[GRASS-SVN] r30389 - in grass/trunk/gui/wxpython: . gui_modules icons
Thu Feb 28 11:04:56 EST 2008
Author: martinl
Date: 2008-02-28 11:04:55 -0500 (Thu, 28 Feb 2008)
New Revision: 30389
   grass/trunk/gui/wxpython/gui_modules/digit.py
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
   grass/trunk/gui/wxpython/icons/icon.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: digitization settings moved to UserSettings space
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-28 12:39:28 UTC (rev 30388)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-28 16:04:55 UTC (rev 30389)
@@ -59,7 +59,7 @@
 #          (os.linesep, err)
 # which interface to use?
-if UserSettings.Get('digitInterface') == 'vedit' and GV_LINES is not None:
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') == 'vedit' and GV_LINES is not None:
     print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface. " \
         "This can significantly slow down some operations especially for " \
         "middle-large vector maps. "\
@@ -71,7 +71,7 @@
     Abstract digitization class
-    def __init__(self, mapwindow, settings=None):
+    def __init__(self, mapwindow):
         """Initialization
         @param mapwindow reference to mapwindow (MapFrame) instance
@@ -84,54 +84,6 @@
         #self.SetCategory()
-        # is unique for map window instance
-        if not settings:
-            self.settings = {}
-            # symbology
-            # self.settings["symbolBackground"] = (None, (255,255,255, 255)) # white
-            self.settings["symbolHighlight"] = (None, (255, 255, 0, 255)) #yellow
-            self.settings["symbolPoint"] = (True, (0, 0, 0, 255)) # black
-            self.settings["symbolLine"] = (True, (0, 0, 0, 255)) # black
-            self.settings["symbolBoundaryNo"] = (True, (126, 126, 126, 255)) # grey
-            self.settings["symbolBoundaryOne"] = (True, (0, 255, 0, 255)) # green
-            self.settings["symbolBoundaryTwo"] = (True, (255, 135, 0, 255)) # orange
-            self.settings["symbolCentroidIn"] = (True, (0, 0, 255, 255)) # blue
-            self.settings["symbolCentroidOut"] = (True, (165, 42, 42, 255)) # brown
-            self.settings["symbolCentroidDup"] = (True, (156, 62, 206, 255)) # violet
-            self.settings["symbolNodeOne"] = (True, (255, 0, 0, 255)) # red
-            self.settings["symbolNodeTwo"] = (True, (0, 86, 45, 255)) # dark green
-            self.settings["symbolVertex"] = (False, (255, 20, 147, 255)) # deep pink
-            # display
-            self.settings["lineWidth"] = (2, "screen pixels")
-            # snapping
-            self.settings["snapping"] = (10, "screen pixels") # value, unit
-            self.settings["snapToVertex"] = False
-            self.settings["backgroundMap"] = ''
-            # digitize new record
-            self.settings["addRecord"] = True
-            self.settings["layer"] = 1
-            self.settings["category"] = 1
-            self.settings["categoryMode"] = "Next to use"
-            # delete existing feature(s)
-            self.settings["delRecord"] = True
-            # query tool
-            self.settings["query"]       = ("length", True)   # name, select by box
-            self.settings["queryLength"] = ("shorter than", 0) # gt or lt, threshold
-            self.settings["queryDangle"] = ("shorter than", 0)
-            # select feature (point, line, centroid, boundary)
-            self.settings["selectFeature"] = {}
-            self.settings["selectFeature"]["point"] = {'id': None, 'val': True}
-            self.settings["selectFeature"]["line"] = {'id': None, 'val': True}
-            self.settings["selectFeature"]["centroid"] = {'id': None, 'val': True}
-            self.settings["selectFeature"]["boundary"] = {'id': None, 'val': True}
-        else:
-            self.settings = settings
         self.driver = CDisplayDriver(self, mapwindow)
     def SetCategoryNextToUse(self):
@@ -141,10 +93,10 @@
         @return 'True' on success, 'False' on failure
         # vector map layer without categories, reset to '1'
-        self.settings['category'] = 1
+        UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
         if self.map:
-            if UserSettings.Get('digitInterface') == 'vedit':
+            if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') == 'vedit':
                 categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
                                                 "input=%s" % self.map,
                                                 "option=report"])
@@ -154,25 +106,26 @@
                 for line in categoryCmd.ReadStdOutput():
                     if "all" in line:
-                        if self.settings['layer'] != int(line.split(' ')[0]):
+                        if UserSettings.Get(group='vdigit', key='layer', subkey='value') != int(line.split(' ')[0]):
                             continue
                         try:
                             maxCat = int(line.split(' ')[-1]) + 1
-                            self.settings['category'] = maxCat
+                            UserSettings.Set(group='vdigit', key='category', subkey='value', value=maxCat)
                         except:
                             return False
                         return True
             else:
-                self.settings['category'] = self.digit.GetCategory(self.settings['layer']) + 1
+                                  value=self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value') + 1))
     def SetCategory(self):
         """Return category number to use (according Settings)"""
-        if self.settings["categoryMode"] == "No category":
-        elif self.settings["categoryMode"] == "Next to use":
+        if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "No category":
+            UserSettings.Set(group='vdigit', key="category", subkey='value', value=1)
+        elif UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "Next to use":
             self.SetCategoryNextToUse()
-        return self.settings["category"]
+        return UserSettings.Get(group='vdigit', key="category", subkey='value')
     def SetMapName(self, map):
         """Set map name
@@ -198,7 +151,7 @@
                                     'Data are probably corrupted, '
                                     'try to run v.build for rebuilding the topology.') % map)
-        if UserSettings.Get('digitInterface') != 'v.edit':
+        if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') != 'v.edit':
             try:
                 self.digit.InitCats()
             except:
@@ -208,13 +161,13 @@
         """Generic method used for SelectLinesByQuery()
         -- to get threshold value"""
         thresh = 0.0
-        if self.settings['query'][0] == "length":
-            thresh = self.settings['queryLength'][1]
-            if self.settings["queryLength"][0] == "shorter than":
