWIGTYPE_p_std__lessTint_t,  0  | 0);
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::less<int > const &""'");
+  if (!argp1) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::less<int > const &""'");
+  arg1 = reinterpret_cast< std::less<int > * >(argp1);
+  result = (std::map<int,std::vector<int > > *)new std::map<int,std::vector<int > >((std::less<int > const &)*arg1);
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, SWIG_POINTER_NEW |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > > *arg1 = (std::map<int,std::vector<int > > *) 0 ;
+  PyObject **arg2 = (PyObject **) 0 ;
+  swig::PySwigIterator *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  arg2 = &obj0;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_iterator",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, 0 |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_iterator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  arg1 = reinterpret_cast< std::map<int,std::vector<int > > * >(argp1);
+  result = (swig::PySwigIterator *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__iterator(arg1,arg2);
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap___nonzero__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap___nonzero__",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___nonzero__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = (bool)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____nonzero__((std::map<int,std::vector<int > > const *)arg1);
+  resultobj = SWIG_From_bool(static_cast< bool >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap___len__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::size_type result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap___len__",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___len__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____len__((std::map<int,std::vector<int > > const *)arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap___getitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::key_type *arg2 = 0 ;
+  std::map<int,std::vector<int > >::mapped_type result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  std::map<int,std::vector<int > >::key_type temp2 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap___getitem__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___getitem__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  ecode2 = SWIG_AsVal_int(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___getitem__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  temp2 = static_cast< std::map<int,std::vector<int > >::key_type >(val2);
+  arg2 = &temp2;
+  try {
+    result = std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____getitem__((std::map<int,std::vector<int > > const *)arg1,(int const &)*arg2);
+  catch(std::out_of_range &_e) {
+    SWIG_exception_fail(SWIG_IndexError, (&_e)->what());
+  resultobj = swig::from(static_cast< std::vector<int,std::allocator<int > > >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap___delitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap___delitem__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___delitem__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___delitem__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  try {
+    std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____delitem__(arg1,(int const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_has_key(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_has_key",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_has_key" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_has_key" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = (bool)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__has_key((std::map<int,std::vector<int > > const *)arg1,(int const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_keys(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_keys",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_keys" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (PyObject *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__keys(arg1);
+  resultobj = result;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_values(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_values",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_values" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (PyObject *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__values(arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_items(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_items",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_items" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (PyObject *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__items(arg1);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap___contains__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap___contains__",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___contains__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___contains__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = (bool)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____contains__(arg1,(int const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_key_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  arg2 = &obj0;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_key_iterator",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_key_iterator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (swig::PySwigIterator *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__key_iterator(arg1,arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_value_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  arg2 = &obj0;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_value_iterator",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_value_iterator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (swig::PySwigIterator *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__value_iterator(arg1,arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap___setitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::mapped_type *arg3 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  int res3 = SWIG_OLDOBJ ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVecIntMap___setitem__",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___setitem__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___setitem__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+    std::vector<int,std::allocator<int > > *ptr = (std::vector<int,std::allocator<int > > *)0;
+    res3 = swig::asptr(obj2, &ptr);
+    if (!SWIG_IsOK(res3)) {
+      SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "IntVecIntMap___setitem__" "', argument " "3"" of type '" "std::map<int,std::vector<int > >::mapped_type const &""'");
+    if (!ptr) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVecIntMap___setitem__" "', argument " "3"" of type '" "std::map<int,std::vector<int > >::mapped_type const &""'");
+    arg3 = ptr;
+  try {
+    std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____setitem__(arg1,(int const &)*arg2,(std::vector<int,std::allocator<int > > const &)*arg3);
+  if (SWIG_IsNewObj(res3)) delete arg3;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVecIntMap__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  if (!PyArg_ParseTuple(args,(char *)":new_IntVecIntMap")) SWIG_fail;
+  result = (std::map<int,std::vector<int > > *)new std::map<int,std::vector<int > >();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVecIntMap__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int,std::allocator<int > > > *arg1 = 0 ;
+  int res1 = SWIG_OLDOBJ ;
+    std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > *ptr = (std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > *)0;
+    res1 = swig::asptr(obj0, &ptr);
+      SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > const &""'");
+    if (!ptr) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > const &""'");
+    arg1 = ptr;
+  result = (std::map<int,std::vector<int > > *)new std::map<int,std::vector<int > >((std::map<int,std::vector<int,std::allocator<int > > > const &)*arg1);
+  if (SWIG_IsNewObj(res1)) delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_IntVecIntMap(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[2];
+  int ii;
+  for (ii = 0; (ii < argc) && (ii < 1); ii++) {
+  if (argc == 0) {
+    return _wrap_new_IntVecIntMap__SWIG_1(self, args);
+  if (argc == 1) {
+    int _v;
+    int res = SWIG_ConvertPtr(argv[0], 0, SWIGTYPE_p_std__lessTint_t, 0);
+    if (_v) {
+      return _wrap_new_IntVecIntMap__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    int res = swig::asptr(argv[0], (std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >**)(0));
+    if (_v) {
+      return _wrap_new_IntVecIntMap__SWIG_2(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'new_IntVecIntMap'.\n  Possible C/C++ prototypes are:\n""    std::map<(int,std::vector<(int)>)>(std::less<int > const &)\n""    std::map<(int,std::vector<(int)>)>()\n""    std::map<(int,std::vector<(int)>)>(std::map<int,std::vector<int,std::allocator<int > > > const &)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_empty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_empty",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_empty" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = (bool)((std::map<int,std::vector<int > > const *)arg1)->empty();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_size(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_size",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_size" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = ((std::map<int,std::vector<int > > const *)arg1)->size();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_clear(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_clear",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_clear" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  (arg1)->clear();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_swap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int,std::allocator<int > > > *arg2 = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 = 0 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_swap",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_swap" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t,  0 );
+  if (!SWIG_IsOK(res2)) {
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "IntVecIntMap_swap" "', argument " "2"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > &""'");
+  if (!argp2) {
+    SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVecIntMap_swap" "', argument " "2"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > &""'");
+  arg2 = reinterpret_cast< std::map<int,std::vector<int,std::allocator<int > > > * >(argp2);
+  (arg1)->swap(*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_get_allocator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  SwigValueWrapper< std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_get_allocator",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_get_allocator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = ((std::map<int,std::vector<int > > const *)arg1)->get_allocator();
+  resultobj = SWIG_NewPointerObj((new std::map<int,std::vector<int > >::allocator_type(static_cast< const std::map<int,std::vector<int > >::allocator_type& >(result))), SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type, SWIG_POINTER_OWN |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_begin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_begin",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_begin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (arg1)->begin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::iterator & >(result)),
+    swig::PySwigIterator::descriptor(),SWIG_POINTER_OWN);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_begin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::const_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_begin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = ((std::map<int,std::vector<int > > const *)arg1)->begin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::const_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_begin(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_begin__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_begin__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_begin'.\n  Possible C/C++ prototypes are:\n""    begin(std::map<int,std::vector<int > > *)\n""    begin(std::map<int,std::vector<int > > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_end__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_end",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_end" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (arg1)->end();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_end__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_end" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = ((std::map<int,std::vector<int > > const *)arg1)->end();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_end(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_end__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_end__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_end'.\n  Possible C/C++ prototypes are:\n""    end(std::map<int,std::vector<int > > *)\n""    end(std::map<int,std::vector<int > > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_rbegin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::reverse_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_rbegin",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rbegin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (arg1)->rbegin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::reverse_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_rbegin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::const_reverse_iterator result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rbegin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = ((std::map<int,std::vector<int > > const *)arg1)->rbegin();
