[GRASS-SVN] r32030 - grass/trunk
Sun Jul 6 14:32:22 EDT 2008
Author: glynn
Date: 2008-07-06 14:32:21 -0400 (Sun, 06 Jul 2008)
New Revision: 32030
   grass/trunk/configure
   grass/trunk/configure.in
Set CFLAGS when linking test programs
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-07-06 18:06:51 UTC (rev 32029)
+++ grass/trunk/configure	2008-07-06 18:32:21 UTC (rev 32030)
@@ -7664,16 +7664,18 @@
   GDAL=
   ac_save_libs="$LIBS"
+  ac_save_cflags="$CFLAGS"
   LIBS="$LIBS $GDAL_LIBS"
+  CFLAGS="$CFLAGS $GDAL_CFLAGS"
   cat > conftest.$ac_ext <<EOF
-#line 7670 "configure"
+#line 7672 "configure"
 #include "confdefs.h"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7682,14 +7684,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7686 "configure"
+#line 7688 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7705,6 +7707,7 @@
 fi
 rm -f conftest*
   LIBS=${ac_save_libs}
+  CFLAGS=${ac_save_cflags}
@@ -7716,7 +7719,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7720: checking whether to use TIFF" >&5
+echo "configure:7723: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7736,7 +7739,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7740: checking for location of TIFF includes" >&5
+echo "configure:7743: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7762,15 +7765,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7766: checking for $ac_hdr" >&5
+echo "configure:7769: checking for $ac_hdr" >&5
-#line 7769 "configure"
+#line 7772 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7774: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7804,7 +7807,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7808: checking for location of TIFF library" >&5
+echo "configure:7811: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7835,13 +7838,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7839: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7842: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7845 "configure"
+#line 7848 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7852,7 +7855,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7871,13 +7874,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7875: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7878: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7881 "configure"
+#line 7884 "configure"
@@ -7888,7 +7891,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7907,13 +7910,13 @@
-echo "configure:7911: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7914: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7917 "configure"
+#line 7920 "configure"
@@ -7924,7 +7927,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7943,13 +7946,13 @@
-echo "configure:7947: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7950: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7953 "configure"
+#line 7956 "configure"
@@ -7960,7 +7963,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7979,13 +7982,13 @@
-echo "configure:7983: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7986: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7989 "configure"
+#line 7992 "configure"
@@ -7996,7 +7999,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8015,13 +8018,13 @@
-echo "configure:8019: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8022: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8025 "configure"
+#line 8028 "configure"
@@ -8032,7 +8035,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8051,13 +8054,13 @@
-echo "configure:8055: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8058: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8061 "configure"
+#line 8064 "configure"
@@ -8068,7 +8071,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8087,13 +8090,13 @@
-echo "configure:8091: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8094: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8097 "configure"
+#line 8100 "configure"
@@ -8104,7 +8107,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8202,7 +8205,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8206: checking whether to use PNG" >&5
+echo "configure:8209: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8221,7 +8224,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8225: checking for location of PNG includes" >&5
+echo "configure:8228: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8247,15 +8250,15 @@
 do
-echo "configure:8251: checking for $ac_hdr" >&5
+echo "configure:8254: checking for $ac_hdr" >&5
-#line 8254 "configure"
+#line 8257 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8289,7 +8292,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8293: checking for location of PNG library" >&5
+echo "configure:8296: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8314,13 +8317,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8318: checking for png_read_image in -lpng" >&5
+echo "configure:8321: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8324 "configure"
+#line 8327 "configure"
@@ -8331,7 +8334,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8373,7 +8376,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8377: checking whether to use Tcl/Tk" >&5
+echo "configure:8380: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8393,7 +8396,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8397: checking for location of Tcl/Tk includes" >&5
+echo "configure:8400: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8419,15 +8422,15 @@
 do
-echo "configure:8423: checking for $ac_hdr" >&5
+echo "configure:8426: checking for $ac_hdr" >&5
-#line 8426 "configure"
+#line 8429 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8464,15 +8467,15 @@
 do
-echo "configure:8468: checking for $ac_hdr" >&5
+echo "configure:8471: checking for $ac_hdr" >&5
-#line 8471 "configure"
+#line 8474 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8506,7 +8509,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8510: checking Tcl version" >&5
+echo "configure:8513: checking Tcl version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8514,7 +8517,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8518 "configure"
+#line 8521 "configure"
 #include <stdio.h>
@@ -8526,7 +8529,7 @@
 EOF
-if { (eval echo configure:8530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8544,7 +8547,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8548: checking Tk version" >&5
+echo "configure:8551: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8552,7 +8555,7 @@
 else
-#line 8556 "configure"
+#line 8559 "configure"
 #include <stdio.h>
