[GRASS-SVN] r29963 - in grass/trunk/gui/wxpython: gui_modules vdigit
Tue Feb 5 18:42:45 EST 2008
Author: martinl
Date: 2008-02-05 18:42:44 -0500 (Tue, 05 Feb 2008)
New Revision: 29963
   grass/trunk/gui/wxpython/gui_modules/digit.py
   grass/trunk/gui/wxpython/vdigit/digit.h
   grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
   grass/trunk/gui/wxpython/vdigit/line.cpp
   grass/trunk/gui/wxpython/vdigit/vertex.cpp
wxGUI/vdigit: fixed support for snapping to background map objects in vdigit interface.
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-05 21:39:40 UTC (rev 29962)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-05 23:42:44 UTC (rev 29963)
@@ -59,7 +59,7 @@
 # Use v.edit on background or experimental C++ interface (not yet completed)
-USEVEDIT = True
+USEVEDIT = False
 if USEVEDIT is True and GV_LINES is not None:
     print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface by default. " \
         "This can significantly slow down some operations especially for " \
@@ -467,7 +467,10 @@
         if tool == "vertexmove":
             command.append("coords=%f,%f" % (float(coords[0]), float(coords[1])))
             command.append("-1") # modify only first selected
+        if self.settings['backgroundMap'] != '':
+            command.append("bgmap=%s" % self.settings['backgroundMap'])
         # run the command
         vedit = gcmd.Command(cmd=command, stderr=None)
@@ -862,7 +865,7 @@
         snap, thresh = self.__getSnapThreshold()
         nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
-                                      snap, thresh)
+                                      str(self.settings["backgroundMap"]), snap, thresh)
         return nlines
@@ -879,7 +882,7 @@
         return self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
-                                     snap, thresh)
     def AddVertex(self, coords):
         """Add new vertex to the selected line/boundary on position 'coords'
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h	2008-02-05 21:39:40 UTC (rev 29962)
+++ grass/trunk/gui/wxpython/vdigit/digit.h	2008-02-05 23:42:44 UTC (rev 29963)
@@ -14,6 +14,7 @@
     DisplayDriver *display;
     int SetCategory(int, int);
+    struct Map_info** OpenBackgroundVectorMap(const char *);
 public:
     Digit(DisplayDriver *);
@@ -28,7 +29,7 @@
     int DeleteLines(bool);
     int MoveLines(double, double, double,
-		  int, double);
+		  const char*, int, double);
     int FlipLines();
     int MergeLines();
     int BreakLines();
@@ -40,7 +41,7 @@
     int MoveVertex(double, double, double,
-		   int, double);
     int ModifyLineVertex(int, double, double, double,
 			 double);
Modified: grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
--- grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp	2008-02-05 21:39:40 UTC (rev 29962)
+++ grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp	2008-02-05 23:42:44 UTC (rev 29963)
@@ -11044,8 +11044,9 @@
   double arg2 ;
   double arg3 ;
   double arg4 ;
-  int arg5 ;
-  double arg6 ;
+  char *arg5 = (char *) 0 ;
+  int arg6 ;
+  double arg7 ;
   int result;
   void *argp1 = 0 ;
   int res1 = 0 ;
@@ -11055,18 +11056,22 @@
   int ecode3 = 0 ;
   double val4 ;
   int ecode4 = 0 ;
-  int val5 ;
-  int ecode5 = 0 ;
-  double val6 ;
+  int res5 ;
+  char *buf5 = 0 ;
+  int alloc5 = 0 ;
+  int val6 ;
   int ecode6 = 0 ;
+  double val7 ;
+  int ecode7 = 0 ;
   PyObject * obj0 = 0 ;
   PyObject * obj1 = 0 ;
   PyObject * obj2 = 0 ;
   PyObject * obj3 = 0 ;
   PyObject * obj4 = 0 ;
   PyObject * obj5 = 0 ;
+  PyObject * obj6 = 0 ;
-  if (!PyArg_ParseTuple(args,(char *)"OOOOOO:Digit_MoveLines",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5)) SWIG_fail;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOO:Digit_MoveLines",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6)) SWIG_fail;
   res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, 0 |  0 );
   if (!SWIG_IsOK(res1)) {
     SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MoveLines" "', argument " "1"" of type '" "Digit *""'");
@@ -11087,20 +11092,27 @@
     SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_MoveLines" "', argument " "4"" of type '" "double""'");
