[GRASS-SVN] r29881 - grass/trunk/vector/v.hull
Mon Jan 28 08:56:00 EST 2008
Author: neteler
Date: 2008-01-28 08:56:00 -0500 (Mon, 28 Jan 2008)
New Revision: 29881
Added:
   grass/trunk/vector/v.hull/chull.c
   grass/trunk/vector/v.hull/chull.h
   grass/trunk/vector/v.hull/globals.h
   grass/trunk/vector/v.hull/macros.h
   grass/trunk/vector/v.hull/README
Benjamin Ducke: <benjamin.ducke ufg.uni-kiel.de> 3D hull support added using chull.c from Joseph O'Rourke, 1998
Modified: grass/trunk/vector/v.hull/README
--- grass/trunk/vector/v.hull/README	2008-01-28 13:44:17 UTC (rev 29880)
+++ grass/trunk/vector/v.hull/README	2008-01-28 13:56:00 UTC (rev 29881)
@@ -12,3 +12,9 @@
 Andrea Aime <aaime at libero.it> 9/2001
+chull.c
+http://maven.smith.edu/~orourke/books/compgeom.html
+http://maven.smith.edu/~orourke/books/ftp.html
Added: grass/trunk/vector/v.hull/chull.c
--- grass/trunk/vector/v.hull/chull.c	                        (rev 0)
+++ grass/trunk/vector/v.hull/chull.c	2008-01-28 13:56:00 UTC (rev 29881)
@@ -0,0 +1,785 @@
+This code is described in "Computational Geometry in C" (Second Edition),
+Chapter 4.  It is not written to be comprehensible without the
+explanation in that book.
+Input: 3n integer coordinates for the points.
+Output: the 3D convex hull, in postscript with embedded comments
+        showing the vertices and faces.
+Compile: gcc -o chull chull.c
+Written by Joseph O'Rourke, with contributions by
+  Kristy Anderson, John Kutcher, Catherine Schevon, Susan Weller.
+Last modified: March 1998
+Questions to orourke at cs.smith.edu.
+This code is Copyright 1998 by Joseph O'Rourke.  It may be freely
+redistributed in its entirety provided that this copyright notice is
+not removed.
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include "globals.h"
+/*Define Boolean type */
+typedef	enum { BFALSE, BTRUE }	bool;
+/* Define vertex indices. */
+#define X   0
+#define Y   1
+#define Z   2
+/* Define structures for vertices, edges and faces */
+typedef struct tVertexStructure tsVertex;
+typedef tsVertex *tVertex;
+typedef struct tEdgeStructure tsEdge;
+typedef tsEdge *tEdge;
+typedef struct tFaceStructure tsFace;
+typedef tsFace *tFace;
+struct tVertexStructure {
+   double      v[3];
+   int	    vnum;
+   tEdge    duplicate;	        /* pointer to incident cone edge (or NULL) */
+   bool     onhull;		/* T iff point on hull. */
+   bool	    mark;		/* T iff point already processed. */
+   tVertex  next, prev;
+struct tEdgeStructure {
+   tFace    adjface[2];
+   tVertex  endpts[2];
+   tFace    newface;            /* pointer to incident cone face. */
+   bool     delete;		/* T iff edge should be delete. */
+   tEdge    next, prev;
+struct tFaceStructure {
+   tEdge    edge[3];
+   tVertex  vertex[3];
+   bool	    visible;	        /* T iff face visible from new point. */
+   tFace    next, prev;
+/* Define flags */
+#define ONHULL   	BTRUE
+#define REMOVED  	BTRUE
+#define VISIBLE  	BTRUE
+#define PROCESSED	BTRUE
