[GRASS-SVN] r30242 - grass/branches/releasebranch_6_3
Mon Feb 18 16:39:36 EST 2008
Author: martinl
Date: 2008-02-18 16:39:36 -0500 (Mon, 18 Feb 2008)
New Revision: 30242
   grass/branches/releasebranch_6_3/configure
wxwidgets and python checks merged from trunk, #38
Modified: grass/branches/releasebranch_6_3/configure
--- grass/branches/releasebranch_6_3/configure	2008-02-18 21:38:33 UTC (rev 30241)
+++ grass/branches/releasebranch_6_3/configure	2008-02-18 21:39:36 UTC (rev 30242)
@@ -65,8 +65,12 @@
 ac_help="$ac_help
   --with-curses           support Curses functionality (default: yes)"
 ac_help="$ac_help
-  --with-python           support PYTHON functionality (default: no)"
+  --with-python[=path/python-config] enable Python support (python-config with path, \
+e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
 ac_help="$ac_help
+  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
+e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
+ac_help="$ac_help
   --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
 e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
@@ -715,7 +719,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:719: checking host system type" >&5
+echo "configure:723: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -738,7 +742,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:742: checking for $ac_word" >&5
+echo "configure:746: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -765,7 +769,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:769: checking for $ac_word" >&5
+echo "configure:773: checking for $ac_word" >&5
@@ -813,7 +817,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:817: checking for $ac_word" >&5
+echo "configure:821: checking for $ac_word" >&5
@@ -842,7 +846,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:846: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:850: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -853,12 +857,12 @@
 cat > conftest.$ac_ext << EOF
-#line 857 "configure"
+#line 861 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -884,19 +888,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:888: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:892: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:893: checking whether we are using GNU C" >&5
+echo "configure:897: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:904: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -914,7 +918,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:918: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:922: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -943,10 +947,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:947: checking for Cygwin environment" >&5
+echo "configure:951: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 950 "configure"
+#line 954 "configure"
 int main() {
@@ -957,7 +961,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:965: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -973,17 +977,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:977: checking for mingw32 environment" >&5
+echo "configure:981: checking for mingw32 environment" >&5
-#line 980 "configure"
+#line 984 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1001,7 +1005,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1005: checking for executable suffix" >&5
+echo "configure:1009: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1009,10 +1013,10 @@
   rm -f conftest*
   echo 'int main () { return 0; }' > conftest.$ac_ext
   ac_cv_exeext=
-  if { (eval echo configure:1013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
+  if { (eval echo configure:1017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
     for file in conftest.*; do
       case $file in
-      *.c | *.o | *.obj) ;;
+      *.$ac_ext | *.c | *.o | *.obj) ;;
       *) ac_cv_exeext=`echo $file | sed -e s/conftest//` ;;
       esac
     done
@@ -1034,23 +1038,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1038: checking for full floating-point support" >&5
+echo "configure:1042: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1043: checking whether "cc -mieee" works" >&5
+echo "configure:1047: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1047 "configure"
+#line 1051 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1058: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1066,7 +1070,7 @@
 else
-#line 1070 "configure"
+#line 1074 "configure"
 #include <float.h>
@@ -1080,7 +1084,7 @@
 EOF
-if { (eval echo configure:1084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1093,14 +1097,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1097: checking for full floating-point support with -mieee" >&5
+echo "configure:1101: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1104 "configure"
+#line 1108 "configure"
 #include <float.h>
@@ -1114,7 +1118,7 @@
 EOF
-if { (eval echo configure:1118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1151,7 +1155,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1155: checking for $ac_word" >&5
+echo "configure:1159: checking for $ac_word" >&5
 case "$pwd" in
@@ -1189,7 +1193,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1193: checking for source directory" >&5
+echo "configure:1197: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1200,7 +1204,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1204: checking for build directory" >&5
+echo "configure:1208: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1263,7 +1267,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1267: checking for MacOSX App" >&5
+echo "configure:1271: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1286,7 +1290,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1290: checking how to build libraries" >&5
+echo "configure:1294: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1329,7 +1333,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1333: checking for $ac_word" >&5
+echo "configure:1337: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1354,7 +1358,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1358: checking how to run the C preprocessor" >&5
+echo "configure:1362: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1367,13 +1371,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1371 "configure"
+#line 1375 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1381: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1384,13 +1388,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1388 "configure"
+#line 1392 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1401,13 +1405,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1405 "configure"
+#line 1409 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1435,7 +1439,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1439: checking if 64bit support is requested" >&5
+echo "configure:1443: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1455,7 +1459,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1459: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1463: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1479,7 +1483,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1483: checking system version (for dynamic loading)" >&5
+echo "configure:1487: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1505,13 +1509,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1509: checking for dlopen in -ldl" >&5
+echo "configure:1513: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1515 "configure"
+#line 1519 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1522,7 +1526,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1569,7 +1573,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1573: checking for $ac_word" >&5
+echo "configure:1577: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1698,13 +1702,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1702: checking for gettimeofday in -lbsd" >&5
+echo "configure:1706: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1708 "configure"
+#line 1712 "configure"
@@ -1715,7 +1719,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1756,13 +1760,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1760: checking for inet_ntoa in -lbind" >&5
+echo "configure:1764: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1766 "configure"
+#line 1770 "configure"
@@ -1773,7 +1777,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1834,13 +1838,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1838: checking for shl_load in -ldld" >&5
+echo "configure:1842: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1844 "configure"
+#line 1848 "configure"
@@ -1851,7 +1855,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1916,13 +1920,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1920: checking for shl_load in -ldld" >&5
+echo "configure:1924: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1926 "configure"
+#line 1930 "configure"
@@ -1933,7 +1937,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2055,15 +2059,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2059: checking for dld.h" >&5
+echo "configure:2063: checking for dld.h" >&5
-#line 2062 "configure"
+#line 2066 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2123,15 +2127,15 @@
 	    else
-echo "configure:2127: checking for dld.h" >&5
+echo "configure:2131: checking for dld.h" >&5
-#line 2130 "configure"
+#line 2134 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2228,9 +2232,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2232: checking for ELF" >&5
+echo "configure:2236: checking for ELF" >&5
-#line 2234 "configure"
+#line 2238 "configure"
 #ifdef __ELF__
@@ -2260,15 +2264,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2264: checking for dlfcn.h" >&5
+echo "configure:2268: checking for dlfcn.h" >&5
-#line 2267 "configure"
+#line 2271 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2292,9 +2296,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2296: checking for ELF" >&5
+echo "configure:2300: checking for ELF" >&5
-#line 2298 "configure"
+#line 2302 "configure"
 #ifdef __ELF__
@@ -2618,17 +2622,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2622: checking for ld accepts -Bexport flag" >&5
+echo "configure:2626: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2625 "configure"
+#line 2629 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2966,15 +2970,21 @@
 fi
 # Check whether --with-python or --without-python was given.
 if test "${with_python+set}" = set; then
   withval="$with_python"
 else
-  with_python=no
+  with_python="no"
 fi
+# Check whether --with-wxwidgets or --without-wxwidgets was given.