@@ -8564,7 +8567,7 @@
 EOF
-if { (eval echo configure:8568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8593,7 +8596,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8597: checking for location of Tcl/Tk library" >&5
+echo "configure:8600: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8623,13 +8626,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8627: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8630: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8633 "configure"
+#line 8636 "configure"
@@ -8640,7 +8643,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8659,13 +8662,13 @@
-echo "configure:8663: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8666: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8669 "configure"
+#line 8672 "configure"
@@ -8676,7 +8679,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8703,13 +8706,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8707: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8710: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8713 "configure"
+#line 8716 "configure"
@@ -8720,7 +8723,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8739,13 +8742,13 @@
-echo "configure:8743: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8746: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8749 "configure"
+#line 8752 "configure"
@@ -8756,7 +8759,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8783,13 +8786,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8787: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8790: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8793 "configure"
+#line 8796 "configure"
@@ -8800,7 +8803,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8819,13 +8822,13 @@
-echo "configure:8823: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8826: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8829 "configure"
+#line 8832 "configure"
@@ -8836,7 +8839,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8914,13 +8917,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8918: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8921: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8924 "configure"
+#line 8927 "configure"
@@ -8931,7 +8934,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8950,13 +8953,13 @@
-echo "configure:8954: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8957: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8960 "configure"
+#line 8963 "configure"
@@ -8967,7 +8970,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8994,13 +8997,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8998: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9001: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9004 "configure"
+#line 9007 "configure"
@@ -9011,7 +9014,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9030,13 +9033,13 @@
-echo "configure:9034: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9037: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9040 "configure"
+#line 9043 "configure"
@@ -9047,7 +9050,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9074,13 +9077,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9078: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9081: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9084 "configure"
+#line 9087 "configure"
@@ -9091,7 +9094,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9110,13 +9113,13 @@
-echo "configure:9114: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9117: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9120 "configure"
+#line 9123 "configure"
@@ -9127,7 +9130,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9219,7 +9222,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9223: checking whether to use PostgreSQL" >&5
+echo "configure:9226: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9246,7 +9249,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9250: checking for location of PostgreSQL includes" >&5
+echo "configure:9253: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9272,15 +9275,15 @@
 do
-echo "configure:9276: checking for $ac_hdr" >&5
+echo "configure:9279: checking for $ac_hdr" >&5
-#line 9279 "configure"
+#line 9282 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9318,7 +9321,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9322: checking for location of PostgreSQL library" >&5
+echo "configure:9325: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9347,13 +9350,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9351: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9354: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9357 "configure"
+#line 9360 "configure"
@@ -9364,7 +9367,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9383,13 +9386,13 @@
-echo "configure:9387: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9390: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9393 "configure"
+#line 9396 "configure"
@@ -9400,7 +9403,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9419,13 +9422,13 @@
-echo "configure:9423: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9426: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9429 "configure"
+#line 9432 "configure"
@@ -9436,7 +9439,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9455,13 +9458,13 @@
-echo "configure:9459: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9462: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9465 "configure"
+#line 9468 "configure"
@@ -9472,7 +9475,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9529,13 +9532,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9533: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9536: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9539 "configure"
+#line 9542 "configure"
@@ -9546,7 +9549,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9568,13 +9571,13 @@
-echo "configure:9572: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9575: checking for PQcmdTuples in -lpq" >&5
-#line 9578 "configure"
+#line 9581 "configure"
@@ -9585,7 +9588,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9628,7 +9631,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9632: checking whether to use MySQL" >&5
+echo "configure:9635: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9648,7 +9651,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9652: checking for location of MySQL includes" >&5
+echo "configure:9655: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9674,15 +9677,15 @@
 do
-echo "configure:9678: checking for $ac_hdr" >&5
+echo "configure:9681: checking for $ac_hdr" >&5
