[GRASS-SVN] r29718 - grass/trunk
Wed Jan 16 08:35:15 EST 2008
Author: martinl
Date: 2008-01-16 08:35:15 -0500 (Wed, 16 Jan 2008)
New Revision: 29718
   grass/trunk/configure
   grass/trunk/configure.in
Reverting changes (adding --with-wxpython) in configuration script
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-01-16 13:14:07 UTC (rev 29717)
+++ grass/trunk/configure	2008-01-16 13:35:15 UTC (rev 29718)
@@ -67,8 +67,6 @@
 ac_help="$ac_help
   --with-python           support PYTHON functionality (default: no)"
 ac_help="$ac_help
-  --with-wxpython         support wxPython functionality (default: no)"
-ac_help="$ac_help
   --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
 e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
@@ -717,7 +715,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:721: checking host system type" >&5
+echo "configure:719: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -740,7 +738,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:744: checking for $ac_word" >&5
+echo "configure:742: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -767,7 +765,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:771: checking for $ac_word" >&5
+echo "configure:769: checking for $ac_word" >&5
@@ -815,7 +813,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:819: checking for $ac_word" >&5
+echo "configure:817: checking for $ac_word" >&5
@@ -844,7 +842,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:848: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:846: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -855,12 +853,12 @@
 cat > conftest.$ac_ext << EOF
-#line 859 "configure"
+#line 857 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -886,19 +884,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:890: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:888: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:895: checking whether we are using GNU C" >&5
+echo "configure:893: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -916,7 +914,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:920: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:918: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -945,10 +943,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:949: checking for Cygwin environment" >&5
+echo "configure:947: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 952 "configure"
+#line 950 "configure"
 int main() {
@@ -959,7 +957,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -975,17 +973,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:979: checking for mingw32 environment" >&5
+echo "configure:977: checking for mingw32 environment" >&5
-#line 982 "configure"
+#line 980 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1003,7 +1001,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1007: checking for executable suffix" >&5
+echo "configure:1005: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1011,7 +1009,7 @@
   rm -f conftest*
   echo 'int main () { return 0; }' > conftest.$ac_ext
   ac_cv_exeext=
-  if { (eval echo configure:1015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
+  if { (eval echo configure:1013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
     for file in conftest.*; do
       case $file in
       *.$ac_ext | *.c | *.o | *.obj) ;;
@@ -1036,23 +1034,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1040: checking for full floating-point support" >&5
+echo "configure:1038: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1045: checking whether "cc -mieee" works" >&5
+echo "configure:1043: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1049 "configure"
+#line 1047 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1068,7 +1066,7 @@
 else
-#line 1072 "configure"
+#line 1070 "configure"
 #include <float.h>
@@ -1082,7 +1080,7 @@
 EOF
-if { (eval echo configure:1086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1095,14 +1093,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1099: checking for full floating-point support with -mieee" >&5
+echo "configure:1097: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1106 "configure"
+#line 1104 "configure"
 #include <float.h>
@@ -1116,7 +1114,7 @@
 EOF
-if { (eval echo configure:1120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1153,7 +1151,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1157: checking for $ac_word" >&5
+echo "configure:1155: checking for $ac_word" >&5
 case "$pwd" in
@@ -1191,7 +1189,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1195: checking for source directory" >&5
+echo "configure:1193: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1202,7 +1200,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1206: checking for build directory" >&5
+echo "configure:1204: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1265,7 +1263,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1269: checking for MacOSX App" >&5
+echo "configure:1267: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1288,7 +1286,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1292: checking how to build libraries" >&5
+echo "configure:1290: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1331,7 +1329,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1335: checking for $ac_word" >&5
+echo "configure:1333: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1356,7 +1354,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1360: checking how to run the C preprocessor" >&5
+echo "configure:1358: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1369,13 +1367,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1373 "configure"
+#line 1371 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1386,13 +1384,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1390 "configure"
+#line 1388 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1396: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1403,13 +1401,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1407 "configure"
+#line 1405 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1437,7 +1435,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1441: checking if 64bit support is requested" >&5
+echo "configure:1439: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1457,7 +1455,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1461: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1459: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1481,7 +1479,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1485: checking system version (for dynamic loading)" >&5
+echo "configure:1483: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1507,13 +1505,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1511: checking for dlopen in -ldl" >&5
+echo "configure:1509: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1517 "configure"
+#line 1515 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1524,7 +1522,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1571,7 +1569,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1575: checking for $ac_word" >&5
+echo "configure:1573: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1700,13 +1698,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1704: checking for gettimeofday in -lbsd" >&5
+echo "configure:1702: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1710 "configure"
+#line 1708 "configure"
@@ -1717,7 +1715,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1758,13 +1756,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1762: checking for inet_ntoa in -lbind" >&5
+echo "configure:1760: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1768 "configure"
+#line 1766 "configure"
@@ -1775,7 +1773,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1836,13 +1834,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1840: checking for shl_load in -ldld" >&5
+echo "configure:1838: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1846 "configure"
+#line 1844 "configure"
@@ -1853,7 +1851,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1918,13 +1916,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1922: checking for shl_load in -ldld" >&5
+echo "configure:1920: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1928 "configure"
+#line 1926 "configure"
@@ -1935,7 +1933,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2057,15 +2055,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2061: checking for dld.h" >&5
+echo "configure:2059: checking for dld.h" >&5
-#line 2064 "configure"
+#line 2062 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2125,15 +2123,15 @@
 	    else
-echo "configure:2129: checking for dld.h" >&5
+echo "configure:2127: checking for dld.h" >&5
-#line 2132 "configure"
+#line 2130 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2230,9 +2228,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2234: checking for ELF" >&5
+echo "configure:2232: checking for ELF" >&5
-#line 2236 "configure"
+#line 2234 "configure"
 #ifdef __ELF__
@@ -2262,15 +2260,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2266: checking for dlfcn.h" >&5
+echo "configure:2264: checking for dlfcn.h" >&5
-#line 2269 "configure"
+#line 2267 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2274: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2294,9 +2292,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2298: checking for ELF" >&5
+echo "configure:2296: checking for ELF" >&5
-#line 2300 "configure"
+#line 2298 "configure"
 #ifdef __ELF__
@@ -2620,17 +2618,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2624: checking for ld accepts -Bexport flag" >&5
+echo "configure:2622: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2627 "configure"
+#line 2625 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2979,16 +2977,6 @@
-# Check whether --with-wxpython or --without-wxpython was given.
-if test "${with_wxpython+set}" = set; then
-  withval="$with_wxpython"