+/* Global variable definitions */
+tVertex vertices = NULL;
+tEdge edges    	 = NULL;
+tFace faces    	 = NULL;
+/* Function declarations */
+tVertex MakeNullVertex( void );
+void    ReadVertices( double *px, double *py, double *pz, int num_points);
+void	writeVertices ( struct Map_info *Map );
+int    DoubleTriangle( void );
+void    ConstructHull( void );
+bool	AddOne( tVertex p );
+int     VolumeSign(tFace f, tVertex p);
+tFace	MakeConeFace( tEdge e, tVertex p );
+void    MakeCcw( tFace f, tEdge e, tVertex p );
+tEdge   MakeNullEdge( void );
+tFace   MakeNullFace( void );
+tFace   MakeFace( tVertex v0, tVertex v1, tVertex v2, tFace f );
+void    CleanUp( void );
+void    CleanEdges( void );
+void    CleanFaces( void );
+void    CleanVertices( void );
+bool	Collinear( tVertex a, tVertex b, tVertex c );
+#include "macros.h"
+	Release all memory allocated for edges, faces and vertices
+void freeMem ( void ) {
+   tEdge  e;	/* Primary index into edge list. */
+   tFace  f;	/* Primary pointer into face list. */
+   tVertex v;
+   tEdge  te;	/* Temporary edge pointer. */
+   tFace  tf;	/* Temporary face pointer. */
+   tVertex  tv;	/* Temporary vertex pointer. */
+   e = edges;
+   do {
+      te = e;
+      e = e->next;
+      DELETE( edges, te );
+   } while ( e != edges );
+   f = faces;
+   do {
+      tf = f;
+      f = f->next;
+      DELETE( faces, tf );
+   } while ( f != faces );
+   v = vertices;
+   do {
+      tv = v;
+      v = v->next;
+      DELETE( vertices, tv );
+   } while ( v != vertices );
+   FREE (te);
+   FREE (tf);
+   FREE (tv);
+   DELETE (edges, e);
+   DELETE (faces, f);
+   DELETE (vertices, v);
+   FREE (edges);
+   FREE (faces);
+   FREE (vertices);
+int make3DHull ( double *px, double *py, double *pz, int num_points, struct Map_info *Map )
+	int error;
+	ReadVertices( px, py, pz, num_points );
+	error = DoubleTriangle();
+	if ( error < 0 ) {
+		G_fatal_error ( "All points of 3D input map are in the same plane.\n  Cannot create a 3D hull." );
+	ConstructHull();
+	writeVertices ( Map );
+	freeMem ();
+	return (0);
+MakeNullVertex: Makes a vertex, nulls out fields.
+   tVertex  v;
+   NEW( v, tsVertex );
+   v->duplicate = NULL;
+   v->onhull = !ONHULL;
+   v->mark = !PROCESSED;
+   ADD( vertices, v );
+   return v;
+ReadVertices: Reads in the vertices, and links them into a circular
+list with MakeNullVertex.  There is no need for the # of vertices to be
+the first line: the function looks for EOF instead.  Sets the global
+variable vertices via the ADD macro.
+void	ReadVertices( double *px, double *py, double *pz, int num_points )
+   tVertex  v;
+   int vnum = 0;
+   int i;
+   G_message ( "Reading 3D vertices:" );
+   for ( i=0; i < num_points; i++ ) {
+      v = MakeNullVertex();
+      v->v[X] = px[i];
+      v->v[Y] = py[i];
+      v->v[Z] = pz[i];
+      v->vnum = vnum++;
+      G_percent (i, (num_points-1), 1);
+   fflush (stdout);
+Outputs the 3D triangles to a GRASS 3d vector map.
