[GRASS-SVN] r31939 - grass/trunk/gui/wxpython/gui_modules
    svn_grass at osgeo.org
    Tue Jul  1 17:11:23 EDT 2008
Author: martinl
Date: 2008-07-01 17:11:22 -0400 (Tue, 01 Jul 2008)
New Revision: 31939
Added:
   grass/trunk/gui/wxpython/gui_modules/nviz.py
nviz2/wxGUI: missing nviz module added
Added: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-01 21:11:22 UTC (rev 31939)
@@ -0,0 +1,1319 @@
+ at package nviz.py
+ at brief 2.5/3D visialization mode for Map Display Window
+List of classes:
+ - GLWindow
+ - NvizToolWindow
+ - ViewPositionWindow
+(C) 2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+import os
+import sys
+import time
+from threading import Thread
+import wx
+import wx.lib.colourselect as csel
+try:
+    from wx import glcanvas
+    haveGLCanvas = True
+except ImportError:
+    haveGLCanvas = False
+try:
+    from OpenGL.GL import *
+    from OpenGL.GLUT import *
+    haveOpenGL = True
+    haveOpenGL = False
+import globalvar
+import gcmd
+import gselect
+from debug import Debug as Debug
+from mapdisp import MapWindow as MapWindow
+from preferences import globalSettings as UserSettings
+try:
+    nvizPath = os.path.join(globalvar.ETCWXDIR, "nviz")
+    sys.path.append(nvizPath)
+    import grass6_wxnviz as wxnviz
+    haveNviz = True
+    haveNviz = False
+class GLWindow(MapWindow, glcanvas.GLCanvas):
+    """OpenGL canvas for Map Display Window"""
+    def __init__(self, parent, id,
+                 pos=wx.DefaultPosition,
+                 size=wx.DefaultSize,
+                 style=wx.NO_FULL_REPAINT_ON_RESIZE,
+                 Map=None, tree=None, gismgr=None):
+        self.parent = parent # MapFrame
+        self.Map = Map
+        self.tree = tree
+        self.gismgr = gismgr
+        glcanvas.GLCanvas.__init__(self, parent, id)
+        MapWindow.__init__(self, parent, id, pos, size, style,
+                           Map, tree, gismgr)
+        # attribList=[wx.WX_GL_RGBA, wx.GLX_RED_SIZE, 1,
+        #             wx.GLX_GREEN_SIZE, 1,
+        #             wx.GLX_BLUE_SIZE, 1,
+        #             wx.GLX_DEPTH_SIZE, 1,
+        #             None])
+        self.init = False
+        # create nviz instance
+        self.nvizClass = wxnviz.Nviz()
+        # set current display
+        self.nvizClass.SetDisplay(self)
+        # set default lighting model
+        self.nvizClass.SetLightsDefault()
+        # initialize mouse position
+        self.lastX = self.x = 30
+        self.lastY = self.y = 30
+        # default values
+        self.view = UserSettings.Get(group='nviz', key='view') # reference
+        self.update = {} # update view/controls
+        self.object = {} # loaded data objects (layer index / gsurf id)
+        self.size = None
+        self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
+        self.Bind(wx.EVT_SIZE, self.OnSize)
+        self.Bind(wx.EVT_PAINT, self.OnPaint)
+        self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
+        self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp)
+        self.Bind(wx.EVT_MOTION, self.OnMouseAction)
+        self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
+    def OnEraseBackground(self, event):
+        pass # do nothing, to avoid flashing on MSW
+    def OnSize(self, event):
+        self.size = self.parent.GetClientSize()
+        if self.GetContext():
+            Debug.msg(3, "GLCanvas.OnPaint(): w=%d, h=%d" % \
+                      (self.size.width, self.size.height))
+            self.SetCurrent()
+            self.nvizClass.ResizeWindow(self.size.width,
+                                        self.size.height)
+        event.Skip()
+    def OnPaint(self, event):
+        Debug.msg(3, "GLCanvas.OnPaint()")
+        dc = wx.PaintDC(self)
+        self.SetCurrent()
+        if not self.init:
+            self.nvizClass.InitView()
+            self.LoadDataLayers()
+            self.view['z-exag']['value'], \
+                self.view['height']['value'] = self.nvizClass.SetViewDefault()
+            if hasattr(self.parent, "nvizToolWin"):
+                self.parent.nvizToolWin.UpdatePage('view')
+                self.parent.nvizToolWin.UpdateSettings()
+            self.init = True
+        self.UpdateMap()
+    def OnMouseAction(self, event):
+        # change position
+        if event.Dragging() and event.LeftIsDown():
+            self.lastX = self.lastY = self.x = self.y
+            self.x, self.y = event.GetPosition()
+            self.Refresh(False)
+        # change perspective with mouse wheel
+        wheel = event.GetWheelRotation()
+        if wheel != 0:
+            current  = event.GetPositionTuple()[:]
+            Debug.msg (5, "GLWindow.OnMouseMotion(): wheel=%d" % wheel)
+            if wheel > 0:
+                value = -1 * self.view['persp']['step']
+            else:
+                value = self.view['persp']['step']
+            self.view['persp']['value'] += value
+            if self.view['persp']['value'] < 0:
+                self.view['persp']['value'] = 0
+            elif self.view['persp']['value'] > 100:
+                self.view['persp']['value'] = 100
+            self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
+                                   self.view['height']['value'],
+                                   self.view['persp']['value'],
+                                   self.view['twist']['value'])
+            # redraw map
+            self.OnPaint(None)
+            # update statusbar
+            ### self.parent.StatusbarUpdate()
+    def OnLeftDown(self, event):
+        self.CaptureMouse()
+        self.x, self.y = self.lastX, self.lastY = event.GetPosition()
+    def OnLeftUp(self, event):
+        self.ReleaseMouse()
+    def UpdateMap(self, render=False):
+        Updates the canvas anytime there is a change to the
+        underlaying images or to the geometry of the canvas.