-else
-  with_wxpython=no
-fi
 # With includes and libs options
 # Check whether --with-gdal or --without-gdal was given.
@@ -3369,7 +3357,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3373: checking for additional include dirs" >&5
+echo "configure:3361: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3392,7 +3380,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3396: checking for additional library dirs" >&5
+echo "configure:3384: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3426,7 +3414,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3430: checking for a BSD compatible install" >&5
+echo "configure:3418: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3479,7 +3467,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3483: checking for $ac_word" >&5
+echo "configure:3471: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3510,13 +3498,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3514: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3502: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3520 "configure"
+#line 3508 "configure"
@@ -3527,7 +3515,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3552,7 +3540,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3556: checking for $ac_word" >&5
+echo "configure:3544: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3592,7 +3580,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3596: checking for $ac_word" >&5
+echo "configure:3584: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3623,7 +3611,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3627: checking for $ac_word" >&5
+echo "configure:3615: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3661,7 +3649,7 @@
-echo "configure:3665: checking for $ac_word" >&5
+echo "configure:3653: checking for $ac_word" >&5
@@ -3690,7 +3678,7 @@
-echo "configure:3694: checking for $ac_word" >&5
+echo "configure:3682: checking for $ac_word" >&5
@@ -3721,7 +3709,7 @@
-echo "configure:3725: checking for $ac_word" >&5
+echo "configure:3713: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3750,7 +3738,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3754: checking for $ac_word" >&5
+echo "configure:3742: checking for $ac_word" >&5
 case "$PERL" in
@@ -3781,10 +3769,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3785: checking for ANSI C header files" >&5
+echo "configure:3773: checking for ANSI C header files" >&5
-#line 3788 "configure"
+#line 3776 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3792,7 +3780,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3784: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3809,7 +3797,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3813 "configure"
+#line 3801 "configure"
 #include <string.h>
 EOF
@@ -3827,7 +3815,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3831 "configure"
+#line 3819 "configure"
 #include <stdlib.h>
 EOF
@@ -3848,7 +3836,7 @@
 else
-#line 3852 "configure"
+#line 3840 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3859,7 +3847,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3886,15 +3874,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3890: checking for $ac_hdr" >&5
+echo "configure:3878: checking for $ac_hdr" >&5
-#line 3893 "configure"
+#line 3881 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3898: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3923,15 +3911,15 @@
 do
-echo "configure:3927: checking for $ac_hdr" >&5
+echo "configure:3915: checking for $ac_hdr" >&5
-#line 3930 "configure"
+#line 3918 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3960,15 +3948,15 @@
 do
-echo "configure:3964: checking for $ac_hdr" >&5
+echo "configure:3952: checking for $ac_hdr" >&5
-#line 3967 "configure"
+#line 3955 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3997,15 +3985,15 @@
 do
-echo "configure:4001: checking for $ac_hdr" >&5
+echo "configure:3989: checking for $ac_hdr" >&5
-#line 4004 "configure"
+#line 3992 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4034,15 +4022,15 @@
 do
-echo "configure:4038: checking for $ac_hdr" >&5
+echo "configure:4026: checking for $ac_hdr" >&5
-#line 4041 "configure"
+#line 4029 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4068,10 +4056,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4072: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4060: checking whether time.h and sys/time.h may both be included" >&5
-#line 4075 "configure"
+#line 4063 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4080,7 +4068,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4072: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4100,10 +4088,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4104: checking for off_t" >&5
+echo "configure:4092: checking for off_t" >&5
-#line 4107 "configure"
+#line 4095 "configure"
 #if STDC_HEADERS
@@ -4130,10 +4118,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4134: checking for uid_t in sys/types.h" >&5
+echo "configure:4122: checking for uid_t in sys/types.h" >&5
-#line 4137 "configure"
+#line 4125 "configure"
 EOF
@@ -4161,10 +4149,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4165: checking return type of signal handlers" >&5
+echo "configure:4153: checking return type of signal handlers" >&5
-#line 4168 "configure"
+#line 4156 "configure"
 #include <signal.h>
@@ -4181,7 +4169,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4185: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4173: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4199,10 +4187,10 @@
-echo "configure:4203: checking for Cygwin environment" >&5
+echo "configure:4191: checking for Cygwin environment" >&5
-#line 4206 "configure"
+#line 4194 "configure"
 int main() {
@@ -4213,7 +4201,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4217: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4205: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4231,10 +4219,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4235: checking for $ac_func" >&5
+echo "configure:4223: checking for $ac_func" >&5
-#line 4238 "configure"
+#line 4226 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4257,7 +4245,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4283,10 +4271,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4287: checking for $ac_func" >&5
+echo "configure:4275: checking for $ac_func" >&5
-#line 4290 "configure"
+#line 4278 "configure"
@@ -4309,7 +4297,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4335,10 +4323,10 @@
 for ac_func in drand48
 do
-echo "configure:4339: checking for $ac_func" >&5
+echo "configure:4327: checking for $ac_func" >&5
-#line 4342 "configure"
+#line 4330 "configure"
@@ -4361,7 +4349,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4387,10 +4375,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4391: checking for $ac_func" >&5
+echo "configure:4379: checking for $ac_func" >&5
-#line 4394 "configure"
+#line 4382 "configure"
@@ -4413,7 +4401,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4439,10 +4427,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4443: checking for $ac_func" >&5
+echo "configure:4431: checking for $ac_func" >&5
-#line 4446 "configure"
+#line 4434 "configure"
@@ -4465,7 +4453,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4490,13 +4478,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4494: checking whether setpgrp takes no argument" >&5
+echo "configure:4482: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4500 "configure"
+#line 4488 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4516,7 +4504,7 @@
 EOF
-if { (eval echo configure:4520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4544,16 +4532,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4548: checking for long long int" >&5
+echo "configure:4536: checking for long long int" >&5
-#line 4550 "configure"
+#line 4538 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4545: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4573,7 +4561,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4577: checking for W11" >&5
+echo "configure:4565: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4601,7 +4589,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4605: checking for X" >&5
+echo "configure:4593: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4661,12 +4649,12 @@
   # First, try using that file with no special directory specified.
-#line 4665 "configure"
+#line 4653 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4658: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4735,14 +4723,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4739 "configure"
+#line 4727 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4847,17 +4835,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4851: checking whether -R must be followed by a space" >&5
+echo "configure:4839: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4854 "configure"
+#line 4842 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4873,14 +4861,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4877 "configure"
+#line 4865 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4912,13 +4900,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4916: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4904: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4922 "configure"
+#line 4910 "configure"
@@ -4929,7 +4917,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4950,13 +4938,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4954: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4942: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4960 "configure"
+#line 4948 "configure"
@@ -4967,7 +4955,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4995,10 +4983,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4999: checking for gethostbyname" >&5
+echo "configure:4987: checking for gethostbyname" >&5
-#line 5002 "configure"
+#line 4990 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5021,7 +5009,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5041,13 +5029,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5045: checking for gethostbyname in -lnsl" >&5
+echo "configure:5033: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5051 "configure"
+#line 5039 "configure"
@@ -5058,7 +5046,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5087,10 +5075,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5091: checking for connect" >&5
+echo "configure:5079: checking for connect" >&5
-#line 5094 "configure"
+#line 5082 "configure"
     which can conflict with char connect(); below.  */
@@ -5113,7 +5101,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5133,13 +5121,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5137: checking for connect in -lsocket" >&5
+echo "configure:5125: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5143 "configure"
+#line 5131 "configure"
@@ -5150,7 +5138,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5173,10 +5161,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5177: checking for remove" >&5
+echo "configure:5165: checking for remove" >&5
-#line 5180 "configure"
+#line 5168 "configure"
     which can conflict with char remove(); below.  */
@@ -5199,7 +5187,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5219,13 +5207,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5223: checking for remove in -lposix" >&5
+echo "configure:5211: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5229 "configure"
+#line 5217 "configure"
@@ -5236,7 +5224,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5259,10 +5247,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5263: checking for shmat" >&5
+echo "configure:5251: checking for shmat" >&5
-#line 5266 "configure"
+#line 5254 "configure"
     which can conflict with char shmat(); below.  */
@@ -5285,7 +5273,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5305,13 +5293,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5309: checking for shmat in -lipc" >&5
+echo "configure:5297: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5315 "configure"
+#line 5303 "configure"
@@ -5322,7 +5310,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5354,13 +5342,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5358: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5346: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5364 "configure"
+#line 5352 "configure"
@@ -5371,7 +5359,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5409,7 +5397,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5413: checking whether to use Curses" >&5