+   /* Pointers to vertices, edges, faces. */
+   tVertex  v;
+   tEdge    e;
+   tFace    f;
+   double *px,*py,*pz;
+   double fx,fy,fz;
+   double kx, ky, kz;
+   long int cat, num_faces;
+   struct line_pnts *Points;
+   struct line_cats *Cats;
+   Points = Vect_new_line_struct ();
+   Cats = Vect_new_cats_struct ();
+   px = G_malloc ( sizeof (double) * 4);
+   py = G_malloc ( sizeof (double) * 4);
+   pz = G_malloc ( sizeof (double) * 4);
+   f = faces;
+   num_faces = 0;
+   cat = 0;
+   kx = 0.0;
+   ky = 0.0;
+   kz = 0.0;
+   G_message ( "Writing faces and kernel to output map ..." );
+   do {
+         num_faces ++;
+   	 /* write one triangular face */
+   	 px[0] = ((double) ( f->vertex[0]->v[X] ) );
+	 py[0] = ((double) ( f->vertex[0]->v[Y] ) );
+	 pz[0] = ((double) ( f->vertex[0]->v[Z] ) );
+   	 px[1] = ((double) ( f->vertex[1]->v[X] ) );
+	 py[1] = ((double) ( f->vertex[1]->v[Y] ) );
+	 pz[1] = ((double) ( f->vertex[1]->v[Z] ) );
+   	 px[2] = ((double) ( f->vertex[2]->v[X] ) );
+	 py[2] = ((double) ( f->vertex[2]->v[Y] ) );
+	 pz[2] = ((double) ( f->vertex[2]->v[Z] ) );
+   	 px[3] = ((double) ( f->vertex[0]->v[X] ) );
+	 py[3] = ((double) ( f->vertex[0]->v[Y] ) );
+	 pz[3] = ((double) ( f->vertex[0]->v[Z] ) );
+	 /* kernel position: 1st get 3D center of this face */
+	 fx = ( px[0] + px[1] + px[2] ) / 3.0;
+	 fy = ( py[0] + py[1] + py[2] ) / 3.0;
+	 fz = ( pz[0] + pz[1] + pz[2] ) / 3.0;
+	 /* kernel position: now add this to kernel coordinates */
+	 kx = kx + fx;
+	 ky = ky + fy;
+	 kz = kz + fz;
+	 /* write out face */
+	 Vect_copy_xyz_to_pnts(Points, px, py, pz, 4);
+      	 cat ++;
+	 Vect_cat_set ( Cats, 1, cat );
+      	 Vect_write_line ( Map, GV_FACE, Points, Cats );
+      	 f = f->next;
+   /* write kernel for the center of the whole hull */
+   kx = kx / num_faces;
+   ky = ky / num_faces;
+   kz = kz / num_faces;
+   Vect_cat_set ( Cats, 1, cat + 1 );
+   Vect_copy_xyz_to_pnts(Points, &kx, &ky, &kz, 1);
+   Vect_write_line ( Map, GV_KERNEL, Points, Cats );
+   Vect_destroy_line_struct (Points);
+   fflush ( stdout );
+   G_free (px);
+   G_free (py);
+   G_free (pz);
+ DoubleTriangle builds the initial double triangle.  It first finds 3
+ noncollinear points and makes two faces out of them, in opposite order.
+ It then finds a fourth point that is not coplanar with that face.  The
+ vertices are stored in the face structure in counterclockwise order so
+ that the volume between the face and the point is negative. Lastly, the
+ 3 newfaces to the fourth point are constructed and the data structures
+ are cleaned up.