-#line 9681 "configure"
+#line 9684 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9719,7 +9722,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9723: checking for location of MySQL library" >&5
+echo "configure:9726: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9750,13 +9753,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9754: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9757: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9760 "configure"
+#line 9763 "configure"
@@ -9767,7 +9770,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9786,13 +9789,13 @@
-echo "configure:9790: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9793: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9796 "configure"
+#line 9799 "configure"
@@ -9803,7 +9806,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9822,13 +9825,13 @@
-echo "configure:9826: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9829: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9832 "configure"
+#line 9835 "configure"
@@ -9839,7 +9842,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9858,13 +9861,13 @@
-echo "configure:9862: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9865: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9868 "configure"
+#line 9871 "configure"
@@ -9875,7 +9878,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9894,13 +9897,13 @@
-echo "configure:9898: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9901: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9904 "configure"
+#line 9907 "configure"
@@ -9911,7 +9914,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9930,13 +9933,13 @@
-echo "configure:9934: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9937: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9940 "configure"
+#line 9943 "configure"
@@ -9947,7 +9950,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9966,13 +9969,13 @@
-echo "configure:9970: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9973: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9976 "configure"
+#line 9979 "configure"
@@ -9983,7 +9986,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10002,13 +10005,13 @@
-echo "configure:10006: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10009: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10012 "configure"
+#line 10015 "configure"
@@ -10019,7 +10022,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10109,7 +10112,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10113: checking for $ac_word" >&5
+echo "configure:10116: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10150,10 +10153,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10154: checking for mysql_server_init" >&5
+echo "configure:10157: checking for mysql_server_init" >&5
-#line 10157 "configure"
+#line 10160 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10176,7 +10179,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10214,7 +10217,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10218: checking whether to use SQLite" >&5
+echo "configure:10221: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10234,7 +10237,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10238: checking for location of SQLite includes" >&5
+echo "configure:10241: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10260,15 +10263,15 @@
 do
-echo "configure:10264: checking for $ac_hdr" >&5
+echo "configure:10267: checking for $ac_hdr" >&5
-#line 10267 "configure"
+#line 10270 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10275: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10311,7 +10314,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10315: checking for location of SQLite library" >&5
+echo "configure:10318: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10338,13 +10341,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10342: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10345: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10348 "configure"
+#line 10351 "configure"
@@ -10355,7 +10358,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10374,13 +10377,13 @@
-echo "configure:10378: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10381: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10384 "configure"
+#line 10387 "configure"
@@ -10391,7 +10394,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10444,7 +10447,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10448: checking whether to use FFMPEG" >&5
+echo "configure:10451: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10464,7 +10467,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10468: checking for location of FFMPEG includes" >&5
+echo "configure:10471: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10490,15 +10493,15 @@
 do
-echo "configure:10494: checking for $ac_hdr" >&5
+echo "configure:10497: checking for $ac_hdr" >&5
-#line 10497 "configure"
+#line 10500 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10534,15 +10537,15 @@
 do
-echo "configure:10538: checking for $ac_hdr" >&5
+echo "configure:10541: checking for $ac_hdr" >&5
-#line 10541 "configure"
+#line 10544 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10546: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10578,15 +10581,15 @@
 do
-echo "configure:10582: checking for $ac_hdr" >&5
+echo "configure:10585: checking for $ac_hdr" >&5
-#line 10585 "configure"
+#line 10588 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10590: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10629,7 +10632,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10633: checking for location of FFMPEG library" >&5
+echo "configure:10636: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10656,13 +10659,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10660: checking for av_free in -lavutil" >&5
+echo "configure:10663: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10666 "configure"
+#line 10669 "configure"
@@ -10673,7 +10676,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10692,13 +10695,13 @@
-echo "configure:10696: checking for av_free in -lavutil" >&5
+echo "configure:10699: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10702 "configure"
+#line 10705 "configure"
@@ -10709,7 +10712,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10754,13 +10757,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10758: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10761: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10764 "configure"
+#line 10767 "configure"