+echo "configure:5401: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5428,15 +5416,15 @@
 do
-echo "configure:5432: checking for $ac_hdr" >&5
+echo "configure:5420: checking for $ac_hdr" >&5
-#line 5435 "configure"
+#line 5423 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5467,10 +5455,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5471: checking curses.h WINDOW structure component" >&5
+echo "configure:5459: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5474 "configure"
+#line 5462 "configure"
 #include <curses.h>
@@ -5479,7 +5467,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5483: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5471: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5488,7 +5476,7 @@
 fi
 rm -f conftest*
-#line 5492 "configure"
+#line 5480 "configure"
 #include <curses.h>
@@ -5497,7 +5485,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5489: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5513,13 +5501,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5517: checking for initscr in -lncurses" >&5
+echo "configure:5505: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5523 "configure"
+#line 5511 "configure"
@@ -5530,7 +5518,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5549,13 +5537,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5553: checking for initscr in -lcurses" >&5
+echo "configure:5541: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5559 "configure"
+#line 5547 "configure"
@@ -5566,7 +5554,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5595,13 +5583,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5599: checking for keypad in -lncurses" >&5
+echo "configure:5587: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5605 "configure"
+#line 5593 "configure"
@@ -5612,7 +5600,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5634,13 +5622,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5638: checking for keypad in -lcurses" >&5
+echo "configure:5626: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5644 "configure"
+#line 5632 "configure"
@@ -5651,7 +5639,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5681,13 +5669,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5685: checking for gtty in -lcompat" >&5
+echo "configure:5673: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5691 "configure"
+#line 5679 "configure"
@@ -5698,7 +5686,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5717,13 +5705,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5721: checking for gtty in -lbsd-compat" >&5
+echo "configure:5709: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5727 "configure"
+#line 5715 "configure"
@@ -5734,7 +5722,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5753,13 +5741,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5757: checking for gtty in -lbsd" >&5
+echo "configure:5745: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5763 "configure"
+#line 5751 "configure"
@@ -5770,7 +5758,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5804,12 +5792,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5808: checking for library containing cuserid" >&5
+echo "configure:5796: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5813 "configure"
+#line 5801 "configure"
@@ -5820,7 +5808,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5831,7 +5819,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5835 "configure"
+#line 5823 "configure"
@@ -5842,7 +5830,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5868,10 +5856,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5872: checking for xdrmem_create" >&5
+echo "configure:5860: checking for xdrmem_create" >&5
-#line 5875 "configure"
+#line 5863 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5894,7 +5882,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5912,13 +5900,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5916: checking for xdrmem_create in -lsun" >&5
+echo "configure:5904: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5922 "configure"
+#line 5910 "configure"
@@ -5929,7 +5917,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5948,13 +5936,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5952: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5940: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5958 "configure"
+#line 5946 "configure"
@@ -5965,7 +5953,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5984,13 +5972,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5988: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5976: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5994 "configure"
+#line 5982 "configure"
@@ -6001,7 +5989,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6020,13 +6008,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6024: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6012: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6030 "configure"
+#line 6018 "configure"
@@ -6037,7 +6025,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6071,10 +6059,10 @@
 for ac_func in asprintf
 do
-echo "configure:6075: checking for $ac_func" >&5
+echo "configure:6063: checking for $ac_func" >&5
-#line 6078 "configure"
+#line 6066 "configure"
@@ -6097,7 +6085,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6124,10 +6112,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6128: checking for atan" >&5
+echo "configure:6116: checking for atan" >&5
-#line 6131 "configure"
+#line 6119 "configure"
     which can conflict with char atan(); below.  */
@@ -6150,7 +6138,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6168,13 +6156,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6172: checking for atan in -lm" >&5
+echo "configure:6160: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6178 "configure"
+#line 6166 "configure"
@@ -6185,7 +6173,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6212,10 +6200,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6216: checking for dlsym" >&5
+echo "configure:6204: checking for dlsym" >&5
-#line 6219 "configure"
+#line 6207 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6238,7 +6226,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6256,13 +6244,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6260: checking for dlsym in -ldl" >&5
+echo "configure:6248: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6266 "configure"
+#line 6254 "configure"
@@ -6273,7 +6261,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6300,10 +6288,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6304: checking for iconv" >&5
+echo "configure:6292: checking for iconv" >&5
-#line 6307 "configure"
+#line 6295 "configure"
     which can conflict with char iconv(); below.  */
@@ -6326,7 +6314,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6344,13 +6332,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6348: checking for iconv in -liconv" >&5
+echo "configure:6336: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6354 "configure"
+#line 6342 "configure"
@@ -6361,7 +6349,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6380,13 +6368,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6384: checking for iconv in -lgiconv" >&5
+echo "configure:6372: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6390 "configure"
+#line 6378 "configure"
@@ -6397,7 +6385,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6416,10 +6404,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6420: checking for libiconv" >&5
+echo "configure:6408: checking for libiconv" >&5
-#line 6423 "configure"
+#line 6411 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6442,7 +6430,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6460,13 +6448,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6464: checking for libiconv in -liconv" >&5
+echo "configure:6452: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6470 "configure"
+#line 6458 "configure"
@@ -6477,7 +6465,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6496,13 +6484,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6500: checking for libiconv in -lgiconv" >&5
+echo "configure:6488: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6506 "configure"
+#line 6494 "configure"
@@ -6513,7 +6501,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6550,10 +6538,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6554: checking for socket" >&5
+echo "configure:6542: checking for socket" >&5
-#line 6557 "configure"
+#line 6545 "configure"
     which can conflict with char socket(); below.  */
@@ -6576,7 +6564,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6594,13 +6582,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6598: checking for socket in -lsocket" >&5
+echo "configure:6586: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6604 "configure"
+#line 6592 "configure"
@@ -6611,7 +6599,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6659,7 +6647,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6663: checking for location of zlib includes" >&5
+echo "configure:6651: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6685,15 +6673,15 @@
 do
-echo "configure:6689: checking for $ac_hdr" >&5
+echo "configure:6677: checking for $ac_hdr" >&5
-#line 6692 "configure"
+#line 6680 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6727,7 +6715,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6731: checking for location of zlib library" >&5
+echo "configure:6719: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6752,13 +6740,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6756: checking for deflate in -lz" >&5
+echo "configure:6744: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6762 "configure"
+#line 6750 "configure"
@@ -6769,7 +6757,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6817,7 +6805,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6821: checking for location of External PROJ.4 includes" >&5
+echo "configure:6809: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6843,15 +6831,15 @@
 do
-echo "configure:6847: checking for $ac_hdr" >&5
+echo "configure:6835: checking for $ac_hdr" >&5
-#line 6850 "configure"
+#line 6838 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6888,7 +6876,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6892: checking External PROJ.4 version" >&5
+echo "configure:6880: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6896,7 +6884,7 @@
 else
-#line 6900 "configure"
+#line 6888 "configure"
 #include <stdio.h>
@@ -6908,7 +6896,7 @@
 EOF
-if { (eval echo configure:6912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6933,7 +6921,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6937: checking for location of External PROJ.4 library" >&5
+echo "configure:6925: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6958,13 +6946,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6962: checking for pj_get_def in -lproj" >&5
+echo "configure:6950: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 6968 "configure"
+#line 6956 "configure"
@@ -6975,7 +6963,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7009,7 +6997,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7013: checking for location of External PROJ.4 data files" >&5
+echo "configure:7001: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7033,14 +7021,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7037: checking for epsg" >&5
+echo "configure:7025: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7044: checking for $PROJSHARE/epsg" >&5
+echo "configure:7032: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7072,7 +7060,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7076: checking for $ac_word" >&5
+echo "configure:7064: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7112,7 +7100,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7116: checking whether to use Readline" >&5
+echo "configure:7104: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7133,7 +7121,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7137: checking for location of Readline includes" >&5
+echo "configure:7125: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7159,15 +7147,15 @@
 do
-echo "configure:7163: checking for $ac_hdr" >&5
+echo "configure:7151: checking for $ac_hdr" >&5
-#line 7166 "configure"
+#line 7154 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7203,15 +7191,15 @@
 do
-echo "configure:7207: checking for $ac_hdr" >&5
+echo "configure:7195: checking for $ac_hdr" >&5
-#line 7210 "configure"
+#line 7198 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7203: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7245,7 +7233,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7249: checking for location of Readline library" >&5
