[GRASS-SVN] r29979 - in grass/trunk/gui/wxpython: . gui_modules
Wed Feb 6 10:26:23 EST 2008
Author: martinl
Date: 2008-02-06 10:26:23 -0500 (Wed, 06 Feb 2008)
New Revision: 29979
Added:
   grass/trunk/gui/wxpython/gui_modules/preferences.py
Removed:
   grass/trunk/gui/wxpython/gui_modules/defaultfont.py
   grass/trunk/gui/wxpython/gui_modules/__init__.py
   grass/trunk/gui/wxpython/gui_modules/histogram.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/menudata.py
   grass/trunk/gui/wxpython/gui_modules/profile.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: New dialog 'GUI Preferences' add. Setting default display font moved to the preferences dialog.
Module defaultfont.py renamed to preferences.py.
TODO: add more items to the dialog.
TODO: to save settings.
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -1,6 +1,5 @@
 all = [ "dbm",
         "debug",
-        "defaultfont",
         "digit",
         "disp_print",
         "gcmd",
@@ -13,6 +12,7 @@
         "mapdisp",
         "menudata",
         "menuform",
+        "preferences",
         "profile",
         "render",
         "rules",
Deleted: grass/trunk/gui/wxpython/gui_modules/defaultfont.py
--- grass/trunk/gui/wxpython/gui_modules/defaultfont.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/gui_modules/defaultfont.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -1,143 +0,0 @@
-MODULE: defaultfont
-CLASSES:
- * SetDefaultFont
-PURPOSE: Sets default display font
-AUTHORS: The GRASS Development Team
-         Michael Barton (Arizona State University)
-COPYRIGHT: (C) 2007 by the GRASS Development Team
-       This program is free software under the GNU General Public
-       License (>=v2). Read the file COPYING that comes with GRASS
-       for details.
-import wx
-import wx.lib.filebrowsebutton as filebrowse
-import os,sys
-try:
-   from subprocess import *
-except:
-   from compat import subprocess
-   from compat.subprocess import *
-try:
-   import subprocess
-except:
-   CompatPath = os.getenv("GISBASE") + "/etc/wx"
-   sys.path.append(CompatPath)
-class SetDefaultFont(wx.Dialog):
-    Opens a file selection dialog to select default font
-    to use in all GRASS displays
-    def __init__(self, parent, ID, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
-            style=wx.DEFAULT_DIALOG_STYLE, encoding='ISO-8859-1'):
-        wx.Dialog.__init__(self, parent, ID, title, pos, size, style)
-        if "GRASS_FONT" in os.environ:
-            self.font = os.environ["GRASS_FONT"]
-        else:
-            self.font = None
-        self.fontlist = self.GetFonts()
-        self.encoding = encoding
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        box = wx.BoxSizer(wx.HORIZONTAL)
-        label = wx.StaticText(self, -1, "Select Font:", (15, 50))
-        box.Add(label, 0, wx.EXPAND|wx.GROW|wx.ALIGN_TOP|wx.RIGHT, 5)
-        self.fontlb = wx.ListBox(self, wx.ID_ANY, pos=wx.DefaultPosition,
-                                 size=(280,150), choices=self.fontlist,
-                                 style=wx.LB_SINGLE|wx.LB_SORT)
-        self.Bind(wx.EVT_LISTBOX, self.EvtListBox, self.fontlb)
-        self.Bind(wx.EVT_LISTBOX_DCLICK, self.EvtListBoxDClick, self.fontlb)
-        if self.font:
-            self.fontlb.SetStringSelection(self.font, True)
-        box.Add(self.fontlb, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT)
-        sizer.Add(box, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT|wx.ALL, 8)
-        label = wx.StaticText(self, -1, "Character encoding:")
-        box.Add(label, 0, wx.ALIGN_RIGHT|wx.RIGHT, 5)
-        self.textentry = wx.TextCtrl(self, -1, "", size=(200,-1))
-        self.textentry.SetValue(self.encoding)
-        box.Add(self.textentry, 0, wx.ALIGN_LEFT)
-        self.textentry.Bind(wx.EVT_TEXT, self.OnEncoding)
-        sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 8)
-        line = wx.StaticLine(self, -1, size=(20,-1), style=wx.LI_HORIZONTAL)
-        sizer.Add(line, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 10)
