[GRASS-SVN] r30177 - grass/trunk/raster/simwe/r.sim.water
Sat Feb 16 00:34:17 EST 2008
Author: helena
Date: 2008-02-16 00:34:16 -0500 (Sat, 16 Feb 2008)
New Revision: 30177
   grass/trunk/raster/simwe/r.sim.water/main.c
improved description, option for rain and mannings as values added, non-functioning flag -m removed
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c	2008-02-15 22:42:03 UTC (rev 30176)
+++ grass/trunk/raster/simwe/r.sim.water/main.c	2008-02-16 05:34:16 UTC (rev 30177)
@@ -1,6 +1,6 @@
- * MODULE:       r.simwe.hydro: main program for hydrologic and sediment transport
+ * MODULE:       r.sim.water: main program for hydrologic and sediment transport
  *               simulation (SIMWE)
  * AUTHOR(S):    L. Mitas,  H. Mitasova, J. Hofierka
@@ -15,7 +15,7 @@
- * r.simwe.hydro: main program for hydrologic and sediment transport
+ * r.sim.water: main program for hydrologic and sediment transport
  * Original program (2002) and various modifications:
@@ -46,15 +46,23 @@
+/* DEFINE GLOB VAR		*/
 #define NWALK	"2000000"
 #define DIFFC	"0.8"
-#define HMAX	"0.4"
+#define HMAX	"0.3"
 #define HALPHA	"4.0"
 #define	HBETA	"0.5"
-#define NITER   "1200"
-#define ITEROUT "300"
+#define NITER   "10"
+#define ITEROUT "2"
 #define DENSITY "200"
+#define RAINVAL "30"
+#define MANINVAL "0.1"
+/* INCLUDES			*/
 #include <stdio.h>
 #include <stdlib.h>
 #include <math.h>
@@ -70,6 +78,9 @@
 #include <grass/site.h>
 #include <grass/glocale.h>
+/* Specific stuff		*/
 #define MAIN
 #include <grass/waterglobs.h>
@@ -83,352 +94,379 @@
 char msg[1024];
+/* MAIN					*/
 int main ( int argc, char *argv[])
-  int i,ii,j,l;
-  int ret_val;
-  double x_orig, y_orig;
-  static int rand1 = 12345;
-  static int rand2 = 67891;
+	int i,ii,j,l;
+	int ret_val;
+	double x_orig, y_orig;
+	static int rand1 = 12345;
+	static int rand2 = 67891;
+	G_gisinit (argv[0]);
+	module = G_define_module();
+	module->keywords = _("raster");
+	module->description =
+		_("Overland flow hydrologic simulation using "
+		"path sampling method (SIMWE)");
+	if (G_get_set_window (&cellhd) == -1)
+		exit (EXIT_FAILURE);
-  G_gisinit (argv[0]);
+	conv = G_database_units_to_meters_factor();
+	mixx = conv * cellhd.west;
+	maxx = conv * cellhd.east;
+	miyy = conv * cellhd.south;
+	mayy = conv * cellhd.north;
+	stepx = cellhd.ew_res * conv;
+	stepy = cellhd.ns_res * conv;
+	/*  step = amin1(stepx,stepy);*/
+	step = (stepx + stepy) / 2.;
+	mx = cellhd.cols;
+	my = cellhd.rows;
+	x_orig = cellhd.west * conv;
+	y_orig = cellhd.south * conv;/* do we need this? */
+	xmin = 0.;
+	ymin = 0.;
+	xp0 = xmin + stepx / 2.;
+	yp0 = ymin + stepy / 2.;
+	xmax = xmin + stepx * (float) mx;
+	ymax = ymin + stepy * (float) my;
+	bxmi=2093113. * conv;
+	bymi=731331. * conv;
+	bxma=2093461. * conv;
+	byma=731529. * conv;
+	bresx=2. * conv;
+	bresy=2. * conv;
+	maxwab=100000;
+	mx2o= (int)((bxma-bxmi)/bresx);
+	my2o= (int)((byma-bymi)/bresy);
+	/* relative small box coordinates: leave 1 grid layer for overlap */
+	bxmi = bxmi - mixx + stepx;
+	bymi = bymi - miyy + stepy;
+	bxma = bxma - mixx - stepx;
+	byma = byma - miyy - stepy;
+	mx2 = mx2o - 2*((int) (stepx / bresx));
+	my2 = my2o - 2*((int) (stepy / bresy));
+	parm.elevin = G_define_option();
+	parm.elevin->key = "elevin";
+	parm.elevin->type = TYPE_STRING;