+echo "configure:7237: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7270,13 +7258,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7274: checking for readline in -lreadline" >&5
+echo "configure:7262: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7280 "configure"
+#line 7268 "configure"
@@ -7287,7 +7275,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7322,13 +7310,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7326: checking for add_history in -lhistory" >&5
+echo "configure:7314: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7332 "configure"
+#line 7320 "configure"
@@ -7339,7 +7327,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7382,7 +7370,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7386: checking whether to use JPEG" >&5
+echo "configure:7374: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7402,7 +7390,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7406: checking for location of JPEG includes" >&5
+echo "configure:7394: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7428,15 +7416,15 @@
 do
-echo "configure:7432: checking for $ac_hdr" >&5
+echo "configure:7420: checking for $ac_hdr" >&5
-#line 7435 "configure"
+#line 7423 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7470,7 +7458,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7474: checking for location of JPEG library" >&5
+echo "configure:7462: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7497,13 +7485,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7501: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7489: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7507 "configure"
+#line 7495 "configure"
@@ -7514,7 +7502,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7533,13 +7521,13 @@
-echo "configure:7537: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7525: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7543 "configure"
+#line 7531 "configure"
@@ -7550,7 +7538,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7599,20 +7587,20 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7603: checking whether to use GDAL" >&5
+echo "configure:7591: checking whether to use GDAL" >&5
 if test "`basename xx/$with_gdal`" = "gdal-config" ; then
   GDAL_CONFIG="$with_gdal"
-  echo "$ac_t""yes" 1>&6
 fi
 if test "$with_gdal" = "no" ; then
 else
+  echo "$ac_t""yes" 1>&6
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7616: checking for $ac_word" >&5
+echo "configure:7604: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7670,10 +7658,10 @@
   ac_save_libs="$LIBS"
   LIBS="$LIBS $GDAL_LIBS"
   echo $ac_n "checking for GDALOpen""... $ac_c" 1>&6
-echo "configure:7674: checking for GDALOpen" >&5
+echo "configure:7662: checking for GDALOpen" >&5
-#line 7677 "configure"
+#line 7665 "configure"
     which can conflict with char GDALOpen(); below.  */
@@ -7696,7 +7684,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GDALOpen=yes"
 else
@@ -7715,10 +7703,10 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-echo "configure:7719: checking for GDALOpen" >&5
+echo "configure:7707: checking for GDALOpen" >&5
-#line 7722 "configure"
+#line 7710 "configure"
@@ -7741,7 +7729,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7777,7 +7765,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7781: checking whether to use TIFF" >&5
+echo "configure:7769: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7797,7 +7785,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7801: checking for location of TIFF includes" >&5
+echo "configure:7789: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7823,15 +7811,15 @@
 do
-echo "configure:7827: checking for $ac_hdr" >&5
+echo "configure:7815: checking for $ac_hdr" >&5
-#line 7830 "configure"
+#line 7818 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7823: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7865,7 +7853,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7869: checking for location of TIFF library" >&5
+echo "configure:7857: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7896,13 +7884,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7900: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7888: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7906 "configure"
+#line 7894 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7913,7 +7901,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7932,13 +7920,13 @@
-echo "configure:7936: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7924: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7942 "configure"
+#line 7930 "configure"
@@ -7949,7 +7937,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7968,13 +7956,13 @@
-echo "configure:7972: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7960: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7978 "configure"
+#line 7966 "configure"
@@ -7985,7 +7973,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8004,13 +7992,13 @@
-echo "configure:8008: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7996: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8014 "configure"
+#line 8002 "configure"
@@ -8021,7 +8009,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8040,13 +8028,13 @@
-echo "configure:8044: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8032: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8050 "configure"
+#line 8038 "configure"
@@ -8057,7 +8045,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8076,13 +8064,13 @@
-echo "configure:8080: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8068: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8086 "configure"
+#line 8074 "configure"
@@ -8093,7 +8081,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8112,13 +8100,13 @@
-echo "configure:8116: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8104: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8122 "configure"
+#line 8110 "configure"
@@ -8129,7 +8117,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8148,13 +8136,13 @@
-echo "configure:8152: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8140: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8158 "configure"
+#line 8146 "configure"
@@ -8165,7 +8153,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8263,7 +8251,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8267: checking whether to use PNG" >&5
+echo "configure:8255: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8282,7 +8270,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8286: checking for location of PNG includes" >&5
+echo "configure:8274: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8308,15 +8296,15 @@
 do
-echo "configure:8312: checking for $ac_hdr" >&5
+echo "configure:8300: checking for $ac_hdr" >&5
-#line 8315 "configure"
+#line 8303 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8308: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8350,7 +8338,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8354: checking for location of PNG library" >&5
+echo "configure:8342: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8375,13 +8363,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8379: checking for png_read_image in -lpng" >&5
+echo "configure:8367: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8385 "configure"
+#line 8373 "configure"
@@ -8392,7 +8380,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8434,7 +8422,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8438: checking whether to use Tcl/Tk" >&5
+echo "configure:8426: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8454,7 +8442,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8458: checking for location of Tcl/Tk includes" >&5
+echo "configure:8446: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8480,15 +8468,15 @@
 do
-echo "configure:8484: checking for $ac_hdr" >&5
+echo "configure:8472: checking for $ac_hdr" >&5
-#line 8487 "configure"
+#line 8475 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8525,15 +8513,15 @@
 do
-echo "configure:8529: checking for $ac_hdr" >&5
+echo "configure:8517: checking for $ac_hdr" >&5
-#line 8532 "configure"
+#line 8520 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8537: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8525: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8567,7 +8555,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8571: checking Tcl version" >&5
+echo "configure:8559: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8575,7 +8563,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8579 "configure"
+#line 8567 "configure"
 #include <stdio.h>
@@ -8587,7 +8575,7 @@
 EOF
-if { (eval echo configure:8591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8605,7 +8593,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8609: checking Tk version" >&5
+echo "configure:8597: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8613,7 +8601,7 @@
 else
-#line 8617 "configure"
+#line 8605 "configure"
 #include <stdio.h>
@@ -8625,7 +8613,7 @@
 EOF
-if { (eval echo configure:8629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8654,7 +8642,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8658: checking for location of Tcl/Tk library" >&5
+echo "configure:8646: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8684,13 +8672,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8688: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8676: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8694 "configure"
+#line 8682 "configure"
@@ -8701,7 +8689,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8720,13 +8708,13 @@
-echo "configure:8724: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8712: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8730 "configure"
+#line 8718 "configure"
@@ -8737,7 +8725,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8764,13 +8752,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8768: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8756: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8774 "configure"
+#line 8762 "configure"
@@ -8781,7 +8769,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8800,13 +8788,13 @@
-echo "configure:8804: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8792: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8810 "configure"
+#line 8798 "configure"
@@ -8817,7 +8805,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8844,13 +8832,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8848: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8836: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8854 "configure"
+#line 8842 "configure"
@@ -8861,7 +8849,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8880,13 +8868,13 @@
-echo "configure:8884: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8872: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8890 "configure"
+#line 8878 "configure"
@@ -8897,7 +8885,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8975,13 +8963,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8979: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8967: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8985 "configure"
+#line 8973 "configure"
@@ -8992,7 +8980,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9011,13 +8999,13 @@
-echo "configure:9015: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9003: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9021 "configure"
+#line 9009 "configure"
@@ -9028,7 +9016,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9055,13 +9043,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9059: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9047: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9065 "configure"
+#line 9053 "configure"
@@ -9072,7 +9060,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9091,13 +9079,13 @@
-echo "configure:9095: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9083: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9101 "configure"
+#line 9089 "configure"
@@ -9108,7 +9096,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9135,13 +9123,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9139: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9127: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9145 "configure"
+#line 9133 "configure"
@@ -9152,7 +9140,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9171,13 +9159,13 @@
-echo "configure:9175: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9163: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9181 "configure"
