[GRASS-SVN] r29554 - grass/trunk/lib/init
Thu Jan 3 05:29:26 EST 2008
Author: neteler
Date: 2008-01-03 05:29:26 -0500 (Thu, 03 Jan 2008)
New Revision: 29554
   grass/trunk/lib/init/init.sh
generate VAR file if LOCATION is created via cmd line startup
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh	2008-01-03 05:36:55 UTC (rev 29553)
+++ grass/trunk/lib/init/init.sh	2008-01-03 10:29:26 UTC (rev 29554)
@@ -501,11 +501,10 @@
 			mkdir -p "$LOCATION"
 			cp "$GISDBASE/$LOCATION_NAME/PERMANENT/WIND" "$LOCATION/WIND"
 			echo "Missing WIND file fixed"
-			# predefine DBF driver
-			#  why is this needed ??
-			#echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
-			#echo "DB_DATABASE: \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >> "$LOCATION/VAR"
-			#mkdir "$LOCATION"/dbf
+			# predefine DBF driver to avoid v.* module breakage
+			echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
+			echo "DB_DATABASE: \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >> "$LOCATION/VAR"
+			mkdir "$LOCATION"/dbf
 		   fi
 		fi
     	fi
