[GRASS-SVN] r32048 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Tue Jul 8 09:07:10 EDT 2008
Author: martinl
Date: 2008-07-08 09:07:10 -0400 (Tue, 08 Jul 2008)
New Revision: 32048
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI: fix r32002, enable button OnResult? (merged from trunk r32047)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2008-07-08 13:05:13 UTC (rev 32047)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2008-07-08 13:07:10 UTC (rev 32048)
@@ -329,7 +329,17 @@
             if hasattr(self.parent.parent, "btn_abort"):
                 dialog.btn_abort.Enable(False)
+            if hasattr(self.parent.parent, "btn_cancel"):
+                dialog.btn_cancel.Enable(True)
+            if hasattr(self.parent.parent, "btn_clipboard"):
+                dialog.btn_clipboard.Enable(True)
+            if hasattr(self.parent.parent, "btn_help"):
+                dialog.btn_help.Enable(True)
             dialog.btn_run.Enable(True)
             if dialog.get_dcmd is None and \
                    dialog.closebox.IsChecked():
                 time.sleep(1)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-07-08 13:05:13 UTC (rev 32047)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-07-08 13:07:10 UTC (rev 32048)
@@ -812,13 +812,6 @@
         except IndexError:
             pass
-        for btn in (self.btn_run,
-                    self.btn_cancel,
-                    self.btn_clipboard,
-                    self.btn_help):
-            btn.Enable(True)
-        self.btn_abort.Enable(False)
     def OnCopy(self, event):
         """Copy the command"""
         cmddata = wx.TextDataObject()
