[GRASS-SVN] r30018 - in grass/trunk/gui/wxpython: gui_modules vdigit
Fri Feb 8 12:57:10 EST 2008
Author: martinl
Date: 2008-02-08 12:57:10 -0500 (Fri, 08 Feb 2008)
New Revision: 30018
   grass/trunk/gui/wxpython/gui_modules/digit.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/vdigit/digit.h
   grass/trunk/gui/wxpython/vdigit/digit.i
   grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
   grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI/vdigit: new feature implemented (change type of selected features, point<->centroid, line<->boundary). Currently only in vdigit component.
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-08 17:57:10 UTC (rev 30018)
@@ -1014,6 +1014,18 @@
         """Get list of layers"""
         return self.digit.GetLayers()
+    def TypeConvForSelectedLines(self):
+        """Feature type conversion for selected objects.
+        Supported conversions:
+         - point <-> centroid
+         - line <-> boundary
+        @return number of modified features
+        @return -1 on error
+        return self.digit.TypeConvLines()
     def __getSnapThreshold(self):
         """Get snap mode and threshold value
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-02-08 17:57:10 UTC (rev 30018)
@@ -1176,7 +1176,7 @@
             if digitToolbar.action in ["deleteLine", "moveLine", "moveVertex",
                                        "copyCats", "editLine", "flipLine",
                                        "mergeLine", "snapLine",
-                                       "queryLine", "breakLine"]:
+                                       "queryLine", "breakLine", "typeConv"]:
                 nselected = 0
                 # -> delete line || move line || move vertex
                 if digitToolbar.action in ["moveVertex", "editLine"]:
@@ -1554,6 +1554,11 @@
                     digitClass.ZBulkLine(pos1, pos2, dlg.value.GetValue(), dlg.step.GetValue())
                 self.UpdateMap(render=False, renderVector=True)
+            elif digitToolbar.action == "typeConv":
+                # -> feature type conversion
+                # - point <-> centroid
+                # - line <-> boundary
+                digitClass.TypeConvForSelectedLines()
             if digitToolbar.action != "addLine":
                 # unselect and re-render
@@ -1588,10 +1593,10 @@
                 self.UpdateMap(render=False, renderVector=False)
             elif digitToolbar.action in ["deleteLine", "moveLine", "splitLine",
-                                  "addVertex", "removeVertex", "moveVertex",
-                                  "copyCats", "flipLine", "mergeLine",
-                                  "snapLine", "connectLine", "copyLine",
+                                         "addVertex", "removeVertex", "moveVertex",
+                                         "copyCats", "flipLine", "mergeLine",
+                                         "snapLine", "connectLine", "copyLine",
                 # varios tools -> unselected selected features
                 digitClass.driver.SetSelected([])
                 if digitToolbar.action in ["moveLine", "moveVertex", "editLine"] and \
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2008-02-08 17:57:10 UTC (rev 30018)
@@ -514,6 +514,10 @@
         toolMenu.AppendItem(zbulk)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
+        typeconv = wx.MenuItem(toolMenu, wx.ID_ANY, 'Feature type conversion')
+        toolMenu.AppendItem(typeconv)