+if test "${with_wxwidgets+set}" = set; then
+  withval="$with_wxwidgets"
+else
+  with_wxwidgets="no"
+fi
 # With includes and libs options
@@ -3357,7 +3367,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3361: checking for additional include dirs" >&5
+echo "configure:3371: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3380,7 +3390,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3384: checking for additional library dirs" >&5
+echo "configure:3394: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3414,7 +3424,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3418: checking for a BSD compatible install" >&5
+echo "configure:3428: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3467,7 +3477,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3471: checking for $ac_word" >&5
+echo "configure:3481: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3498,13 +3508,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3502: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3512: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3508 "configure"
+#line 3518 "configure"
@@ -3515,7 +3525,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3540,7 +3550,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3544: checking for $ac_word" >&5
+echo "configure:3554: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3580,7 +3590,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3584: checking for $ac_word" >&5
+echo "configure:3594: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3611,7 +3621,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3615: checking for $ac_word" >&5
+echo "configure:3625: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3649,7 +3659,7 @@
-echo "configure:3653: checking for $ac_word" >&5
+echo "configure:3663: checking for $ac_word" >&5
@@ -3678,7 +3688,7 @@
-echo "configure:3682: checking for $ac_word" >&5
+echo "configure:3692: checking for $ac_word" >&5
@@ -3709,7 +3719,7 @@
-echo "configure:3713: checking for $ac_word" >&5
+echo "configure:3723: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3738,7 +3748,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3742: checking for $ac_word" >&5
+echo "configure:3752: checking for $ac_word" >&5
 case "$PERL" in
@@ -3769,10 +3779,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3773: checking for ANSI C header files" >&5
+echo "configure:3783: checking for ANSI C header files" >&5
-#line 3776 "configure"
+#line 3786 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3780,7 +3790,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3784: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3797,7 +3807,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3801 "configure"
+#line 3811 "configure"
 #include <string.h>
 EOF
@@ -3815,7 +3825,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3819 "configure"
+#line 3829 "configure"
 #include <stdlib.h>
 EOF
@@ -3836,7 +3846,7 @@
 else
-#line 3840 "configure"
+#line 3850 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3847,7 +3857,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3874,15 +3884,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3878: checking for $ac_hdr" >&5
+echo "configure:3888: checking for $ac_hdr" >&5
-#line 3881 "configure"
+#line 3891 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3911,15 +3921,15 @@
 do
-echo "configure:3915: checking for $ac_hdr" >&5
+echo "configure:3925: checking for $ac_hdr" >&5
-#line 3918 "configure"
+#line 3928 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3933: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3948,15 +3958,15 @@
 do
-echo "configure:3952: checking for $ac_hdr" >&5
+echo "configure:3962: checking for $ac_hdr" >&5
-#line 3955 "configure"
+#line 3965 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3985,15 +3995,15 @@
 do
-echo "configure:3989: checking for $ac_hdr" >&5
+echo "configure:3999: checking for $ac_hdr" >&5
-#line 3992 "configure"
+#line 4002 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4022,15 +4032,15 @@
 do
-echo "configure:4026: checking for $ac_hdr" >&5
+echo "configure:4036: checking for $ac_hdr" >&5
-#line 4029 "configure"
+#line 4039 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4056,10 +4066,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4060: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4070: checking whether time.h and sys/time.h may both be included" >&5
-#line 4063 "configure"
+#line 4073 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4068,7 +4078,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4072: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4088,10 +4098,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4092: checking for off_t" >&5
+echo "configure:4102: checking for off_t" >&5
-#line 4095 "configure"
+#line 4105 "configure"
 #if STDC_HEADERS
@@ -4118,10 +4128,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4122: checking for uid_t in sys/types.h" >&5
+echo "configure:4132: checking for uid_t in sys/types.h" >&5
-#line 4125 "configure"
+#line 4135 "configure"
 EOF
@@ -4149,10 +4159,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4153: checking return type of signal handlers" >&5
+echo "configure:4163: checking return type of signal handlers" >&5
-#line 4156 "configure"
+#line 4166 "configure"
 #include <signal.h>
@@ -4169,7 +4179,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4173: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4183: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4187,10 +4197,10 @@
-echo "configure:4191: checking for Cygwin environment" >&5
+echo "configure:4201: checking for Cygwin environment" >&5
-#line 4194 "configure"
+#line 4204 "configure"
 int main() {
@@ -4201,7 +4211,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4205: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4215: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4219,10 +4229,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4223: checking for $ac_func" >&5
+echo "configure:4233: checking for $ac_func" >&5
-#line 4226 "configure"
+#line 4236 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4245,7 +4255,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4271,10 +4281,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4275: checking for $ac_func" >&5
+echo "configure:4285: checking for $ac_func" >&5
-#line 4278 "configure"
+#line 4288 "configure"
@@ -4297,7 +4307,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4323,10 +4333,10 @@
 for ac_func in drand48
 do
-echo "configure:4327: checking for $ac_func" >&5
+echo "configure:4337: checking for $ac_func" >&5
-#line 4330 "configure"
+#line 4340 "configure"
@@ -4349,7 +4359,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4375,10 +4385,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4379: checking for $ac_func" >&5
+echo "configure:4389: checking for $ac_func" >&5
-#line 4382 "configure"
+#line 4392 "configure"
@@ -4401,7 +4411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4427,10 +4437,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4431: checking for $ac_func" >&5
+echo "configure:4441: checking for $ac_func" >&5
-#line 4434 "configure"
+#line 4444 "configure"
@@ -4453,7 +4463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4478,13 +4488,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4482: checking whether setpgrp takes no argument" >&5
+echo "configure:4492: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4488 "configure"
+#line 4498 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4504,7 +4514,7 @@
 EOF
-if { (eval echo configure:4508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4532,16 +4542,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4536: checking for long long int" >&5
+echo "configure:4546: checking for long long int" >&5
-#line 4538 "configure"
+#line 4548 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4545: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4555: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4561,7 +4571,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4565: checking for W11" >&5
+echo "configure:4575: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4589,7 +4599,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4593: checking for X" >&5
+echo "configure:4603: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4649,12 +4659,12 @@
   # First, try using that file with no special directory specified.
-#line 4653 "configure"
+#line 4663 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4658: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4723,14 +4733,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4727 "configure"
+#line 4737 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4835,17 +4845,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4839: checking whether -R must be followed by a space" >&5
+echo "configure:4849: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4842 "configure"
+#line 4852 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4861,14 +4871,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4865 "configure"
+#line 4875 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4900,13 +4910,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4904: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4914: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4910 "configure"
+#line 4920 "configure"
@@ -4917,7 +4927,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4938,13 +4948,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4942: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4952: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4948 "configure"
+#line 4958 "configure"
@@ -4955,7 +4965,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4983,10 +4993,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4987: checking for gethostbyname" >&5
+echo "configure:4997: checking for gethostbyname" >&5
-#line 4990 "configure"
+#line 5000 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5009,7 +5019,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5029,13 +5039,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5033: checking for gethostbyname in -lnsl" >&5
+echo "configure:5043: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5039 "configure"
+#line 5049 "configure"
@@ -5046,7 +5056,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5075,10 +5085,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5079: checking for connect" >&5
+echo "configure:5089: checking for connect" >&5
-#line 5082 "configure"
+#line 5092 "configure"
     which can conflict with char connect(); below.  */
@@ -5101,7 +5111,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5121,13 +5131,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5125: checking for connect in -lsocket" >&5
+echo "configure:5135: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5131 "configure"
+#line 5141 "configure"
@@ -5138,7 +5148,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5161,10 +5171,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5165: checking for remove" >&5
+echo "configure:5175: checking for remove" >&5
-#line 5168 "configure"
+#line 5178 "configure"
     which can conflict with char remove(); below.  */
@@ -5187,7 +5197,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5207,13 +5217,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5211: checking for remove in -lposix" >&5
+echo "configure:5221: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5217 "configure"
+#line 5227 "configure"
@@ -5224,7 +5234,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5247,10 +5257,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5251: checking for shmat" >&5
+echo "configure:5261: checking for shmat" >&5
-#line 5254 "configure"
+#line 5264 "configure"
     which can conflict with char shmat(); below.  */
@@ -5273,7 +5283,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5293,13 +5303,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5297: checking for shmat in -lipc" >&5
+echo "configure:5307: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5303 "configure"
+#line 5313 "configure"
@@ -5310,7 +5320,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5342,13 +5352,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5346: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5356: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5352 "configure"
+#line 5362 "configure"
@@ -5359,7 +5369,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5397,7 +5407,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5401: checking whether to use Curses" >&5
+echo "configure:5411: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5416,15 +5426,15 @@
 do
-echo "configure:5420: checking for $ac_hdr" >&5
+echo "configure:5430: checking for $ac_hdr" >&5
-#line 5423 "configure"
+#line 5433 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5455,10 +5465,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5459: checking curses.h WINDOW structure component" >&5
