[GRASS-SVN] r30077 - grass/trunk/lib/init
Mon Feb 11 06:21:23 EST 2008
Author: martinl
Date: 2008-02-11 06:21:23 -0500 (Mon, 11 Feb 2008)
New Revision: 30077
   grass/trunk/lib/init/init.sh
Switch 'wx' renamed to 'wxpython', 'oldtcltk' used for d.m.
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh	2008-02-11 10:51:52 UTC (rev 30076)
+++ grass/trunk/lib/init/init.sh	2008-02-11 11:21:23 UTC (rev 30077)
@@ -72,18 +72,20 @@
     	# Check if the user asked for help
 	help|-h|-help|--help)
 	    echo "Usage:"
-	    echo "  $CMD_NAME [-h | -help | --help] [-text | -gui | -tcltk | -wx] [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]"
+	    echo "  $CMD_NAME [-h | -help | --help] [-text | -gui | -tcltk | -wxpython] [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]"
 	    echo
             echo "Flags:"
             echo "  -h or -help or --help          print this help message"
             echo "  -text                          use text based interface"
             echo "                                   and set as default"
-            echo "  -gui (or -tcltk)               use Tcl/Tk based graphical user interface"
+            echo "  -gui                           use graphical user interface (tcltk by default)"
-	    echo "  -oldgui                        use the old Tcl/Tk GUI interface "
+            echo "  -tcltk                         use Tcl/Tk based graphical user interface"
-            echo "  -wx                            use wxPython based graphical user interface"
+	    echo "  -oldtcltk                      use old Tcl/Tk based graphical user interface"
+            echo "  -wxpython                      use wxPython based graphical user interface"
+            echo "                                   and set as default"
             echo
             echo "Parameters:"
             echo "  GISDBASE                       initial database (path to GIS data)"
@@ -93,7 +95,7 @@
             echo "  GISDBASE/LOCATION_NAME/MAPSET  fully qualified initial mapset directory"
             echo
             echo "Environment variables relevant for startup:"
-            echo "  GRASS_GUI                      select GUI (text, gis.m, d.m, wx)"
+            echo "  GRASS_GUI                      select GUI (text, gui, tcltk, oldtcltk, wxpython)"
             echo "  GRASS_TCLSH                    set tclsh shell name to override 'tclsh'"
             echo "  GRASS_WISH                     set wish shell name to override 'wish'"
             echo "  GRASS_HTML_BROWSER             set html web browser for help pages"
@@ -116,17 +118,21 @@
 	    shift
-	# Check if the -oldgui flag was given
-	-oldgui)
-	    GRASS_GUI="d.m"
+	# Check if the -oldtcltk flag was given
+	-oldtcltk)
+	    GRASS_GUI="oldtcltk"
 	    shift
-	# Check if the -wx flag was given
-	-wx)
-	    GRASS_GUI="wx"
+	# Check if the -wxpython flag was given
+	-wxpython)
+	    GRASS_GUI="wxpython"
 	    shift
+	    GRASS_GUI="text"
+	    shift
     esac
 done
@@ -385,12 +391,13 @@
 if [ "$DISPLAY" -o "$MINGW" ] ; then
     # Check if python is working properly
-    if [ "$GRASS_GUI" = "wx" ]; then
+    if [ "$GRASS_GUI" = "wxpython" ]; then
         echo 'variable=True' | "$GRASS_PYTHON" >/dev/null 2>&1
     fi
     # Check if we need to find wish
     if [ "$GRASS_GUI" = "tcltk" ] || \
         [ "$GRASS_GUI" = "gis.m" ] || \
+	[ "$GRASS_GUI" = "oldtcltk" ] || \
         [ "$GRASS_GUI" = "d.m" ] ; then
 	# Check if wish is working properly
@@ -402,7 +409,7 @@
         # Set the tcltkgrass base directory
         TCLTKGRASSBASE="$ETC"
         # Set the wxpython base directory
-        WXPYTHONGRASSBASE="$ETC/wx"
+        WXPYTHONGRASSBASE="$ETC/wxpython"
     else
         # Wish was not found - switch to text interface mode
@@ -560,18 +567,17 @@
 	# Check for tcltk interface
-	tcltk | gis.m | d.m | wx)
+	tcltk | gis.m | oldtcltk | d.m | wxpython)
 			# eval `foo` will return subshell return code and not app foo return code!!!
 			eval '"$GRASS_WISH" -file "$TCLTKGRASSBASE/gis_set.tcl"'
 			thetest=$?
 		else
-			#"$GRASS_PYTHON" "$WXPYTHONGRASSBASE/gis_set.py"
-			#exit
 			eval '"$GRASS_PYTHON" "$WXPYTHONGRASSBASE/gis_set.py"'
 			thetest=$?
 		fi
@@ -763,15 +769,14 @@
 		"$GISBASE/scripts/gis.m"
 	fi
-    d.m)
+    oldtcltk | d.m)
 	if [ "$osxaqua" ] ; then
 		"$GISBASE/scripts/d.m" | sh &
 	else
 	fi
-    wx)
+    wxpython)
         "$GISBASE/scripts/wxgrass" &
@@ -815,9 +820,12 @@
     tcltk | gis.m)
         echo "If required, restart the graphical user interface with: gis.m"
-    wx)
-        echo "If required, restart the graphical user interface with: wxgrass &"
+    oldtcltk | d.m)
+        echo "If required, restart the graphical user interface with: d.m"
+    wxpython)
+        echo "If required, restart the graphical user interface with: wxgrass"
         echo "Start the graphical user interface with: gis.m"