+        render:
+         - None do not render (todo)
+         - True render
+         - False quick render
+        @param render re-render map composition
+        start = time.clock()
+        self.resize = False
+        # if self.size is None:
+        #    self.size = self.GetClientSize()
+        #         w, h = self.size
+        #         w = float(max(w, 1.0))
+        #         h = float(max(h, 1.0))
+        #         d = float(min(w, h))
+        #         xScale = d / w
+        #         yScale = d / h
+        # print w, h, d, xScale, yScale
+        # print self.y, self.lastY, self.x, self.lastX
+        # print (self.y - self.lastY) * yScale, (self.x - self.lastX) * xScale
+        # print self.x * xScale
+        #glRotatef((self.y - self.lastY) * yScale, 1.0, 0.0, 0.0);
+        #glRotatef((self.x - self.lastX) * xScale, 0.0, 1.0, 0.0);
+        if render is not None:
+            self.parent.onRenderGauge.Show()
+            if self.parent.onRenderGauge.GetRange() > 0:
+                self.parent.onRenderGauge.SetValue(1)
+                self.parent.onRenderTimer.Start(100)
+            self.parent.onRenderCounter = 0
+        if 'view' in self.update.keys():
+            del self.update['view']
+        if 'z-exag' in self.update.keys():
+            self.nvizClass.SetZExag(self.view['z-exag']['value'])
+            del self.update['z-exag']
+        #         if render is True:
+        #             self.nvizClass.Draw(False)
+        #         elif render is False:
+        #             self.nvizClass.Draw(True) # quick
+        self.nvizClass.Draw(False)
+        self.SwapBuffers()
+        stop = time.clock()
+        # hide process bar
+            self.parent.onRenderTimer.Stop()
+        self.parent.onRenderGauge.Hide()
+        ### self.Map.SetRegion()
+        # self.parent.StatusbarUpdate()
+        Debug.msg(3, "GLWindow.UpdateMap(): render=%s, -> time=%g" % \
+                      (render, (stop-start)))
+    def EraseMap(self):
+        Erase the canvas
+        self.nvizClass.EraseMap()
+    def LoadDataLayers(self):
+        """Load raster/vector from current layer tree
+        @todo volumes
+        for raster in self.Map.GetListOfLayers(l_type='raster', l_active=True):
+            id = self.nvizClass.LoadRaster(str(raster.name), None, None)
+            # set resolution
+            res = UserSettings.Get(group='nviz', key='surface',
+                                   subkey=['draw', 'res-fine'])
+            wire = UserSettings.Get(group='nviz', key='surface',
+                                    subkey=['draw', 'res-coarse'])
+            self.nvizClass.SetSurfaceRes(id, res, wire)
+            self.object[self.Map.GetLayerIndex(raster)] = id
+    def Reset(self):
+        """Reset (unload data)"""
+        self.nvizClass.Reset()
+        self.init = False
+    def ZoomToMap(self, event):
+        Set display extents to match selected raster
+        or vector map or volume.