+#line 9169 "configure"
@@ -9188,7 +9176,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9280,7 +9268,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9284: checking whether to use PostgreSQL" >&5
+echo "configure:9272: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9307,7 +9295,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9311: checking for location of PostgreSQL includes" >&5
+echo "configure:9299: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9333,15 +9321,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9337: checking for $ac_hdr" >&5
+echo "configure:9325: checking for $ac_hdr" >&5
-#line 9340 "configure"
+#line 9328 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9379,7 +9367,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9383: checking for location of PostgreSQL library" >&5
+echo "configure:9371: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9408,13 +9396,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9412: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9400: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9418 "configure"
+#line 9406 "configure"
@@ -9425,7 +9413,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9444,13 +9432,13 @@
-echo "configure:9448: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9436: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9454 "configure"
+#line 9442 "configure"
@@ -9461,7 +9449,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9480,13 +9468,13 @@
-echo "configure:9484: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9472: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9490 "configure"
+#line 9478 "configure"
@@ -9497,7 +9485,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9516,13 +9504,13 @@
-echo "configure:9520: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9508: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9526 "configure"
+#line 9514 "configure"
@@ -9533,7 +9521,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9590,13 +9578,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9594: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9582: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9600 "configure"
+#line 9588 "configure"
@@ -9607,7 +9595,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9629,13 +9617,13 @@
-echo "configure:9633: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9621: checking for PQcmdTuples in -lpq" >&5
-#line 9639 "configure"
+#line 9627 "configure"
@@ -9646,7 +9634,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9689,7 +9677,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9693: checking whether to use MySQL" >&5
+echo "configure:9681: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9709,7 +9697,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9713: checking for location of MySQL includes" >&5
+echo "configure:9701: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9735,15 +9723,15 @@
 do
-echo "configure:9739: checking for $ac_hdr" >&5
+echo "configure:9727: checking for $ac_hdr" >&5
-#line 9742 "configure"
+#line 9730 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9780,7 +9768,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9784: checking for location of MySQL library" >&5
+echo "configure:9772: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9811,13 +9799,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9815: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9803: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9821 "configure"
+#line 9809 "configure"
@@ -9828,7 +9816,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9847,13 +9835,13 @@
-echo "configure:9851: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9839: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9857 "configure"
+#line 9845 "configure"
@@ -9864,7 +9852,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9883,13 +9871,13 @@
-echo "configure:9887: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9875: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9893 "configure"
+#line 9881 "configure"
@@ -9900,7 +9888,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9919,13 +9907,13 @@
-echo "configure:9923: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9911: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9929 "configure"
+#line 9917 "configure"
@@ -9936,7 +9924,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9955,13 +9943,13 @@
-echo "configure:9959: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9947: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9965 "configure"
+#line 9953 "configure"
@@ -9972,7 +9960,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9991,13 +9979,13 @@
-echo "configure:9995: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9983: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10001 "configure"
+#line 9989 "configure"
@@ -10008,7 +9996,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10027,13 +10015,13 @@
-echo "configure:10031: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10019: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10037 "configure"
+#line 10025 "configure"
@@ -10044,7 +10032,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10063,13 +10051,13 @@
-echo "configure:10067: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10055: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10073 "configure"
+#line 10061 "configure"
@@ -10080,7 +10068,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10170,7 +10158,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10174: checking for $ac_word" >&5
+echo "configure:10162: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10211,10 +10199,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10215: checking for mysql_server_init" >&5
+echo "configure:10203: checking for mysql_server_init" >&5
-#line 10218 "configure"
+#line 10206 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10237,7 +10225,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10275,7 +10263,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10279: checking whether to use SQLite" >&5
+echo "configure:10267: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10295,7 +10283,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10299: checking for location of SQLite includes" >&5
+echo "configure:10287: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10321,15 +10309,15 @@
 do
-echo "configure:10325: checking for $ac_hdr" >&5
+echo "configure:10313: checking for $ac_hdr" >&5
-#line 10328 "configure"
+#line 10316 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10372,7 +10360,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10376: checking for location of SQLite library" >&5
+echo "configure:10364: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10399,13 +10387,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10403: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10391: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10409 "configure"
+#line 10397 "configure"
@@ -10416,7 +10404,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10435,13 +10423,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10439: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10427: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10445 "configure"
+#line 10433 "configure"
@@ -10452,7 +10440,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10505,7 +10493,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10509: checking whether to use FFMPEG" >&5
+echo "configure:10497: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10525,7 +10513,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10529: checking for location of FFMPEG includes" >&5
+echo "configure:10517: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10551,15 +10539,15 @@
 do
-echo "configure:10555: checking for $ac_hdr" >&5
+echo "configure:10543: checking for $ac_hdr" >&5
-#line 10558 "configure"
+#line 10546 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10551: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10595,15 +10583,15 @@
 do
-echo "configure:10599: checking for $ac_hdr" >&5
+echo "configure:10587: checking for $ac_hdr" >&5
-#line 10602 "configure"
+#line 10590 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10595: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10646,7 +10634,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10650: checking for location of FFMPEG library" >&5
+echo "configure:10638: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10673,13 +10661,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10677: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10665: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec  $LIBS"
-#line 10683 "configure"
+#line 10671 "configure"
@@ -10690,7 +10678,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10709,13 +10697,13 @@
-echo "configure:10713: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10701: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
-#line 10719 "configure"
+#line 10707 "configure"
@@ -10726,7 +10714,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10771,13 +10759,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10775: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10763: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat  $LIBS"
-#line 10781 "configure"
+#line 10769 "configure"
@@ -10788,7 +10776,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10807,13 +10795,13 @@
-echo "configure:10811: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10799: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat -lavutil $MATHLIB $LIBS"
-#line 10817 "configure"
+#line 10805 "configure"
@@ -10824,7 +10812,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10884,7 +10872,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10888: checking whether to use OpenGL" >&5
+echo "configure:10876: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10918,7 +10906,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10922: checking for location of OpenGL includes" >&5
+echo "configure:10910: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10944,15 +10932,15 @@
 do
-echo "configure:10948: checking for $ac_hdr" >&5
+echo "configure:10936: checking for $ac_hdr" >&5
-#line 10951 "configure"
+#line 10939 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10956: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10986,7 +10974,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10990: checking for location of OpenGL library" >&5
+echo "configure:10978: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11015,13 +11003,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11019: checking for glBegin in -lGL" >&5
+echo "configure:11007: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11025 "configure"
+#line 11013 "configure"
@@ -11032,7 +11020,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11051,13 +11039,13 @@
-echo "configure:11055: checking for glBegin in -lGL" >&5
+echo "configure:11043: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11061 "configure"
+#line 11049 "configure"
@@ -11068,7 +11056,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11087,13 +11075,13 @@
-echo "configure:11091: checking for glBegin in -lGL" >&5
+echo "configure:11079: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11097 "configure"
+#line 11085 "configure"
@@ -11104,7 +11092,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11123,13 +11111,13 @@
-echo "configure:11127: checking for glBegin in -lGL" >&5
+echo "configure:11115: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11133 "configure"
+#line 11121 "configure"
@@ -11140,7 +11128,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11202,13 +11190,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11206: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11194: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11212 "configure"
+#line 11200 "configure"
@@ -11219,7 +11207,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11238,13 +11226,13 @@
-echo "configure:11242: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11230: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11248 "configure"
+#line 11236 "configure"
@@ -11255,7 +11243,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11299,10 +11287,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11303: checking for glXCreatePbuffer" >&5
+echo "configure:11291: checking for glXCreatePbuffer" >&5
-#line 11306 "configure"
+#line 11294 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11325,7 +11313,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11347,10 +11335,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11351: checking for glXCreateGLXPixmap" >&5