+  resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::const_reverse_iterator & >(result)),
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_rbegin(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_rbegin__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_rbegin__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_rbegin'.\n  Possible C/C++ prototypes are:\n""    rbegin(std::map<int,std::vector<int > > *)\n""    rbegin(std::map<int,std::vector<int > > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_rend__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_rend",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rend" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  result = (arg1)->rend();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_rend__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rend" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+  result = ((std::map<int,std::vector<int > > const *)arg1)->rend();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_rend(PyObject *self, PyObject *args) {
+  int argc;
+  int ii;
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_rend__SWIG_0(self, args);
+  if (argc == 1) {
+    int _v;
+    if (_v) {
+      return _wrap_IntVecIntMap_rend__SWIG_1(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_rend'.\n  Possible C/C++ prototypes are:\n""    rend(std::map<int,std::vector<int > > *)\n""    rend(std::map<int,std::vector<int > > const *)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_erase__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_erase",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_erase" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_erase" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = (arg1)->erase((std::map<int,std::vector<int > >::key_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_count(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_count",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_count" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_count" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = ((std::map<int,std::vector<int > > const *)arg1)->count((std::map<int,std::vector<int > >::key_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_erase__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::iterator arg2 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  swig::PySwigIterator *iter2 = 0 ;
+  int res2 ;
+  res2 = SWIG_ConvertPtr(obj1, SWIG_as_voidptrptr(&iter2), swig::PySwigIterator::descriptor(), 0);
+  if (!SWIG_IsOK(res2) || !iter2) {
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVecIntMap_erase" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::iterator""'");
+  } else {
+    swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *>(iter2);
+    if (iter_t) {
+      arg2 = iter_t->get_current();
+    } else {
+  (arg1)->erase(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_erase__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::map<int,std::vector<int > >::iterator arg3 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  swig::PySwigIterator *iter3 = 0 ;
+  int res3 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:IntVecIntMap_erase",&obj0,&obj1,&obj2)) SWIG_fail;
+  } else {
+    if (iter_t) {
+    } else {
+  res3 = SWIG_ConvertPtr(obj2, SWIG_as_voidptrptr(&iter3), swig::PySwigIterator::descriptor(), 0);
+  if (!SWIG_IsOK(res3) || !iter3) {
+    SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVecIntMap_erase" "', argument " "3"" of type '" "std::map<int,std::vector<int > >::iterator""'");
+  } else {
+    swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *>(iter3);
+    if (iter_t) {
+      arg3 = iter_t->get_current();
+    } else {
+  (arg1)->erase(arg2,arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_erase(PyObject *self, PyObject *args) {
+  int argc;
+  PyObject *argv[4];
+  int ii;
+  for (ii = 0; (ii < argc) && (ii < 3); ii++) {
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+      swig::PySwigIterator *iter = 0;
+      int res = SWIG_ConvertPtr(argv[1], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
+      _v = (SWIG_IsOK(res) && iter && (dynamic_cast<swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *>(iter) != 0));
+      if (_v) {
+        return _wrap_IntVecIntMap_erase__SWIG_1(self, args);
+  if (argc == 2) {
+    int _v;
+    if (_v) {
+        int res = SWIG_AsVal_int(argv[1], NULL);
+      if (_v) {
+        return _wrap_IntVecIntMap_erase__SWIG_0(self, args);
+  if (argc == 3) {
+    int _v;
+    if (_v) {
+      if (_v) {
+        int res = SWIG_ConvertPtr(argv[2], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
+        if (_v) {
+          return _wrap_IntVecIntMap_erase__SWIG_2(self, args);
+fail:
+  SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_erase'.\n  Possible C/C++ prototypes are:\n""    erase(std::map<int,std::vector<int > > *,std::map<int,std::vector<int > >::key_type const &)\n""    erase(std::map<int,std::vector<int > > *,std::map<int,std::vector<int > >::iterator)\n""    erase(std::map<int,std::vector<int > > *,std::map<int,std::vector<int > >::iterator,std::map<int,std::vector<int > >::iterator)\n");
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_find(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_find",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_find" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_find" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = (arg1)->find((std::map<int,std::vector<int > >::key_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_lower_bound(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_lower_bound",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_lower_bound" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_lower_bound" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = (arg1)->lower_bound((std::map<int,std::vector<int > >::key_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_IntVecIntMap_upper_bound(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_upper_bound",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_upper_bound" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_upper_bound" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
+  arg2 = &temp2;
+  result = (arg1)->upper_bound((std::map<int,std::vector<int > >::key_type const &)*arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_delete_IntVecIntMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:delete_IntVecIntMap",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, SWIG_POINTER_DISOWN |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_IntVecIntMap" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
+  delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *IntVecIntMap_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *obj;
+  SWIG_TypeNewClientData(SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_new_DisplayDriver(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *arg1 = (void *) 0 ;
+  DisplayDriver *result = 0 ;
+  int res1 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:new_DisplayDriver",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0,SWIG_as_voidptrptr(&arg1), 0, 0);
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_DisplayDriver" "', argument " "1"" of type '" "void *""'");
+  result = (DisplayDriver *)new DisplayDriver(arg1);
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_DisplayDriver, SWIG_POINTER_NEW |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_delete_DisplayDriver(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  DisplayDriver *arg1 = (DisplayDriver *) 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:delete_DisplayDriver",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_DisplayDriver, SWIG_POINTER_DISOWN |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_DisplayDriver" "', argument " "1"" of type '" "DisplayDriver *""'");
+  arg1 = reinterpret_cast< DisplayDriver * >(argp1);
+  delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_DrawMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  bool val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_DrawMap",&obj0,&obj1)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_DisplayDriver, 0 |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_DrawMap" "', argument " "1"" of type '" "DisplayDriver *""'");
+  ecode2 = SWIG_AsVal_bool(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_DrawMap" "', argument " "2"" of type '" "bool""'");
+  arg2 = static_cast< bool >(val2);
+  result = (int)(arg1)->DrawMap(arg2);
+  resultobj = SWIG_From_int(static_cast< int >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_SelectLinesByBox(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  double arg6 ;
+  double arg7 ;
+  int arg8 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  double val7 ;
+  int ecode7 = 0 ;
+  int val8 ;
+  int ecode8 = 0 ;
+  PyObject * obj4 = 0 ;
+  PyObject * obj5 = 0 ;
+  PyObject * obj6 = 0 ;
+  PyObject * obj7 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOO:DisplayDriver_SelectLinesByBox",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7)) SWIG_fail;
+  if (!SWIG_IsOK(res1)) {
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "1"" of type '" "DisplayDriver *""'");
+  ecode2 = SWIG_AsVal_double(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "2"" of type '" "double""'");
+  arg2 = static_cast< double >(val2);
+  ecode3 = SWIG_AsVal_double(obj2, &val3);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "3"" of type '" "double""'");
+  arg3 = static_cast< double >(val3);
+  if (!SWIG_IsOK(ecode4)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "4"" of type '" "double""'");
+  arg4 = static_cast< double >(val4);
+  ecode5 = SWIG_AsVal_double(obj4, &val5);
+  if (!SWIG_IsOK(ecode5)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "5"" of type '" "double""'");
+  arg5 = static_cast< double >(val5);
+  ecode6 = SWIG_AsVal_double(obj5, &val6);
+  if (!SWIG_IsOK(ecode6)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "6"" of type '" "double""'");
+  arg6 = static_cast< double >(val6);
+  ecode7 = SWIG_AsVal_double(obj6, &val7);
+  if (!SWIG_IsOK(ecode7)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "7"" of type '" "double""'");
+  arg7 = static_cast< double >(val7);
+  ecode8 = SWIG_AsVal_int(obj7, &val8);
+  if (!SWIG_IsOK(ecode8)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "8"" of type '" "int""'");
+  arg8 = static_cast< int >(val8);
+  result = (int)(arg1)->SelectLinesByBox(arg2,arg3,arg4,arg5,arg6,arg7,arg8);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_SelectLineByPoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *resultobj = 0;
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  int arg6 ;
+  int arg7 ;
+  std::vector<double,std::allocator<double > > result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  int val6 ;
+  int ecode6 = 0 ;
+  int val7 ;
+  int ecode7 = 0 ;
+  PyObject * obj0 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOO:DisplayDriver_SelectLineByPoint",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "1"" of type '" "DisplayDriver *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "5"" of type '" "double""'");
+  ecode6 = SWIG_AsVal_int(obj5, &val6);
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "6"" of type '" "int""'");
+  arg6 = static_cast< int >(val6);
+  ecode7 = SWIG_AsVal_int(obj6, &val7);
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "7"" of type '" "int""'");
+  arg7 = static_cast< int >(val7);
+  result = (arg1)->SelectLineByPoint(arg2,arg3,arg4,arg5,arg6,arg7);
+  resultobj = swig::from(static_cast< std::vector<double,std::allocator<double > > >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_GetSelected(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool arg2 ;
+  std::vector<int,std::allocator<int > > result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  bool val2 ;
+  int ecode2 = 0 ;
+  PyObject * obj1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_GetSelected",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_GetSelected" "', argument " "1"" of type '" "DisplayDriver *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_GetSelected" "', argument " "2"" of type '" "bool""'");
+  result = (arg1)->GetSelected(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_SetSelected(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  std::vector<int,std::allocator<int > > arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_SetSelected",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SetSelected" "', argument " "1"" of type '" "DisplayDriver *""'");