-        btnsizer = wx.StdDialogButtonSizer()
-        btn = wx.Button(self, wx.ID_OK)
-        btn.SetDefault()
-        btnsizer.AddButton(btn)
-        btn = wx.Button(self, wx.ID_CANCEL)
-        btnsizer.Realize()
-        sizer.Add(btnsizer, 0, wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
-        self.SetSizer(sizer)
-        sizer.Fit(self)
-    def EvtRadioBox(self, event):
-        if event.GetInt() == 0:
-            self.fonttype = 'grassfont'
-        elif event.GetInt() == 1:
-            self.fonttype = 'truetype'
-        self.fontlist = self.GetFonts(self.fonttype)
-        self.fontlb.SetItems(self.fontlist)
-    def OnEncoding(self, event):
-        self.encoding = event.GetString()
-    def EvtListBox(self, event):
-        self.font = event.GetString()
-        event.Skip()
-    def EvtListBoxDClick(self, event):
-        event.Skip()
-    def GetFonts(self):
-        parses fonts directory or fretypecap file to get a list of fonts for the listbox
-        fontlist = []
-        cmd = "d.font -l"
-        try:
-            p = Popen(cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=PIPE, close_fds=True)
-            dfonts = p.stdout.read().strip().split('\n')
-            dfonts.sort(lambda x,y: cmp(x.lower(), y.lower()))
-            for item in range(len(dfonts)):
-                # ignore duplicate fonts and those starting with #
-                if not dfonts[item].startswith('#') and \
-                    dfonts[item] != dfonts[item-1]:
-                    fontlist.append(dfonts[item])
-            if p.stdout < 0:
-                print >> sys.stderr, "Child was terminated by signal", p.stdout
-            elif p.stdout > 0:
-                #print >> sys.stderr, p.stdout
-                pass
-        except OSError, e:
-            print >> sys.stderr, "Execution failed:", e
-        return fontlist
Modified: grass/trunk/gui/wxpython/gui_modules/histogram.py
--- grass/trunk/gui/wxpython/gui_modules/histogram.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/gui_modules/histogram.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -36,7 +36,7 @@
 import render
 import menuform
 import disp_print
-import gui_modules.defaultfont as defaultfont
+from gui_modules.preferences import SetDefaultFont as SetDefaultFont
 from debug import Debug as Debug
 from icon import Icons as Icons
@@ -416,10 +416,10 @@
         set, font will be default display font.
-        dlg = defaultfont.SetDefaultFont(self, wx.ID_ANY, 'Select font for histogram text',
-                                   pos=wx.DefaultPosition, size=wx.DefaultSize,
-                                   encoding=self.encoding)
+        dlg = SetDefaultFont(self, wx.ID_ANY, 'Select font for histogram text',
+                             pos=wx.DefaultPosition, size=wx.DefaultSize,
+                             style=wx.DEFAULT_DIALOG_STYLE,
+                             encoding=self.encoding)
         dlg.fontlb.SetStringSelection(self.font, True)
         if dlg.ShowModal() == wx.ID_CANCEL:
             dlg.Destroy()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -59,7 +59,6 @@
 import disp_print
 import gcmd
 import dbm
-import defaultfont
 import histogram
 import profile
 import globalvar
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -160,7 +160,7 @@
                 ("Convert coordinates", "Convert coordinates from one projection to another", "self.OnMenuCmd", "m.proj"),
-              ("Display font", "Set default font for GRASS displays", "self.DefaultFont", ""),
+              ("Preferences", "GUI preferences (display font, etc.)", "self.OnPreferences", ""),
           ("Raster", (
               ("Develop map", (
Copied: grass/trunk/gui/wxpython/gui_modules/preferences.py (from rev 29976, grass/trunk/gui/wxpython/gui_modules/defaultfont.py)
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -0,0 +1,266 @@
+ at package preferences
+ at brief GUI preferences dialog
+Sets default display font, etc.
