[GRASS-SVN] r32020 - grass/trunk/gui/wxpython/gui_modules
Sun Jul 6 07:23:03 EDT 2008
Author: martinl
Date: 2008-07-06 07:23:03 -0400 (Sun, 06 Jul 2008)
New Revision: 32020
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
wxGUI: expand/collapse element list option added to GUI preferences, default is 'Collapse all except PERMANENT and current'
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-07-06 11:10:35 UTC (rev 32019)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-07-06 11:23:03 UTC (rev 32020)
@@ -211,8 +211,26 @@
                 continue
             if self.seltree.ItemHasChildren(dir_node):
-                self.seltree.Expand(dir_node)
+                sel = UserSettings.Get(group='general', key='elementListExpand',
+                                       subkey='selection')
+                collapse = True
+                if sel == 0: # collapse all expect PERMANENT and current
+                    if dir in ('PERMANENT', curr_mapset):
+                        collapse = False
+                elif sel == 1: # collapse all expect PERMANENT
+                    if dir == 'PERMANENT':
+                        collapse = False
+                elif sel == 2: # collapse all
+                    pass
+                elif sel == 3: # expand all
+                    collapse = False
+                if collapse:
+                    self.seltree.Collapse(dir_node)
+                else:
+                    self.seltree.Expand(dir_node)
     # helpers
     def FindItem(self, parentItem, text):
         item, cookie = self.seltree.GetFirstChild(parentItem)
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-07-06 11:10:35 UTC (rev 32019)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-07-06 11:23:03 UTC (rev 32020)
@@ -59,6 +59,8 @@
                 'mapsetPath'  : { 'selection' : 0 },
                 # use default window layout (layer manager, displays, ...)
                 'defWindowPos' : { 'enabled' : False, 'dim' : '' },
+                # expand/collapse element list
+                'elementListExpand' : { 'selection' : 0 },
             'manager' : {
                 # show opacity level widget
@@ -285,24 +287,28 @@
                 self.internalSettings[group][key] = {}
         self.internalSettings['general']["mapsetPath"]['value'] = self.GetMapsetPath()
-        self.internalSettings['general']['mapsetPath']['choices'] = [_('Mapset search path'),
-        _('All available mapsets')]
-        self.internalSettings['atm']['leftDbClick']['choices'] = [_('Edit selected record'),
-        _('Display selected')]
-        self.internalSettings['advanced']['settingsFile']['choices'] = ['home',
+        self.internalSettings['general']['mapsetPath']['choices'] = (_('Mapset search path'),
+        _('All available mapsets'))
+        self.internalSettings['general']['elementListExpand']['choices'] = (_("Collapse all except PERMANENT and current"),
+        _("Collapse all except PERMANENT"),
+        _("Collapse all"),
+        _("Expand all"))
+        self.internalSettings['atm']['leftDbClick']['choices'] = (_('Edit selected record'),
+        _('Display selected'))
+        self.internalSettings['advanced']['settingsFile']['choices'] = ('home',
        'gisdbase',
        'location',
-        'mapset']
-        self.internalSettings['advanced']['iconTheme']['choices'] = ['grass',
-        'silk']
-        self.internalSettings['advanced']['digitInterface']['choices'] = ['vedit',
-        'vdigit']
-        self.internalSettings['cmd']['verbosity']['choices'] = ['grassenv',
+        'mapset')
+        self.internalSettings['advanced']['iconTheme']['choices'] = ('grass',
+        'silk')
+        self.internalSettings['advanced']['digitInterface']['choices'] = ('vedit',
+        'vdigit')
+        self.internalSettings['cmd']['verbosity']['choices'] = ('grassenv',
        'verbose',
-        'quiet']
+        'quiet')
         self.internalSettings['display']['driver']['choices'] = ['default']
         self.internalSettings['display']['statusbarMode']['choices'] = globalvar.MAP_DISPLAY_STATUSBAR_MODE
     def GetMapsetPath(self):
         """Store mapset search path"""
         all, access = utils.ListOfMapsets()
@@ -638,7 +644,28 @@
                       wx.ALIGN_CENTER_VERTICAL,
                       pos=(row, 1))
+        # expand element list
+        row +=1
+        gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                         label=_("Element list:")),
+                      flag=wx.ALIGN_LEFT |
+                      wx.ALIGN_CENTER_VERTICAL,
+                      pos=(row, 0))
+        elementList = wx.Choice(parent=panel, id=wx.ID_ANY,
+                                choices=self.settings.Get(group='general', key='elementListExpand',
+                                                          subkey='choices', internal=True),
+                                name="GetSelection")
+        elementList.SetSelection(self.settings.Get(group='general', key='elementListExpand',
+                                                   subkey='selection'))
+        self.winId['general:elementListExpand:selection'] = elementList.GetId()
+        gridSizer.Add(item=elementList,
+                      flag=wx.ALIGN_RIGHT |
+                      pos=(row, 1))
         # default window layout