+    int res = swig::asptr(obj1, &ptr);
+    if (!SWIG_IsOK(res) || !ptr) {
+      SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "DisplayDriver_SetSelected" "', argument " "2"" of type '" "std::vector<int,std::allocator<int > >""'");
+    arg2 = *ptr;
+    if (SWIG_IsNewObj(res)) delete ptr;
+  result = (int)(arg1)->SetSelected(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_GetSelectedVertex(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOO:DisplayDriver_GetSelectedVertex",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "1"" of type '" "DisplayDriver *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "4"" of type '" "double""'");
+  result = (arg1)->GetSelectedVertex(arg2,arg3,arg4);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_CloseMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DisplayDriver_CloseMap",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_CloseMap" "', argument " "1"" of type '" "DisplayDriver *""'");
+  result = (int)(arg1)->CloseMap();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_OpenMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  char *arg2 = (char *) 0 ;
+  char *arg3 = (char *) 0 ;
+  bool arg4 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  char *buf2 = 0 ;
+  int alloc2 = 0 ;
+  int res3 ;
+  char *buf3 = 0 ;
+  int alloc3 = 0 ;
+  bool val4 ;
+  int ecode4 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOO:DisplayDriver_OpenMap",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_OpenMap" "', argument " "1"" of type '" "DisplayDriver *""'");
+  res2 = SWIG_AsCharPtrAndSize(obj1, &buf2, NULL, &alloc2);
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "DisplayDriver_OpenMap" "', argument " "2"" of type '" "char const *""'");
+  arg2 = reinterpret_cast< char * >(buf2);
+  res3 = SWIG_AsCharPtrAndSize(obj2, &buf3, NULL, &alloc3);
+    SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "DisplayDriver_OpenMap" "', argument " "3"" of type '" "char const *""'");
+  arg3 = reinterpret_cast< char * >(buf3);
+  ecode4 = SWIG_AsVal_bool(obj3, &val4);
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_OpenMap" "', argument " "4"" of type '" "bool""'");
+  arg4 = static_cast< bool >(val4);
+  result = (int)(arg1)->OpenMap((char const *)arg2,(char const *)arg3,arg4);
+  if (alloc2 == SWIG_NEWOBJ) delete[] buf2;
+  if (alloc3 == SWIG_NEWOBJ) delete[] buf3;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_ReloadMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:DisplayDriver_ReloadMap",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_ReloadMap" "', argument " "1"" of type '" "DisplayDriver *""'");
+  (arg1)->ReloadMap();
+  resultobj = SWIG_Py_Void();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_SetDevice(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *arg2 = (void *) 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res2 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_SetDevice",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SetDevice" "', argument " "1"" of type '" "DisplayDriver *""'");
+  res2 = SWIG_ConvertPtr(obj1,SWIG_as_voidptrptr(&arg2), 0, 0);
+    SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "DisplayDriver_SetDevice" "', argument " "2"" of type '" "void *""'");
+  (arg1)->SetDevice(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_SetRegion(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  double arg6 ;
+  double arg7 ;
+  double arg8 ;
+  double arg9 ;
+  double arg10 ;
+  double arg11 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  double val7 ;
+  int ecode7 = 0 ;
+  double val8 ;
+  int ecode8 = 0 ;
+  double val9 ;
+  int ecode9 = 0 ;
+  double val10 ;
+  int ecode10 = 0 ;
+  double val11 ;
+  int ecode11 = 0 ;
+  PyObject * obj8 = 0 ;
+  PyObject * obj9 = 0 ;
+  PyObject * obj10 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOO:DisplayDriver_SetRegion",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SetRegion" "', argument " "1"" of type '" "DisplayDriver *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_SetRegion" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_SetRegion" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_SetRegion" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_SetRegion" "', argument " "5"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_SetRegion" "', argument " "6"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_SetRegion" "', argument " "7"" of type '" "double""'");
+  ecode8 = SWIG_AsVal_double(obj7, &val8);
+    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "DisplayDriver_SetRegion" "', argument " "8"" of type '" "double""'");
+  arg8 = static_cast< double >(val8);
+  ecode9 = SWIG_AsVal_double(obj8, &val9);
+  if (!SWIG_IsOK(ecode9)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "DisplayDriver_SetRegion" "', argument " "9"" of type '" "double""'");
+  arg9 = static_cast< double >(val9);
+  ecode10 = SWIG_AsVal_double(obj9, &val10);
+  if (!SWIG_IsOK(ecode10)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "DisplayDriver_SetRegion" "', argument " "10"" of type '" "double""'");
+  arg10 = static_cast< double >(val10);
+  ecode11 = SWIG_AsVal_double(obj10, &val11);
+  if (!SWIG_IsOK(ecode11)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "DisplayDriver_SetRegion" "', argument " "11"" of type '" "double""'");
+  arg11 = static_cast< double >(val11);
+  (arg1)->SetRegion(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_DisplayDriver_UpdateSettings(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  unsigned long arg2 ;
+  bool arg3 ;
+  unsigned long arg4 ;
+  bool arg5 ;
+  unsigned long arg6 ;
+  bool arg7 ;
+  unsigned long arg8 ;
+  bool arg9 ;
+  unsigned long arg10 ;
+  bool arg11 ;
+  unsigned long arg12 ;
+  bool arg13 ;
+  unsigned long arg14 ;
+  bool arg15 ;
+  unsigned long arg16 ;
+  bool arg17 ;
+  unsigned long arg18 ;
+  bool arg19 ;
+  unsigned long arg20 ;
+  bool arg21 ;
+  unsigned long arg22 ;
+  bool arg23 ;
+  unsigned long arg24 ;
+  int arg25 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  unsigned long val2 ;
+  int ecode2 = 0 ;
+  bool val3 ;
+  int ecode3 = 0 ;
+  unsigned long val4 ;
+  int ecode4 = 0 ;
+  bool val5 ;
+  int ecode5 = 0 ;
+  unsigned long val6 ;
+  int ecode6 = 0 ;
+  bool val7 ;
+  int ecode7 = 0 ;
+  unsigned long val8 ;
+  int ecode8 = 0 ;
+  bool val9 ;
+  int ecode9 = 0 ;
+  unsigned long val10 ;
+  int ecode10 = 0 ;
+  bool val11 ;
+  int ecode11 = 0 ;
+  unsigned long val12 ;
+  int ecode12 = 0 ;
+  bool val13 ;
+  int ecode13 = 0 ;
+  unsigned long val14 ;
+  int ecode14 = 0 ;
+  bool val15 ;
+  int ecode15 = 0 ;
+  unsigned long val16 ;
+  int ecode16 = 0 ;
+  bool val17 ;
+  int ecode17 = 0 ;
+  unsigned long val18 ;
+  int ecode18 = 0 ;
+  bool val19 ;
+  int ecode19 = 0 ;
+  unsigned long val20 ;
+  int ecode20 = 0 ;
+  bool val21 ;
+  int ecode21 = 0 ;
+  unsigned long val22 ;
+  int ecode22 = 0 ;
+  bool val23 ;
+  int ecode23 = 0 ;
+  unsigned long val24 ;
+  int ecode24 = 0 ;
+  int val25 ;
+  int ecode25 = 0 ;
+  PyObject * obj11 = 0 ;
+  PyObject * obj12 = 0 ;
+  PyObject * obj13 = 0 ;
+  PyObject * obj14 = 0 ;
+  PyObject * obj15 = 0 ;
+  PyObject * obj16 = 0 ;
+  PyObject * obj17 = 0 ;
+  PyObject * obj18 = 0 ;
+  PyObject * obj19 = 0 ;
+  PyObject * obj20 = 0 ;
+  PyObject * obj21 = 0 ;
+  PyObject * obj22 = 0 ;
+  PyObject * obj23 = 0 ;
+  PyObject * obj24 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOOOOOOOOOOOOOOOO:DisplayDriver_UpdateSettings",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10,&obj11,&obj12,&obj13,&obj14,&obj15,&obj16,&obj17,&obj18,&obj19,&obj20,&obj21,&obj22,&obj23,&obj24)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_UpdateSettings" "', argument " "1"" of type '" "DisplayDriver *""'");
+  ecode2 = SWIG_AsVal_unsigned_SS_long(obj1, &val2);
+  if (!SWIG_IsOK(ecode2)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_UpdateSettings" "', argument " "2"" of type '" "unsigned long""'");
+  arg2 = static_cast< unsigned long >(val2);
+  ecode3 = SWIG_AsVal_bool(obj2, &val3);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_UpdateSettings" "', argument " "3"" of type '" "bool""'");
+  arg3 = static_cast< bool >(val3);
+  ecode4 = SWIG_AsVal_unsigned_SS_long(obj3, &val4);
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_UpdateSettings" "', argument " "4"" of type '" "unsigned long""'");
+  arg4 = static_cast< unsigned long >(val4);
+  ecode5 = SWIG_AsVal_bool(obj4, &val5);
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_UpdateSettings" "', argument " "5"" of type '" "bool""'");
+  arg5 = static_cast< bool >(val5);
+  ecode6 = SWIG_AsVal_unsigned_SS_long(obj5, &val6);
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_UpdateSettings" "', argument " "6"" of type '" "unsigned long""'");
+  arg6 = static_cast< unsigned long >(val6);
+  ecode7 = SWIG_AsVal_bool(obj6, &val7);
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_UpdateSettings" "', argument " "7"" of type '" "bool""'");
+  arg7 = static_cast< bool >(val7);
+  ecode8 = SWIG_AsVal_unsigned_SS_long(obj7, &val8);
+    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "DisplayDriver_UpdateSettings" "', argument " "8"" of type '" "unsigned long""'");
+  arg8 = static_cast< unsigned long >(val8);
+  ecode9 = SWIG_AsVal_bool(obj8, &val9);
+    SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "DisplayDriver_UpdateSettings" "', argument " "9"" of type '" "bool""'");
+  arg9 = static_cast< bool >(val9);
+  ecode10 = SWIG_AsVal_unsigned_SS_long(obj9, &val10);
+    SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "DisplayDriver_UpdateSettings" "', argument " "10"" of type '" "unsigned long""'");
+  arg10 = static_cast< unsigned long >(val10);
+  ecode11 = SWIG_AsVal_bool(obj10, &val11);
+    SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "DisplayDriver_UpdateSettings" "', argument " "11"" of type '" "bool""'");
+  arg11 = static_cast< bool >(val11);
+  ecode12 = SWIG_AsVal_unsigned_SS_long(obj11, &val12);
+  if (!SWIG_IsOK(ecode12)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode12), "in method '" "DisplayDriver_UpdateSettings" "', argument " "12"" of type '" "unsigned long""'");
+  arg12 = static_cast< unsigned long >(val12);
+  ecode13 = SWIG_AsVal_bool(obj12, &val13);
+  if (!SWIG_IsOK(ecode13)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode13), "in method '" "DisplayDriver_UpdateSettings" "', argument " "13"" of type '" "bool""'");
+  arg13 = static_cast< bool >(val13);
+  ecode14 = SWIG_AsVal_unsigned_SS_long(obj13, &val14);
+  if (!SWIG_IsOK(ecode14)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode14), "in method '" "DisplayDriver_UpdateSettings" "', argument " "14"" of type '" "unsigned long""'");
+  arg14 = static_cast< unsigned long >(val14);
+  ecode15 = SWIG_AsVal_bool(obj14, &val15);
+  if (!SWIG_IsOK(ecode15)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode15), "in method '" "DisplayDriver_UpdateSettings" "', argument " "15"" of type '" "bool""'");
+  arg15 = static_cast< bool >(val15);
+  ecode16 = SWIG_AsVal_unsigned_SS_long(obj15, &val16);
+  if (!SWIG_IsOK(ecode16)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode16), "in method '" "DisplayDriver_UpdateSettings" "', argument " "16"" of type '" "unsigned long""'");
+  arg16 = static_cast< unsigned long >(val16);
+  ecode17 = SWIG_AsVal_bool(obj16, &val17);
+  if (!SWIG_IsOK(ecode17)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode17), "in method '" "DisplayDriver_UpdateSettings" "', argument " "17"" of type '" "bool""'");
+  arg17 = static_cast< bool >(val17);
+  ecode18 = SWIG_AsVal_unsigned_SS_long(obj17, &val18);
+  if (!SWIG_IsOK(ecode18)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode18), "in method '" "DisplayDriver_UpdateSettings" "', argument " "18"" of type '" "unsigned long""'");
+  arg18 = static_cast< unsigned long >(val18);
+  ecode19 = SWIG_AsVal_bool(obj18, &val19);
+  if (!SWIG_IsOK(ecode19)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode19), "in method '" "DisplayDriver_UpdateSettings" "', argument " "19"" of type '" "bool""'");
+  arg19 = static_cast< bool >(val19);
+  ecode20 = SWIG_AsVal_unsigned_SS_long(obj19, &val20);
+  if (!SWIG_IsOK(ecode20)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode20), "in method '" "DisplayDriver_UpdateSettings" "', argument " "20"" of type '" "unsigned long""'");
+  arg20 = static_cast< unsigned long >(val20);
+  ecode21 = SWIG_AsVal_bool(obj20, &val21);
+  if (!SWIG_IsOK(ecode21)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode21), "in method '" "DisplayDriver_UpdateSettings" "', argument " "21"" of type '" "bool""'");
+  arg21 = static_cast< bool >(val21);
+  ecode22 = SWIG_AsVal_unsigned_SS_long(obj21, &val22);
+  if (!SWIG_IsOK(ecode22)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode22), "in method '" "DisplayDriver_UpdateSettings" "', argument " "22"" of type '" "unsigned long""'");
+  arg22 = static_cast< unsigned long >(val22);
+  ecode23 = SWIG_AsVal_bool(obj22, &val23);