@@ -10771,7 +10774,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10790,13 +10793,13 @@
-echo "configure:10794: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10797: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10800 "configure"
+#line 10803 "configure"
@@ -10807,7 +10810,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10852,13 +10855,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10856: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10859: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10862 "configure"
+#line 10865 "configure"
@@ -10869,7 +10872,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10888,13 +10891,13 @@
-echo "configure:10892: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10895: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10898 "configure"
+#line 10901 "configure"
@@ -10905,7 +10908,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10965,7 +10968,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10969: checking whether to use OpenGL" >&5
+echo "configure:10972: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10999,7 +11002,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11003: checking for location of OpenGL includes" >&5
+echo "configure:11006: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11025,15 +11028,15 @@
 do
-echo "configure:11029: checking for $ac_hdr" >&5
+echo "configure:11032: checking for $ac_hdr" >&5
-#line 11032 "configure"
+#line 11035 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11040: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11067,7 +11070,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11071: checking for location of OpenGL library" >&5
+echo "configure:11074: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11096,13 +11099,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11100: checking for glBegin in -lGL" >&5
+echo "configure:11103: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11106 "configure"
+#line 11109 "configure"
@@ -11113,7 +11116,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11132,13 +11135,13 @@
-echo "configure:11136: checking for glBegin in -lGL" >&5
+echo "configure:11139: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11142 "configure"
+#line 11145 "configure"
@@ -11149,7 +11152,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11168,13 +11171,13 @@
-echo "configure:11172: checking for glBegin in -lGL" >&5
+echo "configure:11175: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11178 "configure"
+#line 11181 "configure"
@@ -11185,7 +11188,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11204,13 +11207,13 @@
-echo "configure:11208: checking for glBegin in -lGL" >&5
+echo "configure:11211: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11214 "configure"
+#line 11217 "configure"
@@ -11221,7 +11224,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11283,13 +11286,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11287: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11290: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11293 "configure"
+#line 11296 "configure"
@@ -11300,7 +11303,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11319,13 +11322,13 @@
-echo "configure:11323: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11326: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11329 "configure"
+#line 11332 "configure"
@@ -11336,7 +11339,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11380,10 +11383,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11384: checking for glXCreatePbuffer" >&5
+echo "configure:11387: checking for glXCreatePbuffer" >&5
-#line 11387 "configure"
+#line 11390 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11406,7 +11409,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11428,10 +11431,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11432: checking for glXCreateGLXPixmap" >&5
+echo "configure:11435: checking for glXCreateGLXPixmap" >&5
-#line 11435 "configure"
+#line 11438 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11454,7 +11457,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11493,7 +11496,7 @@
-echo "configure:11497: checking for location of OpenGL includes" >&5
+echo "configure:11500: checking for location of OpenGL includes" >&5
@@ -11519,15 +11522,15 @@
 do
-echo "configure:11523: checking for $ac_hdr" >&5
+echo "configure:11526: checking for $ac_hdr" >&5
-#line 11526 "configure"
+#line 11529 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11562,10 +11565,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11566: checking for glBegin" >&5
+echo "configure:11569: checking for glBegin" >&5
-#line 11569 "configure"
+#line 11572 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11588,7 +11591,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11603,10 +11606,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11607: checking for gluBeginCurve" >&5
+echo "configure:11610: checking for gluBeginCurve" >&5
-#line 11610 "configure"
+#line 11613 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11629,7 +11632,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11675,7 +11678,7 @@
-echo "configure:11679: checking for location of OpenGL includes" >&5
+echo "configure:11682: checking for location of OpenGL includes" >&5
@@ -11701,15 +11704,15 @@
 do
-echo "configure:11705: checking for $ac_hdr" >&5
+echo "configure:11708: checking for $ac_hdr" >&5
-#line 11708 "configure"
+#line 11711 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11713: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11743,7 +11746,7 @@
-echo "configure:11747: checking for location of OpenGL library" >&5
+echo "configure:11750: checking for location of OpenGL library" >&5
@@ -11762,22 +11765,24 @@
 fi
+ac_save_cflags="$CFLAGS"
+CFLAGS="$CFLAGS $OPENGLINC"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11770: checking for OpenGL library" >&5
+echo "configure:11775: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11774 "configure"
+#line 11779 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11801,18 +11806,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11805: checking for GLU library" >&5
+echo "configure:11810: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11809 "configure"
+#line 11814 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11832,6 +11837,7 @@
 LDFLAGS=${ac_save_ldflags}
+CFLAGS=${ac_save_cflags}
 OPENGLLIB="$OPENGL_LIB_PATH $OPENGLLIB"
 OPENGLULIB="$OPENGL_LIB_PATH $OPENGLULIB"
@@ -11860,7 +11866,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11864: checking whether to use ODBC" >&5