+echo "configure:5469: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5462 "configure"
+#line 5472 "configure"
 #include <curses.h>
@@ -5467,7 +5477,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5471: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5481: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5476,7 +5486,7 @@
 fi
 rm -f conftest*
-#line 5480 "configure"
+#line 5490 "configure"
 #include <curses.h>
@@ -5485,7 +5495,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5489: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5499: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5501,13 +5511,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5505: checking for initscr in -lncurses" >&5
+echo "configure:5515: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5511 "configure"
+#line 5521 "configure"
@@ -5518,7 +5528,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5537,13 +5547,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5541: checking for initscr in -lcurses" >&5
+echo "configure:5551: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5547 "configure"
+#line 5557 "configure"
@@ -5554,7 +5564,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5583,13 +5593,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5587: checking for keypad in -lncurses" >&5
+echo "configure:5597: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5593 "configure"
+#line 5603 "configure"
@@ -5600,7 +5610,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5622,13 +5632,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5626: checking for keypad in -lcurses" >&5
+echo "configure:5636: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5632 "configure"
+#line 5642 "configure"
@@ -5639,7 +5649,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5669,13 +5679,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5673: checking for gtty in -lcompat" >&5
+echo "configure:5683: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5679 "configure"
+#line 5689 "configure"
@@ -5686,7 +5696,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5705,13 +5715,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5709: checking for gtty in -lbsd-compat" >&5
+echo "configure:5719: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5715 "configure"
+#line 5725 "configure"
@@ -5722,7 +5732,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5741,13 +5751,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5745: checking for gtty in -lbsd" >&5
+echo "configure:5755: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5751 "configure"
+#line 5761 "configure"
@@ -5758,7 +5768,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5792,12 +5802,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5796: checking for library containing cuserid" >&5
+echo "configure:5806: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5801 "configure"
+#line 5811 "configure"
@@ -5808,7 +5818,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5819,7 +5829,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5823 "configure"
+#line 5833 "configure"
@@ -5830,7 +5840,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5856,10 +5866,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5860: checking for xdrmem_create" >&5
+echo "configure:5870: checking for xdrmem_create" >&5
-#line 5863 "configure"
+#line 5873 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5882,7 +5892,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5900,13 +5910,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5904: checking for xdrmem_create in -lsun" >&5
+echo "configure:5914: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5910 "configure"
+#line 5920 "configure"
@@ -5917,7 +5927,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5936,13 +5946,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5940: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5950: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5946 "configure"
+#line 5956 "configure"
@@ -5953,7 +5963,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5972,13 +5982,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5976: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5986: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5982 "configure"
+#line 5992 "configure"
@@ -5989,7 +5999,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6008,13 +6018,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6012: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6022: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6018 "configure"
+#line 6028 "configure"
@@ -6025,7 +6035,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6059,10 +6069,10 @@
 for ac_func in asprintf
 do
-echo "configure:6063: checking for $ac_func" >&5
+echo "configure:6073: checking for $ac_func" >&5
-#line 6066 "configure"
+#line 6076 "configure"
@@ -6085,7 +6095,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6112,10 +6122,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6116: checking for atan" >&5
+echo "configure:6126: checking for atan" >&5
-#line 6119 "configure"
+#line 6129 "configure"
     which can conflict with char atan(); below.  */
@@ -6138,7 +6148,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6156,13 +6166,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6160: checking for atan in -lm" >&5
+echo "configure:6170: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6166 "configure"
+#line 6176 "configure"
@@ -6173,7 +6183,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6200,10 +6210,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6204: checking for dlsym" >&5
+echo "configure:6214: checking for dlsym" >&5
-#line 6207 "configure"
+#line 6217 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6226,7 +6236,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6244,13 +6254,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6248: checking for dlsym in -ldl" >&5
+echo "configure:6258: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6254 "configure"
+#line 6264 "configure"
@@ -6261,7 +6271,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6288,10 +6298,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6292: checking for iconv" >&5
+echo "configure:6302: checking for iconv" >&5
-#line 6295 "configure"
+#line 6305 "configure"
     which can conflict with char iconv(); below.  */
@@ -6314,7 +6324,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6332,13 +6342,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6336: checking for iconv in -liconv" >&5
+echo "configure:6346: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6342 "configure"
+#line 6352 "configure"
@@ -6349,7 +6359,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6368,13 +6378,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6372: checking for iconv in -lgiconv" >&5
+echo "configure:6382: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6378 "configure"
+#line 6388 "configure"
@@ -6385,7 +6395,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6404,10 +6414,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6408: checking for libiconv" >&5
+echo "configure:6418: checking for libiconv" >&5
-#line 6411 "configure"
+#line 6421 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6430,7 +6440,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6448,13 +6458,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6452: checking for libiconv in -liconv" >&5
+echo "configure:6462: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6458 "configure"
+#line 6468 "configure"
@@ -6465,7 +6475,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6484,13 +6494,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6488: checking for libiconv in -lgiconv" >&5
+echo "configure:6498: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6494 "configure"
+#line 6504 "configure"
@@ -6501,7 +6511,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6538,10 +6548,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6542: checking for socket" >&5
+echo "configure:6552: checking for socket" >&5
-#line 6545 "configure"
+#line 6555 "configure"
     which can conflict with char socket(); below.  */
@@ -6564,7 +6574,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6582,13 +6592,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6586: checking for socket in -lsocket" >&5
+echo "configure:6596: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6592 "configure"
+#line 6602 "configure"
@@ -6599,7 +6609,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6647,7 +6657,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6651: checking for location of zlib includes" >&5
+echo "configure:6661: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6673,15 +6683,15 @@
 do
-echo "configure:6677: checking for $ac_hdr" >&5
+echo "configure:6687: checking for $ac_hdr" >&5
-#line 6680 "configure"
+#line 6690 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6715,7 +6725,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6719: checking for location of zlib library" >&5
+echo "configure:6729: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6740,13 +6750,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6744: checking for deflate in -lz" >&5
+echo "configure:6754: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6750 "configure"
+#line 6760 "configure"
@@ -6757,7 +6767,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6805,7 +6815,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6809: checking for location of External PROJ.4 includes" >&5
+echo "configure:6819: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6831,15 +6841,15 @@
 do
-echo "configure:6835: checking for $ac_hdr" >&5
+echo "configure:6845: checking for $ac_hdr" >&5
-#line 6838 "configure"
+#line 6848 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6876,7 +6886,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6880: checking External PROJ.4 version" >&5
+echo "configure:6890: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6884,7 +6894,7 @@
 else
-#line 6888 "configure"
+#line 6898 "configure"
 #include <stdio.h>
@@ -6896,7 +6906,7 @@
 EOF
-if { (eval echo configure:6900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6921,7 +6931,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6925: checking for location of External PROJ.4 library" >&5
+echo "configure:6935: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6946,13 +6956,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6950: checking for pj_get_def in -lproj" >&5
+echo "configure:6960: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 6956 "configure"
+#line 6966 "configure"
@@ -6963,7 +6973,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6997,7 +7007,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7001: checking for location of External PROJ.4 data files" >&5
+echo "configure:7011: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7021,14 +7031,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7025: checking for epsg" >&5
+echo "configure:7035: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7032: checking for $PROJSHARE/epsg" >&5
+echo "configure:7042: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7060,7 +7070,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7064: checking for $ac_word" >&5
+echo "configure:7074: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7100,7 +7110,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7104: checking whether to use Readline" >&5
+echo "configure:7114: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7121,7 +7131,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7125: checking for location of Readline includes" >&5
+echo "configure:7135: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7147,15 +7157,15 @@
 do
-echo "configure:7151: checking for $ac_hdr" >&5
+echo "configure:7161: checking for $ac_hdr" >&5
-#line 7154 "configure"
+#line 7164 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7169: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7191,15 +7201,15 @@
 do
-echo "configure:7195: checking for $ac_hdr" >&5
+echo "configure:7205: checking for $ac_hdr" >&5
-#line 7198 "configure"
+#line 7208 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7203: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7233,7 +7243,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7237: checking for location of Readline library" >&5
+echo "configure:7247: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7258,13 +7268,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7262: checking for readline in -lreadline" >&5
+echo "configure:7272: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7268 "configure"
+#line 7278 "configure"
@@ -7275,7 +7285,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7310,13 +7320,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7314: checking for add_history in -lhistory" >&5
+echo "configure:7324: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7320 "configure"