+        if UserSettings.Get(group='vdigit', key='query', subkey='type') == "length":
+            thresh = UserSettings.Get(group='vdigit', key='queryLength', subkey='thresh')
+            if UserSettings.Get(group='vdigit', key="queryLength", subkey='than') == "shorter than":
                 thresh = -1 * thresh
         else:
-            thresh = self.settings['queryDangle'][1]
-            if self.settings["queryDangle"][0] == "shorter than":
+            thresh = UserSettings.Get(group='vdigit', key='queryDangle', subkey='thresh')
+            if UserSettings.Get(group='vdigit', key="queryDangle", subkey='than') == "shorter than":
         return thresh
@@ -225,11 +178,11 @@
         Used by SelectLinesByBox() and SelectLinesByPoint()"""
         type = 0
-        for feature in (('point', vdigit.GV_POINT),
-                        ('line', vdigit.GV_LINE),
-                        ('centroid', vdigit.GV_CENTROID),
-                        ('boundary', vdigit.GV_BOUNDARY)):
-            if self.settings['selectFeature'][feature[0]]['val'] is True:
+        for feature in (('Point', vdigit.GV_POINT),
+                        ('Line', vdigit.GV_LINE),
+                        ('Centroid', vdigit.GV_CENTROID),
+                        ('Boundary', vdigit.GV_BOUNDARY)):
+            if UserSettings.Get(group='vdigit', key='selectFeature'+feature[0], subkey='enabled') is True:
                 type |= feature[1]
         return type
@@ -240,7 +193,7 @@
         @param pos1,pos2 bounding box defifinition
-        if self.settings['backgroundMap'] == '':
+        if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') == '':
             Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
             return []
@@ -249,7 +202,7 @@
         vEditCmd = gcmd.Command(['v.edit',
                                  '--q',
-                                 'map=%s' % self.settings['backgroundMap'],
+                                 'map=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'),
                                  'tool=select',
                                  'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
                                  #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
@@ -273,13 +226,13 @@
     Note: This should be replaced by VDigit class.
         """Initialization
         @param settings  initial settings of digitization tool
-        AbstractDigit.__init__(self, mapwindow, settings)
+        AbstractDigit.__init__(self, mapwindow)
     def AddPoint (self, map, point, x, y, z=None):
         """Add point/centroid
@@ -293,7 +246,7 @@
         else:
             key = "C"
-        layer = self.settings["layer"]
+        layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
         cat   = self.SetCategory()
         if layer > 0 and cat != "None":
@@ -325,7 +278,7 @@
         if len(coords) < 2:
             return
         if line:
@@ -363,10 +316,10 @@
         @param input feature definition in GRASS ASCII format
         @param flags additional flags
-        if self.settings['snapping'][0] <= 0.0:
+        if UserSettings.Get(group='vdigit', key='snapping', subkey='value') <= 0.0:
             snap = "no"
         else:
-            if self.settings['snapToVertex']:
+            if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
                 snap = "vertex"
             else:
                 snap = "node"
@@ -377,8 +330,8 @@
                    "thresh=%f" % self.driver.GetThreshold(),
                    "snap=%s" % snap]
-        if self.settings['backgroundMap'] != '':
-            command.append("bgmap=%s" % self.settings['backgroundMap'])
+        if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') != '':
+            command.append("bgmap=%s" % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
         # additional flags
         for flag in flags:
@@ -404,7 +357,7 @@
                       ids)
         # delete also attributes if requested
-        if self.settings['delRecord'] is True:
+        if UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled') is True:
             layerCommand = gcmd.Command(cmd=["v.db.connect",
                                              "-g", "--q",
                                              "map=%s" % self.map],
@@ -486,10 +439,10 @@
         Debug.msg(4, "Digit.MoveSelectedLines(): ids=%s, move=%s" % \
                       (ids, move))
-        if self.settings['snapping'][0] <= 0:
             snap = "no"
         else:
                 snap = "vertex"
             else:
                 snap = "node"
@@ -507,8 +460,8 @@
             command.append("coords=%f,%f" % (float(coords[0]), float(coords[1])))
             command.append("-1") # modify only first selected
         # run the command
         vedit = gcmd.Command(cmd=command, stderr=None)
@@ -691,8 +644,8 @@
                  'tool=copy',
                  'ids=%s' % ",".join(["%d" % v for v in ids])]
-            vEdit.append('bgmap=%s' % self.settings['backgroundMap'])
+            vEdit.append('bgmap=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
         runCmd = gcmd.Command(vEdit)
@@ -733,7 +686,7 @@
         w, n = pos1
         e, s = pos2
-        if self.settings['query'][1] == False: # select globaly
+        if UserSettings.Get(group='vdigit', key='query', subkey='box') == False: # select globaly
             vInfo = gcmd.Command(['v.info',
                                   'map=%s' % self.map,
                                   '-g'])
@@ -752,7 +705,7 @@
                   'tool=select',
                   'bbox=%f,%f,%f,%f' % (w, n, e, s),
-                  'query=%s' % self.settings['query'][0],
+                  'query=%s' % UserSettings.Get(group='vdigit', key='query', subkey='thresh'),
                   'thresh=%f' % thresh])
         vEditCmd = gcmd.Command(vEdit)
@@ -790,13 +743,13 @@
     Under development (wxWidgets C/C++ background)
         """Initialization
         try:
             self.digit = vdigit.Digit(self.driver.GetDevice())
@@ -810,7 +763,7 @@
         @param point feature type (if true point otherwise centroid)
         @param x,y,z coordinates
         if point:
@@ -822,10 +775,10 @@
         if z:
             ret = self.digit.AddLine(type, [x, y, z], layer, cat,
-                                     str(self.settings["backgroundMap"]), snap, thresh)
+                                     str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'), snap, thresh))
         else:
             ret = self.digit.AddLine(type, [x, y], layer, cat,
         if ret == -1:
             raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
@@ -840,7 +793,7 @@
         if len(coords) < 2:
             return
         if line:
@@ -856,7 +809,7 @@
         snap, thresh = self.__getSnapThreshold()
         ret = self.digit.AddLine(type, listCoords, layer, cat,
         if ret == -1:
@@ -867,7 +820,7 @@
         @return number of deleted lines
