[GRASS-SVN] r31996 - in grass/trunk/gui/wxpython: gui_modules vdigit
Sat Jul 5 00:37:34 EDT 2008
Author: martinl
Date: 2008-07-05 00:37:34 -0400 (Sat, 05 Jul 2008)
New Revision: 31996
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/vdigit.py
   grass/trunk/gui/wxpython/vdigit/digit.h
   grass/trunk/gui/wxpython/vdigit/driver.cpp
   grass/trunk/gui/wxpython/vdigit/driver.h
wxGUI/vdigit: visualize line directions implemented, trac #209
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-07-04 20:56:45 UTC (rev 31995)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-07-05 04:37:34 UTC (rev 31996)
@@ -125,6 +125,7 @@
                 'symbolNodeOne'     : { 'enabled' : True,  'color' : (255, 0, 0, 255) }, # red
                 'symbolNodeTwo'     : { 'enabled' : True,  'color' : (0, 86, 45, 255) }, # dark green
                 'symbolVertex'      : { 'enabled' : False, 'color' : (255, 20, 147, 255) }, # deep pink
+                'symbolDirection'   : { 'enabled' : False, 'color' : (255, 0, 0, 255) }, # red
                 # display
                 'lineWidth' : { 'value' : 2, 'units' : 'screen pixels' },
                 # snapping
@@ -327,7 +328,7 @@
         if self.filePath:
             self.__ReadFile(self.filePath, settings)
     def __ReadFile(self, filename, settings=None):
         """Read settings from file to dict"""
         if settings is None:
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py	2008-07-04 20:56:45 UTC (rev 31995)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py	2008-07-05 04:37:34 UTC (rev 31996)
@@ -1563,6 +1563,11 @@
                                                 UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
                                                 UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
                                                 255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolDirection', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolDirection', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolDirection', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolDirection', subkey='color')[2],
+                                                255).GetRGB(),
                                        UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
 class VDigitSettingsDialog(wx.Dialog):
@@ -1969,7 +1974,8 @@
             (_("Centroid (duplicate in area)"), "symbolCentroidDup"),
             (_("Node (one line)"), "symbolNodeOne"),
             (_("Node (two lines)"), "symbolNodeTwo"),
-            (_("Vertex"), "symbolVertex"))
+            (_("Vertex"), "symbolVertex"),
+            (_("Direction"), "symbolDirection"),)
     def OnChangeCategoryMode(self, event):
         """Change category mode"""
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h	2008-07-04 20:56:45 UTC (rev 31995)
+++ grass/trunk/gui/wxpython/vdigit/digit.h	2008-07-05 04:37:34 UTC (rev 31996)
@@ -1,5 +1,5 @@
-#ifndef __DIGIT_H__
-#define __DIGIT_H__
+#ifndef WXVDIGIT_DIGIT_H
+#define WXVDIGIT_DIGIT_H
 #define GSQL_MAX 4000
@@ -83,5 +83,5 @@
     int GetUndoLevel();
-#endif /* __DIGIT_H__ */
+#endif /* WXVDIGIT_DIGIT_H */
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp	2008-07-04 20:56:45 UTC (rev 31995)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp	2008-07-05 04:37:34 UTC (rev 31996)
@@ -6,16 +6,18 @@
    This driver is designed for wxPython GRASS GUI (digitization tool).
    Draw vector map layer to PseudoDC.
+   (C) by the GRASS Development Team
    This program is free software under the GNU General Public
    License (>=v2). Read the file COPYING that comes with GRASS
    for details.
-   \author (C) by the GRASS Development Team
-   Martin Landa <landa.martin gmail.com>
+   \author Martin Landa <landa.martin gmail.com>
    \date 2007-2008
+#include <cmath>
 #include "driver.h"
@@ -274,12 +276,18 @@
 	    else {
-		wxPoint points[pointsScreen->GetCount()];
+		wxPoint wxPoints[pointsScreen->GetCount()];
 		for (size_t i = 0; i < pointsScreen->GetCount(); i++) {
 		    wxPoint *point_beg = (wxPoint *) pointsScreen->Item(i)->GetData();
-		    points[i] = *point_beg;
+		    wxPoints[i] = *point_beg;
-		dc->DrawLines(pointsScreen->GetCount(), points);
+		dc->DrawLines(pointsScreen->GetCount(), wxPoints);
+		if (!IsSelected(line) && settings.direction.enabled) {
+		    DrawDirectionArrow();
+		    // restore pen
+		    dc->SetPen(*pen);
@@ -572,15 +580,33 @@
     *x = int((east  - w) / region.map_res);
     *y = int((n - north) / region.map_res);
-    *x = (east  - w) / region.map_res;
-    *y = (n - north) / region.map_res;
+    if (x)
+	*x = (east  - w) / region.map_res;
+    if (y)
+	*y = (n - north) / region.map_res;
+    if (z)
+	*z = 0.;
-    *z = 0;
     return;
+   \brief Calculate distance in pixels
+   \todo LL projection
+   \param dist real distance
+double DisplayDriver::DistanceInPixels(double dist)
+    double x;
+    Cell2Pixel(region.map_west + dist, region.map_north, 0.0, &x, NULL, NULL);
+    return std::sqrt(x * x);
    \brief Set geographical region
    Region must be upgraded because of Cell2Pixel().