+	parm.elevin->required = YES;
+	parm.elevin->gisprompt = "old,cell,raster";
+	parm.elevin->description = _("Name of the elevation raster map, same units as N,E: [m] or [ft] ");
+	parm.elevin->guisection  = _("Input_options");
+	parm.dxin = G_define_option();
+	parm.dxin->key = "dxin";
+	parm.dxin->type = TYPE_STRING;
+	parm.dxin->required = YES;
+	parm.dxin->gisprompt = "old,cell,raster";
+	parm.dxin->description = _("Name of the x-derivatives raster map [m/m] or [ft/ft]");
+	parm.dxin->guisection  = _("Input_options");
+	parm.dyin = G_define_option();
+	parm.dyin->key = "dyin";
+	parm.dyin->type = TYPE_STRING;
+	parm.dyin->required = YES;
+	parm.dyin->gisprompt = "old,cell,raster";
+	parm.dyin->description = _("Name of the y-derivatives raster map [m/m] or [ft/ft]");
+	parm.dyin->guisection  = _("Input_options");
+	parm.rain = G_define_option();
+	parm.rain->key = "rain";
+	parm.rain->type = TYPE_STRING;
+	parm.rain->required = NO;
+	parm.rain->gisprompt = "old,cell,raster";
+	parm.rain->description = _("Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]");
+	parm.rain->guisection  = _("Input_options");
+	parm.rainval = G_define_option();
+	parm.rainval->key = "rain_val";
+	parm.rainval->type = TYPE_DOUBLE;
+	parm.rainval->answer = RAINVAL;
+	parm.rainval->required = NO;
+	parm.rainval->description = _("Rainfall excess rate unique value [mm/hr]");
+	parm.rainval->guisection  = _("Input_options");
+	parm.infil = G_define_option();
+	parm.infil->key = "infil";
+	parm.infil->type = TYPE_STRING;
+	parm.infil->required = YES;
+	parm.infil->gisprompt = "old,cell,raster";
+	parm.infil->description = _("Name of the runoff infiltration rate raster map [mm/hr]");
+	parm.infil->guisection  = _("Input_options");
+	parm.traps = G_define_option();
+	parm.traps->key = "traps";
+	parm.traps->type = TYPE_STRING;
+	parm.traps->required = NO;
+	parm.traps->gisprompt = "old,cell,raster";
+	parm.traps->description = _("Name of the flow controls raster map (permeability ratio 0-1)");
+	parm.traps->guisection  = _("Input_options");
+	parm.manin = G_define_option();
+	parm.manin->key = "manin";
+	parm.manin->type = TYPE_STRING;
+	parm.manin->required = NO;
+	parm.manin->gisprompt = "old,cell,raster";
+	parm.manin->description = _("Name of the Mannings n raster map");
+	parm.manin->guisection  = _("Input_options");
+	parm.maninval = G_define_option();
+	parm.maninval->key = "manin_val";
+	parm.maninval->type = TYPE_DOUBLE;
+	parm.maninval->answer = MANINVAL;
+	parm.maninval->required = NO;
+	parm.maninval->description = _("Mannings n unique value");
+	parm.maninval->guisection  = _("Input_options");
+	/* needs to be updated to GRASS 6 vector format !! */
+	parm.sfile = G_define_option ();
+	parm.sfile->key = "vector";
+	parm.sfile->type = TYPE_STRING;
+	parm.sfile->required = NO;
+	parm.sfile->gisprompt = "old,vector,vector";
+	parm.sfile->description = _("Name of the sampling locations vector points map");
+	parm.sfile->guisection  = _("Input_options");
+	parm.depth = G_define_option();
+	parm.depth->key = "depth";
+	parm.depth->type = TYPE_STRING;
+	parm.depth->required = NO;
+	parm.depth->gisprompt = "new,cell,raster";
+	parm.depth->description = _("Output water depth raster map [m]");
+	parm.depth->guisection  = _("Output_options");
+	parm.disch = G_define_option();