+#line 7330 "configure"
@@ -7327,7 +7337,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7370,7 +7380,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7374: checking whether to use JPEG" >&5
+echo "configure:7384: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7390,7 +7400,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7394: checking for location of JPEG includes" >&5
+echo "configure:7404: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7416,15 +7426,15 @@
 do
-echo "configure:7420: checking for $ac_hdr" >&5
+echo "configure:7430: checking for $ac_hdr" >&5
-#line 7423 "configure"
+#line 7433 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7458,7 +7468,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7462: checking for location of JPEG library" >&5
+echo "configure:7472: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7485,13 +7495,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7489: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7499: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7495 "configure"
+#line 7505 "configure"
@@ -7502,7 +7512,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7521,13 +7531,13 @@
-echo "configure:7525: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7535: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7531 "configure"
+#line 7541 "configure"
@@ -7538,7 +7548,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7587,11 +7597,10 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7591: checking whether to use GDAL" >&5
+echo "configure:7601: checking whether to use GDAL" >&5
 if test "`basename xx/$with_gdal`" = "gdal-config" ; then
   GDAL_CONFIG="$with_gdal"
-  echo "$ac_t""yes" 1>&6
 fi
 if test "$with_gdal" = "no" ; then
@@ -7601,7 +7610,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7605: checking for $ac_word" >&5
+echo "configure:7614: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7659,10 +7668,10 @@
   ac_save_libs="$LIBS"
   LIBS="$LIBS $GDAL_LIBS"
   echo $ac_n "checking for GDALOpen""... $ac_c" 1>&6
-echo "configure:7663: checking for GDALOpen" >&5
+echo "configure:7672: checking for GDALOpen" >&5
-#line 7666 "configure"
+#line 7675 "configure"
     which can conflict with char GDALOpen(); below.  */
@@ -7685,7 +7694,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GDALOpen=yes"
 else
@@ -7704,10 +7713,10 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-echo "configure:7708: checking for GDALOpen" >&5
+echo "configure:7717: checking for GDALOpen" >&5
-#line 7711 "configure"
+#line 7720 "configure"
@@ -7730,7 +7739,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7766,7 +7775,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7770: checking whether to use TIFF" >&5
+echo "configure:7779: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7786,7 +7795,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7790: checking for location of TIFF includes" >&5
+echo "configure:7799: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7812,15 +7821,15 @@
 do
-echo "configure:7816: checking for $ac_hdr" >&5
+echo "configure:7825: checking for $ac_hdr" >&5
-#line 7819 "configure"
+#line 7828 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7833: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7854,7 +7863,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7858: checking for location of TIFF library" >&5
+echo "configure:7867: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7885,13 +7894,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7889: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7898: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7895 "configure"
+#line 7904 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7902,7 +7911,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7921,13 +7930,13 @@
-echo "configure:7925: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7934: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7931 "configure"
+#line 7940 "configure"
@@ -7938,7 +7947,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7957,13 +7966,13 @@
-echo "configure:7961: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7970: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7967 "configure"
+#line 7976 "configure"
@@ -7974,7 +7983,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7993,13 +8002,13 @@
-echo "configure:7997: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8006: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8003 "configure"
+#line 8012 "configure"
@@ -8010,7 +8019,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8029,13 +8038,13 @@
-echo "configure:8033: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8042: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8039 "configure"
+#line 8048 "configure"
@@ -8046,7 +8055,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8065,13 +8074,13 @@
-echo "configure:8069: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8078: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8075 "configure"
+#line 8084 "configure"
@@ -8082,7 +8091,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8101,13 +8110,13 @@
-echo "configure:8105: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8114: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8111 "configure"
+#line 8120 "configure"
@@ -8118,7 +8127,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8137,13 +8146,13 @@
-echo "configure:8141: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8150: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8147 "configure"
+#line 8156 "configure"
@@ -8154,7 +8163,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8252,7 +8261,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8256: checking whether to use PNG" >&5
+echo "configure:8265: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8271,7 +8280,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8275: checking for location of PNG includes" >&5
+echo "configure:8284: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8297,15 +8306,15 @@
 do
-echo "configure:8301: checking for $ac_hdr" >&5
+echo "configure:8310: checking for $ac_hdr" >&5
-#line 8304 "configure"
+#line 8313 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8318: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8339,7 +8348,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8343: checking for location of PNG library" >&5
+echo "configure:8352: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8364,13 +8373,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8368: checking for png_read_image in -lpng" >&5
+echo "configure:8377: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8374 "configure"
+#line 8383 "configure"
@@ -8381,7 +8390,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8423,7 +8432,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8427: checking whether to use Tcl/Tk" >&5
+echo "configure:8436: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8443,7 +8452,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8447: checking for location of Tcl/Tk includes" >&5
+echo "configure:8456: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8469,15 +8478,15 @@
 do
-echo "configure:8473: checking for $ac_hdr" >&5
+echo "configure:8482: checking for $ac_hdr" >&5
-#line 8476 "configure"
+#line 8485 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8514,15 +8523,15 @@
 do
-echo "configure:8518: checking for $ac_hdr" >&5
+echo "configure:8527: checking for $ac_hdr" >&5
-#line 8521 "configure"
+#line 8530 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8535: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8556,7 +8565,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8560: checking Tcl version" >&5
+echo "configure:8569: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8564,7 +8573,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8568 "configure"
+#line 8577 "configure"
 #include <stdio.h>
@@ -8576,7 +8585,7 @@
 EOF
-if { (eval echo configure:8580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8594,7 +8603,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8598: checking Tk version" >&5
+echo "configure:8607: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8602,7 +8611,7 @@
 else
-#line 8606 "configure"
+#line 8615 "configure"
 #include <stdio.h>
@@ -8614,7 +8623,7 @@
 EOF
-if { (eval echo configure:8618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8643,7 +8652,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8647: checking for location of Tcl/Tk library" >&5
+echo "configure:8656: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8673,13 +8682,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8677: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8686: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8683 "configure"
+#line 8692 "configure"
@@ -8690,7 +8699,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8709,13 +8718,13 @@
-echo "configure:8713: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8722: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8719 "configure"
+#line 8728 "configure"
@@ -8726,7 +8735,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8753,13 +8762,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8757: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8766: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8763 "configure"
+#line 8772 "configure"
@@ -8770,7 +8779,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8789,13 +8798,13 @@
-echo "configure:8793: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8802: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8799 "configure"
+#line 8808 "configure"
@@ -8806,7 +8815,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8833,13 +8842,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8837: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8846: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8843 "configure"
+#line 8852 "configure"
@@ -8850,7 +8859,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8869,13 +8878,13 @@
-echo "configure:8873: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8882: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8879 "configure"
+#line 8888 "configure"
@@ -8886,7 +8895,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8964,13 +8973,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8968: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8977: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8974 "configure"
+#line 8983 "configure"
@@ -8981,7 +8990,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9000,13 +9009,13 @@
-echo "configure:9004: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9013: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9010 "configure"
+#line 9019 "configure"
@@ -9017,7 +9026,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9044,13 +9053,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9048: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9057: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9054 "configure"
+#line 9063 "configure"
@@ -9061,7 +9070,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9080,13 +9089,13 @@
-echo "configure:9084: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9093: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9090 "configure"
+#line 9099 "configure"
@@ -9097,7 +9106,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9124,13 +9133,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9128: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9137: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9134 "configure"
+#line 9143 "configure"
@@ -9141,7 +9150,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9160,13 +9169,13 @@
-echo "configure:9164: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9173: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9170 "configure"
+#line 9179 "configure"
@@ -9177,7 +9186,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9269,7 +9278,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9273: checking whether to use PostgreSQL" >&5
+echo "configure:9282: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9296,7 +9305,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9300: checking for location of PostgreSQL includes" >&5
+echo "configure:9309: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9322,15 +9331,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9326: checking for $ac_hdr" >&5
+echo "configure:9335: checking for $ac_hdr" >&5
-#line 9329 "configure"
+#line 9338 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9343: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9368,7 +9377,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9372: checking for location of PostgreSQL library" >&5
+echo "configure:9381: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9397,13 +9406,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9401: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9410: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9407 "configure"