+        @todo vector, volume
+        layer = self.GetSelectedLayer()
+        if layer is None:
+            return
+        Debug.msg (3, "GLWindow.ZoomToMap(): layer=%s, type=%s" % \
+                       (layer.name, layer.type))
+        self.nvizClass.SetViewportDefault()
+    def ResetView(self):
+        """Reset to default view"""
+        self.view['pos']['x'] = wxnviz.VIEW_DEFAULT_POS_X
+        self.view['pos']['y'] = wxnviz.VIEW_DEFAULT_POS_Y
+        self.view['persp']['value'] = wxnviz.VIEW_DEFAULT_PERSP
+        self.view['twist']['value'] = wxnviz.VIEW_DEFAULT_TWIST
+        self.update['view'] = None
+        self.update['z-exag'] = None
+    def GetMapObjId(self, layer):
+        """Get map object id of given map layer (2D)
+        @param layer MapLayer instance
+        index = self.Map.GetLayerIndex(layer)
+        try:
+            return self.object[index]
+        except:
+            return -1
+    def SetLayerSettings(self, data):
+        """Set settings for selected layer
+        @param data settings
+        @return 1 on success
+        @return 0 on failure
+        # get currently selected map layer
+        if not self.tree or not self.tree.GetSelection():
+            return 0
+        item = self.tree.GetSelection()
+        try:
+            self.tree.SetPyData(item)[0]['nviz'] = data
+        except:
+            return 0
+        return 1
+class NvizToolWindow(wx.Frame):
+    """Experimental window for Nviz tools
+    @todo integrate with Map display
+    def __init__(self, parent=None, id=wx.ID_ANY, title=_("Nviz tools"),
+                 pos=wx.DefaultPosition, size=wx.DefaultSize,
+                 style=wx.DEFAULT_FRAME_STYLE, mapWindow=None):
+        self.mapWindow = mapWindow
+        self.settings = mapWindow.view # GLWindow.view
+        wx.Frame.__init__(self, parent, id, title, pos, size, style)
+        # dialog body
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        self.win = {} # window ids
+        # notebook
+        self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        self.__createViewPage()
+        self.__createSurfacePage()
+        self.UpdatePage('surface')
+        mainSizer.Add(item=self.notebook, proportion=1,
+                      flag=wx.EXPAND | wx.ALL, border=5)
+        # button (see menuform)
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnApply = wx.Button(self, wx.ID_APPLY)
+        btnSave = wx.Button(self, wx.ID_SAVE)
+        btnSave.SetDefault()
+        # bindings
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+        btnApply.SetToolTipString(_("Apply changes for this session"))
+        btnApply.SetDefault()
+        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+        btnSave.SetToolTipString(_("Close dialog and save changes to user settings file"))
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnClose)
+        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+        # sizer
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(btnApply)
+        btnSizer.AddButton(btnCancel)
+        btnSizer.AddButton(btnSave)
+        btnSizer.Realize()
+        mainSizer.Add(item=btnSizer, proportion=0, flag=wx.ALIGN_CENTER | wx.ALL,
+                      border=5)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+    def __createViewPage(self):
+        """Create view settings page"""
+        panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
+        self.notebook.AddPage(page=panel,
+                              text=" %s " % _("View"))
+        pageSizer = wx.BoxSizer(wx.VERTICAL)
+        gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
+        self.win['view'] = {}
+        # position
+        posSizer = wx.GridBagSizer(vgap=3, hgap=3)
+        posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("W")),
+                     pos=(1, 0), flag=wx.ALIGN_CENTER)
+        posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("N")),
+                     pos=(0, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_BOTTOM)
+        viewPos = ViewPositionWindow(panel, id=wx.ID_ANY, size=(175, 175),
+                                     settings=self.settings, mapwindow=self.mapWindow)
+        self.win['view']['pos'] = viewPos.GetId()
+        posSizer.Add(item=viewPos,
+                     pos=(1, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_CENTER_VERTICAL)
+        posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("S")),
+                     pos=(2, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_TOP)
+        posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("E")),
+                     pos=(1, 2), flag=wx.ALIGN_CENTER)
+        gridSizer.Add(item=posSizer, pos=(0, 0))
+        # perspective
+        self.CreateControl(panel, 'persp')
+        gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Perspective:")),
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['slider']), pos=(2, 0))
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['spin']), pos=(3, 0),
+                      flag=wx.ALIGN_CENTER)
+        # twist
+        self.CreateControl(panel, 'twist')
+        gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Twist:")),
+                      pos=(1, 1), flag=wx.ALIGN_CENTER)
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['slider']), pos=(2, 1))
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['spin']), pos=(3, 1),