+	parm.disch->key = "disch";
+	parm.disch->type = TYPE_STRING;
+	parm.disch->required = NO;
+	parm.disch->gisprompt = "new,cell,raster";
+	parm.disch->description = _("Output water discharge raster map [m3/s]");
+	parm.disch->guisection  = _("Output_options");
+	parm.err = G_define_option();
+	parm.err->key = "err";
+	parm.err->type = TYPE_STRING;
+	parm.err->required = NO;
+	parm.err->gisprompt = "new,cell,raster";
+	parm.err->description = _("Output simulation error raster map [m]");
+	parm.err->guisection  = _("Output_options");
+	parm.outwalk = G_define_option ();
+	parm.outwalk->key = "outwalk";
+	parm.outwalk->type = TYPE_STRING;
+	parm.outwalk->required = NO;
+	parm.outwalk->gisprompt = "new,vector,vector";
+	parm.outwalk->description = _("Name of the output walkers vector points map");
+	parm.outwalk->guisection  = _("Output_options");
+	parm.nwalk = G_define_option();
+	parm.nwalk->key = "nwalk";
+	parm.nwalk->type = TYPE_INTEGER;
+	parm.nwalk->answer = NWALK;
+	parm.nwalk->required = NO;
+	parm.nwalk->description = _("Number of walkers");
+	parm.nwalk->guisection  = _("Parameters");
+	parm.niter = G_define_option();
+	parm.niter->key = "niter";
+	parm.niter->type = TYPE_INTEGER;
+	parm.niter->answer = NITER;
+	parm.niter->required = NO;
+	parm.niter->description = _("Time used for iterations [minutes]");
+	parm.niter->guisection  = _("Parameters");
+	parm.outiter = G_define_option();
+	parm.outiter->key = "outiter";
+	parm.outiter->type = TYPE_INTEGER;
+	parm.outiter->answer = ITEROUT;
+	parm.outiter->required = NO;
+	parm.outiter->description = _("Time interval for creating output maps [minutes]");
+	parm.outiter->guisection  = _("Parameters");
+	parm.density = G_define_option();
+	parm.density->key = "density";
+	parm.density->type = TYPE_INTEGER;
+	parm.density->answer = DENSITY;
+	parm.density->required = NO;
+	parm.density->description = _("Density of output walkers");
+	parm.density->guisection  = _("Parameters");
+	parm.diffc = G_define_option();
+	parm.diffc->key = "diffc";
+	parm.diffc->type = TYPE_DOUBLE;
+	parm.diffc->answer = DIFFC;
+	parm.diffc->required = NO;
+	parm.diffc->description = _("Water diffusion constant");
+	parm.diffc->guisection  = _("Parameters");
+	parm.hmax = G_define_option();
+	parm.hmax->key = "hmax";
+	parm.hmax->type = TYPE_DOUBLE;
+	parm.hmax->answer = HMAX;
+	parm.hmax->required = NO;
+	parm.hmax->description = _("Threshold water depth [m] (diffusion increases after this water depth is reached)");
+	parm.hmax->guisection  = _("Parameters");
+	parm.halpha = G_define_option();
+	parm.halpha->key = "halpha";
+	parm.halpha->type = TYPE_DOUBLE;
+	parm.halpha->answer = HALPHA;
+	parm.halpha->required = NO;
+	parm.halpha->description = _("Diffusion increase constant");
+	parm.halpha->guisection  = _("Parameters");
+	parm.hbeta = G_define_option();
+	parm.hbeta->key = "hbeta";
+	parm.hbeta->type = TYPE_DOUBLE;
+	parm.hbeta->answer = HBETA;
+	parm.hbeta->required = NO;
+	parm.hbeta->description = _("Weighting factor for water flow velocity vector");
+	parm.hbeta->guisection  = _("Parameters");
+	flag.mscale = G_define_flag ();
+	flag.mscale->key = 'm';
+	flag.mscale->description = _("Multiscale simulation");
+	flag.tserie = G_define_flag ();
+	flag.tserie->key = 't';