+#line 9416 "configure"
@@ -9414,7 +9423,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9433,13 +9442,13 @@
-echo "configure:9437: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9446: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9443 "configure"
+#line 9452 "configure"
@@ -9450,7 +9459,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9469,13 +9478,13 @@
-echo "configure:9473: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9482: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9479 "configure"
+#line 9488 "configure"
@@ -9486,7 +9495,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9505,13 +9514,13 @@
-echo "configure:9509: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9518: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9515 "configure"
+#line 9524 "configure"
@@ -9522,7 +9531,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9579,13 +9588,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9583: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9592: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9589 "configure"
+#line 9598 "configure"
@@ -9596,7 +9605,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9618,13 +9627,13 @@
-echo "configure:9622: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9631: checking for PQcmdTuples in -lpq" >&5
-#line 9628 "configure"
+#line 9637 "configure"
@@ -9635,7 +9644,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9678,7 +9687,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9682: checking whether to use MySQL" >&5
+echo "configure:9691: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9698,7 +9707,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9702: checking for location of MySQL includes" >&5
+echo "configure:9711: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9724,15 +9733,15 @@
 do
-echo "configure:9728: checking for $ac_hdr" >&5
+echo "configure:9737: checking for $ac_hdr" >&5
-#line 9731 "configure"
+#line 9740 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9745: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9769,7 +9778,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9773: checking for location of MySQL library" >&5
+echo "configure:9782: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9800,13 +9809,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9804: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9813: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9810 "configure"
+#line 9819 "configure"
@@ -9817,7 +9826,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9836,13 +9845,13 @@
-echo "configure:9840: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9849: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9846 "configure"
+#line 9855 "configure"
@@ -9853,7 +9862,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9872,13 +9881,13 @@
-echo "configure:9876: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9885: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9882 "configure"
+#line 9891 "configure"
@@ -9889,7 +9898,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9908,13 +9917,13 @@
-echo "configure:9912: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9921: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9918 "configure"
+#line 9927 "configure"
@@ -9925,7 +9934,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9944,13 +9953,13 @@
-echo "configure:9948: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9957: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9954 "configure"
+#line 9963 "configure"
@@ -9961,7 +9970,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9980,13 +9989,13 @@
-echo "configure:9984: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9993: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9990 "configure"
+#line 9999 "configure"
@@ -9997,7 +10006,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10016,13 +10025,13 @@
-echo "configure:10020: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10029: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10026 "configure"
+#line 10035 "configure"
@@ -10033,7 +10042,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10052,13 +10061,13 @@
-echo "configure:10056: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10065: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10062 "configure"
+#line 10071 "configure"
@@ -10069,7 +10078,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10159,7 +10168,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10163: checking for $ac_word" >&5
+echo "configure:10172: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10200,10 +10209,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10204: checking for mysql_server_init" >&5
+echo "configure:10213: checking for mysql_server_init" >&5
-#line 10207 "configure"
+#line 10216 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10226,7 +10235,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10264,7 +10273,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10268: checking whether to use SQLite" >&5
+echo "configure:10277: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10284,7 +10293,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10288: checking for location of SQLite includes" >&5
+echo "configure:10297: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10310,15 +10319,15 @@
 do
-echo "configure:10314: checking for $ac_hdr" >&5
+echo "configure:10323: checking for $ac_hdr" >&5
-#line 10317 "configure"
+#line 10326 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10361,7 +10370,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10365: checking for location of SQLite library" >&5
+echo "configure:10374: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10388,13 +10397,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10392: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10401: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10398 "configure"
+#line 10407 "configure"
@@ -10405,7 +10414,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10424,13 +10433,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10428: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10437: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10434 "configure"
+#line 10443 "configure"
@@ -10441,7 +10450,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10494,7 +10503,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10498: checking whether to use FFMPEG" >&5
+echo "configure:10507: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10514,7 +10523,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10518: checking for location of FFMPEG includes" >&5
+echo "configure:10527: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10540,15 +10549,15 @@
 do
-echo "configure:10544: checking for $ac_hdr" >&5
+echo "configure:10553: checking for $ac_hdr" >&5
-#line 10547 "configure"
+#line 10556 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10561: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10584,15 +10593,15 @@
 do
-echo "configure:10588: checking for $ac_hdr" >&5
+echo "configure:10597: checking for $ac_hdr" >&5
-#line 10591 "configure"
+#line 10600 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10635,7 +10644,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10639: checking for location of FFMPEG library" >&5
+echo "configure:10648: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10662,13 +10671,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10666: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10675: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec  $LIBS"
-#line 10672 "configure"
+#line 10681 "configure"
@@ -10679,7 +10688,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10698,13 +10707,13 @@
-echo "configure:10702: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10711: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
-#line 10708 "configure"
+#line 10717 "configure"
@@ -10715,7 +10724,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10760,13 +10769,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10764: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10773: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat  $LIBS"
-#line 10770 "configure"
+#line 10779 "configure"
@@ -10777,7 +10786,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10796,13 +10805,13 @@
-echo "configure:10800: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10809: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat -lavutil $MATHLIB $LIBS"
-#line 10806 "configure"
+#line 10815 "configure"
@@ -10813,7 +10822,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10873,7 +10882,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10877: checking whether to use OpenGL" >&5
+echo "configure:10886: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10907,7 +10916,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10911: checking for location of OpenGL includes" >&5
+echo "configure:10920: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10933,15 +10942,15 @@
 do
-echo "configure:10937: checking for $ac_hdr" >&5
+echo "configure:10946: checking for $ac_hdr" >&5
-#line 10940 "configure"
+#line 10949 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10945: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10954: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10975,7 +10984,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10979: checking for location of OpenGL library" >&5
+echo "configure:10988: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11004,13 +11013,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11008: checking for glBegin in -lGL" >&5
+echo "configure:11017: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11014 "configure"
+#line 11023 "configure"
@@ -11021,7 +11030,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11040,13 +11049,13 @@
-echo "configure:11044: checking for glBegin in -lGL" >&5
+echo "configure:11053: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11050 "configure"
+#line 11059 "configure"
@@ -11057,7 +11066,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11076,13 +11085,13 @@
-echo "configure:11080: checking for glBegin in -lGL" >&5
+echo "configure:11089: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11086 "configure"
+#line 11095 "configure"
@@ -11093,7 +11102,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11112,13 +11121,13 @@
-echo "configure:11116: checking for glBegin in -lGL" >&5
+echo "configure:11125: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11122 "configure"
+#line 11131 "configure"
@@ -11129,7 +11138,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11191,13 +11200,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11195: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11204: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11201 "configure"
+#line 11210 "configure"
@@ -11208,7 +11217,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11227,13 +11236,13 @@
-echo "configure:11231: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11240: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11237 "configure"
+#line 11246 "configure"
@@ -11244,7 +11253,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11288,10 +11297,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11292: checking for glXCreatePbuffer" >&5
+echo "configure:11301: checking for glXCreatePbuffer" >&5
-#line 11295 "configure"
+#line 11304 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11314,7 +11323,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11336,10 +11345,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11340: checking for glXCreateGLXPixmap" >&5
+echo "configure:11349: checking for glXCreateGLXPixmap" >&5
-#line 11343 "configure"
+#line 11352 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11362,7 +11371,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11401,7 +11410,7 @@
-echo "configure:11405: checking for location of OpenGL includes" >&5
+echo "configure:11414: checking for location of OpenGL includes" >&5
@@ -11427,15 +11436,15 @@
 do
-echo "configure:11431: checking for $ac_hdr" >&5
+echo "configure:11440: checking for $ac_hdr" >&5
-#line 11434 "configure"
+#line 11443 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11448: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11470,10 +11479,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11474: checking for glBegin" >&5
+echo "configure:11483: checking for glBegin" >&5
-#line 11477 "configure"
+#line 11486 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11496,7 +11505,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11511,10 +11520,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11515: checking for gluBeginCurve" >&5
+echo "configure:11524: checking for gluBeginCurve" >&5
-#line 11518 "configure"
+#line 11527 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11537,7 +11546,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11583,7 +11592,7 @@