   arg4 = static_cast< double >(val4);
-  ecode5 = SWIG_AsVal_int(obj4, &val5);
-  if (!SWIG_IsOK(ecode5)) {
-    SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_MoveLines" "', argument " "5"" of type '" "int""'");
-  arg5 = static_cast< int >(val5);
-  ecode6 = SWIG_AsVal_double(obj5, &val6);
+  res5 = SWIG_AsCharPtrAndSize(obj4, &buf5, NULL, &alloc5);
+  if (!SWIG_IsOK(res5)) {
+    SWIG_exception_fail(SWIG_ArgError(res5), "in method '" "Digit_MoveLines" "', argument " "5"" of type '" "char const *""'");
+  arg5 = reinterpret_cast< char * >(buf5);
+  ecode6 = SWIG_AsVal_int(obj5, &val6);
   if (!SWIG_IsOK(ecode6)) {
-    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_MoveLines" "', argument " "6"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_MoveLines" "', argument " "6"" of type '" "int""'");
-  arg6 = static_cast< double >(val6);
-  result = (int)(arg1)->MoveLines(arg2,arg3,arg4,arg5,arg6);
+  arg6 = static_cast< int >(val6);
+  ecode7 = SWIG_AsVal_double(obj6, &val7);
+  if (!SWIG_IsOK(ecode7)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_MoveLines" "', argument " "7"" of type '" "double""'");
+  arg7 = static_cast< double >(val7);
+  result = (int)(arg1)->MoveLines(arg2,arg3,arg4,(char const *)arg5,arg6,arg7);
   resultobj = SWIG_From_int(static_cast< int >(result));
+  if (alloc5 == SWIG_NEWOBJ) delete[] buf5;
   return resultobj;
 fail:
   return NULL;
@@ -11363,8 +11375,9 @@
   double arg5 ;
   double arg6 ;
   double arg7 ;
-  int arg8 ;
-  double arg9 ;
+  char *arg8 = (char *) 0 ;
+  int arg9 ;
+  double arg10 ;
   int result;
   void *argp1 = 0 ;
   int res1 = 0 ;
@@ -11380,10 +11393,13 @@
   int ecode6 = 0 ;
   double val7 ;
   int ecode7 = 0 ;
-  int val8 ;
-  int ecode8 = 0 ;
-  double val9 ;
+  int res8 ;
+  char *buf8 = 0 ;
+  int alloc8 = 0 ;
+  int val9 ;
   int ecode9 = 0 ;
+  double val10 ;
+  int ecode10 = 0 ;
@@ -11393,8 +11409,9 @@
   PyObject * obj7 = 0 ;
   PyObject * obj8 = 0 ;
+  PyObject * obj9 = 0 ;
-  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOO:Digit_MoveVertex",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8)) SWIG_fail;
+  if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOO:Digit_MoveVertex",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9)) SWIG_fail;
     SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MoveVertex" "', argument " "1"" of type '" "Digit *""'");
@@ -11430,20 +11447,27 @@
     SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_MoveVertex" "', argument " "7"" of type '" "double""'");
-  ecode8 = SWIG_AsVal_int(obj7, &val8);
-  if (!SWIG_IsOK(ecode8)) {
-    SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "Digit_MoveVertex" "', argument " "8"" of type '" "int""'");
-  arg8 = static_cast< int >(val8);
-  ecode9 = SWIG_AsVal_double(obj8, &val9);
+  res8 = SWIG_AsCharPtrAndSize(obj7, &buf8, NULL, &alloc8);
+  if (!SWIG_IsOK(res8)) {
+    SWIG_exception_fail(SWIG_ArgError(res8), "in method '" "Digit_MoveVertex" "', argument " "8"" of type '" "char const *""'");
+  arg8 = reinterpret_cast< char * >(buf8);
+  ecode9 = SWIG_AsVal_int(obj8, &val9);
   if (!SWIG_IsOK(ecode9)) {
-    SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "Digit_MoveVertex" "', argument " "9"" of type '" "double""'");
+    SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "Digit_MoveVertex" "', argument " "9"" of type '" "int""'");
-  arg9 = static_cast< double >(val9);
-  result = (int)(arg1)->MoveVertex(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9);
+  arg9 = static_cast< int >(val9);
+  ecode10 = SWIG_AsVal_double(obj9, &val10);
+  if (!SWIG_IsOK(ecode10)) {
+    SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "Digit_MoveVertex" "', argument " "10"" of type '" "double""'");
+  arg10 = static_cast< double >(val10);
+  result = (int)(arg1)->MoveVertex(arg2,arg3,arg4,arg5,arg6,arg7,(char const *)arg8,arg9,arg10);
+  if (alloc8 == SWIG_NEWOBJ) delete[] buf8;
   return resultobj;
 fail:
   return NULL;
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-02-05 21:39:40 UTC (rev 29962)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-02-05 23:42:44 UTC (rev 29963)
@@ -70,28 +70,13 @@
     BgMap = NULL;
     nbgmaps = 0;
     if (bgmap && strlen(bgmap) > 0) {