-        nlines = self.digit.DeleteLines(self.settings['delRecord'])
+        nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
         return nlines
@@ -879,7 +832,7 @@
         nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
         return nlines
@@ -896,7 +849,7 @@
         return self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
+                                     str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
     def AddVertex(self, coords):
         """Add new vertex to the selected line/boundary on position 'coords'
@@ -945,7 +898,7 @@
         return self.digit.RewriteLine(lineid, listCoords,
     def FlipLine(self):
         """Flip selected lines/boundaries"""
@@ -974,7 +927,7 @@
         @param ids list of line ids to be copied
-        return self.digit.CopyLines(ids, str(self.settings['backgroundMap']))
+        return self.digit.CopyLines(ids, str(UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value')))
     def CopyCats(self, cats, ids):
         """Copy given categories to objects with id listed in ids
@@ -998,14 +951,14 @@
         e, s = pos2
         query = vdigit.QUERY_UNKNOWN
-        if self.settings['query'][0] == 'length':
+        if UserSettings.Get(group='vdigit', key='query', subkey='type') == 'length':
             query = vdigit.QUERY_LENGTH
-        elif self.settings['query'][0] == 'dangle':
+        elif UserSettings.Get(group='vdigit', key='query', subkey='type') == 'dangle':
             query = vdigit.QUERY_DANGLE
         type = vdigit.GV_POINTS | vdigit.GV_LINES # TODO: 3D
-        ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0, self.settings['query'][1],
+        ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0, UserSettings.Get(group='vdigit', key='query', subkey='box'),
                                             query, type, thresh)
         Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
@@ -1054,7 +1007,7 @@
         thresh = self.driver.GetThreshold()
         if thresh > 0.0:
                 snap = vdigit.SNAPVERTEX
             else:
                 snap = vdigit.SNAP
@@ -1063,7 +1016,7 @@
         return (snap, thresh)
-if UserSettings.Get('digitInterface') == 'vedit':
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') == 'vedit':
     class Digit(VEdit):
         """Default digit class"""
@@ -1097,10 +1050,10 @@
         @param units units (map, screen)
         if not value:
-            value = self.parent.settings["snapping"][0]
+            value = UserSettings.Get(group='vdigit', key="snapping", subkey='value')
         if not units:
-            units = self.parent.settings["snapping"][1]
+            units = UserSettings.Get(group='vdigit', key="snapping", subkey='units')
         if units == "screen pixels":
             # pixel -> cell
@@ -1138,7 +1091,6 @@
         except:
             self.__display = None
-        settings = self.parent.settings
         self.UpdateSettings()
     def GetDevice(self):
@@ -1167,7 +1119,7 @@
         if map:
             name, mapset = map.split('@')
             try:
                     ret = self.__display.OpenMap(str(name), str(mapset), False)
                 else:
                     ret = self.__display.OpenMap(str(name), str(mapset), True)
@@ -1295,72 +1247,71 @@
     def UpdateSettings(self):
         """Update display driver settings"""
         # TODO map units
         if not self.__display:
             return
-        self.__display.UpdateSettings (wx.Color(settings['symbolHighlight'][1][0],
-                                                settings['symbolHighlight'][1][1],
-                                                settings['symbolHighlight'][1][2],
+        self.__display.UpdateSettings (wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolPoint'][0],
-                                       wx.Color(settings['symbolPoint'][1][0],
-                                                settings['symbolPoint'][1][1],
-                                                settings['symbolPoint'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolPoint', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolLine'][0],
-                                       wx.Color(settings['symbolLine'][1][0],
-                                                settings['symbolLine'][1][1],
-                                                settings['symbolLine'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolLine', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[2],
                                            255).GetRGB(),
-                                       settings['symbolBoundaryNo'][0],
-                                       wx.Color(settings['symbolBoundaryNo'][1][0],
-                                                settings['symbolBoundaryNo'][1][1],
-                                                settings['symbolBoundaryNo'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolBoundaryOne'][0],
-                                       wx.Color(settings['symbolBoundaryOne'][1][0],
-                                                settings['symbolBoundaryOne'][1][1],
-                                                settings['symbolBoundaryOne'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolBoundaryTwo'][0],
-                                       wx.Color(settings['symbolBoundaryTwo'][1][0],
-                                                settings['symbolBoundaryTwo'][1][1],
-                                                settings['symbolBoundaryTwo'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolCentroidIn'][0],
-                                       wx.Color(settings['symbolCentroidIn'][1][0],
-                                                settings['symbolCentroidIn'][1][1],
-                                                settings['symbolCentroidIn'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolCentroidOut'][0],
-                                       wx.Color(settings['symbolCentroidOut'][1][0],
-                                                settings['symbolCentroidOut'][1][1],
-                                                settings['symbolCentroidOut'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolCentroidDup'][0],
-                                       wx.Color(settings['symbolCentroidDup'][1][0],
-                                                settings['symbolCentroidDup'][1][1],
-                                                settings['symbolCentroidDup'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolNodeOne'][0],
-                                       wx.Color(settings['symbolNodeOne'][1][0],
-                                                settings['symbolNodeOne'][1][1],
-                                                settings['symbolNodeOne'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolNodeTwo'][0],
-                                       wx.Color(settings['symbolNodeTwo'][1][0],