+echo "configure:11339: checking for glXCreateGLXPixmap" >&5
-#line 11354 "configure"
+#line 11342 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11373,7 +11361,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11412,7 +11400,7 @@
-echo "configure:11416: checking for location of OpenGL includes" >&5
+echo "configure:11404: checking for location of OpenGL includes" >&5
@@ -11438,15 +11426,15 @@
 do
-echo "configure:11442: checking for $ac_hdr" >&5
+echo "configure:11430: checking for $ac_hdr" >&5
-#line 11445 "configure"
+#line 11433 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11481,10 +11469,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11485: checking for glBegin" >&5
+echo "configure:11473: checking for glBegin" >&5
-#line 11488 "configure"
+#line 11476 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11507,7 +11495,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11522,10 +11510,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11526: checking for gluBeginCurve" >&5
+echo "configure:11514: checking for gluBeginCurve" >&5
-#line 11529 "configure"
+#line 11517 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11548,7 +11536,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11594,7 +11582,7 @@
-echo "configure:11598: checking for location of OpenGL includes" >&5
+echo "configure:11586: checking for location of OpenGL includes" >&5
@@ -11620,15 +11608,15 @@
 do
-echo "configure:11624: checking for $ac_hdr" >&5
+echo "configure:11612: checking for $ac_hdr" >&5
-#line 11627 "configure"
+#line 11615 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11662,7 +11650,7 @@
-echo "configure:11666: checking for location of OpenGL library" >&5
+echo "configure:11654: checking for location of OpenGL library" >&5
@@ -11685,33 +11673,33 @@
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11689: checking for OpenGL library" >&5
+echo "configure:11677: checking for OpenGL library" >&5
 LIBS="-lopengl32"
-#line 11692 "configure"
+#line 11680 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
 OPENGLLIB=-lopengl32
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11705: checking for GLU library" >&5
+echo "configure:11693: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB"
-#line 11708 "configure"
+#line 11696 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11762,7 +11750,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11766: checking whether to use ODBC" >&5
+echo "configure:11754: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11781,7 +11769,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11785: checking for location of ODBC includes" >&5
+echo "configure:11773: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11807,15 +11795,15 @@
 do
-echo "configure:11811: checking for $ac_hdr" >&5
+echo "configure:11799: checking for $ac_hdr" >&5
-#line 11814 "configure"
+#line 11802 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11807: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11849,7 +11837,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11853: checking for location of ODBC library" >&5
+echo "configure:11841: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11874,13 +11862,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11878: checking for SQLConnect in -lodbc" >&5
+echo "configure:11866: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11884 "configure"
+#line 11872 "configure"
@@ -11891,7 +11879,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11916,13 +11904,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11920: checking for SQLConnect in -liodbc" >&5
+echo "configure:11908: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11926 "configure"
+#line 11914 "configure"
 #include "confdefs.h"
@@ -11933,7 +11921,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11982,7 +11970,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11986: checking whether to use FFTW" >&5
+echo "configure:11974: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12001,7 +11989,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12005: checking for location of FFTW includes" >&5
+echo "configure:11993: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12027,15 +12015,15 @@
 do
-echo "configure:12031: checking for $ac_hdr" >&5
+echo "configure:12019: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12034 "configure"
+#line 12022 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12063,15 +12051,15 @@
 do
-echo "configure:12067: checking for $ac_hdr" >&5
+echo "configure:12055: checking for $ac_hdr" >&5
-#line 12070 "configure"
+#line 12058 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12099,15 +12087,15 @@
 do
-echo "configure:12103: checking for $ac_hdr" >&5
+echo "configure:12091: checking for $ac_hdr" >&5
-#line 12106 "configure"
+#line 12094 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12153,7 +12141,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12157: checking for location of FFTW library" >&5
+echo "configure:12145: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12178,13 +12166,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12182: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12170: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12188 "configure"
+#line 12176 "configure"
@@ -12195,7 +12183,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12220,13 +12208,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12224: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12212: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12230 "configure"
+#line 12218 "configure"
@@ -12237,7 +12225,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12262,13 +12250,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12266: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12254: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12272 "configure"
+#line 12260 "configure"
@@ -12279,7 +12267,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12336,7 +12324,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12340: checking whether to use BLAS" >&5
+echo "configure:12328: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12357,7 +12345,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12361: checking for location of BLAS includes" >&5
+echo "configure:12349: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12377,7 +12365,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12381: checking for location of BLAS library" >&5
+echo "configure:12369: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12403,15 +12391,15 @@
 do
-echo "configure:12407: checking for $ac_hdr" >&5
+echo "configure:12395: checking for $ac_hdr" >&5
-#line 12410 "configure"
+#line 12398 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12446,13 +12434,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12450: checking for dnrm2_ in -lblas" >&5
+echo "configure:12438: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12456 "configure"
+#line 12444 "configure"
@@ -12463,7 +12451,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12482,13 +12470,13 @@
-echo "configure:12486: checking for dnrm2_ in -lblas" >&5
+echo "configure:12474: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12492 "configure"
+#line 12480 "configure"
@@ -12499,7 +12487,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12543,13 +12531,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12547: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12535: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12553 "configure"
+#line 12541 "configure"
@@ -12560,7 +12548,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12575,13 +12563,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12579: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12567: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12585 "configure"
+#line 12573 "configure"
@@ -12592,7 +12580,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12607,13 +12595,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12611: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12599: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12617 "configure"
+#line 12605 "configure"
@@ -12624,7 +12612,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12669,16 +12657,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12673: checking for sgemm in $vlib_flags" >&5
+echo "configure:12661: checking for sgemm in $vlib_flags" >&5
-#line 12675 "configure"
+#line 12663 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12696,13 +12684,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12700: checking for sgemm_ in -lblas" >&5
+echo "configure:12688: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12706 "configure"
+#line 12694 "configure"
@@ -12713,7 +12701,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12728,13 +12716,13 @@
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12732: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12720: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12738 "configure"
+#line 12726 "configure"
@@ -12745,7 +12733,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12760,13 +12748,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12764: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12752: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12770 "configure"
+#line 12758 "configure"
@@ -12777,7 +12765,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12811,13 +12799,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12815: checking for acosp in -lsunmath" >&5
+echo "configure:12803: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lsunmath  $LIBS"
-#line 12821 "configure"
+#line 12809 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12828,7 +12816,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12843,13 +12831,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12847: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12835: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12853 "configure"
+#line 12841 "configure"
@@ -12860,7 +12848,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12890,13 +12878,13 @@
 # Generic BLAS library
-echo "configure:12894: checking for sgemm_ in -lblas" >&5
+echo "configure:12882: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12900 "configure"
+#line 12888 "configure"
@@ -12907,7 +12895,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12946,7 +12934,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12950: checking whether to use LAPACK" >&5
+echo "configure:12938: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12971,7 +12959,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12975: checking for location of LAPACK includes" >&5
+echo "configure:12963: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12991,7 +12979,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12995: checking for location of LAPACK library" >&5
+echo "configure:12983: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13017,15 +13005,15 @@
 do
-echo "configure:13021: checking for $ac_hdr" >&5
+echo "configure:13009: checking for $ac_hdr" >&5
-#line 13024 "configure"
+#line 13012 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13017: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13057,10 +13045,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13061: checking for dsegv_" >&5
+echo "configure:13049: checking for dsegv_" >&5
-#line 13064 "configure"
+#line 13052 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13083,7 +13071,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13110,13 +13098,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13114: checking for desgv_ in -llapack" >&5
+echo "configure:13102: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13120 "configure"
+#line 13108 "configure"
@@ -13127,7 +13115,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13159,13 +13147,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13163: checking for dgesv_ in -llapack" >&5
+echo "configure:13151: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13169 "configure"
+#line 13157 "configure"
@@ -13176,7 +13164,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13195,13 +13183,13 @@
-echo "configure:13199: checking for dgesv_ in -llapack" >&5
+echo "configure:13187: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13205 "configure"
+#line 13193 "configure"
@@ -13212,7 +13200,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13268,7 +13256,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13272: checking whether to use Motif" >&5
