[GRASS-SVN] r29597 - grass/branches/releasebranch_6_3
Tue Jan 8 06:02:55 EST 2008
Author: neteler
Date: 2008-01-08 06:02:54 -0500 (Tue, 08 Jan 2008)
New Revision: 29597
   grass/branches/releasebranch_6_3/configure
   grass/branches/releasebranch_6_3/configure.in
backported avformat fix
Modified: grass/branches/releasebranch_6_3/configure
--- grass/branches/releasebranch_6_3/configure	2008-01-08 09:45:21 UTC (rev 29596)
+++ grass/branches/releasebranch_6_3/configure	2008-01-08 11:02:54 UTC (rev 29597)
@@ -10578,6 +10578,50 @@
 CPPFLAGS=$ac_save_cppflags
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$FFMPEGINCPATH $CPPFLAGS"
+for ac_hdr in avformat.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:10588: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 10591 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:10596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate FFMPEG includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
 cat >> confdefs.h <<\EOF
 #define HAVE_FFMPEG 1
 EOF
@@ -10591,7 +10635,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10595: checking for location of FFMPEG library" >&5
+echo "configure:10639: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10618,13 +10662,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10622: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10666: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lavcodec  $LIBS"
-#line 10628 "configure"
+#line 10672 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -10635,7 +10679,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -10654,13 +10698,13 @@
-echo "configure:10658: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10702: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
-#line 10664 "configure"
+#line 10708 "configure"
@@ -10671,7 +10715,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10709,6 +10753,104 @@
 LDFLAGS=${ac_save_ldflags}
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$FFMPEGLIBPATH $LDFLAGS"
+echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
+echo "configure:10764: checking for av_set_parameters in -lavformat" >&5
+ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lavformat  $LIBS"
+#line 10770 "configure"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char av_set_parameters();
+int main() {
+av_set_parameters()
+; return 0; }
+EOF
+if { (eval echo configure:10781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  FFMPEGLIB="$FFMPEGLIB -lavformat "
+else
+echo "configure:10800: checking for av_set_parameters in -lavformat" >&5
+LIBS="-lavformat -lavutil $MATHLIB $LIBS"
+#line 10806 "configure"
+int main() {
+; return 0; }
+EOF
+if { (eval echo configure:10817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  FFMPEGLIB="$FFMPEGLIB -lavformat -lavutil $MATHLIB"
+else
+LDFLAGS=${ac_save_ldflags}
+    { echo "configure: error: *** Unable to locate FFMPEG library." 1>&2; exit 1; }
+fi
+fi
 fi # $USE_FFMPEG
@@ -10731,7 +10873,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10735: checking whether to use OpenGL" >&5
+echo "configure:10877: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10765,7 +10907,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10769: checking for location of OpenGL includes" >&5
+echo "configure:10911: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10791,15 +10933,15 @@
 do
-echo "configure:10795: checking for $ac_hdr" >&5
+echo "configure:10937: checking for $ac_hdr" >&5
-#line 10798 "configure"
+#line 10940 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10945: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10833,7 +10975,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10837: checking for location of OpenGL library" >&5
+echo "configure:10979: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10862,13 +11004,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10866: checking for glBegin in -lGL" >&5
+echo "configure:11008: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10872 "configure"
+#line 11014 "configure"
@@ -10879,7 +11021,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10898,13 +11040,13 @@
-echo "configure:10902: checking for glBegin in -lGL" >&5
+echo "configure:11044: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10908 "configure"
+#line 11050 "configure"
@@ -10915,7 +11057,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10934,13 +11076,13 @@
-echo "configure:10938: checking for glBegin in -lGL" >&5
+echo "configure:11080: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10944 "configure"
+#line 11086 "configure"
@@ -10951,7 +11093,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10970,13 +11112,13 @@
-echo "configure:10974: checking for glBegin in -lGL" >&5
+echo "configure:11116: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10980 "configure"
+#line 11122 "configure"
@@ -10987,7 +11129,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11049,13 +11191,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11053: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11195: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11059 "configure"
+#line 11201 "configure"
@@ -11066,7 +11208,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11085,13 +11227,13 @@
-echo "configure:11089: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11231: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11095 "configure"
+#line 11237 "configure"
@@ -11102,7 +11244,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11146,10 +11288,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11150: checking for glXCreatePbuffer" >&5
+echo "configure:11292: checking for glXCreatePbuffer" >&5
-#line 11153 "configure"
+#line 11295 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11172,7 +11314,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11194,10 +11336,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11198: checking for glXCreateGLXPixmap" >&5
+echo "configure:11340: checking for glXCreateGLXPixmap" >&5
-#line 11201 "configure"
+#line 11343 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11220,7 +11362,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11259,7 +11401,7 @@
-echo "configure:11263: checking for location of OpenGL includes" >&5
+echo "configure:11405: checking for location of OpenGL includes" >&5
@@ -11285,15 +11427,15 @@
 do
-echo "configure:11289: checking for $ac_hdr" >&5
+echo "configure:11431: checking for $ac_hdr" >&5
-#line 11292 "configure"
+#line 11434 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11328,10 +11470,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11332: checking for glBegin" >&5