-                                                settings['symbolNodeTwo'][1][1],
-                                                settings['symbolNodeTwo'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['symbolVertex'][0],
-                                       wx.Color(settings['symbolVertex'][1][0],
-                                                settings['symbolVertex'][1][1],
-                                                settings['symbolVertex'][1][2],
+                                       UserSettings.Get(group='vdigit', key='symbolVertex', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
                                                 255).GetRGB(),
-                                       settings['lineWidth'][0])
+                                       UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
 class DigitSettingsDialog(wx.Dialog):
@@ -1419,8 +1370,8 @@
         for label, key in self.__SymbologyData():
             textLabel = wx.StaticText(panel, wx.ID_ANY, label)
             color = csel.ColourSelect(panel, id=wx.ID_ANY,
-                                      colour=self.parent.digit.settings[key][1], size=(25, 25))
-            isEnabled = self.parent.digit.settings[key][0]
+                                      colour=UserSettings.Get(group='vdigit', key=key, subkey='color'), size=(25, 25))
+            isEnabled = UserSettings.Get(group='vdigit', key=key, subkey='enabled')
             if isEnabled is not None:
                 enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
                 enabled.SetValue(isEnabled)
@@ -1456,15 +1407,16 @@
         flexSizer.AddGrowableCol(0)
         # line width
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
-        self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
-                                          initial=self.parent.digit.settings["lineWidth"][0],
+        self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+                                          initial=UserSettings.Get(group='vdigit', key="lineWidth", subkey='value'),
                                           min=1, max=1e6)
-        self.lineWidthUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
-                                       choices=["screen pixels", "map units"])
-        self.lineWidthUnit.SetStringSelection(self.parent.digit.settings["lineWidth"][1])
+        units = wx.StaticText(parent=panel, id=wx.ID_ANY, size=(115, -1),
+                              label=UserSettings.Get(group='vdigit', key="lineWidth", subkey='units'),
+                              style=wx.ALIGN_LEFT)
         flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
         flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer.Add(self.lineWidthUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
+                      border=10)
         sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
         border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
@@ -1480,13 +1432,13 @@
         flexSizer2.AddGrowableCol(0)
         # snapping
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
-        self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
-                                         initial=self.parent.digit.settings["snapping"][0],
+        self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+                                         initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
                                          min=1, max=1e6)
         self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
         self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
-        self.snappingUnit.SetStringSelection(self.parent.digit.settings["snapping"][1])
+        self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
         self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
         flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
         flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
@@ -1495,7 +1447,7 @@
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Backgroud vector map"))
         self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=(200,-1),
                                            type="vector")
-        self.backgroundMap.SetValue(self.parent.digit.settings["backgroundMap"])
+        self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
         self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
         flexSizer2.Add(text, proportion=1, flag=wx.ALIGN_CENTER_VERTICAL)
         flexSizer2.Add(self.backgroundMap, proportion=1, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
@@ -1504,7 +1456,7 @@
         vertexSizer = wx.BoxSizer(wx.VERTICAL)
         self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
                                       label=_("Snap also to vertex"))
-        self.snapVertex.SetValue(self.parent.digit.settings["snapToVertex"])
+        self.snapVertex.SetValue(UserSettings.Get(group='vdigit', key="snapToVertex", subkey='enabled'))
         vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
         self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
         self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
@@ -1527,7 +1479,7 @@
         # checkbox
         self.addRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
                                      label=_("Add new record into table"))
-        self.addRecord.SetValue(self.parent.digit.settings["addRecord"])
+        self.addRecord.SetValue(UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'))
         sizer.Add(item=self.addRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
         # settings
         flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
@@ -1538,22 +1490,22 @@
         if self.parent.digit.map:
             layers = map(str, self.parent.digit.GetLayers())
             if len(layers) == 0:
-                layers = [str(self.parent.digit.settings["layer"]), ]
+                layers = [str(UserSettings.Get(group='vdigit', key="layer", subkey='value')), ]
         else:
         self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
                                choices=layers)
-        self.layer.SetStringSelection(str(self.parent.digit.settings["layer"]))
+        self.layer.SetStringSelection(str(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
         flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
         flexSizer.Add(item=self.layer, proportion=0,
                       flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
         # category number
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
         self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
-                                    initial=self.parent.digit.settings["category"],
+                                    initial=UserSettings.Get(group='vdigit', key="category", subkey='value'),
                                     min=-1e9, max=1e9)
