[GRASS-SVN] r29562 - grass/trunk/gui/wxpython/gui_modules
Fri Jan 4 15:30:59 EST 2008
Author: martinl
Date: 2008-01-04 15:30:58 -0500 (Fri, 04 Jan 2008)
New Revision: 29562
   grass/trunk/gui/wxpython/gui_modules/menudata.py
wxGUI: cosmetics in vector menu, 'create empty vector map' item added (v.edit tool=create)
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-01-04 19:31:32 UTC (rev 29561)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-01-04 20:30:58 UTC (rev 29562)
@@ -348,11 +348,12 @@
           ("Vector", (
-              ("Develop map", (
-                ("Digitize vector", "Digitize/edit vector map", "self.OnMenuCmd", "v.digit"),
+              ("Develop vector map", (
+                ("Create empty vector map", "Create new empty vector map", "self.OnMenuCmd", "v.edit tool=create"),
+                ("Digitize vector map", "Digitize/edit vector map", "self.OnMenuCmd", "v.digit"),
                 ("Create/rebuild topology", "Create or rebuild topology of vector objects", "self.OnMenuCmd", "v.build"),
-                ("Clean vector", "Clean vector objects", "self.OnMenuCmd", "v.clean"),
+                ("Clean vector map", "Clean vector objects", "self.OnMenuCmd", "v.clean"),
                 ("Convert object types", "Convert vector objects from one feature type to another", "self.OnMenuCmd", "v.type.sh"),
@@ -364,20 +365,20 @@
                 ("Dissolve boundaries", "Dissolve common boundaries of areas", "self.OnMenuCmd", "v.dissolve"),
-                ("Create 3D vector over raster", "Create 3D objects by sampling raster with 2D vector", "self.OnMenuCmd", "v.drape"),
-                ("Extrude 3D vector", "Extrude 3D objects from 2D vector", "self.OnMenuCmd", "v.extrude"),
+                ("Create 3D vector map over raster", "Create 3D objects by sampling raster with 2D vector", "self.OnMenuCmd", "v.drape"),
+                ("Extrude 3D vector map", "Extrude 3D objects from 2D vector", "self.OnMenuCmd", "v.extrude"),
                 ("Link to OGR", "Create new vector as link to external OGR layer", "self.OnMenuCmd", "v.external"),
                 ("Create labels", "Create text label file for vector features", "self.OnMenuCmd", "v.label"),
-                ("Reposition vector", "Reposition (shift, rotate, skew) vector file in coordinate space", "self.OnMenuCmd", "v.transform"),
-                ("Reproject vector", "Reproject vector from other location", "self.OnMenuCmd", "v.proj"),
+                ("Reposition vector map", "Reposition (shift, rotate, skew) vector file in coordinate space", "self.OnMenuCmd", "v.transform"),
+                ("Reproject vector map", "Reproject vector from other location", "self.OnMenuCmd", "v.proj"),
               ("Query with attributes", "Query vector objects by attribute values", "self.OnMenuCmd", "v.extract"),
               ("Query with coordinate(s)", "Query vector objects by coordinate(s)", "self.OnMenuCmd", "v.what"),
-              ("Query with another map", "Query objects using objects from a second map", "self.OnMenuCmd", "v.select"),
+              ("Query with another vector map", "Query objects using objects from a second map", "self.OnMenuCmd", "v.select"),
               ("Buffer vectors", "Create vector buffers around vector objects", "self.OnMenuCmd", "v.buffer"),
               ("Lidar analysis", (
@@ -401,7 +402,7 @@
                 ("Steiner tree", "Create Steiner tree for network and given terminals", "self.OnMenuCmd", "v.net.steiner"),
                 ("Traveling salesman analysis", "Calculate shortest route connecting given set of nodes (Traveling salesman analysis)", "self.OnMenuCmd", "v.net.salesman"),
-              ("Overlay maps", (
+              ("Overlay vector maps", (
                 ("Overlay vector maps", "Boolean overlay of 2 vector maps", "self.OnMenuCmd", "v.overlay"),
                 ("Patch vector maps", "Patch/combine multiple maps (Boolean OR)", "self.OnMenuCmd", "v.patch"),
