[GRASS-SVN] r30023 - in grass/trunk/gui/wxpython: gui_modules vdigit
Fri Feb 8 16:20:14 EST 2008
Author: martinl
Date: 2008-02-08 16:20:14 -0500 (Fri, 08 Feb 2008)
New Revision: 30023
   grass/trunk/gui/wxpython/gui_modules/digit.py
   grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI: Change geometry type of selected features implemented also in vedit component. For vdigit is used veditlib fn.
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-08 21:08:16 UTC (rev 30022)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-08 21:20:14 UTC (rev 30023)
@@ -607,7 +607,15 @@
         """Connect selected lines/boundaries"""
         return self.__ModifyLines('connect')
+    def TypeConvForSelectedLines(self):
+        """Feature type conversion for selected objects.
+        Supported conversions:
+         - point <-> centroid
+         - line <-> boundary
+        return self.__ModifyLines('chtype')
     def ZBulkLine(self, pos1, pos2, value, step):
         """Provide z bulk-labeling (automated assigment of z coordinate
         to 3d lines
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-02-08 21:08:16 UTC (rev 30022)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-02-08 21:20:14 UTC (rev 30023)
@@ -646,59 +646,12 @@
 int Digit::TypeConvLines()
-    int nlines, line;
-    int type, newtype;
-    struct line_pnts *Points;
-    struct line_cats *Cats;
     if (!display->mapInfo) {
 	return -1;
-    nlines = 0;
-    Points = Vect_new_line_struct();
-    Cats = Vect_new_cats_struct();
-    for (int i = 0; i < display->selected->n_values; i++) {
-	line = display->selected->value[i];
-	if (!Vect_line_alive(display->mapInfo, line))
-	    continue;
-	type = Vect_read_line(display->mapInfo, Points, Cats, line);
-	if (type < 0) {
-	    return -1;
-	switch (type) {
-	case GV_POINT:
-	    newtype = GV_CENTROID;
-	    break;
-	case GV_CENTROID:
-	    newtype = GV_POINT;
-	    break;
-	case GV_LINE:
-	    newtype = GV_BOUNDARY;
-	    break;
-	case GV_BOUNDARY:
-	    newtype = GV_LINE;
-	    break;
-	default:
-	    newtype = -1;
-	    break;
-	G_debug(3, "Digit.TypeConvLines(): line=%d, from_type=%d, to_type=%d",
-		line, type, newtype);
-	if (newtype > 0) {
-	    if (Vect_rewrite_line(display->mapInfo, line, newtype, Points, Cats) < 0) {
-		return -1;
-	    nlines++;
-    Vect_destroy_line_struct(Points);
-    Vect_destroy_cats_struct(Cats);
-    return nlines;
+    int npoints, nlines, ncentroids, nboundaries;
+    return Vedit_chtype_lines (display->mapInfo, display->selected,
+			       &npoints, &ncentroids,
+			       &nlines, &nboundaries);