+echo "configure:13260: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13287,7 +13275,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13291: checking for location of Motif includes" >&5
+echo "configure:13279: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13313,15 +13301,15 @@
 do
-echo "configure:13317: checking for $ac_hdr" >&5
+echo "configure:13305: checking for $ac_hdr" >&5
-#line 13320 "configure"
+#line 13308 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13355,7 +13343,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13359: checking for location of Motif library" >&5
+echo "configure:13347: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13380,13 +13368,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13384: checking for XmStringCreate in -lXm" >&5
+echo "configure:13372: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13390 "configure"
+#line 13378 "configure"
@@ -13397,7 +13385,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13438,7 +13426,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13442: checking whether to use GLw" >&5
+echo "configure:13430: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13457,7 +13445,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13461: checking for location of GLw includes" >&5
+echo "configure:13449: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13483,15 +13471,15 @@
 do
-echo "configure:13487: checking for $ac_hdr" >&5
+echo "configure:13475: checking for $ac_hdr" >&5
-#line 13490 "configure"
+#line 13478 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13483: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13519,15 +13507,15 @@
 do
-echo "configure:13523: checking for $ac_hdr" >&5
+echo "configure:13511: checking for $ac_hdr" >&5
-#line 13526 "configure"
+#line 13514 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13519: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13567,7 +13555,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13571: checking for location of GLw library" >&5
+echo "configure:13559: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13592,13 +13580,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13596: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13584: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13602 "configure"
+#line 13590 "configure"
@@ -13609,7 +13597,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13634,13 +13622,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13638: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13626: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13644 "configure"
+#line 13632 "configure"
@@ -13651,7 +13639,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13676,13 +13664,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13680: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13668: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13686 "configure"
+#line 13674 "configure"
@@ -13693,7 +13681,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13718,13 +13706,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13722: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13710: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13728 "configure"
+#line 13716 "configure"
@@ -13735,7 +13723,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13760,13 +13748,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13764: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13752: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13770 "configure"
+#line 13758 "configure"
@@ -13777,7 +13765,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13802,13 +13790,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13806: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13794: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13812 "configure"
+#line 13800 "configure"
@@ -13819,7 +13807,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13846,13 +13834,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:13850: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13838: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13856 "configure"
+#line 13844 "configure"
@@ -13863,7 +13851,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13882,13 +13870,13 @@
-echo "configure:13886: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13874: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13892 "configure"
+#line 13880 "configure"
@@ -13899,7 +13887,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13926,13 +13914,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:13930: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13918: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13936 "configure"
+#line 13924 "configure"
@@ -13943,7 +13931,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13962,13 +13950,13 @@
-echo "configure:13966: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13954: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13972 "configure"
+#line 13960 "configure"
@@ -13979,7 +13967,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14092,7 +14080,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14096: checking whether to use FreeType" >&5
+echo "configure:14084: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14111,7 +14099,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14115: checking for location of FreeType includes" >&5
+echo "configure:14103: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14137,15 +14125,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14141: checking for $ac_hdr" >&5
+echo "configure:14129: checking for $ac_hdr" >&5
-#line 14144 "configure"
+#line 14132 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14179,7 +14167,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14183: checking for location of FreeType library" >&5
+echo "configure:14171: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14204,13 +14192,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14208: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14196: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14214 "configure"
+#line 14202 "configure"
@@ -14221,7 +14209,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14262,7 +14250,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14266: checking whether to use NLS" >&5
+echo "configure:14254: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14282,10 +14270,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14286: checking for gettext" >&5
+echo "configure:14274: checking for gettext" >&5
-#line 14289 "configure"
+#line 14277 "configure"
     which can conflict with char gettext(); below.  */
@@ -14308,7 +14296,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14326,13 +14314,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14330: checking for gettext in -lintl" >&5
+echo "configure:14318: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14336 "configure"
+#line 14324 "configure"
@@ -14343,7 +14331,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14378,7 +14366,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14382: checking whether to use C++" >&5
+echo "configure:14370: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14394,7 +14382,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14398: checking for $ac_word" >&5
+echo "configure:14386: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14423,7 +14411,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14427: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14415: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14434,12 +14422,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14438 "configure"
+#line 14426 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14465,19 +14453,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14469: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14457: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14474: checking whether we are using GNU C++" >&5
+echo "configure:14462: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14495,7 +14483,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14499: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14487: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14536,7 +14524,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14540: checking whether to use openDWG" >&5
+echo "configure:14528: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14556,7 +14544,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14560: checking for location of openDGW includes" >&5
+echo "configure:14548: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14582,15 +14570,15 @@
 do
-echo "configure:14586: checking for $ac_hdr" >&5
+echo "configure:14574: checking for $ac_hdr" >&5
-#line 14589 "configure"
+#line 14577 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14624,7 +14612,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14628: checking for location of openDWG library" >&5
+echo "configure:14616: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14671,7 +14659,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14675: checking for special C compiler options needed for large files" >&5
+echo "configure:14663: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14679,7 +14667,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14683 "configure"
+#line 14671 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14695,7 +14683,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14699: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14687: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14704,7 +14692,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14708 "configure"
+#line 14696 "configure"
@@ -14720,7 +14708,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14724: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14712: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14740,11 +14728,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14744: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14732: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14748 "configure"
+#line 14736 "configure"
@@ -14760,14 +14748,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14764: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14752: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14771 "configure"
+#line 14759 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14785,7 +14773,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14789: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14777: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14804,11 +14792,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14808: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14796: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14812 "configure"
+#line 14800 "configure"
@@ -14824,14 +14812,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14816: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14835 "configure"
+#line 14823 "configure"
 #define _LARGE_FILES 1
@@ -14849,7 +14837,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14841: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14868,25 +14856,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14872: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14860: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14876 "configure"
+#line 14864 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14883: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14871: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14890 "configure"
+#line 14878 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14895,7 +14883,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14899: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14887: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14916,10 +14904,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14920: checking if system supports Large Files at all" >&5
+echo "configure:14908: checking if system supports Large Files at all" >&5
-#line 14923 "configure"
+#line 14911 "configure"
 #include <stdio.h>
@@ -14951,7 +14939,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14955: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14943: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14981,7 +14969,7 @@
 echo $ac_n "checking whether to use PYTHON""... $ac_c" 1>&6
-echo "configure:14985: checking whether to use PYTHON" >&5
+echo "configure:14973: checking whether to use PYTHON" >&5
 echo "$ac_t"""$with_python"" 1>&6
 case "$with_python" in
 	"no")	USE_PYTHON=	;;