-        if self.parent.digit.settings["categoryMode"] != "Manual entry":
+        if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') != "Manual entry":
             self.category.Enable(False)
         flexSizer.Add(item=self.category, proportion=0,
@@ -1562,7 +1514,7 @@
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
         self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
                                       choices=[_("Next to use"), _("Manual entry"), _("No category")])
-        self.categoryMode.SetStringSelection(self.parent.digit.settings["categoryMode"])
+        self.categoryMode.SetStringSelection(UserSettings.Get(group='vdigit', key="categoryMode", subkey='value'))
         flexSizer.Add(item=self.categoryMode, proportion=0,
@@ -1576,7 +1528,7 @@
         # checkbox
         self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
                                         label=_("Delete record from table"))
-        self.deleteRecord.SetValue(self.parent.digit.settings["delRecord"])
+        self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
         sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
                    flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
@@ -1593,8 +1545,6 @@
     def __CreateQueryPage(self, notebook):
         """Create notebook page for query tool"""
-        settings = self.parent.digit.settings
         panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
         notebook.AddPage(page=panel, text=_("Query tool"))
@@ -1609,7 +1559,7 @@
         LocUnits = self.parent.MapWindow.Map.ProjInfo()['units']
         self.queryBox = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_("Select by box"))
-        self.queryBox.SetValue(settings["query"][1])
+        self.queryBox.SetValue(UserSettings.Get(group='vdigit', key="query", subkey='box'))
         sizer.Add(item=self.queryBox, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
         sizer.Add((0, 5))
@@ -1625,11 +1575,11 @@
         txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select lines"))
         self.queryLengthSL = wx.Choice (parent=panel, id=wx.ID_ANY,
                                         choices = [_("shorter than"), _("longer than")])
-        self.queryLengthSL.SetStringSelection(settings["queryLength"][0])
+        self.queryLengthSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryLength", subkey='than'))
         self.queryLengthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
                                             initial=1,
                                             min=0, max=1e6)
-        self.queryLengthValue.SetValue(settings["queryLength"][1])
+        self.queryLengthValue.SetValue(UserSettings.Get(group='vdigit', key="queryLength", subkey='thresh'))
         units = wx.StaticText(parent=panel, id=wx.ID_ANY, label="%s" % LocUnits)
         flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
         flexSizer.Add(self.queryLengthSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
@@ -1648,11 +1598,11 @@
         txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select dangles"))
         self.queryDangleSL = wx.Choice (parent=panel, id=wx.ID_ANY,
-        self.queryDangleSL.SetStringSelection(settings["queryDangle"][0])
+        self.queryDangleSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryDangle", subkey='than'))
         self.queryDangleValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
                                        initial=1,
                                        min=0, max=1e6)
-        self.queryDangleValue.SetValue(settings["queryDangle"][1])
+        self.queryDangleValue.SetValue(UserSettings.Get(group='vdigit', key="queryDangle", subkey='thresh'))
         flexSizer.Add(self.queryDangleSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
@@ -1660,7 +1610,7 @@
         flexSizer.Add(units, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
         sizer.Add(item=flexSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        if settings["query"][0] == "length":
+        if UserSettings.Get(group='vdigit', key="query", subkey='type') == "length":
             self.queryLength.SetValue(True)
         else:
             self.queryDangle.SetValue(True)
@@ -1674,17 +1624,33 @@
         # select box
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
-        sizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
-        for feature in ('point', 'line',
-                        'centroid', 'boundary'):
+        # feature type
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        inSizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.selectFeature = {}
+        for feature in ('Point', 'Line',
+                        'Centroid', 'Boundary'):
             chkbox = wx.CheckBox(parent=panel, label=feature)
-            settings['selectFeature'][feature]['id'] = chkbox.GetId()
-            chkbox.SetValue(settings['selectFeature'][feature]['val'])
-            sizer.Add(item=chkbox, proportion=0,
-                      flag=wx.EXPAND | wx.ALL, border=3)
-        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+            self.selectFeature[feature] = chkbox.GetId()
+            chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectFeature'+feature, subkey='enabled'))
+            inSizer.Add(item=chkbox, proportion=0,
+                        flag=wx.EXPAND | wx.ALL, border=5)
+        sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
+        # threshold
+        flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+        flexSizer.AddGrowableCol(0)
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select threshold"))
+        self.selectThreshValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+                                             initial=UserSettings.Get(group='vdigit', key="selectThresh", subkey='value'),
+                                             min=1, max=1e6)
+        units = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("screen pixels"))
+        flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(self.selectThreshValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.FIXED_MINSIZE)
+        sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
+        border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
         panel.SetSizer(border)
         return panel
@@ -1716,7 +1682,7 @@
         """Change category mode"""
         mode = event.GetString()
-        self.parent.digit.settings["categoryMode"] = mode
+        UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=mode)
         if mode == "Manual entry": # enable
             self.category.Enable(True)
         elif self.category.IsEnabled(): # disable
@@ -1725,15 +1691,15 @@
         if mode == "No category" and self.addRecord.IsChecked():
             self.addRecord.SetValue(False)
         self.parent.digit.SetCategory()