+  if (!SWIG_IsOK(ecode23)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode23), "in method '" "DisplayDriver_UpdateSettings" "', argument " "23"" of type '" "bool""'");
+  arg23 = static_cast< bool >(val23);
+  ecode24 = SWIG_AsVal_unsigned_SS_long(obj23, &val24);
+  if (!SWIG_IsOK(ecode24)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode24), "in method '" "DisplayDriver_UpdateSettings" "', argument " "24"" of type '" "unsigned long""'");
+  arg24 = static_cast< unsigned long >(val24);
+  ecode25 = SWIG_AsVal_int(obj24, &val25);
+  if (!SWIG_IsOK(ecode25)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode25), "in method '" "DisplayDriver_UpdateSettings" "', argument " "25"" of type '" "int""'");
+  arg25 = static_cast< int >(val25);
+  (arg1)->UpdateSettings(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11,arg12,arg13,arg14,arg15,arg16,arg17,arg18,arg19,arg20,arg21,arg22,arg23,arg24,arg25);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *DisplayDriver_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *obj;
+  SWIG_TypeNewClientData(SWIGTYPE_p_DisplayDriver, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_print_error(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  char *arg1 = (char *) 0 ;
+  int arg2 ;
+  int result;
+  int res1 ;
+  char *buf1 = 0 ;
+  int alloc1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:print_error",&obj0,&obj1)) SWIG_fail;
+  res1 = SWIG_AsCharPtrAndSize(obj0, &buf1, NULL, &alloc1);
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "print_error" "', argument " "1"" of type '" "char const *""'");
+  arg1 = reinterpret_cast< char * >(buf1);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "print_error" "', argument " "2"" of type '" "int""'");
+  arg2 = static_cast< int >(val2);
+  result = (int)print_error((char const *)arg1,arg2);
+  if (alloc1 == SWIG_NEWOBJ) delete[] buf1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_new_Digit(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  Digit *result = 0 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:new_Digit",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_Digit" "', argument " "1"" of type '" "DisplayDriver *""'");
+  result = (Digit *)new Digit(arg1);
+  resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_Digit, SWIG_POINTER_NEW |  0 );
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_InitCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  Digit *arg1 = (Digit *) 0 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:Digit_InitCats",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, 0 |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_InitCats" "', argument " "1"" of type '" "Digit *""'");
+  arg1 = reinterpret_cast< Digit * >(argp1);
+  result = (int)(arg1)->InitCats();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_AddLine(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int arg2 ;
+  std::vector<double,std::allocator<double > > arg3 ;
+  int arg4 ;
+  int arg5 ;
+  char *arg6 = (char *) 0 ;
+  int arg7 ;
+  double arg8 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  int val4 ;
+  int ecode4 = 0 ;
+  int val5 ;
+  int ecode5 = 0 ;
+  int res6 ;
+  char *buf6 = 0 ;
+  int alloc6 = 0 ;
+  int val7 ;
+  int ecode7 = 0 ;
+  double val8 ;
+  int ecode8 = 0 ;
+  PyObject * obj2 = 0 ;
+  PyObject * obj3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOO:Digit_AddLine",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_AddLine" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_AddLine" "', argument " "2"" of type '" "int""'");
+    std::vector<double,std::allocator<double > > *ptr = (std::vector<double,std::allocator<double > > *)0;
+    int res = swig::asptr(obj2, &ptr);
+      SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_AddLine" "', argument " "3"" of type '" "std::vector<double,std::allocator<double > >""'");
+    arg3 = *ptr;
+  ecode4 = SWIG_AsVal_int(obj3, &val4);
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_AddLine" "', argument " "4"" of type '" "int""'");
+  arg4 = static_cast< int >(val4);
+  ecode5 = SWIG_AsVal_int(obj4, &val5);
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_AddLine" "', argument " "5"" of type '" "int""'");
+  arg5 = static_cast< int >(val5);
+  res6 = SWIG_AsCharPtrAndSize(obj5, &buf6, NULL, &alloc6);
+  if (!SWIG_IsOK(res6)) {
+    SWIG_exception_fail(SWIG_ArgError(res6), "in method '" "Digit_AddLine" "', argument " "6"" of type '" "char const *""'");
+  arg6 = reinterpret_cast< char * >(buf6);
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_AddLine" "', argument " "7"" of type '" "int""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "Digit_AddLine" "', argument " "8"" of type '" "double""'");
+  result = (int)(arg1)->AddLine(arg2,arg3,arg4,arg5,(char const *)arg6,arg7,arg8);
+  if (alloc6 == SWIG_NEWOBJ) delete[] buf6;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_RewriteLine(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:Digit_RewriteLine",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_RewriteLine" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_RewriteLine" "', argument " "2"" of type '" "int""'");
+      SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_RewriteLine" "', argument " "3"" of type '" "std::vector<double,std::allocator<double > >""'");
+    arg3 = *ptr;
+  result = (int)(arg1)->RewriteLine(arg2,arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_SplitLine(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOO:Digit_SplitLine",&obj0,&obj1,&obj2,&obj3,&obj4)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SplitLine" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SplitLine" "', argument " "2"" of type '" "double""'");
+  if (!SWIG_IsOK(ecode3)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_SplitLine" "', argument " "3"" of type '" "double""'");
+  ecode4 = SWIG_AsVal_double(obj3, &val4);
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_SplitLine" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_SplitLine" "', argument " "5"" of type '" "double""'");
+  result = (int)(arg1)->SplitLine(arg2,arg3,arg4,arg5);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_DeleteLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  bool arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  bool val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:Digit_DeleteLines",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_DeleteLines" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_DeleteLines" "', argument " "2"" of type '" "bool""'");
+  result = (int)(arg1)->DeleteLines(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_MoveLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  int arg5 ;
+  double arg6 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  int val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOO:Digit_MoveLines",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MoveLines" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_MoveLines" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_MoveLines" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_MoveLines" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_MoveLines" "', argument " "5"" of type '" "int""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_MoveLines" "', argument " "6"" of type '" "double""'");
+  result = (int)(arg1)->MoveLines(arg2,arg3,arg4,arg5,arg6);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_FlipLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:Digit_FlipLines",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_FlipLines" "', argument " "1"" of type '" "Digit *""'");
+  result = (int)(arg1)->FlipLines();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_MergeLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:Digit_MergeLines",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MergeLines" "', argument " "1"" of type '" "Digit *""'");
+  result = (int)(arg1)->MergeLines();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_BreakLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:Digit_BreakLines",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_BreakLines" "', argument " "1"" of type '" "Digit *""'");
+  result = (int)(arg1)->BreakLines();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_SnapLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:Digit_SnapLines",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SnapLines" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SnapLines" "', argument " "2"" of type '" "double""'");
+  result = (int)(arg1)->SnapLines(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_ConnectLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:Digit_ConnectLines",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_ConnectLines" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_ConnectLines" "', argument " "2"" of type '" "double""'");
+  result = (int)(arg1)->ConnectLines(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_ZBulkLabeling(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  double arg6 ;
+  double arg7 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  double val7 ;
+  int ecode7 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOO:Digit_ZBulkLabeling",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_ZBulkLabeling" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_ZBulkLabeling" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_ZBulkLabeling" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_ZBulkLabeling" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_ZBulkLabeling" "', argument " "5"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_ZBulkLabeling" "', argument " "6"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_ZBulkLabeling" "', argument " "7"" of type '" "double""'");
+  result = (int)(arg1)->ZBulkLabeling(arg2,arg3,arg4,arg5,arg6,arg7);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_CopyLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int res3 ;
+  char *buf3 = 0 ;
+  int alloc3 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:Digit_CopyLines",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_CopyLines" "', argument " "1"" of type '" "Digit *""'");
+      SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_CopyLines" "', argument " "2"" of type '" "std::vector<int,std::allocator<int > >""'");
+    arg2 = *ptr;
+    SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "Digit_CopyLines" "', argument " "3"" of type '" "char const *""'");
+  result = (int)(arg1)->CopyLines(arg2,(char const *)arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_MoveVertex(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  double arg6 ;
+  double arg7 ;
+  int arg8 ;
+  double arg9 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  double val7 ;
+  int ecode7 = 0 ;
+  int val8 ;
+  int ecode8 = 0 ;
+  double val9 ;
+  int ecode9 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOO:Digit_MoveVertex",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MoveVertex" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_MoveVertex" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_MoveVertex" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_MoveVertex" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_MoveVertex" "', argument " "5"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_MoveVertex" "', argument " "6"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_MoveVertex" "', argument " "7"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "Digit_MoveVertex" "', argument " "8"" of type '" "int""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "Digit_MoveVertex" "', argument " "9"" of type '" "double""'");
+  result = (int)(arg1)->MoveVertex(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_ModifyLineVertex(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  double arg6 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOO:Digit_ModifyLineVertex",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_ModifyLineVertex" "', argument " "1"" of type '" "Digit *""'");
+  ecode2 = SWIG_AsVal_int(obj1, &val2);
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_ModifyLineVertex" "', argument " "2"" of type '" "int""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_ModifyLineVertex" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_ModifyLineVertex" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_ModifyLineVertex" "', argument " "5"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_ModifyLineVertex" "', argument " "6"" of type '" "double""'");
+  result = (int)(arg1)->ModifyLineVertex(arg2,arg3,arg4,arg5,arg6);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_SelectLinesByQuery(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  double arg2 ;
+  double arg3 ;
+  double arg4 ;
+  double arg5 ;
+  double arg6 ;
+  double arg7 ;
+  bool arg8 ;
+  int arg9 ;
+  int arg10 ;
+  double arg11 ;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  double val2 ;
+  int ecode2 = 0 ;
+  double val3 ;
+  int ecode3 = 0 ;
+  double val4 ;
+  int ecode4 = 0 ;
+  double val5 ;
+  int ecode5 = 0 ;
+  double val6 ;
+  int ecode6 = 0 ;
+  double val7 ;
+  int ecode7 = 0 ;
+  bool val8 ;
+  int ecode8 = 0 ;
+  int val9 ;
+  int ecode9 = 0 ;
+  int val10 ;
+  int ecode10 = 0 ;
+  double val11 ;