+echo "configure:11474: checking for glBegin" >&5
-#line 11335 "configure"
+#line 11477 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11354,7 +11496,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11369,10 +11511,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11373: checking for gluBeginCurve" >&5
+echo "configure:11515: checking for gluBeginCurve" >&5
-#line 11376 "configure"
+#line 11518 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11395,7 +11537,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11441,7 +11583,7 @@
-echo "configure:11445: checking for location of OpenGL includes" >&5
+echo "configure:11587: checking for location of OpenGL includes" >&5
@@ -11467,15 +11609,15 @@
 do
-echo "configure:11471: checking for $ac_hdr" >&5
+echo "configure:11613: checking for $ac_hdr" >&5
-#line 11474 "configure"
+#line 11616 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11621: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11509,7 +11651,7 @@
-echo "configure:11513: checking for location of OpenGL library" >&5
+echo "configure:11655: checking for location of OpenGL library" >&5
@@ -11532,33 +11674,33 @@
 ac_save_libs="$LIBS"
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11536: checking for OpenGL library" >&5
+echo "configure:11678: checking for OpenGL library" >&5
 LIBS="-lopengl32"
-#line 11539 "configure"
+#line 11681 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
 OPENGLLIB=-lopengl32
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11552: checking for GLU library" >&5
+echo "configure:11694: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB"
-#line 11555 "configure"
+#line 11697 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11609,7 +11751,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11613: checking whether to use ODBC" >&5
+echo "configure:11755: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11628,7 +11770,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11632: checking for location of ODBC includes" >&5
+echo "configure:11774: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11654,15 +11796,15 @@
 do
-echo "configure:11658: checking for $ac_hdr" >&5
+echo "configure:11800: checking for $ac_hdr" >&5
-#line 11661 "configure"
+#line 11803 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11696,7 +11838,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11700: checking for location of ODBC library" >&5
+echo "configure:11842: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11721,13 +11863,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11725: checking for SQLConnect in -lodbc" >&5
+echo "configure:11867: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11731 "configure"
+#line 11873 "configure"
@@ -11738,7 +11880,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11763,13 +11905,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11767: checking for SQLConnect in -liodbc" >&5
+echo "configure:11909: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11773 "configure"
+#line 11915 "configure"
@@ -11780,7 +11922,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11829,7 +11971,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11833: checking whether to use FFTW" >&5
+echo "configure:11975: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11848,7 +11990,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11852: checking for location of FFTW includes" >&5
+echo "configure:11994: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11874,15 +12016,15 @@
 do
-echo "configure:11878: checking for $ac_hdr" >&5
+echo "configure:12020: checking for $ac_hdr" >&5
-#line 11881 "configure"
+#line 12023 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11910,15 +12052,15 @@
 do
-echo "configure:11914: checking for $ac_hdr" >&5
+echo "configure:12056: checking for $ac_hdr" >&5
-#line 11917 "configure"
+#line 12059 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11922: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11946,15 +12088,15 @@
 do
-echo "configure:11950: checking for $ac_hdr" >&5
+echo "configure:12092: checking for $ac_hdr" >&5
-#line 11953 "configure"
+#line 12095 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12000,7 +12142,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12004: checking for location of FFTW library" >&5
+echo "configure:12146: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12025,13 +12167,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12029: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12171: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12035 "configure"
+#line 12177 "configure"
@@ -12042,7 +12184,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12067,13 +12209,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12071: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12213: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12077 "configure"
+#line 12219 "configure"
@@ -12084,7 +12226,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12109,13 +12251,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12113: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12255: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12119 "configure"
+#line 12261 "configure"
@@ -12126,7 +12268,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12183,7 +12325,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12187: checking whether to use BLAS" >&5
+echo "configure:12329: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12204,7 +12346,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12208: checking for location of BLAS includes" >&5
+echo "configure:12350: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12224,7 +12366,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12228: checking for location of BLAS library" >&5
+echo "configure:12370: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12250,15 +12392,15 @@
 do
-echo "configure:12254: checking for $ac_hdr" >&5
+echo "configure:12396: checking for $ac_hdr" >&5
-#line 12257 "configure"
+#line 12399 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12293,13 +12435,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12297: checking for dnrm2_ in -lblas" >&5
+echo "configure:12439: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12303 "configure"
+#line 12445 "configure"
@@ -12310,7 +12452,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12329,13 +12471,13 @@
-echo "configure:12333: checking for dnrm2_ in -lblas" >&5
+echo "configure:12475: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12339 "configure"
+#line 12481 "configure"