@@ -661,6 +687,7 @@
 				   bool eNodeOne,     unsigned long cNodeOne,
 				   bool eNodeTwo,     unsigned long cNodeTwo,
 				   bool eVertex,      unsigned long cVertex,
+				   bool eDirection,   unsigned long cDirection,
 				   int lineWidth)
     settings.highlight.Set(highlight);
@@ -697,6 +724,9 @@
     settings.vertex.enabled = eVertex;
     settings.vertex.color.Set(cVertex);
+    settings.direction.enabled = eDirection;
+    settings.direction.color.Set(cDirection);
     settings.lineWidth = lineWidth;
@@ -1233,3 +1263,109 @@
     return;
+   \brief Draw line direction arrow
+   \return number of drawn arrows
+int DisplayDriver::DrawDirectionArrow()
+    int narrows;
+    int size; // arrow length in pixels
+    int limit; // segment length limit for drawing symbol (in pixels)
+    double dist, angle, pos;
+    double e, n, d, x0, y0, z0, x1, y1, z1;
+    struct line_pnts *points_seg;
+    wxPen *pen_arrow;
+    narrows = 0;
+    size = 5;
+    limit = 5; // 5px for line segment
+    points_seg = Vect_new_line_struct();
+    pen_arrow = new wxPen(settings.direction.color, settings.lineWidth, wxSOLID);
+    dc->SetPen(*pen_arrow);
+    dist = Vect_line_length(points);
+    if (DistanceInPixels(dist) >= limit) {
+	while (1) {
+	    pos = (narrows + 1) * 8 * limit * region.map_res;
+	    if (Vect_point_on_line(points, pos,
+				   &e, &n, &d, NULL, NULL) < 1) {
+		break;
+	    Cell2Pixel(e, n, d, &x0, &y0, &z0);
+	    if (Vect_point_on_line(points, pos - 3 * size * region.map_res,
+				   &e, &n, &d, &angle, NULL) < 1) {
+		break;
+	    Cell2Pixel(e, n, d, &x1, &y1, &z1);
+	    DrawArrow(x0, y0, x1, y1, angle, size);
+	    if(narrows > 1e2) // low resolution, break
+		break;
+	    narrows++;
+	// draw at least one arrow in the middle of line
+	if (narrows < 1) {
+	    dist /= 2.;
+	    if (Vect_point_on_line(points, dist,
+				   &e, &n, &d, NULL, NULL) > 0) {
+		if (Vect_point_on_line(points, dist - 3 * size * region.map_res,
+				       &e, &n, &d, &angle, NULL) > 0) {
+    Vect_destroy_line_struct(points_seg);
+    return narrows;
+   \brief Draw arrow symbol on line
+   \param x0,y0 arrow origin
+   \param x1,x1 arrow ending point (on line)
+   \param angle point ending point angle
+   \param size arrow size
+   \return 1
+int DisplayDriver::DrawArrow(double x0, double y0,
+			     double x1, double y1, double angle,
+			     int size)
+    double x, y;
+    double angle_symb;
+    angle_symb = angle - M_PI / 2.;
+    x = x1 + size * std::cos(angle_symb);
+    y = y1 - size * std::sin(angle_symb);
+    dc->DrawLine((wxCoord) x, (wxCoord) y, (wxCoord) x0, (wxCoord) y0);
+    angle_symb = M_PI / 2. + angle;
+    dc->DrawLine((wxCoord) x0, (wxCoord) y0, (wxCoord) x, (wxCoord) y);
+    return 1;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h	2008-07-04 20:56:45 UTC (rev 31995)
+++ grass/trunk/gui/wxpython/vdigit/driver.h	2008-07-05 04:37:34 UTC (rev 31996)
@@ -1,5 +1,5 @@
-#ifndef __DRIVER_H__
-#define __DRIVER_H__
+#ifndef WXVDIGIT_DRIVER_H
+#define WXVDIGIT_DRIVER_H
 #include <iostream> // debug
 #include <vector>
@@ -107,6 +107,8 @@
 	symbol vertex;
+	symbol direction;
 	int lineWidth;    // screen units
     } settings;
@@ -132,12 +134,16 @@
     void Cell2Pixel (double, double, double,
 		     double *, double *, double *);
+    double DistanceInPixels(double);
     int DrawCross(int, const wxPoint *, int size=5);
+    int DrawArrow(double, double, double, double, double,
+		   int);
     int DrawLine(int);
     int DrawLineVerteces(int);
     int DrawLineNodes(int);
+    int DrawDirectionArrow();
     /* debug */
     void PrintIds();
@@ -200,9 +206,10 @@
 			bool, unsigned long,
+			bool, unsigned long,
 			int);
 int print_error(const char *, int);
-#endif /* __DRIVER_H__ */
+#endif /* WXVDIGIT_DRIVER_H */