+        # height + z-exag
+        self.CreateControl(panel, 'height', sliderHor=False)
+        self.CreateControl(panel, 'z-exag', sliderHor=False)
+        heightSizer = wx.GridBagSizer(vgap=3, hgap=3)
+        heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Height:")),
+                      pos=(0, 0), flag=wx.ALIGN_LEFT, span=(1, 2))
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['slider']),
+                        flag=wx.ALIGN_RIGHT, pos=(1, 0))
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['spin']),
+                        flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT | wx.TOP |
+                        wx.BOTTOM | wx.RIGHT, pos=(1, 1))
+        heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Z-exag:")),
+                      pos=(0, 2), flag=wx.ALIGN_LEFT, span=(1, 2))
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['slider']),
+                        flag=wx.ALIGN_RIGHT, pos=(1, 2))
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['spin']),
+                        wx.BOTTOM | wx.RIGHT, pos=(1, 3))
+        gridSizer.Add(item=heightSizer, pos=(0, 1), flag=wx.ALIGN_RIGHT)
+        # view setup + reset
+        viewSizer = wx.BoxSizer(wx.HORIZONTAL)
+        viewSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY,
+                                         label=_("Look at:")),
+                      flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=5)
+        viewType = wx.Choice (parent=panel, id=wx.ID_ANY, size=(125, -1),
+                              choices = [_("top"),
+                                         _("north"),
+                                         _("south"),
+                                         _("east"),
+                                         _("west"),
+                                         _("north-west"),
+                                         _("north-east"),
+                                         _("south-east"),
+                                         _("south-west")])
+        viewType.SetSelection(0)
+        viewType.Bind(wx.EVT_CHOICE, self.OnLookAt)
+        # self.win['lookAt'] = viewType.GetId()
+        viewSizer.Add(item=viewType, flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL,
+                      border=5)
+        reset = wx.Button(panel, id=wx.ID_ANY, label=_("Reset"))
+        reset.SetToolTipString(_("Reset to default view"))
+        # self.win['reset'] = reset.GetId()
+        reset.Bind(wx.EVT_BUTTON, self.OnResetView)
+        viewSizer.Add(item=reset, proportion=1,
+                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT,
+                      border=5)
+        gridSizer.AddGrowableCol(3)
+        gridSizer.Add(item=viewSizer, pos=(4, 0), span=(1, 2),
+                      flag=wx.EXPAND)
+        # body
+        pageSizer.Add(item=gridSizer, proportion=1,
+                      border=5)
+        panel.SetSizer(pageSizer)
+    def __createSurfacePage(self):
+                              text=" %s " % _("Surface"))
+        self.win['surface'] = {}
+        # surface attributes
+        box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
+                            label=" %s " % (_("Surface attributes")))
+        boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        # labels
+        # col = 0
+        #         for type in (_("Attribute"),
+        #                      _("Use"),
+        #                      _("Map"),
+        #                      _("Constant")):
+        #             gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+        #                                              label=type),
+        #                           pos=(0, col))
+        #             col += 1
+        # type
+        self.win['surface']['attr'] = {}
+        row = 0
+        for code, attrb in (('topo', _("Topography")),
+                           ('color', _("Color")),
+                           ('mask', _("Mask")),
+                           ('transp', _("Transparency")),
+                           ('shine', _("Shininess")),
+                           ('emit', _("Emission"))):
+            self.win['surface'][code] = {}
+            gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                             label=attrb + ':'),
+                          pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+            use = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+                             choices = [_("map")])
+            if code not in ('topo', 'color', 'shine'):
+                use.Insert(item=_("unset"), pos=0)
+                self.win['surface'][code]['required'] = False
+            else:
+                self.win['surface'][code]['required'] = True
+            if code != 'mask':
+                use.Append(item=_('constant'))
+            self.win['surface'][code]['use'] = use.GetId()
+            use.Bind(wx.EVT_CHOICE, self.OnSurfaceUse)
+            gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
+                          pos=(row, 1))
+            map = gselect.Select(parent=panel, id=wx.ID_ANY,
+                                 # size=globalvar.DIALOG_GSELECT_SIZE,
+                                 size=(200, -1),
+                                 type="raster")
+            self.win['surface'][code]['map'] = map.GetId() - 1 # FIXME !
