[GRASS-SVN] r30032 - grass/trunk/lib/gis
Sat Feb 9 05:41:14 EST 2008
Author: neteler
Date: 2008-02-09 05:41:13 -0500 (Sat, 09 Feb 2008)
New Revision: 30032
   grass/trunk/lib/gis/mapset.c
use GMAPSET_MAX; direct use of G_fatal_error()
Modified: grass/trunk/lib/gis/mapset.c
--- grass/trunk/lib/gis/mapset.c	2008-02-09 08:56:43 UTC (rev 30031)
+++ grass/trunk/lib/gis/mapset.c	2008-02-09 10:41:13 UTC (rev 30032)
@@ -30,12 +30,10 @@
 char *
 G_mapset(void)
-    static char mapset[30];
+    static char mapset[GMAPSET_MAX];
     static int first = 1;
     char *m;
-    char msg[100];
     m = G__mapset();
     if( m == NULL )
         G_fatal_error( _("MAPSET is not set") );
@@ -53,14 +51,13 @@
 	    return mapset;
     case 0:
-	    sprintf(msg,"MAPSET %s - permission denied", mapset);
+	    G_fatal_error ("MAPSET %s - permission denied", mapset);
 	    break;
     default:
-	    sprintf(msg,_("MAPSET %s not found"), mapset);
+	    G_fatal_error (_("MAPSET %s not found"), mapset);
 	    break;
-    G_fatal_error (msg);
     exit(EXIT_FAILURE);