+/* RETURN: 	0 if OK */
+/* 		-1 if all points collinear */
+/*		-2 if all points coplanar */
+   tVertex  v0, v1, v2, v3, t;
+   tFace    f0, f1 = NULL;
+   tEdge    e0, e1, e2, s;
+   long int      vol;
+   /* Find 3 noncollinear points. */
+   v0 = vertices;
+   while ( Collinear( v0, v0->next, v0->next->next ) ) {
+      if ( ( v0 = v0->next ) == vertices ) {
+          	G_warning ("DoubleTriangle:  All points are collinear!\n");
+	  return (-1);
+   v1 = v0->next;
+   v2 = v1->next;
+   /* Mark the vertices as processed. */
+   v0->mark = PROCESSED;
+   v1->mark = PROCESSED;
+   v2->mark = PROCESSED;
+   /* Create the two "twin" faces. */
+   f0 = MakeFace( v0, v1, v2, f1 );
+   f1 = MakeFace( v2, v1, v0, f0 );
+   /* Link adjacent face fields. */
+   f0->edge[0]->adjface[1] = f1;
+   f0->edge[1]->adjface[1] = f1;
+   f0->edge[2]->adjface[1] = f1;
+   f1->edge[0]->adjface[1] = f0;
+   f1->edge[1]->adjface[1] = f0;
+   f1->edge[2]->adjface[1] = f0;
+   /* Find a fourth, noncoplanar point to form tetrahedron. */
+   v3 = v2->next;
+   vol = VolumeSign( f0, v3 );
+   while ( !vol )   {
+      if ( ( v3 = v3->next ) == v0 ) {
+         	G_warning ("DoubleTriangle:  All points are coplanar!\n");
+	 return (-2);
+   /* Insure that v3 will be the first added. */
+   vertices = v3;
+   return (0);
+ConstructHull adds the vertices to the hull one at a time.  The hull
+vertices are those in the list marked as onhull.
+   tVertex  v, vnext;
+   long int 	    vol;
+   bool	    changed;	/* T if addition changes hull; not used. */
+   int i;
+   int numVertices;
+   G_message ("Constructing 3D hull:");
+   v = vertices;
+   i = 0;
+   do {
+   	vnext = v->next;
+	v = vnext;
+	i ++;
+   numVertices = i;
+   v = vertices;
+   i = 0;
+   do {
+      vnext = v->next;
+      if ( !v->mark ) {
+         v->mark = PROCESSED;
+	 changed = AddOne( v );
+	 CleanUp();
+      v = vnext;
+      i ++;
+      G_percent (i, numVertices, 1);
+   fflush (stdout);
+AddOne is passed a vertex.  It first determines all faces visible from
+that point.  If none are visible then the point is marked as not
+onhull.  Next is a loop over edges.  If both faces adjacent to an edge
+are visible, then the edge is marked for deletion.  If just one of the
+adjacent faces is visible then a new face is constructed.
+   tFace  f;
+   tEdge  e, temp;
+   long int 	  vol;
+   bool	  vis = BFALSE;
+   /* Mark faces visible from p. */
+   f = faces;
+   do {
+      vol = VolumeSign( f, p );
+      if ( vol < 0 ) {
+	 f->visible = VISIBLE;
+	 vis = BTRUE;
+      f = f->next;
+   /* If no faces are visible from p, then p is inside the hull. */
+   if ( !vis ) {
+      p->onhull = !ONHULL;
+      return BFALSE;
+   /* Mark edges in interior of visible region for deletion.
+      Erect a newface based on each border edge. */
+   e = edges;
+   do {
+      temp = e->next;
+      if ( e->adjface[0]->visible && e->adjface[1]->visible )
+	 /* e interior: mark for deletion. */
+	 e->delete = REMOVED;
+      else if ( e->adjface[0]->visible || e->adjface[1]->visible )
+	 /* e border: make a new face. */
+	 e->newface = MakeConeFace( e, p );
+      e = temp;
+   return BTRUE;
+VolumeSign returns the sign of the volume of the tetrahedron determined by f
+and p.  VolumeSign is +1 iff p is on the negative side of f,
+where the positive side is determined by the rh-rule.  So the volume
+is positive if the ccw normal to f points outside the tetrahedron.
+The final fewer-multiplications form is due to Bob Williamson.