-echo "configure:11587: checking for location of OpenGL includes" >&5
+echo "configure:11596: checking for location of OpenGL includes" >&5
@@ -11609,15 +11618,15 @@
 do
-echo "configure:11613: checking for $ac_hdr" >&5
+echo "configure:11622: checking for $ac_hdr" >&5
-#line 11616 "configure"
+#line 11625 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11621: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11630: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11651,7 +11660,7 @@
-echo "configure:11655: checking for location of OpenGL library" >&5
+echo "configure:11664: checking for location of OpenGL library" >&5
@@ -11674,33 +11683,33 @@
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11678: checking for OpenGL library" >&5
+echo "configure:11687: checking for OpenGL library" >&5
 LIBS="-lopengl32"
-#line 11681 "configure"
+#line 11690 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
 OPENGLLIB=-lopengl32
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11694: checking for GLU library" >&5
+echo "configure:11703: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB"
-#line 11697 "configure"
+#line 11706 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11751,7 +11760,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11755: checking whether to use ODBC" >&5
+echo "configure:11764: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11770,7 +11779,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11774: checking for location of ODBC includes" >&5
+echo "configure:11783: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11796,15 +11805,15 @@
 do
-echo "configure:11800: checking for $ac_hdr" >&5
+echo "configure:11809: checking for $ac_hdr" >&5
-#line 11803 "configure"
+#line 11812 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11838,7 +11847,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11842: checking for location of ODBC library" >&5
+echo "configure:11851: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11863,13 +11872,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11867: checking for SQLConnect in -lodbc" >&5
+echo "configure:11876: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11873 "configure"
+#line 11882 "configure"
@@ -11880,7 +11889,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11905,13 +11914,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11909: checking for SQLConnect in -liodbc" >&5
+echo "configure:11918: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11915 "configure"
+#line 11924 "configure"
 #include "confdefs.h"
@@ -11922,7 +11931,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11971,7 +11980,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11975: checking whether to use FFTW" >&5
+echo "configure:11984: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11990,7 +11999,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11994: checking for location of FFTW includes" >&5
+echo "configure:12003: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12016,15 +12025,15 @@
 do
-echo "configure:12020: checking for $ac_hdr" >&5
+echo "configure:12029: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12023 "configure"
+#line 12032 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12052,15 +12061,15 @@
 do
-echo "configure:12056: checking for $ac_hdr" >&5
+echo "configure:12065: checking for $ac_hdr" >&5
-#line 12059 "configure"
+#line 12068 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12088,15 +12097,15 @@
 do
-echo "configure:12092: checking for $ac_hdr" >&5
+echo "configure:12101: checking for $ac_hdr" >&5
-#line 12095 "configure"
+#line 12104 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12142,7 +12151,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12146: checking for location of FFTW library" >&5
+echo "configure:12155: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12167,13 +12176,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12171: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12180: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12177 "configure"
+#line 12186 "configure"
@@ -12184,7 +12193,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12209,13 +12218,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12213: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12222: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12219 "configure"
+#line 12228 "configure"
@@ -12226,7 +12235,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12251,13 +12260,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12255: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12264: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12261 "configure"
+#line 12270 "configure"
@@ -12268,7 +12277,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12325,7 +12334,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12329: checking whether to use BLAS" >&5
+echo "configure:12338: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12346,7 +12355,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12350: checking for location of BLAS includes" >&5
+echo "configure:12359: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12366,7 +12375,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12370: checking for location of BLAS library" >&5
+echo "configure:12379: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12392,15 +12401,15 @@
 do
-echo "configure:12396: checking for $ac_hdr" >&5
+echo "configure:12405: checking for $ac_hdr" >&5
-#line 12399 "configure"
+#line 12408 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12435,13 +12444,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12439: checking for dnrm2_ in -lblas" >&5
+echo "configure:12448: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12445 "configure"
+#line 12454 "configure"
@@ -12452,7 +12461,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12471,13 +12480,13 @@
-echo "configure:12475: checking for dnrm2_ in -lblas" >&5
+echo "configure:12484: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12481 "configure"
+#line 12490 "configure"
@@ -12488,7 +12497,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12532,13 +12541,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12536: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12545: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12542 "configure"
+#line 12551 "configure"
@@ -12549,7 +12558,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12564,13 +12573,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12568: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12577: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12574 "configure"
+#line 12583 "configure"
@@ -12581,7 +12590,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12596,13 +12605,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12600: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12609: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12606 "configure"
+#line 12615 "configure"
@@ -12613,7 +12622,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12658,16 +12667,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12662: checking for sgemm in $vlib_flags" >&5
+echo "configure:12671: checking for sgemm in $vlib_flags" >&5
-#line 12664 "configure"
+#line 12673 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12685,13 +12694,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12689: checking for sgemm_ in -lblas" >&5
+echo "configure:12698: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12695 "configure"
+#line 12704 "configure"
@@ -12702,7 +12711,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12717,13 +12726,13 @@
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12721: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12730: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12727 "configure"
+#line 12736 "configure"
@@ -12734,7 +12743,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12749,13 +12758,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12753: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12762: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12759 "configure"
+#line 12768 "configure"
@@ -12766,7 +12775,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12800,13 +12809,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12804: checking for acosp in -lsunmath" >&5
+echo "configure:12813: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lsunmath  $LIBS"
-#line 12810 "configure"
+#line 12819 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12817,7 +12826,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12832,13 +12841,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12836: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12845: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12842 "configure"
+#line 12851 "configure"
@@ -12849,7 +12858,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12879,13 +12888,13 @@
 # Generic BLAS library
-echo "configure:12883: checking for sgemm_ in -lblas" >&5
+echo "configure:12892: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12889 "configure"
+#line 12898 "configure"
@@ -12896,7 +12905,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12935,7 +12944,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12939: checking whether to use LAPACK" >&5
+echo "configure:12948: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12960,7 +12969,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12964: checking for location of LAPACK includes" >&5
+echo "configure:12973: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12980,7 +12989,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12984: checking for location of LAPACK library" >&5
+echo "configure:12993: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13006,15 +13015,15 @@
 do
-echo "configure:13010: checking for $ac_hdr" >&5
+echo "configure:13019: checking for $ac_hdr" >&5
-#line 13013 "configure"
+#line 13022 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13046,10 +13055,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13050: checking for dsegv_" >&5
+echo "configure:13059: checking for dsegv_" >&5
-#line 13053 "configure"
+#line 13062 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13072,7 +13081,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13099,13 +13108,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13103: checking for desgv_ in -llapack" >&5
+echo "configure:13112: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13109 "configure"
+#line 13118 "configure"
@@ -13116,7 +13125,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13148,13 +13157,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13152: checking for dgesv_ in -llapack" >&5
+echo "configure:13161: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13158 "configure"
+#line 13167 "configure"
@@ -13165,7 +13174,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13184,13 +13193,13 @@
-echo "configure:13188: checking for dgesv_ in -llapack" >&5
+echo "configure:13197: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13194 "configure"
+#line 13203 "configure"
@@ -13201,7 +13210,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13257,7 +13266,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13261: checking whether to use Motif" >&5
+echo "configure:13270: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13276,7 +13285,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13280: checking for location of Motif includes" >&5
+echo "configure:13289: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13302,15 +13311,15 @@
 do
-echo "configure:13306: checking for $ac_hdr" >&5
+echo "configure:13315: checking for $ac_hdr" >&5
-#line 13309 "configure"
+#line 13318 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13323: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13344,7 +13353,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13348: checking for location of Motif library" >&5
+echo "configure:13357: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13369,13 +13378,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13373: checking for XmStringCreate in -lXm" >&5
+echo "configure:13382: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13379 "configure"
+#line 13388 "configure"
@@ -13386,7 +13395,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13427,7 +13436,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13431: checking whether to use GLw" >&5
+echo "configure:13440: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13446,7 +13455,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13450: checking for location of GLw includes" >&5
+echo "configure:13459: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13472,15 +13481,15 @@
 do
-echo "configure:13476: checking for $ac_hdr" >&5
+echo "configure:13485: checking for $ac_hdr" >&5
-#line 13479 "configure"
