[GRASS-SVN] r30356 - in grass/trunk/gui/wxpython: . gui_modules
Tue Feb 26 09:02:00 EST 2008
Author: martinl
Date: 2008-02-26 09:02:00 -0500 (Tue, 26 Feb 2008)
New Revision: 30356
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: MapsetAccess dialog moved to preferences.py
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-26 11:53:43 UTC (rev 30355)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-26 14:02:00 UTC (rev 30356)
@@ -6,8 +6,9 @@
 Sets default display font, etc.
 Classes:
- * PreferencesDialog
- * SetDefaultFont
+ - PreferencesDialog
+ - SetDefaultFont
+ - MapsetAccess
 (C) 2007-2008 by the GRASS Development Team
 This program is free software under the GNU General Public
@@ -553,3 +554,81 @@
               fontlist.append(dfonts[item])
         return fontlist
+class MapsetAccess(wx.Dialog):
+    Controls setting options and displaying/hiding map overlay decorations
+    def __init__(self, parent, id, title=_('Set/unset access to mapsets in current location'),
+                 pos=wx.DefaultPosition, size=(-1, -1),
+                 style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER):
+        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+        self.all_mapsets, self.accessible_mapsets = utils.ListOfMapsets()
+        self.curr_mapset = grassenv.GetGRASSVariable('MAPSET')
+        # make a checklistbox from available mapsets and check those that are active
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        label = wx.StaticText(parent=self, id=wx.ID_ANY,
+                              label=_("Check mapset to make it accessible, uncheck it to hide it.%s"
+                                      "Note: PERMANENT and current mapset are always accessible.") % os.linesep)
+        sizer.Add(item=label, proportion=0,
+                  flag=wx.ALL, border=5)
+        self.mapsetlb = wx.CheckListBox(parent=self, id=wx.ID_ANY, pos=wx.DefaultPosition,
+                                        size=(350,200), choices=self.all_mapsets)
+        self.mapsetlb.Bind(wx.EVT_CHECKLISTBOX, self.OnCheckMapset)
+        sizer.Add(item=self.mapsetlb, proportion=1,
+                  flag=wx.ALL | wx.EXPAND, border=5)
+        # check all accessible mapsets
+        if globalSettings.Get('mapsetPath') == 'l':
+            for mset in self.all_mapsets:
+                self.mapsetlb.Check(self.all_mapsets.index(mset), True)
+        else:
+            for mset in self.accessible_mapsets:
+        # dialog buttons
+        line = wx.StaticLine(parent=self, id=wx.ID_ANY,
+                             style=wx.LI_HORIZONTAL)
+        sizer.Add(item=line, proportion=0,
+                  flag=wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border=5)
+        btnsizer = wx.StdDialogButtonSizer()
+        okbtn = wx.Button(self, wx.ID_OK)
+        okbtn.SetDefault()
+        btnsizer.AddButton(okbtn)
+        cancelbtn = wx.Button(self, wx.ID_CANCEL)
+        btnsizer.AddButton(cancelbtn)
+        btnsizer.Realize()
+        sizer.Add(item=btnsizer, proportion=0,
+                  flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+        # do layout
+        self.Layout()
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+        self.SetMinSize(self.GetBestSize())
+    def OnCheckMapset(self, event):
+        """Mapset checked/unchecked"""
+        mapset = self.mapsetlb.GetString(event.GetSelection())
+        if mapset == 'PERMANENT' or mapset == self.curr_mapset:
+            self.mapsetlb.Check(event.GetSelection(), True)
+    def GetMapsets(self):
+        """Get list of checked mapsets"""
+        ms = []
+        i = 0
+            if self.mapsetlb.IsChecked(i):
+                ms.append(mset)
+            i += 1
+        return ms
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-02-26 11:53:43 UTC (rev 30355)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-02-26 14:02:00 UTC (rev 30356)
@@ -82,8 +82,8 @@
 import gui_modules.globalvar as globalvar
 from   gui_modules.debug import Debug as Debug
 from   icons.icon import Icons as Icons
+from   gui_modules.preferences import globalSettings as UserSettings
 class GMFrame(wx.Frame):
     GIS Manager frame with notebook widget for controlling
@@ -330,27 +330,18 @@
         Launch mapset access dialog
-        dlg = MapsetAccess(self, wx.ID_ANY)
+        dlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
         dlg.CenterOnScreen()