+  int ecode11 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOO:Digit_SelectLinesByQuery",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SelectLinesByQuery" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SelectLinesByQuery" "', argument " "2"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_SelectLinesByQuery" "', argument " "3"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_SelectLinesByQuery" "', argument " "4"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_SelectLinesByQuery" "', argument " "5"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_SelectLinesByQuery" "', argument " "6"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_SelectLinesByQuery" "', argument " "7"" of type '" "double""'");
+  ecode8 = SWIG_AsVal_bool(obj7, &val8);
+    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "Digit_SelectLinesByQuery" "', argument " "8"" of type '" "bool""'");
+  arg8 = static_cast< bool >(val8);
+  ecode9 = SWIG_AsVal_int(obj8, &val9);
+    SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "Digit_SelectLinesByQuery" "', argument " "9"" of type '" "int""'");
+  arg9 = static_cast< int >(val9);
+  ecode10 = SWIG_AsVal_int(obj9, &val10);
+    SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "Digit_SelectLinesByQuery" "', argument " "10"" of type '" "int""'");
+  arg10 = static_cast< int >(val10);
+    SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "Digit_SelectLinesByQuery" "', argument " "11"" of type '" "double""'");
+  result = (arg1)->SelectLinesByQuery(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11);
+  resultobj = swig::from(static_cast< std::vector<int,std::allocator<int > > >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_CopyCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  SwigValueWrapper< std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > > arg2 ;
+  std::vector<int,std::allocator<int > > arg3 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  void *argp2 ;
+  int res2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOO:Digit_CopyCats",&obj0,&obj1,&obj2)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_CopyCats" "', argument " "1"" of type '" "Digit *""'");
+    res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t,  0  | 0);
+      SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Digit_CopyCats" "', argument " "2"" of type '" "std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > >""'");
+    if (!argp2) {
+      SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "Digit_CopyCats" "', argument " "2"" of type '" "std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > >""'");
+    } else {
+      std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > * temp = reinterpret_cast< std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > * >(argp2);
+      arg2 = *temp;
+      if (SWIG_IsNewObj(res2)) delete temp;
+    std::vector<int,std::allocator<int > > *ptr = (std::vector<int,std::allocator<int > > *)0;
+      SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_CopyCats" "', argument " "3"" of type '" "std::vector<int,std::allocator<int > >""'");
+    arg3 = *ptr;
+  result = (int)(arg1)->CopyCats(arg2,arg3);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_GetCategory(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int arg2 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:Digit_GetCategory",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_GetCategory" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_GetCategory" "', argument " "2"" of type '" "int""'");
+  result = (int)(arg1)->GetCategory(arg2);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_GetLineCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int arg2 ;
+  std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OO:Digit_GetLineCats",&obj0,&obj1)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_GetLineCats" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_GetLineCats" "', argument " "2"" of type '" "int""'");
+  result = (arg1)->GetLineCats(arg2);
+  resultobj = swig::from(static_cast< std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > >(result));
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_SetLineCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  int arg2 ;
+  int arg3 ;
+  std::vector<int,std::allocator<int > > arg4 ;
+  bool arg5 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  int val2 ;
+  int ecode2 = 0 ;
+  int val3 ;
+  int ecode3 = 0 ;
+  bool val5 ;
+  int ecode5 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOO:Digit_SetLineCats",&obj0,&obj1,&obj2,&obj3,&obj4)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SetLineCats" "', argument " "1"" of type '" "Digit *""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SetLineCats" "', argument " "2"" of type '" "int""'");
+  ecode3 = SWIG_AsVal_int(obj2, &val3);
+    SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_SetLineCats" "', argument " "3"" of type '" "int""'");
+  arg3 = static_cast< int >(val3);
+    int res = swig::asptr(obj3, &ptr);
+      SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_SetLineCats" "', argument " "4"" of type '" "std::vector<int,std::allocator<int > >""'");
+    arg4 = *ptr;
+    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_SetLineCats" "', argument " "5"" of type '" "bool""'");
+  result = (int)(arg1)->SetLineCats(arg2,arg3,arg4,arg5);
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_Digit_GetLayers(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:Digit_GetLayers",&obj0)) SWIG_fail;
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_GetLayers" "', argument " "1"" of type '" "Digit *""'");
+  result = (arg1)->GetLayers();
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *_wrap_delete_Digit(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:delete_Digit",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, SWIG_POINTER_DISOWN |  0 );
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Digit" "', argument " "1"" of type '" "Digit *""'");
+  delete arg1;
+  return resultobj;
+fail:
+  return NULL;
+SWIGINTERN PyObject *Digit_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *obj;
+  if (!PyArg_ParseTuple(args,(char*)"O|swigregister", &obj)) return NULL;
+  SWIG_TypeNewClientData(SWIGTYPE_p_Digit, SWIG_NewClientData(obj));
+  return SWIG_Py_Void();
+static PyMethodDef SwigMethods[] = {
+	 { (char *)"delete_PySwigIterator", _wrap_delete_PySwigIterator, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_value", _wrap_PySwigIterator_value, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_incr", _wrap_PySwigIterator_incr, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_decr", _wrap_PySwigIterator_decr, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_distance", _wrap_PySwigIterator_distance, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_equal", _wrap_PySwigIterator_equal, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_copy", _wrap_PySwigIterator_copy, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_next", _wrap_PySwigIterator_next, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_previous", _wrap_PySwigIterator_previous, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_advance", _wrap_PySwigIterator_advance, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator___eq__", _wrap_PySwigIterator___eq__, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator___ne__", _wrap_PySwigIterator___ne__, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator___iadd__", _wrap_PySwigIterator___iadd__, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator___isub__", _wrap_PySwigIterator___isub__, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator___add__", _wrap_PySwigIterator___add__, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator___sub__", _wrap_PySwigIterator___sub__, METH_VARARGS, NULL},
+	 { (char *)"PySwigIterator_swigregister", PySwigIterator_swigregister, METH_VARARGS, NULL},
+	 { (char *)"IntVector_iterator", _wrap_IntVector_iterator, METH_VARARGS, NULL},
+	 { (char *)"IntVector___nonzero__", _wrap_IntVector___nonzero__, METH_VARARGS, NULL},
+	 { (char *)"IntVector___len__", _wrap_IntVector___len__, METH_VARARGS, NULL},
+	 { (char *)"IntVector_pop", _wrap_IntVector_pop, METH_VARARGS, NULL},
+	 { (char *)"IntVector___getslice__", _wrap_IntVector___getslice__, METH_VARARGS, NULL},
+	 { (char *)"IntVector___setslice__", _wrap_IntVector___setslice__, METH_VARARGS, NULL},
+	 { (char *)"IntVector___delslice__", _wrap_IntVector___delslice__, METH_VARARGS, NULL},
+	 { (char *)"IntVector___delitem__", _wrap_IntVector___delitem__, METH_VARARGS, NULL},
+	 { (char *)"IntVector___getitem__", _wrap_IntVector___getitem__, METH_VARARGS, NULL},
+	 { (char *)"IntVector___setitem__", _wrap_IntVector___setitem__, METH_VARARGS, NULL},
+	 { (char *)"IntVector_append", _wrap_IntVector_append, METH_VARARGS, NULL},
+	 { (char *)"IntVector_empty", _wrap_IntVector_empty, METH_VARARGS, NULL},
+	 { (char *)"IntVector_size", _wrap_IntVector_size, METH_VARARGS, NULL},
+	 { (char *)"IntVector_clear", _wrap_IntVector_clear, METH_VARARGS, NULL},
+	 { (char *)"IntVector_swap", _wrap_IntVector_swap, METH_VARARGS, NULL},
+	 { (char *)"IntVector_get_allocator", _wrap_IntVector_get_allocator, METH_VARARGS, NULL},
+	 { (char *)"IntVector_begin", _wrap_IntVector_begin, METH_VARARGS, NULL},
+	 { (char *)"IntVector_end", _wrap_IntVector_end, METH_VARARGS, NULL},
+	 { (char *)"IntVector_rbegin", _wrap_IntVector_rbegin, METH_VARARGS, NULL},
+	 { (char *)"IntVector_rend", _wrap_IntVector_rend, METH_VARARGS, NULL},
+	 { (char *)"IntVector_pop_back", _wrap_IntVector_pop_back, METH_VARARGS, NULL},
+	 { (char *)"IntVector_erase", _wrap_IntVector_erase, METH_VARARGS, NULL},
+	 { (char *)"new_IntVector", _wrap_new_IntVector, METH_VARARGS, NULL},
+	 { (char *)"IntVector_push_back", _wrap_IntVector_push_back, METH_VARARGS, NULL},
+	 { (char *)"IntVector_front", _wrap_IntVector_front, METH_VARARGS, NULL},
+	 { (char *)"IntVector_back", _wrap_IntVector_back, METH_VARARGS, NULL},
+	 { (char *)"IntVector_assign", _wrap_IntVector_assign, METH_VARARGS, NULL},
+	 { (char *)"IntVector_resize", _wrap_IntVector_resize, METH_VARARGS, NULL},
+	 { (char *)"IntVector_insert", _wrap_IntVector_insert, METH_VARARGS, NULL},
+	 { (char *)"IntVector_reserve", _wrap_IntVector_reserve, METH_VARARGS, NULL},
+	 { (char *)"IntVector_capacity", _wrap_IntVector_capacity, METH_VARARGS, NULL},
+	 { (char *)"delete_IntVector", _wrap_delete_IntVector, METH_VARARGS, NULL},
+	 { (char *)"IntVector_swigregister", IntVector_swigregister, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_iterator", _wrap_DoubleVector_iterator, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___nonzero__", _wrap_DoubleVector___nonzero__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___len__", _wrap_DoubleVector___len__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_pop", _wrap_DoubleVector_pop, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___getslice__", _wrap_DoubleVector___getslice__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___setslice__", _wrap_DoubleVector___setslice__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___delslice__", _wrap_DoubleVector___delslice__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___delitem__", _wrap_DoubleVector___delitem__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___getitem__", _wrap_DoubleVector___getitem__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector___setitem__", _wrap_DoubleVector___setitem__, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_append", _wrap_DoubleVector_append, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_empty", _wrap_DoubleVector_empty, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_size", _wrap_DoubleVector_size, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_clear", _wrap_DoubleVector_clear, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_swap", _wrap_DoubleVector_swap, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_get_allocator", _wrap_DoubleVector_get_allocator, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_begin", _wrap_DoubleVector_begin, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_end", _wrap_DoubleVector_end, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_rbegin", _wrap_DoubleVector_rbegin, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_rend", _wrap_DoubleVector_rend, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_pop_back", _wrap_DoubleVector_pop_back, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_erase", _wrap_DoubleVector_erase, METH_VARARGS, NULL},
+	 { (char *)"new_DoubleVector", _wrap_new_DoubleVector, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_push_back", _wrap_DoubleVector_push_back, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_front", _wrap_DoubleVector_front, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_back", _wrap_DoubleVector_back, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_assign", _wrap_DoubleVector_assign, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_resize", _wrap_DoubleVector_resize, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_insert", _wrap_DoubleVector_insert, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_reserve", _wrap_DoubleVector_reserve, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_capacity", _wrap_DoubleVector_capacity, METH_VARARGS, NULL},