+int  VolumeSign( tFace f, tVertex p )
+   double  vol;
+   double  ax, ay, az, bx, by, bz, cx, cy, cz;
+   ax = f->vertex[0]->v[X] - p->v[X];
+   ay = f->vertex[0]->v[Y] - p->v[Y];
+   az = f->vertex[0]->v[Z] - p->v[Z];
+   bx = f->vertex[1]->v[X] - p->v[X];
+   by = f->vertex[1]->v[Y] - p->v[Y];
+   bz = f->vertex[1]->v[Z] - p->v[Z];
+   cx = f->vertex[2]->v[X] - p->v[X];
+   cy = f->vertex[2]->v[Y] - p->v[Y];
+   cz = f->vertex[2]->v[Z] - p->v[Z];
+   vol =   ax * (by*cz - bz*cy)
+         + ay * (bz*cx - bx*cz)
+         + az * (bx*cy - by*cx);
+   /* The volume should be an integer. */
+   if      ( vol >  0.0 )  return  1;
+   else if ( vol < -0.0 )  return -1;
+   else                    return  0;
+MakeConeFace makes a new face and two new edges between the
+edge and the point that are passed to it. It returns a pointer to
+the new face.
+   tEdge  new_edge[2];
+   tFace  new_face;
+   int 	  i, j;
+   /* Make two new edges (if don't already exist). */
+   for ( i=0; i < 2; ++i )
+      /* If the edge exists, copy it into new_edge. */
+      if ( !( new_edge[i] = e->endpts[i]->duplicate) ) {
+	 /* Otherwise (duplicate is NULL), MakeNullEdge. */
+	 new_edge[i] = MakeNullEdge();
+	 new_edge[i]->endpts[0] = e->endpts[i];
+	 new_edge[i]->endpts[1] = p;
+	 e->endpts[i]->duplicate = new_edge[i];
+   /* Make the new face. */
+   new_face = MakeNullFace();
+   new_face->edge[0] = e;
+   new_face->edge[1] = new_edge[0];
+   new_face->edge[2] = new_edge[1];
+   MakeCcw( new_face, e, p );
+   /* Set the adjacent face pointers. */
+      for ( j=0; j < 2; ++j )
+	 /* Only one NULL link should be set to new_face. */
+	 if ( !new_edge[i]->adjface[j] ) {
+	    new_edge[i]->adjface[j] = new_face;
+	    break;
+   return new_face;
+MakeCcw puts the vertices in the face structure in counterclock wise
+order.  We want to store the vertices in the same
+order as in the visible face.  The third vertex is always p.
+   tFace  fv;   /* The visible face adjacent to e */
+   int    i;    /* Index of e->endpoint[0] in fv. */
+   tEdge  s;	/* Temporary, for swapping */
+   if  ( e->adjface[0]->visible )
+        fv = e->adjface[0];
+   else fv = e->adjface[1];
+   /* Set vertex[0] & [1] of f to have the same orientation
+      as do the corresponding vertices of fv. */
+   for ( i=0; fv->vertex[i] != e->endpts[0]; ++i )
+   /* Orient f the same as fv. */
+   if ( fv->vertex[ (i+1) % 3 ] != e->endpts[1] ) {
+      f->vertex[0] = e->endpts[1];
+      f->vertex[1] = e->endpts[0];
+   else {
+      f->vertex[0] = e->endpts[0];
+      f->vertex[1] = e->endpts[1];
+      SWAP( s, f->edge[1], f->edge[2] );
+   /* This swap is tricky. e is edge[0]. edge[1] is based on endpt[0],
+      edge[2] on endpt[1].  So if e is oriented "forwards," we
+      need to move edge[1] to follow [0], because it precedes. */
+   f->vertex[2] = p;
+MakeNullEdge creates a new cell and initializes all pointers to NULL
+and sets all flags to off.  It returns a pointer to the empty cell.
+   tEdge  e;
+   NEW( e, tsEdge );
+   e->adjface[0] = e->adjface[1] = e->newface = NULL;
+   e->endpts[0] = e->endpts[1] = NULL;
+   e->delete = !REMOVED;
+   ADD( edges, e );
+   return e;
+MakeNullFace creates a new face structure and initializes all of its
+flags to NULL and sets all the flags to off.  It returns a pointer
+to the empty cell.