+            map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+            gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
+                          pos=(row, 2))
+            if code == 'color':
+                value = csel.ColourSelect(panel, id=wx.ID_ANY,
+                                          colour=UserSettings.Get(group='nviz', key='surface',
+        subkey=['color', 'value']))
+                value.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceMap)
+            elif code == 'mask':
+                value = None
+            else:
+                value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+                                    initial=0)
+                if code == 'topo':
+                    value.SetRange(minVal=-1e9, maxVal=1e9)
+                elif code in ('shine', 'transp', 'emit'):
+                    value.SetRange(minVal=0, maxVal=255)
+                else:
+                    value.SetRange(minVal=0, maxVal=100)
+                value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+            if value:
+                self.win['surface'][code]['const'] = value.GetId()
+                value.Enable(False)
+                gridSizer.Add(item=value, flag=wx.ALIGN_CENTER_VERTICAL,
+                              pos=(row, 3))
+            else:
+                self.win['surface'][code]['const'] = None
+            self.SetSurfaceUseMap(code) # -> enable map / disable constant
+            row += 1
+        boxSizer.Add(item=gridSizer, proportion=1,
+                  flag=wx.ALL | wx.EXPAND, border=3)
+        pageSizer.Add(item=boxSizer, proportion=0,
+                      border=5)
+        # draw
+        self.win['surface']['draw'] = {}
+                            label=" %s " % (_("Draw")))
+        gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+        gridSizer.AddGrowableCol(4)
+        # mode
+                                         label=_("Mode:")),
+                      pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+        mode = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+                          choices = [_("coarse"),
+                                     _("fine"),
+                                     _("both")])
+        mode.SetName("selection")
+        mode.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+        self.win['surface']['draw']['mode'] = mode.GetId()
+        gridSizer.Add(item=mode, flag=wx.ALIGN_CENTER_VERTICAL,
+                      pos=(0, 1))
+        # resolution (mode)
+                                         label=_("Resolution:")),
+                      pos=(0, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+        resSizer = wx.BoxSizer(wx.HORIZONTAL)
+        resSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                        label=_("coarse:")),
+                     flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=3)
+        resC = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+                           initial=1,
+                           min=1,
+                           max=100)
+        resC.SetName("value")
+        self.win['surface']['draw']['res-coarse'] = resC.GetId()
+        resC.Bind(wx.EVT_SPINCTRL, self.OnSurfaceResolution)
+        resSizer.Add(item=resC, flag=wx.ALL, border=3)
+                                        label=_("fine:")),
+        resF = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+                           initial=1,
+                           min=1,
+                           max=100)
+        resF.SetName("value")
+        self.win['surface']['draw']['res-fine'] = resF.GetId()
+        resF.Bind(wx.EVT_SPINCTRL, self.OnSurfaceResolution)
+        resSizer.Add(item=resF, flag=wx.ALL, border=3)
+        gridSizer.Add(item=resSizer, pos=(0, 3), span=(1, 2))
+        # style
+                                         label=_("Coarse style:")),
+                      pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+        style = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+                          choices = [_("wire"),
+                                     _("surface")])
+        style.SetName("selection")
+        self.win['surface']['draw']['style'] = style.GetId()
+        style.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+        gridSizer.Add(item=style, flag=wx.ALIGN_CENTER_VERTICAL,
+                      pos=(1, 1))
+        # shading
+                                         label=_("Shading:")),
+                      pos=(1, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+        shade = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+                           choices = [_("flat"),
+                                      _("gouraud")])
+        shade.SetName("selection")
+        self.win['surface']['draw']['shading'] = shade.GetId()
+        shade.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+        gridSizer.Add(item=shade, flag=wx.ALIGN_CENTER_VERTICAL,
+                      pos=(1, 3))
+        # color
+                                         label=_("Wire color:")),
+                      pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+        color = csel.ColourSelect(panel, id=wx.ID_ANY)
+        color.SetName("colour")
+        color.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceWireColor)
+        self.win['surface']['draw']['color'] = color.GetId()
+        gridSizer.Add(item=color, flag=wx.ALIGN_CENTER_VERTICAL,
+                      pos=(2, 1))
+                      flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
+                      border=5)
+        all = wx.Button(panel, id=wx.ID_ANY, label=_("All"))
+        all.SetToolTipString(_("Use for all loaded surfaces"))
+        # reset.Bind(wx.EVT_BUTTON, self.OnResetView)
+        gridSizer.Add(item=all, flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+                      pos=(2, 4))
+        # mask
+                            label=" %s " % (_("Mask")))