+	flag.tserie->description = _("Time-series output");
-  module = G_define_module();
-  module->keywords = _("raster");
-  module->description =
-	_("Overland flow hydrologic model based on duality "
-	  "particle-field concept (SIMWE)");
-  if (G_get_set_window (&cellhd) == -1)
-    exit (EXIT_FAILURE);
-  conv = G_database_units_to_meters_factor();
+	if (G_parser (argc, argv))
-  mixx = conv * cellhd.west;
-  maxx = conv * cellhd.east;
-  miyy = conv * cellhd.south;
-  mayy = conv * cellhd.north;
-  stepx = cellhd.ew_res * conv;
-  stepy = cellhd.ns_res * conv;
-/*  step = amin1(stepx,stepy);*/
-  step = (stepx + stepy) / 2.;
-  mx = cellhd.cols;
-  my = cellhd.rows;
-  x_orig = cellhd.west * conv;
-  y_orig = cellhd.south * conv;/* do we need this? */
-    xmin = 0.;
-    ymin = 0.;
-    xp0 = xmin + stepx / 2.;
-    yp0 = ymin + stepy / 2.;
-    xmax = xmin + stepx * (float) mx;
-    ymax = ymin + stepy * (float) my;
+	/* mscale=flag.mscale->answer;*/
+	ts=flag.tserie->answer;
-    bxmi=2093113. * conv;
-    bymi=731331. * conv;
-    bxma=2093461. * conv;
-    byma=731529. * conv;
-    bresx=2. * conv;
-    bresy=2. * conv;
-    maxwab=100000;
+	elevin = parm.elevin->answer;
+	dxin = parm.dxin->answer;
+	dyin = parm.dyin->answer;
+	/*  maskmap = parm.maskmap->answer;*/
+	rain = parm.rain->answer;
+	infil = parm.infil->answer;
+	traps = parm.traps->answer;
+	manin = parm.manin->answer;
+	depth = parm.depth->answer;
+	disch = parm.disch->answer;
+	err = parm.err->answer;
+	outwalk = parm.outwalk->answer;
+	sfile = parm.sfile->answer;
+	sscanf(parm.nwalk->answer, "%d", &maxwa);
+	sscanf(parm.niter->answer, "%d", &timesec);
+	sscanf(parm.outiter->answer, "%d", &iterout);
+	sscanf(parm.density->answer, "%d", &ldemo);
+	sscanf(parm.diffc->answer, "%lf", &frac);
+	sscanf(parm.hmax->answer, "%lf", &hhmax);
+	sscanf(parm.halpha->answer, "%lf", &halpha);
+	sscanf(parm.hbeta->answer, "%lf", &hbeta);
+	/*Check for Rain Unique Value Input*/
+	if(parm.rainval->answer==NULL){
+		rain_val = -999.99;
+		printf("rain_val is set to: %f\n",rain_val);
+	} else {
+		sscanf(parm.rainval->answer, "%lf", &rain_val);
+	/*Check for Manin Unique Value Input*/
+	if(parm.maninval->answer==NULL){
+		manin_val = -999.99;
+		printf("manin_val is set to: %f\n",manin_val);
+	} else {
+		sscanf(parm.maninval->answer, "%lf", &manin_val);
-    mx2o= (int)((bxma-bxmi)/bresx);
-    my2o= (int)((byma-bymi)/bresy);
+	/* Recompute timesec from user input in minutes
+	 * to real timesec in seconds */
+	timesec = timesec * 60.0;
+        iterout = iterout * 60.0;
+	if ((timesec/iterout) > 100.0)
+		G_message(_("More than 100 files are going to be created !!!!!"));
+	/* compute how big the raster is and set this to appr 2 walkers per cell */
+	rwalk = (double) maxwa;
-/* relative small box coordinates: leave 1 grid layer for overlap */
+	if (conv != 1.0)
+		G_message(_("Using metric conversion factor %f, step=%f"), conv, step);
-    bxmi = bxmi - mixx + stepx;
-    bymi = bymi - miyy + stepy;
-    bxma = bxma - mixx - stepx;
-    byma = byma - miyy - stepy;
-    mx2 = mx2o - 2*((int) (stepx / bresx));
-    my2 = my2o - 2*((int) (stepy / bresy));
+	* G_set_embedded_null_value_mode(1);
-  parm.elevin = G_define_option();
-  parm.elevin->key = "elevin";
-  parm.elevin->type = TYPE_STRING;
-  parm.elevin->required = YES;