-        self.category.SetValue(self.parent.digit.settings['category'])
+        self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
     def OnChangeLayer(self, event):
         """Layer changed"""
         layer = int(event.GetString())
         if layer > 0:
-            self.parent.digit.settings['layer'] = layer
+            UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
         event.Skip()
@@ -1762,7 +1728,7 @@
         threshold = self.parent.digit.driver.GetThreshold(value, units)
         if units == "map units":
-            self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(name)s") %
+            self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
                                        {'value' : value,
                                         'units' : self.mapUnits})
         else:
@@ -1776,7 +1742,7 @@
         """Change background map"""
         map = self.backgroundMap.GetValue()
-        self.parent.digit.settings['backgroundMap'] = map
+        UserSettings.Set(group='vdigit', key='backgroundMap', subkey='value', value=map)
     def OnChangeQuery(self, event):
         """Change query"""
@@ -1809,34 +1775,34 @@
         self.Close()
-        """Update self.parent.digit.settings"""
+        """Update UserSettings"""
         # symbology
         for key, (enabled, color) in self.symbology.iteritems():
             if enabled:
-                self.parent.digit.settings[key] = (enabled.IsChecked(), color.GetColour())
+                UserSettings.Set(group='vdigit', key=key, subkey='enabled', value=enabled.IsChecked())
+                UserSettings.Set(group='vdigit', key=key, subkey='color', value=color.GetColour())
             else:
-                self.parent.digit.settings[key] = (None, color.GetColour())
         # display
-        self.parent.digit.settings["lineWidth"] = (int(self.lineWidthValue.GetValue()),
-                                                   self.lineWidthUnit.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="lineWidth", subkey='value', value=int(self.lineWidthValue.GetValue()))
         # snapping
-        self.parent.digit.settings["snapping"] = (int(self.snappingValue.GetValue()), # value
-                                      self.snappingUnit.GetStringSelection()) # unit
-        self.parent.digit.settings["snapToVertex"] = self.snapVertex.IsChecked()
+        UserSettings.Set(group='vdigit', key="snapping", subkey='value', value=int(self.snappingValue.GetValue()))
+        UserSettings.Set(group='vdigit', key="snapping", subkey='units', value=self.snappingUnit.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled', value=self.snapVertex.IsChecked())
         # digitize new feature
-        self.parent.digit.settings["addRecord"] = self.addRecord.IsChecked()
-        self.parent.digit.settings["layer"] = int(self.layer.GetStringSelection())
-        if self.parent.digit.settings["categoryMode"] == "No category":
-            self.parent.digit.settings["category"] = None
+        UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled', value=self.addRecord.IsChecked())
+        UserSettings.Set(group='vdigit', key="layer", subkey='value', value=int(self.layer.GetStringSelection()))
+            UserSettings.Set(group='vdigit', key="category", subkey='value', value=None)
         else:
-            self.parent.digit.settings["category"] = int(self.category.GetValue())
-        self.parent.digit.settings["categoryMode"] = self.categoryMode.GetStringSelection()
+            UserSettings.Set(group='vdigit', key="category", subkey='value', value=int(self.category.GetValue()))
+        UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=self.categoryMode.GetStringSelection())
-        self.parent.digit.settings["delRecord"] = self.deleteRecord.IsChecked()
+        UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled', value=self.deleteRecord.IsChecked())
         # threshold
         try:
@@ -1846,19 +1812,20 @@
         # query tool
         if self.queryLength.GetValue():
-            self.parent.digit.settings["query"] = ("length", self.queryBox.IsChecked())
+            UserSettings.Set(group='vdigit', key="query", subkey='type', value="length")
         else:
-            self.parent.digit.settings["query"] = ("dangle", self.queryBox.IsChecked())
-        self.parent.digit.settings["queryLength"] = (self.queryLengthSL.GetStringSelection(),
-                                                     int(self.queryLengthValue.GetValue()))
-        self.parent.digit.settings["queryDangle"] = (self.queryDangleSL.GetStringSelection(),
-                                                     int(self.queryDangleValue.GetValue()))
+            UserSettings.Set(group='vdigit', key="query", subkey='type', value="dangle")
+        UserSettings.Set(group='vdigit', key="query", subkey='box', value=self.queryBox.IsChecked())
+        UserSettings.Set(group='vdigit', key="queryLength", subkey='than', value=self.queryLengthSL.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="queryLength", subkey='thresh', value=int(self.queryLengthValue.GetValue()))
+        UserSettings.Set(group='vdigit', key="queryDangle", subkey='than', value=self.queryDangleSL.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="queryDangle", subkey='thresh', value=int(self.queryDangleValue.GetValue()))
         # select features
-            self.parent.digit.settings['selectFeature'][feature]['val'] = \
-                self.FindWindowById(self.parent.digit.settings["selectFeature"][feature]['id']).IsChecked()
+            UserSettings.Set(group='vdigit', key='selectFeature'+feature, subkey='enabled',
+                                           value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
         # update driver settings
         self.parent.digit.driver.UpdateSettings()
@@ -2179,7 +2146,7 @@
                             cat not in cats[1][layer]:
                         catList.append(cat)
                 if catList != []:
                         vEditCmd = ['v.edit', '--q',
                                     'layer=%d' % layer,
@@ -2198,7 +2165,7 @@
                         if self.line < 0:
                             wx.MessageBox(parent=self, message=_("Unable to update vector map."),
                                           caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
             # reload map (needed for v.edit)
             self.parent.parent.digit.driver.ReloadMap()
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-02-28 12:39:28 UTC (rev 30388)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-02-28 16:04:55 UTC (rev 30389)
@@ -160,7 +160,7 @@
         curr_mapset = gcmd.Command(cmdlist).ReadStdOutput()[0]
         #mapsets in current location
-        mapsets = UserSettings.Get('mapsetPath', internal=True)
+        mapsets = UserSettings.Get(group='general', key='mapsetPath', subkey='value', internal=True)
