[GRASS-SVN] r30045 - grass/trunk/visualization/nviz/scripts
Sat Feb 9 20:14:11 EST 2008
Author: cmbarton
Date: 2008-02-09 20:14:11 -0500 (Sat, 09 Feb 2008)
New Revision: 30045
   grass/trunk/visualization/nviz/scripts/nviz2.2_script
   grass/trunk/visualization/nviz/scripts/panel_main.tcl
Committing patches from Maris Nartiss. Improve 3dview loading and optimizing code for setting view mode.
Modified: grass/trunk/visualization/nviz/scripts/nviz2.2_script
--- grass/trunk/visualization/nviz/scripts/nviz2.2_script	2008-02-10 01:12:26 UTC (rev 30044)
+++ grass/trunk/visualization/nviz/scripts/nviz2.2_script	2008-02-10 01:14:11 UTC (rev 30045)
@@ -730,21 +730,31 @@
         # Do not redraw automaticly display while loading state...
         set oNauto_draw $Nauto_draw
         set Nauto_draw 0
-        #do a quick draw to make sure display initialized
-        Nquick_draw
-        Nload_3dview $file_name
 	Nquick_draw
 	#Reset position GUI
-	set ht [lindex [Nget_real_position 1] 2]
+	#set ht [lindex [Nget_real_position 1] 2]
+	# for some strange reason height gets read/loaded from file correctly
+	#   only if view is loaded for second time
+	# Also currently light related stuff is not updated
+	set ht [lindex [Nget_height] 0]
+	set ex [Nget_exag]
+	set tw [Nget_twist]
+	set pe [Nget_fov]
 	#reset height
-	Nv_setEntry $Nv_(main_BASE).midf.height.f.entry	 $ht
+	Nv_setEntry $Nv_(main_BASE).midf.height.f.entry	$ht
 	Nv_floatscaleCallback $Nv_(main_BASE).midf.height e 2 null $ht
-	#change_display 2
-	#change_display 1
+	# reset exag
+	Nv_setEntry $Nv_(main_BASE).midf.zexag.f.entry $ex
+	Nv_floatscaleCallback $Nv_(main_BASE).midf.zexag b 2 Nchange_exag $ex
+	# reset twist/perspective
+	Nv_setEntry $Nv_(main_BASE).bframe.cframe.tw.f.entry $tw
+	Nv_scaleCallback $Nv_(main_BASE).bframe.cframe.tw b 2 Nchange_twist $tw
+	Nv_setEntry $Nv_(main_BASE).bframe.cframe.pers.f.entry $pe
+	Nv_scaleCallback $Nv_(main_BASE).bframe.cframe.pers b 2 Nchange_persp $pe
         if { $draw_option == 1 } { change_display 0 } \
         elseif { $draw_option == 0 } { change_display 1 }
Modified: grass/trunk/visualization/nviz/scripts/panel_main.tcl
--- grass/trunk/visualization/nviz/scripts/panel_main.tcl	2008-02-10 01:12:26 UTC (rev 30044)
+++ grass/trunk/visualization/nviz/scripts/panel_main.tcl	2008-02-10 01:14:11 UTC (rev 30045)
@@ -508,7 +508,6 @@
 	set h [lindex [Nget_real_position 1] 2]
 	set min [lindex [Nget_height] 1]
 	set max [lindex [Nget_height] 2]
-	set Nv_(FlyThrough) 0
 	if {$flag == 1} {
 		#draw eye position
@@ -521,12 +520,13 @@
 		set XY [Nv_mkXYScale $NAME cross XY_POS 125 125 109 109 update_center_position]
-	if {$Nv_(FlyThrough) == 0} {
+	if {$Nv_(FlyThrough)} {
 		pack_XY
 	} else {
 		pack $XY -side left -before $Nv_(HEIGHT_SLIDER)
+	set Nv_(FlyThrough) 0
 	update_height $h
 	reset_res
 	move_position
