[GRASS-SVN] r30226 - in grass-addons/v.strahler: . images
    svn_grass at osgeo.org
    Mon Feb 18 05:03:04 EST 2008
Author: florian
Date: 2008-02-18 05:03:04 -0500 (Mon, 18 Feb 2008)
New Revision: 30226
Added:
   grass-addons/v.strahler/images/
   grass-addons/v.strahler/images/Qgis.jpg
   grass-addons/v.strahler/images/example_input.jpg
   grass-addons/v.strahler/images/example_out2.jpg
   grass-addons/v.strahler/images/example_output.jpg
   grass-addons/v.strahler/images/example_shell.jpg
   grass-addons/v.strahler/r.broscoe.sh
   grass-addons/v.strahler/r.strahler.sh
Added additional work by Annalisa Minelli and Ivan Marchesini
Added: grass-addons/v.strahler/images/Qgis.jpg
(Binary files differ)
Property changes on: grass-addons/v.strahler/images/Qgis.jpg
___________________________________________________________________
   + application/octet-stream
Added: grass-addons/v.strahler/images/example_input.jpg
Property changes on: grass-addons/v.strahler/images/example_input.jpg
Added: grass-addons/v.strahler/images/example_out2.jpg
Property changes on: grass-addons/v.strahler/images/example_out2.jpg
Added: grass-addons/v.strahler/images/example_output.jpg
Property changes on: grass-addons/v.strahler/images/example_output.jpg
Added: grass-addons/v.strahler/images/example_shell.jpg
Property changes on: grass-addons/v.strahler/images/example_shell.jpg
Added: grass-addons/v.strahler/r.broscoe.sh
--- grass-addons/v.strahler/r.broscoe.sh	                        (rev 0)
+++ grass-addons/v.strahler/r.broscoe.sh	2008-02-18 10:03:04 UTC (rev 30226)
@@ -0,0 +1,301 @@
+#!/bin/sh
+# MODULE:	r.broscoe
+# AUTHOR(S):	Annalisa Minelli, Ivan Marchesini
+# PURPOSE:	Calculates waerden test and t test statistics
+#		for some values of threshold, on a single basin
+#		according to A. J. Broscoe theory (1959)
+# COPYRIGHT:	(C) 2008 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+# REQUIREMENTS: you need R installed with "agricolae" package
+#	You can install the package by starting R as root and typing
+#	install.packages("agricolae")
+#	This will install the package from a CRAN mirror on the internet.
+#	For more information on R see the documentation available at
+#	http://www.r-project.org/
+# TODO: solve stability problems for low area threshold (cf. v.strahler)
+#%Module
+#%  description: Calculates waerden test and t test statistics for some values of threshold, on a single basin according to A. J. Broscoe theory (1959)
+#%  keywords: waerden.test,t.test,mean stream drop
+#%End
+#%option
+#% key: dem
+#% type: string
+#% key_desc: dem
+#% gisprompt: old,cell,raster
+#% description: Name of DEM raster map
+#% required : yes
+#%END
+#%option
+#% key: thresholds
+#% type: integer
+#% description: Threshold values to calculate statistics on (separated by <space>)
+#% required : yes
+#%end
+#%option
+#% key: xcoor
+#% type: double
+#% description: x coord of outlet
+#% required : yes
+#%end
+#%option
+#% key: ycoor
+#% type: double
+#% description: y coord of outlet
+#% required : yes
+#%end
+#%option
+#% key: lt
+#% type: integer
+#% description: Lesser than (in meters), the program doesn't consider stream drops lesser than this
+#% required : yes
+#%END
+#%option
+#% key: result
+#% type: string