+	 { (char *)"delete_DoubleVector", _wrap_delete_DoubleVector, METH_VARARGS, NULL},
+	 { (char *)"DoubleVector_swigregister", DoubleVector_swigregister, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_iterator", _wrap_IntVecIntMap_iterator, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap___nonzero__", _wrap_IntVecIntMap___nonzero__, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap___len__", _wrap_IntVecIntMap___len__, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap___getitem__", _wrap_IntVecIntMap___getitem__, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap___delitem__", _wrap_IntVecIntMap___delitem__, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_has_key", _wrap_IntVecIntMap_has_key, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_keys", _wrap_IntVecIntMap_keys, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_values", _wrap_IntVecIntMap_values, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_items", _wrap_IntVecIntMap_items, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap___contains__", _wrap_IntVecIntMap___contains__, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_key_iterator", _wrap_IntVecIntMap_key_iterator, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_value_iterator", _wrap_IntVecIntMap_value_iterator, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap___setitem__", _wrap_IntVecIntMap___setitem__, METH_VARARGS, NULL},
+	 { (char *)"new_IntVecIntMap", _wrap_new_IntVecIntMap, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_empty", _wrap_IntVecIntMap_empty, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_size", _wrap_IntVecIntMap_size, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_clear", _wrap_IntVecIntMap_clear, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_swap", _wrap_IntVecIntMap_swap, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_get_allocator", _wrap_IntVecIntMap_get_allocator, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_begin", _wrap_IntVecIntMap_begin, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_end", _wrap_IntVecIntMap_end, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_rbegin", _wrap_IntVecIntMap_rbegin, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_rend", _wrap_IntVecIntMap_rend, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_count", _wrap_IntVecIntMap_count, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_erase", _wrap_IntVecIntMap_erase, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_find", _wrap_IntVecIntMap_find, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_lower_bound", _wrap_IntVecIntMap_lower_bound, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_upper_bound", _wrap_IntVecIntMap_upper_bound, METH_VARARGS, NULL},
+	 { (char *)"delete_IntVecIntMap", _wrap_delete_IntVecIntMap, METH_VARARGS, NULL},
+	 { (char *)"IntVecIntMap_swigregister", IntVecIntMap_swigregister, METH_VARARGS, NULL},
+	 { (char *)"new_DisplayDriver", _wrap_new_DisplayDriver, METH_VARARGS, NULL},
+	 { (char *)"delete_DisplayDriver", _wrap_delete_DisplayDriver, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_DrawMap", _wrap_DisplayDriver_DrawMap, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_SelectLinesByBox", _wrap_DisplayDriver_SelectLinesByBox, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_SelectLineByPoint", _wrap_DisplayDriver_SelectLineByPoint, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_GetSelected", _wrap_DisplayDriver_GetSelected, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_SetSelected", _wrap_DisplayDriver_SetSelected, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_GetSelectedVertex", _wrap_DisplayDriver_GetSelectedVertex, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_CloseMap", _wrap_DisplayDriver_CloseMap, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_OpenMap", _wrap_DisplayDriver_OpenMap, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_ReloadMap", _wrap_DisplayDriver_ReloadMap, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_SetDevice", _wrap_DisplayDriver_SetDevice, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_SetRegion", _wrap_DisplayDriver_SetRegion, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_UpdateSettings", _wrap_DisplayDriver_UpdateSettings, METH_VARARGS, NULL},
+	 { (char *)"DisplayDriver_swigregister", DisplayDriver_swigregister, METH_VARARGS, NULL},
+	 { (char *)"print_error", _wrap_print_error, METH_VARARGS, NULL},
+	 { (char *)"new_Digit", _wrap_new_Digit, METH_VARARGS, NULL},
+	 { (char *)"Digit_InitCats", _wrap_Digit_InitCats, METH_VARARGS, NULL},
+	 { (char *)"Digit_AddLine", _wrap_Digit_AddLine, METH_VARARGS, NULL},
+	 { (char *)"Digit_RewriteLine", _wrap_Digit_RewriteLine, METH_VARARGS, NULL},
+	 { (char *)"Digit_SplitLine", _wrap_Digit_SplitLine, METH_VARARGS, NULL},
+	 { (char *)"Digit_DeleteLines", _wrap_Digit_DeleteLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_MoveLines", _wrap_Digit_MoveLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_FlipLines", _wrap_Digit_FlipLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_MergeLines", _wrap_Digit_MergeLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_BreakLines", _wrap_Digit_BreakLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_SnapLines", _wrap_Digit_SnapLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_ConnectLines", _wrap_Digit_ConnectLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_ZBulkLabeling", _wrap_Digit_ZBulkLabeling, METH_VARARGS, NULL},
+	 { (char *)"Digit_CopyLines", _wrap_Digit_CopyLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_MoveVertex", _wrap_Digit_MoveVertex, METH_VARARGS, NULL},
+	 { (char *)"Digit_ModifyLineVertex", _wrap_Digit_ModifyLineVertex, METH_VARARGS, NULL},
+	 { (char *)"Digit_SelectLinesByQuery", _wrap_Digit_SelectLinesByQuery, METH_VARARGS, NULL},
+	 { (char *)"Digit_CopyCats", _wrap_Digit_CopyCats, METH_VARARGS, NULL},
+	 { (char *)"Digit_GetCategory", _wrap_Digit_GetCategory, METH_VARARGS, NULL},
+	 { (char *)"Digit_GetLineCats", _wrap_Digit_GetLineCats, METH_VARARGS, NULL},
+	 { (char *)"Digit_SetLineCats", _wrap_Digit_SetLineCats, METH_VARARGS, NULL},
+	 { (char *)"Digit_GetLayers", _wrap_Digit_GetLayers, METH_VARARGS, NULL},
+	 { (char *)"delete_Digit", _wrap_delete_Digit, METH_VARARGS, NULL},
+	 { (char *)"Digit_swigregister", Digit_swigregister, METH_VARARGS, NULL},
+	 { NULL, NULL, 0, NULL }
+/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
+static swig_type_info _swigt__p_Digit = {"_p_Digit", "Digit *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_DisplayDriver = {"_p_DisplayDriver", "DisplayDriver *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_allocator_type = {"_p_allocator_type", "allocator_type *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_char = {"_p_char", "char *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_difference_type = {"_p_difference_type", "difference_type *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_key_type = {"_p_key_type", "key_type *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_mapped_type = {"_p_mapped_type", "mapped_type *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_p_PyObject = {"_p_p_PyObject", "PyObject **", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_size_type = {"_p_size_type", "size_type *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__invalid_argument = {"_p_std__invalid_argument", "std::invalid_argument *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__lessTint_t = {"_p_std__lessTint_t", "std::less<int > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t = {"_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t", "std::map<int,std::vector<int > > *|std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > *|std::map<int,std::vector<int,std::allocator<int > > > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type = {"_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type", "std::map<int,std::vector<int > >::allocator_type *|std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t = {"_p_std__vectorTdouble_std__allocatorTdouble_t_t", "std::vector<double,std::allocator<double > > *|std::vector<double > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type = {"_p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type", "std::vector<double >::allocator_type *|std::allocator<double > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__vectorTint_std__allocatorTint_t_t = {"_p_std__vectorTint_std__allocatorTint_t_t", "std::vector<int,std::allocator<int > > *|std::vector<int > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__vectorTint_std__allocatorTint_t_t__allocator_type = {"_p_std__vectorTint_std__allocatorTint_t_t__allocator_type", "std::vector<int >::allocator_type *|std::allocator<int > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t = {"_p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t", "std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_swig__PySwigIterator = {"_p_swig__PySwigIterator", "swig::PySwigIterator *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_value_type = {"_p_value_type", "value_type *", 0, 0, (void*)0, 0};
+static swig_type_info *swig_type_initial[] = {
+  &_swigt__p_Digit,
+  &_swigt__p_DisplayDriver,
+  &_swigt__p_allocator_type,
+  &_swigt__p_char,
+  &_swigt__p_difference_type,
+  &_swigt__p_key_type,
+  &_swigt__p_mapped_type,
+  &_swigt__p_p_PyObject,
+  &_swigt__p_size_type,
+  &_swigt__p_std__invalid_argument,
+  &_swigt__p_std__lessTint_t,
+  &_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t,
+  &_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type,
+  &_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t,
+  &_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type,
+  &_swigt__p_std__vectorTint_std__allocatorTint_t_t,
+  &_swigt__p_std__vectorTint_std__allocatorTint_t_t__allocator_type,
+  &_swigt__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t,
+  &_swigt__p_swig__PySwigIterator,
+  &_swigt__p_value_type,
+static swig_cast_info _swigc__p_Digit[] = {  {&_swigt__p_Digit, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_DisplayDriver[] = {  {&_swigt__p_DisplayDriver, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_allocator_type[] = {  {&_swigt__p_allocator_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_char[] = {  {&_swigt__p_char, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_difference_type[] = {  {&_swigt__p_difference_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_key_type[] = {  {&_swigt__p_key_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_mapped_type[] = {  {&_swigt__p_mapped_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_p_PyObject[] = {  {&_swigt__p_p_PyObject, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_size_type[] = {  {&_swigt__p_size_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__invalid_argument[] = {  {&_swigt__p_std__invalid_argument, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__lessTint_t[] = {  {&_swigt__p_std__lessTint_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t[] = {  {&_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type[] = {  {&_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t[] = {  {&_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type[] = {  {&_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__vectorTint_std__allocatorTint_t_t[] = {  {&_swigt__p_std__vectorTint_std__allocatorTint_t_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__vectorTint_std__allocatorTint_t_t__allocator_type[] = {  {&_swigt__p_std__vectorTint_std__allocatorTint_t_t__allocator_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t[] = {  {&_swigt__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_swig__PySwigIterator[] = {  {&_swigt__p_swig__PySwigIterator, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_value_type[] = {  {&_swigt__p_value_type, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info *swig_cast_initial[] = {
+  _swigc__p_Digit,
+  _swigc__p_DisplayDriver,
+  _swigc__p_allocator_type,
+  _swigc__p_char,
+  _swigc__p_difference_type,
+  _swigc__p_key_type,
+  _swigc__p_mapped_type,
+  _swigc__p_p_PyObject,
+  _swigc__p_size_type,
+  _swigc__p_std__invalid_argument,
+  _swigc__p_std__lessTint_t,
+  _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t,
+  _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type,
+  _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t,
+  _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type,
+  _swigc__p_std__vectorTint_std__allocatorTint_t_t,
+  _swigc__p_std__vectorTint_std__allocatorTint_t_t__allocator_type,
+  _swigc__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t,
+  _swigc__p_swig__PySwigIterator,
+  _swigc__p_value_type,
+/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
+static swig_const_info swig_const_table[] = {
+{0, 0, 0, 0.0, 0, 0}};
+#ifdef __cplusplus
+#endif
+ * Type initialization:
+ * This problem is tough by the requirement that no dynamic
+ * memory is used. Also, since swig_type_info structures store pointers to
+ * swig_cast_info structures and swig_cast_info structures store pointers back
+ * to swig_type_info structures, we need some lookup code at initialization.