+Classes:
+ * PreferencesDialog
+ * SetDefaultFont
+(C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton (Arizona State University)
+Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import wx
+import wx.lib.filebrowsebutton as filebrowse
+gmpath = os.path.join( os.getenv("GISBASE"), "etc", "wx", "gui_modules")
+sys.path.append(gmpath)
+import gcmd
+class PreferencesDialog(wx.Dialog):
+    """GUI preferences dialog"""
+    def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE):
+        self.parent = parent # GMFrame
+        self.title = title
+        wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
+        # notebook
+        notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        # create notebook pages
+        self.__CreateGeneralPage(notebook)
+        self.__CreateAdvancedPage(notebook)
+        # buttons
+        # btnSave = wx.Button(self, wx.ID_SAVE)
+        btnApply = wx.Button(self, wx.ID_APPLY)
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnOk = wx.Button(self, wx.ID_OK)
+        btnOk.SetDefault()
+        # bindigs
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+        btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        # sizers
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(btnCancel)
+        # btnSizer.AddButton(btnSave)
+        btnSizer.AddButton(btnApply)
+        btnSizer.AddButton(btnOk)
+        btnSizer.Realize()
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+        mainSizer.Add(item=btnSizer, proportion=0,
+                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+    def __CreateGeneralPage(self, notebook):
+        """Create notebook page concerning with symbology settings"""
+        panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
+        notebook.AddPage(page=panel, text=_("General"))
+        border = wx.BoxSizer(wx.VERTICAL)
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("General settings"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridSizer = wx.GridBagSizer (hgap=5, vgap=5)
+        gridSizer.AddGrowableCol(0)
+        # display font
+        gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                         label=_("Default font for GRASS displays:")),
+                       flag=wx.ALIGN_LEFT |
+                       wx.ALIGN_CENTER_VERTICAL,
+                       pos=(0, 0))
+        fontButton = wx.Button(parent=panel, id=wx.ID_ANY,
+                               label=_("Set font"))
+        gridSizer.Add(item=fontButton,
+                       pos=(0, 1))
+        sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
+        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+        panel.SetSizer(border)
+        # bindings
+        fontButton.Bind(wx.EVT_BUTTON, self.OnSetFont)
+        return panel
+    def __CreateAdvancedPage(self, notebook):
+        notebook.AddPage(page=panel, text=_("Advanced"))
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Advanced settings"))
+        return panel
+    def OnSetFont(self, event):
+        """'Set font' button pressed"""
+        dlg = SetDefaultFont(parent=self, id=wx.ID_ANY,
+                             title=_('Select default display font'),
+                             encoding=self.parent.encoding)
+        if dlg.ShowModal() == wx.ID_CANCEL:
+            dlg.Destroy()
+            return
+        # set default font type, font, and encoding to whatever selected in dialog
+        if dlg.font != None:
+            self.font = dlg.font
+        if dlg.encoding != None:
+            self.encoding = dlg.encoding
+        dlg.Destroy()
+        # set default font and encoding environmental variables
+        os.environ["GRASS_FONT"] = self.font
+        if self.encoding != None and self.encoding != "ISO-8859-1":
+            os.environ["GRASS_ENCODING"] = self.encoding
+        event.Skip()
+    def OnOK(self, event):
+        """Button 'OK' clicked"""
+        self.Close()
+    def OnApply(self, event):
+        """Button 'Apply' clicked"""
+        pass
+    def OnCancel(self, event):
+        """Button 'Cancel' clicked"""
+        self.Close()
+class SetDefaultFont(wx.Dialog):
+    Opens a file selection dialog to select default font
+    to use in all GRASS displays
+    def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+            style=wx.DEFAULT_DIALOG_STYLE, encoding='ISO-8859-1'):
+        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+        if "GRASS_FONT" in os.environ:
+            self.font = os.environ["GRASS_FONT"]
+        else:
+            self.font = None
+        self.fontlist = self.GetFonts()
+        self.encoding = encoding