@@ -14999,7 +14987,7 @@
   # Extract the first word of "python", so it can be a program name with args.
 set dummy python; ac_word=$2
-echo "configure:15003: checking for $ac_word" >&5
+echo "configure:14991: checking for $ac_word" >&5
 case "$PYTHON_BIN" in
@@ -15032,7 +15020,7 @@
     # Extract the first word of "python2.3", so it can be a program name with args.
 set dummy python2.3; ac_word=$2
-echo "configure:15036: checking for $ac_word" >&5
+echo "configure:15024: checking for $ac_word" >&5
@@ -15065,7 +15053,7 @@
       # Extract the first word of "python2.4", so it can be a program name with args.
 set dummy python2.4; ac_word=$2
-echo "configure:15069: checking for $ac_word" >&5
+echo "configure:15057: checking for $ac_word" >&5
@@ -15109,7 +15097,7 @@
-echo "configure:15113: checking for $ac_word" >&5
+echo "configure:15101: checking for $ac_word" >&5
@@ -15145,7 +15133,7 @@
 # find out python version
 echo $ac_n "checking Python version""... $ac_c" 1>&6
-echo "configure:15149: checking Python version" >&5
+echo "configure:15137: checking Python version" >&5
 PYVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:3]'`
 PYMAJVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:1]'`
 PYMINVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[2:3]'`
@@ -15164,56 +15152,6 @@
-# wxPython check
-echo $ac_n "checking whether to use wxPython""... $ac_c" 1>&6
-echo "configure:15171: checking whether to use wxPython" >&5
-echo "$ac_t"""$with_wxpython"" 1>&6
-case "$with_wxpython" in
-	"no")	USE_WXPYTHON=	;;
-	"yes")	USE_WXPYTHON="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
-if test -n "$USE_WXPYTHON"; then
-   # Python support required
-   if test -z "$USE_PYTHON"; then
-      { echo "configure: error: *** wxPython requires PYTHON functionality (--with-python)." 1>&2; exit 1; }
-   fi
-   # find out wxPython version
-   echo $ac_n "checking wxPython version""... $ac_c" 1>&6
-echo "configure:15189: checking wxPython version" >&5
-   WXVERSION=`$PYTHON_BIN -c 'import wx; print wx.__version__'`
-   if test -z "$WXVERSION"; then
-      { echo "configure: error: *** couldn't find wxPython." 1>&2; exit 1; }
-   fi
-   WXMAJVERSION=`$PYTHON_BIN -c 'import wx; print wx.__version__[:1]'`
-   WXMINVERSION=`$PYTHON_BIN -c 'import wx; print wx.__version__[2:3]'`
-   echo "$ac_t""$WXVERSION" 1>&6
-   # make sure Python is version >= 2.4
-   if test "$PYMAJVERSION" -lt "2" || \
-      (test "$PYMAJVERSION" -eq "2" && test "$PYMINVERSION" -lt "4"); then
-      { echo "configure: error: *** wxPython functionality requires at least Python version 2.4.
-      The one you have seems to be $PYVERSION.  You can specify an alternate python
-      by using (for example) --with-python=/usr/bin/python2.4" 1>&2; exit 1; }
-   fi
-   # make sure wxPython is version >= 2.8
-   if test "$WXMAJVERSION" -lt "2" || \
-      (test "$WXMAJVERSION" -eq "2" && test "$WXMINVERSION" -lt "8"); then
-        { echo "configure: error: *** This version of GRASS requires at least wxPython version 2.8.
-	The one you have seems to be $WXVERSION." 1>&2; exit 1; }
-   fi
-fi
 USE_TERMIO=
@@ -15474,8 +15412,6 @@
 s%@PYTHON@%$PYTHON%g
 s%@PYVERSION@%$PYVERSION%g
 s%@USE_PYTHON@%$USE_PYTHON%g
-s%@WXVERSION@%$WXVERSION%g
-s%@USE_WXPYTHON@%$USE_WXPYTHON%g
 s%@USE_TERMIO@%$USE_TERMIO%g
 s%@STRIPFLAG@%$STRIPFLAG%g
 s%@GRASS_HOME@%$GRASS_HOME%g
@@ -15797,8 +15733,6 @@
 echo "  Python support:             `if test -n "${USE_PYTHON}" ; then echo yes ; else echo no ; fi`"
-echo "  wxPython support:           `if test -n "${USE_WXPYTHON}" ; then echo yes ; else echo no ; fi`"
 echo "  Readline support:           `if test -n "${USE_READLINE}" ; then echo yes ; else echo no ; fi`"
 echo "  SQLite support:             `if test -n "${USE_SQLITE}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-01-16 13:14:07 UTC (rev 29717)
+++ grass/trunk/configure.in	2008-01-16 13:35:15 UTC (rev 29718)
@@ -193,7 +193,6 @@
 LOC_ARG_WITH(opendwg, openDWG, no)
 LOC_ARG_WITH(curses, Curses, yes)
 LOC_ARG_WITH(python, PYTHON, no)
-LOC_ARG_WITH(wxpython, wxPython, no)
 # With includes and libs options
@@ -672,12 +671,12 @@
 if test "`basename xx/$with_gdal`" = "gdal-config" ; then
   GDAL_CONFIG="$with_gdal"
-  AC_MSG_RESULT(yes)
 fi
 if test "$with_gdal" = "no" ; then
   AC_MSG_RESULT(no)
 else
+  AC_MSG_RESULT(yes)
   AC_PATH_PROG(GDAL_CONFIG, gdal-config, no)
   if test "$GDAL_CONFIG" = "no" ; then
@@ -1638,45 +1637,6 @@
 AC_SUBST(USE_PYTHON)
-# wxPython check
-LOC_CHECK_USE(wxpython, wxPython, USE_WXPYTHON)
-      AC_MSG_ERROR([*** wxPython requires PYTHON functionality (--with-python).])
-   fi
-   AC_MSG_CHECKING(wxPython version)
-   WXVERSION=`$PYTHON_BIN -c ['import wx; print wx.__version__'`]
-      AC_MSG_ERROR([*** couldn't find wxPython.])
-   fi
-   WXMAJVERSION=`$PYTHON_BIN -c ['import wx; print wx.__version__[:1]'`]
-   WXMINVERSION=`$PYTHON_BIN -c ['import wx; print wx.__version__[2:3]'`]
-   AC_MSG_RESULT($WXVERSION)
-   AC_SUBST(WXVERSION)
-      AC_MSG_ERROR([*** wxPython functionality requires at least Python version 2.4.
-      by using (for example) --with-python=/usr/bin/python2.4])
-   fi
-        AC_MSG_ERROR([*** This version of GRASS requires at least wxPython version 2.8.
-	The one you have seems to be $WXVERSION.])
-   fi
-fi
-AC_SUBST(USE_WXPYTHON)
 USE_TERMIO=
 AC_SUBST(USE_TERMIO)
@@ -1734,7 +1694,6 @@
 LOC_MSG_USE(PNG support,USE_PNG)
 LOC_MSG_USE(PostgreSQL support,USE_POSTGRES)
 LOC_MSG_USE(Python support,USE_PYTHON)
-LOC_MSG_USE(wxPython support,USE_WXPYTHON)
 LOC_MSG_USE(Readline support,USE_READLINE)
 LOC_MSG_USE(SQLite support,USE_SQLITE)
 LOC_MSG_USE(Tcl/Tk support,USE_TCLTK)