+                                         label=_("Mask zeros:")),
+        elev = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                           label=_("by elevation"))
+        gridSizer.Add(item=elev, pos=(0, 1))
+        color = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                           label=_("by color"))
+        gridSizer.Add(item=color, pos=(0, 2))
+                      border=5)
+        # position
+                            label=" %s " % (_("Position")))
+        # position
+                                         label="X:"),
+        x = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                        initial=0,
+                        min=0,
+                        max=100)
+        gridSizer.Add(item=x, pos=(0, 1))
+                                         label="X:"),
+        y = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                        initial=0,
+                        min=0,
+                        max=100)
+        gridSizer.Add(item=y, pos=(0, 3))
+                                         label="X:"),
+                      pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
+        z = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                        initial=0,
+                        min=0,
+                        max=100)
+        gridSizer.Add(item=z, pos=(0, 5))
+                      border=5)
+    def CreateControl(self, parent, name, sliderHor=True):
+        """Add control (Slider + SpinCtrl)"""
+        self.win['view'][name] = {}
+        if sliderHor:
+            style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
+                wx.SL_BOTTOM
+            size = (200, -1)
+        else:
+            style = wx.SL_VERTICAL | wx.SL_AUTOTICKS | \
+                wx.SL_BOTTOM | wx.SL_INVERSE
+            size = (-1, 200)
+        slider = wx.Slider(parent=parent, id=wx.ID_ANY,
+                           value=self.settings[name]['value'],
+                           minValue=self.settings[name]['min'],
+                           maxValue=self.settings[name]['max'],
+                           style=style,
+                           size=size)
+        slider.Bind(wx.EVT_SCROLL, self.OnChangeValue)
+        self.win['view'][name]['slider'] = slider.GetId()
+        spin = wx.SpinCtrl(parent=parent, id=wx.ID_ANY, size=(65, -1),
+                           initial=self.settings[name]['value'],
+                           min=self.settings[name]['min'],
+                           max=self.settings[name]['max'])
+        #         spin = wx.SpinButton(parent=parent, id=wx.ID_ANY)
+        #         spin.SetValue (self.settings[name]['value'])
+        #         spin.SetRange(self.settings[name]['min'],
+        #                      self.settings[name]['max'])
+        spin.Bind(wx.EVT_SPINCTRL, self.OnChangeValue)
+        self.win['view'][name]['spin'] = spin.GetId()
+    def UpdateSettings(self):
+        """Update dialog settings"""
+        for control in ('height',
+                        'persp',
+                        'twist',
+                        'z-exag'):
+            for win in self.win['view'][control].itervalues():
+                self.FindWindowById(win).SetValue(int(self.settings[control]['value']))
+        self.FindWindowById(self.win['view']['pos']).Draw()
+        self.FindWindowById(self.win['view']['pos']).Refresh(False)
+    def __GetWindowName(self, dict, id):
+        for name in dict.iterkeys():
+            if type(dict[name]) is type({}):
+                for win in dict[name].itervalues():
+                    if win == id:
+                        return name
+            else:
+                if dict[name] == id:
+                    return name
+        return None
+    def OnChangeValue(self, event):
+        # find control
+        winName = self.__GetWindowName(self.win['view'], event.GetId())
+        if not winName:
+            return
+        self.settings[winName]['value'] = event.GetInt()
+        for win in self.win['view'][winName].itervalues():
+            self.FindWindowById(win).SetValue(self.settings[winName]['value'])
+        if winName in ('pos', 'height', 'twist', 'persp'):
+            self.mapWindow.update['view'] = None
+        else:
+            self.mapWindow.update[winName] = None
+        self.mapWindow.Refresh(False)
+    def OnResetView(self, event):
+        """Reset to default view (view page)"""
+        self.mapWindow.ResetView()
+        self.UpdateSettings()
+    def OnLookAt(self, event):
+        """Look at (view page)"""
+        sel = event.GetSelection()
+        if sel == 0: # top
+            self.settings['pos']['x'] = 0.5
+            self.settings['pos']['y'] = 0.5
+        elif sel == 1: # north
+            self.settings['pos']['y'] = 0.0
+        elif sel == 2: # south
+            self.settings['pos']['y'] = 1.0
+        elif sel == 3: # east
+            self.settings['pos']['x'] = 1.0
+        elif sel == 4: # west
+            self.settings['pos']['x'] = 0.0
+        elif sel == 5: # north-west
+        elif sel == 6: # north-east
+        elif sel == 7: # south-east
+        elif sel == 8: # south-west
+    def OnSave(self, event):
+        """OK button pressed
+        Apply changes, update map and save settings of selected layer
+        # apply changes
+        self.OnApply(None)
+        # save settings
+        type = self.mapWindow.GetSelectedLayer().type
+        data = self.mapWindow.GetSelectedLayer(nviz=True)
+        if data is None: # no settings
+            data = {}
+        if type == 'raster': # -> surface
+            data['attribute'] = {}
+            for attrb in ('topo', 'color', 'mask',
+                         'transp', 'shine', 'emit'):
+                use = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
+                if self.win['surface'][attrb]['required']: # map, constant
+                    if use == 0: # map
+                        map = True