-  parm.elevin->gisprompt = "old,cell,raster";
-  parm.elevin->description = _("Name of the elevation raster map, same units as N,E: [m] or [ft] ");
-  parm.elevin->guisection  = _("Input_options");
+	if ((depth == NULL) && (disch == NULL) && (err == NULL) && (outwalk == NULL))
+    		G_warning(_("You are not outputting any raster or vector points maps"));
+	ret_val = input_data();
+	if (ret_val != 1)
+		G_fatal_error(_("Input failed"));
-  parm.dxin = G_define_option();
-  parm.dxin->key = "dxin";
-  parm.dxin->type = TYPE_STRING;
-  parm.dxin->required = YES;
-  parm.dxin->gisprompt = "old,cell,raster";
-  parm.dxin->description = _("Name of the x-derivatives raster map [m/m] or [ft/ft]");
-  parm.dxin->guisection  = _("Input_options");
+	/* memory allocation for output grids */
-  parm.dyin = G_define_option();
-  parm.dyin->key = "dyin";
-  parm.dyin->type = TYPE_STRING;
-  parm.dyin->required = YES;
-  parm.dyin->gisprompt = "old,cell,raster";
-  parm.dyin->description = _("Name of the y-derivatives raster map [m/m] or [ft/ft]");
-  parm.dyin->guisection  = _("Input_options");
+	gama = (double **)G_malloc (sizeof(double *)*(my));
+		for(l=0;l<my;l++)
+			gama[l]   = (double*)G_malloc (sizeof(double)*(mx));
+		for (j = 0; j < my; j++)
+			for (i = 0; i < mx; i++)
+				gama[j][i] = 0.;
-  parm.rain = G_define_option();
-  parm.rain->key = "rain";
-  parm.rain->type = TYPE_STRING;
-  parm.rain->required = YES;
-  parm.rain->gisprompt = "old,cell,raster";
-  parm.rain->description = _("Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]");
-  parm.rain->guisection  = _("Input_options");
+	if (err != NULL)
+		gammas = (double **)G_malloc (sizeof(double *)*(my));
+		for(l=0;l<my;l++)
+			gammas[l]   = (double*)G_malloc (sizeof(double)*(mx));
+				gammas[j][i] = 0.;
-  parm.infil = G_define_option();
-  parm.infil->key = "infil";
-  parm.infil->type = TYPE_STRING;
-  parm.infil->required = YES;
-  parm.infil->gisprompt = "old,cell,raster";
-  parm.infil->description = _("Name of the runoff infiltration rate raster map [mm/hr]");
-  parm.infil->guisection  = _("Input_options");
+	dif = (float **)G_malloc (sizeof(float *)*(my));
+	for(l=0;l<my;l++)
+		dif[l]   = (float*)G_malloc (sizeof(float)*(mx));
+			dif[j][i] = 0.;
+	/*  if (maskmap != NULL)
+	bitmask = BM_create (cols, rows);
+	IL_create_bitmask (&params, bitmask);
+	seeds(rand1,rand2);
+	grad_check();
+	main_loop();
-  parm.traps = G_define_option();
-  parm.traps->key = "traps";
-  parm.traps->type = TYPE_STRING;
-  parm.traps->required = NO;
-  parm.traps->gisprompt = "old,cell,raster";
-  parm.traps->description = _("Name of the flow controls raster map (permeability ratio 0-1)");
-  parm.traps->guisection  = _("Input_options");
+	if (ts == 0) {
+		ii=output_data (0,1.);
+		if (ii != 1)
+			G_fatal_error(_("Cannot write raster maps"));
-  parm.manin = G_define_option();
-  parm.manin->key = "manin";
-  parm.manin->type = TYPE_STRING;
-  parm.manin->required = YES;
-  parm.manin->gisprompt = "old,cell,raster";
-  parm.manin->description = _("Name of the Mannings n raster map");
-  parm.manin->guisection  = _("Input_options");
+	if (fdwalkers != NULL)
+		fclose (fdwalkers);
-/* needs to be updated to GRASS 6 vector format !! */
-  parm.sfile = G_define_option ();