+echo "configure:11870: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11879,7 +11885,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11883: checking for location of ODBC includes" >&5
+echo "configure:11889: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11905,15 +11911,15 @@
 do
-echo "configure:11909: checking for $ac_hdr" >&5
+echo "configure:11915: checking for $ac_hdr" >&5
-#line 11912 "configure"
+#line 11918 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11947,7 +11953,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11951: checking for location of ODBC library" >&5
+echo "configure:11957: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11972,13 +11978,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11976: checking for SQLConnect in -lodbc" >&5
+echo "configure:11982: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11982 "configure"
+#line 11988 "configure"
@@ -11989,7 +11995,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12014,13 +12020,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12018: checking for SQLConnect in -liodbc" >&5
+echo "configure:12024: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12024 "configure"
+#line 12030 "configure"
@@ -12031,7 +12037,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12050,15 +12056,17 @@
+CFLAGS="$CFLAGS $ODBCINC"
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12058: checking for ODBC library" >&5
+echo "configure:12066: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12062 "configure"
+#line 12070 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12066,7 +12074,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12086,6 +12094,7 @@
 fi
@@ -12114,7 +12123,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12118: checking whether to use FFTW" >&5
+echo "configure:12127: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12133,7 +12142,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12137: checking for location of FFTW includes" >&5
+echo "configure:12146: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12159,15 +12168,15 @@
 do
-echo "configure:12163: checking for $ac_hdr" >&5
+echo "configure:12172: checking for $ac_hdr" >&5
-#line 12166 "configure"
+#line 12175 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12180: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12195,15 +12204,15 @@
 do
-echo "configure:12199: checking for $ac_hdr" >&5
+echo "configure:12208: checking for $ac_hdr" >&5
-#line 12202 "configure"
+#line 12211 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12207: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12231,15 +12240,15 @@
 do
-echo "configure:12235: checking for $ac_hdr" >&5
+echo "configure:12244: checking for $ac_hdr" >&5
-#line 12238 "configure"
+#line 12247 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12285,7 +12294,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12289: checking for location of FFTW library" >&5
+echo "configure:12298: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12310,13 +12319,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12314: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12323: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12320 "configure"
+#line 12329 "configure"
@@ -12327,7 +12336,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12352,13 +12361,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12356: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12365: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12362 "configure"
+#line 12371 "configure"
@@ -12369,7 +12378,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12394,13 +12403,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12398: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12407: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12404 "configure"
+#line 12413 "configure"
@@ -12411,7 +12420,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12468,7 +12477,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12472: checking whether to use BLAS" >&5
+echo "configure:12481: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12489,7 +12498,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12493: checking for location of BLAS includes" >&5
+echo "configure:12502: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12509,7 +12518,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12513: checking for location of BLAS library" >&5
+echo "configure:12522: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12535,15 +12544,15 @@
 do
-echo "configure:12539: checking for $ac_hdr" >&5
+echo "configure:12548: checking for $ac_hdr" >&5
-#line 12542 "configure"
+#line 12551 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12547: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12578,13 +12587,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12582: checking for dnrm2_ in -lblas" >&5
+echo "configure:12591: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12588 "configure"
+#line 12597 "configure"
@@ -12595,7 +12604,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12614,13 +12623,13 @@
-echo "configure:12618: checking for dnrm2_ in -lblas" >&5
+echo "configure:12627: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12624 "configure"
+#line 12633 "configure"
 #include "confdefs.h"
@@ -12631,7 +12640,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12675,13 +12684,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12679: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12688: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12685 "configure"
+#line 12694 "configure"
@@ -12692,7 +12701,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12707,13 +12716,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12711: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12720: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12717 "configure"
+#line 12726 "configure"
@@ -12724,7 +12733,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12739,13 +12748,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12743: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12752: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12749 "configure"
+#line 12758 "configure"
@@ -12756,7 +12765,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12801,16 +12810,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12805: checking for sgemm in $vlib_flags" >&5
+echo "configure:12814: checking for sgemm in $vlib_flags" >&5
-#line 12807 "configure"
