[GRASS-SVN] r29606 - grass/branches/releasebranch_6_3/imagery/i.ortho.photo/photo.rectify
Tue Jan 8 08:13:55 EST 2008
Author: neteler
Date: 2008-01-08 08:13:55 -0500 (Tue, 08 Jan 2008)
New Revision: 29606
   grass/branches/releasebranch_6_3/imagery/i.ortho.photo/photo.rectify/write.c
create temp file if it doesn't exist; open fix; i18N (merge from HEAD)
Modified: grass/branches/releasebranch_6_3/imagery/i.ortho.photo/photo.rectify/write.c
--- grass/branches/releasebranch_6_3/imagery/i.ortho.photo/photo.rectify/write.c	2008-01-08 13:09:37 UTC (rev 29605)
+++ grass/branches/releasebranch_6_3/imagery/i.ortho.photo/photo.rectify/write.c	2008-01-08 13:13:55 UTC (rev 29606)
@@ -4,21 +4,27 @@
 #include <unistd.h>
 #include <string.h>
 #include <errno.h>
+#include <grass/glocale.h>
 #include "global.h"
 int write_matrix (int row, int col)
     int n;
-    off_t offset;
     select_target_env();
-    if(!temp_fd)
+    /* create temp file if it doesn't eexist */
+    if (!temp_fd || (fcntl (temp_fd, F_GETFD) == -1))
         temp_name = G_tempfile();
         temp_fd = creat(temp_name,0660);
     for (n=0; n < matrix_rows; n++)
+        off_t offset;
         offset = ((off_t) row++ * target_window.cols + col) * G_raster_size(map_type);
         lseek(temp_fd,offset,SEEK_SET);
@@ -26,14 +32,16 @@
                                 != G_raster_size(map_type)*matrix_cols)
            unlink(temp_name);
-           G_fatal_error("error while writing to temp file: %s", strerror(errno));
+           G_fatal_error (_("Unable to write temp file: %s"), strerror(errno));
     select_current_env();
     return 0;
 int write_map(char *name)
    int fd, row;
@@ -43,23 +51,25 @@
    rast = G_allocate_raster_buf(map_type);
    close(temp_fd);
-   temp_fd = open(temp_name,0);
+   temp_fd = open (temp_name, F_DUPFD);
    fd = G_open_raster_new(name,map_type);
    if(fd <=0)
-       G_fatal_error("Can't open map %s", name);
+       G_fatal_error (_("Unable to open map %s"), name);
    for(row = 0; row < target_window.rows; row++)
        if(read(temp_fd,rast,target_window.cols * G_raster_size(map_type))
                     != target_window.cols * G_raster_size(map_type))
-          G_fatal_error("error writing row %d", row);
+          G_fatal_error (_("Unable to write row %d"), row);
        if(G_put_raster_row(fd,rast, map_type) < 0)
-          G_fatal_error("error while writing to raster map. You might want to check available disk space and write permissions.");
+          G_fatal_error (_("Unable to write raster map. You might want to check available disk space and write permissions."));
           unlink(temp_name);
    close(temp_fd);
    unlink(temp_name);
    G_close_cell(fd);