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% description: Resultant text file to write statistics into
+#% required: yes
+#%end
+if  [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." >&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+dem=$GIS_OPT_DEM
+thresholds=$GIS_OPT_THRESHOLDS
+xcoor=$GIS_OPT_XCOOR
+ycoor=$GIS_OPT_YCOOR
+lt=$GIS_OPT_LT
+result=$GIS_OPT_RESULT
+### setup enviro vars ###
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+echo $LOCATION_NAME
+#g.region rast=$dem
+res=`g.region -p | grep res | sed 1d | cut -f2 -d':' | tr -d ' ' `
+#g.region vect=$input
+#g.region n=n+$res s=s-$res e=e+$res w=w-$res
+for j in $thresholds
+do
+g.remove vect=ordered_$j
+rm orderedtxt_$j
+echo "initializing statistics for threshold value=$j"
+r.strahler dem=$dem xcoor=$xcoor ycoor=$ycoor thr=$j output=ordered_$j textoutput=orderedtxt_$j --overwrite
+rm one
+rm two
+rm three
+rm maxord
+`cat orderedtxt_$j | sed 2d |sed 1d > one
+sort -r -k 4,4 one > two
+head -1 two > three
+awk 'NR==1{print $4}' three > "maxord"`
+maxord=`cat maxord`
+rm thrVSmaxord_$j
+echo "$j	$maxord" > thrVSmaxord_$j
+   a=1
+   until [ "$a" -gt "$maxord" ]
+   do
+      g.remove vect=ord1,ord1_pl,ord1_pl_3d
+      g.remove vect=ord1_pl_3d_cat
+      rm tmp
+      rm ordcol
+      rm textout
+      v.extract input=ordered_$j output=ord1 type=line layer=1 new=-1 list=$a
+      v.build.polylines input=ord1 output=ord1_pl cats=no
+      v.drape input=ord1_pl type=line rast=$dem method=nearest output=ord1_pl_3d
+      v.category input=ord1_pl_3d output=ord1_pl_3d_cat type=line option=add cat=1 layer=1 step=1
+      v.db.addtable map=ord1_pl_3d_cat table=ord1_pl_3d_cat layer=1 'columns=cat integer, sx double, sy double, sz double, ex double, ey double, ez double'
+      v.to.db map=ord1_pl_3d_cat type=line layer=1 qlayer=1 option=start units=meters 'column=sx, sy, sz'
+      v.to.db map=ord1_pl_3d_cat type=line layer=1 qlayer=1 option=end units=meters 'column=ex, ey, ez'
+      v.rast.stats vector=ord1_pl_3d_cat raster=$dem colprefix=stats percentile=90 --verbose -c
+     for i in `db.select table=ord1_pl_3d_cat database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ driver=dbf 'sql=select cat from ord1_pl_3d_cat' | sed 1d`
+     do
+         min=`echo "select stats_min from ord1_pl_3d_cat where cat=$i" | db.select | sed 1d`
+         sz=`echo "select sz from ord1_pl_3d_cat where cat=$i" | db.select | sed 1d`
+         ez=`echo "select ez from ord1_pl_3d_cat where cat=$i" | db.select | sed 1d`
+	 if [  `echo "$ez - $min" | bc -l | cut -f1 -d'.'` -lt "$lt" ] || [ `echo "$sz - $min" | bc -l | cut -f1 -d'.'` -lt "$lt" ]
+	   then
+ 	   if [ "$ez" -gt "$sz" ]
+		then
+		echo "$ez - $min" | bc -l | cut -f1 -d'.' >> tmp
+		echo $a >> ordcol
+	   else
+		echo "$sz - $min" | bc -l | cut -f1 -d'.' >> tmp
+		echo $a >> ordcol
+	   fi
+	 else
+	   echo $a >> ordcol
+	   echo $a >> ordcol
+	 fi
+      done
+   paste ordcol tmp > textout\_$a
+   #read
+   if [ "$a" -gt 1 ]
+     then
+     b=`echo "$a-1" | bc -l`
+     cat textout\_$b textout\_$a > textout_temp
+     rm textout\_$a textout\_$b
+     mv textout_temp textout\_$a
+   fi
+   a=$(($a+1))
+   done
+   mv textout\_$maxord textout
+   echo "plotting textout..."