+#line 12816 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12828,13 +12837,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12832: checking for sgemm_ in -lblas" >&5
+echo "configure:12841: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 12838 "configure"
+#line 12847 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12845,7 +12854,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12860,13 +12869,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12864: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12873: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12870 "configure"
+#line 12879 "configure"
@@ -12877,7 +12886,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12892,13 +12901,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12896: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12905: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12902 "configure"
+#line 12911 "configure"
@@ -12909,7 +12918,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12943,13 +12952,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12947: checking for acosp in -lsunmath" >&5
+echo "configure:12956: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12953 "configure"
+#line 12962 "configure"
@@ -12960,7 +12969,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12975,13 +12984,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12979: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12988: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12985 "configure"
+#line 12994 "configure"
@@ -12992,7 +13001,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13022,13 +13031,13 @@
 # Generic BLAS library
-echo "configure:13026: checking for sgemm_ in -lblas" >&5
+echo "configure:13035: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13032 "configure"
+#line 13041 "configure"
@@ -13039,7 +13048,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13078,7 +13087,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13082: checking whether to use LAPACK" >&5
+echo "configure:13091: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13103,7 +13112,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13107: checking for location of LAPACK includes" >&5
+echo "configure:13116: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13123,7 +13132,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13127: checking for location of LAPACK library" >&5
+echo "configure:13136: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13149,15 +13158,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13153: checking for $ac_hdr" >&5
+echo "configure:13162: checking for $ac_hdr" >&5
-#line 13156 "configure"
+#line 13165 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13170: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13189,10 +13198,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13193: checking for dsegv_" >&5
+echo "configure:13202: checking for dsegv_" >&5
-#line 13196 "configure"
+#line 13205 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13215,7 +13224,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13242,13 +13251,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13246: checking for desgv_ in -llapack" >&5
+echo "configure:13255: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13252 "configure"
+#line 13261 "configure"
@@ -13259,7 +13268,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13291,13 +13300,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13295: checking for dgesv_ in -llapack" >&5
+echo "configure:13304: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13301 "configure"
+#line 13310 "configure"
@@ -13308,7 +13317,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13327,13 +13336,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:13331: checking for dgesv_ in -llapack" >&5
+echo "configure:13340: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13337 "configure"
+#line 13346 "configure"
@@ -13344,7 +13353,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13400,7 +13409,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13404: checking whether to use Motif" >&5
+echo "configure:13413: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13419,7 +13428,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13423: checking for location of Motif includes" >&5
+echo "configure:13432: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13445,15 +13454,15 @@
 do
-echo "configure:13449: checking for $ac_hdr" >&5
+echo "configure:13458: checking for $ac_hdr" >&5
-#line 13452 "configure"
+#line 13461 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13466: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13487,7 +13496,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13491: checking for location of Motif library" >&5
+echo "configure:13500: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13512,13 +13521,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13516: checking for XmStringCreate in -lXm" >&5
+echo "configure:13525: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13522 "configure"
+#line 13531 "configure"
@@ -13529,7 +13538,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13570,7 +13579,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13574: checking whether to use Cairo" >&5
+echo "configure:13583: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13596,15 +13605,15 @@
 do
-echo "configure:13600: checking for $ac_hdr" >&5
+echo "configure:13609: checking for $ac_hdr" >&5
-#line 13603 "configure"
+#line 13612 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13641,10 +13650,10 @@
 LDFLAGS="$LDFLAGS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13645: checking for cairo_create" >&5
+echo "configure:13654: checking for cairo_create" >&5
-#line 13648 "configure"
+#line 13657 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13667,7 +13676,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13702,7 +13711,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13706: checking whether to use GLw" >&5
+echo "configure:13715: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13721,7 +13730,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13725: checking for location of GLw includes" >&5
+echo "configure:13734: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13747,15 +13756,15 @@
 do
-echo "configure:13751: checking for $ac_hdr" >&5
+echo "configure:13760: checking for $ac_hdr" >&5
-#line 13754 "configure"
+#line 13763 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13783,15 +13792,15 @@
 do
