[GRASS-SVN] r29989 - grass/trunk/scripts/i.landsat.rgb
Thu Feb 7 00:05:33 EST 2008
Author: hamish
Date: 2008-02-07 00:05:32 -0500 (Thu, 07 Feb 2008)
New Revision: 29989
   grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb
support for FP input maps (from i.fusion.brovey). thanks to Martin Landa for the bulk of the patch
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb	2008-02-07 00:18:52 UTC (rev 29988)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb	2008-02-07 05:05:32 UTC (rev 29989)
@@ -81,7 +81,13 @@
     exec g.parser "$0" "$@"
 fi
-# setting environment, so that awk works properly in all languages (unused?)
+# check if we have awk
+if [ ! -x "`which awk`" ] ; then
+    g.message -e "awk required, please install awk or gawk first"
+    exit 1
+fi
+# setting environment, so that awk works properly in all languages
 unset LC_ALL
 LC_NUMERIC=C
 export LC_NUMERIC
@@ -116,10 +122,10 @@
 if [ 0 -eq $GIS_FLAG_P ] ; then
    for i in $RED $GREEN $BLUE ; do
-      g.message "Processing [$i] .."
+      g.message "Processing <$i> ..."
       MIN=`r.univar -ge $i perc=2 | grep "^percentile_" | cut -d'=' -f2`
       MAX=`r.univar -ge $i perc=$BRIGHTNESS | grep "^percentile_" | cut -d'=' -f2`
-      #echo "[$i]:  min=$MIN   max=$MAX"
+      g.message -d message="<$i>:  min=$MIN   max=$MAX"
       r.colors $i col=rules << EOF
 	0% black
 	$MIN black
@@ -131,18 +137,14 @@
    ALL_MAX=0
    ALL_MIN=255
-      if [ $MAX -gt $ALL_MAX ] ; then
-	ALL_MAX=$MAX
-      fi
-      if [ $MIN -lt $ALL_MIN ] ; then
-	ALL_MIN=$MIN
-      fi
+      ALL_MAX=`echo "$MAX $ALL_MAX" | awk '{if ($1 > $2) print $1; else print $2}'`
+      ALL_MIN=`echo "$MIN $ALL_MIN" | awk '{if ($1 < $2) print $1; else print $2}'`
    done
-   #echo "all_min=$ALL_MIN   all_max=$ALL_MAX"
+   g.message -d message="all_min=$ALL_MIN   all_max=$ALL_MAX"
 	0% black