-	char name[GNAME_MAX];
-	char mapset[GMAPSET_MAX];
-	if (G_find_vector2 (bgmap, "") == NULL) {
+	BgMap = OpenBackgroundVectorMap(bgmap);
+	if (!BgMap) {
 	    return -1;
-	G__name_is_fully_qualified(bgmap, name, mapset);
-	if (strcmp(G_fully_qualified_name((const char*) display->mapInfo->name, (const char*) G_mapset()),
-		   G_fully_qualified_name((const char*) bgmap, (const char*) mapset))) {
+	else {
 	    nbgmaps = 1;
-	    BgMap = (struct Map_info**) G_malloc (nbgmaps * sizeof(struct Map_info*));
-	    BgMap[nbgmaps-1] = (struct Map_info *) G_malloc (sizeof(struct Map_info));
-	    // avoid GUI crash
-	    Vect_set_fatal_error(GV_FATAL_PRINT);
-	    if (Vect_open_old(BgMap[nbgmaps-1], name, mapset) == -1) {
-		G_free ((void *) BgMap[nbgmaps-1]);
-		return -1;
@@ -345,6 +330,7 @@
     \brief Move selected vector features
     \param move_x,move_y,move_z move direction (move_z is used only if map is 3D)
+    \param bgmap  map of background map or NULL
     \param snap snapping move (see vedit.h)
     \param thresh threshold value for snapping
@@ -352,17 +338,36 @@
     \return -1 on error
 int Digit::MoveLines(double move_x, double move_y, double move_z,
-		     int snap, double thresh)
+		     const char *bgmap, int snap, double thresh)
     int ret;
+    struct Map_info **BgMap; /* backgroud vector maps */
+    int nbgmaps;             /* number of registrated background maps */
     if (!display->mapInfo)
 	return -1;
-    ret = Vedit_move_lines(display->mapInfo, display->selected,
+    BgMap = NULL;
+    nbgmaps = 0;
+    if (bgmap && strlen(bgmap) > 0) {
+	if (!BgMap) {
+	    return -1;
+	else {
+	    nbgmaps = 1;
+    ret = Vedit_move_lines(display->mapInfo, BgMap, nbgmaps,
+			   display->selected,
 			   move_x, move_y, move_z,
 			   snap, thresh);
+    if (BgMap && BgMap[0]) {
+	Vect_close(BgMap[0]);
     return ret;
@@ -551,3 +556,52 @@
     return ret;
+   \brief Open background vector map
+   @todo support more background maps then only one
+   \param bgmap pointer to vector map name
+   \return vector map array
+   \return NULL on error
+struct Map_info** Digit::OpenBackgroundVectorMap(const char *bgmap)
+    char name[GNAME_MAX];
+    char mapset[GMAPSET_MAX];
+    int nbgmaps;
+    struct Map_info** BgMap;
+    if (!display->mapInfo) {
+	return NULL;
+    if (G_find_vector2 (bgmap, "") == NULL) {
+	return NULL;
+    nbgmaps = 0;
+    if (!G__name_is_fully_qualified(bgmap, name, mapset)) {
+	G_strncpy(name, bgmap, GNAME_MAX);
+	mapset[0] = '\0';
+    if (strcmp(G_fully_qualified_name((const char*) display->mapInfo->name, (const char*) G_mapset()),
+	       G_fully_qualified_name((const char*) bgmap, (const char*) mapset))) {
+	nbgmaps = 1;
+	BgMap = (struct Map_info**) G_malloc (nbgmaps * sizeof(struct Map_info*));
+	BgMap[nbgmaps-1] = (struct Map_info *) G_malloc (sizeof(struct Map_info));
+	// avoid GUI crash
+	Vect_set_fatal_error(GV_FATAL_PRINT);
+	if (Vect_open_old(BgMap[nbgmaps-1], name, mapset) == -1) {
+	    G_free ((void *) BgMap[nbgmaps-1]);
+	    BgMap = NULL;
+    return BgMap;
Modified: grass/trunk/gui/wxpython/vdigit/vertex.cpp
--- grass/trunk/gui/wxpython/vdigit/vertex.cpp	2008-02-05 21:39:40 UTC (rev 29962)
+++ grass/trunk/gui/wxpython/vdigit/vertex.cpp	2008-02-05 23:42:44 UTC (rev 29963)
@@ -25,6 +25,7 @@
    \param x,y,z coordinates (z is used only if map is 3d)
    \param move_x,move_y,move_z direction for moving vertex
    \param snap snap mode (see vector/v.edit/lib/vedit.h)
    \param thresh threshold value to identify vertex position
@@ -34,24 +35,42 @@
 int Digit::MoveVertex(double x, double y, double z,
-		      int snap, double thresh) {
+		      const char *bgmap, int snap, double thresh) {
     int ret;
     struct line_pnts *point;
 	return -1;
+    BgMap = NULL;
+    nbgmaps = 0;
+	if (!BgMap) {
+	    return -1;
+	else {
+	    nbgmaps = 1;
     point = Vect_new_line_struct();
     Vect_append_point(point, x, y, z);
     /* move only first found vertex in bbox */
-    ret = Vedit_move_vertex(display->mapInfo, NULL, 0, /* TODO: BG */
+    ret = Vedit_move_vertex(display->mapInfo, BgMap, nbgmaps,
 			    display->selected,
 			    point, thresh,
 			    1, snap);
     Vect_destroy_line_struct(point);
     return ret;