+#line 13488 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13484: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13493: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13508,15 +13517,15 @@
 do
-echo "configure:13512: checking for $ac_hdr" >&5
+echo "configure:13521: checking for $ac_hdr" >&5
-#line 13515 "configure"
+#line 13524 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13529: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13556,7 +13565,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13560: checking for location of GLw library" >&5
+echo "configure:13569: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13581,13 +13590,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13585: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13594: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13591 "configure"
+#line 13600 "configure"
@@ -13598,7 +13607,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13623,13 +13632,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13627: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13636: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13633 "configure"
+#line 13642 "configure"
@@ -13640,7 +13649,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13665,13 +13674,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13669: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13678: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13675 "configure"
+#line 13684 "configure"
@@ -13682,7 +13691,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13707,13 +13716,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13711: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13720: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13717 "configure"
+#line 13726 "configure"
@@ -13724,7 +13733,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13749,13 +13758,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13753: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13762: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13759 "configure"
+#line 13768 "configure"
@@ -13766,7 +13775,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13791,13 +13800,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13795: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13804: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13801 "configure"
+#line 13810 "configure"
@@ -13808,7 +13817,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13835,13 +13844,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:13839: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13848: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13845 "configure"
+#line 13854 "configure"
@@ -13852,7 +13861,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13871,13 +13880,13 @@
-echo "configure:13875: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13884: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13881 "configure"
+#line 13890 "configure"
@@ -13888,7 +13897,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13915,13 +13924,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:13919: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13928: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13925 "configure"
+#line 13934 "configure"
@@ -13932,7 +13941,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13951,13 +13960,13 @@
-echo "configure:13955: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13964: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13961 "configure"
+#line 13970 "configure"
@@ -13968,7 +13977,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14081,7 +14090,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14085: checking whether to use FreeType" >&5
+echo "configure:14094: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14100,7 +14109,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14104: checking for location of FreeType includes" >&5
+echo "configure:14113: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14126,15 +14135,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14130: checking for $ac_hdr" >&5
+echo "configure:14139: checking for $ac_hdr" >&5
-#line 14133 "configure"
+#line 14142 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14168,7 +14177,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14172: checking for location of FreeType library" >&5
+echo "configure:14181: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14193,13 +14202,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14197: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14206: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14203 "configure"
+#line 14212 "configure"
@@ -14210,7 +14219,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14251,7 +14260,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14255: checking whether to use NLS" >&5
+echo "configure:14264: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14271,10 +14280,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14275: checking for gettext" >&5
+echo "configure:14284: checking for gettext" >&5
-#line 14278 "configure"
+#line 14287 "configure"
     which can conflict with char gettext(); below.  */
@@ -14297,7 +14306,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14315,13 +14324,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14319: checking for gettext in -lintl" >&5
+echo "configure:14328: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14325 "configure"
+#line 14334 "configure"
@@ -14332,7 +14341,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14367,7 +14376,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14371: checking whether to use C++" >&5
+echo "configure:14380: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14383,7 +14392,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14387: checking for $ac_word" >&5
+echo "configure:14396: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14412,7 +14421,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14416: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14425: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14423,12 +14432,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14427 "configure"
+#line 14436 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14454,19 +14463,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14458: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14467: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14463: checking whether we are using GNU C++" >&5
+echo "configure:14472: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14470: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14484,7 +14493,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14488: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14497: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14525,7 +14534,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14529: checking whether to use openDWG" >&5
+echo "configure:14538: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14545,7 +14554,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14549: checking for location of openDGW includes" >&5
+echo "configure:14558: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14571,15 +14580,15 @@
 do
-echo "configure:14575: checking for $ac_hdr" >&5
+echo "configure:14584: checking for $ac_hdr" >&5
-#line 14578 "configure"
+#line 14587 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14592: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14613,7 +14622,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14617: checking for location of openDWG library" >&5
+echo "configure:14626: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14660,7 +14669,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14664: checking for special C compiler options needed for large files" >&5
+echo "configure:14673: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14668,7 +14677,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14672 "configure"
+#line 14681 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14684,7 +14693,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14688: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14693,7 +14702,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14697 "configure"
+#line 14706 "configure"
@@ -14709,7 +14718,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14722: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14729,11 +14738,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14733: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14742: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14737 "configure"
+#line 14746 "configure"
@@ -14749,14 +14758,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14753: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14762: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14760 "configure"
+#line 14769 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14774,7 +14783,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14778: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14787: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14793,11 +14802,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14797: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14806: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14801 "configure"
+#line 14810 "configure"
@@ -14813,14 +14822,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14817: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14826: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14824 "configure"
+#line 14833 "configure"
 #define _LARGE_FILES 1
@@ -14838,7 +14847,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14842: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14851: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14857,25 +14866,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14861: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14870: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14865 "configure"
+#line 14874 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14872: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14881: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14879 "configure"
+#line 14888 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14884,7 +14893,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14888: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14897: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14905,10 +14914,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14909: checking if system supports Large Files at all" >&5
+echo "configure:14918: checking if system supports Large Files at all" >&5
-#line 14912 "configure"
+#line 14921 "configure"
 #include <stdio.h>
@@ -14940,7 +14949,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14953: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14968,34 +14977,34 @@
 # Python check
+echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
+echo "configure:14982: checking whether to use Python" >&5
-echo $ac_n "checking whether to use PYTHON""... $ac_c" 1>&6
-echo "configure:14974: checking whether to use PYTHON" >&5
-echo "$ac_t"""$with_python"" 1>&6
-case "$with_python" in
-	"no")	USE_PYTHON=	;;
-	"yes")	USE_PYTHON="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
+PYTHONINC=
+PYTHONCFLAGS=
+PYTHONLDFLAGS=
+USE_PYTHON=
+if test "$with_python" = "no" ; then
+  echo "$ac_t""no" 1>&6
+else
+  echo "$ac_t""yes" 1>&6
+  USE_PYTHON="1"
+  if test "$with_python" != "yes" ; then
+    PY_CONFIG="$with_python"
+  fi
-if test -n "$USE_PYTHON"; then
-# check for Python executable
-if test -z "$PYTHON_BIN"; then
-  # Extract the first word of "python", so it can be a program name with args.
-set dummy python; ac_word=$2
+  # Extract the first word of "python-config", so it can be a program name with args.
+set dummy python-config; ac_word=$2
-echo "configure:14992: checking for $ac_word" >&5
+echo "configure:15001: checking for $ac_word" >&5
-case "$PYTHON_BIN" in
+case "$PY_CONFIG" in
-  ac_cv_path_PYTHON_BIN="$PYTHON_BIN" # Let the user override the test with a path.
+  ac_cv_path_PY_CONFIG="$PY_CONFIG" # Let the user override the test with a path.
-  ac_cv_path_PYTHON_BIN="$PYTHON_BIN" # Let the user override the test with a dos path.
+  ac_cv_path_PY_CONFIG="$PY_CONFIG" # Let the user override the test with a dos path.
   IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
@@ -15003,65 +15012,118 @@
   for ac_dir in $ac_dummy; do
     test -z "$ac_dir" && ac_dir=.
     if test -f $ac_dir/$ac_word; then
-      ac_cv_path_PYTHON_BIN="$ac_dir/$ac_word"
+      ac_cv_path_PY_CONFIG="$ac_dir/$ac_word"
       break
     fi
   done
   IFS="$ac_save_ifs"
+  test -z "$ac_cv_path_PY_CONFIG" && ac_cv_path_PY_CONFIG="no"
 esac
-PYTHON_BIN="$ac_cv_path_PYTHON_BIN"
-if test -n "$PYTHON_BIN"; then
-  echo "$ac_t""$PYTHON_BIN" 1>&6
+PY_CONFIG="$ac_cv_path_PY_CONFIG"
+if test -n "$PY_CONFIG"; then
+  echo "$ac_t""$PY_CONFIG" 1>&6
 else
 fi
-  if test -z "$PYTHON_BIN"; then
-    # Extract the first word of "python2.3", so it can be a program name with args.