-echo "configure:13787: checking for $ac_hdr" >&5
+echo "configure:13796: checking for $ac_hdr" >&5
-#line 13790 "configure"
+#line 13799 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13831,7 +13840,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13835: checking for location of GLw library" >&5
+echo "configure:13844: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13856,13 +13865,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13860: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13869: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13866 "configure"
+#line 13875 "configure"
@@ -13873,7 +13882,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13898,13 +13907,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13902: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13911: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13908 "configure"
+#line 13917 "configure"
@@ -13915,7 +13924,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13940,13 +13949,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13944: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13953: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13950 "configure"
+#line 13959 "configure"
@@ -13957,7 +13966,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13982,13 +13991,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13986: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13995: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13992 "configure"
+#line 14001 "configure"
@@ -13999,7 +14008,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14024,13 +14033,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14028: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14037: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14034 "configure"
+#line 14043 "configure"
@@ -14041,7 +14050,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14066,13 +14075,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14070: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14079: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14076 "configure"
+#line 14085 "configure"
@@ -14083,7 +14092,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14110,13 +14119,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14114: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14123: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14120 "configure"
+#line 14129 "configure"
@@ -14127,7 +14136,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14146,13 +14155,13 @@
-echo "configure:14150: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14159: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14156 "configure"
+#line 14165 "configure"
@@ -14163,7 +14172,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14190,13 +14199,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14194: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14203: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14200 "configure"
+#line 14209 "configure"
@@ -14207,7 +14216,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14226,13 +14235,13 @@
-echo "configure:14230: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14239: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14236 "configure"
+#line 14245 "configure"
@@ -14243,7 +14252,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14356,7 +14365,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14360: checking whether to use FreeType" >&5
+echo "configure:14369: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14375,7 +14384,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14379: checking for location of FreeType includes" >&5
+echo "configure:14388: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14401,15 +14410,15 @@
 do
-echo "configure:14405: checking for $ac_hdr" >&5
+echo "configure:14414: checking for $ac_hdr" >&5
-#line 14408 "configure"
+#line 14417 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14443,7 +14452,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14447: checking for location of FreeType library" >&5
+echo "configure:14456: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14468,13 +14477,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14472: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14481: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14478 "configure"
+#line 14487 "configure"
@@ -14485,7 +14494,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14526,7 +14535,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14530: checking whether to use NLS" >&5
+echo "configure:14539: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14546,10 +14555,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14550: checking for gettext" >&5
+echo "configure:14559: checking for gettext" >&5
-#line 14553 "configure"
+#line 14562 "configure"
     which can conflict with char gettext(); below.  */
@@ -14572,7 +14581,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14590,13 +14599,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14594: checking for gettext in -lintl" >&5
+echo "configure:14603: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14600 "configure"
+#line 14609 "configure"
@@ -14607,7 +14616,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14642,7 +14651,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14646: checking whether to use C++" >&5
+echo "configure:14655: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14658,7 +14667,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:14662: checking for $ac_word" >&5
+echo "configure:14671: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14687,7 +14696,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14691: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14700: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14698,12 +14707,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14702 "configure"
+#line 14711 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14729,19 +14738,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14733: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14742: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14738: checking whether we are using GNU C++" >&5
+echo "configure:14747: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14745: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14759,7 +14768,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14763: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14772: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14800,7 +14809,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14804: checking whether to use openDWG" >&5
