[GRASS-SVN] r32032 - grass/trunk/lib/nviz
Sun Jul 6 16:25:12 EDT 2008
Author: martinl
Date: 2008-07-06 16:25:12 -0400 (Sun, 06 Jul 2008)
New Revision: 32032
   grass/trunk/lib/nviz/Makefile
   grass/trunk/lib/nviz/draw.c
Makefile of nvizlib updated (based on ogsf Makefile)
Modified: grass/trunk/lib/nviz/Makefile
--- grass/trunk/lib/nviz/Makefile	2008-07-06 18:51:27 UTC (rev 32031)
+++ grass/trunk/lib/nviz/Makefile	2008-07-06 20:25:12 UTC (rev 32032)
@@ -2,18 +2,16 @@
 LIB_NAME = $(NVIZ_LIBNAME)
-DEPENDENCIES = $(BITMAPDEP) $(DBMIDEP) $(GISDEP) $(OGSFDEP) $(G3DDEP) $(VECTRDEP)
+EXTRA_LIBS = $(GISLIB) $(BITMAPLIB) $(VECTLIB) $(XLIBPATH) $(OPENGLLIB) $(OPENGLULIB) $(TIFFLIBPATH) $(TIFFLIB) $(FFMPEGLIBPATH) $(FFMPEGLIB) $(SITESLIB) $(G3DLIB)
-EXTRA_INC = $(VECT_INC)
-EXTRA_CFLAGS = $(INC) \
-	$(TIFFINCPATH) $(DSPINC) \
-	$(VECT_CFLAGS) $(OPENGLINC)
-EXTRA_LIBS = $(GISLIB) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB)
 include $(MODULE_TOPDIR)/include/Make/Lib.make
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
-# doxygen
-DOXNAME=nviz
+EXTRA_INC = $(VECT_INC) $(OPENGLINC) $(TIFFINCPATH) $(FFMPEGINCPATH)
+EXTRA_CFLAGS = $(VECT_CFLAGS) $(XCFLAGS)
 default: lib
+# doxygen
+DOXNAME=nviz
Modified: grass/trunk/lib/nviz/draw.c
--- grass/trunk/lib/nviz/draw.c	2008-07-06 18:51:27 UTC (rev 32031)
+++ grass/trunk/lib/nviz/draw.c	2008-07-06 20:25:12 UTC (rev 32032)
@@ -20,7 +20,6 @@
 #include <grass/nviz.h>
 static int sort_surfs_max(int *, int *, int *, int);
-static int check_blank(int);
   \brief Draw all loaded surfaces
@@ -56,9 +55,7 @@
     GS_setlight_position(num, 0., 0., 1., 0);
     for (i = 0; i < nsurfs; i++) {
-	if (!check_blank(sortSurfs[i])) {
-	    GS_draw_surf(sortSurfs[i]);
+	GS_draw_surf(sortSurfs[i]);
     /* GS_draw_cplane_fence params will change - surfs aren't used anymore */
@@ -115,30 +112,39 @@
     return 1;
-  \brief Check if a specific map object should be blanked for
-  a draw.
+  \brief Draw all loaded vector sets
-  This option is used by one of the script tools for
-  blanking maps during specific frames.
-  \param map_id map object id
-  \return 0 not blank
-  \return 1 blank
+  \param dc nviz data
+  \return 1
-int check_blank(int map_id)
+int Nviz_draw_all_vect(nv_data *dc)
-    return 0;
+    // GS_set_cancel(0);
+    /* in case transparency is set */
+    GS_set_draw(GSD_BOTH);
+    GS_ready_draw();
+    GV_alldraw_vect();
+    GS_done_draw();
+    GS_set_draw(GSD_BACK);
+    return 1;
-  \brief Draw all
+  \brief Draw all map objects (in full resolution) and decorations
   \param data nviz data
-  \param clear clear screen before drawing
-int Nviz_draw_all(nv_data *data, int clear)
+int Nviz_draw_all(nv_data *data)
     int draw_surf, draw_vect, draw_site, draw_vol;
     int draw_north_arrow, arrow_x, draw_label, draw_legend;
@@ -166,10 +172,11 @@
     // Tcl_SetVar(interp, "is_drawing", "1", TCL_GLOBAL_ONLY);
     GS_set_draw(GSD_BACK); /* needs to be BACK to avoid flickering */
-    if (clear)
-	GS_clear(data->bgcolor);
     GS_ready_draw();
+    GS_clear(data->bgcolor);
     buf_surf     = Tcl_GetVar(interp, "surface", TCL_GLOBAL_ONLY);
     buf_vect     = Tcl_GetVar(interp, "vector", TCL_GLOBAL_ONLY);
@@ -302,23 +309,27 @@
-  \brief Draw in coarse mode
+  \brief Draw all surfaces in wireframe
   \param dc nviz data
   \return 1
-int Nviz_draw_quick(nv_data *dc, int clear)
+int Nviz_draw_quick(nv_data *data)
-    if (clear)
-	GS_clear(dc->bgcolor);
     GS_ready_draw();
+    /* draw surfaces */
     GS_alldraw_wire();
+    /* draw vector */
+    /* GV_alldraw_fastvect(); is broken */
+    /* GV_alldraw_vect(); */
     vol_list = GVL_get_vol_list(&max);
     max = GVL_num_vols();
@@ -336,39 +347,3 @@
     return 1;
-  \brief Draw all loaded vector sets
-  \param dc nviz data
-  \return 1
-int Nviz_draw_all_vect(nv_data *dc)
-    int i, nvects;
-    int *vect_list;
-    // GS_set_cancel(0);
-    vect_list = GV_get_vect_list(&nvects);
-    /* in case transparency is set */
-    GS_set_draw(GSD_BOTH);
-    GS_ready_draw();
-    for (i = 0; i < nvects; i++) {
-	if (!check_blank(vect_list[i])) {
-	    GV_draw_vect(vect_list[i]);
-    G_free (vect_list);
-    GS_done_draw();
-    GS_set_draw(GSD_BACK);
-    return 1;