+                    elif use == 1: # constant
+                        map = False
+                else: # unset, map, constant
+                    if use == 0: # unset
+                        map = None
+                    elif use == 1: # map
+                        map = True
+                    elif use == 2: # constant
+                        map = False
+                if map is None:
+                    continue
+                if map:
+                    value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
+                else:
+                    if attrb == 'color':
+                        value = self.FindWindowById(self.win['surface'][attrb]['map']).GetColour()
+                    else:
+                        value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
+                data['attribute'][attrb] = {}
+                data['attribute'][attrb]['map'] = map
+                data['attribute'][attrb]['value'] = value
+            # draw
+            data['draw'] = {}
+            for control in ('mode', 'shading', 'style'):
+                data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetSelection()
+            for control in ('res-coarse', 'res-fine'):
+                data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetValue()
+        self.mapWindow.SetLayerSettings(data)
+    def OnApply(self, event):
+        """Apply button pressed
+        layer = self.mapWindow.GetSelectedLayer()
+        id = self.mapWindow.GetMapObjId(layer)
+        # surface
+            if self.mapWindow.update.has_key(attrb):
+                map, value = self.mapWindow.update[attrb]
+                if map is None: # unset
+                    # only optional attributes
+                    if attrb == 'mask':
+                        # TODO: invert mask
+                        # TODO: broken in NVIZ
+                        self.mapWindow.nvizClass.UnsetSurfaceMask(id)
+                    elif attrb == 'transp':
+                        self.mapWindow.nvizClass.UnsetSurfaceTransp(id)
+                    elif attrb == 'emit':
+                        self.mapWindow.nvizClass.UnsetSurfaceEmit(id)
+                else:
+                    if len(value) <= 0: # ignore empty values (TODO: warning)
+                        continue
+                    if attrb == 'topo':
+                        self.mapWindow.nvizClass.SetSurfaceTopo(id, map, str(value))
+                    elif attrb == 'color':
+                        self.mapWindow.nvizClass.SetSurfaceColor(id, map, str(value))
+                    elif attrb == 'mask':
+                        self.mapWindow.nvizClass.SetSurfaceMask(id, False, str(value))
+                        self.mapWindow.nvizClass.SetSurfaceTransp(id, map, str(value))
+                    elif attrb == 'shine':
+                        self.mapWindow.nvizClass.SetSurfaceShine(id, map, str(value))
+                        self.mapWindow.nvizClass.SetSurfaceEmit(id, map, str(value))
+                del self.mapWindow.update[attrb]
+        # draw mode
+        if self.mapWindow.update.has_key('draw-mode'):
+            self.mapWindow.nvizClass.SetDrawMode(self.mapWindow.update['draw-mode'])
+        # draw res
+        if self.mapWindow.update.has_key('draw-res'):
+            coarse, fine = self.mapWindow.update['draw-res']
+            self.mapWindow.nvizClass.SetSurfaceRes(id, fine, coarse)
+        # draw style
+        if self.mapWindow.update.has_key('draw-style'):
+            self.mapWindow.nvizClass.SetSurfaceStyle(id, self.mapWindow.update['draw-style'])
+        # wire color
+        if self.mapWindow.update.has_key('draw-color'):
+            self.mapWindow.nvizClass.SetWireColor(id, str(self.mapWindow.update['draw-color']))
+    def OnClose(self, event):
+        """Close button pressed
+        Close dialog
+        self.Hide()
+    def OnSurfaceUse(self, event):
+        """Surface attribute -- use -- map/constant"""
+        if not self.mapWindow.init:
+            return
+        # find attribute row
+        attrb = self.__GetWindowName(self.win['surface'], event.GetId())
+        if not attrb:
+            return
+        selection = event.GetSelection()
+        if self.win['surface'][attrb]['required']: # no 'unset'
+            selection += 1
+        if selection == 0: # unset
+            useMap = None
+            value = ''
+        elif selection == 1: # map
+            useMap = True
+        elif selection == 2: # constant
+            useMap = False
+                value = self.FindWindowById(self.win['surface'][attrb]['const']).GetColour()
+                value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
+            else:
+        self.SetSurfaceUseMap(attrb, useMap)
+        self.mapWindow.update[attrb] = (useMap, str(value))
+        if self.parent.autoRender.IsChecked():
+    def SetSurfaceUseMap(self, attrb, map=None):
+        if attrb in ('topo', 'color', 'shine'):
+            incSel = -1 # decrement selection (no 'unset')
+        else:
+            incSel = 0
+        if map is True: # map
+            self.FindWindowById(self.win['surface'][attrb]['map']).Enable(True)
+            if self.win['surface'][attrb]['const']:
+                self.FindWindowById(self.win['surface'][attrb]['const']).Enable(False)
+            self.FindWindowById(self.win['surface'][attrb]['use']).SetSelection(1 + incSel)
+        elif map is False: # const
+            self.FindWindowById(self.win['surface'][attrb]['map']).Enable(False)
+                self.FindWindowById(self.win['surface'][attrb]['const']).Enable(True)
+            self.FindWindowById(self.win['surface'][attrb]['use']).SetSelection(2 + incSel)
+        else: # unset
+            self.FindWindowById(self.win['surface'][attrb]['use']).SetSelection(0)
+    def OnSurfaceMap(self, event):
+        """Set surface attribute"""
+            return
+        if not attrb:
+            return
+        selection = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