+   tFace  f;
+   int    i;
+   NEW( f, tsFace);
+   for ( i=0; i < 3; ++i ) {
+      f->edge[i] = NULL;
+      f->vertex[i] = NULL;
+   f->visible = !VISIBLE;
+   ADD( faces, f );
+   return f;
+MakeFace creates a new face structure from three vertices (in ccw
+order).  It returns a pointer to the face.
+tFace   MakeFace( tVertex v0, tVertex v1, tVertex v2, tFace fold )
+   tFace  f;
+   tEdge  e0, e1, e2;
+   /* Create edges of the initial triangle. */
+   if( !fold ) {
+     e0 = MakeNullEdge();
+     e1 = MakeNullEdge();
+     e2 = MakeNullEdge();
+   else { /* Copy from fold, in reverse order. */
+     e0 = fold->edge[2];
+     e1 = fold->edge[1];
+     e2 = fold->edge[0];
+   e0->endpts[0] = v0;              e0->endpts[1] = v1;
+   e1->endpts[0] = v1;              e1->endpts[1] = v2;
+   e2->endpts[0] = v2;              e2->endpts[1] = v0;
+   /* Create face for triangle. */
+   f = MakeNullFace();
+   f->edge[0]   = e0;  f->edge[1]   = e1; f->edge[2]   = e2;
+   f->vertex[0] = v0;  f->vertex[1] = v1; f->vertex[2] = v2;
+   /* Link edges to face. */
+   e0->adjface[0] = e1->adjface[0] = e2->adjface[0] = f;
+   return f;
+CleanUp goes through each data structure list and clears all
+flags and NULLs out some pointers.  The order of processing
+(edges, faces, vertices) is important.
+   CleanEdges();
+   CleanFaces();
+   CleanVertices();
+CleanEdges runs through the edge list and cleans up the structure.
+If there is a newface then it will put that face in place of the
+visible face and NULL out newface. It also deletes so marked edges.
+   tEdge  t;	/* Temporary edge pointer. */
+   /* Integrate the newface's into the data structure. */
+   /* Check every edge. */
+   e = edges;
+   do {
+      if ( e->newface ) {
+	    e->adjface[0] = e->newface;
+	 else	e->adjface[1] = e->newface;
+	 e->newface = NULL;
+      e = e->next;
+   /* Delete any edges marked for deletion. */
+   while ( edges && edges->delete ) {
+      e = edges;
+      DELETE( edges, e );
+   e = edges->next;
+   do {
+      if ( e->delete ) {
+	 t = e;
+	 e = e->next;
+	 DELETE( edges, t );
+      else e = e->next;
+CleanFaces runs through the face list and deletes any face marked visible.
+   tFace  t;	/* Temporary pointer, for deleting. */
+   while ( faces && faces->visible ) {
+      f = faces;
+      DELETE( faces, f );
+   f = faces->next;
+   do {
+      if ( f->visible ) {
+	 t = f;
+	 f = f->next;
+	 DELETE( faces, t );
+      else f = f->next;
+CleanVertices runs through the vertex list and deletes the
+vertices that are marked as processed but are not incident to any
+undeleted edges.
+   tEdge    e;
+   tVertex  v, t;
+   /* Mark all vertices incident to some undeleted edge as on the hull. */
+   e = edges;
+   do {
+      e->endpts[0]->onhull = e->endpts[1]->onhull = ONHULL;
+      e = e->next;
+   } while (e != edges);
+   /* Delete all vertices that have been processed but
+      are not on the hull. */
+   while ( vertices && vertices->mark && !vertices->onhull ) {
+      v = vertices;
+      DELETE( vertices, v );
+   v = vertices->next;
+   do {
+      if ( v->mark && !v->onhull ) {
+	 t = v;
+	 v = v->next;
+	 DELETE( vertices, t )
+      else v = v->next;
+   /* Reset flags. */
+   v = vertices;
+   do {
+      v = v->next;
+Collinear checks to see if the three points given are collinear,
+by checking to see if each element of the cross product is zero.
