[GRASS-SVN] r29724 - grass/branches/releasebranch_6_3/raster/r.covar
Wed Jan 16 13:36:50 EST 2008
Author: epatton
Date: 2008-01-16 13:36:50 -0500 (Wed, 16 Jan 2008)
New Revision: 29724
   grass/branches/releasebranch_6_3/raster/r.covar/description.html
Standardized section headings
Modified: grass/branches/releasebranch_6_3/raster/r.covar/description.html
--- grass/branches/releasebranch_6_3/raster/r.covar/description.html	2008-01-16 18:36:15 UTC (rev 29723)
+++ grass/branches/releasebranch_6_3/raster/r.covar/description.html	2008-01-16 18:36:50 UTC (rev 29724)
@@ -9,6 +9,24 @@
 The output is an N x N symmetric covariance (correlation) matrix,
 where N is the number of raster map layers specified on the command line.
+<H2>NOTES</H2>
+This module can be used as the first step of a principle components
+transformation.
+The covariance matrix would be input into a system which determines
+eigen values and eigen vectors. An NxN covariance matrix would result in
+N real eigen values and N eigen vectors (each composed of N real numbers).
+<P>
+The module <EM><A HREF="m.eigensystem.html">m.eigensystem</A></EM> in
+src.contrib can be compiled and used to generate the eigen values and
+vectors.
+<H2>EXAMPLE</H2>
 For example,
 <DL>
@@ -24,13 +42,6 @@
      0.889581  0.939452  1.000000
 </PRE>
-<H2>PRINCIPLE COMPONENTS</H2>
-This module can be used as the first step of a principle components
-transformation.
-The covariance matrix would be input into a system which determines
-eigen values and eigen vectors. An NxN covariance matrix would result in
-N real eigen values and N eigen vectors (each composed of N real numbers).
 In the above example, the eigen values and corresponding eigen vectors
 for the covariance matrix are:
@@ -71,12 +82,6 @@
 the desired range (e.g. 0-255).
 This can be done with <EM><A HREF="r.rescale.html">r.rescale</A></EM>.
-<H2>NOTES</H2>
-The module <EM><A HREF="m.eigensystem.html">m.eigensystem</A></EM> in
-src.contrib can be compiled and used to generate the eigen values and
-vectors.
 <H2>SEE ALSO</H2>
 <EM><A HREF="i.pca.html">i.pca</A></EM>,