         # map element types to g.mlist types
         elementdict = {'cell':'rast',
                        'raster':'rast',
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-28 12:39:28 UTC (rev 30388)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-28 16:04:55 UTC (rev 30389)
@@ -39,14 +39,63 @@
         # default settings
         self.defaultSettings = {
             # general
-            'displayFont' : '',
-            'mapsetPath' : 'p', # current mapset search path
+            'general': {
+            'displayFont' : { 'value' : '' },
+            'mapsetPath'  : { 'value' : 'p' }, # current mapset search path
             # advanced
-            'settingsFile' : 'gisdbase', # gisdbase, location, mapset
-            'digitInterface' : 'vdigit', # vedit, vdigit
-            'iconTheme': 'silk', # grass, silk
+            'advanced' : {
+            'settingsFile'   : { 'value' : 'gisdbase' }, # gisdbase, location, mapset
+            'digitInterface' : { 'value' : 'vdigit' }, # vedit, vdigit
+            'iconTheme'      : { 'value' : 'silk' }, # grass, silk
+            # vdigit
+            'vdigit' : {
+            # symbology
+            'symbolHighlight'   : { 'enabled' : None,  'color' : (255, 255, 0, 255) }, #yellow
+            'symbolPoint'       : { 'enabled' : True,  'color' : (0, 0, 0, 255) }, # black
+            'symbolLine'        : { 'enabled' : True,  'color' : (0, 0, 0, 255) }, # black
+            'symbolBoundaryNo'  : { 'enabled' : True,  'color' : (126, 126, 126, 255) }, # grey
+            'symbolBoundaryOne' : { 'enabled' : True,  'color' : (0, 255, 0, 255) }, # green
+            'symbolBoundaryTwo' : { 'enabled' : True,  'color' : (255, 135, 0, 255) }, # orange
+            'symbolCentroidIn'  : { 'enabled' : True,  'color' : (0, 0, 255, 255) }, # blue
+            'symbolCentroidOut' : { 'enabled' : True,  'color' : (165, 42, 42, 255) }, # brown
+            'symbolCentroidDup' : { 'enabled' : True,  'color' : (156, 62, 206, 255) }, # violet
+            'symbolNodeOne'     : { 'enabled' : True,  'color' : (255, 0, 0, 255) }, # red
+            'symbolNodeTwo'     : { 'enabled' : True,  'color' : (0, 86, 45, 255) }, # dark green
+            'symbolVertex'      : { 'enabled' : False, 'color' : (255, 20, 147, 255) }, # deep pink
+            # display
+            'lineWidth' : { 'value' : 2, 'units' : 'screen pixels' },
+            # snapping
+            'snapping' : { 'value' : 10, 'units' : 'screen pixels' },
+            'snapToVertex' : { 'enabled' : False },
+            'backgroundMap' : {'value' : ''},
+            # digitize new record
+            'addRecord' : { 'enabled' : True },
+            'layer' : {'value' : 1 },
+            'category' : {'value' : 1 },
+            'categoryMode' : {'value' : 'Next to use' },
+            # delete existing feature(s)
+            'delRecord' : { 'enabled' : True },
+            # query tool
+            'query'       : { 'type' : 'length', 'box' : True },
+            'queryLength' : { 'than' : 'shorter than', 'thresh' : 0 },
+            'queryDangle' : { 'than' : 'shorter than', 'thresh' : 0 },
+            # select feature (point, line, centroid, boundary)
+            'selectFeaturePoint'    : { 'enabled' : True },
+            'selectFeatureLine'     : { 'enabled' : True },
+            'selectFeatureCentroid' : { 'enabled' : True },
+            'selectFeatureBoundary' : { 'enabled' : True },
+            'selectThresh'          : { 'value' : 10, 'units' : 'screen pixels'},
         # user settings
         self.userSettings = copy.deepcopy(self.defaultSettings)
@@ -59,13 +108,15 @@
         # internal settings (based on user settings)
         self.internalSettings = {}
-        self.internalSettings["mapsetPath"] = self.GetMapsetPath()
+        self.internalSettings['general'] = {}
+        self.internalSettings['general']["mapsetPath"] = {}
+        self.internalSettings['general']["mapsetPath"]['value'] = self.GetMapsetPath()
     def GetMapsetPath(self):
         """Store mapset search path"""
         all, access = utils.ListOfMapsets()
-        if self.Get('mapsetPath') == 'p':
+        if self.Get(group='general', key='mapsetPath', subkey='value') == 'p':
             return access
         else:
             return all
@@ -100,22 +151,21 @@
             settings = self.userSettings
         try:
+            # print '#', filename
             file = open(filename, "r")
             for line in file.readlines():
-                try:
-                    key, value = line.rstrip('%s' % os.linesep).split(':', 1)
-                except:
-                    raise SettingsError('Reading settings from file <%s> failed. '
-                                        'Line \'%s\'.' % (filename, line))
-                if settings.has_key(key):
-                    settings[key] = value
-                else:
-                                        'Unknow item <%s>.' % (filename, key))
+                line = line.rstrip('%s' % os.linesep)
+                group, key = line.split(':')[0:2]
+                kv = line.split(':')[2:]
+                idx = 0
+                while idx < len(kv):
+                    # print group, key, kv[idx], kv[idx+1]
+                    # settings.Set(grou=group, key=key, subkey=kv[idx], value=kv[idx+1])
+                    idx += 2
         except IOError, e:
             raise gcmd.SettingsError(e)
         except:
-            raise gcmd.SettingsError('Reading settings from file <%s> failed.' % filename)
+            raise gcmd.SettingsError(_('Reading settings from file <%s> failed.') % filename)
         file.close()
@@ -124,7 +174,7 @@
         if settings is None:
-        loc = self.Get('settingsFile')
+        loc = self.Get(group='advanced', key='settingsFile', subkey='value')
         gisdbase = grassenv.GetGRASSVariable("GISDBASE")
         location_name = grassenv.GetGRASSVariable("LOCATION_NAME")
         mapset_name = grassenv.GetGRASSVariable("MAPSET")
@@ -141,9 +191,15 @@
         try:
             file = open(filePath, "w")
-            for item in settings.keys():
-                if settings[item] != '':
-                    file.write('%s:%s%s' % (item, settings[item], os.linesep))
+            for group in settings.keys():
+                for item in settings[group].keys():
+                    file.write('%s:%s:' % (group, item))
+                    items = settings[group][item].keys()
+                    for idx in range(len(items)):
+                        file.write('%s:%s' % (items[idx], settings[group][item][items[idx]]))
+                        if idx < len(items) - 1:
+                            file.write(':')
+                    file.write('%s' % os.linesep)
         except IOError, e:
         except:
@@ -153,34 +209,54 @@
         return filePath
-    def Get(self, key, internal=False):
-        """Get value by key
+    def Get(self, group, key, subkey=None, internal=False):