+   return
+         ( c->v[Z] - a->v[Z] ) * ( b->v[Y] - a->v[Y] ) -
+         ( b->v[Z] - a->v[Z] ) * ( c->v[Y] - a->v[Y] ) == 0
+      && ( b->v[Z] - a->v[Z] ) * ( c->v[X] - a->v[X] ) -
+         ( b->v[X] - a->v[X] ) * ( c->v[Z] - a->v[Z] ) == 0
+      && ( b->v[X] - a->v[X] ) * ( c->v[Y] - a->v[Y] ) -
+         ( b->v[Y] - a->v[Y] ) * ( c->v[X] - a->v[X] ) == 0  ;
Property changes on: grass/trunk/vector/v.hull/chull.c
___________________________________________________________________
   + native
Added: grass/trunk/vector/v.hull/chull.h
--- grass/trunk/vector/v.hull/chull.h	                        (rev 0)
+++ grass/trunk/vector/v.hull/chull.h	2008-01-28 13:56:00 UTC (rev 29881)
@@ -0,0 +1,3 @@
+int make3DHull ( double *X, double *Y, double *Z, int num_points, struct Map_info *Map );
Property changes on: grass/trunk/vector/v.hull/chull.h
   + native
Added: grass/trunk/vector/v.hull/globals.h
--- grass/trunk/vector/v.hull/globals.h	                        (rev 0)
+++ grass/trunk/vector/v.hull/globals.h	2008-01-28 13:56:00 UTC (rev 29881)
@@ -0,0 +1,27 @@
+#define PROGVERSION 0.10
+#define PROGNAME "v.hull"
+/* if DEBUG > 1 we will dump even more details */
+#define DEBUG 0
+/* NULL valued cells */
+#define NULLVALUE -1
+/* masked cells */
+#define MASKVALUE -2
+/* unset cells */
+#define UNSET -3
+/* value to represent NULL in VTK files */
+#define DNULLVALUE -99999.99
+#define TMPFILE "voxeltmp.tmp"
+/* number of decimal places with which coordinates are stored */
+double PRECISION;
+/* verbose output includes progress display */
+int VERBOSE;
+/* number of DEMs in the input */
+int NSLICES;
Property changes on: grass/trunk/vector/v.hull/globals.h
   + native
Added: grass/trunk/vector/v.hull/macros.h
--- grass/trunk/vector/v.hull/macros.h	                        (rev 0)
+++ grass/trunk/vector/v.hull/macros.h	2008-01-28 13:56:00 UTC (rev 29881)
@@ -0,0 +1,39 @@
+    macros.h
+ 	macros used to access data structures and perform quick tests.
+/* general-purpose macros */
+#define SWAP(t,x,y)	{ t = x; x = y; y = t; }
+#define NEW(p,type)	if ((p=(type *) malloc (sizeof(type))) == NULL) {\
+				printf ("Out of Memory!\n");\
+				exit(0);\
+#define FREE(p)		if (p) { free ((char *) p); p = NULL; }
+#define ADD( head, p )  if ( head )  { \
+				p->next = head; \
+				p->prev = head->prev; \
+				head->prev = p; \
+				p->prev->next = p; \
+			else { \
+				head = p; \
+				head->next = head->prev = p; \
+#define DELETE( head, p ) if ( head )  { \
+				if ( head == head->next ) \
+					head = NULL;  \
+				else if ( p == head ) \
+					head = head->next; \
+				p->next->prev = p->prev;  \
+				p->prev->next = p->next;  \
+				FREE( p ); \
Property changes on: grass/trunk/vector/v.hull/macros.h
   + native