+ * The idea is that swig generates all the structures that are needed.
+ * The runtime then collects these partially filled structures.
+ * The SWIG_InitializeModule function takes these initial arrays out of
+ * swig_module, and does all the lookup, filling in the swig_module.types
+ * array with the correct data and linking the correct swig_cast_info
+ * structures together.
+ * The generated swig_type_info structures are assigned staticly to an initial
+ * array. We just loop through that array, and handle each type individually.
+ * First we lookup if this type has been already loaded, and if so, use the
+ * loaded structure instead of the generated one. Then we have to fill in the
+ * cast linked list. The cast data is initially stored in something like a
+ * two-dimensional array. Each row corresponds to a type (there are the same
+ * number of rows as there are in the swig_type_initial array). Each entry in
+ * a column is one of the swig_cast_info structures for that type.
+ * The cast_initial array is actually an array of arrays, because each row has
+ * a variable number of columns. So to actually build the cast linked list,
+ * we find the array of casts associated with the type, and loop through it
+ * adding the casts to the list. The one last trick we need to do is making
+ * sure the type pointer in the swig_cast_info struct is correct.
+ * First off, we lookup the cast->type name to see if it is already loaded.
+ * There are three cases to handle:
+ *  1) If the cast->type has already been loaded AND the type we are adding
+ *     casting info to has not been loaded (it is in this module), THEN we
+ *     replace the cast->type pointer with the type pointer that has already
+ *     been loaded.
+ *  2) If BOTH types (the one we are adding casting info to, and the
+ *     cast->type) are loaded, THEN the cast info has already been loaded by
+ *     the previous module so we just ignore it.
+ *  3) Finally, if cast->type has not already been loaded, then we add that
+ *     swig_cast_info to the linked list (because the cast->type) pointer will
+ *     be correct.
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* c-mode */
+#endif
+#endif
+#if 0
+#define SWIGRUNTIME_DEBUG
+#endif
+SWIGRUNTIME void
+SWIG_InitializeModule(void *clientdata) {
+  size_t i;
+  swig_module_info *module_head, *iter;
+  int found;
+  clientdata = clientdata;
+  /* check to see if the circular list has been setup, if not, set it up */
+  if (swig_module.next==0) {
+    /* Initialize the swig_module */
+    swig_module.type_initial = swig_type_initial;
+    swig_module.cast_initial = swig_cast_initial;
+    swig_module.next = &swig_module;
+  /* Try and load any already created modules */
+  module_head = SWIG_GetModule(clientdata);
+  if (!module_head) {
+    /* This is the first module loaded for this interpreter */
+    /* so set the swig module into the interpreter */
+    SWIG_SetModule(clientdata, &swig_module);
+    module_head = &swig_module;
+  } else {
+    /* the interpreter has loaded a SWIG module, but has it loaded this one? */
+    found=0;
+    iter=module_head;
+    do {
+      if (iter==&swig_module) {
+        found=1;
+        break;
+      iter=iter->next;
+    } while (iter!= module_head);
+    /* if the is found in the list, then all is done and we may leave */
+    if (found) return;
+    /* otherwise we must add out module into the list */
+    swig_module.next = module_head->next;
+    module_head->next = &swig_module;
+  /* Now work on filling in swig_module.types */
+#ifdef SWIGRUNTIME_DEBUG
+  printf("SWIG_InitializeModule: size %d\n", swig_module.size);
+#endif
+  for (i = 0; i < swig_module.size; ++i) {
+    swig_type_info *type = 0;
+    swig_type_info *ret;
+    swig_cast_info *cast;
+    printf("SWIG_InitializeModule: type %d %s\n", i, swig_module.type_initial[i]->name);
+#endif
+    /* if there is another module already loaded */
+    if (swig_module.next != &swig_module) {
+      type = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, swig_module.type_initial[i]->name);
+    if (type) {
+      /* Overwrite clientdata field */
+      printf("SWIG_InitializeModule: found type %s\n", type->name);
+#endif
+      if (swig_module.type_initial[i]->clientdata) {
+        type->clientdata = swig_module.type_initial[i]->clientdata;
+        printf("SWIG_InitializeModule: found and overwrite type %s \n", type->name);
+#endif
+    } else {
+      type = swig_module.type_initial[i];
+    /* Insert casting types */
+    cast = swig_module.cast_initial[i];
+    while (cast->type) {
+      /* Don't need to add information already in the list */
+      ret = 0;
+      printf("SWIG_InitializeModule: look cast %s\n", cast->type->name);
+#endif
+        ret = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, cast->type->name);
+        if (ret) printf("SWIG_InitializeModule: found cast %s\n", ret->name);
+#endif
+      if (ret) {
+        if (type == swig_module.type_initial[i]) {
+          printf("SWIG_InitializeModule: skip old type %s\n", ret->name);
+#endif
+          cast->type = ret;
+          ret = 0;
+        } else {
+          /* Check for casting already in the list */
+          swig_cast_info *ocast = SWIG_TypeCheck(ret->name, type);
+          if (ocast) printf("SWIG_InitializeModule: skip old cast %s\n", ret->name);
+#endif
+          if (!ocast) ret = 0;
+      if (!ret) {
+        printf("SWIG_InitializeModule: adding cast %s\n", cast->type->name);
+#endif
+        if (type->cast) {
+          type->cast->prev = cast;
+          cast->next = type->cast;
+        type->cast = cast;
+      cast++;
+    /* Set entry in modules->types array equal to the type */
+    swig_module.types[i] = type;
+  swig_module.types[i] = 0;
+  printf("**** SWIG_InitializeModule: Cast List ******\n");
+    int j = 0;
+    swig_cast_info *cast = swig_module.cast_initial[i];
+      printf("SWIG_InitializeModule: cast type %s\n", cast->type->name);
+      cast++;
+      ++j;
+    printf("---- Total casts: %d\n",j);
+#endif
+/* This function will propagate the clientdata field of type to
+* any new swig_type_info structures that have been added into the list
+* of equivalent types.  It is like calling
+* SWIG_TypeClientData(type, clientdata) a second time.
+SWIGRUNTIME void
+SWIG_PropagateClientData(void) {
+  size_t i;
+  swig_cast_info *equiv;
+  static int init_run = 0;
+  if (init_run) return;
+  init_run = 1;
+  for (i = 0; i < swig_module.size; i++) {
+    if (swig_module.types[i]->clientdata) {
+      equiv = swig_module.types[i]->cast;
+      while (equiv) {
+        if (!equiv->converter) {
+          if (equiv->type && !equiv->type->clientdata)
+          SWIG_TypeClientData(equiv->type, swig_module.types[i]->clientdata);
+        equiv = equiv->next;
+#ifdef __cplusplus
+#if 0
+  /* c-mode */
+#endif
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+  /* Python-specific SWIG API */
+#define SWIG_newvarlink()                             SWIG_Python_newvarlink()
+#define SWIG_addvarlink(p, name, get_attr, set_attr)  SWIG_Python_addvarlink(p, name, get_attr, set_attr)
+#define SWIG_InstallConstants(d, constants)           SWIG_Python_InstallConstants(d, constants)
+   * global variable support code.