+   cat textout
+   echo "
+   imported=read.csv('textout', sep = '\t', dec='.', header = F)
+   dframe=data.frame(imported)
+   str(dframe)
+   nrow_maxord=nrow(dframe[dframe\$V1==max(dframe\$V1),])
+   maxord=max(dframe\$V1)
+   ifelse(nrow_maxord==1, (dframe=na.omit(subset(dframe[dframe\$V1 < maxord,]))), (dframe))
+   cat('plotted dframe \n')
+   nord=c(1:max(dframe\$V1))
+   #search for negative values of drop, replacing them with 0.1 values
+   dframe\$V2[(dframe\$V2 < 0)]<-0.1
+   tmp<-dframe
+   #search for zero values of drop, replacing them with 0.1 values
+   tmp\$V2[dframe\$V2==0]<-0.1
+   dframe<-tmp
+   delta=c()
+   for(i in nord)
+	offset=(qt(0.025,nrow(dframe[dframe\$V1==i,])-1,lower.tail=FALSE)*(sd(log(dframe\$V2[dframe\$V1==i])))/sqrt(nrow(dframe[dframe\$V1==i,])))/(mean	(log(dframe\$V2[dframe\$V1==i])))
+	delta=c(delta,offset)
+   delta=delta[delta<0.5]
+   delta<-data.frame(na.omit(delta))
+   dframe<-data.frame(na.omit(dframe[dframe\$V1 <= (nrow(delta)),]))
+   print(dframe)
+   cat('plotted input dataframe \n')
+   linear_regr=summary(lm(dframe\$V2~dframe\$V1))
+   print(linear_regr)
+   cat('plotted linear regression output \n')
+   t=linear_regr\$coefficients[2,3]
+   Pr=linear_regr\$coefficients[2,4]
+   Radj=linear_regr\$adj.r.squared
+   library(agricolae)
+   wer_t=waerden.test(dframe\$V2,dframe\$V1,group=F)
+   print(wer_t)
+   cat('plotted Van der Waerden test output \n')
+   sink(file=\"tmpfile\")
+   waerden.test(dframe\$V2,dframe\$V1,group=F)
+   sink()
+   Pval=try(system(\"cat tmpfile | grep Pvalue | cut -f2 -d' '\", intern=TRUE))
+   system(\"rm tmpfile\")
+   Pval<-as.numeric(Pval)
+   out_row<-as.numeric(c(\"$j\",t,Pr,Radj,Pval))
+   cat('plotting values: threshold, t, Pr, Radj, Pval \n')
+   print(out_row)
+   write(out_row,file='results\_$j',ncolumns=5,sep='\t')
+   " > R_temp
+   echo 'source ("R_temp")' | R --vanilla --slave
+   rm R_temp
+done
+rm $result
+rm thrVSmaxord
+echo "threshold	t	Pr	Radj	Pvalue">$result
+echo "threshold	maxord">thrVSmaxord
+for k in $thresholds
+do
+   cat results_$k >> $result
+   rm results_$k
+   cat thrVSmaxord_$k >> thrVSmaxord
+   rm thrVSmaxord_$k
+done
+echo "plotting results..."
+cat $result
+echo "
+thrVSmaxord=read.csv(\"thrVSmaxord\", sep = '\t', dec='.', header = F)
+names(thrVSmaxord)[1]=\"Threshold\"
+names(thrVSmaxord)[2]=\"Maxord\"
+xgraph=read.csv(\"$result\", sep = '\t', dec='.', header = F)
+names(xgraph)[1]=\"Threshold\"
+names(xgraph)[2]=\"t_statistic\"
+names(xgraph)[3]=\"Pr\"
+names(xgraph)[4]=\"R_squared_adj\"
+names(xgraph)[5]=\"Pvalue\"
+pdf('waerden_test.pdf')
+print(matplot(xgraph\$Threshold, xgraph[, c(\"Pvalue\")], type=\"l\", col=\"red\", lwd=3, lty=1, ylab=\"Pvalue\", pch=1))
+dev.off()
+pdf('linear_regression.pdf')
+print(matplot(xgraph\$Threshold, xgraph[, c(\"Pr\")], type=\"l\", col=\"green\", lwd=3, lty=1, ylab=\"Pr\", pch=1))
+dev.off()
+pdf('all_tests.pdf')
+print(matplot(xgraph\$Threshold, xgraph[, c(\"Pr\",\"Pvalue\")], type=\"b\", lwd=3, lty=1, ylab=\"(1)Pr, (2)Pvalue\"))
+dev.off()
+pdf('thrVSmaxord.pdf')
+print(matplot(thrVSmaxord\$Threshold, thrVSmaxord[, c(\"Maxord\")], type=\"l\", col=\"blue\", lwd=3, lty=1, ylab=\"Maxord\", pch=1))
+dev.off()
+" > R_temp
+echo 'source ("R_temp")' | R --vanilla --slave
+rm R_temp
Modified: grass-addons/v.strahler/r.strahler.sh
--- grass-addons/v.strahler/r.strahler.sh	2008-02-18 07:54:48 UTC (rev 30225)
+++ grass-addons/v.strahler/r.strahler.sh	2008-02-18 10:03:04 UTC (rev 30226)
@@ -20,9 +20,13 @@
 #%Module
-#%  description: Create a vector map of strahler ordered streems of a single basin starting from a DEM
-#%  keywords: strahler, streems, vector