@@ -12346,7 +12488,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12390,13 +12532,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12394: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12536: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12400 "configure"
+#line 12542 "configure"
@@ -12407,7 +12549,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12422,13 +12564,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12426: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12568: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12432 "configure"
+#line 12574 "configure"
@@ -12439,7 +12581,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12454,13 +12596,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12458: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12600: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12464 "configure"
+#line 12606 "configure"
@@ -12471,7 +12613,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12516,16 +12658,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12520: checking for sgemm in $vlib_flags" >&5
+echo "configure:12662: checking for sgemm in $vlib_flags" >&5
-#line 12522 "configure"
+#line 12664 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12543,13 +12685,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12547: checking for sgemm_ in -lblas" >&5
+echo "configure:12689: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12553 "configure"
+#line 12695 "configure"
@@ -12560,7 +12702,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12575,13 +12717,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12579: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12721: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12585 "configure"
+#line 12727 "configure"
@@ -12592,7 +12734,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12607,13 +12749,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12611: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12753: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12617 "configure"
+#line 12759 "configure"
@@ -12624,7 +12766,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12658,13 +12800,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12662: checking for acosp in -lsunmath" >&5
+echo "configure:12804: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12668 "configure"
+#line 12810 "configure"
@@ -12675,7 +12817,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12690,13 +12832,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12694: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12836: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12700 "configure"
+#line 12842 "configure"
@@ -12707,7 +12849,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12737,13 +12879,13 @@
 # Generic BLAS library
-echo "configure:12741: checking for sgemm_ in -lblas" >&5
+echo "configure:12883: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12747 "configure"
+#line 12889 "configure"
@@ -12754,7 +12896,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12793,7 +12935,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12797: checking whether to use LAPACK" >&5
+echo "configure:12939: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12818,7 +12960,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12822: checking for location of LAPACK includes" >&5
+echo "configure:12964: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12838,7 +12980,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12842: checking for location of LAPACK library" >&5
+echo "configure:12984: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12864,15 +13006,15 @@
 do
-echo "configure:12868: checking for $ac_hdr" >&5
+echo "configure:13010: checking for $ac_hdr" >&5
-#line 12871 "configure"
+#line 13013 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12904,10 +13046,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12908: checking for dsegv_" >&5
+echo "configure:13050: checking for dsegv_" >&5
-#line 12911 "configure"
+#line 13053 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -12930,7 +13072,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -12957,13 +13099,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12961: checking for desgv_ in -llapack" >&5
+echo "configure:13103: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 12967 "configure"
+#line 13109 "configure"
@@ -12974,7 +13116,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13006,13 +13148,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13010: checking for dgesv_ in -llapack" >&5
+echo "configure:13152: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13016 "configure"
+#line 13158 "configure"
@@ -13023,7 +13165,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13042,13 +13184,13 @@
-echo "configure:13046: checking for dgesv_ in -llapack" >&5
+echo "configure:13188: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13052 "configure"
+#line 13194 "configure"
@@ -13059,7 +13201,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13115,7 +13257,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13119: checking whether to use Motif" >&5
+echo "configure:13261: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13134,7 +13276,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13138: checking for location of Motif includes" >&5
+echo "configure:13280: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13160,15 +13302,15 @@
 do
-echo "configure:13164: checking for $ac_hdr" >&5
+echo "configure:13306: checking for $ac_hdr" >&5
-#line 13167 "configure"
+#line 13309 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13172: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13202,7 +13344,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13206: checking for location of Motif library" >&5
+echo "configure:13348: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13227,13 +13369,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13231: checking for XmStringCreate in -lXm" >&5
+echo "configure:13373: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13237 "configure"
+#line 13379 "configure"
@@ -13244,7 +13386,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13285,7 +13427,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13289: checking whether to use GLw" >&5
+echo "configure:13431: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13304,7 +13446,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13308: checking for location of GLw includes" >&5
+echo "configure:13450: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13330,15 +13472,15 @@
 do
-echo "configure:13334: checking for $ac_hdr" >&5