+  typedef struct swig_globalvar {
+    char       *name;                  /* Name of global variable */
+    PyObject *(*get_attr)(void);       /* Return the current value */
+    int       (*set_attr)(PyObject *); /* Set the value */
+    struct swig_globalvar *next;
+  } swig_globalvar;
+  typedef struct swig_varlinkobject {
+    PyObject_HEAD
+    swig_globalvar *vars;
+  } swig_varlinkobject;
+  SWIGINTERN PyObject *
+  swig_varlink_repr(swig_varlinkobject *SWIGUNUSEDPARM(v)) {
+    return PyString_FromString("<Swig global variables>");
+  swig_varlink_str(swig_varlinkobject *v) {
+    PyObject *str = PyString_FromString("(");
+    swig_globalvar  *var;
+    for (var = v->vars; var; var=var->next) {
+      PyString_ConcatAndDel(&str,PyString_FromString(var->name));
+      if (var->next) PyString_ConcatAndDel(&str,PyString_FromString(", "));
+    PyString_ConcatAndDel(&str,PyString_FromString(")"));
+    return str;
+  SWIGINTERN int
+  swig_varlink_print(swig_varlinkobject *v, FILE *fp, int SWIGUNUSEDPARM(flags)) {
+    PyObject *str = swig_varlink_str(v);
+    fprintf(fp,"Swig global variables ");
+    fprintf(fp,"%s\n", PyString_AsString(str));
+    Py_DECREF(str);
+    return 0;
+  SWIGINTERN void
+  swig_varlink_dealloc(swig_varlinkobject *v) {
+    swig_globalvar *var = v->vars;
+    while (var) {
+      swig_globalvar *n = var->next;
+      free(var->name);
+      free(var);
+      var = n;
+  swig_varlink_getattr(swig_varlinkobject *v, char *n) {
+    PyObject *res = NULL;
+    while (var) {
+      if (strcmp(var->name,n) == 0) {
+        res = (*var->get_attr)();
+        break;
+      var = var->next;
+    if (res == NULL && !PyErr_Occurred()) {
+      PyErr_SetString(PyExc_NameError,"Unknown C global variable");
+    return res;
+  SWIGINTERN int
+  swig_varlink_setattr(swig_varlinkobject *v, char *n, PyObject *p) {
+    int res = 1;
+    while (var) {
+        res = (*var->set_attr)(p);
+        break;
+      var = var->next;
+    if (res == 1 && !PyErr_Occurred()) {
+    return res;
+  SWIGINTERN PyTypeObject*
+  swig_varlink_type(void) {
+    static char varlink__doc__[] = "Swig var link object";
+    static PyTypeObject varlink_type;
+    static int type_init = 0;
+    if (!type_init) {
+      const PyTypeObject tmp
+        PyObject_HEAD_INIT(NULL)
+        0,                                  /* Number of items in variable part (ob_size) */
+        (char *)"swigvarlink",              /* Type name (tp_name) */
+        sizeof(swig_varlinkobject),         /* Basic size (tp_basicsize) */
+        0,                                  /* Itemsize (tp_itemsize) */
+        (destructor) swig_varlink_dealloc,   /* Deallocator (tp_dealloc) */
+        (printfunc) swig_varlink_print,     /* Print (tp_print) */
+        (getattrfunc) swig_varlink_getattr, /* get attr (tp_getattr) */
+        (setattrfunc) swig_varlink_setattr, /* Set attr (tp_setattr) */
+        0,                                  /* tp_compare */
+        (reprfunc) swig_varlink_repr,       /* tp_repr */
+        0,                                  /* tp_as_number */
+        0,                                  /* tp_as_sequence */
+        0,                                  /* tp_as_mapping */
+        0,                                  /* tp_hash */
+        0,                                  /* tp_call */
+        (reprfunc)swig_varlink_str,        /* tp_str */
+        0,                                  /* tp_getattro */
+        0,                                  /* tp_setattro */
+        0,                                  /* tp_as_buffer */
+        0,                                  /* tp_flags */
+        varlink__doc__,                     /* tp_doc */
+        0,                                  /* tp_traverse */
+        0,                                  /* tp_clear */
+        0,                                  /* tp_richcompare */
+        0,                                  /* tp_weaklistoffset */
+#if PY_VERSION_HEX >= 0x02020000
+        0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, /* tp_iter -> tp_weaklist */
+#endif
+#if PY_VERSION_HEX >= 0x02030000
+        0,                                  /* tp_del */
+#endif
+#ifdef COUNT_ALLOCS
+        0,0,0,0                             /* tp_alloc -> tp_next */
+#endif
+      varlink_type = tmp;
+      varlink_type.ob_type = &PyType_Type;
+      type_init = 1;
+    return &varlink_type;
+  /* Create a variable linking object for use later */
+  SWIG_Python_newvarlink(void) {
+    swig_varlinkobject *result = PyObject_NEW(swig_varlinkobject, swig_varlink_type());
+    if (result) {
+      result->vars = 0;
+    return ((PyObject*) result);
+  SWIGINTERN void
+  SWIG_Python_addvarlink(PyObject *p, char *name, PyObject *(*get_attr)(void), int (*set_attr)(PyObject *p)) {
+    swig_varlinkobject *v = (swig_varlinkobject *) p;
+    swig_globalvar *gv = (swig_globalvar *) malloc(sizeof(swig_globalvar));
+    if (gv) {
+      size_t size = strlen(name)+1;
+      gv->name = (char *)malloc(size);
+      if (gv->name) {
+        strncpy(gv->name,name,size);
+        gv->get_attr = get_attr;
+        gv->set_attr = set_attr;
+        gv->next = v->vars;
+    v->vars = gv;
+  SWIG_globals(void) {
+    static PyObject *_SWIG_globals = 0;
+    if (!_SWIG_globals) _SWIG_globals = SWIG_newvarlink();
+    return _SWIG_globals;
+   * constants/methods manipulation
+  /* Install Constants */
+  SWIGINTERN void
+  SWIG_Python_InstallConstants(PyObject *d, swig_const_info constants[]) {
+    PyObject *obj = 0;
+    size_t i;
+    for (i = 0; constants[i].type; ++i) {
+      switch(constants[i].type) {
+      case SWIG_PY_POINTER:
+        obj = SWIG_NewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
+        break;
+      case SWIG_PY_BINARY:
+        obj = SWIG_NewPackedObj(constants[i].pvalue, constants[i].lvalue, *(constants[i].ptype));
+        break;
+      default:
+        obj = 0;
+        break;
+      if (obj) {
+        PyDict_SetItemString(d, constants[i].name, obj);
+        Py_DECREF(obj);
+  /* Fix SwigMethods to carry the callback ptrs when needed */
+  SWIGINTERN void
+  SWIG_Python_FixMethods(PyMethodDef *methods,
+    swig_const_info *const_table,
+    swig_type_info **types,
+    swig_type_info **types_initial) {
+    size_t i;
+    for (i = 0; methods[i].ml_name; ++i) {
+      const char *c = methods[i].ml_doc;
+      if (c && (c = strstr(c, "swig_ptr: "))) {
+        int j;
+        swig_const_info *ci = 0;
+        const char *name = c + 10;
+        for (j = 0; const_table[j].type; ++j) {
+          if (strncmp(const_table[j].name, name,
+              strlen(const_table[j].name)) == 0) {
+            ci = &(const_table[j]);
+            break;
+        if (ci) {
+          size_t shift = (ci->ptype) - types;
+          swig_type_info *ty = types_initial[shift];
+          size_t ldoc = (c - methods[i].ml_doc);
+          size_t lptr = strlen(ty->name)+2*sizeof(void*)+2;
+          char *ndoc = (char*)malloc(ldoc + lptr + 10);
+          if (ndoc) {
+            char *buff = ndoc;
+            void *ptr = (ci->type == SWIG_PY_POINTER) ? ci->pvalue : 0;
+            if (ptr) {
+              strncpy(buff, methods[i].ml_doc, ldoc);
+              buff += ldoc;
+              strncpy(buff, "swig_ptr: ", 10);
+              buff += 10;
+              SWIG_PackVoidPtr(buff, ptr, ty->name, lptr);
+              methods[i].ml_doc = ndoc;
+#ifdef __cplusplus
+#endif
+ *  Partial Init method
+#ifdef __cplusplus
+extern "C"
+#endif
+SWIGEXPORT void SWIG_init(void) {
+  PyObject *m, *d;
+  SWIG_Python_FixMethods(SwigMethods, swig_const_table, swig_types, swig_type_initial);
+  m = Py_InitModule((char *) SWIG_name, SwigMethods);
+  d = PyModule_GetDict(m);
+  SWIG_InitializeModule(0);
+  SWIG_InstallConstants(d,swig_const_table);
+  SWIG_Python_SetConstant(d, "GV_POINT",SWIG_From_int(static_cast< int >(0x01)));
+  SWIG_Python_SetConstant(d, "GV_LINE",SWIG_From_int(static_cast< int >(0x02)));
+  SWIG_Python_SetConstant(d, "GV_BOUNDARY",SWIG_From_int(static_cast< int >(0x04)));
+  SWIG_Python_SetConstant(d, "GV_CENTROID",SWIG_From_int(static_cast< int >(0x08)));
+  SWIG_Python_SetConstant(d, "GV_FACE",SWIG_From_int(static_cast< int >(0x10)));
+  SWIG_Python_SetConstant(d, "GV_KERNEL",SWIG_From_int(static_cast< int >(0x20)));
+  SWIG_Python_SetConstant(d, "GV_AREA",SWIG_From_int(static_cast< int >(0x40)));
+  SWIG_Python_SetConstant(d, "GV_VOLUME",SWIG_From_int(static_cast< int >(0x80)));
+  SWIG_Python_SetConstant(d, "GV_POINTS",SWIG_From_int(static_cast< int >((0x01|0x08))));
+  SWIG_Python_SetConstant(d, "GV_LINES",SWIG_From_int(static_cast< int >((0x02|0x04))));
+  SWIG_Python_SetConstant(d, "PORT_DOUBLE_MAX",SWIG_From_double(static_cast< double >(1.7976931348623157e+308)));
+  SWIG_Python_SetConstant(d, "NO_SNAP",SWIG_From_int(static_cast< int >(0)));
+  SWIG_Python_SetConstant(d, "SNAP",SWIG_From_int(static_cast< int >(1)));
+  SWIG_Python_SetConstant(d, "SNAPVERTEX",SWIG_From_int(static_cast< int >(2)));
+  SWIG_Python_SetConstant(d, "QUERY_UNKNOWN",SWIG_From_int(static_cast< int >(-1)));
+  SWIG_Python_SetConstant(d, "QUERY_LENGTH",SWIG_From_int(static_cast< int >(0)));
+  SWIG_Python_SetConstant(d, "QUERY_DANGLE",SWIG_From_int(static_cast< int >(1)));
+  SWIG_Python_SetConstant(d, "GSQL_MAX",SWIG_From_int(static_cast< int >(4000)));
Added: grass/trunk/gui/wxpython/vdigit/select.cpp
--- grass/trunk/gui/wxpython/vdigit/select.cpp	                        (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/select.cpp	2008-02-04 21:00:48 UTC (rev 29946)
@@ -0,0 +1,91 @@
+   \file select.cpp
+   \brief Select lines (by query)
+   This program is free software under the GNU General Public
+   License (>=v2). Read the file COPYING that comes with GRASS
+   for details.
+   (C) 2008 by The GRASS development team
+   \author Martin Landa <landa.martin gmail.com>
+   \date 2008
+extern "C" {
+#include <grass/vedit.h>
+#include "driver.h"
+#include "digit.h"
+   \brief Select features by query (based on geometry)
+   Currently supported:
+    - QUERY_LENGTH, select all lines longer then threshold (or shorter if threshold is negative)
+    - QUERY_DANGLE, select all dangles then threshold (or shorter if threshold is negative)
+   \todo Rewrite dangle part to use Vector library functionality
+   \todo 3D
+   \param x1,y1,z1,x2,y2,z2 bounding box
+   \param query query (length, dangle, ...)
+   \param thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
+   \param type feature type
+   \param box query features in bounding box
+   \return list of selected features
+std::vector<int> Digit::SelectLinesByQuery(double x1, double y1, double z1,
+					   double x2, double y2, double z2, bool box,
+					   int query, int type, double thresh)
+    int layer;
+    std::vector<int> ids;
+    struct ilist *List;
+    struct line_pnts *bbox;
+    if (!display->mapInfo) {
+	return ids;
+    layer = 1; // TODO
+    bbox  = NULL;
+    List = Vect_new_list();
+    if (box) {
+      bbox = Vect_new_line_struct();
+      Vect_append_point(bbox, x1, y1, z1);
+      Vect_append_point(bbox, x2, y1, z2);
+      Vect_append_point(bbox, x2, y2, z1);
+      Vect_append_point(bbox, x1, y2, z2);
+      Vect_select_lines_by_polygon (display->mapInfo, bbox, 0, NULL, type, List);
+      if (List->n_values == 0) {
+	  return ids;
+    G_debug(3, "wxDigit.SelectLinesByQuery(): lines=%d", List->n_values);
+    Vedit_select_by_query(display->mapInfo,
+			  type, layer, thresh, query,
+			  List);
+    ids = display->ListToVector(List); // TODO
+    Vect_destroy_list(List);
+    if (bbox) {
+	Vect_destroy_line_struct(bbox);
+    return ids;