+echo "configure:14813: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14820,7 +14829,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14824: checking for location of openDGW includes" >&5
+echo "configure:14833: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14846,15 +14855,15 @@
 do
-echo "configure:14850: checking for $ac_hdr" >&5
+echo "configure:14859: checking for $ac_hdr" >&5
-#line 14853 "configure"
+#line 14862 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14888,7 +14897,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14892: checking for location of openDWG library" >&5
+echo "configure:14901: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14935,7 +14944,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14939: checking for special C compiler options needed for large files" >&5
+echo "configure:14948: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14943,7 +14952,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14947 "configure"
+#line 14956 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14959,7 +14968,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14972: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14968,7 +14977,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14972 "configure"
+#line 14981 "configure"
@@ -14984,7 +14993,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14988: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15004,11 +15013,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15008: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15017: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15012 "configure"
+#line 15021 "configure"
@@ -15024,14 +15033,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15028: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15035 "configure"
+#line 15044 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15049,7 +15058,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15068,11 +15077,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15072: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15081: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15076 "configure"
+#line 15085 "configure"
@@ -15088,14 +15097,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15092: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15099 "configure"
+#line 15108 "configure"
 #define _LARGE_FILES 1
@@ -15113,7 +15122,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15117: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15132,25 +15141,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15136: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15145: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15140 "configure"
+#line 15149 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15154 "configure"
+#line 15163 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15159,7 +15168,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15163: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15180,10 +15189,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15184: checking if system supports Large Files at all" >&5
+echo "configure:15193: checking if system supports Large Files at all" >&5
-#line 15187 "configure"
+#line 15196 "configure"
 #include <stdio.h>
@@ -15215,7 +15224,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15219: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15228: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15244,7 +15253,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15248: checking whether to use Python" >&5
+echo "configure:15257: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15264,7 +15273,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15268: checking for $ac_word" >&5
+echo "configure:15277: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15309,15 +15318,15 @@
 do
-echo "configure:15313: checking for $ac_hdr" >&5
+echo "configure:15322: checking for $ac_hdr" >&5
-#line 15316 "configure"
+#line 15325 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15357,7 +15366,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15361: checking for $ac_word" >&5
+echo "configure:15370: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15403,7 +15412,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15407: checking whether to use wxWidgets" >&5
+echo "configure:15416: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15423,7 +15432,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15427: checking for $ac_word" >&5
+echo "configure:15436: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15471,7 +15480,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15475: checking wxWidgets version" >&5
+echo "configure:15484: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15494,15 +15503,15 @@
 do
-echo "configure:15498: checking for $ac_hdr" >&5
+echo "configure:15507: checking for $ac_hdr" >&5
-#line 15501 "configure"
+#line 15510 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15506: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15515: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15538,15 +15547,15 @@
 do
-echo "configure:15542: checking for $ac_hdr" >&5
+echo "configure:15551: checking for $ac_hdr" >&5
-#line 15545 "configure"
+#line 15554 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15550: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-07-06 18:06:51 UTC (rev 32029)
+++ grass/trunk/configure.in	2008-07-06 18:32:21 UTC (rev 32030)
@@ -707,7 +707,9 @@
   GDAL=
   ac_save_libs="$LIBS"
+  ac_save_cflags="$CFLAGS"
   LIBS="$LIBS $GDAL_LIBS"
+  CFLAGS="$CFLAGS $GDAL_CFLAGS"
   AC_TRY_LINK([#include <gdal.h>],[GDALOpen("foo", GA_ReadOnly);],,[
   LIBS="$LIBS $GDAL_DEP_LIBS"
   AC_TRY_LINK([#include <gdal.h>],[GDALOpen("foo", GA_ReadOnly);],GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS",[
@@ -715,6 +717,7 @@
   LIBS=${ac_save_libs}
+  CFLAGS=${ac_save_cflags}
   AC_SUBST(GDAL_LIBS)
   AC_SUBST(GDAL_CFLAGS)
@@ -1142,8 +1145,11 @@
 LOC_CHECK_LIB_PATH(opengl,OpenGL,OPENGL_LIB_PATH)
 LOC_CHECK_LINK(opengl32,[#include <GL/gl.h>],[glEnd();],OpenGL,$OPENGL_LIB_PATH,OPENGLLIB)
 LOC_CHECK_LINK(glu32,[#include <GL/glu.h>],[gluNewQuadric();],GLU,$OPENGL_LIB_PATH,OPENGLULIB,$OPENGLLIB)
@@ -1186,8 +1192,11 @@
 LOC_CHECK_LIBS(odbc,SQLConnect,ODBC,$ODBCLIB,ODBCLIB,$ICONVLIB,,[
 LOC_CHECK_LIBS(iodbc,SQLConnect,ODBC,$ODBCLIB,ODBCLIB,,,[
 LOC_CHECK_LINK(odbc32,[#include <windows.h>
 #include <sql.h>],[SQLAllocEnv((SQLHENV *)0);],ODBC,$ODBCLIB,ODBCLIB)