         # if OK is pressed...
         if dlg.ShowModal() == wx.ID_OK:
-            # create string of accessible mapsets
-            ms_string = 'PERMANENT'
-            if dlg.curr_mapset == 'PERMANENT':
-            else:
-                ms_string = 'PERMANENT,%s' % dlg.curr_mapset
-            for mset in dlg.all_mapsets:
-                    index = dlg.all_mapsets.index(mset)
-                    if dlg.mapsetlb.IsChecked(index):
-                        ms_string += ',%s' % mset
+            ms = dlg.GetMapsets()
             # run g.mapsets with string of accessible mapsets
-            cmdlist = ['g.mapsets', 'mapset=%s' % ms_string]
+            cmdlist = ['g.mapsets', 'mapset=%s' % ','.join(ms)]
             gcmd.Command(cmdlist)
+            UserSettings.Set('mapsetPath', ms, internal=True)
+            print UserSettings.Get('mapsetPath', internal=True)
     def OnRDigit(self, event):
         Launch raster digitizing module
@@ -1252,72 +1243,6 @@
         dlg.ShowModal()
         dlg.Destroy()
-class MapsetAccess(wx.Dialog):
-    Controls setting options and displaying/hiding map overlay decorations
-    def __init__(self, parent, id, title=_('Set/unset access to mapsets in current location'),
-                           pos=wx.DefaultPosition, size=(-1,-1),
-                           style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER):
-        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
-        self.all_mapsets, self.accessible_mapsets = utils.ListOfMapsets()
-        self.curr_mapset = grassenv.GetGRASSVariable('MAPSET')
-        # remove PERMANENT and current mapset from list because they are always accessible
-        self.PERMANENT_ndx = self.all_mapsets.index("PERMANENT")
-        self.all_mapsets.pop(self.PERMANENT_ndx)
-        if self.curr_mapset != "PERMANENT":
-            self.curr_ndx = self.all_mapsets.index(self.curr_mapset)
-            self.all_mapsets.pop(self.curr_ndx)
-        # make a checklistbox from available mapsets and check those that are active
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        box = wx.BoxSizer(wx.HORIZONTAL)
-        if len(self.all_mapsets) == 0:
-            label = wx.StaticText(self, -1, "No other accessible mapsets besides \
-                                \nPERMANENT and current mapset.",
-                                style=wx.ALIGN_CENTRE)
-        else:
-            label = wx.StaticText(self, -1, "Check mapset to make it accessible, uncheck it to hide it.\
-                                \nPERMANENT and current mapset are always accessible.",
-        box.Add(label, 0, wx.ALIGN_CENTRE)
-        sizer.Add(box, 0, wx.ALIGN_CENTRE|wx.TOP|wx.BOTTOM, 5)
-        self.mapsetlb = wx.CheckListBox(self, -1, pos=wx.DefaultPosition,
-                                        size=(350,200), choices=self.all_mapsets)
-        box.Add(self.mapsetlb, 0, wx.ALIGN_CENTRE)
-        # check all accessible mapsets
-        for mset in self.accessible_mapsets:
-            if mset != 'PERMANENT' and mset != self.curr_mapset:
-                self.mapsetlb.Check(self.all_mapsets.index(mset),True)
-        # dialog buttons
-        line = wx.StaticLine(self, -1, size=(-1,-1), style=wx.LI_HORIZONTAL)
-        sizer.Add(line, 0, wx.EXPAND|wx.ALIGN_CENTRE|wx.TOP|wx.BOTTOM, 5)
-        btnsizer = wx.StdDialogButtonSizer()
-        okbtn = wx.Button(self, wx.ID_OK)
-        okbtn.SetDefault()
-        btnsizer.AddButton(okbtn)
-        cancelbtn = wx.Button(self, wx.ID_CANCEL)
-        btnsizer.AddButton(cancelbtn)
-        btnsizer.Realize()
-        sizer.Add(btnsizer, 0, wx.EXPAND|wx.ALIGN_RIGHT|wx.ALL, 5)
-        self.Layout()
-        self.SetSizer(sizer)
-        sizer.Fit(self)
 class GMApp(wx.App):
     GMApp class
