[GRASS-SVN] r30302 - grass/trunk/include
Sat Feb 23 12:16:19 EST 2008
Author: martinl
Date: 2008-02-23 12:16:19 -0500 (Sat, 23 Feb 2008)
New Revision: 30302
Added:
   grass/trunk/include/vedit.h
missing header added
Added: grass/trunk/include/vedit.h
--- grass/trunk/include/vedit.h	                        (rev 0)
+++ grass/trunk/include/vedit.h	2008-02-23 17:16:19 UTC (rev 30302)
@@ -0,0 +1,86 @@
+#ifndef __VEDIT_H__
+#define __VEDIT_H__
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#define NO_SNAP    0 /* snapping disabled */
+#define SNAP       1 /* snapping enabled for nodes */
+#define SNAPVERTEX 2 /* snapping enabled for vertex also */
+#define QUERY_UNKNOWN -1
+#define QUERY_LENGTH   0 /* select by line length */
+#define QUERY_DANGLE   1 /* select dangles */
+/* break.c */
+int Vedit_split_lines(struct Map_info *, struct ilist *,
+		      struct line_pnts *, double,
+		      struct ilist *);
+int Vedit_connect_lines (struct Map_info *, struct ilist *,
+			 double);
+/* cats.c */
+int Vedit_modify_cats (struct Map_info *, struct ilist *,
+		       int, int, struct cat_list *);
+/* copy.c */
+int Vedit_copy_lines (struct Map_info *, struct Map_info *,
+		      struct ilist *);
+/* chtype.c */
+int Vedit_chtype_lines(struct Map_info *, struct ilist *,
+		       int *, int *, int *, int *);
+/* delete.c */
+int Vedit_delete_lines(struct Map_info *, struct ilist *);
+/* distance.c */
+double Vedit_get_min_distance(struct line_pnts *, struct line_pnts *,
+			      int, int *);
+/* flip.c */
+int Vedit_flip_lines(struct Map_info *, struct ilist *);
+/* merge.c */
+int Vedit_merge_lines(struct Map_info *, struct ilist *);
+/* move.c */
+int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
+		     struct ilist *,
+		     double, double, double, int, double);
+/* select.c */
+int Vedit_select_by_query(struct Map_info *,
+			  int, int, double, int,
+			  struct ilist *);
+/* snap.c */
+int Vedit_snap_point(struct Map_info *,
+		     int, double *, double *, double *, double,
+		     int);
+int Vedit_snap_line(struct Map_info *, struct Map_info **, int,
+		    int, struct line_pnts *,
+		    double, int);
+int Vedit_snap_lines(struct Map_info *, struct Map_info **, int,
+		     struct ilist*,
+		     double, int);
+/* vertex.c */
+int Vedit_move_vertex(struct Map_info *, struct Map_info **, int,
+		      struct ilist *,
+		      struct line_pnts*, double,
+		      int, int);
+int Vedit_add_vertex(struct Map_info *Map, struct ilist *,
+		     struct line_pnts*, double);
+int Vedit_remove_vertex(struct Map_info *, struct ilist *,
+			struct line_pnts *, double);
+/* zbulk.c */
+int Vedit_bulk_labeling (struct Map_info *, struct ilist *,
+			 double, double, double, double,
+			 double, double);
+#endif /* __VEDIT_H__ */