+            map = None
+            value = ''
+            map = True
+        else: # constant
+            else:
+            map = False
+        self.mapWindow.update[attrb] = (map, str(value))
+    def OnSurfaceResolution(self, event):
+        """Draw resolution changed"""
+        coarse = self.FindWindowById(self.win['surface']['draw']['res-coarse']).GetValue()
+        fine = self.FindWindowById(self.win['surface']['draw']['res-fine']).GetValue()
+        self.mapWindow.update['draw-res'] = (coarse, fine)
+    def SetSurfaceMode(self):
+        """Set draw mode"""
+        value = 0
+        mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
+        if mode == 0: # coarse
+            value |= wxnviz.DM_WIRE
+            self.mapWindow.update['draw-mode'] = wxnviz.DRAW_COARSE
+            self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(True)
+            self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(False)
+        elif mode == 1: # fine
+            value |= wxnviz.DM_POLY
+            self.mapWindow.update['draw-mode'] = wxnviz.DRAW_FINE
+            self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(False)
+            self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(True)
+        else: # both
+            value |= wxnviz.DM_WIRE_POLY
+            self.mapWindow.update['draw-mode'] = wxnviz.DRAW_BOTH
+        style = self.FindWindowById(self.win['surface']['draw']['style']).GetSelection()
+        if style == 0: # wire
+            value |= wxnviz.DM_GRID_WIRE
+        else: # surface
+            value |= wxnviz.DM_GRID_SURF
+        shade = self.FindWindowById(self.win['surface']['draw']['shading']).GetSelection()
+        if shade == 0:
+            value |= wxnviz.DM_FLAT
+        else: # surface
+            value |= wxnviz.DM_GOURAUD
+        self.mapWindow.update['draw-style'] = value
+    def OnSurfaceMode(self, event):
+        self.SetSurfaceMode()
+    def SetSurfaceWireColor(self, color):
+        """Set wire color"""
+        value = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
+        self.mapWindow.update['draw-color'] = value
+    def OnSurfaceWireColor(self, event):
+        self.SetSurfaceWireColor(event.GetValue())
+    def UpdatePage(self, pageId):
+        """Update dialog (selected page)"""
+        if pageId == 'view':
+            max = self.settings['z-exag']['value'] * 10
+            for control in ('spin', 'slider'):
+                self.FindWindowById(self.win['view']['z-exag'][control]).SetRange(0,
+        max)
+        elif pageId == 'surface':
+            if data is None: # use default values
+                # attributes
+                for attr in ('topo', 'color'):
+                    self.SetSurfaceUseMap(attr, True) # -> map
+                    self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
+                if UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'map']) is False:
+                    self.SetSurfaceUseMap('shine', False)
+                    value = UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'value'])
+                    self.FindWindowById(self.win['surface']['shine']['const']).SetValue(value)
+                # draw
+                for control, value in UserSettings.Get(group='nviz', key='surface', subkey='draw').iteritems():
+                    win = self.FindWindowById(self.win['surface']['draw'][control])
+                    name = win.GetName()
+                    if name == "selection":
+                        win.SetSelection(value)
+                    elif name == "colour":
+                        win.SetColour(value)
+                    else:
+                        win.SetValue(value)
+                # enable/disable res widget + set draw mode
+                color = self.FindWindowById(self.win['surface']['draw']['color'])
+                self.SetSurfaceWireColor(color.GetColour())
+            elif layer.type == 'raster':
+                for attr in data['attr']:
+                    if attr['map']:
+                        win = self.FindWindowById(self.win['surface'][attr]['map'])
+                    else:
+                        win = self.FindWindowById(self.win['surface'][attr]['const'])
+                    win.SetValue(data['value'])
+class ViewPositionWindow(wx.Window):
+    """Position control window (for NvizToolWindow)"""
+    def __init__(self, parent, id, mapwindow,
+                 size=wx.DefaultSize, settings={}):
+        self.settings = settings
+        self.mapWindow = mapwindow
+        wx.Window.__init__(self, parent, id, pos, size)
+        self.SetBackgroundColour("WHITE")
+        self.pdc = wx.PseudoDC()
+        self.pdc.SetBrush(wx.Brush(colour='dark green', style=wx.SOLID))
+        self.pdc.SetPen(wx.Pen(colour='dark green', width=2, style=wx.SOLID))
+        self.Draw()
+        self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x: None)
+        self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouse)
+    def Draw(self, pos=None):
+        w, h = self.GetClientSize()
+        if pos is None:
+            x = self.settings['pos']['x']
+            y = self.settings['pos']['y']
+            x = x * w
+            y = y * h
+        else:
+            x, y = pos
+        self.pdc.Clear()
+        self.pdc.BeginDrawing()
+        self.pdc.DrawLine(w / 2, h / 2, x, y)
+        self.pdc.DrawCircle(x, y, 5)
+        self.pdc.EndDrawing()
+        dc = wx.BufferedPaintDC(self)
+        dc.SetBackground(wx.Brush("White"))
+        dc.Clear()
+        self.PrepareDC(dc)
+        self.pdc.DrawToDC(dc)
+    def OnMouse(self, event):
+        if event.LeftIsDown():
+            x, y = event.GetPosition()
+            self.Draw(pos=(x, y))
+            x = float(x) / w
+            y = float(y) / h
+            self.settings['pos']['x'] = x
+            self.settings['pos']['y'] = y
+            self.mapWindow.Refresh(eraseBackground=False)
+            # self.mapWindow.UpdateMap()
+            # self.mapWindow.OnPaint(None)