-  parm.sfile->key = "vector";
-  parm.sfile->type = TYPE_STRING;
-  parm.sfile->required = NO;
-  parm.sfile->gisprompt = "old,vector,vector";
-  parm.sfile->description = _("Name of the vector points map with x,y locations");
-  parm.sfile->guisection  = _("Input_options");
-  parm.depth = G_define_option();
-  parm.depth->key = "depth";
-  parm.depth->type = TYPE_STRING;
-  parm.depth->required = NO;
-  parm.depth->gisprompt = "new,cell,raster";
-  parm.depth->description = _("Output water depth raster map");
-  parm.depth->guisection  = _("Output_options");
-  parm.disch = G_define_option();
-  parm.disch->key = "disch";
-  parm.disch->type = TYPE_STRING;
-  parm.disch->required = NO;
-  parm.disch->gisprompt = "new,cell,raster";
-  parm.disch->description = _("Output water discharge raster map");
-  parm.disch->guisection  = _("Output_options");
-  parm.err = G_define_option();
-  parm.err->key = "err";
-  parm.err->type = TYPE_STRING;
-  parm.err->required = NO;
-  parm.err->gisprompt = "new,cell,raster";
-  parm.err->description = _("Output simulation error raster map");
-  parm.err->guisection  = _("Output_options");
-  parm.outwalk = G_define_option ();
-  parm.outwalk->key = "outwalk";
-  parm.outwalk->type = TYPE_STRING;
-  parm.outwalk->required = NO;
-  parm.outwalk->gisprompt = "new,vector,vector";
-  parm.outwalk->description = _("Name of the output walkers vector points map");
-  parm.outwalk->guisection  = _("Output_options");
-  parm.nwalk = G_define_option();
-  parm.nwalk->key = "nwalk";
-  parm.nwalk->type = TYPE_INTEGER;
-  parm.nwalk->answer = NWALK;
-  parm.nwalk->required = NO;
-  parm.nwalk->description = _("Number of walkers");
-  parm.nwalk->guisection  = _("Parameters");
-  parm.niter = G_define_option();
-  parm.niter->key = "niter";
-  parm.niter->type = TYPE_INTEGER;
-  parm.niter->answer = NITER;
-  parm.niter->required = NO;
-  parm.niter->description = _("Number of time iterations (sec.)");
-  parm.niter->guisection  = _("Parameters");
-  parm.outiter = G_define_option();
-  parm.outiter->key = "outiter";
-  parm.outiter->type = TYPE_INTEGER;
-  parm.outiter->answer = ITEROUT;
-  parm.outiter->required = NO;
-  parm.outiter->description = _("Time step for saving output maps (sec.)");
-  parm.outiter->guisection  = _("Parameters");
-  parm.density = G_define_option();
-  parm.density->key = "density";
-  parm.density->type = TYPE_INTEGER;
-  parm.density->answer = DENSITY;
-  parm.density->required = NO;
-  parm.density->description = _("Density of output walkers");
-  parm.density->guisection  = _("Parameters");
-  parm.diffc = G_define_option();
-  parm.diffc->key = "diffc";
-  parm.diffc->type = TYPE_DOUBLE;
-  parm.diffc->answer = DIFFC;
-  parm.diffc->required = NO;
-  parm.diffc->description = _("Water diffusion constant");
-  parm.diffc->guisection  = _("Parameters");
-  parm.hmax = G_define_option();
-  parm.hmax->key = "hmax";
-  parm.hmax->type = TYPE_DOUBLE;
-  parm.hmax->answer = HMAX;
-  parm.hmax->required = NO;
-  parm.hmax->description = _("Threshold water depth (diffusion increases after this water depth is reached)");
-  parm.hmax->guisection  = _("Parameters");
-  parm.halpha = G_define_option();
-  parm.halpha->key = "halpha";
-  parm.halpha->type = TYPE_DOUBLE;
-  parm.halpha->answer = HALPHA;
