[GRASS-SVN] r30304 - grass/trunk/lib/vector/vedit
Sat Feb 23 12:54:33 EST 2008
Author: martinl
Date: 2008-02-23 12:54:33 -0500 (Sat, 23 Feb 2008)
New Revision: 30304
   grass/trunk/lib/vector/vedit/break.c
   grass/trunk/lib/vector/vedit/cats.c
   grass/trunk/lib/vector/vedit/chtype.c
   grass/trunk/lib/vector/vedit/copy.c
   grass/trunk/lib/vector/vedit/delete.c
   grass/trunk/lib/vector/vedit/distance.c
   grass/trunk/lib/vector/vedit/flip.c
   grass/trunk/lib/vector/vedit/merge.c
   grass/trunk/lib/vector/vedit/move.c
   grass/trunk/lib/vector/vedit/select.c
   grass/trunk/lib/vector/vedit/snap.c
   grass/trunk/lib/vector/vedit/vertex.c
   grass/trunk/lib/vector/vedit/zbulk.c
veditlib: the vedit header changed to be public (#include <grass/vedit.h>)
Modified: grass/trunk/lib/vector/vedit/break.c
--- grass/trunk/lib/vector/vedit/break.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/break.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
 #include <math.h>
-#include "vedit.h"
+#include <grass/vedit.h>
    \brief Split selected lines on given position
Modified: grass/trunk/lib/vector/vedit/cats.c
--- grass/trunk/lib/vector/vedit/cats.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/cats.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
    \date 2006-2008
-#include "vedit.h"
    \brief Add/remove categories of selected vector features
Modified: grass/trunk/lib/vector/vedit/chtype.c
--- grass/trunk/lib/vector/vedit/chtype.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/chtype.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -18,7 +18,7 @@
    \date 2008
-#include "vedit.h"
 int Vedit_chtype_lines(struct Map_info *Map, struct ilist *List,
 		       int *npoints, int *ncentroids,
Modified: grass/trunk/lib/vector/vedit/copy.c
--- grass/trunk/lib/vector/vedit/copy.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/copy.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
    \date 2007-2008
-#include "vedit.h"
    \brief Copy selected features
Modified: grass/trunk/lib/vector/vedit/delete.c
--- grass/trunk/lib/vector/vedit/delete.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/delete.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -14,7 +14,7 @@
    \date 2007-2008
-#include "vedit.h"
    \brief Delete selected features
Modified: grass/trunk/lib/vector/vedit/distance.c
--- grass/trunk/lib/vector/vedit/distance.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/distance.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
    \date 2007-2008
-#include "vedit.h"
    \brief Calculate distances between two lines
Modified: grass/trunk/lib/vector/vedit/flip.c
--- grass/trunk/lib/vector/vedit/flip.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/flip.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -14,7 +14,7 @@
    \date 2007-2008
-#include "vedit.h"
    \brief Flip direction of selected vector lines
Modified: grass/trunk/lib/vector/vedit/merge.c
--- grass/trunk/lib/vector/vedit/merge.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/merge.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
    \date 2006-2008
-#include "vedit.h"
    \brief Merge two given lines a, b
Modified: grass/trunk/lib/vector/vedit/move.c
--- grass/trunk/lib/vector/vedit/move.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/move.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
    \date 2007-2008
-#include "vedit.h"
    \brief Move selected features
Modified: grass/trunk/lib/vector/vedit/select.c
--- grass/trunk/lib/vector/vedit/select.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/select.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -12,7 +12,7 @@
    \date 2007-2008
-#include "vedit.h"
 static int select_by_query(struct Map_info *, int, int, int,
 			   int, double,
Modified: grass/trunk/lib/vector/vedit/snap.c
--- grass/trunk/lib/vector/vedit/snap.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/snap.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -14,7 +14,7 @@
    \date 2007-2008
-#include "vedit.h"
    \brief Snap given point to the nearest feature
Modified: grass/trunk/lib/vector/vedit/vertex.c
--- grass/trunk/lib/vector/vedit/vertex.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/vertex.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
    \date 2006-2008
-#include "vedit.h"
    \brief Move all vertices in bounding box(es)
Modified: grass/trunk/lib/vector/vedit/zbulk.c
--- grass/trunk/lib/vector/vedit/zbulk.c	2008-02-23 17:24:09 UTC (rev 30303)
+++ grass/trunk/lib/vector/vedit/zbulk.c	2008-02-23 17:54:33 UTC (rev 30304)
@@ -15,7 +15,7 @@
 #include <grass/dbmi.h>
-#include "vedit.h"
    \brief Z bulk-labeling.
