[GRASS-SVN] r29919 - grass/branches/releasebranch_6_3/raster/r.compress
Thu Jan 31 22:38:08 EST 2008
Author: epatton
Date: 2008-01-31 22:38:08 -0500 (Thu, 31 Jan 2008)
New Revision: 29919
   grass/branches/releasebranch_6_3/raster/r.compress/description.html
Updated old terminology and module descriptions; standardized section headings
Modified: grass/branches/releasebranch_6_3/raster/r.compress/description.html
--- grass/branches/releasebranch_6_3/raster/r.compress/description.html	2008-02-01 03:25:50 UTC (rev 29918)
+++ grass/branches/releasebranch_6_3/raster/r.compress/description.html	2008-02-01 03:38:08 UTC (rev 29919)
@@ -1,6 +1,5 @@
 <H2>DESCRIPTION</H2>
 The GRASS program <EM>r.compress</EM> can be used to compress and decompress
 raster map layers.
@@ -13,11 +12,12 @@
 reduced in size. Some raster map layers are shrunk to
 roughly 1% of their original sizes.  Raster map layers
 containing complex images such as elevation and photo or
-satellite images may increase slightly in size. GRASS uses
-a new compressed format, and all new raster maps are now
-automatically stored in compressed form (see FORMATS
-below).  GRASS programs can read both compressed and
-regular (uncompressed) file formats.  This allows the use
+satellite images may increase slightly in size.
+<!-- The 'new compressed format' probably isn't new anymore as of 2008. - EP
+GRASS uses a new compressed format, -->
+All new raster maps are now automatically stored in compressed
+form (see FORMATS below).  GRASS programs can read both compressed
+and regular (uncompressed) file formats.  This allows the use
 of whichever raster data format consumes less space.
 <P>
@@ -30,14 +30,13 @@
 <P>
 Raster files may be decompressed to return them to their
-original format, using the <B>-u</B> option of
+original format, using the <B>-u</B> flag of
 <EM>r.compress</EM>. If <EM>r.compress</EM> is asked to
 compress a raster map which is already compressed (or to
-decompress an already decompressed file), it simply informs
-the user of this and asks the user if he wishes to perform
-the reverse operation.
+decompress an already decompressed raster map), it simply informs
+the user the map is already (de)compressed and exits.
-<H2>PROGRAM OPTIONS</H2>
+<H2>NOTES</H2>
 <EM>r.compress</EM> can be run either non-interactively or
 interactively.  In non-interactive use, the user must
@@ -45,26 +44,11 @@
 compressed (or decompressed) on the command line, using the
 form <B>map=</B><EM>name</EM>[,<EM>name</EM>,...] (where
 each <EM>name</EM> is the name of a raster map layer to be
-compressed or decompressed). To decompress a map, the user
-must include the <B>-u</B> option on the command line. If
-the <B>-u</B> option is not included on the command line,
-<EM>r.compress</EM> will attempt to compress the named map
-layer(s).
+compressed or decompressed). The default behavior is to
+compress the named map(s).
-<P>
+<H3>FORMATS</H3>
-If the user simply types <B>r.compress</B> without specifying any
-map layer name(s) on the command line,
-<EM>r.compress</EM> will prompt the user for the names of the map layers
-to be compressed/decompressed, and ask whether these maps are to be
-compressed or decompressed.
-<P>
-If the <B>-u</B> flag is set, <EM>r.compress</EM> converts a compressed map
-to its <EM>uncompressed</EM> format.  If not set, <EM>r.compress</EM> will
-attempt to compress the named map layer(s).
-<H2>FORMATS</H2>
 Conceptually, a raster data file consists of rows of cells,
 with each row containing the same number of cells.  A cell
 consists of one or more bytes.  The number of bytes per
@@ -103,7 +87,7 @@
 automatically used when new raster map layers are
 created).
-<H3>PRE-3.0 FORMAT:</H3>
+<H4>PRE-3.0 FORMAT:</H4>
 First 3 bytes (chars) - These are a special code that identifies
 the raster data as compressed.
@@ -124,7 +108,7 @@
 255) of the number of cells that contain the category
 values given by the remaining bytes of the group.
-<H3>POST-3.0 FORMAT:</H3>
+<H4>POST-3.0 FORMAT:</H4>
 The 3 byte code is not used.
 Instead, a field in the cell header is used to indicate compressed format.