+#%  description: Create a vector map of strahler ordered streams of a single basin starting from a DEM
+#%  keywords: strahler, streams, vector
 #%End
+#%flag
+#%  key: i
+#%  description: find interactively the outlet coords
+#%END
 #%option
 #% key: dem
 #% type: string
@@ -32,6 +36,18 @@
 #% required : yes
 #%END
 #%option
+#% key: xcoor
+#% type: double
+#% required : no
+#%end
+#%option
+#% key: ycoor
+#% type: double
+#% required : no
+#%end
+#%option
 #% key: thr
 #% type: integer
 #% description: minimum size of exterior watershed basin
@@ -41,7 +57,7 @@
 #% key: output
 #% type: string
 #% gisprompt: new,vector,vector
-#% description: Name of streems ordered map created
+#% description: Name of streams ordered map created
 #% required : yes
 #%end
 #%option
@@ -71,11 +87,27 @@
 fi
 dem=$GIS_OPT_DEM
 thr=$GIS_OPT_THR
 output=$GIS_OPT_OUTPUT
 textoutput=$GIS_OPT_TEXTOUTPUT
 bkgrmap=$GIS_OPT_BKGRMAP
+#check presence of x and y coordinates if you want to use the un-interactive mode
+if [ $GIS_FLAG_I -eq 0 ] && [ -z $xcoor ] && [ -z $ycoor ]; then
+echo "
+If you don't want to use the interactive-mode you must select the outlets' coodinates
+exit 0
+fi
 #check presence of raster MASK, put it aside
 MASKFOUND=0
 eval `g.findfile element=cell file=MASK`
@@ -95,49 +127,64 @@
 #get resolution of DEM
 res=`g.region -p | grep nsres | cut -f2 -d':' | tr -d ' '`
-#find raster streems and plot them
+#find raster streams and plot them
 r.watershed elevation=$dem threshold=$thr stream=rnetwork drainage=drainage --overwrite
 r.null map=rnetwork setnull=0
 r.thin input=rnetwork output=rnetwork_th iterations=200 --overwrite
 r.mapcalc "rnetwork_thin=rnetwork_th/rnetwork_th"
 d.erase
+if [ "$bkgrmap" ]; then
 d.rast map=$bkgrmap
+fi
 d.rast -o map=rnetwork_thin
-#ask the user for zooming and choosing the outlet cell
-echo "
+#use the interactive mode
+if [ $GIS_FLAG_I -eq 1 ] ; then
+	#ask the user for zooming and choosing the outlet cell
+	echo "
-Now, please zoom to the area where you want to put the outlet cross section
+	Now, please zoom to the area where you want to put the outlet cross section
-d.zoom
-echo "
+	d.zoom
+	echo "
-Now, please click on the cell representing the cross section
+	Now, please click on the cell representing the cross section
-#prevent from choosing a wrong cell outside from the streems
-cat=2
-while [ "$cat" != "1" ]
-do
-result=`d.what.rast -t -1 rnetwork_thin`
-coor=`echo $result | cut -f1 -d ' '`
-x=`echo $coor | cut -f1 -d':'`
-y=`echo $coor | cut -f2 -d':'`
-cat=`echo $result | cut -f3 -d ' ' | tr -d :`
-done
-#come back to the previous zoom
-d.zoom -r
+	#prevent from choosing a wrong cell outside from the streams
+	cat=2
+	while [ "$cat" != "1" ]
+	do
+	result=`d.what.rast -t -1 rnetwork_thin`
+	coor=`echo $result | cut -f1 -d ' '`
+	x=`echo $coor | cut -f1 -d':'`
+	y=`echo $coor | cut -f2 -d':'`
+	cat=`echo $result | cut -f3 -d ' ' | tr -d :`
+	done
+	#come back to the previous zoom
+	d.zoom -r
+#do not use the interactive mode
+else
+	x=$xcoor
+	y=$ycoor
+fi
 #find the basin and set the mask
 r.water.outlet drainage=drainage basin=basin easting=$x northing=$y
 d.rast basin
@@ -165,7 +212,7 @@
 v.build.polylines input=vnetwork_dangle output=vnetwork_poly cats=first --overwrite
 d.vect vnetwork_poly
-#enlarge region to ensure v.strahler get raster values at streems ends and use v.strahler
+#enlarge region to ensure v.strahler get raster values at streams ends and use v.strahler
 g.region -a res=$res n=n+$soglia s=s-$soglia e=e+$soglia w=w-$soglia
 v.strahler input=vnetwork_poly output=$output dem=$dem sloppy=0 layer=1 txout=$textoutput