+        """Get value by key/subkey
+        Raise KeyError if key is not found
+        @param group settings group
+        @param key
+        @param subkey if not given return dict of key
         @return value
-        @return None if key not found
         if internal is True:
             settings = self.internalSettings
         else:
-            return settings[key]
+        if settings.has_key(group) and settings[group].has_key(key):
+            if subkey is None:
+                return settings[group][key]
+            else:
+                if settings[group][key].has_key(subkey):
+                    return settings[group][key][subkey]
+                else:
+                    raise KeyError
+        else:
+            raise KeyError
         return None
-    def Set(self, key, value, internal=False):
-        """Set value by key
+    def Set(self, group, key, subkey, value, internal=False):
+        """Set value by key/subkey
+        @param key
+        @param subkey
+        @param value
         else:
+        if settings.has_key(group) and settings[group].has_key(key) and \
+               settings[group][key].has_key(subkey):
+            settings[group][key][subkey] = value
         else:
             raise KeyError
@@ -274,7 +350,7 @@
                        pos=(2, 0))
         self.mapsetPath = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
                                       choices=['mapset search path', 'all available mapsets'])
-        if self.settings.Get('mapsetPath') == 'p':
+        if self.settings.Get(group='general', key='mapsetPath', subkey='value') == 'p':
             self.mapsetPath.SetSelection(0)
         else:
             self.mapsetPath.SetSelection(1)
@@ -318,7 +394,7 @@
                        pos=(row, 0))
         self.settingsFile = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
                                       choices=['gisdbase', 'location', 'mapset'])
-        self.settingsFile.SetStringSelection(self.settings.Get('settingsFile'))
+        self.settingsFile.SetStringSelection(self.settings.Get(group='advanced', key='settingsFile', subkey='value'))
         gridSizer.Add(item=self.settingsFile,
                       wx.ALIGN_CENTER_VERTICAL,
@@ -335,7 +411,7 @@
                        pos=(row, 0))
         self.iconTheme = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
                                    choices=['grass', 'silk'])
-        self.iconTheme.SetStringSelection(self.settings.Get('iconTheme'))
+        self.iconTheme.SetStringSelection(self.settings.Get(group='advanced', key='iconTheme', subkey='value'))
         gridSizer.Add(item=self.iconTheme,
@@ -362,7 +438,7 @@
                        pos=(row, 0))
         self.digitInterface = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
                                         choices=['vdigit', 'vedit'])
-        self.digitInterface.SetStringSelection(self.settings.Get('digitInterface'))
+        self.digitInterface.SetStringSelection(self.settings.Get(group='advanced', key='digitInterface', subkey='value'))
         gridSizer.Add(item=self.digitInterface,
@@ -419,12 +495,12 @@
     def OnChangeMapsetPath(self, event):
         """Mapset path changed"""
         if event.GetSelection() == 0:
-            self.settings.Set('mapsetPath', 'p')
+            self.settings.Set(group='general', key='mapsetPath', subkey='value', value='p')
         else:
-            self.settings.Set('mapsetPath', 'l')
+            self.settings.Set(group='general', key='mapsetPath', subkey='value', value='l')
         # update internal settings
-        self.settings.Set("mapsetPath", self.settings.GetMapsetPath(), internal=True)
+        self.settings.Set(group='general', key="mapsetPath", subkey='value', value=self.settings.GetMapsetPath(), internal=True)
     def OnSave(self, event):
         """Button 'Save' clicked"""
@@ -447,13 +523,13 @@
         # TODO
         # location
-        self.settings.Set('settingsFile', self.settingsFile.GetStringSelection())
+        self.settings.Set(group='advanced', key='settingsFile', subkey='value', value=self.settingsFile.GetStringSelection())
         # icon theme
-        self.settings.Set('iconTheme', self.iconTheme.GetStringSelection())
+        self.settings.Set(group='advanced', key='iconTheme', subkey='value', value=self.iconTheme.GetStringSelection())
         # digitization interface
-        self.settings.Set('digitInterface', self.digitInterface.GetStringSelection())
+        self.settings.Set(group='advanced', key='digitInterface', subkey='value', value=self.digitInterface.GetStringSelection())
 class SetDefaultFont(wx.Dialog):
@@ -584,7 +660,7 @@
         # check all accessible mapsets
-        if globalSettings.Get('mapsetPath') == 'l':
+        if globalSettings.Get(group='general', key='mapsetPath', subkey='value') == 'l':
             for mset in self.all_mapsets:
                 self.mapsetlb.Check(self.all_mapsets.index(mset), True)
         else:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-02-28 12:39:28 UTC (rev 30388)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-02-28 16:04:55 UTC (rev 30389)
@@ -1502,7 +1502,7 @@
         self.mapset = wx.ComboBox(parent=self, id=wx.ID_ANY,
                                   style=wx.CB_SIMPLE | wx.CB_READONLY,
-                                  choices=UserSettings.Get('mapsetPath', internal=True),
+                                  choices=UserSettings.Get(group='general', key='mapsetPath', subkey='value', internal=True),
                                   size=(200,-1))
         self.mapset.SetStringSelection(grassenv.GetGRASSVariable("MAPSET"))
         bodySizer.Add(item=self.mapset,
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2008-02-28 12:39:28 UTC (rev 30388)
+++ grass/trunk/gui/wxpython/icons/icon.py	2008-02-28 16:04:55 UTC (rev 30389)
@@ -32,7 +32,7 @@
 # iconpath = grassenv.GetGRASSVariable('GRASS_ICONPATH')
 # if not iconpath:
 #    iconpath = os.getenv("GRASS_ICONPATH")
-iconTheme = UserSettings.Get('iconTheme')
+iconTheme = UserSettings.Get(group='advanced', key='iconTheme', subkey='value')
 if iconTheme and iconTheme == 'silk':
     iconpath = os.path.join(globalvar.ETCWXDIR, "icons", "silk")
 else:
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-02-28 12:39:28 UTC (rev 30388)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-02-28 16:04:55 UTC (rev 30389)
@@ -343,8 +343,8 @@
             # run g.mapsets with string of accessible mapsets
             cmdlist = ['g.mapsets', 'mapset=%s' % ','.join(ms)]
-            UserSettings.Set('mapsetPath', ms, internal=True)
-            print UserSettings.Get('mapsetPath', internal=True)
+            UserSettings.Set(group='general', key='mapsetPath', subkey='value', value=ms, internal=True)
+            print UserSettings.Get(group='general', key='mapsetPath', internal=True)
     def OnRDigit(self, event):