-  parm.halpha->required = NO;
-  parm.halpha->description = _("Diffusion increase constant");
-  parm.halpha->guisection  = _("Parameters");
-  parm.hbeta = G_define_option();
-  parm.hbeta->key = "hbeta";
-  parm.hbeta->type = TYPE_DOUBLE;
-  parm.hbeta->answer = HBETA;
-  parm.hbeta->required = NO;
-  parm.hbeta->description = _("Weighting factor for water flow velocity vector");
-  parm.hbeta->guisection  = _("Parameters");
-  flag.mscale = G_define_flag ();
-  flag.mscale->key = 'm';
-  flag.mscale->description = _("Multiscale simulation");
-  flag.tserie = G_define_flag ();
-  flag.tserie->key = 't';
-  flag.tserie->description = _("Time-series (dynamic) output");
-  if (G_parser (argc, argv))
-  mscale=flag.mscale->answer;
-  ts=flag.tserie->answer;
-  elevin = parm.elevin->answer;
-  dxin = parm.dxin->answer;
-  dyin = parm.dyin->answer;
-/*  maskmap = parm.maskmap->answer;*/
-  rain = parm.rain->answer;
-  infil = parm.infil->answer;
-  traps = parm.traps->answer;
-  manin = parm.manin->answer;
-  depth = parm.depth->answer;
-  disch = parm.disch->answer;
-  err = parm.err->answer;
-  outwalk = parm.outwalk->answer;
-  sfile = parm.sfile->answer;
-  sscanf(parm.nwalk->answer, "%d", &maxwa);
-  sscanf(parm.niter->answer, "%d", &timesec);
-  sscanf(parm.outiter->answer, "%d", &iterout);
-  sscanf(parm.density->answer, "%d", &ldemo);
-  sscanf(parm.diffc->answer, "%lf", &frac);
-  sscanf(parm.hmax->answer, "%lf", &hhmax);
-  sscanf(parm.halpha->answer, "%lf", &halpha);
-  sscanf(parm.hbeta->answer, "%lf", &hbeta);
-  /* compute how big the raster is and set this to appr 2 walkers per cell */
-    rwalk = (double) maxwa;
-  if (conv != 1.0)
-    G_message(_("Using metric conversion factor %f, step=%f"), conv, step);
-   * G_set_embedded_null_value_mode(1);
-  if ((depth == NULL) && (disch == NULL) && (err == NULL) && (outwalk == NULL))
-    G_warning(_("You are not outputting any raster or vector points maps"));
-  ret_val = input_data();
-  if (ret_val != 1)
-    G_fatal_error(_("Input failed"));
-/* memory allocation for output grids */
-        gama = (double **)G_malloc (sizeof(double *)*(my));
-           for(l=0;l<my;l++)
-                gama[l]   = (double*)G_malloc (sizeof(double)*(mx));
-           for (j = 0; j < my; j++)
-                for (i = 0; i < mx; i++)
-                   gama[j][i] = 0.;
-   if (err != NULL)
-        gammas = (double **)G_malloc (sizeof(double *)*(my));
-           for(l=0;l<my;l++)
-                gammas[l]   = (double*)G_malloc (sizeof(double)*(mx));
-                   gammas[j][i] = 0.;
-        dif = (float **)G_malloc (sizeof(float *)*(my));
-           for(l=0;l<my;l++)
-                dif[l]   = (float*)G_malloc (sizeof(float)*(mx));
-                   dif[j][i] = 0.;
-/*  if (maskmap != NULL)
-    bitmask = BM_create (cols, rows);
-  IL_create_bitmask (&params, bitmask);
-  seeds(rand1,rand2);
-  grad_check();
-/*  fprintf (stdout, "\n Percent complete: ");*/
-  main_loop();
-  if (ts == 0) {
-  ii=output_data (0,1.);
-  if (ii != 1)
-    G_fatal_error(_("Cannot write raster maps"));
-  if (fdwalkers != NULL)
-    fclose (fdwalkers);
-  if (sfile != NULL)
-    fclose(fw);
-  exit (EXIT_SUCCESS);
+	if (sfile != NULL)
+		fclose(fw);
+	/* Exit with Success */
+	exit (EXIT_SUCCESS);