+echo "configure:13476: checking for $ac_hdr" >&5
-#line 13337 "configure"
+#line 13479 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13342: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13484: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13366,15 +13508,15 @@
 do
-echo "configure:13370: checking for $ac_hdr" >&5
+echo "configure:13512: checking for $ac_hdr" >&5
-#line 13373 "configure"
+#line 13515 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13414,7 +13556,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13418: checking for location of GLw library" >&5
+echo "configure:13560: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13439,13 +13581,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13443: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13585: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13449 "configure"
+#line 13591 "configure"
@@ -13456,7 +13598,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13481,13 +13623,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13485: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13627: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13491 "configure"
+#line 13633 "configure"
@@ -13498,7 +13640,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13523,13 +13665,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13527: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13669: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13533 "configure"
+#line 13675 "configure"
@@ -13540,7 +13682,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13565,13 +13707,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13569: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13711: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13575 "configure"
+#line 13717 "configure"
@@ -13582,7 +13724,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13607,13 +13749,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13611: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13753: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13617 "configure"
+#line 13759 "configure"
@@ -13624,7 +13766,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13649,13 +13791,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13653: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13795: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13659 "configure"
+#line 13801 "configure"
@@ -13666,7 +13808,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13693,13 +13835,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:13697: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13839: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13703 "configure"
+#line 13845 "configure"
@@ -13710,7 +13852,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13729,13 +13871,13 @@
-echo "configure:13733: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13875: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13739 "configure"
+#line 13881 "configure"
@@ -13746,7 +13888,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13773,13 +13915,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:13777: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13919: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13783 "configure"
+#line 13925 "configure"
@@ -13790,7 +13932,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13809,13 +13951,13 @@
-echo "configure:13813: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13955: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13819 "configure"
+#line 13961 "configure"
@@ -13826,7 +13968,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13939,7 +14081,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13943: checking whether to use FreeType" >&5
+echo "configure:14085: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13958,7 +14100,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13962: checking for location of FreeType includes" >&5
+echo "configure:14104: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13984,15 +14126,15 @@
 do
-echo "configure:13988: checking for $ac_hdr" >&5
+echo "configure:14130: checking for $ac_hdr" >&5
-#line 13991 "configure"
+#line 14133 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13996: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14026,7 +14168,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14030: checking for location of FreeType library" >&5
+echo "configure:14172: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14051,13 +14193,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14055: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14197: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14061 "configure"
+#line 14203 "configure"
@@ -14068,7 +14210,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14109,7 +14251,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14113: checking whether to use NLS" >&5
+echo "configure:14255: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14129,10 +14271,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14133: checking for gettext" >&5
+echo "configure:14275: checking for gettext" >&5
-#line 14136 "configure"
+#line 14278 "configure"
     which can conflict with char gettext(); below.  */
@@ -14155,7 +14297,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14173,13 +14315,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14177: checking for gettext in -lintl" >&5
+echo "configure:14319: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14183 "configure"
+#line 14325 "configure"
@@ -14190,7 +14332,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14225,7 +14367,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14229: checking whether to use C++" >&5
+echo "configure:14371: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14241,7 +14383,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14245: checking for $ac_word" >&5
+echo "configure:14387: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14270,7 +14412,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14274: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14416: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14281,12 +14423,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14285 "configure"
+#line 14427 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14312,19 +14454,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14316: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14458: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14321: checking whether we are using GNU C++" >&5