+        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
         # Popup the menu.  If an item is selected then its handler
         # will be called before PopupMenu returns.
         self.parent.MapWindow.PopupMenu(toolMenu)
@@ -567,6 +571,17 @@
         self.action="zbulkLine"
         self.parent.MapWindow.mouse['box'] = 'line'
+    def OnTypeConversion(self, event):
+        Debug.msg(2, "Digittoolbar.OnTypeConversion():")
+        self.action="typeConv"
+        self.parent.MapWindow.mouse['box'] = 'box'
     def OnSelectMap (self, event):
         Select vector map layer for editing
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/vdigit/digit.h	2008-02-08 17:57:10 UTC (rev 30018)
@@ -35,6 +35,7 @@
     int BreakLines();
     int SnapLines(double);
     int ConnectLines(double);
+    int TypeConvLines();
     int ZBulkLabeling(double, double, double, double,
 		      double, double);
     int CopyLines(std::vector<int>, const char*);
Modified: grass/trunk/gui/wxpython/vdigit/digit.i
--- grass/trunk/gui/wxpython/vdigit/digit.i	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/vdigit/digit.i	2008-02-08 17:57:10 UTC (rev 30018)
@@ -19,3 +19,5 @@
 namespace std {
    %template(IntVecIntMap) map<int, vector<int> >;
+%include "driver.h"
+%include "digit.h"
\ No newline at end of file
Modified: grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
--- grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp	2008-02-08 17:57:10 UTC (rev 30018)
@@ -11245,6 +11245,28 @@
+SWIGINTERN PyObject *_wrap_Digit_TypeConvLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+  PyObject *resultobj = 0;
+  Digit *arg1 = (Digit *) 0 ;
+  int result;
+  void *argp1 = 0 ;
+  int res1 = 0 ;
+  PyObject * obj0 = 0 ;
+  if (!PyArg_ParseTuple(args,(char *)"O:Digit_TypeConvLines",&obj0)) SWIG_fail;
+  res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, 0 |  0 );
+  if (!SWIG_IsOK(res1)) {
+    SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_TypeConvLines" "', argument " "1"" of type '" "Digit *""'");
+  arg1 = reinterpret_cast< Digit * >(argp1);
+  result = (int)(arg1)->TypeConvLines();
+  resultobj = SWIG_From_int(static_cast< int >(result));
+  return resultobj;
+fail:
+  return NULL;
 SWIGINTERN PyObject *_wrap_Digit_ZBulkLabeling(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
@@ -12016,6 +12038,7 @@
 	 { (char *)"Digit_BreakLines", _wrap_Digit_BreakLines, METH_VARARGS, NULL},
 	 { (char *)"Digit_SnapLines", _wrap_Digit_SnapLines, METH_VARARGS, NULL},
 	 { (char *)"Digit_ConnectLines", _wrap_Digit_ConnectLines, METH_VARARGS, NULL},
+	 { (char *)"Digit_TypeConvLines", _wrap_Digit_TypeConvLines, METH_VARARGS, NULL},
 	 { (char *)"Digit_ZBulkLabeling", _wrap_Digit_ZBulkLabeling, METH_VARARGS, NULL},
 	 { (char *)"Digit_CopyLines", _wrap_Digit_CopyLines, METH_VARARGS, NULL},
 	 { (char *)"Digit_MoveVertex", _wrap_Digit_MoveVertex, METH_VARARGS, NULL},
@@ -12640,6 +12663,7 @@
   SWIG_InstallConstants(d,swig_const_table);
+  SWIG_Python_SetConstant(d, "GSQL_MAX",SWIG_From_int(static_cast< int >(4000)));
   SWIG_Python_SetConstant(d, "GV_POINT",SWIG_From_int(static_cast< int >(0x01)));
   SWIG_Python_SetConstant(d, "GV_LINE",SWIG_From_int(static_cast< int >(0x02)));
   SWIG_Python_SetConstant(d, "GV_BOUNDARY",SWIG_From_int(static_cast< int >(0x04)));
@@ -12657,6 +12681,5 @@
   SWIG_Python_SetConstant(d, "QUERY_UNKNOWN",SWIG_From_int(static_cast< int >(-1)));
   SWIG_Python_SetConstant(d, "QUERY_LENGTH",SWIG_From_int(static_cast< int >(0)));
   SWIG_Python_SetConstant(d, "QUERY_DANGLE",SWIG_From_int(static_cast< int >(1)));
-  SWIG_Python_SetConstant(d, "GSQL_MAX",SWIG_From_int(static_cast< int >(4000)));
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-02-08 17:33:17 UTC (rev 30017)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-02-08 17:57:10 UTC (rev 30018)
@@ -633,3 +633,72 @@
     return BgMap;
+   \brief Type conversion of selected features
+   \return number of modified features
+   \return -1 on error
+int Digit::TypeConvLines()
+    int nlines, line;
+    int type, newtype;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    if (!display->mapInfo) {
+	return -1;
+    nlines = 0;
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    for (int i = 0; i < display->selected->n_values; i++) {
+	line = display->selected->value[i];
+	if (!Vect_line_alive(display->mapInfo, line))
+	    continue;
+	type = Vect_read_line(display->mapInfo, Points, Cats, line);
+	if (type < 0) {
+	    return -1;
+	switch (type) {
+	case GV_POINT:
+	    newtype = GV_CENTROID;
+	    break;
+	case GV_CENTROID:
+	    newtype = GV_POINT;
+	    break;
+	case GV_LINE:
+	    newtype = GV_BOUNDARY;
+	    break;
+	case GV_BOUNDARY:
+	    newtype = GV_LINE;
+	    break;
+	default:
+	    newtype = -1;
+	    break;
+	G_debug(3, "Digit.TypeConvLines(): line=%d, from_type=%d, to_type=%d",
+		line, type, newtype);
+	if (newtype > 0) {
+	    if (Vect_rewrite_line(display->mapInfo, line, newtype, Points, Cats) < 0) {
+		return -1;
+	    nlines++;
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_cats_struct(Cats);
+    return nlines;