-set dummy python2.3; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15025: checking for $ac_word" >&5
-  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
-  ac_dummy="$PATH"
-  for ac_dir in $ac_dummy; do
-    test -z "$ac_dir" && ac_dir=.
-    if test -f $ac_dir/$ac_word; then
-      break
-    fi
-  done
-  IFS="$ac_save_ifs"
-esac
+  if test "$PY_CONFIG" = "no" ; then
+    { echo "configure: error: *** couldn't find python-config" 1>&2; exit 1; }
+ fi
+  # With Python includes directory
+  PYTHONINC=`"$PY_CONFIG" --includes`
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$PYTHONINC $CPPFLAGS"
+for ac_hdr in Python.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:15046: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 15049 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:15054: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
 else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+{ echo "configure: error: *** Unable to locate Python includes." 1>&2; exit 1; }
 fi
+done
-      # Extract the first word of "python2.4", so it can be a program name with args.
-set dummy python2.4; ac_word=$2
+CPPFLAGS=$ac_save_cppflags
+  PYTHONCFLAGS=`"$PY_CONFIG" --cflags`
+  # With Python library directory
+  PYTHONLDFLAGS=`"$PY_CONFIG" --ldflags`
+fi # Done checking Python
+# Enable wxWidgets support (for wxGUI)
+echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
+echo "configure:15100: checking whether to use wxWidgets" >&5
+WXVERSION=
+WXWIDGETSCXXFLAGS=
+WXWIDGETSCPPFLAGS=
+WXWIDGETSLIB=
+USE_WXWIDGETS=
+if test "$with_wxwidgets" = "no" ; then
+else
+  USE_WXWIDGETS="1"
+  if test "`basename $with_wxwidgets`" = "wx-config" ; then
+    WX_CONFIG="$with_wxwidgets"
+  fi
+  # Extract the first word of "wx-config", so it can be a program name with args.
+set dummy wx-config; ac_word=$2
-echo "configure:15058: checking for $ac_word" >&5
+echo "configure:15120: checking for $ac_word" >&5
+case "$WX_CONFIG" in
+  ac_cv_path_WX_CONFIG="$WX_CONFIG" # Let the user override the test with a path.
+  ac_cv_path_WX_CONFIG="$WX_CONFIG" # Let the user override the test with a dos path.
@@ -15069,90 +15131,157 @@
+      ac_cv_path_WX_CONFIG="$ac_dir/$ac_word"
       break
     fi
   done
   IFS="$ac_save_ifs"
+  test -z "$ac_cv_path_WX_CONFIG" && ac_cv_path_WX_CONFIG="no"
 esac
+WX_CONFIG="$ac_cv_path_WX_CONFIG"
+if test -n "$WX_CONFIG"; then
+  echo "$ac_t""$WX_CONFIG" 1>&6
 else
 fi
-         { echo "configure: error: python binary not found in path" 1>&2; exit 1; }
-      fi
-    fi
-  fi
-fi
-PYTHON=`basename $PYTHON_BIN`
+  if test "$WX_CONFIG" = "no" ; then
+    { echo "configure: error: *** couldn't find wx-config
+  	  	  wxWidgets must be installed on your system.
+                  Please check that wx-config is in path, the directory
+                  where wxWidgets libraries are installed (returned by
+                  'wx-config --libs' or 'wx-config --static --libs' command)
+                  is in LD_LIBRARY_PATH or equivalent variable and
+                  wxWidgets version is 2.8.1 or above." 1>&2; exit 1; }
+ fi
-echo "configure:15102: checking for $ac_word" >&5
+ # Check wxWidgets version
-  ac_dummy="$PATH"
-      break
-    fi
-  done
-esac
+ REQWX="2.8.1"
+ echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
+echo "configure:15168: checking wxWidgets version" >&5
+ if WXVERSION=`"$WX_CONFIG" --version`; then
+   echo "$ac_t""$WXVERSION" 1>&6
+ else
+   echo "$ac_t""not found" 1>&6
+   { echo "configure: error: wxWidgets is required." 1>&2; exit 1; }
+ fi
+ if test `expr "$WXVERSION" \< "$REQWX"` = 1 ; then
+   { echo "configure: error: *** wxWidgets "$REQWX" or later is required." 1>&2; exit 1; }
+ fi
+ # With wxWidgets includes directory
+ WXWIDGETSCXXFLAGS=`"$WX_CONFIG" --cxxflags`
+ WXWIDGETSCPPFLAGS=`"$WX_CONFIG" --cppflags`
+CPPFLAGS="$WXWIDGETSCPPFLAGS $CPPFLAGS"
+for ac_hdr in wx/wxprec.h
+do
+echo "configure:15191: checking for $ac_hdr" >&5
+#line 15194 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:15199: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+  rm -rf conftest*
 else
+  rm -rf conftest*
+fi
+rm -f conftest*
+EOF
+else
-fi
+{ echo "configure: error: *** Unable to locate wxWidgets includes." 1>&2; exit 1; }
-  fi
 fi
+done
-# find out python version
-echo $ac_n "checking Python version""... $ac_c" 1>&6
-echo "configure:15138: checking Python version" >&5
-PYVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:3]'`
-PYMAJVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:1]'`
-PYMINVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[2:3]'`
-echo "$ac_t""$PYVERSION" 1>&6
+for ac_hdr in wx/wxPython/pseudodc.h
+do
+echo "configure:15235: checking for $ac_hdr" >&5
-# make sure Python is version 2
-if test "$PYMAJVERSION" -lt "2" || \
-   (test "$PYMAJVERSION" -eq "2" && test "$PYMINVERSION" -lt "2"); then
-  { echo "configure: error: This version of GRASS requires at least Python version 2.3.
-The one you have seems to be $PYVERSION.  You can specify an alternate python
-by using (for example) --with-python=/usr/bin/python2.3" 1>&2; exit 1; }
+#line 15238 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:15243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+  rm -rf conftest*
+else
+  rm -rf conftest*
 fi
+rm -f conftest*
+EOF
+else
 fi
+done
+ # With wxWidgets library directory
+ WXWIDGETSLIB=`"$WX_CONFIG" --libs`
+fi # $USE_WXWIDGETS
+# Done checking wxWidgets
 USE_TERMIO=
@@ -15409,10 +15538,17 @@
 s%@OPENDWGLIB@%$OPENDWGLIB%g
 s%@USE_OPENDWG@%$USE_OPENDWG%g
 s%@USE_LARGEFILES@%$USE_LARGEFILES%g
-s%@PYTHON_BIN@%$PYTHON_BIN%g
-s%@PYTHON@%$PYTHON%g
-s%@PYVERSION@%$PYVERSION%g
+s%@PY_CONFIG@%$PY_CONFIG%g
+s%@PYTHONINC@%$PYTHONINC%g
+s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
+s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
 s%@USE_PYTHON@%$USE_PYTHON%g
+s%@WX_CONFIG@%$WX_CONFIG%g
+s%@WXVERSION@%$WXVERSION%g
+s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
+s%@WXWIDGETSCPPFLAGS@%$WXWIDGETSCPPFLAGS%g
+s%@WXWIDGETSLIB@%$WXWIDGETSLIB%g
+s%@USE_WXWIDGETS@%$USE_WXWIDGETS%g
 s%@USE_TERMIO@%$USE_TERMIO%g
 s%@STRIPFLAG@%$STRIPFLAG%g
 s%@GRASS_HOME@%$GRASS_HOME%g
@@ -15740,6 +15876,8 @@
 echo "  Tcl/Tk support:             `if test -n "${USE_TCLTK}" ; then echo yes ; else echo no ; fi`"
+echo "  wxWidgets support:          `if test -n "${USE_WXWIDGETS}" ; then echo yes ; else echo no ; fi`"
 echo "  TIFF support:               `if test -n "${USE_TIFF}" ; then echo yes ; else echo no ; fi`"
 echo "  X11 support:                `if test -n "${USE_X11}" ; then echo yes ; else echo no ; fi`"
