[GRASS-SVN] r31946 - grass/trunk
Tue Jul 1 20:58:02 EDT 2008
Author: glynn
Date: 2008-07-01 20:58:01 -0400 (Tue, 01 Jul 2008)
New Revision: 31946
   grass/trunk/SUBMITTING
Add more detail on setting SVN properties
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING	2008-07-01 22:33:57 UTC (rev 31945)
+++ grass/trunk/SUBMITTING	2008-07-02 00:58:01 UTC (rev 31946)
@@ -388,7 +388,24 @@
     See
     http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
+    To set a property:
+      svn propset svn:keywords 'Author Date Id' <directory>
+    To edit the svn:ignore property using your default text editor:
+      svn propedit svn:ignore <directory>
+    To set the svn:ignore property non-interactively, first create a
+    file containing the value:
+      echo "*.tmp.html" > ignore.txt
+      echo "*OBJ*" >> ignore.txt
+    then use:
+      svn propset -F ignore.txt svn:ignore <directory>
 30. Use doxygen style for source code documentation. It is required
     for GRASS libraries, but also recommended for GRASS modules.