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        box = wx.BoxSizer(wx.HORIZONTAL)
+        label = wx.StaticText(self, -1, "Select Font:", (15, 50))
+        box.Add(label, 0, wx.EXPAND|wx.GROW|wx.ALIGN_TOP|wx.RIGHT, 5)
+        self.fontlb = wx.ListBox(self, wx.ID_ANY, pos=wx.DefaultPosition,
+                                 size=(280,150), choices=self.fontlist,
+                                 style=wx.LB_SINGLE|wx.LB_SORT)
+        self.Bind(wx.EVT_LISTBOX, self.EvtListBox, self.fontlb)
+        self.Bind(wx.EVT_LISTBOX_DCLICK, self.EvtListBoxDClick, self.fontlb)
+        if self.font:
+            self.fontlb.SetStringSelection(self.font, True)
+        box.Add(self.fontlb, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT)
+        sizer.Add(box, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT|wx.ALL, 8)
+        label = wx.StaticText(self, -1, "Character encoding:")
+        box.Add(label, 0, wx.ALIGN_RIGHT|wx.RIGHT, 5)
+        self.textentry = wx.TextCtrl(self, -1, "", size=(200,-1))
+        self.textentry.SetValue(self.encoding)
+        box.Add(self.textentry, 0, wx.ALIGN_LEFT)
+        self.textentry.Bind(wx.EVT_TEXT, self.OnEncoding)
+        sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 8)
+        line = wx.StaticLine(self, -1, size=(20,-1), style=wx.LI_HORIZONTAL)
+        sizer.Add(line, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 10)
+        btnsizer = wx.StdDialogButtonSizer()
+        btn = wx.Button(self, wx.ID_OK)
+        btn.SetDefault()
+        btnsizer.AddButton(btn)
+        btn = wx.Button(self, wx.ID_CANCEL)
+        btnsizer.Realize()
+        sizer.Add(btnsizer, 0, wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+    def EvtRadioBox(self, event):
+        if event.GetInt() == 0:
+            self.fonttype = 'grassfont'
+        elif event.GetInt() == 1:
+            self.fonttype = 'truetype'
+        self.fontlist = self.GetFonts(self.fonttype)
+        self.fontlb.SetItems(self.fontlist)
+    def OnEncoding(self, event):
+        self.encoding = event.GetString()
+    def EvtListBox(self, event):
+        self.font = event.GetString()
+        event.Skip()
+    def EvtListBoxDClick(self, event):
+        event.Skip()
+    def GetFonts(self):
+        parses fonts directory or fretypecap file to get a list of fonts for the listbox
+        fontlist = []
+        cmd = ["d.font", "-l"]
+        p = gcmd.Command(cmd, stderr=None)
+        dfonts = p.ReadStdOutput()
+        dfonts.sort(lambda x,y: cmp(x.lower(), y.lower()))
+        for item in range(len(dfonts)):
+           # ignore duplicate fonts and those starting with #
+           if not dfonts[item].startswith('#') and \
+                  dfonts[item] != dfonts[item-1]:
+              fontlist.append(dfonts[item])
+        return fontlist
Modified: grass/trunk/gui/wxpython/gui_modules/profile.py
--- grass/trunk/gui/wxpython/gui_modules/profile.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/gui_modules/profile.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -51,7 +51,6 @@
 import disp_print
 import gselect
 import gcmd
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-02-06 15:19:50 UTC (rev 29978)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-02-06 15:26:23 UTC (rev 29979)
@@ -69,7 +69,7 @@
 import gui_modules.menudata as menudata
 import gui_modules.menuform as menuform
 import gui_modules.grassenv as grassenv
+import gui_modules.preferences as preferences
 import gui_modules.histogram as histogram
 import gui_modules.profile as profile
 import gui_modules.rules as rules
@@ -792,31 +792,12 @@
         # reset display mode
         os.environ['GRASS_RENDER_IMMEDIATE'] = 'TRUE'
-    def DefaultFont(self, event):
-        """Set default font for GRASS displays"""
+    def OnPreferences(self, event):
+        """General GUI preferences/settings"""
+        preferences.PreferencesDialog(parent=self, title=_("GUI Preferences")).ShowModal()
-        dlg = defaultfont.SetDefaultFont(self, wx.ID_ANY, 'Select default display font',
-        if dlg.ShowModal() == wx.ID_CANCEL:
-            dlg.Destroy()
-            return
+        event.Skip()
-        # set default font type, font, and encoding to whatever selected in dialog
-        if dlg.font != None:
-            self.font = dlg.font
-        if dlg.encoding != None:
-            self.encoding = dlg.encoding
-        dlg.Destroy()
-        # set default font and encoding environmental variables
-        os.environ["GRASS_FONT"] = self.font
-        if self.encoding != None and self.encoding != "ISO-8859-1":
-            os.environ["GRASS_ENCODING"] = self.encoding
     def DispHistogram(self, event):
         Init histogram display canvas and tools