+echo "configure:14463: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14470: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14342,7 +14484,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14346: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14488: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14383,7 +14525,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14387: checking whether to use openDWG" >&5
+echo "configure:14529: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14403,7 +14545,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14407: checking for location of openDGW includes" >&5
+echo "configure:14549: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14429,15 +14571,15 @@
 do
-echo "configure:14433: checking for $ac_hdr" >&5
+echo "configure:14575: checking for $ac_hdr" >&5
-#line 14436 "configure"
+#line 14578 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14441: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14471,7 +14613,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14475: checking for location of openDWG library" >&5
+echo "configure:14617: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14518,7 +14660,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14522: checking for special C compiler options needed for large files" >&5
+echo "configure:14664: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14526,7 +14668,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14530 "configure"
+#line 14672 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14542,7 +14684,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14546: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14688: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14551,7 +14693,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14555 "configure"
+#line 14697 "configure"
@@ -14567,7 +14709,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14571: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14587,11 +14729,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14591: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14733: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14595 "configure"
+#line 14737 "configure"
@@ -14607,14 +14749,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14611: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14753: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14618 "configure"
+#line 14760 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14632,7 +14774,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14636: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14778: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14651,11 +14793,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14655: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14797: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14659 "configure"
+#line 14801 "configure"
@@ -14671,14 +14813,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14675: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14817: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14682 "configure"
+#line 14824 "configure"
 #define _LARGE_FILES 1
@@ -14696,7 +14838,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14700: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14842: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14715,25 +14857,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14719: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14861: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14723 "configure"
+#line 14865 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14730: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14872: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14737 "configure"
+#line 14879 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14742,7 +14884,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14746: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14888: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14763,10 +14905,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14767: checking if system supports Large Files at all" >&5
+echo "configure:14909: checking if system supports Large Files at all" >&5
-#line 14770 "configure"
+#line 14912 "configure"
 #include <stdio.h>
@@ -14798,7 +14940,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14802: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14828,7 +14970,7 @@
 echo $ac_n "checking whether to use PYTHON""... $ac_c" 1>&6
-echo "configure:14832: checking whether to use PYTHON" >&5
+echo "configure:14974: checking whether to use PYTHON" >&5
 echo "$ac_t"""$with_python"" 1>&6
 case "$with_python" in
 	"no")	USE_PYTHON=	;;
@@ -14846,7 +14988,7 @@
   # Extract the first word of "python", so it can be a program name with args.
 set dummy python; ac_word=$2
-echo "configure:14850: checking for $ac_word" >&5
+echo "configure:14992: checking for $ac_word" >&5
 case "$PYTHON_BIN" in
@@ -14879,7 +15021,7 @@
     # Extract the first word of "python2.3", so it can be a program name with args.
 set dummy python2.3; ac_word=$2
-echo "configure:14883: checking for $ac_word" >&5
+echo "configure:15025: checking for $ac_word" >&5
@@ -14912,7 +15054,7 @@
       # Extract the first word of "python2.4", so it can be a program name with args.
 set dummy python2.4; ac_word=$2
-echo "configure:14916: checking for $ac_word" >&5
+echo "configure:15058: checking for $ac_word" >&5
@@ -14956,7 +15098,7 @@
-echo "configure:14960: checking for $ac_word" >&5
+echo "configure:15102: checking for $ac_word" >&5
@@ -14992,7 +15134,7 @@
 # find out python version
 echo $ac_n "checking Python version""... $ac_c" 1>&6
-echo "configure:14996: checking Python version" >&5
+echo "configure:15138: checking Python version" >&5
 PYVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:3]'`
 PYMAJVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:1]'`
 PYMINVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[2:3]'`
Modified: grass/branches/releasebranch_6_3/configure.in
--- grass/branches/releasebranch_6_3/configure.in	2008-01-08 09:45:21 UTC (rev 29596)
+++ grass/branches/releasebranch_6_3/configure.in	2008-01-08 11:02:54 UTC (rev 29597)
@@ -999,6 +999,7 @@
 LOC_CHECK_INC_PATH(ffmpeg, FFMPEG, FFMPEGINCPATH)
 LOC_CHECK_INCLUDES(avcodec.h,FFMPEG,$FFMPEGINCPATH)
+LOC_CHECK_INCLUDES(avformat.h,FFMPEG,$FFMPEGINCPATH)
 AC_DEFINE(HAVE_FFMPEG)
@@ -1011,6 +1012,7 @@
 LOC_CHECK_LIB_PATH(ffmpeg, FFMPEG, FFMPEGLIBPATH)
 LOC_CHECK_LIBS(avcodec, avcodec_init, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,-lavutil $MATHLIB)
+LOC_CHECK_LIBS(avformat, av_set_parameters, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,-lavutil $MATHLIB)
 fi # $USE_FFMPEG
